[PATCH v2] list: use list_count_nodes() to count list entries
Use the API function list_count_nodes() to count the number of list entries.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V1: Rebased on top of next
boot/scene.c | 8 +------- drivers/mtd/ubi/fastmap.c | 8 +++----- fs/yaffs2/yaffs_guts.c | 5 ++--- lib/fwu_updates/fwu_mtd.c | 5 +---- test/boot/expo.c | 4 +--- 5 files changed, 8 insertions(+), 22 deletions(-)
diff --git a/boot/scene.c b/boot/scene.c index ac976aa26b..270c9c6723 100644 --- a/boot/scene.c +++ b/boot/scene.c @@ -79,13 +79,7 @@ int scene_title_set(struct scene *scn, uint id)
int scene_obj_count(struct scene *scn) { - struct scene_obj *obj; - int count = 0; - - list_for_each_entry(obj, &scn->obj_head, sibling) - count++; - - return count; + return list_count_nodes(&scn->obj_head); }
void *scene_obj_find(const struct scene *scn, uint id, enum scene_obj_t type) diff --git a/drivers/mtd/ubi/fastmap.c b/drivers/mtd/ubi/fastmap.c index 21750e1817..9c6b15b8cb 100644 --- a/drivers/mtd/ubi/fastmap.c +++ b/drivers/mtd/ubi/fastmap.c @@ -581,13 +581,11 @@ static int count_fastmap_pebs(struct ubi_attach_info *ai) struct ubi_ainf_peb *aeb; struct ubi_ainf_volume *av; struct rb_node *rb1, *rb2; - int n = 0; + int n;
- list_for_each_entry(aeb, &ai->erase, u.list) - n++; + n = list_count_nodes(&ai->erase);
- list_for_each_entry(aeb, &ai->free, u.list) - n++; + n += list_count_nodes(&ai->free);
ubi_rb_for_each_entry(rb1, av, &ai->volumes, rb) ubi_rb_for_each_entry(rb2, aeb, &av->root, u.rb) diff --git a/fs/yaffs2/yaffs_guts.c b/fs/yaffs2/yaffs_guts.c index e89d02513c..c20f2f8298 100644 --- a/fs/yaffs2/yaffs_guts.c +++ b/fs/yaffs2/yaffs_guts.c @@ -4452,13 +4452,12 @@ loff_t yaffs_get_obj_length(struct yaffs_obj *obj) int yaffs_get_obj_link_count(struct yaffs_obj *obj) { int count = 0; - struct list_head *i;
if (!obj->unlinked) count++; /* the object itself */
- list_for_each(i, &obj->hard_links) - count++; /* add the hard links; */ + /* add the hard links; */ + count += list_count_nodes(&obj->hard_links);
return count; } diff --git a/lib/fwu_updates/fwu_mtd.c b/lib/fwu_updates/fwu_mtd.c index ccaba3f311..c14203b9dd 100644 --- a/lib/fwu_updates/fwu_mtd.c +++ b/lib/fwu_updates/fwu_mtd.c @@ -60,10 +60,7 @@ int fwu_mtd_get_alt_num(efi_guid_t *image_id, u8 *alt_num, if (ret) return -ENOENT;
- nalt = 0; - list_for_each_entry(dfu, &dfu_list, list) - nalt++; - + nalt = list_count_nodes(&dfu_list); if (!nalt) { log_warning("No entities in dfu_alt_info\n"); dfu_free_entities(); diff --git a/test/boot/expo.c b/test/boot/expo.c index 4b24f504e2..9b4aa803eb 100644 --- a/test/boot/expo.c +++ b/test/boot/expo.c @@ -702,9 +702,7 @@ static int expo_test_build(struct unit_test_state *uts) txt = scene_obj_find(scn, item->label_id, SCENEOBJT_NONE); ut_asserteq_str("2 GHz", expo_get_str(exp, txt->str_id));
- count = 0; - list_for_each_entry(item, &menu->item_head, sibling) - count++; + count = list_count_nodes(&menu->item_head); ut_asserteq(3, count);
expo_destroy(exp);
Sughosh Ganu
