There seems to be a problem handling emmc with configured GP partition.
Below the "mmc info". The problem might be that user capacity is calculated/shown as "0". At least it shows the GP1 partition with correct size - which is not the case for "mmc hwpartition" - it denies its existence ;)
Can someone help me to fix this?
Thanks a lot. - Arno
mmc info
Device: sdhci at e0100000 Manufacturer ID: 13 OEM: 14e Name: Q1J54 Tran Speed: 52000000 Rd Block Len: 512 MMC version 5.0 High Capacity: Yes Capacity: 0 Bytes Bus Width: 4-bit Erase Group Size: 512 KiB HC WP Group Size: 8 MiB User Capacity: 0 Bytes WRREL Boot Capacity: 2 MiB ENH RPMB Capacity: 512 KiB ENH GP1 Capacity: 1.8 GiB ENH WRREL
mmc hwpartition
Partition configuration: No enhanced user data area No GP1 partition No GP2 partition No GP3 partition No GP4 partition Card already partitioned Failed!
mmc read 0 0 1
MMC read: dev # 0, block # 0, count 1 ... MMC: block number 0x1 exceeds max(0x0) 0 blocks read: ERROR
mmc dev 0 0
MMC: block number 0x1 exceeds max(0x0) switch to partitions #0, OK mmc0(part 0) is current device
BTW: The GP partiton was created in Linux by the mmc-utils with “mmc gp create -y 1908736 1 1 0 /dev/mmcblk0”
Linux can handle this as you can see in boot message: [ 1.248426] mmc0: new high speed MMC card at address 0001 [ 1.264301] mmcblk0: mmc0:0001 Q1J54A 0 B [ 1.268525] mmcblk0boot0: mmc0:0001 Q1J54A partition 1 2.00 MiB [ 1.284605] mmcblk0boot1: mmc0:0001 Q1J54A partition 2 2.00 MiB [ 1.300666] mmcblk0gp0: mmc0:0001 Q1J54A partition 4 1.82 GiB [ 1.316563] mmcblk0rpmb: mmc0:0001 Q1J54A partition 3 512 KiB [ 1.325255] mmcblk0gp0: p1 p2 p3 … [ 3.083325] EXT4-fs (mmcblk0gp0p1): INFO: recovery required on readonly filesystem [ 3.090893] EXT4-fs (mmcblk0gp0p1): write access will be enabled during recovery [ 3.189597] EXT4-fs (mmcblk0gp0p1): recovery complete [ 3.196310] EXT4-fs (mmcblk0gp0p1): mounted filesystem with ordered data mode. Opts: (null)
Which board do you use? It seems that the initializing mmc might be failed. After enabling debug option, share the log about mmc.
Best Regards, Jaehoon Chung
mmc info
mmc hwpartition
mmc read 0 0 1
mmc dev 0 0
Linux can handle this as you can see in boot message: [ 1.248426] mmc0: new high speed MMC card at address 0001 [ 1.264301] mmcblk0: mmc0:0001 Q1J54A 0 B [ 1.268525] mmcblk0boot0: mmc0:0001 Q1J54A partition 1 2.00 MiB [ 1.284605] mmcblk0boot1: mmc0:0001 Q1J54A partition 2 2.00 MiB [ 1.300666] mmcblk0gp0: mmc0:0001 Q1J54A partition 4 1.82 GiB [ 1.316563] mmcblk0rpmb: mmc0:0001 Q1J54A partition 3 512 KiB [ 1.325255] mmcblk0gp0: p1 p2 p3 … [ 3.083325] EXT4-fs (mmcblk0gp0p1): INFO: recovery required on readonly filesystem [ 3.090893] EXT4-fs (mmcblk0gp0p1): write access will be enabled during recovery [ 3.189597] EXT4-fs (mmcblk0gp0p1): recovery complete [ 3.196310] EXT4-fs (mmcblk0gp0p1): mounted filesystem with ordered data mode. Opts: (null) _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi, I am using latest release: U-boot 2017.03. The board is a custom board, simular to Zynq-MicroZed board. But MicroZed board has SD card, while our board has a fixed mounted emmc vom Micron.
I compiled it again with #define DEBUG 1 in cmd/mmc.c cmd/parts.c cmd/mtdparts.c driver/mmc/mmc.c driver/mmc/zynq_sdhci.c driver/mmc/sdhci.c driver/mmc/mmc_write.c driver/mmc/mmc_uclass.c driver/mmc/mmc_legacy.c But this doesn't give me more information for the commands "mmc info" and mmc hwpartition".
As it works with "normal" formatted mmc - have you ever tried to use enhanced partitions? What is correct command to access a GP partition? For me it is not 100% sure how the commands are working, but because of the non consistence in "mmc info" and "mmc hwpartition" about the existence of a GP1 partition it must be a bug in U-boot.
My main problems to debug this - I have no comparison to a working system (to know what is wrong and what is ok) and how it works. There is no help/doc about this enhanced partition
I found something here: https://lists.denx.de/pipermail/u-boot/2014-April/177378.html
What is strange to me: mmc_startup seems not to know MMC Version 5.0. There is a switch matrix, which only goes up to 4.0 ?!?
Let me know if I can do something to go ahead with this bug.
Thanks Arno
Gesendet: Donnerstag, 06. April 2017 um 14:08 Uhr Von: "Jaehoon Chung" jh80.chung@samsung.com An: "Arno Steffens" star@gmx.li, u-boot@lists.denx.de Betreff: Re: [U-Boot] Bug in emmc subsystem
mmc info
mmc hwpartition
mmc read 0 0 1
mmc dev 0 0
Arno Steffens
Jaehoon Chung
