[U-Boot] [PATCH 1/4] mx6: Add support for the mx6solox variant
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx6/clock.c | 4 +- arch/arm/cpu/armv7/mx6/soc.c | 26 +++++ arch/arm/imx-common/cpu.c | 2 + arch/arm/include/asm/arch-imx/cpu.h | 3 +- arch/arm/include/asm/arch-mx6/crm_regs.h | 170 ++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx6/imx-regs.h | 122 ++++++++++++++++++++- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 4 + arch/arm/include/asm/arch-mx6/mx6sx-ddr.h | 45 ++++++++ 8 files changed, 369 insertions(+), 7 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx6/mx6sx-ddr.h
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index bd65a08..d31fbbd 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -214,7 +214,7 @@ static u32 get_uart_clk(void) u32 reg, uart_podf; u32 freq = decode_pll(PLL_USBOTG, MXC_HCLK) / 6; /* static divider */ reg = __raw_readl(&imx_ccm->cscdr1); -#ifdef CONFIG_MX6SL +#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX)) if (reg & MXC_CCM_CSCDR1_UART_CLK_SEL) freq = MXC_HCLK; #endif @@ -282,7 +282,7 @@ static u32 get_emi_slow_clk(void) return root_freq / (emi_slow_podf + 1); }
-#ifdef CONFIG_MX6SL +#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX)) static u32 get_mmdc_ch0_clk(void) { u32 cbcmr = __raw_readl(&imx_ccm->cbcmr); diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 1725279..e394e3f 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -79,9 +79,15 @@ u32 __weak get_board_rev(void) void init_aips(void) { struct aipstz_regs *aips1, *aips2; +#ifdef CONFIG_MX6SX + struct aipstz_regs *aips3; +#endif
aips1 = (struct aipstz_regs *)AIPS1_BASE_ADDR; aips2 = (struct aipstz_regs *)AIPS2_BASE_ADDR; +#ifdef CONFIG_MX6SX + aips3 = (struct aipstz_regs *)AIPS3_BASE_ADDR; +#endif
/* * Set all MPROTx to be non-bufferable, trusted for R/W, @@ -107,6 +113,26 @@ void init_aips(void) writel(0x00000000, &aips2->opacr2); writel(0x00000000, &aips2->opacr3); writel(0x00000000, &aips2->opacr4); + +#ifdef CONFIG_MX6SX + /* + * Set all MPROTx to be non-bufferable, trusted for R/W, + * not forced to user-mode. + */ + writel(0x77777777, &aips3->mprot0); + writel(0x77777777, &aips3->mprot1); + + /* + * Set all OPACRx to be non-bufferable, not require + * supervisor privilege level for access,allow for + * write access and untrusted master access. + */ + writel(0x00000000, &aips3->opacr0); + writel(0x00000000, &aips3->opacr1); + writel(0x00000000, &aips3->opacr2); + writel(0x00000000, &aips3->opacr3); + writel(0x00000000, &aips3->opacr4); +#endif }
static void clear_ldo_ramp(void) diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 5a09107..7bb0e83 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -112,6 +112,8 @@ const char *get_imx_type(u32 imxtype) return "6SOLO"; /* Solo version of the mx6 */ case MXC_CPU_MX6SL: return "6SL"; /* Solo-Lite version of the mx6 */ + case MXC_CPU_MX6SX: + return "6SX"; /* SoloX version of the mx6 */ case MXC_CPU_MX51: return "51"; case MXC_CPU_MX53: diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index a35940e..a3cc96f 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -8,6 +8,7 @@ #define MXC_CPU_MX53 0x53 #define MXC_CPU_MX6SL 0x60 #define MXC_CPU_MX6DL 0x61 -#define MXC_CPU_MX6SOLO 0x62 +#define MXC_CPU_MX6SX 0x62 #define MXC_CPU_MX6Q 0x63 #define MXC_CPU_MX6D 0x64 +#define MXC_CPU_MX6SOLO 0x65 /* dummy ID */ diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index 7202073..0fcef69 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -113,7 +113,11 @@ struct mxc_ccm_reg { #define MXC_CCM_CCR_WB_COUNT_MASK 0x7 #define MXC_CCM_CCR_WB_COUNT_OFFSET (1 << 16) #define MXC_CCM_CCR_COSC_EN (1 << 12) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCR_OSCNT_MASK 0x7F +#else #define MXC_CCM_CCR_OSCNT_MASK 0xFF +#endif #define MXC_CCM_CCR_OSCNT_OFFSET 0
/* Define the bits in register CCDR */ @@ -146,8 +150,10 @@ struct mxc_ccm_reg { #define MXC_CCM_CBCDR_PERIPH_CLK2_PODF_OFFSET 27 #define MXC_CCM_CBCDR_PERIPH2_CLK2_SEL (1 << 26) #define MXC_CCM_CBCDR_PERIPH_CLK_SEL (1 << 25) +#ifndef CONFIG_MX6SX #define MXC_CCM_CBCDR_MMDC_CH0_PODF_MASK (0x7 << 19) #define MXC_CCM_CBCDR_MMDC_CH0_PODF_OFFSET 19 +#endif #define MXC_CCM_CBCDR_AXI_PODF_MASK (0x7 << 16) #define MXC_CCM_CBCDR_AXI_PODF_OFFSET 16 #define MXC_CCM_CBCDR_AHB_PODF_MASK (0x7 << 10) @@ -173,28 +179,40 @@ struct mxc_ccm_reg { #define MXC_CCM_CBCMR_PRE_PERIPH2_CLK2_SEL (1 << 20) #define MXC_CCM_CBCMR_PRE_PERIPH_CLK_SEL_MASK (0x3 << 18) #define MXC_CCM_CBCMR_PRE_PERIPH_CLK_SEL_OFFSET 18 +#ifndef CONFIG_MX6SX #define MXC_CCM_CBCMR_GPU2D_CLK_SEL_MASK (0x3 << 16) #define MXC_CCM_CBCMR_GPU2D_CLK_SEL_OFFSET 16 #define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_MASK (0x3 << 14) #define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_OFFSET 14 +#endif #define MXC_CCM_CBCMR_PERIPH_CLK2_SEL_MASK (0x3 << 12) #define MXC_CCM_CBCMR_PERIPH_CLK2_SEL_OFFSET 12 +#ifndef CONFIG_MX6SX #define MXC_CCM_CBCMR_VDOAXI_CLK_SEL (1 << 11) +#endif #define MXC_CCM_CBCMR_PCIE_AXI_CLK_SEL (1 << 10) #define MXC_CCM_CBCMR_GPU3D_SHADER_CLK_SEL_MASK (0x3 << 8) #define MXC_CCM_CBCMR_GPU3D_SHADER_CLK_SEL_OFFSET 8 #define MXC_CCM_CBCMR_GPU3D_CORE_CLK_SEL_MASK (0x3 << 4) #define MXC_CCM_CBCMR_GPU3D_CORE_CLK_SEL_OFFSET 4 +#ifndef CONFIG_MX6SX #define MXC_CCM_CBCMR_GPU3D_AXI_CLK_SEL (1 << 1) #define MXC_CCM_CBCMR_GPU2D_AXI_CLK_SEL (1 << 0) +#endif
/* Define the bits in register CSCMR1 */ #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_MASK (0x3 << 29) #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_OFFSET 29 +#ifdef CONFIG_MX6SX +#define MXC_CCM_CSCMR1_QSPI1_PODF_MASK (0x7 << 26) +#define MXC_CCM_CSCMR1_QSPI1_PODF_OFFSET 26 +#else #define MXC_CCM_CSCMR1_ACLK_EMI_MASK (0x3 << 27) #define MXC_CCM_CSCMR1_ACLK_EMI_OFFSET 27 +#endif #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_PODF_MASK (0x7 << 23) #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_PODF_OFFSET 23 +/* ACLK_EMI_PODF is LCFIF2_PODF on MX6SX */ #define MXC_CCM_CSCMR1_ACLK_EMI_PODF_MASK (0x7 << 20) #define MXC_CCM_CSCMR1_ACLK_EMI_PODF_OFFSET 20 #define MXC_CCM_CSCMR1_USDHC4_CLK_SEL (1 << 19) @@ -207,19 +225,38 @@ struct mxc_ccm_reg { #define MXC_CCM_CSCMR1_SSI2_CLK_SEL_OFFSET 12 #define MXC_CCM_CSCMR1_SSI1_CLK_SEL_MASK (0x3 << 10) #define MXC_CCM_CSCMR1_SSI1_CLK_SEL_OFFSET 10 +#ifdef CONFIG_MX6SX +#define MXC_CCM_CSCMR1_QSPI1_CLK_SEL_MASK (0x7 << 7) +#define MXC_CCM_CSCMR1_QSPI1_CLK_SEL_OFFSET 7 +#define MXC_CCM_CSCMR1_PER_CLK_SEL_MASK (1 << 6) +#define MXC_CCM_CSCMR1_PER_CLK_SEL_OFFSET 6 +#endif #define MXC_CCM_CSCMR1_PERCLK_PODF_MASK 0x3F
/* Define the bits in register CSCMR2 */ +#ifdef CONFIG_MX6SX +#define MXC_CCM_CSCMR2_VID_CLK_SEL_MASK (0x7 << 21) +#define MXC_CCM_CSCMR2_VID_CLK_SEL_OFFSET 21 +#endif #define MXC_CCM_CSCMR2_ESAI_PRE_SEL_MASK (0x3 << 19) #define MXC_CCM_CSCMR2_ESAI_PRE_SEL_OFFSET 19 #define MXC_CCM_CSCMR2_LDB_DI1_IPU_DIV (1 << 11) #define MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV (1 << 10) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CSCMR2_CAN_CLK_SEL_MASK (0x3 << 8) +#define MXC_CCM_CSCMR2_CAN_CLK_SEL_OFFSET 8 +#define MXC_CCM_CSCMR2_CAN_CLK_PODF_MASK (0x3F << 2) +#define MXC_CCM_CSCMR2_CAN_CLK_PODF_OFFSET 2 +#else #define MXC_CCM_CSCMR2_CAN_CLK_SEL_MASK (0x3F << 2) #define MXC_CCM_CSCMR2_CAN_CLK_SEL_OFFSET 2 +#endif
/* Define the bits in register CSCDR1 */ +#ifndef CONFIG_MX6SX #define MXC_CCM_CSCDR1_VPU_AXI_PODF_MASK (0x7 << 25) #define MXC_CCM_CSCDR1_VPU_AXI_PODF_OFFSET 25 +#endif #define MXC_CCM_CSCDR1_USDHC4_PODF_MASK (0x7 << 22) #define MXC_CCM_CSCDR1_USDHC4_PODF_OFFSET 22 #define MXC_CCM_CSCDR1_USDHC3_PODF_MASK (0x7 << 19) @@ -228,21 +265,28 @@ struct mxc_ccm_reg { #define MXC_CCM_CSCDR1_USDHC2_PODF_OFFSET 16 #define MXC_CCM_CSCDR1_USDHC1_PODF_MASK (0x7 << 11) #define MXC_CCM_CSCDR1_USDHC1_PODF_OFFSET 11 +#ifndef CONFIG_MX6SX #define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_OFFSET 8 #define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_MASK (0x7 << 8) #define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_OFFSET 6 #define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_MASK (0x3 << 6) +#endif #ifdef CONFIG_MX6SL #define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x1F #define MXC_CCM_CSCDR1_UART_CLK_SEL (1 << 6) #else #define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x3F +#ifdef CONFIG_MX6SX +#define MXC_CCM_CSCDR1_UART_CLK_SEL (1 << 6) +#endif #endif #define MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET 0
/* Define the bits in register CS1CDR */ #define MXC_CCM_CS1CDR_ESAI_CLK_PODF_MASK (0x3F << 25) #define MXC_CCM_CS1CDR_ESAI_CLK_PODF_OFFSET 25 +#define MXC_CCM_CS1CDR_SSI3_CLK_PRED_MASK (0x7 << 22) +#define MXC_CCM_CS1CDR_SSI3_CLK_PRED_OFFSET 22 #define MXC_CCM_CS1CDR_SSI3_CLK_PODF_MASK (0x3F << 16) #define MXC_CCM_CS1CDR_SSI3_CLK_PODF_OFFSET 16 #define MXC_CCM_CS1CDR_ESAI_CLK_PRED_MASK (0x3 << 9) @@ -253,6 +297,17 @@ struct mxc_ccm_reg { #define MXC_CCM_CS1CDR_SSI1_CLK_PODF_OFFSET 0
/* Define the bits in register CS2CDR */ +#ifdef CONFIG_MX6SX +#define MXC_CCM_CS2CDR_QSPI2_CLK_PODF_MASK (0x3F << 21) +#define MXC_CCM_CS2CDR_QSPI2_CLK_PODF_OFFSET 21 +#define MXC_CCM_CS2CDR_QSPI2_CLK_PODF(v) (((v) & 0x3f) << 21) +#define MXC_CCM_CS2CDR_QSPI2_CLK_PRED_MASK (0x7 << 18) +#define MXC_CCM_CS2CDR_QSPI2_CLK_PRED_OFFSET 18 +#define MXC_CCM_CS2CDR_QSPI2_CLK_PRED(v) (((v) & 0x7) << 18) +#define MXC_CCM_CS2CDR_QSPI2_CLK_SEL_MASK (0x7 << 15) +#define MXC_CCM_CS2CDR_QSPI2_CLK_SEL_OFFSET 15 +#define MXC_CCM_CS2CDR_QSPI2_CLK_SEL(v) (((v) & 0x7) << 15) +#else #define MXC_CCM_CS2CDR_ENFC_CLK_PODF_MASK (0x3F << 21) #define MXC_CCM_CS2CDR_ENFC_CLK_PODF_OFFSET 21 #define MXC_CCM_CS2CDR_ENFC_CLK_PODF(v) (((v) & 0x3f) << 21) @@ -262,6 +317,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CS2CDR_ENFC_CLK_SEL_MASK (0x3 << 16) #define MXC_CCM_CS2CDR_ENFC_CLK_SEL_OFFSET 16 #define MXC_CCM_CS2CDR_ENFC_CLK_SEL(v) (((v) & 0x3) << 16) +#endif #define MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK (0x7 << 12) #define MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET 12 #define MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK (0x7 << 9) @@ -272,9 +328,11 @@ struct mxc_ccm_reg { #define MXC_CCM_CS2CDR_SSI2_CLK_PODF_OFFSET 0
/* Define the bits in register CDCDR */ +#ifndef CONFIG_MX6SX #define MXC_CCM_CDCDR_HSI_TX_PODF_MASK (0x7 << 29) #define MXC_CCM_CDCDR_HSI_TX_PODF_OFFSET 29 #define MXC_CCM_CDCDR_HSI_TX_CLK_SEL (1 << 28) +#endif #define MXC_CCM_CDCDR_SPDIF0_CLK_PRED_MASK (0x7 << 25) #define MXC_CCM_CDCDR_SPDIF0_CLK_PRED_OFFSET 25 #define MXC_CCM_CDCDR_SPDIF0_CLK_PODF_MASK (0x7 << 19) @@ -289,6 +347,20 @@ struct mxc_ccm_reg { #define MXC_CCM_CDCDR_SPDIF1_CLK_SEL_OFFSET 7
/* Define the bits in register CHSCCDR */ +#ifdef CONFIG_MX6SX +#define MXC_CCM_CHSCCDR_ENET_PRE_CLK_SEL_MASK (0x7 << 15) +#define MXC_CCM_CHSCCDR_ENET_PRE_CLK_SEL_OFFSET 15 +#define MXC_CCM_CHSCCDR_ENET_PODF_MASK (0x7 << 12) +#define MXC_CCM_CHSCCDR_ENET_PODF_OFFSET 12 +#define MXC_CCM_CHSCCDR_ENET_CLK_SEL_MASK (0x7 << 9) +#define MXC_CCM_CHSCCDR_ENET_CLK_SEL_OFFSET 9 +#define MXC_CCM_CHSCCDR_M4_PRE_CLK_SEL_MASK (0x7 << 6) +#define MXC_CCM_CHSCCDR_M4_PRE_CLK_SEL_OFFSET 6 +#define MXC_CCM_CHSCCDR_M4_PODF_MASK (0x7 << 3) +#define MXC_CCM_CHSCCDR_M4_PODF_OFFSET 3 +#define MXC_CCM_CHSCCDR_M4_CLK_SEL_MASK (0x7) +#define MXC_CCM_CHSCCDR_M4_CLK_SEL_OFFSET 0 +#else #define MXC_CCM_CHSCCDR_IPU1_DI1_PRE_CLK_SEL_MASK (0x7 << 15) #define MXC_CCM_CHSCCDR_IPU1_DI1_PRE_CLK_SEL_OFFSET 15 #define MXC_CCM_CHSCCDR_IPU1_DI1_PODF_MASK (0x7 << 12) @@ -301,6 +373,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET 3 #define MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK (0x7) #define MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET 0 +#endif
#define CHSCCDR_CLK_SEL_LDB_DI0 3 #define CHSCCDR_PODF_DIVIDE_BY_3 2 @@ -309,12 +382,14 @@ struct mxc_ccm_reg { /* Define the bits in register CSCDR2 */ #define MXC_CCM_CSCDR2_ECSPI_CLK_PODF_MASK (0x3F << 19) #define MXC_CCM_CSCDR2_ECSPI_CLK_PODF_OFFSET 19 +/* All IPU2_DI1 are LCDIF1 on MX6SX */ #define MXC_CCM_CHSCCDR_IPU2_DI1_PRE_CLK_SEL_MASK (0x7 << 15) #define MXC_CCM_CHSCCDR_IPU2_DI1_PRE_CLK_SEL_OFFSET 15 #define MXC_CCM_CHSCCDR_IPU2_DI1_PODF_MASK (0x7 << 12) #define MXC_CCM_CHSCCDR_IPU2_DI1_PODF_OFFSET 12 #define MXC_CCM_CHSCCDR_IPU2_DI1_CLK_SEL_MASK (0x7 << 9) #define MXC_CCM_CHSCCDR_IPU2_DI1_CLK_SEL_OFFSET 9 +/* All IPU2_DI0 are LCDIF2 on MX6SX */ #define MXC_CCM_CHSCCDR_IPU2_DI0_PRE_CLK_SEL_MASK (0x7 << 6) #define MXC_CCM_CHSCCDR_IPU2_DI0_PRE_CLK_SEL_OFFSET 6 #define MXC_CCM_CHSCCDR_IPU2_DI0_PODF_MASK (0x7 << 3) @@ -335,7 +410,9 @@ struct mxc_ccm_reg { /* Define the bits in register CDHIPR */ #define MXC_CCM_CDHIPR_ARM_PODF_BUSY (1 << 16) #define MXC_CCM_CDHIPR_PERIPH_CLK_SEL_BUSY (1 << 5) +#ifndef CONFIG_MX6SX #define MXC_CCM_CDHIPR_MMDC_CH0_PODF_BUSY (1 << 4) +#endif #define MXC_CCM_CDHIPR_PERIPH2_CLK_SEL_BUSY (1 << 3) #define MXC_CCM_CDHIPR_MMDC_CH1_PODF_BUSY (1 << 2) #define MXC_CCM_CDHIPR_AHB_PODF_BUSY (1 << 1) @@ -344,13 +421,17 @@ struct mxc_ccm_reg { /* Define the bits in register CLPCR */ #define MXC_CCM_CLPCR_MASK_L2CC_IDLE (1 << 27) #define MXC_CCM_CLPCR_MASK_SCU_IDLE (1 << 26) +#ifndef CONFIG_MX6SX #define MXC_CCM_CLPCR_MASK_CORE3_WFI (1 << 25) #define MXC_CCM_CLPCR_MASK_CORE2_WFI (1 << 24) #define MXC_CCM_CLPCR_MASK_CORE1_WFI (1 << 23) +#endif #define MXC_CCM_CLPCR_MASK_CORE0_WFI (1 << 22) #define MXC_CCM_CLPCR_BYP_MMDC_CH1_LPM_HS (1 << 21) +#ifndef CONFIG_MX6SX #define MXC_CCM_CLPCR_BYP_MMDC_CH0_LPM_HS (1 << 19) #define MXC_CCM_CLPCR_WB_CORE_AT_LPM (1 << 17) +#endif #define MXC_CCM_CLPCR_WB_PER_AT_LPM (1 << 17) #define MXC_CCM_CLPCR_COSC_PWRDOWN (1 << 11) #define MXC_CCM_CLPCR_STBY_COUNT_MASK (0x3 << 9) @@ -359,15 +440,19 @@ struct mxc_ccm_reg { #define MXC_CCM_CLPCR_DIS_REF_OSC (1 << 7) #define MXC_CCM_CLPCR_SBYOS (1 << 6) #define MXC_CCM_CLPCR_ARM_CLK_DIS_ON_LPM (1 << 5) +#ifndef CONFIG_MX6SX #define MXC_CCM_CLPCR_LPSR_CLK_SEL_MASK (0x3 << 3) #define MXC_CCM_CLPCR_LPSR_CLK_SEL_OFFSET 3 #define MXC_CCM_CLPCR_BYPASS_PMIC_VFUNC_READY (1 << 2) +#endif #define MXC_CCM_CLPCR_LPM_MASK 0x3 #define MXC_CCM_CLPCR_LPM_OFFSET 0
/* Define the bits in register CISR */ #define MXC_CCM_CISR_ARM_PODF_LOADED (1 << 26) +#ifndef CONFIG_MX6SX #define MXC_CCM_CISR_MMDC_CH0_PODF_LOADED (1 << 23) +#endif #define MXC_CCM_CISR_PERIPH_CLK_SEL_LOADED (1 << 22) #define MXC_CCM_CISR_MMDC_CH1_PODF_LOADED (1 << 21) #define MXC_CCM_CISR_AHB_PODF_LOADED (1 << 20) @@ -378,7 +463,9 @@ struct mxc_ccm_reg {
/* Define the bits in register CIMR */ #define MXC_CCM_CIMR_MASK_ARM_PODF_LOADED (1 << 26) +#ifndef CONFIG_MX6SX #define MXC_CCM_CIMR_MASK_MMDC_CH0_PODF_LOADED (1 << 23) +#endif #define MXC_CCM_CIMR_MASK_PERIPH_CLK_SEL_LOADED (1 << 22) #define MXC_CCM_CIMR_MASK_MMDC_CH1_PODF_LOADED (1 << 21) #define MXC_CCM_CIMR_MASK_AHB_PODF_LOADED (1 << 20) @@ -393,6 +480,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CCOSR_CKO2_DIV_OFFSET 21 #define MXC_CCM_CCOSR_CKO2_SEL_OFFSET 16 #define MXC_CCM_CCOSR_CKO2_SEL_MASK (0x1F << 16) +#define MXC_CCM_CCOSR_CLK_OUT_SEL (0x1 << 8) #define MXC_CCM_CCOSR_CKOL_EN (0x1 << 7) #define MXC_CCM_CCOSR_CKOL_DIV_MASK (0x7 << 4) #define MXC_CCM_CCOSR_CKOL_DIV_OFFSET 4 @@ -400,6 +488,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CCOSR_CKOL_SEL_OFFSET 0
/* Define the bits in registers CGPR */ +#define MXC_CCM_CGPR_FAST_PLL_EN (1 << 16) #define MXC_CCM_CGPR_EFUSE_PROG_SUPPLY_GATE (1 << 4) #define MXC_CCM_CGPR_MMDC_EXT_CLK_DIS (1 << 2) #define MXC_CCM_CGPR_PMIC_DELAY_SCALER 1 @@ -435,8 +524,13 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR0_DCIC1_MASK (3 << MXC_CCM_CCGR0_DCIC1_OFFSET) #define MXC_CCM_CCGR0_DCIC2_OFFSET 26 #define MXC_CCM_CCGR0_DCIC2_MASK (3 << MXC_CCM_CCGR0_DCIC2_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR0_AIPS_TZ3_OFFSET 30 +#define MXC_CCM_CCGR0_AIPS_TZ3_MASK (3 << MXC_CCM_CCGR0_AIPS_TZ3_OFFSET) +#else #define MXC_CCM_CCGR0_DTCP_OFFSET 28 #define MXC_CCM_CCGR0_DTCP_MASK (3 << MXC_CCM_CCGR0_DTCP_OFFSET) +#endif
#define MXC_CCM_CCGR1_ECSPI1S_OFFSET 0 #define MXC_CCM_CCGR1_ECSPI1S_MASK (3 << MXC_CCM_CCGR1_ECSPI1S_OFFSET) @@ -448,27 +542,48 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR1_ECSPI4S_MASK (3 << MXC_CCM_CCGR1_ECSPI4S_OFFSET) #define MXC_CCM_CCGR1_ECSPI5S_OFFSET 8 #define MXC_CCM_CCGR1_ECSPI5S_MASK (3 << MXC_CCM_CCGR1_ECSPI5S_OFFSET) +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR1_ENET_CLK_ENABLE_OFFSET 10 #define MXC_CCM_CCGR1_ENET_CLK_ENABLE_MASK (3 << MXC_CCM_CCGR1_ENET_CLK_ENABLE_OFFSET) +#endif #define MXC_CCM_CCGR1_EPIT1S_OFFSET 12 #define MXC_CCM_CCGR1_EPIT1S_MASK (3 << MXC_CCM_CCGR1_EPIT1S_OFFSET) #define MXC_CCM_CCGR1_EPIT2S_OFFSET 14 #define MXC_CCM_CCGR1_EPIT2S_MASK (3 << MXC_CCM_CCGR1_EPIT2S_OFFSET) #define MXC_CCM_CCGR1_ESAIS_OFFSET 16 #define MXC_CCM_CCGR1_ESAIS_MASK (3 << MXC_CCM_CCGR1_ESAIS_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR1_WAKEUP_OFFSET 18 +#define MXC_CCM_CCGR1_WAKEUP_MASK (3 << MXC_CCM_CCGR1_WAKEUP_OFFSET) +#endif #define MXC_CCM_CCGR1_GPT_BUS_OFFSET 20 #define MXC_CCM_CCGR1_GPT_BUS_MASK (3 << MXC_CCM_CCGR1_GPT_BUS_OFFSET) #define MXC_CCM_CCGR1_GPT_SERIAL_OFFSET 22 #define MXC_CCM_CCGR1_GPT_SERIAL_MASK (3 << MXC_CCM_CCGR1_GPT_SERIAL_OFFSET) +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR1_GPU2D_OFFSET 24 #define MXC_CCM_CCGR1_GPU2D_MASK (3 << MXC_CCM_CCGR1_GPU2D_OFFSET) +#endif #define MXC_CCM_CCGR1_GPU3D_OFFSET 26 #define MXC_CCM_CCGR1_GPU3D_MASK (3 << MXC_CCM_CCGR1_GPU3D_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR1_OCRAM_S_OFFSET 28 +#define MXC_CCM_CCGR1_OCRAM_S_MASK (3 << MXC_CCM_CCGR1_OCRAM_S_OFFSET) +#define MXC_CCM_CCGR1_CANFD_OFFSET 30 +#define MXC_CCM_CCGR1_CANFD_MASK (3 << MXC_CCM_CCGR1_CANFD_OFFSET) +#endif
+#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_OFFSET 0 #define MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK (3 << MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_OFFSET) +#else +#define MXC_CCM_CCGR2_CSI_OFFSET 2 +#define MXC_CCM_CCGR2_CSI_MASK (3 << MXC_CCM_CCGR2_CSI_OFFSET) +#endif +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_OFFSET 4 #define MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK (3 << MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_OFFSET) +#endif #define MXC_CCM_CCGR2_I2C1_SERIAL_OFFSET 6 #define MXC_CCM_CCGR2_I2C1_SERIAL_MASK (3 << MXC_CCM_CCGR2_I2C1_SERIAL_OFFSET) #define MXC_CCM_CCGR2_I2C2_SERIAL_OFFSET 8 @@ -487,17 +602,33 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR2_IPMUX3_MASK (3 << MXC_CCM_CCGR2_IPMUX3_OFFSET) #define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_OFFSET 22 #define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_MASK (3 << MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR2_LCD_OFFSET 28 +#define MXC_CCM_CCGR2_LCD_MASK (3 << MXC_CCM_CCGR2_LCD_OFFSET) +#define MXC_CCM_CCGR2_PXP_OFFSET 30 +#define MXC_CCM_CCGR2_PXP_MASK (3 << MXC_CCM_CCGR2_PXP_OFFSET) +#else #define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_OFFSET 24 #define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_MASK (3 << MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_OFFSET) #define MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_OFFSET 26 #define MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_MASK (3 << MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_OFFSET) +#endif
+#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR3_M4_OFFSET 2 +#define MXC_CCM_CCGR3_M4_MASK (3 << MXC_CCM_CCGR3_M4_OFFSET) +#define MXC_CCM_CCGR3_ENET_OFFSET 4 +#define MXC_CCM_CCGR3_ENET_MASK (3 << MXC_CCM_CCGR3_ENET_OFFSET) +#define MXC_CCM_CCGR3_QSPI_OFFSET 14 +#define MXC_CCM_CCGR3_QSPI_MASK (3 << MXC_CCM_CCGR3_QSPI_OFFSET) +#else #define MXC_CCM_CCGR3_IPU1_IPU_OFFSET 0 #define MXC_CCM_CCGR3_IPU1_IPU_MASK (3 << MXC_CCM_CCGR3_IPU1_IPU_OFFSET) #define MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET 2 #define MXC_CCM_CCGR3_IPU1_IPU_DI0_MASK (3 << MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET) #define MXC_CCM_CCGR3_IPU1_IPU_DI1_OFFSET 4 #define MXC_CCM_CCGR3_IPU1_IPU_DI1_MASK (3 << MXC_CCM_CCGR3_IPU1_IPU_DI1_OFFSET) +#endif #define MXC_CCM_CCGR3_IPU2_IPU_OFFSET 6 #define MXC_CCM_CCGR3_IPU2_IPU_MASK (3 << MXC_CCM_CCGR3_IPU2_IPU_OFFSET) #define MXC_CCM_CCGR3_IPU2_IPU_DI0_OFFSET 8 @@ -506,29 +637,43 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR3_IPU2_IPU_DI1_MASK (3 << MXC_CCM_CCGR3_IPU2_IPU_DI1_OFFSET) #define MXC_CCM_CCGR3_LDB_DI0_OFFSET 12 #define MXC_CCM_CCGR3_LDB_DI0_MASK (3 << MXC_CCM_CCGR3_LDB_DI0_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR3_QSPI1_OFFSET 14 +#define MXC_CCM_CCGR3_QSPI1_MASK (3 << MXC_CCM_CCGR3_QSPI1_OFFSET) +#else #define MXC_CCM_CCGR3_LDB_DI1_OFFSET 14 #define MXC_CCM_CCGR3_LDB_DI1_MASK (3 << MXC_CCM_CCGR3_LDB_DI1_OFFSET) #define MXC_CCM_CCGR3_MIPI_CORE_CFG_OFFSET 16 #define MXC_CCM_CCGR3_MIPI_CORE_CFG_MASK (3 << MXC_CCM_CCGR3_MIPI_CORE_CFG_OFFSET) +#endif #define MXC_CCM_CCGR3_MLB_OFFSET 18 #define MXC_CCM_CCGR3_MLB_MASK (3 << MXC_CCM_CCGR3_MLB_OFFSET) #define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_OFFSET 20 #define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_MASK (3 << MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_OFFSET) +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_OFFSET 22 #define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_MASK (3 << MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_OFFSET) +#endif #define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_OFFSET 24 #define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_MASK (3 << MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_OFFSET) #define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_OFFSET 26 #define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_MASK (3 << MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_OFFSET) #define MXC_CCM_CCGR3_OCRAM_OFFSET 28 #define MXC_CCM_CCGR3_OCRAM_MASK (3 << MXC_CCM_CCGR3_OCRAM_OFFSET) +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR3_OPENVGAXICLK_OFFSET 30 #define MXC_CCM_CCGR3_OPENVGAXICLK_MASK (3 << MXC_CCM_CCGR3_OPENVGAXICLK_OFFSET) +#endif
