[PATCH] cmd: pwm: Rework argc sanity checking
Currently, we check argc in a number of places to make sure that we have all of the required arguments for each of the pwm sub-commands. However, there's at least one place where we've got dead code as we'll never have argc == 0, due to checking that argc was at least 4 earlier and having only subtracted 3. Rework things so that when we have determined our subcommand make sure we have the right number of arguments for it, or error out. This means we can stop checking against argc again later.
Reported-by: Coverity (CID: 316601) Cc: Pragnesh Patel pragnesh.patel@sifive.com Signed-off-by: Tom Rini trini@konsulko.com --- cmd/pwm.c | 41 +++++++++++++++++++---------------------- 1 file changed, 19 insertions(+), 22 deletions(-)
diff --git a/cmd/pwm.c b/cmd/pwm.c index 5849fc57b666..e1f97c759d2c 100644 --- a/cmd/pwm.c +++ b/cmd/pwm.c @@ -34,11 +34,9 @@ static int do_pwm(struct cmd_tbl *cmdtp, int flag, int argc, argc -= 2; argv += 2;
- if (argc > 0) { - str_pwm = *argv; - argc--; - argv++; - } + str_pwm = *argv; + argc--; + argv++;
if (!str_pwm) return CMD_RET_USAGE; @@ -46,15 +44,23 @@ static int do_pwm(struct cmd_tbl *cmdtp, int flag, int argc, switch (*str_cmd) { case 'i': sub_cmd = PWM_SET_INVERT; + if (argc != 2) + return CMD_RET_USAGE; break; case 'c': sub_cmd = PWM_SET_CONFIG; + if (argc != 3) + return CMD_RET_USAGE; break; case 'e': sub_cmd = PWM_SET_ENABLE; + if (argc != 1) + return CMD_RET_USAGE; break; case 'd': sub_cmd = PWM_SET_DISABLE; + if (argc != 1) + return CMD_RET_USAGE; break; default: return CMD_RET_USAGE; @@ -67,38 +73,29 @@ static int do_pwm(struct cmd_tbl *cmdtp, int flag, int argc, return cmd_process_error(cmdtp, ret); }
- if (argc > 0) { - str_channel = *argv; - channel = simple_strtoul(str_channel, NULL, 10); - argc--; - argv++; - } else { - return CMD_RET_USAGE; - } + str_channel = *argv; + channel = simple_strtoul(str_channel, NULL, 10); + argc--; + argv++;
- if (sub_cmd == PWM_SET_INVERT && argc > 0) { + if (sub_cmd == PWM_SET_INVERT) { str_enable = *argv; pwm_enable = simple_strtoul(str_enable, NULL, 10); ret = pwm_set_invert(dev, channel, pwm_enable); - } else if (sub_cmd == PWM_SET_CONFIG && argc == 2) { + } else if (sub_cmd == PWM_SET_CONFIG) { str_period = *argv; argc--; argv++; period_ns = simple_strtoul(str_period, NULL, 10);
- if (argc > 0) { - str_duty = *argv; - duty_ns = simple_strtoul(str_duty, NULL, 10); - } + str_duty = *argv; + duty_ns = simple_strtoul(str_duty, NULL, 10);
ret = pwm_set_config(dev, channel, period_ns, duty_ns); } else if (sub_cmd == PWM_SET_ENABLE) { ret = pwm_set_enable(dev, channel, 1); } else if (sub_cmd == PWM_SET_DISABLE) { ret = pwm_set_enable(dev, channel, 0); - } else { - printf("PWM arguments missing\n"); - return CMD_RET_FAILURE; }
if (ret) {
