[U-Boot] [PATCH 1/3] arm: mvebu: Consolidate board Kconfig options into one file
Merging all the board specific Kconfig options into the main Kconfig file for mach-mvebu makes things easier to maintain.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/Kconfig | 4 ---- arch/arm/mach-mvebu/Kconfig | 17 +++++++++++++++++ board/Marvell/db-88f6820-gp/Kconfig | 12 ------------ board/Marvell/db-mv784mp-gp/Kconfig | 12 ------------ board/maxbcm/Kconfig | 9 --------- board/solidrun/clearfog/Kconfig | 12 ------------ 6 files changed, 17 insertions(+), 49 deletions(-) delete mode 100644 board/Marvell/db-88f6820-gp/Kconfig delete mode 100644 board/Marvell/db-mv784mp-gp/Kconfig delete mode 100644 board/maxbcm/Kconfig delete mode 100644 board/solidrun/clearfog/Kconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index c246a49..b878623 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -774,8 +774,6 @@ source "board/BuR/kwb/Kconfig" source "board/BuR/tseries/Kconfig" source "board/CarMediaLab/flea3/Kconfig" source "board/Marvell/aspenite/Kconfig" -source "board/Marvell/db-88f6820-gp/Kconfig" -source "board/Marvell/db-mv784mp-gp/Kconfig" source "board/Marvell/gplugd/Kconfig" source "board/armadeus/apf27/Kconfig" source "board/armltd/vexpress/Kconfig" @@ -814,7 +812,6 @@ source "board/h2200/Kconfig" source "board/hisilicon/hikey/Kconfig" source "board/imx31_phycore/Kconfig" source "board/isee/igep0033/Kconfig" -source "board/maxbcm/Kconfig" source "board/mpl/vcma9/Kconfig" source "board/olimex/mx23_olinuxino/Kconfig" source "board/phytec/pcm051/Kconfig" @@ -827,7 +824,6 @@ source "board/siemens/draco/Kconfig" source "board/siemens/pxm2/Kconfig" source "board/siemens/rut/Kconfig" source "board/silica/pengwyn/Kconfig" -source "board/solidrun/clearfog/Kconfig" source "board/spear/spear300/Kconfig" source "board/spear/spear310/Kconfig" source "board/spear/spear320/Kconfig" diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 82a439e..9f4d46b 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -18,6 +18,23 @@ config TARGET_MAXBCM
endchoice
+config SYS_BOARD + default "clearfog" if TARGET_CLEARFOG + default "db-88f6820-gp" if TARGET_DB_88F6820_GP + default "db-mv784mp-gp" if TARGET_DB_MV784MP_GP + default "maxbcm" if TARGET_MAXBCM + +config SYS_CONFIG_NAME + default "clearfog" if TARGET_CLEARFOG + default "db-88f6820-gp" if TARGET_DB_88F6820_GP + default "db-mv784mp-gp" if TARGET_DB_MV784MP_GP + default "maxbcm" if TARGET_MAXBCM + +config SYS_VENDOR + default "Marvell" if TARGET_DB_MV784MP_GP + default "Marvell" if TARGET_DB_88F6820_GP + default "solidrun" if TARGET_CLEARFOG + config SYS_SOC default "mvebu"