#define MXC_CCM_CCGR4_PCIE_OFFSET 0 #define MXC_CCM_CCGR4_PCIE_MASK (3 << MXC_CCM_CCGR4_PCIE_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR4_QSPI2_ENFC_OFFSET 10 +#define MXC_CCM_CCGR4_QSPI2_ENFC_MASK (3 << MXC_CCM_CCGR4_QSPI2_ENFC_OFFSET) +#else #define MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_OFFSET 8 #define MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_MASK (3 << MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_OFFSET) +#endif #define MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET 12 #define MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_MASK (3 << MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET) #define MXC_CCM_CCGR4_PL301_MX6QPER2_MAINCLK_ENABLE_OFFSET 14 @@ -552,8 +697,10 @@ struct mxc_ccm_reg {
#define MXC_CCM_CCGR5_ROM_OFFSET 0 #define MXC_CCM_CCGR5_ROM_MASK (3 << MXC_CCM_CCGR5_ROM_OFFSET) +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR5_SATA_OFFSET 4 #define MXC_CCM_CCGR5_SATA_MASK (3 << MXC_CCM_CCGR5_SATA_OFFSET) +#endif #define MXC_CCM_CCGR5_SDMA_OFFSET 6 #define MXC_CCM_CCGR5_SDMA_MASK (3 << MXC_CCM_CCGR5_SDMA_OFFSET) #define MXC_CCM_CCGR5_SPBA_OFFSET 12 @@ -570,6 +717,12 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR5_UART_MASK (3 << MXC_CCM_CCGR5_UART_OFFSET) #define MXC_CCM_CCGR5_UART_SERIAL_OFFSET 26 #define MXC_CCM_CCGR5_UART_SERIAL_MASK (3 << MXC_CCM_CCGR5_UART_SERIAL_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR5_SAI1_OFFSET 20 +#define MXC_CCM_CCGR5_SAI1_MASK (3 << MXC_CCM_CCGR5_SAI1_OFFSET) +#define MXC_CCM_CCGR5_SAI2_OFFSET 30 +#define MXC_CCM_CCGR5_SAI2_MASK (3 << MXC_CCM_CCGR5_SAI2_OFFSET) +#endif
#define MXC_CCM_CCGR6_USBOH3_OFFSET 0 #define MXC_CCM_CCGR6_USBOH3_MASK (3 << MXC_CCM_CCGR6_USBOH3_OFFSET) @@ -583,8 +736,25 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR6_USDHC4_MASK (3 << MXC_CCM_CCGR6_USDHC4_OFFSET) #define MXC_CCM_CCGR6_EMI_SLOW_OFFSET 10 #define MXC_CCM_CCGR6_EMI_SLOW_MASK (3 << MXC_CCM_CCGR6_EMI_SLOW_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR6_PWM8_OFFSET 16 +#define MXC_CCM_CCGR6_PWM8_MASK (3 << MXC_CCM_CCGR6_PWM8_OFFSET) +#define MXC_CCM_CCGR6_VADC_OFFSET 20 +#define MXC_CCM_CCGR6_VADC_MASK (3 << MXC_CCM_CCGR6_VADC_OFFSET) +#define MXC_CCM_CCGR6_GIS_OFFSET 22 +#define MXC_CCM_CCGR6_GIS_MASK (3 << MXC_CCM_CCGR6_GIS_OFFSET) +#define MXC_CCM_CCGR6_I2C4_OFFSET 24 +#define MXC_CCM_CCGR6_I2C4_MASK (3 << MXC_CCM_CCGR6_I2C4_OFFSET) +#define MXC_CCM_CCGR6_PWM5_OFFSET 26 +#define MXC_CCM_CCGR6_PWM5_MASK (3 << MXC_CCM_CCGR6_PWM5_OFFSET) +#define MXC_CCM_CCGR6_PWM6_OFFSET 28 +#define MXC_CCM_CCGR6_PWM6_MASK (3 << MXC_CCM_CCGR6_PWM6_OFFSET) +#define MXC_CCM_CCGR6_PWM7_OFFSET 30 +#define MXC_CCM_CCGR6_PWM7_MASK (3 << MXC_CCM_CCGR6_PWM7_OFFSET) +#else #define MXC_CCM_CCGR6_VDOAXICLK_OFFSET 12 #define MXC_CCM_CCGR6_VDOAXICLK_MASK (3 << MXC_CCM_CCGR6_VDOAXICLK_OFFSET) +#endif
#define BM_ANADIG_PLL_SYS_LOCK 0x80000000 #define BP_ANADIG_PLL_SYS_RSVD0 20 diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 1f19727..b47e039 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -19,6 +19,19 @@ #define GPU_2D_ARB_END_ADDR 0x02203FFF #define OPENVG_ARB_BASE_ADDR 0x02204000 #define OPENVG_ARB_END_ADDR 0x02207FFF +#elif CONFIG_MX6SX +#define CAAM_ARB_BASE_ADDR 0x00100000 +#define CAAM_ARB_END_ADDR 0x00107FFF +#define GPU_ARB_BASE_ADDR 0x01800000 +#define GPU_ARB_END_ADDR 0x01803FFF +#define APBH_DMA_ARB_BASE_ADDR 0x01804000 +#define APBH_DMA_ARB_END_ADDR 0x0180BFFF +#define M4_BOOTROM_BASE_ADDR 0x007F8000 + +#define MXS_APBH_BASE APBH_DMA_ARB_BASE_ADDR +#define MXS_GPMI_BASE (APBH_DMA_ARB_BASE_ADDR + 0x02000) +#define MXS_BCH_BASE (APBH_DMA_ARB_BASE_ADDR + 0x04000) + #else #define CAAM_ARB_BASE_ADDR 0x00100000 #define CAAM_ARB_END_ADDR 0x00103FFF @@ -39,14 +52,27 @@ #define MXS_BCH_BASE (APBH_DMA_ARB_BASE_ADDR + 0x04000)
/* GPV - PL301 configuration ports */ -#ifdef CONFIG_MX6SL +#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX)) #define GPV2_BASE_ADDR 0x00D00000 #else #define GPV2_BASE_ADDR 0x00200000 #endif
+#ifdef CONFIG_MX6SX +#define GPV3_BASE_ADDR 0x00E00000 +#define GPV4_BASE_ADDR 0x00F00000 +#define GPV5_BASE_ADDR 0x01000000 +#define GPV6_BASE_ADDR 0x01100000 +#define PCIE_ARB_BASE_ADDR 0x08000000 +#define PCIE_ARB_END_ADDR 0x08FFFFFF + +#else #define GPV3_BASE_ADDR 0x00300000 #define GPV4_BASE_ADDR 0x00800000 +#define PCIE_ARB_BASE_ADDR 0x01000000 +#define PCIE_ARB_END_ADDR 0x01FFFFFF +#endif + #define IRAM_BASE_ADDR 0x00900000 #define SCU_BASE_ADDR 0x00A00000 #define IC_INTERFACES_BASE_ADDR 0x00A00100 @@ -56,13 +82,21 @@ #define L2_PL310_BASE 0x00A02000 #define GPV0_BASE_ADDR 0x00B00000 #define GPV1_BASE_ADDR 0x00C00000 -#define PCIE_ARB_BASE_ADDR 0x01000000 -#define PCIE_ARB_END_ADDR 0x01FFFFFF
#define AIPS1_ARB_BASE_ADDR 0x02000000 #define AIPS1_ARB_END_ADDR 0x020FFFFF #define AIPS2_ARB_BASE_ADDR 0x02100000 #define AIPS2_ARB_END_ADDR 0x021FFFFF +#ifdef CONFIG_MX6SX +#define AIPS3_BASE_ADDR 0x02200000 +#define AIPS3_END_ADDR 0x022FFFFF +#define WEIM_ARB_BASE_ADDR 0x50000000 +#define WEIM_ARB_END_ADDR 0x57FFFFFF +#define QSPI1_ARB_BASE_ADDR 0x60000000 +#define QSPI1_ARB_END_ADDR 0x6FFFFFFF +#define QSPI2_ARB_BASE_ADDR 0x70000000 +#define QSPI2_ARB_END_ADDR 0x7FFFFFFF +#else #define SATA_ARB_BASE_ADDR 0x02200000 #define SATA_ARB_END_ADDR 0x02203FFF #define OPENVG_ARB_BASE_ADDR 0x02204000 @@ -75,8 +109,9 @@ #define IPU2_ARB_END_ADDR 0x02BFFFFF #define WEIM_ARB_BASE_ADDR 0x08000000 #define WEIM_ARB_END_ADDR 0x0FFFFFFF +#endif
-#ifdef CONFIG_MX6SL +#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX)) #define MMDC0_ARB_BASE_ADDR 0x80000000 #define MMDC0_ARB_END_ADDR 0xFFFFFFFF #define MMDC1_ARB_BASE_ADDR 0xC0000000 @@ -88,8 +123,10 @@ #define MMDC1_ARB_END_ADDR 0xFFFFFFFF #endif
+#ifndef CONFIG_MX6SX #define IPU_SOC_BASE_ADDR IPU1_ARB_BASE_ADDR #define IPU_SOC_OFFSET 0x00200000 +#endif
/* Defines for Blocks connected via AIPS (SkyBlue) */ #define ATZ1_BASE_ADDR AIPS1_ARB_BASE_ADDR @@ -112,7 +149,9 @@ #define UART3_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x34000) #define UART4_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x38000) #else +#ifndef CONFIG_MX6SX #define ECSPI5_BASE_ADDR (ATZ1_BASE_ADDR + 0x18000) +#endif #define UART1_BASE (ATZ1_BASE_ADDR + 0x20000) #define ESAI1_BASE_ADDR (ATZ1_BASE_ADDR + 0x24000) #define SSI1_BASE_ADDR (ATZ1_BASE_ADDR + 0x28000) @@ -121,8 +160,10 @@ #define ASRC_BASE_ADDR (ATZ1_BASE_ADDR + 0x34000) #endif
+#ifndef CONFIG_MX6SX #define SPBA_BASE_ADDR (ATZ1_BASE_ADDR + 0x3C000) #define VPU_BASE_ADDR (ATZ1_BASE_ADDR + 0x40000) +#endif #define AIPS1_ON_BASE_ADDR (ATZ1_BASE_ADDR + 0x7C000)
#define AIPS1_OFF_BASE_ADDR (ATZ1_BASE_ADDR + 0x80000) @@ -157,6 +198,13 @@ #define CSI_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x64000) #define SIPIX_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x68000) #define SDMA_PORT_HOST_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x6C000) +#elif CONFIG_MX6SX +#define CANFD1_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x68000) +#define SDMA_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x6C000) +#define CANFD2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x70000) +#define SEMAPHORE1_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x74000) +#define SEMAPHORE2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x78000) +#define RDC_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x7C000) #else #define DCIC1_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x64000) #define DCIC2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x68000) @@ -193,6 +241,8 @@ #define MMDC_P0_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x30000) #ifdef CONFIG_MX6SL #define RNGB_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x34000) +#elif CONFIG_MX6SX +#define ENET2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x34000) #else #define MMDC_P1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x34000) #endif @@ -202,13 +252,28 @@ #define CSU_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x40000) #define IP2APB_PERFMON1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x44000) #define IP2APB_PERFMON2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x48000) +#ifdef CONFIG_MX6SX +#define DEBUG_MONITOR_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x4C000) +#else #define IP2APB_PERFMON3_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x4C000) +#endif #define IP2APB_TZASC1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x50000) +#ifdef CONFIG_MX6SX +#define SAI1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x54000) +#else #define IP2APB_TZASC2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x54000) +#endif #define AUDMUX_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x58000) +#define AUDMUX_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x58000) +#ifdef CONFIG_MX6SX +#define SAI2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x5C000) +#define QSPI1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x60000) +#define QSPI2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x64000) +#else #define MIPI_CSI2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x5C000) #define MIPI_DSI_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x60000) #define VDOA_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x64000) +#endif #define UART2_BASE (AIPS2_OFF_BASE_ADDR + 0x68000) #define UART3_BASE (AIPS2_OFF_BASE_ADDR + 0x6C000) #define UART4_BASE (AIPS2_OFF_BASE_ADDR + 0x70000) @@ -216,8 +281,40 @@ #define IP2APB_USBPHY1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x78000) #define IP2APB_USBPHY2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x7C000)
+#ifdef CONFIG_MX6SX +#define GIS_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x04000) +#define DCIC1_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x0C000) +#define DCIC2_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x10000) +#define CSI1_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x14000) +#define PXP_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x18000) +#define CSI2_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x1C000) +#define LCDIF1_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x20000) +#define LCDIF2_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x24000) +#define VADC_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x28000) +#define VDEC_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x2C000) +#define SPBA_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x3C000) +#define AIPS3_CONFIG_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x7C000) +#define ADC1_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x80000) +#define ADC2_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x84000) +#define WDOG3_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x88000) +#define ECSPI5_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x8C000) +#define HS_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x90000) +#define MU_MCU_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x94000) +#define CANFD_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x98000) +#define MU_DSP_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x9C000) +#define UART6_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xA0000) +#define PWM5_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xA4000) +#define PWM6_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xA8000) +#define PWM7_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xAC000) +#define PWM8_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xB0000) +#endif + #define CHIP_REV_1_0 0x10 +#ifndef CONFIG_MX6SX #define IRAM_SIZE 0x00040000 +#else +#define IRAM_SIZE 0x00020000 +#endif #define FEC_QUIRK_ENET_MAC
#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) @@ -471,6 +568,22 @@ struct fuse_bank0_regs { u32 rsvd7[4]; };
+#ifdef CONFIG_MX6SX +struct fuse_bank4_regs { + u32 sjc_resp_low; + u32 rsvd0[3]; + u32 sjc_resp_high; + u32 rsvd1[3]; + u32 mac_addr_low; + u32 rsvd2[3]; + u32 mac_addr_high; + u32 rsvd3[3]; + u32 mac_addr2; + u32 rsvd4[7]; + u32 gp1; + u32 rsvd5[7]; +}; +#else struct fuse_bank4_regs { u32 sjc_resp_low; u32 rsvd0[3]; @@ -485,6 +598,7 @@ struct fuse_bank4_regs { u32 gp2; u32 rsvd5[3]; }; +#endif
struct aipstz_regs { u32 mprot0; diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h index d544d2e..5ebabfa 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-ddr.h +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -13,7 +13,11 @@ #if defined(CONFIG_MX6DL) || defined(CONFIG_MX6S) #include "mx6dl-ddr.h" #else +#ifdef CONFIG_MX6SX +#include "mx6sx-ddr.h" +#else #error "Please select cpu" +#endif /* CONFIG_MX6SX */ #endif /* CONFIG_MX6DL or CONFIG_MX6S */ #endif /* CONFIG_MX6Q */ #else diff --git a/arch/arm/include/asm/arch-mx6/mx6sx-ddr.h b/arch/arm/include/asm/arch-mx6/mx6sx-ddr.h new file mode 100644 index 0000000..2cc94aa --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6sx-ddr.h @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARCH_MX6SX_DDR_H__ +#define __ASM_ARCH_MX6SX_DDR_H__ + +#ifndef CONFIG_MX6SX +#error "wrong CPU" +#endif + +#define MX6_IOM_DRAM_DQM0 0x020e02ec +#define MX6_IOM_DRAM_DQM1 0x020e02f0 +#define MX6_IOM_DRAM_DQM2 0x020e02f4 +#define MX6_IOM_DRAM_DQM3 0x020e02f8 + +#define MX6_IOM_DRAM_RAS 0x020e02fc +#define MX6_IOM_DRAM_CAS 0x020e0300 +#define MX6_IOM_DRAM_SDODT0 0x020e0310 +#define MX6_IOM_DRAM_SDODT1 0x020e0314 +#define MX6_IOM_DRAM_SDBA2 0x020e0320 +#define MX6_IOM_DRAM_SDCKE0 0x020e0324 +#define MX6_IOM_DRAM_SDCKE1 0x020e0328 +#define MX6_IOM_DRAM_SDCLK_0 0x020e032c +#define MX6_IOM_DRAM_RESET 0x020e0340 + +#define MX6_IOM_DRAM_SDQS0 0x020e0330 +#define MX6_IOM_DRAM_SDQS1 0x020e0334 +#define MX6_IOM_DRAM_SDQS2 0x020e0338 +#define MX6_IOM_DRAM_SDQS3 0x020e033c + +#define MX6_IOM_GRP_ADDDS 0x020e05f4 +#define MX6_IOM_DDRMODE_CTL 0x020e05f8 +#define MX6_IOM_GRP_DDRPKE 0x020e05fc +#define MX6_IOM_GRP_DDRMODE 0x020e0608 +#define MX6_IOM_GRP_B0DS 0x020e060c +#define MX6_IOM_GRP_B1DS 0x020e0610 +#define MX6_IOM_GRP_CTLDS 0x020e0614 +#define MX6_IOM_GRP_DDR_TYPE 0x020e0618 +#define MX6_IOM_GRP_B2DS 0x020e061c +#define MX6_IOM_GRP_B3DS 0x020e0620 + +#endif /*__ASM_ARCH_MX6SX_DDR_H__ */
Add the pin definitions for mx6sx.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/include/asm/arch-mx6/mx6-pins.h | 2 + arch/arm/include/asm/arch-mx6/mx6sx_pins.h | 1675 ++++++++++++++++++++++++++++ 2 files changed, 1677 insertions(+) create mode 100644 arch/arm/include/asm/arch-mx6/mx6sx_pins.h
diff --git a/arch/arm/include/asm/arch-mx6/mx6-pins.h b/arch/arm/include/asm/arch-mx6/mx6-pins.h index dcd7f8f..534f780 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6-pins.h @@ -35,6 +35,8 @@ enum { }; #elif defined(CONFIG_MX6SL) #include "mx6sl_pins.h" +#elif defined(CONFIG_MX6SX) +#include "mx6sx_pins.h" #else #error "Please select cpu" #endif /* CONFIG_MX6Q */ diff --git a/arch/arm/include/asm/arch-mx6/mx6sx_pins.h b/arch/arm/include/asm/arch-mx6/mx6sx_pins.h new file mode 100644 index 0000000..7c6c1e8 --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6sx_pins.h @@ -0,0 +1,1675 @@ +/* + * Copyright (C) 2014 Freescale Semiconductor, Inc. All Rights Reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARCH_MX6_MX6_PINS_H__ +#define __ASM_ARCH_MX6_MX6_PINS_H__ + +#include <asm/imx-common/iomux-v3.h> + +enum { + MX6_PAD_GPIO1_IO00__I2C1_SCL = IOMUX_PAD(0x035C, 0x0014, IOMUX_CONFIG_SION | 0, 0x07A8, 1, 0), + MX6_PAD_GPIO1_IO00__USDHC1_VSELECT = IOMUX_PAD(0x035C, 0x0014, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO00__SPDIF_LOCK = IOMUX_PAD(0x035C, 0x0014, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO00__CCM_WAIT = IOMUX_PAD(0x035C, 0x0014, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO00__WDOG1_WDOG_ANY = IOMUX_PAD(0x035C, 0x0014, 4, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO00__GPIO1_IO_0 = IOMUX_PAD(0x035C, 0x0014, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO00__SNVS_HP_WRAPPER_VIO_5 = IOMUX_PAD(0x035C, 0x0014, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO00__PHY_DTB_1 = IOMUX_PAD(0x035C, 0x0014, 7, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO01__I2C1_SDA = IOMUX_PAD(0x0360, 0x0018, IOMUX_CONFIG_SION | 0, 0x07AC, 1, 0), + MX6_PAD_GPIO1_IO01__USDHC1_RESET_B = IOMUX_PAD(0x0360, 0x0018, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO01__SPDIF_SR_CLK = IOMUX_PAD(0x0360, 0x0018, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO01__CCM_STOP = IOMUX_PAD(0x0360, 0x0018, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO01__WDOG3_WDOG_B = IOMUX_PAD(0x0360, 0x0018, 4, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO01__GPIO1_IO_1 = IOMUX_PAD(0x0360, 0x0018, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO01__SNVS_HP_WRAPPER_VIO_5_CTL = IOMUX_PAD(0x0360, 0x0018, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO01__PHY_DTB_0 = IOMUX_PAD(0x0360, 0x0018, 7, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO02__I2C2_SCL = IOMUX_PAD(0x0364, 0x001C, IOMUX_CONFIG_SION | 0, 0x07B0, 1, 0), + MX6_PAD_GPIO1_IO02__USDHC1_CD_B = IOMUX_PAD(0x0364, 0x001C, 1, 0x0864, 1, 0), + MX6_PAD_GPIO1_IO02__CSI2_MCLK = IOMUX_PAD(0x0364, 0x001C, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO02__CCM_DI0_EXT_CLK = IOMUX_PAD(0x0364, 0x001C, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO02__WDOG1_WDOG_B = IOMUX_PAD(0x0364, 0x001C, 4, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO02__GPIO1_IO_2 = IOMUX_PAD(0x0364, 0x001C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO02__CCM_REF_EN_B = IOMUX_PAD(0x0364, 0x001C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO02__PHY_TDI = IOMUX_PAD(0x0364, 0x001C, 7, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO03__I2C2_SDA = IOMUX_PAD(0x0368, 0x0020, IOMUX_CONFIG_SION | 0, 0x07B4, 1, 0), + MX6_PAD_GPIO1_IO03__USDHC1_WP = IOMUX_PAD(0x0368, 0x0020, 1, 0x0868, 1, 0), + MX6_PAD_GPIO1_IO03__ENET1_REF_CLK_25M = IOMUX_PAD(0x0368, 0x0020, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO03__CCM_DI1_EXT_CLK = IOMUX_PAD(0x0368, 0x0020, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO03__WDOG2_WDOG_B = IOMUX_PAD(0x0368, 0x0020, 4, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO03__GPIO1_IO_3 = IOMUX_PAD(0x0368, 0x0020, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO03__CCM_PLL3_BYP = IOMUX_PAD(0x0368, 0x0020, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO03__PHY_TCK = IOMUX_PAD(0x0368, 0x0020, 7, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO04__UART1_TX = IOMUX_PAD(0x036C, 0x0024, 0, 0x0830, 0, 0), + MX6_PAD_GPIO1_IO04__USDHC2_RESET_B = IOMUX_PAD(0x036C, 0x0024, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO04__ENET1_MDC = IOMUX_PAD(0x036C, 0x0024, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO04__OSC32K_32K_OUT = IOMUX_PAD(0x036C, 0x0024, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO04__ENET2_REF_CLK2 = IOMUX_PAD(0x036C, 0x0024, 4, 0x076C, 0, 0), + MX6_PAD_GPIO1_IO04__GPIO1_IO_4 = IOMUX_PAD(0x036C, 0x0024, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO04__CCM_PLL2_BYP = IOMUX_PAD(0x036C, 0x0024, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO04__PHY_TMS = IOMUX_PAD(0x036C, 0x0024, 7, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO05__UART1_RX = IOMUX_PAD(0x0370, 0x0028, 0, 0x0830, 1, 0), + MX6_PAD_GPIO1_IO05__USDHC2_VSELECT = IOMUX_PAD(0x0370, 