[U-Boot] [PATCH 2/3] pci: Remove parameter 'class' of pci_rom_load()
pci_rom_load() does not use its parameter 'class', so remove it.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/pci/pci_rom.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index 49c118d..37450c8 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -139,7 +139,7 @@ static int pci_rom_probe(pci_dev_t dev, uint class, return 0; }
-int pci_rom_load(uint16_t class, struct pci_rom_header *rom_header, +int pci_rom_load(struct pci_rom_header *rom_header, struct pci_rom_header **ram_headerp) { struct pci_rom_data *rom_data; @@ -253,7 +253,7 @@ int pci_run_vga_bios(pci_dev_t dev, int (*int15_handler)(void), int exec_method) if (ret) return ret;
- ret = pci_rom_load(class, rom, &ram); + ret = pci_rom_load(rom, &ram); if (ret) return ret;
Applied to u-boot-x86, thanks!
Bin Meng