diff --git a/board/Marvell/db-88f6820-gp/Kconfig b/board/Marvell/db-88f6820-gp/Kconfig deleted file mode 100644 index f12b968..0000000 --- a/board/Marvell/db-88f6820-gp/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_DB_88F6820_GP - -config SYS_BOARD - default "db-88f6820-gp" - -config SYS_VENDOR - default "Marvell" - -config SYS_CONFIG_NAME - default "db-88f6820-gp" - -endif diff --git a/board/Marvell/db-mv784mp-gp/Kconfig b/board/Marvell/db-mv784mp-gp/Kconfig deleted file mode 100644 index 428a5e1..0000000 --- a/board/Marvell/db-mv784mp-gp/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_DB_MV784MP_GP - -config SYS_BOARD - default "db-mv784mp-gp" - -config SYS_VENDOR - default "Marvell" - -config SYS_CONFIG_NAME - default "db-mv784mp-gp" - -endif diff --git a/board/maxbcm/Kconfig b/board/maxbcm/Kconfig deleted file mode 100644 index 2edccfe..0000000 --- a/board/maxbcm/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_MAXBCM - -config SYS_BOARD - default "maxbcm" - -config SYS_CONFIG_NAME - default "maxbcm" - -endif diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig deleted file mode 100644 index cdf8938..0000000 --- a/board/solidrun/clearfog/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_CLEARFOG - -config SYS_BOARD - default "clearfog" - -config SYS_VENDOR - default "solidrun" - -config SYS_CONFIG_NAME - default "clearfog" - -endif
Until now, the SoC selection for the ARCH_MVEBU platforms has been done in the config header. Using CONFIG_ARMADA_XP in a non-clear way. As it needed to get selected for AXP and A38x based boards. This patch now changes this to move the SoC selection to Kconfig. And also uses CONFIG_ARCH_MVEBU as a common define for both AXP and A38x. This makes things a bit clearer - especially for new board additions.
Additionally the defines CONFIG_SYS_MVEBU_DDR_AXP and CONFIG_SYS_MVEBU_DDR_A38X are replaced with the already available CONFIG_ARMADA_38X and CONFIG_ARMADA_XP.
And CONFIG_DDR3 is removed, as its not referenced anywhere.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/Makefile | 2 +- arch/arm/mach-mvebu/Kconfig | 10 ++++++++++ arch/arm/mach-mvebu/Makefile | 8 ++++---- arch/arm/mach-mvebu/dram.c | 11 ++++------- arch/arm/mach-mvebu/include/mach/config.h | 6 +++++- arch/arm/mach-mvebu/mbus.c | 2 +- arch/arm/mach-mvebu/timer.c | 2 +- drivers/Makefile | 4 ++-- drivers/block/mvsata_ide.c | 6 +++--- drivers/i2c/mvtwsi.c | 2 +- include/configs/clearfog.h | 6 ------ include/configs/db-88f6820-gp.h | 6 ------ include/configs/db-mv784mp-gp.h | 2 -- include/configs/maxbcm.h | 2 -- tools/Makefile | 2 +- 15 files changed, 33 insertions(+), 38 deletions(-)
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 18283d1..3d15673 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -49,7 +49,7 @@ machine-$(CONFIG_ARCH_HIGHBANK) += highbank machine-$(CONFIG_ARCH_KEYSTONE) += keystone # TODO: rename CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOOD machine-$(CONFIG_KIRKWOOD) += kirkwood -machine-$(CONFIG_ARMADA_XP) += mvebu +machine-$(CONFIG_ARCH_MVEBU) += mvebu # TODO: rename CONFIG_TEGRA -> CONFIG_ARCH_TEGRA # TODO: rename CONFIG_ORION5X -> CONFIG_ARCH_ORION5X machine-$(CONFIG_ORION5X) += orion5x diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 9f4d46b..d96b2ae 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -1,20 +1,30 @@ if ARCH_MVEBU