0x0028, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO05__ENET1_MDIO = IOMUX_PAD(0x0370, 0x0028, 2, 0x0764, 0, 0), + MX6_PAD_GPIO1_IO05__ASRC_ASRC_EXT_CLK = IOMUX_PAD(0x0370, 0x0028, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO05__ENET1_REF_CLK1 = IOMUX_PAD(0x0370, 0x0028, 4, 0x0760, 0, 0), + MX6_PAD_GPIO1_IO05__GPIO1_IO_5 = IOMUX_PAD(0x0370, 0x0028, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO05__SRC_TESTER_ACK = IOMUX_PAD(0x0370, 0x0028, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO05__PHY_TDO = IOMUX_PAD(0x0370, 0x0028, 7, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO06__UART2_TX = IOMUX_PAD(0x0374, 0x002C, 0, 0x0838, 0, 0), + MX6_PAD_GPIO1_IO06__USDHC2_CD_B = IOMUX_PAD(0x0374, 0x002C, 1, 0x086C, 1, 0), + MX6_PAD_GPIO1_IO06__ENET2_MDC = IOMUX_PAD(0x0374, 0x002C, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO06__CSI1_MCLK = IOMUX_PAD(0x0374, 0x002C, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO06__UART1_RTS_B = IOMUX_PAD(0x0374, 0x002C, 4, 0x082C, 0, 0), + MX6_PAD_GPIO1_IO06__GPIO1_IO_6 = IOMUX_PAD(0x0374, 0x002C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO06__SRC_ANY_PU_RESET = IOMUX_PAD(0x0374, 0x002C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO06__OCOTP_CTRL_WRAPPER_FUSE_LATCHED = IOMUX_PAD(0x0374, 0x002C, 7, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO07__UART2_RX = IOMUX_PAD(0x0378, 0x0030, 0, 0x0838, 1, 0), + MX6_PAD_GPIO1_IO07__USDHC2_WP = IOMUX_PAD(0x0378, 0x0030, 1, 0x0870, 1, 0), + MX6_PAD_GPIO1_IO07__ENET2_MDIO = IOMUX_PAD(0x0378, 0x0030, 2, 0x0770, 0, 0), + MX6_PAD_GPIO1_IO07__AUDMUX_MCLK = IOMUX_PAD(0x0378, 0x0030, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO07__UART1_CTS_B = IOMUX_PAD(0x0378, 0x0030, 4, 0x082C, 1, 0), + MX6_PAD_GPIO1_IO07__GPIO1_IO_7 = IOMUX_PAD(0x0378, 0x0030, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO07__SRC_EARLY_RESET = IOMUX_PAD(0x0378, 0x0030, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO07__DCIC2_OUT = IOMUX_PAD(0x0378, 0x0030, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO07__VDEC_DEBUG_44 = IOMUX_PAD(0x0378, 0x0030, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO08__USB_OTG1_OC = IOMUX_PAD(0x037C, 0x0034, 0, 0x0860, 0, 0), + MX6_PAD_GPIO1_IO08__WDOG1_WDOG_B = IOMUX_PAD(0x037C, 0x0034, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO08__SDMA_EXT_EVENT_0 = IOMUX_PAD(0x037C, 0x0034, 2, 0x081C, 0, 0), + MX6_PAD_GPIO1_IO08__CCM_PMIC_RDY = IOMUX_PAD(0x037C, 0x0034, 3, 0x069C, 1, 0), + MX6_PAD_GPIO1_IO08__UART2_RTS_B = IOMUX_PAD(0x037C, 0x0034, 4, 0x0834, 0, 0), + MX6_PAD_GPIO1_IO08__GPIO1_IO_8 = IOMUX_PAD(0x037C, 0x0034, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO08__SRC_SYSTEM_RESET = IOMUX_PAD(0x037C, 0x0034, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO08__DCIC1_OUT = IOMUX_PAD(0x037C, 0x0034, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO08__VDEC_DEBUG_43 = IOMUX_PAD(0x037C, 0x0034, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO09__USB_OTG1_PWR = IOMUX_PAD(0x0380, 0x0038, 0, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__WDOG2_WDOG_B = IOMUX_PAD(0x0380, 0x0038, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__SDMA_EXT_EVENT_1 = IOMUX_PAD(0x0380, 0x0038, 2, 0x0820, 0, 0), + MX6_PAD_GPIO1_IO09__CCM_OUT0 = IOMUX_PAD(0x0380, 0x0038, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__UART2_CTS_B = IOMUX_PAD(0x0380, 0x0038, 4, 0x0834, 1, 0), + MX6_PAD_GPIO1_IO09__GPIO1_IO_9 = IOMUX_PAD(0x0380, 0x0038, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__SRC_INT_BOOT = IOMUX_PAD(0x0380, 0x0038, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__OBSERVE_MUX_OUT_4 = IOMUX_PAD(0x0380, 0x0038, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO09__VDEC_DEBUG_42 = IOMUX_PAD(0x0380, 0x0038, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO10__ANATOP_OTG1_ID = IOMUX_PAD(0x0384, 0x003C, 0, 0x0624, 0, 0), + MX6_PAD_GPIO1_IO10__SPDIF_EXT_CLK = IOMUX_PAD(0x0384, 0x003C, 1, 0x0828, 0, 0), + MX6_PAD_GPIO1_IO10__PWM1_OUT = IOMUX_PAD(0x0384, 0x003C, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO10__CCM_OUT1 = IOMUX_PAD(0x0384, 0x003C, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO10__CSI1_FIELD = IOMUX_PAD(0x0384, 0x003C, 4, 0x070C, 1, 0), + MX6_PAD_GPIO1_IO10__GPIO1_IO_10 = IOMUX_PAD(0x0384, 0x003C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO10__CSU_CSU_INT_DEB = IOMUX_PAD(0x0384, 0x003C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO10__OBSERVE_MUX_OUT_3 = IOMUX_PAD(0x0384, 0x003C, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO10__VDEC_DEBUG_41 = IOMUX_PAD(0x0384, 0x003C, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO11__USB_OTG2_OC = IOMUX_PAD(0x0388, 0x0040, 0, 0x085C, 0, 0), + MX6_PAD_GPIO1_IO11__SPDIF_IN = IOMUX_PAD(0x0388, 0x0040, 1, 0x0824, 2, 0), + MX6_PAD_GPIO1_IO11__PWM2_OUT = IOMUX_PAD(0x0388, 0x0040, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO11__CCM_CLKO1 = IOMUX_PAD(0x0388, 0x0040, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO11__MLB_DATA = IOMUX_PAD(0x0388, 0x0040, 4, 0x07EC, 0, 0), + MX6_PAD_GPIO1_IO11__GPIO1_IO_11 = IOMUX_PAD(0x0388, 0x0040, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO11__CSU_CSU_ALARM_AUT_0 = IOMUX_PAD(0x0388, 0x0040, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO11__OBSERVE_MUX_OUT_2 = IOMUX_PAD(0x0388, 0x0040, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO11__VDEC_DEBUG_40 = IOMUX_PAD(0x0388, 0x0040, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO12__USB_OTG2_PWR = IOMUX_PAD(0x038C, 0x0044, 0, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO12__SPDIF_OUT = IOMUX_PAD(0x038C, 0x0044, 1, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO12__PWM3_OUT = IOMUX_PAD(0x038C, 0x0044, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO12__CCM_CLKO2 = IOMUX_PAD(0x038C, 0x0044, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO12__MLB_CLK = IOMUX_PAD(0x038C, 0x0044, 4, 0x07E8, 0, 0), + MX6_PAD_GPIO1_IO12__GPIO1_IO_12 = IOMUX_PAD(0x038C, 0x0044, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO12__CSU_CSU_ALARM_AUT_1 = IOMUX_PAD(0x038C, 0x0044, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO12__OBSERVE_MUX_OUT_1 = IOMUX_PAD(0x038C, 0x0044, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO12__VDEC_DEBUG_39 = IOMUX_PAD(0x038C, 0x0044, 8, 0x0000, 0, 0), + + MX6_PAD_GPIO1_IO13__WDOG1_WDOG_ANY = IOMUX_PAD(0x0390, 0x0048, 0, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO13__ANATOP_OTG2_ID = IOMUX_PAD(0x0390, 0x0048, 1, 0x0628, 0, 0), + MX6_PAD_GPIO1_IO13__PWM4_OUT = IOMUX_PAD(0x0390, 0x0048, 2, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO13__CCM_OUT2 = IOMUX_PAD(0x0390, 0x0048, 3, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO13__MLB_SIG = IOMUX_PAD(0x0390, 0x0048, 4, 0x07F0, 0, 0), + MX6_PAD_GPIO1_IO13__GPIO1_IO_13 = IOMUX_PAD(0x0390, 0x0048, 5, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO13__CSU_CSU_ALARM_AUT_2 = IOMUX_PAD(0x0390, 0x0048, 6, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO13__OBSERVE_MUX_OUT_0 = IOMUX_PAD(0x0390, 0x0048, 7, 0x0000, 0, 0), + MX6_PAD_GPIO1_IO13__VDEC_DEBUG_38 = IOMUX_PAD(0x0390, 0x0048, 8, 0x0000, 0, 0), + + MX6_PAD_CSI_DATA00__CSI1_DATA_2 = IOMUX_PAD(0x0394, 0x004C, 0, 0x06A8, 0, 0), + MX6_PAD_CSI_DATA00__ESAI_TX_CLK = IOMUX_PAD(0x0394, 0x004C, 1, 0x078C, 1, 0), + MX6_PAD_CSI_DATA00__AUDMUX_AUD6_TXC = IOMUX_PAD(0x0394, 0x004C, 2, 0x0684, 1, 0), + MX6_PAD_CSI_DATA00__I2C1_SCL = IOMUX_PAD(0x0394, 0x004C, 3, 0x07A8, 0, 0), + MX6_PAD_CSI_DATA00__UART6_RI_B = IOMUX_PAD(0x0394, 0x004C, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA00__GPIO1_IO_14 = IOMUX_PAD(0x0394, 0x004C, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA00__WEIM_DATA_23 = IOMUX_PAD(0x0394, 0x004C, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA00__SAI1_TX_BCLK = IOMUX_PAD(0x0394, 0x004C, 7, 0x0800, 0, 0), + MX6_PAD_CSI_DATA00__VADC_DATA_4 = IOMUX_PAD(0x0394, 0x004C, 8, 0x0000, 0, 0), + MX6_PAD_CSI_DATA00__MMDC_DEBUG_37 = IOMUX_PAD(0x0394, 0x004C, 9, 0x0000, 0, 0), + + MX6_PAD_CSI_DATA01__CSI1_DATA_3 = IOMUX_PAD(0x0398, 0x0050, 0, 0x06AC, 0, 0), + MX6_PAD_CSI_DATA01__ESAI_TX_FS = IOMUX_PAD(0x0398, 0x0050, 1, 0x077C, 1, 0), + MX6_PAD_CSI_DATA01__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x0398, 0x0050, 2, 0x0688, 1, 0), + MX6_PAD_CSI_DATA01__I2C1_SDA = IOMUX_PAD(0x0398, 0x0050, 3, 0x07AC, 0, 0), + MX6_PAD_CSI_DATA01__UART6_DSR_B = IOMUX_PAD(0x0398, 0x0050, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA01__GPIO1_IO_15 = IOMUX_PAD(0x0398, 0x0050, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA01__WEIM_DATA_22 = IOMUX_PAD(0x0398, 0x0050, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA01__SAI1_TX_SYNC = IOMUX_PAD(0x0398, 0x0050, 7, 0x0804, 0, 0), + MX6_PAD_CSI_DATA01__VADC_DATA_5 = IOMUX_PAD(0x0398, 0x0050, 8, 0x0000, 0, 0), + MX6_PAD_CSI_DATA01__MMDC_DEBUG_38 = IOMUX_PAD(0x0398, 0x0050, 9, 0x0000, 0, 0), + + MX6_PAD_CSI_DATA02__CSI1_DATA_4 = IOMUX_PAD(0x039C, 0x0054, 0, 0x06B0, 0, 0), + MX6_PAD_CSI_DATA02__ESAI_RX_CLK = IOMUX_PAD(0x039C, 0x0054, 1, 0x0788, 1, 0), + MX6_PAD_CSI_DATA02__AUDMUX_AUD6_RXC = IOMUX_PAD(0x039C, 0x0054, 2, 0x067C, 1, 0), + MX6_PAD_CSI_DATA02__KPP_COL_5 = IOMUX_PAD(0x039C, 0x0054, 3, 0x07C8, 0, 0), + MX6_PAD_CSI_DATA02__UART6_DTR_B = IOMUX_PAD(0x039C, 0x0054, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA02__GPIO1_IO_16 = IOMUX_PAD(0x039C, 0x0054, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA02__WEIM_DATA_21 = IOMUX_PAD(0x039C, 0x0054, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA02__SAI1_RX_BCLK = IOMUX_PAD(0x039C, 0x0054, 7, 0x07F4, 0, 0), + MX6_PAD_CSI_DATA02__VADC_DATA_6 = IOMUX_PAD(0x039C, 0x0054, 8, 0x0000, 0, 0), + MX6_PAD_CSI_DATA02__MMDC_DEBUG_39 = IOMUX_PAD(0x039C, 0x0054, 9, 0x0000, 0, 0), + + MX6_PAD_CSI_DATA03__CSI1_DATA_5 = IOMUX_PAD(0x03A0, 0x0058, 0, 0x06B4, 0, 0), + MX6_PAD_CSI_DATA03__ESAI_RX_FS = IOMUX_PAD(0x03A0, 0x0058, 1, 0x0778, 1, 0), + MX6_PAD_CSI_DATA03__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x03A0, 0x0058, 2, 0x0680, 1, 0), + MX6_PAD_CSI_DATA03__KPP_ROW_5 = IOMUX_PAD(0x03A0, 0x0058, 3, 0x07D4, 0, 0), + MX6_PAD_CSI_DATA03__UART6_DCD_B = IOMUX_PAD(0x03A0, 0x0058, 4, 0x0000, 0, 0), + MX6_PAD_CSI_DATA03__GPIO1_IO_17 = IOMUX_PAD(0x03A0, 0x0058, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA03__WEIM_DATA_20 = IOMUX_PAD(0x03A0, 0x0058, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA03__SAI1_RX_SYNC = IOMUX_PAD(0x03A0, 0x0058, 7, 0x07FC, 0, 0), + MX6_PAD_CSI_DATA03__VADC_DATA_7 = IOMUX_PAD(0x03A0, 0x0058, 8, 0x0000, 0, 0), + MX6_PAD_CSI_DATA03__MMDC_DEBUG_40 = IOMUX_PAD(0x03A0, 0x0058, 9, 0x0000, 0, 0), + + MX6_PAD_CSI_DATA04__CSI1_DATA_6 = IOMUX_PAD(0x03A4, 0x005C, 0, 0x06B8, 0, 0), + MX6_PAD_CSI_DATA04__ESAI_TX1 = IOMUX_PAD(0x03A4, 0x005C, 1, 0x0794, 1, 0), + MX6_PAD_CSI_DATA04__SPDIF_OUT = IOMUX_PAD(0x03A4, 0x005C, 2, 0x0000, 0, 0), + MX6_PAD_CSI_DATA04__KPP_COL_6 = IOMUX_PAD(0x03A4, 0x005C, 3, 0x07CC, 0, 0), + MX6_PAD_CSI_DATA04__UART6_RX = IOMUX_PAD(0x03A4, 0x005C, 4, 0x0858, 0, 0), + MX6_PAD_CSI_DATA04__GPIO1_IO_18 = IOMUX_PAD(0x03A4, 0x005C, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA04__WEIM_DATA_19 = IOMUX_PAD(0x03A4, 0x005C, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA04__PWM5_OUT = IOMUX_PAD(0x03A4, 0x005C, 7, 0x0000, 0, 0), + MX6_PAD_CSI_DATA04__VADC_DATA_8 = IOMUX_PAD(0x03A4, 0x005C, 8, 0x0000, 0, 0), + MX6_PAD_CSI_DATA04__MMDC_DEBUG_41 = IOMUX_PAD(0x03A4, 0x005C, 9, 0x0000, 0, 0), + + MX6_PAD_CSI_DATA05__CSI1_DATA_7 = IOMUX_PAD(0x03A8, 0x0060, 0, 0x06BC, 0, 0), + MX6_PAD_CSI_DATA05__ESAI_TX4_RX1 = IOMUX_PAD(0x03A8, 0x0060, 1, 0x07A0, 1, 0), + MX6_PAD_CSI_DATA05__SPDIF_IN = IOMUX_PAD(0x03A8, 0x0060, 2, 0x0824, 1, 0), + MX6_PAD_CSI_DATA05__KPP_ROW_6 = IOMUX_PAD(0x03A8, 0x0060, 3, 0x07D8, 0, 0), + MX6_PAD_CSI_DATA05__UART6_TX = IOMUX_PAD(0x03A8, 0x0060, 4, 0x0858, 1, 0), + MX6_PAD_CSI_DATA05__GPIO1_IO_19 = IOMUX_PAD(0x03A8, 0x0060, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA05__WEIM_DATA_18 = IOMUX_PAD(0x03A8, 0x0060, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA05__PWM6_OUT = IOMUX_PAD(0x03A8, 0x0060, 7, 0x0000, 0, 0), + MX6_PAD_CSI_DATA05__VADC_DATA_9 = IOMUX_PAD(0x03A8, 0x0060, 8, 0x0000, 0, 0), + MX6_PAD_CSI_DATA05__MMDC_DEBUG_42 = IOMUX_PAD(0x03A8, 0x0060, 9, 0x0000, 0, 0), + + MX6_PAD_CSI_DATA06__CSI1_DATA_8 = IOMUX_PAD(0x03AC, 0x0064, 0, 0x06C0, 0, 0), + MX6_PAD_CSI_DATA06__ESAI_TX2_RX3 = IOMUX_PAD(0x03AC, 0x0064, 1, 0x0798, 1, 0), + MX6_PAD_CSI_DATA06__I2C4_SCL = IOMUX_PAD(0x03AC, 0x0064, 2, 0x07C0, 2, 0), + MX6_PAD_CSI_DATA06__KPP_COL_7 = IOMUX_PAD(0x03AC, 0x0064, 3, 0x07D0, 0, 0), + MX6_PAD_CSI_DATA06__UART6_RTS_B = IOMUX_PAD(0x03AC, 0x0064, 4, 0x0854, 0, 0), + MX6_PAD_CSI_DATA06__GPIO1_IO_20 = IOMUX_PAD(0x03AC, 0x0064, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA06__WEIM_DATA_17 = IOMUX_PAD(0x03AC, 0x0064, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA06__DCIC2_OUT = IOMUX_PAD(0x03AC, 0x0064, 7, 0x0000, 0, 0), + MX6_PAD_CSI_DATA06__VADC_DATA_10 = IOMUX_PAD(0x03AC, 0x0064, 8, 0x0000, 0, 0), + MX6_PAD_CSI_DATA06__MMDC_DEBUG_43 = IOMUX_PAD(0x03AC, 0x0064, 9, 0x0000, 0, 0), + + MX6_PAD_CSI_DATA07__CSI1_DATA_9 = IOMUX_PAD(0x03B0, 0x0068, 0, 0x06C4, 0, 0), + MX6_PAD_CSI_DATA07__ESAI_TX3_RX2 = IOMUX_PAD(0x03B0, 0x0068, 1, 0x079C, 1, 0), + MX6_PAD_CSI_DATA07__I2C4_SDA = IOMUX_PAD(0x03B0, 0x0068, 2, 0x07C4, 2, 0), + MX6_PAD_CSI_DATA07__KPP_ROW_7 = IOMUX_PAD(0x03B0, 0x0068, 3, 0x07DC, 0, 0), + MX6_PAD_CSI_DATA07__UART6_CTS_B = IOMUX_PAD(0x03B0, 0x0068, 4, 0x0854, 1, 0), + MX6_PAD_CSI_DATA07__GPIO1_IO_21 = IOMUX_PAD(0x03B0, 0x0068, 5, 0x0000, 0, 0), + MX6_PAD_CSI_DATA07__WEIM_DATA_16 = IOMUX_PAD(0x03B0, 0x0068, 6, 0x0000, 0, 0), + MX6_PAD_CSI_DATA07__DCIC1_OUT = IOMUX_PAD(0x03B0, 0x0068, 7, 0x0000, 0, 0), + MX6_PAD_CSI_DATA07__VADC_DATA_11 = IOMUX_PAD(0x03B0, 0x0068, 8, 0x0000, 0, 0), + MX6_PAD_CSI_DATA07__MMDC_DEBUG_44 = IOMUX_PAD(0x03B0, 0x0068, 9, 0x0000, 0, 0), + + MX6_PAD_CSI_HSYNC__CSI1_HSYNC = IOMUX_PAD(0x03B4, 0x006C, 0, 0x0700, 0, 0), + MX6_PAD_CSI_HSYNC__ESAI_TX0 = IOMUX_PAD(0x03B4, 0x006C, 1, 0x0790, 1, 0), + MX6_PAD_CSI_HSYNC__AUDMUX_AUD6_TXD = IOMUX_PAD(0x03B4, 0x006C, 2, 0x0678, 1, 0), + MX6_PAD_CSI_HSYNC__UART4_RTS_B = IOMUX_PAD(0x03B4, 0x006C, 3, 0x0844, 2, 0), + MX6_PAD_CSI_HSYNC__MQS_LEFT = IOMUX_PAD(0x03B4, 0x006C, 4, 0x0000, 0, 0), + MX6_PAD_CSI_HSYNC__GPIO1_IO_22 = IOMUX_PAD(0x03B4, 0x006C, 5, 0x0000, 0, 0), + MX6_PAD_CSI_HSYNC__WEIM_DATA_25 = IOMUX_PAD(0x03B4, 0x006C, 6, 0x0000, 0, 0), + MX6_PAD_CSI_HSYNC__SAI1_TX_DATA_0 = IOMUX_PAD(0x03B4, 0x006C, 7, 0x0000, 0, 0), + MX6_PAD_CSI_HSYNC__VADC_DATA_2 = IOMUX_PAD(0x03B4, 0x006C, 8, 0x0000, 0, 0), + MX6_PAD_CSI_HSYNC__MMDC_DEBUG_35 = IOMUX_PAD(0x03B4, 0x006C, 9, 0x0000, 0, 0), + + MX6_PAD_CSI_MCLK__CSI1_MCLK = IOMUX_PAD(0x03B8, 0x0070, 0, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__ESAI_TX_HF_CLK = IOMUX_PAD(0x03B8, 0x0070, 1, 0x0784, 1, 0), + MX6_PAD_CSI_MCLK__OSC32K_32K_OUT = IOMUX_PAD(0x03B8, 0x0070, 2, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__UART4_RX = IOMUX_PAD(0x03B8, 0x0070, 3, 0x0848, 2, 0), + MX6_PAD_CSI_MCLK__ANATOP_32K_OUT = IOMUX_PAD(0x03B8, 0x0070, 4, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__GPIO1_IO_23 = IOMUX_PAD(0x03B8, 0x0070, 5, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__WEIM_DATA_26 = IOMUX_PAD(0x03B8, 0x0070, 6, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__CSI1_FIELD = IOMUX_PAD(0x03B8, 0x0070, 7, 0x070C, 0, 0), + MX6_PAD_CSI_MCLK__VADC_DATA_1 = IOMUX_PAD(0x03B8, 0x0070, 8, 0x0000, 0, 0), + MX6_PAD_CSI_MCLK__MMDC_DEBUG_34 = IOMUX_PAD(0x03B8, 0x0070, 9, 0x0000, 0, 0), + + MX6_PAD_CSI_PIXCLK__CSI1_PIXCLK = IOMUX_PAD(0x03BC, 0x0074, 0, 0x0704, 0, 0), + MX6_PAD_CSI_PIXCLK__ESAI_RX_HF_CLK = IOMUX_PAD(0x03BC, 0x0074, 1, 0x0780, 1, 0), + MX6_PAD_CSI_PIXCLK__AUDMUX_MCLK = IOMUX_PAD(0x03BC, 0x0074, 2, 0x0000, 0, 0), + MX6_PAD_CSI_PIXCLK__UART4_TX = IOMUX_PAD(0x03BC, 0x0074, 3, 0x0848, 3, 0), + MX6_PAD_CSI_PIXCLK__ANATOP_24M_OUT = IOMUX_PAD(0x03BC, 0x0074, 4, 0x0000, 0, 0), + MX6_PAD_CSI_PIXCLK__GPIO1_IO_24 = IOMUX_PAD(0x03BC, 0x0074, 5, 0x0000, 0, 0), + MX6_PAD_CSI_PIXCLK__WEIM_DATA_27 = IOMUX_PAD(0x03BC, 0x0074, 6, 0x0000, 0, 0), + MX6_PAD_CSI_PIXCLK__ESAI_TX_HF_CLK = IOMUX_PAD(0x03BC, 0x0074, 7, 0x0784, 2, 0), + MX6_PAD_CSI_PIXCLK__VADC_CLK = IOMUX_PAD(0x03BC, 0x0074, 8, 0x0000, 0, 0), + MX6_PAD_CSI_PIXCLK__MMDC_DEBUG_33 = IOMUX_PAD(0x03BC, 0x0074, 9, 0x0000, 0, 0), + + MX6_PAD_CSI_VSYNC__CSI1_VSYNC = IOMUX_PAD(0x03C0, 0x0078, 0, 0x0708, 0, 0), + MX6_PAD_CSI_VSYNC__ESAI_TX5_RX0 = IOMUX_PAD(0x03C0, 0x0078, 1, 0x07A4, 1, 0), + MX6_PAD_CSI_VSYNC__AUDMUX_AUD6_RXD = IOMUX_PAD(0x03C0, 0x0078, 2, 0x0674, 1, 0), + MX6_PAD_CSI_VSYNC__UART4_CTS_B = IOMUX_PAD(0x03C0, 0x0078, 3, 0x0844, 3, 0), + MX6_PAD_CSI_VSYNC__MQS_RIGHT = IOMUX_PAD(0x03C0, 0x0078, 4, 0x0000, 0, 0), + MX6_PAD_CSI_VSYNC__GPIO1_IO_25 = IOMUX_PAD(0x03C0, 0x0078, 5, 0x0000, 0, 0), + MX6_PAD_CSI_VSYNC__WEIM_DATA_24 = IOMUX_PAD(0x03C0, 0x0078, 6, 0x0000, 0, 0), + MX6_PAD_CSI_VSYNC__SAI1_RX_DATA_0 = IOMUX_PAD(0x03C0, 0x0078, 7, 0x07F8, 0, 0), + MX6_PAD_CSI_VSYNC__VADC_DATA_3 = IOMUX_PAD(0x03C0, 0x0078, 8, 0x0000, 0, 0), + MX6_PAD_CSI_VSYNC__MMDC_DEBUG_36 = IOMUX_PAD(0x03C0, 0x0078, 9, 0x0000, 0, 0), + + MX6_PAD_ENET1_COL__ENET1_COL = IOMUX_PAD(0x03C4, 0x007C, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_COL__ENET2_MDC = IOMUX_PAD(0x03C4, 0x007C, 1, 0x0000, 0, 0), + MX6_PAD_ENET1_COL__AUDMUX_AUD4_TXC = IOMUX_PAD(0x03C4, 0x007C, 2, 0x0654, 1, 0), + MX6_PAD_ENET1_COL__UART1_RI_B = IOMUX_PAD(0x03C4, 0x007C, 3, 0x0000, 0, 0), + MX6_PAD_ENET1_COL__SPDIF_EXT_CLK = IOMUX_PAD(0x03C4, 0x007C, 4, 0x0828, 1, 0), + MX6_PAD_ENET1_COL__GPIO2_IO_0 = IOMUX_PAD(0x03C4, 0x007C, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_COL__CSI2_DATA_23 = IOMUX_PAD(0x03C4, 0x007C, 6, 0x0000, 0, 0), + MX6_PAD_ENET1_COL__LCDIF2_DATA_16 = IOMUX_PAD(0x03C4, 0x007C, 7, 0x0000, 0, 0), + MX6_PAD_ENET1_COL__VDEC_DEBUG_37 = IOMUX_PAD(0x03C4, 0x007C, 8, 0x0000, 0, 0), + MX6_PAD_ENET1_COL__PCIE_CTRL_DEBUG_31 = IOMUX_PAD(0x03C4, 0x007C, 9, 0x0000, 0, 0), + + MX6_PAD_ENET1_CRS__ENET1_CRS = IOMUX_PAD(0x03C8, 0x0080, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_CRS__ENET2_MDIO = IOMUX_PAD(0x03C8, 0x0080, 1, 0x0770, 1, 0), + MX6_PAD_ENET1_CRS__AUDMUX_AUD4_TXD = IOMUX_PAD(0x03C8, 0x0080, 2, 0x0648, 1, 0), + MX6_PAD_ENET1_CRS__UART1_DCD_B = IOMUX_PAD(0x03C8, 0x0080, 3, 0x0000, 0, 0), + MX6_PAD_ENET1_CRS__SPDIF_LOCK = IOMUX_PAD(0x03C8, 0x0080, 4, 0x0000, 0, 0), + MX6_PAD_ENET1_CRS__GPIO2_IO_1 = IOMUX_PAD(0x03C8, 0x0080, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_CRS__CSI2_DATA_22 = IOMUX_PAD(0x03C8, 0x0080, 6, 0x0000, 0, 0), + MX6_PAD_ENET1_CRS__LCDIF2_DATA_17 = IOMUX_PAD(0x03C8, 0x0080, 7, 0x0000, 0, 0), + MX6_PAD_ENET1_CRS__VDEC_DEBUG_36 = IOMUX_PAD(0x03C8, 0x0080, 8, 0x0000, 0, 0), + MX6_PAD_ENET1_CRS__PCIE_CTRL_DEBUG_30 = IOMUX_PAD(0x03C8, 0x0080, 9, 0x0000, 0, 0), + + MX6_PAD_ENET1_MDC__ENET1_MDC = IOMUX_PAD(0x03CC, 0x0084, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_MDC__ENET2_MDC = IOMUX_PAD(0x03CC, 0x0084, 1, 0x0000, 0, 0), + MX6_PAD_ENET1_MDC__AUDMUX_AUD3_RXFS = IOMUX_PAD(0x03CC, 0x0084, 2, 0x0638, 1, 0), + MX6_PAD_ENET1_MDC__ANATOP_24M_OUT = IOMUX_PAD(0x03CC, 0x0084, 3, 0x0000, 0, 0), + MX6_PAD_ENET1_MDC__EPIT2_OUT = IOMUX_PAD(0x03CC, 0x0084, 4, 0x0000, 0, 0), + MX6_PAD_ENET1_MDC__GPIO2_IO_2 = IOMUX_PAD(0x03CC, 0x0084, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_MDC__USB_OTG1_PWR = IOMUX_PAD(0x03CC, 0x0084, 6, 0x0000, 0, 0), + MX6_PAD_ENET1_MDC__PWM7_OUT = IOMUX_PAD(0x03CC, 0x0084, 7, 0x0000, 0, 0), + + MX6_PAD_ENET1_MDIO__ENET1_MDIO = IOMUX_PAD(0x03D0, 0x0088, 0, 0x0764, 1, 0), + MX6_PAD_ENET1_MDIO__ENET2_MDIO = IOMUX_PAD(0x03D0, 0x0088, 1, 0x0770, 2, 0), + MX6_PAD_ENET1_MDIO__AUDMUX_MCLK = IOMUX_PAD(0x03D0, 0x0088, 2, 0x0000, 0, 0), + MX6_PAD_ENET1_MDIO__OSC32K_32K_OUT = IOMUX_PAD(0x03D0, 0x0088, 3, 0x0000, 0, 0), + MX6_PAD_ENET1_MDIO__EPIT1_OUT = IOMUX_PAD(0x03D0, 0x0088, 4, 0x0000, 0, 0), + MX6_PAD_ENET1_MDIO__GPIO2_IO_3 = IOMUX_PAD(0x03D0, 0x0088, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_MDIO__USB_OTG1_OC = IOMUX_PAD(0x03D0, 0x0088, 6, 0x0860, 1, 0), + MX6_PAD_ENET1_MDIO__PWM8_OUT = IOMUX_PAD(0x03D0, 0x0088, 7, 0x0000, 0, 0), + + MX6_PAD_ENET1_RX_CLK__ENET1_RX_CLK = IOMUX_PAD(0x03D4, 0x008C, 0, 0x0768, 0, 0), + MX6_PAD_ENET1_RX_CLK__ENET1_REF_CLK_25M = IOMUX_PAD(0x03D4, 0x008C, 1, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_CLK__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x03D4, 0x008C, 2, 0x0658, 1, 0), + MX6_PAD_ENET1_RX_CLK__UART1_DSR_B = IOMUX_PAD(0x03D4, 0x008C, 3, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_CLK__SPDIF_OUT = IOMUX_PAD(0x03D4, 0x008C, 4, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_CLK__GPIO2_IO_4 = IOMUX_PAD(0x03D4, 