[PATCH v1 0/2] spi: stm32_qspi: flags management fixes
This series update flags management in the following cases: - Always check TCF flag in stm32_qspi_wait_cmd() - Don't check BUSY flag when sending new command
Patrice Chotard (2): spi: stm32_qspi: Always check SR_TCF flags in stm32_qspi_wait_cmd() spi: stm32_qspi: Remove SR_BUSY bit check before sending command
drivers/spi/stm32_qspi.c | 27 +++++++++++---------------- 1 file changed, 11 insertions(+), 16 deletions(-)
Currently, SR_TCF flag is checked in case there is data, this criteria is not correct.
SR_TCF flags is set when programmed number of bytes have been transferred to the memory device ("bytes" comprised command and data send to the SPI device). So even if there is no data, we must check SR_TCF flag.
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com ---
drivers/spi/stm32_qspi.c | 23 +++++++++++------------ 1 file changed, 11 insertions(+), 12 deletions(-)
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 8f4aabc3d1..3c8faecb54 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -150,20 +150,19 @@ static int _stm32_qspi_wait_cmd(struct stm32_qspi_priv *priv, u32 sr; int ret = 0;
- if (op->data.nbytes) { - ret = readl_poll_timeout(&priv->regs->sr, sr, - sr & STM32_QSPI_SR_TCF, - STM32_QSPI_CMD_TIMEOUT_US); - if (ret) { - log_err("cmd timeout (stat:%#x)\n", sr); - } else if (readl(&priv->regs->sr) & STM32_QSPI_SR_TEF) { - log_err("transfer error (stat:%#x)\n", sr); - ret = -EIO; - } - /* clear flags */ - writel(STM32_QSPI_FCR_CTCF | STM32_QSPI_FCR_CTEF, &priv->regs->fcr); + ret = readl_poll_timeout(&priv->regs->sr, sr, + sr & STM32_QSPI_SR_TCF, + STM32_QSPI_CMD_TIMEOUT_US); + if (ret) { + log_err("cmd timeout (stat:%#x)\n", sr); + } else if (readl(&priv->regs->sr) & STM32_QSPI_SR_TEF) { + log_err("transfer error (stat:%#x)\n", sr); + ret = -EIO; }
+ /* clear flags */ + writel(STM32_QSPI_FCR_CTCF | STM32_QSPI_FCR_CTEF, &priv->regs->fcr); + if (!ret) ret = _stm32_qspi_wait_for_not_busy(priv);
Hi Patrice,
if (ret) {
ret = -EIO;
/* clear flags */
if (ret) {
ret = -EIO;
/* clear flags */
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
On 5/17/22 10:23, Patrick DELAUNAY wrote:
Hi Patrice,
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 8f4aabc3d1..3c8faecb54 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -150,20 +150,19 @@ static int _stm32_qspi_wait_cmd(struct stm32_qspi_priv *priv, u32 sr; int ret = 0; - if (op->data.nbytes) { - ret = readl_poll_timeout(&priv->regs->sr, sr, - sr & STM32_QSPI_SR_TCF, - STM32_QSPI_CMD_TIMEOUT_US); - if (ret) { - log_err("cmd timeout (stat:%#x)\n", sr); - } else if (readl(&priv->regs->sr) & STM32_QSPI_SR_TEF) { - log_err("transfer error (stat:%#x)\n", sr); - ret = -EIO; - } - /* clear flags */ - writel(STM32_QSPI_FCR_CTCF | STM32_QSPI_FCR_CTEF, &priv->regs->fcr); + ret = readl_poll_timeout(&priv->regs->sr, sr, + sr & STM32_QSPI_SR_TCF, + STM32_QSPI_CMD_TIMEOUT_US); + if (ret) { + log_err("cmd timeout (stat:%#x)\n", sr); + } else if (readl(&priv->regs->sr) & STM32_QSPI_SR_TEF) { + log_err("transfer error (stat:%#x)\n", sr); + ret = -EIO; } + /* clear flags */ + writel(STM32_QSPI_FCR_CTCF | STM32_QSPI_FCR_CTEF, &priv->regs->fcr);
Thanks Patrick
Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Applied to u-boot-stm/master, thanks!
Regards Patrick
Waiting for SR_BUSY bit when receiving a new command is not needed. SR_BUSY bit is already managed in the previous command treatment.
drivers/spi/stm32_qspi.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 3c8faecb54..ceba413727 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -255,10 +255,6 @@ static int stm32_qspi_exec_op(struct spi_slave *slave, op->dummy.buswidth, op->data.buswidth, op->addr.val, op->data.nbytes);
- ret = _stm32_qspi_wait_for_not_busy(priv); - if (ret) - return ret; - addr_max = op->addr.val + op->data.nbytes + 1;
if (op->data.dir == SPI_MEM_DATA_IN && op->data.nbytes) {
Hi Patrice
if (ret)
return ret;
Thanks Patrick
On 5/17/22 10:24, Patrick DELAUNAY wrote:
Hi Patrice
diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 3c8faecb54..ceba413727 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -255,10 +255,6 @@ static int stm32_qspi_exec_op(struct spi_slave *slave, op->dummy.buswidth, op->data.buswidth, op->addr.val, op->data.nbytes); - ret = _stm32_qspi_wait_for_not_busy(priv); - if (ret) - return ret;
addr_max = op->addr.val + op->data.nbytes + 1; if (op->data.dir == SPI_MEM_DATA_IN && op->data.nbytes) {
Thanks Patrick
Regards Patrick
Patrice Chotard
Patrick DELAUNAY