+config ARMADA_38X + bool + +config ARMADA_XP + bool + choice prompt "Marvell MVEBU (Armada XP/38x) board select" optional
config TARGET_CLEARFOG bool "Support ClearFog" + select ARMADA_38X
config TARGET_DB_88F6820_GP bool "Support DB-88F6820-GP" + select ARMADA_38X
config TARGET_DB_MV784MP_GP bool "Support db-mv784mp-gp" + select ARMADA_XP
config TARGET_MAXBCM bool "Support maxbcm" + select ARMADA_XP
endchoice
diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index 21c56a4..b96b81b 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -15,8 +15,8 @@ else obj-y = cpu.o obj-y += dram.o ifndef CONFIG_SPL_BUILD -obj-$(CONFIG_SYS_MVEBU_DDR_A38X) += ../../../drivers/ddr/marvell/a38x/xor.o -obj-$(CONFIG_SYS_MVEBU_DDR_AXP) += ../../../drivers/ddr/marvell/axp/xor.o +obj-$(CONFIG_ARMADA_38X) += ../../../drivers/ddr/marvell/a38x/xor.o +obj-$(CONFIG_ARMADA_XP) += ../../../drivers/ddr/marvell/axp/xor.o endif obj-y += gpio.o obj-y += mbus.o @@ -24,7 +24,7 @@ obj-y += timer.o obj-$(CONFIG_SPL_BUILD) += spl.o obj-$(CONFIG_SPL_BUILD) += lowlevel_spl.o
-obj-$(CONFIG_SYS_MVEBU_DDR_A38X) += serdes/a38x/ -obj-$(CONFIG_SYS_MVEBU_DDR_AXP) += serdes/axp/ +obj-$(CONFIG_ARMADA_38X) += serdes/a38x/ +obj-$(CONFIG_ARMADA_XP) += serdes/axp/
endif diff --git a/arch/arm/mach-mvebu/dram.c b/arch/arm/mach-mvebu/dram.c index 059151a..a8ec5ea 100644 --- a/arch/arm/mach-mvebu/dram.c +++ b/arch/arm/mach-mvebu/dram.c @@ -12,11 +12,8 @@ #include <asm/arch/cpu.h> #include <asm/arch/soc.h>
-#ifdef CONFIG_SYS_MVEBU_DDR_A38X -#include "../../../drivers/ddr/marvell/axp/xor.h" -#include "../../../drivers/ddr/marvell/axp/xor_regs.h" -#endif -#ifdef CONFIG_SYS_MVEBU_DDR_AXP +#if defined(CONFIG_ARCH_MVEBU) +/* Use common XOR definitions for A3x and AXP */ #include "../../../drivers/ddr/marvell/axp/xor.h" #include "../../../drivers/ddr/marvell/axp/xor_regs.h" #endif @@ -112,7 +109,7 @@ void mvebu_sdram_size_adjust(enum memory_bank bank) mvebu_sdram_bs_set(bank, size); }
-#if defined(CONFIG_SYS_MVEBU_DDR_A38X) || defined(CONFIG_SYS_MVEBU_DDR_AXP) +#if defined(CONFIG_ARCH_MVEBU) static u32 xor_ctrl_save; static u32 xor_base_save; static u32 xor_mask_save; @@ -292,7 +289,7 @@ void dram_init_banksize(void) } }
-#if defined(CONFIG_ARMADA_XP) +#if defined(CONFIG_ARCH_MVEBU) void board_add_ram_info(int use_default) { struct sar_freq_modes sar_freq; diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index c282fcb..cc1fc5f 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -17,7 +17,11 @@
-#if defined(CONFIG_ARMADA_XP) +#if defined(CONFIG_ARMADA_XP) || defined(CONFIG_ARMADA_38X) +/* + * Set this for the common xor register definitions needed in dram.c + * for A38x as well here. + */ #define MV88F78X60 /* for the DDR training bin_hdr code */ #endif
diff --git a/arch/arm/mach-mvebu/mbus.c b/arch/arm/mach-mvebu/mbus.c index 346278e..df263bc 100644 --- a/arch/arm/mach-mvebu/mbus.c +++ b/arch/arm/mach-mvebu/mbus.c @@ -491,7 +491,7 @@ int mvebu_mbus_probe(struct mbus_win windows[], int count) #if defined(CONFIG_KIRKWOOD) mbus_state.soc = &kirkwood_mbus_data; #endif -#if defined(CONFIG_ARMADA_XP) +#if defined(CONFIG_ARCH_MVEBU) mbus_state.soc = &armada_370_xp_mbus_data; #endif