0x008C, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_CLK__CSI2_DATA_21 = IOMUX_PAD(0x03D4, 0x008C, 6, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_CLK__LCDIF2_DATA_18 = IOMUX_PAD(0x03D4, 0x008C, 7, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_CLK__VDEC_DEBUG_35 = IOMUX_PAD(0x03D4, 0x008C, 8, 0x0000, 0, 0), + MX6_PAD_ENET1_RX_CLK__PCIE_CTRL_DEBUG_29 = IOMUX_PAD(0x03D4, 0x008C, 9, 0x0000, 0, 0), + + MX6_PAD_ENET1_TX_CLK__ENET1_TX_CLK = IOMUX_PAD(0x03D8, 0x0090, 0, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 = IOMUX_PAD(0x03D8, 0x0090, 1, 0x0760, 1, 0), + MX6_PAD_ENET1_TX_CLK__AUDMUX_AUD4_RXD = IOMUX_PAD(0x03D8, 0x0090, 2, 0x0644, 1, 0), + MX6_PAD_ENET1_TX_CLK__UART1_DTR_B = IOMUX_PAD(0x03D8, 0x0090, 3, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__SPDIF_SR_CLK = IOMUX_PAD(0x03D8, 0x0090, 4, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__GPIO2_IO_5 = IOMUX_PAD(0x03D8, 0x0090, 5, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__CSI2_DATA_20 = IOMUX_PAD(0x03D8, 0x0090, 6, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__LCDIF2_DATA_19 = IOMUX_PAD(0x03D8, 0x0090, 7, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__VDEC_DEBUG_34 = IOMUX_PAD(0x03D8, 0x0090, 8, 0x0000, 0, 0), + MX6_PAD_ENET1_TX_CLK__PCIE_CTRL_DEBUG_28 = IOMUX_PAD(0x03D8, 0x0090, 9, 0x0000, 0, 0), + + MX6_PAD_ENET2_COL__ENET2_COL = IOMUX_PAD(0x03DC, 0x0094, 0, 0x0000, 0, 0), + MX6_PAD_ENET2_COL__ENET1_MDC = IOMUX_PAD(0x03DC, 0x0094, 1, 0x0000, 0, 0), + MX6_PAD_ENET2_COL__AUDMUX_AUD4_RXC = IOMUX_PAD(0x03DC, 0x0094, 2, 0x064C, 1, 0), + MX6_PAD_ENET2_COL__UART1_RX = IOMUX_PAD(0x03DC, 0x0094, 3, 0x0830, 2, 0), + MX6_PAD_ENET2_COL__SPDIF_IN = IOMUX_PAD(0x03DC, 0x0094, 4, 0x0824, 3, 0), + MX6_PAD_ENET2_COL__GPIO2_IO_6 = IOMUX_PAD(0x03DC, 0x0094, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_COL__ANATOP_OTG1_ID = IOMUX_PAD(0x03DC, 0x0094, 6, 0x0624, 1, 0), + MX6_PAD_ENET2_COL__LCDIF2_DATA_20 = IOMUX_PAD(0x03DC, 0x0094, 7, 0x0000, 0, 0), + MX6_PAD_ENET2_COL__VDEC_DEBUG_33 = IOMUX_PAD(0x03DC, 0x0094, 8, 0x0000, 0, 0), + MX6_PAD_ENET2_COL__PCIE_CTRL_DEBUG_27 = IOMUX_PAD(0x03DC, 0x0094, 9, 0x0000, 0, 0), + + MX6_PAD_ENET2_CRS__ENET2_CRS = IOMUX_PAD(0x03E0, 0x0098, 0, 0x0000, 0, 0), + MX6_PAD_ENET2_CRS__ENET1_MDIO = IOMUX_PAD(0x03E0, 0x0098, 1, 0x0764, 2, 0), + MX6_PAD_ENET2_CRS__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x03E0, 0x0098, 2, 0x0650, 1, 0), + MX6_PAD_ENET2_CRS__UART1_TX = IOMUX_PAD(0x03E0, 0x0098, 3, 0x0830, 3, 0), + MX6_PAD_ENET2_CRS__MLB_SIG = IOMUX_PAD(0x03E0, 0x0098, 4, 0x07F0, 1, 0), + MX6_PAD_ENET2_CRS__GPIO2_IO_7 = IOMUX_PAD(0x03E0, 0x0098, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_CRS__ANATOP_OTG2_ID = IOMUX_PAD(0x03E0, 0x0098, 6, 0x0628, 1, 0), + MX6_PAD_ENET2_CRS__LCDIF2_DATA_21 = IOMUX_PAD(0x03E0, 0x0098, 7, 0x0000, 0, 0), + MX6_PAD_ENET2_CRS__VDEC_DEBUG_32 = IOMUX_PAD(0x03E0, 0x0098, 8, 0x0000, 0, 0), + MX6_PAD_ENET2_CRS__PCIE_CTRL_DEBUG_26 = IOMUX_PAD(0x03E0, 0x0098, 9, 0x0000, 0, 0), + + MX6_PAD_ENET2_RX_CLK__ENET2_RX_CLK = IOMUX_PAD(0x03E4, 0x009C, 0, 0x0774, 0, 0), + MX6_PAD_ENET2_RX_CLK__ENET2_REF_CLK_25M = IOMUX_PAD(0x03E4, 0x009C, 1, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_CLK__I2C3_SCL = IOMUX_PAD(0x03E4, 0x009C, 2, 0x07B8, 1, 0), + MX6_PAD_ENET2_RX_CLK__UART1_RTS_B = IOMUX_PAD(0x03E4, 0x009C, 3, 0x082C, 2, 0), + MX6_PAD_ENET2_RX_CLK__MLB_DATA = IOMUX_PAD(0x03E4, 0x009C, 4, 0x07EC, 1, 0), + MX6_PAD_ENET2_RX_CLK__GPIO2_IO_8 = IOMUX_PAD(0x03E4, 0x009C, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_CLK__USB_OTG2_OC = IOMUX_PAD(0x03E4, 0x009C, 6, 0x085C, 1, 0), + MX6_PAD_ENET2_RX_CLK__LCDIF2_DATA_22 = IOMUX_PAD(0x03E4, 0x009C, 7, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_CLK__VDEC_DEBUG_31 = IOMUX_PAD(0x03E4, 0x009C, 8, 0x0000, 0, 0), + MX6_PAD_ENET2_RX_CLK__PCIE_CTRL_DEBUG_25 = IOMUX_PAD(0x03E4, 0x009C, 9, 0x0000, 0, 0), + + MX6_PAD_ENET2_TX_CLK__ENET2_TX_CLK = IOMUX_PAD(0x03E8, 0x00A0, 0, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 = IOMUX_PAD(0x03E8, 0x00A0, 1, 0x076C, 1, 0), + MX6_PAD_ENET2_TX_CLK__I2C3_SDA = IOMUX_PAD(0x03E8, 0x00A0, 2, 0x07BC, 1, 0), + MX6_PAD_ENET2_TX_CLK__UART1_CTS_B = IOMUX_PAD(0x03E8, 0x00A0, 3, 0x082C, 3, 0), + MX6_PAD_ENET2_TX_CLK__MLB_CLK = IOMUX_PAD(0x03E8, 0x00A0, 4, 0x07E8, 1, 0), + MX6_PAD_ENET2_TX_CLK__GPIO2_IO_9 = IOMUX_PAD(0x03E8, 0x00A0, 5, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_CLK__USB_OTG2_PWR = IOMUX_PAD(0x03E8, 0x00A0, 6, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_CLK__LCDIF2_DATA_23 = IOMUX_PAD(0x03E8, 0x00A0, 7, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_CLK__VDEC_DEBUG_30 = IOMUX_PAD(0x03E8, 0x00A0, 8, 0x0000, 0, 0), + MX6_PAD_ENET2_TX_CLK__PCIE_CTRL_DEBUG_24 = IOMUX_PAD(0x03E8, 0x00A0, 9, 0x0000, 0, 0), + + MX6_PAD_KEY_COL0__KPP_COL_0 = IOMUX_PAD(0x03EC, 0x00A4, 0, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__USDHC3_CD_B = IOMUX_PAD(0x03EC, 0x00A4, 1, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__UART6_RTS_B = IOMUX_PAD(0x03EC, 0x00A4, 2, 0x0854, 2, 0), + MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x03EC, 0x00A4, 3, 0x0710, 0, 0), + MX6_PAD_KEY_COL0__AUDMUX_AUD5_TXC = IOMUX_PAD(0x03EC, 0x00A4, 4, 0x066C, 0, 0), + MX6_PAD_KEY_COL0__GPIO2_IO_10 = IOMUX_PAD(0x03EC, 0x00A4, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__SDMA_EXT_EVENT_1 = IOMUX_PAD(0x03EC, 0x00A4, 6, 0x0820, 1, 0), + MX6_PAD_KEY_COL0__SAI2_TX_BCLK = IOMUX_PAD(0x03EC, 0x00A4, 7, 0x0814, 0, 0), + MX6_PAD_KEY_COL0__VADC_DATA_0 = IOMUX_PAD(0x03EC, 0x00A4, 8, 0x0000, 0, 0), + + MX6_PAD_KEY_COL1__KPP_COL_1 = IOMUX_PAD(0x03F0, 0x00A8, 0, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__USDHC3_RESET_B = IOMUX_PAD(0x03F0, 0x00A8, 1, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__UART6_TX = IOMUX_PAD(0x03F0, 0x00A8, 2, 0x0858, 2, 0), + MX6_PAD_KEY_COL1__ECSPI1_MISO = IOMUX_PAD(0x03F0, 0x00A8, 3, 0x0714, 0, 0), + MX6_PAD_KEY_COL1__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x03F0, 0x00A8, 4, 0x0670, 0, 0), + MX6_PAD_KEY_COL1__GPIO2_IO_11 = IOMUX_PAD(0x03F0, 0x00A8, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__USDHC3_RESET = IOMUX_PAD(0x03F0, 0x00A8, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__SAI2_TX_SYNC = IOMUX_PAD(0x03F0, 0x00A8, 7, 0x0818, 0, 0), + + MX6_PAD_KEY_COL2__KPP_COL_2 = IOMUX_PAD(0x03F4, 0x00AC, 0, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__USDHC4_CD_B = IOMUX_PAD(0x03F4, 0x00AC, 1, 0x0874, 1, 0), + MX6_PAD_KEY_COL2__UART5_RTS_B = IOMUX_PAD(0x03F4, 0x00AC, 2, 0x084C, 2, 0), + MX6_PAD_KEY_COL2__CAN1_TX = IOMUX_PAD(0x03F4, 0x00AC, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__CANFD_TX1 = IOMUX_PAD(0x03F4, 0x00AC, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__GPIO2_IO_12 = IOMUX_PAD(0x03F4, 0x00AC, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__WEIM_DATA_30 = IOMUX_PAD(0x03F4, 0x00AC, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__ECSPI1_RDY = IOMUX_PAD(0x03F4, 0x00AC, 7, 0x0000, 0, 0), + + MX6_PAD_KEY_COL3__KPP_COL_3 = IOMUX_PAD(0x03F8, 0x00B0, 0, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__USDHC4_LCTL = IOMUX_PAD(0x03F8, 0x00B0, 1, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__UART5_TX = IOMUX_PAD(0x03F8, 0x00B0, 2, 0x0850, 2, 0), + MX6_PAD_KEY_COL3__CAN2_TX = IOMUX_PAD(0x03F8, 0x00B0, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__CANFD_TX2 = IOMUX_PAD(0x03F8, 0x00B0, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__GPIO2_IO_13 = IOMUX_PAD(0x03F8, 0x00B0, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__WEIM_DATA_28 = IOMUX_PAD(0x03F8, 0x00B0, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__ECSPI1_SS2 = IOMUX_PAD(0x03F8, 0x00B0, 7, 0x0000, 0, 0), + + MX6_PAD_KEY_COL4__KPP_COL_4 = IOMUX_PAD(0x03FC, 0x00B4, 0, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__ENET2_MDC = IOMUX_PAD(0x03FC, 0x00B4, 1, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__I2C3_SCL = IOMUX_PAD(0x03FC, 0x00B4, 2, 0x07B8, 2, 0), + MX6_PAD_KEY_COL4__USDHC2_LCTL = IOMUX_PAD(0x03FC, 0x00B4, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__AUDMUX_AUD5_RXC = IOMUX_PAD(0x03FC, 0x00B4, 4, 0x0664, 0, 0), + MX6_PAD_KEY_COL4__GPIO2_IO_14 = IOMUX_PAD(0x03FC, 0x00B4, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__WEIM_CRE = IOMUX_PAD(0x03FC, 0x00B4, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__SAI2_RX_BCLK = IOMUX_PAD(0x03FC, 0x00B4, 7, 0x0808, 0, 0), + + MX6_PAD_KEY_ROW0__KPP_ROW_0 = IOMUX_PAD(0x0400, 0x00B8, 0, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__USDHC3_WP = IOMUX_PAD(0x0400, 0x00B8, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__UART6_CTS_B = IOMUX_PAD(0x0400, 0x00B8, 2, 0x0854, 3, 0), + MX6_PAD_KEY_ROW0__ECSPI1_MOSI = IOMUX_PAD(0x0400, 0x00B8, 3, 0x0718, 0, 0), + MX6_PAD_KEY_ROW0__AUDMUX_AUD5_TXD = IOMUX_PAD(0x0400, 0x00B8, 4, 0x0660, 0, 0), + MX6_PAD_KEY_ROW0__GPIO2_IO_15 = IOMUX_PAD(0x0400, 0x00B8, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__SDMA_EXT_EVENT_0 = IOMUX_PAD(0x0400, 0x00B8, 6, 0x081C, 1, 0), + MX6_PAD_KEY_ROW0__SAI2_TX_DATA_0 = IOMUX_PAD(0x0400, 0x00B8, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__GPU_IDLE = IOMUX_PAD(0x0400, 0x00B8, 8, 0x0000, 0, 0), + + MX6_PAD_KEY_ROW1__KPP_ROW_1 = IOMUX_PAD(0x0404, 0x00BC, 0, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__USDHC4_VSELECT = IOMUX_PAD(0x0404, 0x00BC, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__UART6_RX = IOMUX_PAD(0x0404, 0x00BC, 2, 0x0858, 3, 0), + MX6_PAD_KEY_ROW1__ECSPI1_SS0 = IOMUX_PAD(0x0404, 0x00BC, 3, 0x071C, 0, 0), + MX6_PAD_KEY_ROW1__AUDMUX_AUD5_RXD = IOMUX_PAD(0x0404, 0x00BC, 4, 0x065C, 0, 0), + MX6_PAD_KEY_ROW1__GPIO2_IO_16 = IOMUX_PAD(0x0404, 0x00BC, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__WEIM_DATA_31 = IOMUX_PAD(0x0404, 0x00BC, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__SAI2_RX_DATA_0 = IOMUX_PAD(0x0404, 0x00BC, 7, 0x080C, 0, 0), + MX6_PAD_KEY_ROW1__M4_NMI = IOMUX_PAD(0x0404, 0x00BC, 8, 0x0000, 0, 0), + + MX6_PAD_KEY_ROW2__KPP_ROW_2 = IOMUX_PAD(0x0408, 0x00C0, 0, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__USDHC4_WP = IOMUX_PAD(0x0408, 0x00C0, 1, 0x0878, 1, 0), + MX6_PAD_KEY_ROW2__UART5_CTS_B = IOMUX_PAD(0x0408, 0x00C0, 2, 0x084C, 3, 0), + MX6_PAD_KEY_ROW2__CAN1_RX = IOMUX_PAD(0x0408, 0x00C0, 3, 0x068C, 1, 0), + MX6_PAD_KEY_ROW2__CANFD_RX1 = IOMUX_PAD(0x0408, 0x00C0, 4, 0x0694, 1, 0), + MX6_PAD_KEY_ROW2__GPIO2_IO_17 = IOMUX_PAD(0x0408, 0x00C0, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__WEIM_DATA_29 = IOMUX_PAD(0x0408, 0x00C0, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__ECSPI1_SS3 = IOMUX_PAD(0x0408, 0x00C0, 7, 0x0000, 0, 0), + + MX6_PAD_KEY_ROW3__KPP_ROW_3 = IOMUX_PAD(0x040C, 0x00C4, 0, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__USDHC3_LCTL = IOMUX_PAD(0x040C, 0x00C4, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__UART5_RX = IOMUX_PAD(0x040C, 0x00C4, 2, 0x0850, 3, 0), + MX6_PAD_KEY_ROW3__CAN2_RX = IOMUX_PAD(0x040C, 0x00C4, 3, 0x0690, 1, 0), + MX6_PAD_KEY_ROW3__CANFD_RX2 = IOMUX_PAD(0x040C, 0x00C4, 4, 0x0698, 1, 0), + MX6_PAD_KEY_ROW3__GPIO2_IO_18 = IOMUX_PAD(0x040C, 0x00C4, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__WEIM_DTACK_B = IOMUX_PAD(0x040C, 0x00C4, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__ECSPI1_SS1 = IOMUX_PAD(0x040C, 0x00C4, 7, 0x0000, 0, 0), + + MX6_PAD_KEY_ROW4__KPP_ROW_4 = IOMUX_PAD(0x0410, 0x00C8, 0, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__ENET2_MDIO = IOMUX_PAD(0x0410, 0x00C8, 1, 0x0770, 3, 0), + MX6_PAD_KEY_ROW4__I2C3_SDA = IOMUX_PAD(0x0410, 0x00C8, 2, 0x07BC, 2, 0), + MX6_PAD_KEY_ROW4__USDHC1_LCTL = IOMUX_PAD(0x0410, 0x00C8, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x0410, 0x00C8, 4, 0x0668, 0, 0), + MX6_PAD_KEY_ROW4__GPIO2_IO_19 = IOMUX_PAD(0x0410, 0x00C8, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__WEIM_ACLK_FREERUN = IOMUX_PAD(0x0410, 0x00C8, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__SAI2_RX_SYNC = IOMUX_PAD(0x0410, 0x00C8, 7, 0x0810, 0, 0), + + MX6_PAD_LCD1_CLK__LCDIF1_CLK = IOMUX_PAD(0x0414, 0x00CC, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_CLK__LCDIF1_WR_RWN = IOMUX_PAD(0x0414, 0x00CC, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_CLK__AUDMUX_AUD3_RXC = IOMUX_PAD(0x0414, 0x00CC, 2, 0x0634, 1, 0), + MX6_PAD_LCD1_CLK__ENET1_1588_EVENT2_IN = IOMUX_PAD(0x0414, 0x00CC, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_CLK__CSI1_DATA_16 = IOMUX_PAD(0x0414, 0x00CC, 4, 0x06DC, 0, 0), + MX6_PAD_LCD1_CLK__GPIO3_IO_0 = IOMUX_PAD(0x0414, 0x00CC, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_CLK__USDHC1_WP = IOMUX_PAD(0x0414, 0x00CC, 6, 0x0868, 0, 0), + MX6_PAD_LCD1_CLK__SIM_M_HADDR_16 = IOMUX_PAD(0x0414, 0x00CC, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_CLK__VADC_TEST_0 = IOMUX_PAD(0x0414, 0x00CC, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_CLK__MMDC_DEBUG_0 = IOMUX_PAD(0x0414, 0x00CC, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA00__LCDIF1_DATA_0 = IOMUX_PAD(0x0418, 0x00D0, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA00__WEIM_CS1_B = IOMUX_PAD(0x0418, 0x00D0, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA00__M4_TRACE_0 = IOMUX_PAD(0x0418, 0x00D0, 2, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA00__KITTEN_TRACE_0 = IOMUX_PAD(0x0418, 0x00D0, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA00__CSI1_DATA_20 = IOMUX_PAD(0x0418, 0x00D0, 4, 0x06EC, 0, 0), + MX6_PAD_LCD1_DATA00__GPIO3_IO_1 = IOMUX_PAD(0x0418, 0x00D0, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA00__SRC_BT_CFG_0 = IOMUX_PAD(0x0418, 0x00D0, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA00__SIM_M_HADDR_21 = IOMUX_PAD(0x0418, 0x00D0, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA00__VADC_TEST_5 = IOMUX_PAD(0x0418, 0x00D0, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA00__MMDC_DEBUG_5 = IOMUX_PAD(0x0418, 0x00D0, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA01__LCDIF1_DATA_1 = IOMUX_PAD(0x041C, 0x00D4, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA01__WEIM_CS2_B = IOMUX_PAD(0x041C, 0x00D4, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA01__M4_TRACE_1 = IOMUX_PAD(0x041C, 0x00D4, 2, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA01__KITTEN_TRACE_1 = IOMUX_PAD(0x041C, 0x00D4, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA01__CSI1_DATA_21 = IOMUX_PAD(0x041C, 0x00D4, 4, 0x06F0, 0, 0), + MX6_PAD_LCD1_DATA01__GPIO3_IO_2 = IOMUX_PAD(0x041C, 0x00D4, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA01__SRC_BT_CFG_1 = IOMUX_PAD(0x041C, 0x00D4, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA01__SIM_M_HADDR_22 = IOMUX_PAD(0x041C, 0x00D4, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA01__VADC_TEST_6 = IOMUX_PAD(0x041C, 0x00D4, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA01__MMDC_DEBUG_6 = IOMUX_PAD(0x041C, 0x00D4, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA02__LCDIF1_DATA_2 = IOMUX_PAD(0x0420, 0x00D8, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA02__WEIM_CS3_B = IOMUX_PAD(0x0420, 0x00D8, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA02__M4_TRACE_2 = IOMUX_PAD(0x0420, 0x00D8, 2, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA02__KITTEN_TRACE_2 = IOMUX_PAD(0x0420, 0x00D8, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA02__CSI1_DATA_22 = IOMUX_PAD(0x0420, 0x00D8, 4, 0x06F4, 0, 0), + MX6_PAD_LCD1_DATA02__GPIO3_IO_3 = IOMUX_PAD(0x0420, 0x00D8, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA02__SRC_BT_CFG_2 = IOMUX_PAD(0x0420, 0x00D8, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA02__SIM_M_HADDR_23 = IOMUX_PAD(0x0420, 0x00D8, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA02__VADC_TEST_7 = IOMUX_PAD(0x0420, 0x00D8, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA02__MMDC_DEBUG_7 = IOMUX_PAD(0x0420, 0x00D8, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA03__LCDIF1_DATA_3 = IOMUX_PAD(0x0424, 0x00DC, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA03__WEIM_ADDR_24 = IOMUX_PAD(0x0424, 0x00DC, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA03__M4_TRACE_3 = IOMUX_PAD(0x0424, 0x00DC, 2, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA03__KITTEN_TRACE_3 = IOMUX_PAD(0x0424, 0x00DC, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA03__CSI1_DATA_23 = IOMUX_PAD(0x0424, 0x00DC, 4, 0x06F8, 0, 0), + MX6_PAD_LCD1_DATA03__GPIO3_IO_4 = IOMUX_PAD(0x0424, 0x00DC, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA03__SRC_BT_CFG_3 = IOMUX_PAD(0x0424, 0x00DC, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA03__SIM_M_HADDR_24 = IOMUX_PAD(0x0424, 0x00DC, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA03__VADC_TEST_8 = IOMUX_PAD(0x0424, 0x00DC, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA03__MMDC_DEBUG_8 = IOMUX_PAD(0x0424, 0x00DC, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA04__LCDIF1_DATA_4 = IOMUX_PAD(0x0428, 0x00E0, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA04__WEIM_ADDR_25 = IOMUX_PAD(0x0428, 0x00E0, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA04__KITTEN_TRACE_4 = IOMUX_PAD(0x0428, 0x00E0, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA04__CSI1_VSYNC = IOMUX_PAD(0x0428, 0x00E0, 4, 0x0708, 1, 0), + MX6_PAD_LCD1_DATA04__GPIO3_IO_5 = IOMUX_PAD(0x0428, 0x00E0, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA04__SRC_BT_CFG_4 = IOMUX_PAD(0x0428, 0x00E0, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA04__SIM_M_HADDR_25 = IOMUX_PAD(0x0428, 0x00E0, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA04__VADC_TEST_9 = IOMUX_PAD(0x0428, 0x00E0, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA04__MMDC_DEBUG_9 = IOMUX_PAD(0x0428, 0x00E0, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA05__LCDIF1_DATA_5 = IOMUX_PAD(0x042C, 0x00E4, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA05__WEIM_ADDR_26 = IOMUX_PAD(0x042C, 0x00E4, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA05__KITTEN_TRACE_5 = IOMUX_PAD(0x042C, 0x00E4, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA05__CSI1_HSYNC = IOMUX_PAD(0x042C, 0x00E4, 4, 0x0700, 1, 0), + MX6_PAD_LCD1_DATA05__GPIO3_IO_6 = IOMUX_PAD(0x042C, 0x00E4, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA05__SRC_BT_CFG_5 = IOMUX_PAD(0x042C, 0x00E4, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA05__SIM_M_HADDR_26 = IOMUX_PAD(0x042C, 0x00E4, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA05__VADC_TEST_10 = IOMUX_PAD(0x042C, 0x00E4, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA05__MMDC_DEBUG_10 = IOMUX_PAD(0x042C, 0x00E4, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA06__LCDIF1_DATA_6 = IOMUX_PAD(0x0430, 0x00E8, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA06__WEIM_EB_B_2 = IOMUX_PAD(0x0430, 0x00E8, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA06__KITTEN_TRACE_6 = IOMUX_PAD(0x0430, 0x00E8, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA06__CSI1_PIXCLK = IOMUX_PAD(0x0430, 0x00E8, 4, 0x0704, 1, 0), + MX6_PAD_LCD1_DATA06__GPIO3_IO_7 = IOMUX_PAD(0x0430, 0x00E8, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA06__SRC_BT_CFG_6 = IOMUX_PAD(0x0430, 0x00E8, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA06__SIM_M_HADDR_27 = IOMUX_PAD(0x0430, 0x00E8, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA06__VADC_TEST_11 = IOMUX_PAD(0x0430, 0x00E8, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA06__MMDC_DEBUG_11 = IOMUX_PAD(0x0430, 0x00E8, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA07__LCDIF1_DATA_7 = IOMUX_PAD(0x0434, 0x00EC, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA07__WEIM_EB_B_3 = IOMUX_PAD(0x0434, 0x00EC, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA07__KITTEN_TRACE_7 = IOMUX_PAD(0x0434, 0x00EC, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA07__CSI1_MCLK = IOMUX_PAD(0x0434, 0x00EC, 4, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA07__GPIO3_IO_8 = IOMUX_PAD(0x0434, 0x00EC, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA07__SRC_BT_CFG_7 = IOMUX_PAD(0x0434, 0x00EC, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA07__SIM_M_HADDR_28 = IOMUX_PAD(0x0434, 0x00EC, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA07__VADC_TEST_12 = IOMUX_PAD(0x0434, 0x00EC, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA07__MMDC_DEBUG_12 = IOMUX_PAD(0x0434, 0x00EC, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA08__LCDIF1_DATA_8 = IOMUX_PAD(0x0438, 0x00F0, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA08__WEIM_AD_8 = IOMUX_PAD(0x0438, 0x00F0, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA08__KITTEN_TRACE_8 = IOMUX_PAD(0x0438, 0x00F0, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA08__CSI1_DATA_9 = IOMUX_PAD(0x0438, 0x00F0, 4, 0x06C4, 1, 0), + MX6_PAD_LCD1_DATA08__GPIO3_IO_9 = IOMUX_PAD(0x0438, 0x00F0, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA08__SRC_BT_CFG_8 = IOMUX_PAD(0x0438, 0x00F0, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA08__SIM_M_HADDR_29 = IOMUX_PAD(0x0438, 0x00F0, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA08__VADC_TEST_13 = IOMUX_PAD(0x0438, 0x00F0, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA08__MMDC_DEBUG_13 = IOMUX_PAD(0x0438, 0x00F0, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA09__LCDIF1_DATA_9 = IOMUX_PAD(0x043C, 0x00F4, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA09__WEIM_AD_9 = IOMUX_PAD(0x043C, 0x00F4, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA09__KITTEN_TRACE_9 = IOMUX_PAD(0x043C, 0x00F4, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA09__CSI1_DATA_8 = IOMUX_PAD(0x043C, 0x00F4, 4, 0x06C0, 1, 0), + MX6_PAD_LCD1_DATA09__GPIO3_IO_10 = IOMUX_PAD(0x043C, 0x00F4, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA09__SRC_BT_CFG_9 = IOMUX_PAD(0x043C, 0x00F4, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA09__SIM_M_HADDR_30 = IOMUX_PAD(0x043C, 0x00F4, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA09__VADC_TEST_14 = IOMUX_PAD(0x043C, 0x00F4, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA09__MMDC_DEBUG_14 = IOMUX_PAD(0x043C, 0x00F4, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA10__LCDIF1_DATA_10 = IOMUX_PAD(0x0440, 0x00F8, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA10__WEIM_AD_10 = IOMUX_PAD(0x0440, 0x00F8, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA10__KITTEN_TRACE_10 = IOMUX_PAD(0x0440, 0x00F8, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA10__CSI1_DATA_7 = IOMUX_PAD(0x0440, 0x00F8, 4, 0x06BC, 1, 0), + MX6_PAD_LCD1_DATA10__GPIO3_IO_11 = IOMUX_PAD(0x0440, 0x00F8, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA10__SRC_BT_CFG_10 = IOMUX_PAD(0x0440, 0x00F8, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA10__SIM_M_HADDR_31 = IOMUX_PAD(0x0440, 0x00F8, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA10__VADC_TEST_15 = IOMUX_PAD(0x0440, 0x00F8, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA10__MMDC_DEBUG_15 = IOMUX_PAD(0x0440, 0x00F8, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA11__LCDIF1_DATA_11 = IOMUX_PAD(0x0444, 0x00FC, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA11__WEIM_AD_11 = IOMUX_PAD(0x0444, 0x00FC, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA11__KITTEN_TRACE_11 = IOMUX_PAD(0x0444, 0x00FC, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA11__CSI1_DATA_6 = IOMUX_PAD(0x0444, 0x00FC, 4, 0x06B8, 1, 0), + MX6_PAD_LCD1_DATA11__GPIO3_IO_12 = IOMUX_PAD(0x0444, 0x00FC, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA11__SRC_BT_CFG_11 = IOMUX_PAD(0x0444, 0x00FC, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA11__SIM_M_HBURST_0 = IOMUX_PAD(0x0444, 0x00FC, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA11__VADC_TEST_16 = IOMUX_PAD(0x0444, 0x00FC, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA11__MMDC_DEBUG_16 = IOMUX_PAD(0x0444, 0x00FC, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA12__LCDIF1_DATA_12 = IOMUX_PAD(0x0448, 0x0100, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA12__WEIM_AD_12 = IOMUX_PAD(0x0448, 0x0100, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA12__KITTEN_TRACE_12 = IOMUX_PAD(0x0448, 0x0100, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA12__CSI1_DATA_5 = IOMUX_PAD(0x0448, 0x0100, 4, 0x06B4, 1, 0), + MX6_PAD_LCD1_DATA12__GPIO3_IO_13 = IOMUX_PAD(0x0448, 0x0100, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA12__SRC_BT_CFG_12 = IOMUX_PAD(0x0448, 0x0100, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA12__SIM_M_HBURST_1 = IOMUX_PAD(0x0448, 0x0100, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA12__VADC_TEST_17 = IOMUX_PAD(0x0448, 0x0100, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA12__MMDC_DEBUG_17 = IOMUX_PAD(0x0448, 0x0100, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA13__LCDIF1_DATA_13 = IOMUX_PAD(0x044C, 0x0104, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA13__WEIM_AD_13 = IOMUX_PAD(0x044C, 0x0104, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA13__KITTEN_TRACE_13 = IOMUX_PAD(0x044C, 0x0104, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA13__CSI1_DATA_4 = IOMUX_PAD(0x044C, 0x0104, 4, 0x06B0, 1, 0), + MX6_PAD_LCD1_DATA13__GPIO3_IO_14 = IOMUX_PAD(0x044C, 0x0104, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA13__SRC_BT_CFG_13 = IOMUX_PAD(0x044C, 0x0104, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA13__SIM_M_HBURST_2 = IOMUX_PAD(0x044C, 0x0104, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA13__VADC_TEST_18 = IOMUX_PAD(0x044C, 0x0104, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA13__MMDC_DEBUG_18 = IOMUX_PAD(0x044C, 0x0104, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA14__LCDIF1_DATA_14 = IOMUX_PAD(0x0450, 0x0108, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA14__WEIM_AD_14 = IOMUX_PAD(0x0450, 0x0108, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA14__KITTEN_TRACE_14 = IOMUX_PAD(0x0450, 0x0108, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA14__CSI1_DATA_3 = IOMUX_PAD(0x0450, 0x0108, 4, 0x06AC, 1, 0), + MX6_PAD_LCD1_DATA14__GPIO3_IO_15 = IOMUX_PAD(0x0450, 0x0108, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA14__SRC_BT_CFG_14 = IOMUX_PAD(0x0450, 0x0108, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA14__SIM_M_HMASTLOCK = IOMUX_PAD(0x0450, 0x0108, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA14__VADC_TEST_19 = IOMUX_PAD(0x0450, 0x0108, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA14__MMDC_DEBUG_19 = IOMUX_PAD(0x0450, 0x0108, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA15__LCDIF1_DATA_15 = IOMUX_PAD(0x0454, 0x010C, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA15__WEIM_AD_15 = IOMUX_PAD(0x0454, 0x010C, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA15__KITTEN_TRACE_15 = IOMUX_PAD(0x0454, 0x010C, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA15__CSI1_DATA_2 = IOMUX_PAD(0x0454, 0x010C, 4, 0x06A8, 1, 0), + MX6_PAD_LCD1_DATA15__GPIO3_IO_16 = IOMUX_PAD(0x0454, 0x010C, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA15__SRC_BT_CFG_15 = IOMUX_PAD(0x0454, 0x010C, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA15__SIM_M_HPROT_0 = IOMUX_PAD(0x0454, 0x010C, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA15__VDEC_DEBUG_0 = IOMUX_PAD(0x0454, 0x010C, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA15__MMDC_DEBUG_20 = IOMUX_PAD(0x0454, 0x010C, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA16__LCDIF1_DATA_16 = IOMUX_PAD(0x0458, 0x0110, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA16__WEIM_ADDR_16 = IOMUX_PAD(0x0458, 0x0110, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA16__M4_TRACE_CLK = IOMUX_PAD(0x0458, 0x0110, 2, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA16__KITTEN_TRACE_CLK = IOMUX_PAD(0x0458, 0x0110, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA16__CSI1_DATA_1 = IOMUX_PAD(0x0458, 0x0110, 4, 0x06A4, 0, 0), + MX6_PAD_LCD1_DATA16__GPIO3_IO_17 = IOMUX_PAD(0x0458, 0x0110, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA16__SRC_BT_CFG_24 = IOMUX_PAD(0x0458, 0x0110, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA16__SIM_M_HPROT_1 = IOMUX_PAD(0x0458, 0x0110, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA16__VDEC_DEBUG_1 = IOMUX_PAD(0x0458, 0x0110, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA16__MMDC_DEBUG_21 = IOMUX_PAD(0x0458, 0x0110, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA17__LCDIF1_DATA_17 = IOMUX_PAD(0x045C, 0x0114, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA17__WEIM_ADDR_17 = IOMUX_PAD(0x045C, 0x0114, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA17__KITTEN_TRACE_CTL = IOMUX_PAD(0x045C, 0x0114, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA17__CSI1_DATA_0 = IOMUX_PAD(0x045C, 0x0114, 4, 0x06A0, 0, 0), + MX6_PAD_LCD1_DATA17__GPIO3_IO_18 = IOMUX_PAD(0x045C, 0x0114, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA17__SRC_BT_CFG_25 = IOMUX_PAD(0x045C, 0x0114, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA17__SIM_M_HPROT_2 = IOMUX_PAD(0x045C, 0x0114, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA17__VDEC_DEBUG_2 = IOMUX_PAD(0x045C, 0x0114, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA17__MMDC_DEBUG_22 = IOMUX_PAD(0x045C, 0x0114, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA18__LCDIF1_DATA_18 = IOMUX_PAD(0x0460, 0x0118, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA18__WEIM_ADDR_18 = IOMUX_PAD(0x0460, 0x0118, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA18__M4_EVENTO = IOMUX_PAD(0x0460, 0x0118, 2, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA18__KITTEN_EVENTO = IOMUX_PAD(0x0460, 0x0118, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA18__CSI1_DATA_15 = IOMUX_PAD(0x0460, 0x0118, 4, 0x06D8, 0, 0), + MX6_PAD_LCD1_DATA18__GPIO3_IO_19 = IOMUX_PAD(0x0460, 0x0118, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA18__SRC_BT_CFG_26 = IOMUX_PAD(0x0460, 0x0118, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA18__SIM_M_HPROT_3 = IOMUX_PAD(0x0460, 0x0118, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA18__VDEC_DEBUG_3 = IOMUX_PAD(0x0460, 0x0118, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA18__MMDC_DEBUG_23 = IOMUX_PAD(0x0460, 0x0118, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA19__LCDIF1_DATA_19 = IOMUX_PAD(0x0464, 0x011C, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA19__WEIM_ADDR_19 = IOMUX_PAD(0x0464, 0x011C, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA19__M4_TRACE_SWO = IOMUX_PAD(0x0464, 0x011C, 2, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA19__CSI1_DATA_14 = IOMUX_PAD(0x0464, 0x011C, 4, 0x06D4, 0, 0), + MX6_PAD_LCD1_DATA19__GPIO3_IO_20 = IOMUX_PAD(0x0464, 0x011C, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA19__SRC_BT_CFG_27 = IOMUX_PAD(0x0464, 0x011C, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA19__SIM_M_HREADYOUT = IOMUX_PAD(0x0464, 0x011C, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA19__VDEC_DEBUG_4 = IOMUX_PAD(0x0464, 0x011C, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA19__MMDC_DEBUG_24 = IOMUX_PAD(0x0464, 0x011C, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA20__LCDIF1_DATA_20 = IOMUX_PAD(0x0468, 0x0120, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA20__WEIM_ADDR_20 = IOMUX_PAD(0x0468, 0x0120, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA20__PWM8_OUT = IOMUX_PAD(0x0468, 0x0120, 2, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA20__ENET1_1588_EVENT2_OUT = IOMUX_PAD(0x0468, 0x0120, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA20__CSI1_DATA_13 = IOMUX_PAD(0x0468, 0x0120, 4, 0x06D0, 0, 0), + MX6_PAD_LCD1_DATA20__GPIO3_IO_21 = IOMUX_PAD(0x0468, 0x0120, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA20__SRC_BT_CFG_28 = IOMUX_PAD(0x0468, 0x0120, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA20__SIM_M_HRESP = IOMUX_PAD(0x0468, 0x0120, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA20__VDEC_DEBUG_5 = IOMUX_PAD(0x0468, 0x0120, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA20__MMDC_DEBUG_25 = IOMUX_PAD(0x0468, 0x0120, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA21__LCDIF1_DATA_21 = IOMUX_PAD(0x046C, 0x0124, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA21__WEIM_ADDR_21 = IOMUX_PAD(0x046C, 0x0124, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA21__PWM7_OUT = IOMUX_PAD(0x046C, 0x0124, 2, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA21__ENET1_1588_EVENT3_OUT = IOMUX_PAD(0x046C, 0x0124, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA21__CSI1_DATA_12 = IOMUX_PAD(0x046C, 0x0124, 4, 0x06CC, 0, 0), + MX6_PAD_LCD1_DATA21__GPIO3_IO_22 = IOMUX_PAD(0x046C, 0x0124, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA21__SRC_BT_CFG_29 = IOMUX_PAD(0x046C, 0x0124, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA21__SIM_M_HSIZE_0 = IOMUX_PAD(0x046C, 0x0124, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA21__VDEC_DEBUG_6 = IOMUX_PAD(0x046C, 0x0124, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA21__MMDC_DEBUG_26 = IOMUX_PAD(0x046C, 0x0124, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA22__LCDIF1_DATA_22 = IOMUX_PAD(0x0470, 0x0128, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA22__WEIM_ADDR_22 = IOMUX_PAD(0x0470, 0x0128, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA22__PWM6_OUT = IOMUX_PAD(0x0470, 0x0128, 2, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA22__ENET2_1588_EVENT2_OUT = IOMUX_PAD(0x0470, 0x0128, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA22__CSI1_DATA_11 = IOMUX_PAD(0x0470, 0x0128, 4, 0x06C8, 0, 0), + MX6_PAD_LCD1_DATA22__GPIO3_IO_23 = IOMUX_PAD(0x0470, 0x0128, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA22__SRC_BT_CFG_30 = IOMUX_PAD(0x0470, 0x0128, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA22__SIM_M_HSIZE_1 = IOMUX_PAD(0x0470, 0x0128, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA22__VDEC_DEBUG_7 = IOMUX_PAD(0x0470, 0x0128, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA22__MMDC_DEBUG_27 = IOMUX_PAD(0x0470, 0x0128, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_DATA23__LCDIF1_DATA_23 = IOMUX_PAD(0x0474, 0x012C, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA23__WEIM_ADDR_23 = IOMUX_PAD(0x0474, 0x012C, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA23__PWM5_OUT = IOMUX_PAD(0x0474, 0x012C, 2, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA23__ENET2_1588_EVENT3_OUT = IOMUX_PAD(0x0474, 0x012C, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA23__CSI1_DATA_10 = IOMUX_PAD(0x0474, 0x012C, 4, 0x06FC, 0, 0), + MX6_PAD_LCD1_DATA23__GPIO3_IO_24 = IOMUX_PAD(0x0474, 0x012C, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA23__SRC_BT_CFG_31 = IOMUX_PAD(0x0474, 0x012C, 6, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA23__SIM_M_HSIZE_2 = IOMUX_PAD(0x0474, 0x012C, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA23__VDEC_DEBUG_8 = IOMUX_PAD(0x0474, 0x012C, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_DATA23__MMDC_DEBUG_28 = IOMUX_PAD(0x0474, 0x012C, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_ENABLE__LCDIF1_ENABLE = IOMUX_PAD(0x0478, 0x0130, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_ENABLE__LCDIF1_RD_E = IOMUX_PAD(0x0478, 0x0130, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_ENABLE__AUDMUX_AUD3_TXC = IOMUX_PAD(0x0478, 0x0130, 2, 0x063C, 1, 0), + MX6_PAD_LCD1_ENABLE__ENET1_1588_EVENT3_IN = IOMUX_PAD(0x0478, 0x0130, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_ENABLE__CSI1_DATA_17 = IOMUX_PAD(0x0478, 0x0130, 4, 0x06E0, 0, 0), + MX6_PAD_LCD1_ENABLE__GPIO3_IO_25 = IOMUX_PAD(0x0478, 0x0130, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_ENABLE__USDHC1_CD_B = IOMUX_PAD(0x0478, 0x0130, 6, 0x0864, 0, 0), + MX6_PAD_LCD1_ENABLE__SIM_M_HADDR_17 = IOMUX_PAD(0x0478, 0x0130, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_ENABLE__VADC_TEST_1 = IOMUX_PAD(0x0478, 0x0130, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_ENABLE__MMDC_DEBUG_1 = IOMUX_PAD(0x0478, 0x0130, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_HSYNC__LCDIF1_HSYNC = IOMUX_PAD(0x047C, 0x0134, 0, 0x07E0, 0, 0), + MX6_PAD_LCD1_HSYNC__LCDIF1_RS = IOMUX_PAD(0x047C, 0x0134, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_HSYNC__AUDMUX_AUD3_TXD = IOMUX_PAD(0x047C, 0x0134, 2, 0x0630, 1, 0), + MX6_PAD_LCD1_HSYNC__ENET2_1588_EVENT2_IN = IOMUX_PAD(0x047C, 0x0134, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_HSYNC__CSI1_DATA_18 = IOMUX_PAD(0x047C, 0x0134, 4, 0x06E4, 0, 0), + MX6_PAD_LCD1_HSYNC__GPIO3_IO_26 = IOMUX_PAD(0x047C, 0x0134, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_HSYNC__USDHC2_WP = IOMUX_PAD(0x047C, 0x0134, 6, 0x0870, 0, 0), + MX6_PAD_LCD1_HSYNC__SIM_M_HADDR_18 = IOMUX_PAD(0x047C, 0x0134, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_HSYNC__VADC_TEST_2 = IOMUX_PAD(0x047C, 0x0134, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_HSYNC__MMDC_DEBUG_2 = IOMUX_PAD(0x047C, 0x0134, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_RESET__LCDIF1_RESET = IOMUX_PAD(0x0480, 0x0138, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_RESET__LCDIF1_CS = IOMUX_PAD(0x0480, 0x0138, 1, 0x0000, 0, 0), + MX6_PAD_LCD1_RESET__AUDMUX_AUD3_RXD = IOMUX_PAD(0x0480, 0x0138, 2, 0x062C, 1, 0), + MX6_PAD_LCD1_RESET__KITTEN_EVENTI = IOMUX_PAD(0x0480, 0x0138, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_RESET__M4_EVENTI = IOMUX_PAD(0x0480, 0x0138, 4, 0x0000, 0, 0), + MX6_PAD_LCD1_RESET__GPIO3_IO_27 = IOMUX_PAD(0x0480, 0x0138, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_RESET__CCM_PMIC_RDY = IOMUX_PAD(0x0480, 0x0138, 6, 0x069C, 0, 0), + MX6_PAD_LCD1_RESET__SIM_M_HADDR_20 = IOMUX_PAD(0x0480, 0x0138, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_RESET__VADC_TEST_4 = IOMUX_PAD(0x0480, 0x0138, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_RESET__MMDC_DEBUG_4 = IOMUX_PAD(0x0480, 0x0138, 9, 0x0000, 0, 0), + + MX6_PAD_LCD1_VSYNC__LCDIF1_VSYNC = IOMUX_PAD(0x0484, 0x013C, 0, 0x0000, 0, 0), + MX6_PAD_LCD1_VSYNC__LCDIF1_BUSY = IOMUX_PAD(0x0484, 0x013C, 1, 0x07E0, 1, 0), + MX6_PAD_LCD1_VSYNC__AUDMUX_AUD3_TXFS = IOMUX_PAD(0x0484, 0x013C, 2, 0x0640, 1, 0), + MX6_PAD_LCD1_VSYNC__ENET2_1588_EVENT3_IN = IOMUX_PAD(0x0484, 0x013C, 3, 0x0000, 0, 0), + MX6_PAD_LCD1_VSYNC__CSI1_DATA_19 = IOMUX_PAD(0x0484, 0x013C, 4, 0x06E8, 0, 0), + MX6_PAD_LCD1_VSYNC__GPIO3_IO_28 = IOMUX_PAD(0x0484, 0x013C, 5, 0x0000, 0, 0), + MX6_PAD_LCD1_VSYNC__USDHC2_CD_B = IOMUX_PAD(0x0484, 0x013C, 6, 0x086C, 0, 0), + MX6_PAD_LCD1_VSYNC__SIM_M_HADDR_19 = IOMUX_PAD(0x0484, 0x013C, 7, 0x0000, 0, 0), + MX6_PAD_LCD1_VSYNC__VADC_TEST_3 = IOMUX_PAD(0x0484, 0x013C, 8, 0x0000, 0, 0), + MX6_PAD_LCD1_VSYNC__MMDC_DEBUG_3 = IOMUX_PAD(0x0484, 0x013C, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_ALE__RAWNAND_ALE = IOMUX_PAD(0x0488, 0x0140, 0, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__I2C3_SDA = IOMUX_PAD(0x0488, 0x0140, 1, 0x07BC, 0, 0), + MX6_PAD_NAND_ALE__QSPI2_A_SS0_B = IOMUX_PAD(0x0488, 0x0140, 2, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__ECSPI2_SS0 = IOMUX_PAD(0x0488, 0x0140, 3, 0x072C, 0, 0), + MX6_PAD_NAND_ALE__ESAI_TX3_RX2 = IOMUX_PAD(0x0488, 0x0140, 4, 0x079C, 0, 0), + MX6_PAD_NAND_ALE__GPIO4_IO_0 = IOMUX_PAD(0x0488, 0x0140, 5, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__WEIM_CS0_B = IOMUX_PAD(0x0488, 0x0140, 6, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__TPSMP_HDATA_0 = IOMUX_PAD(0x0488, 0x0140, 7, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__ANATOP_USBPHY1_TSTI_TX_EN = IOMUX_PAD(0x0488, 0x0140, 8, 0x0000, 0, 0), + MX6_PAD_NAND_ALE__SDMA_DEBUG_PC_12 = IOMUX_PAD(0x0488, 0x0140, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_CE0_B__RAWNAND_CE0_B = IOMUX_PAD(0x048C, 0x0144, 0, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__USDHC2_VSELECT = IOMUX_PAD(0x048C, 0x0144, 1, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__QSPI2_A_DATA_2 = IOMUX_PAD(0x048C, 0x0144, 2, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__AUDMUX_AUD4_TXC = IOMUX_PAD(0x048C, 0x0144, 3, 0x0654, 0, 0), + MX6_PAD_NAND_CE0_B__ESAI_TX_CLK = IOMUX_PAD(0x048C, 0x0144, 4, 0x078C, 0, 0), + MX6_PAD_NAND_CE0_B__GPIO4_IO_1 = IOMUX_PAD(0x048C, 0x0144, 5, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__WEIM_LBA_B = IOMUX_PAD(0x048C, 0x0144, 6, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__TPSMP_HDATA_3 = IOMUX_PAD(0x048C, 0x0144, 7, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__ANATOP_USBPHY1_TSTI_TX_HIZ = IOMUX_PAD(0x048C, 0x0144, 8, 0x0000, 0, 0), + MX6_PAD_NAND_CE0_B__SDMA_DEBUG_PC_9 = IOMUX_PAD(0x048C, 0x0144, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_CE1_B__RAWNAND_CE1_B = IOMUX_PAD(0x0490, 0x0148, 0, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__USDHC3_RESET_B = IOMUX_PAD(0x0490, 0x0148, 1, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__QSPI2_A_DATA_3 = IOMUX_PAD(0x0490, 0x0148, 2, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__AUDMUX_AUD4_TXD = IOMUX_PAD(0x0490, 0x0148, 3, 0x0648, 0, 0), + MX6_PAD_NAND_CE1_B__ESAI_TX0 = IOMUX_PAD(0x0490, 0x0148, 4, 0x0790, 0, 0), + MX6_PAD_NAND_CE1_B__GPIO4_IO_2 = IOMUX_PAD(0x0490, 0x0148, 5, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__WEIM_OE = IOMUX_PAD(0x0490, 0x0148, 6, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__TPSMP_HDATA_4 = IOMUX_PAD(0x0490, 0x0148, 7, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__ANATOP_USBPHY1_TSTI_TX_LS_MODE = IOMUX_PAD(0x0490, 0x0148, 8, 0x0000, 0, 0), + MX6_PAD_NAND_CE1_B__SDMA_DEBUG_PC_8 = IOMUX_PAD(0x0490, 0x0148, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_CLE__RAWNAND_CLE = IOMUX_PAD(0x0494, 0x014C, 0, 0x0000, 0, 0), + MX6_PAD_NAND_CLE__I2C3_SCL = IOMUX_PAD(0x0494, 0x014C, 1, 0x07B8, 0, 0), + MX6_PAD_NAND_CLE__QSPI2_A_SCLK = IOMUX_PAD(0x0494, 0x014C, 2, 0x0000, 0, 0), + MX6_PAD_NAND_CLE__ECSPI2_SCLK = IOMUX_PAD(0x0494, 0x014C, 3, 0x0720, 0, 0), + MX6_PAD_NAND_CLE__ESAI_TX2_RX3 = IOMUX_PAD(0x0494, 0x014C, 4, 0x0798, 0, 0), + MX6_PAD_NAND_CLE__GPIO4_IO_3 = IOMUX_PAD(0x0494, 0x014C, 5, 0x0000, 0, 0), + MX6_PAD_NAND_CLE__WEIM_BCLK = IOMUX_PAD(0x0494, 0x014C, 6, 0x0000, 0, 0), + MX6_PAD_NAND_CLE__TPSMP_CLK = IOMUX_PAD(0x0494, 0x014C, 7, 0x0000, 0, 0), + MX6_PAD_NAND_CLE__ANATOP_USBPHY1_TSTI_TX_DP = IOMUX_PAD(0x0494, 0x014C, 8, 0x0000, 0, 0), + MX6_PAD_NAND_CLE__SDMA_DEBUG_PC_13 = IOMUX_PAD(0x0494, 0x014C, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA00__RAWNAND_DATA00 = IOMUX_PAD(0x0498, 0x0150, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA00__USDHC1_DATA4 = IOMUX_PAD(0x0498, 0x0150, 1, 0x0000, 0, 0), + MX6_PAD_NAND_DATA00__QSPI2_B_DATA_1 = IOMUX_PAD(0x0498, 0x0150, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA00__ECSPI5_MISO = IOMUX_PAD(0x0498, 0x0150, 3, 0x0754, 0, 0), + MX6_PAD_NAND_DATA00__ESAI_RX_CLK = IOMUX_PAD(0x0498, 0x0150, 4, 0x0788, 0, 0), + MX6_PAD_NAND_DATA00__GPIO4_IO_4 = IOMUX_PAD(0x0498, 0x0150, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA00__WEIM_AD_0 = IOMUX_PAD(0x0498, 0x0150, 6, 0x0000, 0, 0), + MX6_PAD_NAND_DATA00__TPSMP_HDATA_7 = IOMUX_PAD(0x0498, 0x0150, 7, 0x0000, 0, 0), + MX6_PAD_NAND_DATA00__ANATOP_USBPHY1_TSTO_RX_DISCON_DET = IOMUX_PAD(0x0498, 0x0150, 8, 0x0000, 0, 0), + MX6_PAD_NAND_DATA00__SDMA_DEBUG_EVT_CHN_LINES_5 = IOMUX_PAD(0x0498, 0x0150, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA01__RAWNAND_DATA01 = IOMUX_PAD(0x049C, 0x0154, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA01__USDHC1_DATA5 = IOMUX_PAD(0x049C, 0x0154, 1, 0x0000, 0, 0), + MX6_PAD_NAND_DATA01__QSPI2_B_DATA_0 = IOMUX_PAD(0x049C, 0x0154, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA01__ECSPI5_MOSI = IOMUX_PAD(0x049C, 0x0154, 3, 0x0758, 0, 0), + MX6_PAD_NAND_DATA01__ESAI_RX_FS = IOMUX_PAD(0x049C, 0x0154, 4, 0x0778, 0, 0), + MX6_PAD_NAND_DATA01__GPIO4_IO_5 = IOMUX_PAD(0x049C, 0x0154, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA01__WEIM_AD_1 = IOMUX_PAD(0x049C, 0x0154, 6, 0x0000, 0, 0), + MX6_PAD_NAND_DATA01__TPSMP_HDATA_8 = IOMUX_PAD(0x049C, 0x0154, 7, 0x0000, 0, 0), + MX6_PAD_NAND_DATA01__ANATOP_USBPHY1_TSTO_RX_HS_RXD = IOMUX_PAD(0x049C, 0x0154, 8, 0x0000, 0, 0), + MX6_PAD_NAND_DATA01__SDMA_DEBUG_EVT_CHN_LINES_4 = IOMUX_PAD(0x049C, 0x0154, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA02__RAWNAND_DATA02 = IOMUX_PAD(0x04A0, 0x0158, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA02__USDHC1_DATA6 = IOMUX_PAD(0x04A0, 0x0158, 1, 0x0000, 0, 0), + MX6_PAD_NAND_DATA02__QSPI2_B_SCLK = IOMUX_PAD(0x04A0, 0x0158, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA02__ECSPI5_SCLK = IOMUX_PAD(0x04A0, 0x0158, 3, 0x0750, 0, 0), + MX6_PAD_NAND_DATA02__ESAI_TX_HF_CLK = IOMUX_PAD(0x04A0, 0x0158, 4, 0x0784, 0, 0), + MX6_PAD_NAND_DATA02__GPIO4_IO_6 = IOMUX_PAD(0x04A0, 0x0158, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA02__WEIM_AD_2 = IOMUX_PAD(0x04A0, 0x0158, 6, 0x0000, 0, 0), + MX6_PAD_NAND_DATA02__TPSMP_HDATA_9 = IOMUX_PAD(0x04A0, 0x0158, 7, 0x0000, 0, 0), + MX6_PAD_NAND_DATA02__ANATOP_USBPHY2_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x04A0, 0x0158, 8, 0x0000, 0, 0), + MX6_PAD_NAND_DATA02__SDMA_DEBUG_EVT_CHN_LINES_3 = IOMUX_PAD(0x04A0, 0x0158, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA03__RAWNAND_DATA03 = IOMUX_PAD(0x04A4, 0x015C, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA03__USDHC1_DATA7 = IOMUX_PAD(0x04A4, 0x015C, 1, 0x0000, 0, 0), + MX6_PAD_NAND_DATA03__QSPI2_B_SS0_B = IOMUX_PAD(0x04A4, 0x015C, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA03__ECSPI5_SS0 = IOMUX_PAD(0x04A4, 0x015C, 3, 0x075C, 0, 0), + MX6_PAD_NAND_DATA03__ESAI_RX_HF_CLK = IOMUX_PAD(0x04A4, 0x015C, 4, 0x0780, 0, 0), + MX6_PAD_NAND_DATA03__GPIO4_IO_7 = IOMUX_PAD(0x04A4, 0x015C, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA03__WEIM_AD_3 = IOMUX_PAD(0x04A4, 0x015C, 6, 0x0000, 0, 0), + MX6_PAD_NAND_DATA03__TPSMP_HDATA_10 = IOMUX_PAD(0x04A4, 0x015C, 7, 0x0000, 0, 0), + MX6_PAD_NAND_DATA03__ANATOP_USBPHY1_TSTO_RX_SQUELCH = IOMUX_PAD(0x04A4, 0x015C, 8, 0x0000, 0, 0), + MX6_PAD_NAND_DATA03__SDMA_DEBUG_EVT_CHN_LINES_6 = IOMUX_PAD(0x04A4, 0x015C, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA04__RAWNAND_DATA04 = IOMUX_PAD(0x04A8, 0x0160, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__USDHC2_DATA4 = IOMUX_PAD(0x04A8, 0x0160, 1, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__QSPI2_B_SS1_B = IOMUX_PAD(0x04A8, 0x0160, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__UART3_RTS_B = IOMUX_PAD(0x04A8, 0x0160, 3, 0x083C, 0, 0), + MX6_PAD_NAND_DATA04__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x04A8, 0x0160, 4, 0x0650, 0, 0), + MX6_PAD_NAND_DATA04__GPIO4_IO_8 = IOMUX_PAD(0x04A8, 0x0160, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__WEIM_AD_4 = IOMUX_PAD(0x04A8, 0x0160, 6, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__TPSMP_HDATA_11 = IOMUX_PAD(0x04A8, 0x0160, 7, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__ANATOP_USBPHY2_TSTO_RX_SQUELCH = IOMUX_PAD(0x04A8, 0x0160, 8, 0x0000, 0, 0), + MX6_PAD_NAND_DATA04__SDMA_DEBUG_CORE_STATE_0 = IOMUX_PAD(0x04A8, 0x0160, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA05__RAWNAND_DATA05 = IOMUX_PAD(0x04AC, 0x0164, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA05__USDHC2_DATA5 = IOMUX_PAD(0x04AC, 0x0164, 1, 0x0000, 0, 0), + MX6_PAD_NAND_DATA05__QSPI2_B_DQS = IOMUX_PAD(0x04AC, 0x0164, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA05__UART3_CTS_B = IOMUX_PAD(0x04AC, 0x0164, 3, 0x083C, 1, 0), + MX6_PAD_NAND_DATA05__AUDMUX_AUD4_RXC = IOMUX_PAD(0x04AC, 0x0164, 4, 0x064C, 0, 0), + MX6_PAD_NAND_DATA05__GPIO4_IO_9 = IOMUX_PAD(0x04AC, 0x0164, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA05__WEIM_AD_5 = IOMUX_PAD(0x04AC, 0x0164, 6, 0x0000, 0, 0), + MX6_PAD_NAND_DATA05__TPSMP_HDATA_12 = IOMUX_PAD(0x04AC, 0x0164, 7, 0x0000, 0, 0), + MX6_PAD_NAND_DATA05__ANATOP_USBPHY2_TSTO_RX_DISCON_DET = IOMUX_PAD(0x04AC, 0x0164, 8, 0x0000, 0, 0), + MX6_PAD_NAND_DATA05__SDMA_DEBUG_CORE_STATE_1 = IOMUX_PAD(0x04AC, 0x0164, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA06__RAWNAND_DATA06 = IOMUX_PAD(0x04B0, 0x0168, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__USDHC2_DATA6 = IOMUX_PAD(0x04B0, 0x0168, 1, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__QSPI2_A_SS1_B = IOMUX_PAD(0x04B0, 0x0168, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__UART3_RX = IOMUX_PAD(0x04B0, 0x0168, 3, 0x0840, 0, 0), + MX6_PAD_NAND_DATA06__PWM3_OUT = IOMUX_PAD(0x04B0, 0x0168, 4, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__GPIO4_IO_10 = IOMUX_PAD(0x04B0, 0x0168, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__WEIM_AD_6 = IOMUX_PAD(0x04B0, 0x0168, 6, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__TPSMP_HDATA_13 = IOMUX_PAD(0x04B0, 0x0168, 7, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__ANATOP_USBPHY2_TSTO_RX_FS_RXD = IOMUX_PAD(0x04B0, 0x0168, 8, 0x0000, 0, 0), + MX6_PAD_NAND_DATA06__SDMA_DEBUG_CORE_STATE_2 = IOMUX_PAD(0x04B0, 0x0168, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_DATA07__RAWNAND_DATA07 = IOMUX_PAD(0x04B4, 0x016C, 0, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__USDHC2_DATA7 = IOMUX_PAD(0x04B4, 0x016C, 1, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__QSPI2_A_DQS = IOMUX_PAD(0x04B4, 0x016C, 2, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__UART3_TX = IOMUX_PAD(0x04B4, 0x016C, 3, 0x0840, 1, 0), + MX6_PAD_NAND_DATA07__PWM4_OUT = IOMUX_PAD(0x04B4, 0x016C, 4, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__GPIO4_IO_11 = IOMUX_PAD(0x04B4, 0x016C, 5, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__WEIM_AD_7 = IOMUX_PAD(0x04B4, 0x016C, 6, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__TPSMP_HDATA_14 = IOMUX_PAD(0x04B4, 0x016C, 7, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__ANATOP_USBPHY1_TSTO_RX_FS_RXD = IOMUX_PAD(0x04B4, 0x016C, 8, 0x0000, 0, 0), + MX6_PAD_NAND_DATA07__SDMA_DEBUG_CORE_STATE_3 = IOMUX_PAD(0x04B4, 0x016C, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_RE_B__RAWNAND_RE_B = IOMUX_PAD(0x04B8, 0x0170, 0, 0x0000, 0, 0), + MX6_PAD_NAND_RE_B__USDHC2_RESET_B = IOMUX_PAD(0x04B8, 0x0170, 1, 0x0000, 0, 0), + MX6_PAD_NAND_RE_B__QSPI2_B_DATA_3 = IOMUX_PAD(0x04B8, 0x0170, 2, 0x0000, 0, 0), + MX6_PAD_NAND_RE_B__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x04B8, 0x0170, 3, 0x0658, 0, 0), + MX6_PAD_NAND_RE_B__ESAI_TX_FS = IOMUX_PAD(0x04B8, 0x0170, 4, 0x077C, 0, 0), + MX6_PAD_NAND_RE_B__GPIO4_IO_12 = IOMUX_PAD(0x04B8, 0x0170, 5, 0x0000, 0, 0), + MX6_PAD_NAND_RE_B__WEIM_RW = IOMUX_PAD(0x04B8, 0x0170, 6, 0x0000, 0, 0), + MX6_PAD_NAND_RE_B__TPSMP_HDATA_5 = IOMUX_PAD(0x04B8, 0x0170, 7, 0x0000, 0, 0), + MX6_PAD_NAND_RE_B__ANATOP_USBPHY2_TSTO_RX_HS_RXD = IOMUX_PAD(0x04B8, 0x0170, 8, 0x0000, 0, 0), + MX6_PAD_NAND_RE_B__SDMA_DEBUG_PC_7 = IOMUX_PAD(0x04B8, 0x0170, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_READY_B__RAWNAND_READY_B = IOMUX_PAD(0x04BC, 0x0174, 0, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__USDHC1_VSELECT = IOMUX_PAD(0x04BC, 0x0174, 1, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__QSPI2_A_DATA_1 = IOMUX_PAD(0x04BC, 0x0174, 2, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__ECSPI2_MISO = IOMUX_PAD(0x04BC, 0x0174, 3, 0x0724, 0, 0), + MX6_PAD_NAND_READY_B__ESAI_TX1 = IOMUX_PAD(0x04BC, 0x0174, 4, 0x0794, 0, 0), + MX6_PAD_NAND_READY_B__GPIO4_IO_13 = IOMUX_PAD(0x04BC, 0x0174, 5, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__WEIM_EB_B_1 = IOMUX_PAD(0x04BC, 0x0174, 6, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__TPSMP_HDATA_2 = IOMUX_PAD(0x04BC, 0x0174, 7, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__ANATOP_USBPHY1_TSTI_TX_DN = IOMUX_PAD(0x04BC, 0x0174, 8, 0x0000, 0, 0), + MX6_PAD_NAND_READY_B__SDMA_DEBUG_PC_10 = IOMUX_PAD(0x04BC, 0x0174, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_WE_B__RAWNAND_WE_B = IOMUX_PAD(0x04C0, 0x0178, 0, 0x0000, 0, 0), + MX6_PAD_NAND_WE_B__USDHC4_VSELECT = IOMUX_PAD(0x04C0, 0x0178, 1, 0x0000, 0, 0), + MX6_PAD_NAND_WE_B__QSPI2_B_DATA_2 = IOMUX_PAD(0x04C0, 0x0178, 2, 0x0000, 0, 0), + MX6_PAD_NAND_WE_B__AUDMUX_AUD4_RXD = IOMUX_PAD(0x04C0, 0x0178, 3, 0x0644, 0, 0), + MX6_PAD_NAND_WE_B__ESAI_TX5_RX0 = IOMUX_PAD(0x04C0, 0x0178, 4, 0x07A4, 0, 0), + MX6_PAD_NAND_WE_B__GPIO4_IO_14 = IOMUX_PAD(0x04C0, 0x0178, 5, 0x0000, 0, 0), + MX6_PAD_NAND_WE_B__WEIM_WAIT = IOMUX_PAD(0x04C0, 0x0178, 6, 0x0000, 0, 0), + MX6_PAD_NAND_WE_B__TPSMP_HDATA_6 = IOMUX_PAD(0x04C0, 0x0178, 7, 0x0000, 0, 0), + MX6_PAD_NAND_WE_B__ANATOP_USBPHY1_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x04C0, 0x0178, 8, 0x0000, 0, 0), + MX6_PAD_NAND_WE_B__SDMA_DEBUG_PC_6 = IOMUX_PAD(0x04C0, 0x0178, 9, 0x0000, 0, 0), + + MX6_PAD_NAND_WP_B__RAWNAND_WP_B = IOMUX_PAD(0x04C4, 0x017C, 0, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__USDHC1_RESET_B = IOMUX_PAD(0x04C4, 0x017C, 1, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__QSPI2_A_DATA_0 = IOMUX_PAD(0x04C4, 0x017C, 2, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__ECSPI2_MOSI = IOMUX_PAD(0x04C4, 0x017C, 3, 0x0728, 0, 0), + MX6_PAD_NAND_WP_B__ESAI_TX4_RX1 = IOMUX_PAD(0x04C4, 0x017C, 4, 0x07A0, 0, 0), + MX6_PAD_NAND_WP_B__GPIO4_IO_15 = IOMUX_PAD(0x04C4, 0x017C, 5, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__WEIM_EB_B_0 = IOMUX_PAD(0x04C4, 0x017C, 6, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__TPSMP_HDATA_1 = IOMUX_PAD(0x04C4, 0x017C, 7, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__ANATOP_USBPHY1_TSTI_TX_HS_MODE = IOMUX_PAD(0x04C4, 0x017C, 8, 0x0000, 0, 0), + MX6_PAD_NAND_WP_B__SDMA_DEBUG_PC_11 = IOMUX_PAD(0x04C4, 0x017C, 9, 0x0000, 0, 0), + + MX6_PAD_QSPI1A_DATA0__QSPI1_A_DATA_0 = IOMUX_PAD(0x04C8, 0x0180, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA0__USB_OTG2_OC = IOMUX_PAD(0x04C8, 0x0180, 1, 0x085C, 2, 0), + MX6_PAD_QSPI1A_DATA0__ECSPI1_MOSI = IOMUX_PAD(0x04C8, 0x0180, 2, 0x0718, 1, 0), + MX6_PAD_QSPI1A_DATA0__ESAI_TX4_RX1 = IOMUX_PAD(0x04C8, 0x0180, 3, 0x07A0, 2, 0), + MX6_PAD_QSPI1A_DATA0__CSI1_DATA_14 = IOMUX_PAD(0x04C8, 0x0180, 4, 0x06D4, 1, 0), + MX6_PAD_QSPI1A_DATA0__GPIO4_IO_16 = IOMUX_PAD(0x04C8, 0x0180, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA0__WEIM_DATA_6 = IOMUX_PAD(0x04C8, 0x0180, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA0__SIM_M_HADDR_3 = IOMUX_PAD(0x04C8, 0x0180, 7, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA0__SDMA_DEBUG_BUS_DEVICE_3 = IOMUX_PAD(0x04C8, 0x0180, 9, 0x0000, 0, 0), + + MX6_PAD_QSPI1A_DATA1__QSPI1_A_DATA_1 = IOMUX_PAD(0x04CC, 0x0184, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA1__ANATOP_OTG1_ID = IOMUX_PAD(0x04CC, 0x0184, 1, 0x0624, 2, 0), + MX6_PAD_QSPI1A_DATA1__ECSPI1_MISO = IOMUX_PAD(0x04CC, 0x0184, 2, 0x0714, 1, 0), + MX6_PAD_QSPI1A_DATA1__ESAI_TX1 = IOMUX_PAD(0x04CC, 0x0184, 3, 0x0794, 2, 0), + MX6_PAD_QSPI1A_DATA1__CSI1_DATA_13 = IOMUX_PAD(0x04CC, 0x0184, 4, 0x06D0, 1, 0), + MX6_PAD_QSPI1A_DATA1__GPIO4_IO_17 = IOMUX_PAD(0x04CC, 0x0184, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA1__WEIM_DATA_5 = IOMUX_PAD(0x04CC, 0x0184, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA1__SIM_M_HADDR_4 = IOMUX_PAD(0x04CC, 0x0184, 7, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA1__SDMA_DEBUG_PC_0 = IOMUX_PAD(0x04CC, 0x0184, 9, 0x0000, 0, 0), + + MX6_PAD_QSPI1A_DATA2__QSPI1_A_DATA_2 = IOMUX_PAD(0x04D0, 0x0188, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA2__USB_OTG1_PWR = IOMUX_PAD(0x04D0, 0x0188, 1, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA2__ECSPI5_SS1 = IOMUX_PAD(0x04D0, 0x0188, 2, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA2__ESAI_TX_CLK = IOMUX_PAD(0x04D0, 0x0188, 3, 0x078C, 2, 0), + MX6_PAD_QSPI1A_DATA2__CSI1_DATA_12 = IOMUX_PAD(0x04D0, 0x0188, 4, 0x06CC, 1, 0), + MX6_PAD_QSPI1A_DATA2__GPIO4_IO_18 = IOMUX_PAD(0x04D0, 0x0188, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA2__WEIM_DATA_4 = IOMUX_PAD(0x04D0, 0x0188, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA2__SIM_M_HADDR_6 = IOMUX_PAD(0x04D0, 0x0188, 7, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA2__SDMA_DEBUG_PC_1 = IOMUX_PAD(0x04D0, 0x0188, 9, 0x0000, 0, 0), + + MX6_PAD_QSPI1A_DATA3__QSPI1_A_DATA_3 = IOMUX_PAD(0x04D4, 0x018C, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA3__USB_OTG1_OC = IOMUX_PAD(0x04D4, 0x018C, 1, 0x0860, 2, 0), + MX6_PAD_QSPI1A_DATA3__ECSPI5_SS2 = IOMUX_PAD(0x04D4, 0x018C, 2, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA3__ESAI_TX0 = IOMUX_PAD(0x04D4, 0x018C, 3, 0x0790, 2, 0), + MX6_PAD_QSPI1A_DATA3__CSI1_DATA_11 = IOMUX_PAD(0x04D4, 0x018C, 4, 0x06C8, 1, 0), + MX6_PAD_QSPI1A_DATA3__GPIO4_IO_19 = IOMUX_PAD(0x04D4, 0x018C, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA3__WEIM_DATA_3 = IOMUX_PAD(0x04D4, 0x018C, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA3__SIM_M_HADDR_7 = IOMUX_PAD(0x04D4, 0x018C, 7, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DATA3__SDMA_DEBUG_PC_2 = IOMUX_PAD(0x04D4, 0x018C, 9, 0x0000, 0, 0), + + MX6_PAD_QSPI1A_DQS__QSPI1_A_DQS = IOMUX_PAD(0x04D8, 0x0190, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DQS__CAN2_TX = IOMUX_PAD(0x04D8, 0x0190, 1, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DQS__CANFD_TX2 = IOMUX_PAD(0x04D8, 0x0190, 2, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DQS__ECSPI5_MOSI = IOMUX_PAD(0x04D8, 0x0190, 3, 0x0758, 1, 0), + MX6_PAD_QSPI1A_DQS__CSI1_DATA_15 = IOMUX_PAD(0x04D8, 0x0190, 4, 0x06D8, 1, 0), + MX6_PAD_QSPI1A_DQS__GPIO4_IO_20 = IOMUX_PAD(0x04D8, 0x0190, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DQS__WEIM_DATA_7 = IOMUX_PAD(0x04D8, 0x0190, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DQS__SIM_M_HADDR_13 = IOMUX_PAD(0x04D8, 0x0190, 7, 0x0000, 0, 0), + MX6_PAD_QSPI1A_DQS__SDMA_DEBUG_BUS_DEVICE_4 = IOMUX_PAD(0x04D8, 0x0190, 9, 0x0000, 0, 0), + + MX6_PAD_QSPI1A_SCLK__QSPI1_A_SCLK = IOMUX_PAD(0x04DC, 0x0194, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SCLK__ANATOP_OTG2_ID = IOMUX_PAD(0x04DC, 0x0194, 1, 0x0628, 2, 0), + MX6_PAD_QSPI1A_SCLK__ECSPI1_SCLK = IOMUX_PAD(0x04DC, 0x0194, 2, 0x0710, 1, 0), + MX6_PAD_QSPI1A_SCLK__ESAI_TX2_RX3 = IOMUX_PAD(0x04DC, 0x0194, 3, 0x0798, 2, 0), + MX6_PAD_QSPI1A_SCLK__CSI1_DATA_1 = IOMUX_PAD(0x04DC, 0x0194, 4, 0x06A4, 1, 0), + MX6_PAD_QSPI1A_SCLK__GPIO4_IO_21 = IOMUX_PAD(0x04DC, 0x0194, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SCLK__WEIM_DATA_0 = IOMUX_PAD(0x04DC, 0x0194, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SCLK__SIM_M_HADDR_0 = IOMUX_PAD(0x04DC, 0x0194, 7, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SCLK__SDMA_DEBUG_PC_5 = IOMUX_PAD(0x04DC, 0x0194, 9, 0x0000, 0, 0), + + MX6_PAD_QSPI1A_SS0_B__QSPI1_A_SS0_B = IOMUX_PAD(0x04E0, 0x0198, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SS0_B__USB_OTG2_PWR = IOMUX_PAD(0x04E0, 0x0198, 1, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SS0_B__ECSPI1_SS0 = IOMUX_PAD(0x04E0, 0x0198, 2, 0x071C, 1, 0), + MX6_PAD_QSPI1A_SS0_B__ESAI_TX3_RX2 = IOMUX_PAD(0x04E0, 0x0198, 3, 0x079C, 2, 0), + MX6_PAD_QSPI1A_SS0_B__CSI1_DATA_0 = IOMUX_PAD(0x04E0, 0x0198, 4, 0x06A0, 1, 0), + MX6_PAD_QSPI1A_SS0_B__GPIO4_IO_22 = IOMUX_PAD(0x04E0, 0x0198, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SS0_B__WEIM_DATA_1 = IOMUX_PAD(0x04E0, 0x0198, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SS0_B__SIM_M_HADDR_1 = IOMUX_PAD(0x04E0, 0x0198, 7, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SS0_B__SDMA_DEBUG_PC_4 = IOMUX_PAD(0x04E0, 0x0198, 9, 0x0000, 0, 0), + + MX6_PAD_QSPI1A_SS1_B__QSPI1_A_SS1_B = IOMUX_PAD(0x04E4, 0x019C, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SS1_B__CAN1_RX = IOMUX_PAD(0x04E4, 0x019C, 1, 0x068C, 2, 0), + MX6_PAD_QSPI1A_SS1_B__CANFD_RX1 = IOMUX_PAD(0x04E4, 0x019C, 2, 0x0694, 2, 0), + MX6_PAD_QSPI1A_SS1_B__ECSPI5_MISO = IOMUX_PAD(0x04E4, 0x019C, 3, 0x0754, 1, 0), + MX6_PAD_QSPI1A_SS1_B__CSI1_DATA_10 = IOMUX_PAD(0x04E4, 0x019C, 4, 0x06FC, 1, 0), + MX6_PAD_QSPI1A_SS1_B__GPIO4_IO_23 = IOMUX_PAD(0x04E4, 0x019C, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SS1_B__WEIM_DATA_2 = IOMUX_PAD(0x04E4, 0x019C, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SS1_B__SIM_M_HADDR_12 = IOMUX_PAD(0x04E4, 0x019C, 7, 0x0000, 0, 0), + MX6_PAD_QSPI1A_SS1_B__SDMA_DEBUG_PC_3 = IOMUX_PAD(0x04E4, 0x019C, 9, 0x0000, 0, 0), + + MX6_PAD_QSPI1B_DATA0__QSPI1_B_DATA_0 = IOMUX_PAD(0x04E8, 0x01A0, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA0__UART3_CTS_B = IOMUX_PAD(0x04E8, 0x01A0, 1, 0x083C, 4, 0), + MX6_PAD_QSPI1B_DATA0__ECSPI3_MOSI = IOMUX_PAD(0x04E8, 0x01A0, 2, 0x0738, 1, 0), + MX6_PAD_QSPI1B_DATA0__ESAI_RX_FS = IOMUX_PAD(0x04E8, 0x01A0, 3, 0x0778, 2, 0), + MX6_PAD_QSPI1B_DATA0__CSI1_DATA_22 = IOMUX_PAD(0x04E8, 0x01A0, 4, 0x06F4, 1, 0), + MX6_PAD_QSPI1B_DATA0__GPIO4_IO_24 = IOMUX_PAD(0x04E8, 0x01A0, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA0__WEIM_DATA_14 = IOMUX_PAD(0x04E8, 0x01A0, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA0__SIM_M_HADDR_9 = IOMUX_PAD(0x04E8, 0x01A0, 7, 0x0000, 0, 0), + + MX6_PAD_QSPI1B_DATA1__QSPI1_B_DATA_1 = IOMUX_PAD(0x04EC, 0x01A4, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA1__UART3_RTS_B = IOMUX_PAD(0x04EC, 0x01A4, 1, 0x083C, 5, 0), + MX6_PAD_QSPI1B_DATA1__ECSPI3_MISO = IOMUX_PAD(0x04EC, 0x01A4, 2, 0x0734, 1, 0), + MX6_PAD_QSPI1B_DATA1__ESAI_RX_CLK = IOMUX_PAD(0x04EC, 0x01A4, 3, 0x0788, 2, 0), + MX6_PAD_QSPI1B_DATA1__CSI1_DATA_21 = IOMUX_PAD(0x04EC, 0x01A4, 4, 0x06F0, 1, 0), + MX6_PAD_QSPI1B_DATA1__GPIO4_IO_25 = IOMUX_PAD(0x04EC, 0x01A4, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA1__WEIM_DATA_13 = IOMUX_PAD(0x04EC, 0x01A4, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA1__SIM_M_HADDR_8 = IOMUX_PAD(0x04EC, 0x01A4, 7, 0x0000, 0, 0), + + MX6_PAD_QSPI1B_DATA2__QSPI1_B_DATA_2 = IOMUX_PAD(0x04F0, 0x01A8, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA2__I2C2_SDA = IOMUX_PAD(0x04F0, 0x01A8, 1, 0x07B4, 2, 0), + MX6_PAD_QSPI1B_DATA2__ECSPI5_RDY = IOMUX_PAD(0x04F0, 0x01A8, 2, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA2__ESAI_TX5_RX0 = IOMUX_PAD(0x04F0, 0x01A8, 3, 0x07A4, 2, 0), + MX6_PAD_QSPI1B_DATA2__CSI1_DATA_20 = IOMUX_PAD(0x04F0, 0x01A8, 4, 0x06EC, 1, 0), + MX6_PAD_QSPI1B_DATA2__GPIO4_IO_26 = IOMUX_PAD(0x04F0, 0x01A8, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA2__WEIM_DATA_12 = IOMUX_PAD(0x04F0, 0x01A8, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA2__SIM_M_HADDR_5 = IOMUX_PAD(0x04F0, 0x01A8, 7, 0x0000, 0, 0), + + MX6_PAD_QSPI1B_DATA3__QSPI1_B_DATA_3 = IOMUX_PAD(0x04F4, 0x01AC, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA3__I2C2_SCL = IOMUX_PAD(0x04F4, 0x01AC, 1, 0x07B0, 2, 0), + MX6_PAD_QSPI1B_DATA3__ECSPI5_SS3 = IOMUX_PAD(0x04F4, 0x01AC, 2, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA3__ESAI_TX_FS = IOMUX_PAD(0x04F4, 0x01AC, 3, 0x077C, 2, 0), + MX6_PAD_QSPI1B_DATA3__CSI1_DATA_19 = IOMUX_PAD(0x04F4, 0x01AC, 4, 0x06E8, 1, 0), + MX6_PAD_QSPI1B_DATA3__GPIO4_IO_27 = IOMUX_PAD(0x04F4, 0x01AC, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA3__WEIM_DATA_11 = IOMUX_PAD(0x04F4, 0x01AC, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DATA3__SIM_M_HADDR_2 = IOMUX_PAD(0x04F4, 0x01AC, 7, 0x0000, 0, 0), + + MX6_PAD_QSPI1B_DQS__QSPI1_B_DQS = IOMUX_PAD(0x04F8, 0x01B0, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DQS__CAN1_TX = IOMUX_PAD(0x04F8, 0x01B0, 1, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DQS__CANFD_TX1 = IOMUX_PAD(0x04F8, 0x01B0, 2, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DQS__ECSPI5_SS0 = IOMUX_PAD(0x04F8, 0x01B0, 3, 0x075C, 1, 0), + MX6_PAD_QSPI1B_DQS__CSI1_DATA_23 = IOMUX_PAD(0x04F8, 0x01B0, 4, 0x06F8, 1, 0), + MX6_PAD_QSPI1B_DQS__GPIO4_IO_28 = IOMUX_PAD(0x04F8, 0x01B0, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DQS__WEIM_DATA_15 = IOMUX_PAD(0x04F8, 0x01B0, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1B_DQS__SIM_M_HADDR_15 = IOMUX_PAD(0x04F8, 0x01B0, 7, 0x0000, 0, 0), + + MX6_PAD_QSPI1B_SCLK__QSPI1_B_SCLK = IOMUX_PAD(0x04FC, 0x01B4, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1B_SCLK__UART3_RX = IOMUX_PAD(0x04FC, 0x01B4, 1, 0x0840, 4, 0), + MX6_PAD_QSPI1B_SCLK__ECSPI3_SCLK = IOMUX_PAD(0x04FC, 0x01B4, 2, 0x0730, 1, 0), + MX6_PAD_QSPI1B_SCLK__ESAI_RX_HF_CLK = IOMUX_PAD(0x04FC, 0x01B4, 3, 0x0780, 2, 0), + MX6_PAD_QSPI1B_SCLK__CSI1_DATA_16 = IOMUX_PAD(0x04FC, 0x01B4, 4, 0x06DC, 1, 0), + MX6_PAD_QSPI1B_SCLK__GPIO4_IO_29 = IOMUX_PAD(0x04FC, 0x01B4, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1B_SCLK__WEIM_DATA_8 = IOMUX_PAD(0x04FC, 0x01B4, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1B_SCLK__SIM_M_HADDR_11 = IOMUX_PAD(0x04FC, 0x01B4, 7, 0x0000, 0, 0), + + MX6_PAD_QSPI1B_SS0_B__QSPI1_B_SS0_B = IOMUX_PAD(0x0500, 0x01B8, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1B_SS0_B__UART3_TX = IOMUX_PAD(0x0500, 0x01B8, 1, 0x0840, 5, 0), + MX6_PAD_QSPI1B_SS0_B__ECSPI3_SS0 = IOMUX_PAD(0x0500, 0x01B8, 2, 0x073C, 1, 0), + MX6_PAD_QSPI1B_SS0_B__ESAI_TX_HF_CLK = IOMUX_PAD(0x0500, 0x01B8, 3, 0x0784, 3, 0), + MX6_PAD_QSPI1B_SS0_B__CSI1_DATA_17 = IOMUX_PAD(0x0500, 0x01B8, 4, 0x06E0, 1, 0), + MX6_PAD_QSPI1B_SS0_B__GPIO4_IO_30 = IOMUX_PAD(0x0500, 0x01B8, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1B_SS0_B__WEIM_DATA_9 = IOMUX_PAD(0x0500, 0x01B8, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1B_SS0_B__SIM_M_HADDR_10 = IOMUX_PAD(0x0500, 0x01B8, 7, 0x0000, 0, 0), + + MX6_PAD_QSPI1B_SS1_B__QSPI1_B_SS1_B = IOMUX_PAD(0x0504, 0x01BC, 0, 0x0000, 0, 0), + MX6_PAD_QSPI1B_SS1_B__CAN2_RX = IOMUX_PAD(0x0504, 0x01BC, 1, 0x0690, 2, 0), + MX6_PAD_QSPI1B_SS1_B__CANFD_RX2 = IOMUX_PAD(0x0504, 0x01BC, 2, 0x0698, 2, 0), + MX6_PAD_QSPI1B_SS1_B__ECSPI5_SCLK = IOMUX_PAD(0x0504, 0x01BC, 3, 0x0750, 1, 0), + MX6_PAD_QSPI1B_SS1_B__CSI1_DATA_18 = IOMUX_PAD(0x0504, 0x01BC, 4, 0x06E4, 1, 0), + MX6_PAD_QSPI1B_SS1_B__GPIO4_IO_31 = IOMUX_PAD(0x0504, 0x01BC, 5, 0x0000, 0, 0), + MX6_PAD_QSPI1B_SS1_B__WEIM_DATA_10 = IOMUX_PAD(0x0504, 0x01BC, 6, 0x0000, 0, 0), + MX6_PAD_QSPI1B_SS1_B__SIM_M_HADDR_14 = IOMUX_PAD(0x0504, 0x01BC, 7, 0x0000, 0, 0), + + MX6_PAD_RGMII1_RD0__ENET1_RX_DATA_0 = IOMUX_PAD(0x0508, 0x01C0, 0, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD0__GPIO5_IO_0 = IOMUX_PAD(0x0508, 0x01C0, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD0__CSI2_DATA_10 = IOMUX_PAD(0x0508, 0x01C0, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD0__ANATOP_TESTI_0 = IOMUX_PAD(0x0508, 0x01C0, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD0__RAWNAND_TESTER_TRIGGER = IOMUX_PAD(0x0508, 0x01C0, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD0__PCIE_CTRL_DEBUG_0 = IOMUX_PAD(0x0508, 0x01C0, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII1_RD1__ENET1_RX_DATA_1 = IOMUX_PAD(0x050C, 0x01C4, 0, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD1__GPIO5_IO_1 = IOMUX_PAD(0x050C, 0x01C4, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD1__CSI2_DATA_11 = IOMUX_PAD(0x050C, 0x01C4, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD1__ANATOP_TESTI_1 = IOMUX_PAD(0x050C, 0x01C4, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD1__USDHC1_TESTER_TRIGGER = IOMUX_PAD(0x050C, 0x01C4, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD1__PCIE_CTRL_DEBUG_1 = IOMUX_PAD(0x050C, 0x01C4, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII1_RD2__ENET1_RX_DATA_2 = IOMUX_PAD(0x0510, 0x01C8, 0, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD2__GPIO5_IO_2 = IOMUX_PAD(0x0510, 0x01C8, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD2__CSI2_DATA_12 = IOMUX_PAD(0x0510, 0x01C8, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD2__ANATOP_TESTI_2 = IOMUX_PAD(0x0510, 0x01C8, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD2__USDHC2_TESTER_TRIGGER = IOMUX_PAD(0x0510, 0x01C8, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD2__PCIE_CTRL_DEBUG_2 = IOMUX_PAD(0x0510, 0x01C8, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII1_RD3__ENET1_RX_DATA_3 = IOMUX_PAD(0x0514, 0x01CC, 0, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD3__GPIO5_IO_3 = IOMUX_PAD(0x0514, 0x01CC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD3__CSI2_DATA_13 = IOMUX_PAD(0x0514, 0x01CC, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD3__ANATOP_TESTI_3 = IOMUX_PAD(0x0514, 0x01CC, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD3__USDHC3_TESTER_TRIGGER = IOMUX_PAD(0x0514, 0x01CC, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_RD3__PCIE_CTRL_DEBUG_3 = IOMUX_PAD(0x0514, 0x01CC, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII1_RX_CTL__ENET1_RX_EN = IOMUX_PAD(0x0518, 0x01D0, 0, 0x0000, 0, 0), + MX6_PAD_RGMII1_RX_CTL__GPIO5_IO_4 = IOMUX_PAD(0x0518, 0x01D0, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_RX_CTL__CSI2_DATA_14 = IOMUX_PAD(0x0518, 0x01D0, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_RX_CTL__ANATOP_TESTO_0 = IOMUX_PAD(0x0518, 0x01D0, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_RX_CTL__USDHC4_TESTER_TRIGGER = IOMUX_PAD(0x0518, 0x01D0, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_RX_CTL__PCIE_CTRL_DEBUG_4 = IOMUX_PAD(0x0518, 0x01D0, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII1_RXC__ENET1_RX_CLK = IOMUX_PAD(0x051C, 0x01D4, 0, 0x0768, 1, 0), + MX6_PAD_RGMII1_RXC__ENET1_RX_ER = IOMUX_PAD(0x051C, 0x01D4, 1, 0x0000, 0, 0), + MX6_PAD_RGMII1_RXC__GPIO5_IO_5 = IOMUX_PAD(0x051C, 0x01D4, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_RXC__CSI2_DATA_15 = IOMUX_PAD(0x051C, 0x01D4, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_RXC__ANATOP_TESTO_1 = IOMUX_PAD(0x051C, 0x01D4, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_RXC__ECSPI1_TESTER_TRIGGER = IOMUX_PAD(0x051C, 0x01D4, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_RXC__PCIE_CTRL_DEBUG_5 = IOMUX_PAD(0x051C, 0x01D4, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII1_TD0__ENET1_TX_DATA_0 = IOMUX_PAD(0x0520, 0x01D8, 0, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD0__SAI2_RX_SYNC = IOMUX_PAD(0x0520, 0x01D8, 2, 0x0810, 1, 0), + MX6_PAD_RGMII1_TD0__GPIO5_IO_6 = IOMUX_PAD(0x0520, 0x01D8, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD0__CSI2_DATA_16 = IOMUX_PAD(0x0520, 0x01D8, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD0__ANATOP_TESTO_2 = IOMUX_PAD(0x0520, 0x01D8, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD0__ECSPI2_TESTER_TRIGGER = IOMUX_PAD(0x0520, 0x01D8, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD0__PCIE_CTRL_DEBUG_6 = IOMUX_PAD(0x0520, 0x01D8, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII1_TD1__ENET1_TX_DATA_1 = IOMUX_PAD(0x0524, 0x01DC, 0, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD1__SAI2_RX_BCLK = IOMUX_PAD(0x0524, 0x01DC, 2, 0x0808, 1, 0), + MX6_PAD_RGMII1_TD1__GPIO5_IO_7 = IOMUX_PAD(0x0524, 0x01DC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD1__CSI2_DATA_17 = IOMUX_PAD(0x0524, 0x01DC, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD1__ANATOP_TESTO_3 = IOMUX_PAD(0x0524, 0x01DC, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD1__ECSPI3_TESTER_TRIGGER = IOMUX_PAD(0x0524, 0x01DC, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD1__PCIE_CTRL_DEBUG_7 = IOMUX_PAD(0x0524, 0x01DC, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII1_TD2__ENET1_TX_DATA_2 = IOMUX_PAD(0x0528, 0x01E0, 0, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD2__SAI2_TX_SYNC = IOMUX_PAD(0x0528, 0x01E0, 2, 0x0818, 1, 0), + MX6_PAD_RGMII1_TD2__GPIO5_IO_8 = IOMUX_PAD(0x0528, 0x01E0, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD2__CSI2_DATA_18 = IOMUX_PAD(0x0528, 0x01E0, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD2__ANATOP_TESTO_4 = IOMUX_PAD(0x0528, 0x01E0, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD2__ECSPI4_TESTER_TRIGGER = IOMUX_PAD(0x0528, 0x01E0, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD2__PCIE_CTRL_DEBUG_8 = IOMUX_PAD(0x0528, 0x01E0, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII1_TD3__ENET1_TX_DATA_3 = IOMUX_PAD(0x052C, 0x01E4, 0, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD3__SAI2_TX_BCLK = IOMUX_PAD(0x052C, 0x01E4, 2, 0x0814, 1, 0), + MX6_PAD_RGMII1_TD3__GPIO5_IO_9 = IOMUX_PAD(0x052C, 0x01E4, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD3__CSI2_DATA_19 = IOMUX_PAD(0x052C, 0x01E4, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD3__ANATOP_TESTO_5 = IOMUX_PAD(0x052C, 0x01E4, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD3__ECSPI5_TESTER_TRIGGER = IOMUX_PAD(0x052C, 0x01E4, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_TD3__PCIE_CTRL_DEBUG_9 = IOMUX_PAD(0x052C, 0x01E4, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII1_TX_CTL__ENET1_TX_EN = IOMUX_PAD(0x0530, 0x01E8, 0, 0x0000, 0, 0), + MX6_PAD_RGMII1_TX_CTL__SAI2_RX_DATA_0 = IOMUX_PAD(0x0530, 0x01E8, 2, 0x080C, 1, 0), + MX6_PAD_RGMII1_TX_CTL__GPIO5_IO_10 = IOMUX_PAD(0x0530, 0x01E8, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_TX_CTL__CSI2_DATA_0 = IOMUX_PAD(0x0530, 0x01E8, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_TX_CTL__ANATOP_TESTO_6 = IOMUX_PAD(0x0530, 0x01E8, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_TX_CTL__QSPI1_TESTER_TRIGGER = IOMUX_PAD(0x0530, 0x01E8, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_TX_CTL__PCIE_CTRL_DEBUG_10 = IOMUX_PAD(0x0530, 0x01E8, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII1_TXC__ENET1_RGMII_TXC = IOMUX_PAD(0x0534, 0x01EC, 0, 0x0000, 0, 0), + MX6_PAD_RGMII1_TXC__ENET1_TX_ER = IOMUX_PAD(0x0534, 0x01EC, 1, 0x0000, 0, 0), + MX6_PAD_RGMII1_TXC__SAI2_TX_DATA_0 = IOMUX_PAD(0x0534, 0x01EC, 2, 0x0000, 0, 0), + MX6_PAD_RGMII1_TXC__GPIO5_IO_11 = IOMUX_PAD(0x0534, 0x01EC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII1_TXC__CSI2_DATA_1 = IOMUX_PAD(0x0534, 0x01EC, 6, 0x0000, 0, 0), + MX6_PAD_RGMII1_TXC__ANATOP_TESTO_7 = IOMUX_PAD(0x0534, 0x01EC, 7, 0x0000, 0, 0), + MX6_PAD_RGMII1_TXC__QSPI2_TESTER_TRIGGER = IOMUX_PAD(0x0534, 0x01EC, 8, 0x0000, 0, 0), + MX6_PAD_RGMII1_TXC__PCIE_CTRL_DEBUG_11 = IOMUX_PAD(0x0534, 0x01EC, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_RD0__ENET2_RX_DATA_0 = IOMUX_PAD(0x0538, 0x01F0, 0, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD0__PWM4_OUT = IOMUX_PAD(0x0538, 0x01F0, 2, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD0__GPIO5_IO_12 = IOMUX_PAD(0x0538, 0x01F0, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD0__CSI2_DATA_2 = IOMUX_PAD(0x0538, 0x01F0, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD0__ANATOP_TESTO_8 = IOMUX_PAD(0x0538, 0x01F0, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD0__VDEC_DEBUG_18 = IOMUX_PAD(0x0538, 0x01F0, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD0__PCIE_CTRL_DEBUG_12 = IOMUX_PAD(0x0538, 0x01F0, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_RD1__ENET2_RX_DATA_1 = IOMUX_PAD(0x053C, 0x01F4, 0, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD1__PWM3_OUT = IOMUX_PAD(0x053C, 0x01F4, 2, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD1__GPIO5_IO_13 = IOMUX_PAD(0x053C, 0x01F4, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD1__CSI2_DATA_3 = IOMUX_PAD(0x053C, 0x01F4, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD1__ANATOP_TESTO_9 = IOMUX_PAD(0x053C, 0x01F4, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD1__VDEC_DEBUG_19 = IOMUX_PAD(0x053C, 0x01F4, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD1__PCIE_CTRL_DEBUG_13 = IOMUX_PAD(0x053C, 0x01F4, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_RD2__ENET2_RX_DATA_2 = IOMUX_PAD(0x0540, 0x01F8, 0, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD2__PWM2_OUT = IOMUX_PAD(0x0540, 0x01F8, 2, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD2__GPIO5_IO_14 = IOMUX_PAD(0x0540, 0x01F8, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD2__CSI2_DATA_4 = IOMUX_PAD(0x0540, 0x01F8, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD2__ANATOP_TESTO_10 = IOMUX_PAD(0x0540, 0x01F8, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD2__VDEC_DEBUG_20 = IOMUX_PAD(0x0540, 0x01F8, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD2__PCIE_CTRL_DEBUG_14 = IOMUX_PAD(0x0540, 0x01F8, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_RD3__ENET2_RX_DATA_3 = IOMUX_PAD(0x0544, 0x01FC, 0, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD3__PWM1_OUT = IOMUX_PAD(0x0544, 0x01FC, 2, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD3__GPIO5_IO_15 = IOMUX_PAD(0x0544, 0x01FC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD3__CSI2_DATA_5 = IOMUX_PAD(0x0544, 0x01FC, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD3__ANATOP_TESTO_11 = IOMUX_PAD(0x0544, 0x01FC, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD3__VDEC_DEBUG_21 = IOMUX_PAD(0x0544, 0x01FC, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_RD3__PCIE_CTRL_DEBUG_15 = IOMUX_PAD(0x0544, 0x01FC, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_RX_CTL__ENET2_RX_EN = IOMUX_PAD(0x0548, 0x0200, 0, 0x0000, 0, 0), + MX6_PAD_RGMII2_RX_CTL__GPIO5_IO_16 = IOMUX_PAD(0x0548, 0x0200, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_RX_CTL__CSI2_DATA_6 = IOMUX_PAD(0x0548, 0x0200, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_RX_CTL__ANATOP_TESTO_12 = IOMUX_PAD(0x0548, 0x0200, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_RX_CTL__VDEC_DEBUG_22 = IOMUX_PAD(0x0548, 0x0200, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_RX_CTL__PCIE_CTRL_DEBUG_16 = IOMUX_PAD(0x0548, 0x0200, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_RXC__ENET2_RX_CLK = IOMUX_PAD(0x054C, 0x0204, 0, 0x0774, 1, 0), + MX6_PAD_RGMII2_RXC__ENET2_RX_ER = IOMUX_PAD(0x054C, 0x0204, 1, 0x0000, 0, 0), + MX6_PAD_RGMII2_RXC__GPIO5_IO_17 = IOMUX_PAD(0x054C, 0x0204, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_RXC__CSI2_DATA_7 = IOMUX_PAD(0x054C, 0x0204, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_RXC__ANATOP_TESTO_13 = IOMUX_PAD(0x054C, 0x0204, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_RXC__VDEC_DEBUG_23 = IOMUX_PAD(0x054C, 0x0204, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_RXC__PCIE_CTRL_DEBUG_17 = IOMUX_PAD(0x054C, 0x0204, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_TD0__ENET2_TX_DATA_0 = IOMUX_PAD(0x0550, 0x0208, 0, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD0__SAI1_RX_SYNC = IOMUX_PAD(0x0550, 0x0208, 2, 0x07FC, 1, 0), + MX6_PAD_RGMII2_TD0__PWM8_OUT = IOMUX_PAD(0x0550, 0x0208, 3, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD0__GPIO5_IO_18 = IOMUX_PAD(0x0550, 0x0208, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD0__CSI2_DATA_8 = IOMUX_PAD(0x0550, 0x0208, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD0__ANATOP_TESTO_14 = IOMUX_PAD(0x0550, 0x0208, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD0__VDEC_DEBUG_24 = IOMUX_PAD(0x0550, 0x0208, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD0__PCIE_CTRL_DEBUG_18 = IOMUX_PAD(0x0550, 0x0208, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_TD1__ENET2_TX_DATA_1 = IOMUX_PAD(0x0554, 0x020C, 0, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD1__SAI1_RX_BCLK = IOMUX_PAD(0x0554, 0x020C, 2, 0x07F4, 1, 0), + MX6_PAD_RGMII2_TD1__PWM7_OUT = IOMUX_PAD(0x0554, 0x020C, 3, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD1__GPIO5_IO_19 = IOMUX_PAD(0x0554, 0x020C, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD1__CSI2_DATA_9 = IOMUX_PAD(0x0554, 0x020C, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD1__ANATOP_TESTO_15 = IOMUX_PAD(0x0554, 0x020C, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD1__VDEC_DEBUG_25 = IOMUX_PAD(0x0554, 0x020C, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD1__PCIE_CTRL_DEBUG_19 = IOMUX_PAD(0x0554, 0x020C, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_TD2__ENET2_TX_DATA_2 = IOMUX_PAD(0x0558, 0x0210, 0, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD2__SAI1_TX_SYNC = IOMUX_PAD(0x0558, 0x0210, 2, 0x0804, 1, 0), + MX6_PAD_RGMII2_TD2__PWM6_OUT = IOMUX_PAD(0x0558, 0x0210, 3, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD2__GPIO5_IO_20 = IOMUX_PAD(0x0558, 0x0210, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD2__CSI2_VSYNC = IOMUX_PAD(0x0558, 0x0210, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD2__SJC_FAIL = IOMUX_PAD(0x0558, 0x0210, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD2__VDEC_DEBUG_26 = IOMUX_PAD(0x0558, 0x0210, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD2__PCIE_CTRL_DEBUG_20 = IOMUX_PAD(0x0558, 0x0210, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_TD3__ENET2_TX_DATA_3 = IOMUX_PAD(0x055C, 0x0214, 0, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD3__SAI1_TX_BCLK = IOMUX_PAD(0x055C, 0x0214, 2, 0x0800, 1, 0), + MX6_PAD_RGMII2_TD3__PWM5_OUT = IOMUX_PAD(0x055C, 0x0214, 3, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD3__GPIO5_IO_21 = IOMUX_PAD(0x055C, 0x0214, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD3__CSI2_HSYNC = IOMUX_PAD(0x055C, 0x0214, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD3__SJC_JTAG_ACT = IOMUX_PAD(0x055C, 0x0214, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD3__VDEC_DEBUG_27 = IOMUX_PAD(0x055C, 0x0214, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_TD3__PCIE_CTRL_DEBUG_21 = IOMUX_PAD(0x055C, 0x0214, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_TX_CTL__ENET2_TX_EN = IOMUX_PAD(0x0560, 0x0218, 0, 0x0000, 0, 0), + MX6_PAD_RGMII2_TX_CTL__SAI1_RX_DATA_0 = IOMUX_PAD(0x0560, 0x0218, 2, 0x07F8, 1, 0), + MX6_PAD_RGMII2_TX_CTL__GPIO5_IO_22 = IOMUX_PAD(0x0560, 0x0218, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_TX_CTL__CSI2_FIELD = IOMUX_PAD(0x0560, 0x0218, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_TX_CTL__SJC_DE_B = IOMUX_PAD(0x0560, 0x0218, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_TX_CTL__VDEC_DEBUG_28 = IOMUX_PAD(0x0560, 0x0218, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_TX_CTL__PCIE_CTRL_DEBUG_22 = IOMUX_PAD(0x0560, 0x0218, 9, 0x0000, 0, 0), + + MX6_PAD_RGMII2_TXC__ENET2_RGMII_TXC = IOMUX_PAD(0x0564, 0x021C, 0, 0x0000, 0, 0), + MX6_PAD_RGMII2_TXC__ENET2_TX_ER = IOMUX_PAD(0x0564, 0x021C, 1, 0x0000, 0, 0), + MX6_PAD_RGMII2_TXC__SAI1_TX_DATA_0 = IOMUX_PAD(0x0564, 0x021C, 2, 0x0000, 0, 0), + MX6_PAD_RGMII2_TXC__GPIO5_IO_23 = IOMUX_PAD(0x0564, 0x021C, 5, 0x0000, 0, 0), + MX6_PAD_RGMII2_TXC__CSI2_PIXCLK = IOMUX_PAD(0x0564, 0x021C, 6, 0x0000, 0, 0), + MX6_PAD_RGMII2_TXC__SJC_DONE = IOMUX_PAD(0x0564, 0x021C, 7, 0x0000, 0, 0), + MX6_PAD_RGMII2_TXC__VDEC_DEBUG_29 = IOMUX_PAD(0x0564, 0x021C, 8, 0x0000, 0, 0), + MX6_PAD_RGMII2_TXC__PCIE_CTRL_DEBUG_23 = IOMUX_PAD(0x0564, 0x021C, 9, 0x0000, 0, 0), + + MX6_PAD_SD1_CLK__USDHC1_CLK = IOMUX_PAD(0x0568, 0x0220, 0, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x0568, 0x0220, 1, 0x0668, 1, 0), + MX6_PAD_SD1_CLK__WDOG2_WDOG_B = IOMUX_PAD(0x0568, 0x0220, 2, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__GPT_CLK = IOMUX_PAD(0x0568, 0x0220, 3, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__WDOG2_WDOG_RST_B_DEB = IOMUX_PAD(0x0568, 0x0220, 4, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__GPIO6_IO_0 = IOMUX_PAD(0x0568, 0x0220, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__ENET2_1588_EVENT1_OUT = IOMUX_PAD(0x0568, 0x0220, 6, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__CCM_OUT1 = IOMUX_PAD(0x0568, 0x0220, 7, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__VADC_ADC_PROC_CLK = IOMUX_PAD(0x0568, 0x0220, 8, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__MMDC_DEBUG_45 = IOMUX_PAD(0x0568, 0x0220, 9, 0x0000, 0, 0), + + MX6_PAD_SD1_CMD__USDHC1_CMD = IOMUX_PAD(0x056C, 0x0224, 0, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__AUDMUX_AUD5_RXC = IOMUX_PAD(0x056C, 0x0224, 1, 0x0664, 1, 