diff --git a/arch/arm/mach-mvebu/timer.c b/arch/arm/mach-mvebu/timer.c index aef2df2..f5c2eaa 100644 --- a/arch/arm/mach-mvebu/timer.c +++ b/arch/arm/mach-mvebu/timer.c @@ -31,7 +31,7 @@ int timer_init(void) writel(TIMER_LOAD_VAL, MVEBU_TIMER_BASE + 0x10); writel(TIMER_LOAD_VAL, MVEBU_TIMER_BASE + 0x14);
-#if defined(CONFIG_ARMADA_XP) +#if defined(CONFIG_ARCH_MVEBU) /* On Armada XP / 38x ..., the 25MHz clock source needs to be enabled */ setbits_le32(MVEBU_TIMER_BASE + 0x00, BIT(11)); #endif diff --git a/drivers/Makefile b/drivers/Makefile index c9031f2..00da40b 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -14,8 +14,8 @@ obj-$(CONFIG_SPL_I2C_SUPPORT) += i2c/ obj-$(CONFIG_SPL_GPIO_SUPPORT) += gpio/ obj-$(CONFIG_SPL_MMC_SUPPORT) += mmc/ obj-$(CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT) += ddr/fsl/ -obj-$(CONFIG_SYS_MVEBU_DDR_A38X) += ddr/marvell/a38x/ -obj-$(CONFIG_SYS_MVEBU_DDR_AXP) += ddr/marvell/axp/ +obj-$(CONFIG_ARMADA_38X) += ddr/marvell/a38x/ +obj-$(CONFIG_ARMADA_XP) += ddr/marvell/axp/ obj-$(CONFIG_ALTERA_SDRAM) += ddr/altera/ obj-$(CONFIG_SPL_SERIAL_SUPPORT) += serial/ obj-$(CONFIG_SPL_SPI_FLASH_SUPPORT) += mtd/spi/ diff --git a/drivers/block/mvsata_ide.c b/drivers/block/mvsata_ide.c index 52c1602..2c6d424 100644 --- a/drivers/block/mvsata_ide.c +++ b/drivers/block/mvsata_ide.c @@ -13,7 +13,7 @@ #include <asm/arch/orion5x.h> #elif defined(CONFIG_KIRKWOOD) #include <asm/arch/soc.h> -#elif defined(CONFIG_ARMADA_XP) +#elif defined(CONFIG_ARCH_MVEBU) #include <linux/mbus.h> #endif
@@ -102,7 +102,7 @@ struct mvsata_port_registers { * Initialize SATA memory windows for Armada XP */
-#ifdef CONFIG_ARMADA_XP +#ifdef CONFIG_ARCH_MVEBU static void mvsata_ide_conf_mbus_windows(void) { const struct mbus_dram_target_info *dram; @@ -174,7 +174,7 @@ int ide_preinit(void) int ret = MVSATA_STATUS_TIMEOUT; int status;
-#ifdef CONFIG_ARMADA_XP +#ifdef CONFIG_ARCH_MVEBU mvsata_ide_conf_mbus_windows(); #endif
diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index f20d1b2..5dc4fbb 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -20,7 +20,7 @@
#if defined(CONFIG_ORION5X) #include <asm/arch/orion5x.h> -#elif (defined(CONFIG_KIRKWOOD) || defined(CONFIG_ARMADA_XP)) +#elif (defined(CONFIG_KIRKWOOD) || defined(CONFIG_ARCH_MVEBU)) #include <asm/arch/soc.h> #elif defined(CONFIG_SUNXI) #include <asm/arch/i2c.h> diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index c74415d..6c5356b 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -10,8 +10,6 @@ /* * High Level Configuration Options (easy to change) */ -#define CONFIG_ARMADA_XP /* SOC Family Name */ -#define CONFIG_ARMADA_38X #define CONFIG_DB_88F6820_GP /* Board target name for DDR training */
#define CONFIG_DISPLAY_BOARDINFO_LATE @@ -170,10 +168,6 @@ #endif #endif
-/* Enable DDR support in SPL (DDR3 training from Marvell bin_hdr) */ -#define CONFIG_SYS_MVEBU_DDR_A38X -#define CONFIG_DDR3 - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index d76ceb7..03a3d31 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -10,8 +10,6 @@ /* * High Level Configuration Options (easy to change) */ -#define CONFIG_ARMADA_XP /* SOC Family Name */ -#define CONFIG_ARMADA_38X #define CONFIG_DB_88F6820_GP /* Board target name for DDR training */
-/* Enable DDR support in SPL (DDR3 training from Marvell bin_hdr) */ -#define CONFIG_SYS_MVEBU_DDR_A38X -#define CONFIG_DDR3 - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index c354e6f..c8b0344 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -10,7 +10,6 @@ /* * High Level Configuration Options (easy to change) */ -#define CONFIG_ARMADA_XP /* SOC Family Name */ #define CONFIG_DB_784MP_GP /* Board target name for DDR training */
#define CONFIG_DISPLAY_BOARDINFO_LATE @@ -144,7 +143,6 @@ #define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_OFFS
/* Enable DDR support in SPL (DDR3 training from Marvell bin_hdr) */ -#define CONFIG_SYS_MVEBU_DDR_AXP #define CONFIG_SPD_EEPROM 0x4e #define CONFIG_BOARD_ECC_SUPPORT /* this board supports ECC */
diff --git a/include/configs/maxbcm.h b/include/configs/maxbcm.h index 23e5526..43d7fd0 100644 --- a/include/configs/maxbcm.h +++ b/include/configs/maxbcm.h @@ -10,7 +10,6 @@ /* * High Level Configuration Options (easy to change) */ -#define CONFIG_ARMADA_XP /* SOC Family Name */ #define CONFIG_DISPLAY_BOARDINFO_LATE
/* @@ -106,7 +105,6 @@ #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
/* Enable DDR support in SPL (DDR3 training from Marvell bin_hdr) */ -#define CONFIG_SYS_MVEBU_DDR_AXP #define CONFIG_DDR_FIXED_SIZE (1 << 20) /* 1GiB */ #define CONFIG_BOARD_ECC_SUPPORT /* this board supports ECC */
diff --git a/tools/Makefile b/tools/Makefile index 9cfd80b..77a1909 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -156,7 +156,7 @@ ubsha1-objs := os_support.o ubsha1.o lib/sha1.o HOSTCFLAGS_ubsha1.o := -pedantic
hostprogs-$(CONFIG_KIRKWOOD) += kwboot -hostprogs-$(CONFIG_ARMADA_XP) += kwboot +hostprogs-$(CONFIG_ARCH_MVEBU) += kwboot hostprogs-y += proftool hostprogs-$(CONFIG_STATIC_RELA) += relocate-rela
This Makefile was not used since quite some time. I only missed to remove it in the move to mach-mvebu. So lets remove it now so that the mvebu-common directory is really removed completely.
Signed-off-by: Stefan Roese sr@denx.de Cc: Luka Perkov luka.perkov@sartura.hr --- arch/arm/mvebu-common/Makefile | 14 -------------- 1 file changed, 14 deletions(-) delete mode 100644 arch/arm/mvebu-common/Makefile
diff --git a/arch/arm/mvebu-common/Makefile b/arch/arm/mvebu-common/Makefile deleted file mode 100644 index de243fe..0000000 --- a/arch/arm/mvebu-common/Makefile +++ /dev/null @@ -1,14 +0,0 @@ -# -# (C) Copyright 2009 -# Marvell Semiconductor <www.marvell.com> -# Written-by: Prafulla Wadaskar prafulla@marvell.com -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = dram.o -obj-y += gpio.o -obj-$(CONFIG_ARMADA_XP) += mbus.o -obj-y += timer.o - -obj-y += serdes/
Stefan Roese