0), + MX6_PAD_SD1_CMD__WDOG1_WDOG_B = IOMUX_PAD(0x056C, 0x0224, 2, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__GPT_COMPARE1 = IOMUX_PAD(0x056C, 0x0224, 3, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__WDOG1_WDOG_RST_B_DEB = IOMUX_PAD(0x056C, 0x0224, 4, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__GPIO6_IO_1 = IOMUX_PAD(0x056C, 0x0224, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__ENET2_1588_EVENT1_IN = IOMUX_PAD(0x056C, 0x0224, 6, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__CCM_CLKO1 = IOMUX_PAD(0x056C, 0x0224, 7, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__VADC_EXT_SYSCLK = IOMUX_PAD(0x056C, 0x0224, 8, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__MMDC_DEBUG_46 = IOMUX_PAD(0x056C, 0x0224, 9, 0x0000, 0, 0), + + MX6_PAD_SD1_DATA0__USDHC1_DATA0 = IOMUX_PAD(0x0570, 0x0228, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__AUDMUX_AUD5_RXD = IOMUX_PAD(0x0570, 0x0228, 1, 0x065C, 1, 0), + MX6_PAD_SD1_DATA0__CAAM_WRAPPER_RNG_OSC_OBS = IOMUX_PAD(0x0570, 0x0228, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__GPT_CAPTURE1 = IOMUX_PAD(0x0570, 0x0228, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__UART2_RX = IOMUX_PAD(0x0570, 0x0228, 4, 0x0838, 2, 0), + MX6_PAD_SD1_DATA0__GPIO6_IO_2 = IOMUX_PAD(0x0570, 0x0228, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__ENET1_1588_EVENT1_IN = IOMUX_PAD(0x0570, 0x0228, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__CCM_OUT2 = IOMUX_PAD(0x0570, 0x0228, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__VADC_CLAMP_UP = IOMUX_PAD(0x0570, 0x0228, 8, 0x0000, 0, 0), + MX6_PAD_SD1_DATA0__MMDC_DEBUG_48 = IOMUX_PAD(0x0570, 0x0228, 9, 0x0000, 0, 0), + + MX6_PAD_SD1_DATA1__USDHC1_DATA1 = IOMUX_PAD(0x0574, 0x022C, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DATA1__AUDMUX_AUD5_TXC = IOMUX_PAD(0x0574, 0x022C, 1, 0x066C, 1, 0), + MX6_PAD_SD1_DATA1__PWM4_OUT = IOMUX_PAD(0x0574, 0x022C, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DATA1__GPT_CAPTURE2 = IOMUX_PAD(0x0574, 0x022C, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DATA1__UART2_TX = IOMUX_PAD(0x0574, 0x022C, 4, 0x0838, 3, 0), + MX6_PAD_SD1_DATA1__GPIO6_IO_3 = IOMUX_PAD(0x0574, 0x022C, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DATA1__ENET1_1588_EVENT1_OUT = IOMUX_PAD(0x0574, 0x022C, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DATA1__CCM_CLKO2 = IOMUX_PAD(0x0574, 0x022C, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DATA1__VADC_CLAMP_DOWN = IOMUX_PAD(0x0574, 0x022C, 8, 0x0000, 0, 0), + MX6_PAD_SD1_DATA1__MMDC_DEBUG_47 = IOMUX_PAD(0x0574, 0x022C, 9, 0x0000, 0, 0), + + MX6_PAD_SD1_DATA2__USDHC1_DATA2 = IOMUX_PAD(0x0578, 0x0230, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DATA2__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x0578, 0x0230, 1, 0x0670, 1, 0), + MX6_PAD_SD1_DATA2__PWM3_OUT = IOMUX_PAD(0x0578, 0x0230, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DATA2__GPT_COMPARE2 = IOMUX_PAD(0x0578, 0x0230, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DATA2__UART2_CTS_B = IOMUX_PAD(0x0578, 0x0230, 4, 0x0834, 2, 0), + MX6_PAD_SD1_DATA2__GPIO6_IO_4 = IOMUX_PAD(0x0578, 0x0230, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DATA2__ECSPI4_RDY = IOMUX_PAD(0x0578, 0x0230, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DATA2__CCM_OUT0 = IOMUX_PAD(0x0578, 0x0230, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DATA2__VADC_EXT_PD_N = IOMUX_PAD(0x0578, 0x0230, 8, 0x0000, 0, 0), + + MX6_PAD_SD1_DATA3__USDHC1_DATA3 = IOMUX_PAD(0x057C, 0x0234, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DATA3__AUDMUX_AUD5_TXD = IOMUX_PAD(0x057C, 0x0234, 1, 0x0660, 1, 0), + MX6_PAD_SD1_DATA3__AUDMUX_AUD5_RXD = IOMUX_PAD(0x057C, 0x0234, 2, 0x065C, 2, 0), + MX6_PAD_SD1_DATA3__GPT_COMPARE3 = IOMUX_PAD(0x057C, 0x0234, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DATA3__UART2_RTS_B = IOMUX_PAD(0x057C, 0x0234, 4, 0x0834, 3, 0), + MX6_PAD_SD1_DATA3__GPIO6_IO_5 = IOMUX_PAD(0x057C, 0x0234, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DATA3__ECSPI4_SS1 = IOMUX_PAD(0x057C, 0x0234, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DATA3__CCM_PMIC_RDY = IOMUX_PAD(0x057C, 0x0234, 7, 0x069C, 2, 0), + MX6_PAD_SD1_DATA3__VADC_RST_N = IOMUX_PAD(0x057C, 0x0234, 8, 0x0000, 0, 0), + + MX6_PAD_SD2_CLK__USDHC2_CLK = IOMUX_PAD(0x0580, 0x0238, 0, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x0580, 0x0238, 1, 0x0680, 2, 0), + MX6_PAD_SD2_CLK__KPP_COL_5 = IOMUX_PAD(0x0580, 0x0238, 2, 0x07C8, 1, 0), + MX6_PAD_SD2_CLK__ECSPI4_SCLK = IOMUX_PAD(0x0580, 0x0238, 3, 0x0740, 1, 0), + MX6_PAD_SD2_CLK__MLB_SIG = IOMUX_PAD(0x0580, 0x0238, 4, 0x07F0, 2, 0), + MX6_PAD_SD2_CLK__GPIO6_IO_6 = IOMUX_PAD(0x0580, 0x0238, 5, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__MQS_RIGHT = IOMUX_PAD(0x0580, 0x0238, 6, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__WDOG1_WDOG_ANY = IOMUX_PAD(0x0580, 0x0238, 7, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__VADC_CLAMP_CURRENT_5 = IOMUX_PAD(0x0580, 0x0238, 8, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__MMDC_DEBUG_29 = IOMUX_PAD(0x0580, 0x0238, 9, 0x0000, 0, 0), + + MX6_PAD_SD2_CMD__USDHC2_CMD = IOMUX_PAD(0x0584, 0x023C, 0, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__AUDMUX_AUD6_RXC = IOMUX_PAD(0x0584, 0x023C, 1, 0x067C, 2, 0), + MX6_PAD_SD2_CMD__KPP_ROW_5 = IOMUX_PAD(0x0584, 0x023C, 2, 0x07D4, 1, 0), + MX6_PAD_SD2_CMD__ECSPI4_MOSI = IOMUX_PAD(0x0584, 0x023C, 3, 0x0748, 1, 0), + MX6_PAD_SD2_CMD__MLB_CLK = IOMUX_PAD(0x0584, 0x023C, 4, 0x07E8, 2, 0), + MX6_PAD_SD2_CMD__GPIO6_IO_7 = IOMUX_PAD(0x0584, 0x023C, 5, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__MQS_LEFT = IOMUX_PAD(0x0584, 0x023C, 6, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__WDOG3_WDOG_B = IOMUX_PAD(0x0584, 0x023C, 7, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__VADC_CLAMP_CURRENT_4 = IOMUX_PAD(0x0584, 0x023C, 8, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__MMDC_DEBUG_30 = IOMUX_PAD(0x0584, 0x023C, 9, 0x0000, 0, 0), + + MX6_PAD_SD2_DATA0__USDHC2_DATA0 = IOMUX_PAD(0x0588, 0x0240, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DATA0__AUDMUX_AUD6_RXD = IOMUX_PAD(0x0588, 0x0240, 1, 0x0674, 2, 0), + MX6_PAD_SD2_DATA0__KPP_ROW_7 = IOMUX_PAD(0x0588, 0x0240, 2, 0x07DC, 1, 0), + MX6_PAD_SD2_DATA0__PWM1_OUT = IOMUX_PAD(0x0588, 0x0240, 3, 0x0000, 0, 0), + MX6_PAD_SD2_DATA0__I2C4_SDA = IOMUX_PAD(0x0588, 0x0240, 4, 0x07C4, 3, 0), + MX6_PAD_SD2_DATA0__GPIO6_IO_8 = IOMUX_PAD(0x0588, 0x0240, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DATA0__ECSPI4_SS3 = IOMUX_PAD(0x0588, 0x0240, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DATA0__UART4_RX = IOMUX_PAD(0x0588, 0x0240, 7, 0x0848, 4, 0), + MX6_PAD_SD2_DATA0__VADC_CLAMP_CURRENT_0 = IOMUX_PAD(0x0588, 0x0240, 8, 0x0000, 0, 0), + MX6_PAD_SD2_DATA0__MMDC_DEBUG_50 = IOMUX_PAD(0x0588, 0x0240, 9, 0x0000, 0, 0), + + MX6_PAD_SD2_DATA1__USDHC2_DATA1 = IOMUX_PAD(0x058C, 0x0244, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DATA1__AUDMUX_AUD6_TXC = IOMUX_PAD(0x058C, 0x0244, 1, 0x0684, 2, 0), + MX6_PAD_SD2_DATA1__KPP_COL_7 = IOMUX_PAD(0x058C, 0x0244, 2, 0x07D0, 1, 0), + MX6_PAD_SD2_DATA1__PWM2_OUT = IOMUX_PAD(0x058C, 0x0244, 3, 0x0000, 0, 0), + MX6_PAD_SD2_DATA1__I2C4_SCL = IOMUX_PAD(0x058C, 0x0244, 4, 0x07C0, 3, 0), + MX6_PAD_SD2_DATA1__GPIO6_IO_9 = IOMUX_PAD(0x058C, 0x0244, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DATA1__ECSPI4_SS2 = IOMUX_PAD(0x058C, 0x0244, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DATA1__UART4_TX = IOMUX_PAD(0x058C, 0x0244, 7, 0x0848, 5, 0), + MX6_PAD_SD2_DATA1__VADC_CLAMP_CURRENT_1 = IOMUX_PAD(0x058C, 0x0244, 8, 0x0000, 0, 0), + MX6_PAD_SD2_DATA1__MMDC_DEBUG_49 = IOMUX_PAD(0x058C, 0x0244, 9, 0x0000, 0, 0), + + MX6_PAD_SD2_DATA2__USDHC2_DATA2 = IOMUX_PAD(0x0590, 0x0248, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DATA2__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x0590, 0x0248, 1, 0x0688, 2, 0), + MX6_PAD_SD2_DATA2__KPP_ROW_6 = IOMUX_PAD(0x0590, 0x0248, 2, 0x07D8, 1, 0), + MX6_PAD_SD2_DATA2__ECSPI4_SS0 = IOMUX_PAD(0x0590, 0x0248, 3, 0x074C, 1, 0), + MX6_PAD_SD2_DATA2__SDMA_EXT_EVENT_0 = IOMUX_PAD(0x0590, 0x0248, 4, 0x081C, 2, 0), + MX6_PAD_SD2_DATA2__GPIO6_IO_10 = IOMUX_PAD(0x0590, 0x0248, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DATA2__SPDIF_OUT = IOMUX_PAD(0x0590, 0x0248, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DATA2__UART6_RX = IOMUX_PAD(0x0590, 0x0248, 7, 0x0858, 4, 0), + MX6_PAD_SD2_DATA2__VADC_CLAMP_CURRENT_2 = IOMUX_PAD(0x0590, 0x0248, 8, 0x0000, 0, 0), + MX6_PAD_SD2_DATA2__MMDC_DEBUG_32 = IOMUX_PAD(0x0590, 0x0248, 9, 0x0000, 0, 0), + + MX6_PAD_SD2_DATA3__USDHC2_DATA3 = IOMUX_PAD(0x0594, 0x024C, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DATA3__AUDMUX_AUD6_TXD = IOMUX_PAD(0x0594, 0x024C, 1, 0x0678, 2, 0), + MX6_PAD_SD2_DATA3__KPP_COL_6 = IOMUX_PAD(0x0594, 0x024C, 2, 0x07CC, 1, 0), + MX6_PAD_SD2_DATA3__ECSPI4_MISO = IOMUX_PAD(0x0594, 0x024C, 3, 0x0744, 1, 0), + MX6_PAD_SD2_DATA3__MLB_DATA = IOMUX_PAD(0x0594, 0x024C, 4, 0x07EC, 2, 0), + MX6_PAD_SD2_DATA3__GPIO6_IO_11 = IOMUX_PAD(0x0594, 0x024C, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DATA3__SPDIF_IN = IOMUX_PAD(0x0594, 0x024C, 6, 0x0824, 4, 0), + MX6_PAD_SD2_DATA3__UART6_TX = IOMUX_PAD(0x0594, 0x024C, 7, 0x0858, 5, 0), + MX6_PAD_SD2_DATA3__VADC_CLAMP_CURRENT_3 = IOMUX_PAD(0x0594, 0x024C, 8, 0x0000, 0, 0), + MX6_PAD_SD2_DATA3__MMDC_DEBUG_31 = IOMUX_PAD(0x0594, 0x024C, 9, 0x0000, 0, 0), + + MX6_PAD_SD3_CLK__USDHC3_CLK = IOMUX_PAD(0x0598, 0x0250, 0, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__UART4_CTS_B = IOMUX_PAD(0x0598, 0x0250, 1, 0x0844, 0, 0), + MX6_PAD_SD3_CLK__ECSPI4_SCLK = IOMUX_PAD(0x0598, 0x0250, 2, 0x0740, 0, 0), + MX6_PAD_SD3_CLK__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x0598, 0x0250, 3, 0x0680, 0, 0), + MX6_PAD_SD3_CLK__LCDIF2_VSYNC = IOMUX_PAD(0x0598, 0x0250, 4, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__GPIO7_IO_0 = IOMUX_PAD(0x0598, 0x0250, 5, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__LCDIF2_BUSY = IOMUX_PAD(0x0598, 0x0250, 6, 0x07E4, 0, 0), + MX6_PAD_SD3_CLK__TPSMP_HDATA_29 = IOMUX_PAD(0x0598, 0x0250, 7, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__SDMA_DEBUG_EVENT_CHANNEL_5 = IOMUX_PAD(0x0598, 0x0250, 9, 0x0000, 0, 0), + + MX6_PAD_SD3_CMD__USDHC3_CMD = IOMUX_PAD(0x059C, 0x0254, 0, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__UART4_TX = IOMUX_PAD(0x059C, 0x0254, 1, 0x0848, 0, 0), + MX6_PAD_SD3_CMD__ECSPI4_MOSI = IOMUX_PAD(0x059C, 0x0254, 2, 0x0748, 0, 0), + MX6_PAD_SD3_CMD__AUDMUX_AUD6_RXC = IOMUX_PAD(0x059C, 0x0254, 3, 0x067C, 0, 0), + MX6_PAD_SD3_CMD__LCDIF2_HSYNC = IOMUX_PAD(0x059C, 0x0254, 4, 0x07E4, 1, 0), + MX6_PAD_SD3_CMD__GPIO7_IO_1 = IOMUX_PAD(0x059C, 0x0254, 5, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__LCDIF2_RS = IOMUX_PAD(0x059C, 0x0254, 6, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__TPSMP_HDATA_28 = IOMUX_PAD(0x059C, 0x0254, 7, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__SDMA_DEBUG_EVENT_CHANNEL_4 = IOMUX_PAD(0x059C, 0x0254, 9, 0x0000, 0, 0), + + MX6_PAD_SD3_DATA0__USDHC3_DATA0 = IOMUX_PAD(0x05A0, 0x0258, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DATA0__I2C4_SCL = IOMUX_PAD(0x05A0, 0x0258, 1, 0x07C0, 0, 0), + MX6_PAD_SD3_DATA0__ECSPI2_SS1 = IOMUX_PAD(0x05A0, 0x0258, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DATA0__AUDMUX_AUD6_RXD = IOMUX_PAD(0x05A0, 0x0258, 3, 0x0674, 0, 0), + MX6_PAD_SD3_DATA0__LCDIF2_DATA_1 = IOMUX_PAD(0x05A0, 0x0258, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DATA0__GPIO7_IO_2 = IOMUX_PAD(0x05A0, 0x0258, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DATA0__DCIC1_OUT = IOMUX_PAD(0x05A0, 0x0258, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DATA0__TPSMP_HDATA_30 = IOMUX_PAD(0x05A0, 0x0258, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DATA0__GPU_DEBUG_0 = IOMUX_PAD(0x05A0, 0x0258, 8, 0x0000, 0, 0), + MX6_PAD_SD3_DATA0__SDMA_DEBUG_EVT_CHN_LINES_0 = IOMUX_PAD(0x05A0, 0x0258, 9, 0x0000, 0, 0), + + MX6_PAD_SD3_DATA1__USDHC3_DATA1 = IOMUX_PAD(0x05A4, 0x025C, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DATA1__I2C4_SDA = IOMUX_PAD(0x05A4, 0x025C, 1, 0x07C4, 0, 0), + MX6_PAD_SD3_DATA1__ECSPI2_SS2 = IOMUX_PAD(0x05A4, 0x025C, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DATA1__AUDMUX_AUD6_TXC = IOMUX_PAD(0x05A4, 0x025C, 3, 0x0684, 0, 0), + MX6_PAD_SD3_DATA1__LCDIF2_DATA_0 = IOMUX_PAD(0x05A4, 0x025C, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DATA1__GPIO7_IO_3 = IOMUX_PAD(0x05A4, 0x025C, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DATA1__DCIC2_OUT = IOMUX_PAD(0x05A4, 0x025C, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DATA1__TPSMP_HDATA_31 = IOMUX_PAD(0x05A4, 0x025C, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DATA1__GPU_DEBUG_1 = IOMUX_PAD(0x05A4, 0x025C, 8, 0x0000, 0, 0), + MX6_PAD_SD3_DATA1__SDMA_DEBUG_EVT_CHN_LINES_1 = IOMUX_PAD(0x05A4, 0x025C, 9, 0x0000, 0, 0), + + MX6_PAD_SD3_DATA2__USDHC3_DATA2 = IOMUX_PAD(0x05A8, 0x0260, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DATA2__UART4_RTS_B = IOMUX_PAD(0x05A8, 0x0260, 1, 0x0844, 1, 0), + MX6_PAD_SD3_DATA2__ECSPI4_SS0 = IOMUX_PAD(0x05A8, 0x0260, 2, 0x074C, 0, 0), + MX6_PAD_SD3_DATA2__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x05A8, 0x0260, 3, 0x0688, 0, 0), + MX6_PAD_SD3_DATA2__LCDIF2_CLK = IOMUX_PAD(0x05A8, 0x0260, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DATA2__GPIO7_IO_4 = IOMUX_PAD(0x05A8, 0x0260, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DATA2__LCDIF2_WR_RWN = IOMUX_PAD(0x05A8, 0x0260, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DATA2__TPSMP_HDATA_26 = IOMUX_PAD(0x05A8, 0x0260, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DATA2__GPU_DEBUG_2 = IOMUX_PAD(0x05A8, 0x0260, 8, 0x0000, 0, 0), + MX6_PAD_SD3_DATA2__SDMA_DEBUG_EVENT_CHANNEL_2 = IOMUX_PAD(0x05A8, 0x0260, 9, 0x0000, 0, 0), + + MX6_PAD_SD3_DATA3__USDHC3_DATA3 = IOMUX_PAD(0x05AC, 0x0264, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DATA3__UART4_RX = IOMUX_PAD(0x05AC, 0x0264, 1, 0x0848, 1, 0), + MX6_PAD_SD3_DATA3__ECSPI4_MISO = IOMUX_PAD(0x05AC, 0x0264, 2, 0x0744, 0, 0), + MX6_PAD_SD3_DATA3__AUDMUX_AUD6_TXD = IOMUX_PAD(0x05AC, 0x0264, 3, 0x0678, 0, 0), + MX6_PAD_SD3_DATA3__LCDIF2_ENABLE = IOMUX_PAD(0x05AC, 0x0264, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DATA3__GPIO7_IO_5 = IOMUX_PAD(0x05AC, 0x0264, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DATA3__LCDIF2_RD_E = IOMUX_PAD(0x05AC, 0x0264, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DATA3__TPSMP_HDATA_27 = IOMUX_PAD(0x05AC, 0x0264, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DATA3__GPU_DEBUG_3 = IOMUX_PAD(0x05AC, 0x0264, 8, 0x0000, 0, 0), + MX6_PAD_SD3_DATA3__SDMA_DEBUG_EVENT_CHANNEL_3 = IOMUX_PAD(0x05AC, 0x0264, 9, 0x0000, 0, 0), + + MX6_PAD_SD3_DATA4__USDHC3_DATA4 = IOMUX_PAD(0x05B0, 0x0268, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DATA4__CAN2_RX = IOMUX_PAD(0x05B0, 0x0268, 1, 0x0690, 0, 0), + MX6_PAD_SD3_DATA4__CANFD_RX2 = IOMUX_PAD(0x05B0, 0x0268, 2, 0x0698, 0, 0), + MX6_PAD_SD3_DATA4__UART3_RX = IOMUX_PAD(0x05B0, 0x0268, 3, 0x0840, 2, 0), + MX6_PAD_SD3_DATA4__LCDIF2_DATA_3 = IOMUX_PAD(0x05B0, 0x0268, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DATA4__GPIO7_IO_6 = IOMUX_PAD(0x05B0, 0x0268, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DATA4__ENET2_1588_EVENT0_IN = IOMUX_PAD(0x05B0, 0x0268, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DATA4__TPSMP_HTRANS_1 = IOMUX_PAD(0x05B0, 0x0268, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DATA4__GPU_DEBUG_4 = IOMUX_PAD(0x05B0, 0x0268, 8, 0x0000, 0, 0), + MX6_PAD_SD3_DATA4__SDMA_DEBUG_BUS_DEVICE_0 = IOMUX_PAD(0x05B0, 0x0268, 9, 0x0000, 0, 0), + + MX6_PAD_SD3_DATA5__USDHC3_DATA5 = IOMUX_PAD(0x05B4, 0x026C, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DATA5__CAN1_TX = IOMUX_PAD(0x05B4, 0x026C, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DATA5__CANFD_TX1 = IOMUX_PAD(0x05B4, 0x026C, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DATA5__UART3_TX = IOMUX_PAD(0x05B4, 0x026C, 3, 0x0840, 3, 0), + MX6_PAD_SD3_DATA5__LCDIF2_DATA_2 = IOMUX_PAD(0x05B4, 0x026C, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DATA5__GPIO7_IO_7 = IOMUX_PAD(0x05B4, 0x026C, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DATA5__ENET2_1588_EVENT0_OUT = IOMUX_PAD(0x05B4, 0x026C, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DATA5__SIM_M_HWRITE = IOMUX_PAD(0x05B4, 0x026C, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DATA5__GPU_DEBUG_5 = IOMUX_PAD(0x05B4, 0x026C, 8, 0x0000, 0, 0), + MX6_PAD_SD3_DATA5__SDMA_DEBUG_BUS_DEVICE_1 = IOMUX_PAD(0x05B4, 0x026C, 9, 0x0000, 0, 0), + + MX6_PAD_SD3_DATA6__USDHC3_DATA6 = IOMUX_PAD(0x05B8, 0x0270, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DATA6__CAN2_TX = IOMUX_PAD(0x05B8, 0x0270, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DATA6__CANFD_TX2 = IOMUX_PAD(0x05B8, 0x0270, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DATA6__UART3_RTS_B = IOMUX_PAD(0x05B8, 0x0270, 3, 0x083C, 2, 0), + MX6_PAD_SD3_DATA6__LCDIF2_DATA_4 = IOMUX_PAD(0x05B8, 0x0270, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DATA6__GPIO7_IO_8 = IOMUX_PAD(0x05B8, 0x0270, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DATA6__ENET1_1588_EVENT0_OUT = IOMUX_PAD(0x05B8, 0x0270, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DATA6__TPSMP_HTRANS_0 = IOMUX_PAD(0x05B8, 0x0270, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DATA6__GPU_DEBUG_7 = IOMUX_PAD(0x05B8, 0x0270, 8, 0x0000, 0, 0), + MX6_PAD_SD3_DATA6__SDMA_DEBUG_EVT_CHN_LINES_7 = IOMUX_PAD(0x05B8, 0x0270, 9, 0x0000, 0, 0), + + MX6_PAD_SD3_DATA7__USDHC3_DATA7 = IOMUX_PAD(0x05BC, 0x0274, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DATA7__CAN1_RX = IOMUX_PAD(0x05BC, 0x0274, 1, 0x068C, 0, 0), + MX6_PAD_SD3_DATA7__CANFD_RX1 = IOMUX_PAD(0x05BC, 0x0274, 2, 0x0694, 0, 0), + MX6_PAD_SD3_DATA7__UART3_CTS_B = IOMUX_PAD(0x05BC, 0x0274, 3, 0x083C, 3, 0), + MX6_PAD_SD3_DATA7__LCDIF2_DATA_5 = IOMUX_PAD(0x05BC, 0x0274, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DATA7__GPIO7_IO_9 = IOMUX_PAD(0x05BC, 0x0274, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DATA7__ENET1_1588_EVENT0_IN = IOMUX_PAD(0x05BC, 0x0274, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DATA7__TPSMP_HDATA_DIR = IOMUX_PAD(0x05BC, 0x0274, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DATA7__GPU_DEBUG_6 = IOMUX_PAD(0x05BC, 0x0274, 8, 0x0000, 0, 0), + MX6_PAD_SD3_DATA7__SDMA_DEBUG_EVT_CHN_LINES_2 = IOMUX_PAD(0x05BC, 0x0274, 9, 0x0000, 0, 0), + + MX6_PAD_SD4_CLK__USDHC4_CLK = IOMUX_PAD(0x05C0, 0x0278, 0, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__RAWNAND_DATA15 = IOMUX_PAD(0x05C0, 0x0278, 1, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__ECSPI2_MISO = IOMUX_PAD(0x05C0, 0x0278, 2, 0x0724, 1, 0), + MX6_PAD_SD4_CLK__AUDMUX_AUD3_RXFS = IOMUX_PAD(0x05C0, 0x0278, 3, 0x0638, 0, 0), + MX6_PAD_SD4_CLK__LCDIF2_DATA_13 = IOMUX_PAD(0x05C0, 0x0278, 4, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__GPIO6_IO_12 = IOMUX_PAD(0x05C0, 0x0278, 5, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__ECSPI3_SS2 = IOMUX_PAD(0x05C0, 0x0278, 6, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__TPSMP_HDATA_20 = IOMUX_PAD(0x05C0, 0x0278, 7, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__VDEC_DEBUG_12 = IOMUX_PAD(0x05C0, 0x0278, 8, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__SDMA_DEBUG_EVENT_CHANNEL_SEL = IOMUX_PAD(0x05C0, 0x0278, 9, 0x0000, 0, 0), + + MX6_PAD_SD4_CMD__USDHC4_CMD = IOMUX_PAD(0x05C4, 0x027C, 0, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__RAWNAND_DATA14 = IOMUX_PAD(0x05C4, 0x027C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__ECSPI2_MOSI = IOMUX_PAD(0x05C4, 0x027C, 2, 0x0728, 1, 0), + MX6_PAD_SD4_CMD__AUDMUX_AUD3_RXC = IOMUX_PAD(0x05C4, 0x027C, 3, 0x0634, 0, 0), + MX6_PAD_SD4_CMD__LCDIF2_DATA_14 = IOMUX_PAD(0x05C4, 0x027C, 4, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__GPIO6_IO_13 = IOMUX_PAD(0x05C4, 0x027C, 5, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__ECSPI3_SS1 = IOMUX_PAD(0x05C4, 0x027C, 6, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__TPSMP_HDATA_19 = IOMUX_PAD(0x05C4, 0x027C, 7, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__VDEC_DEBUG_11 = IOMUX_PAD(0x05C4, 0x027C, 8, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__SDMA_DEBUG_CORE_RUN = IOMUX_PAD(0x05C4, 0x027C, 9, 0x0000, 0, 0), + + MX6_PAD_SD4_DATA0__USDHC4_DATA0 = IOMUX_PAD(0x05C8, 0x0280, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DATA0__RAWNAND_DATA10 = IOMUX_PAD(0x05C8, 0x0280, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DATA0__ECSPI2_SS0 = IOMUX_PAD(0x05C8, 0x0280, 2, 0x072C, 1, 0), + MX6_PAD_SD4_DATA0__AUDMUX_AUD3_RXD = IOMUX_PAD(0x05C8, 0x0280, 3, 0x062C, 0, 0), + MX6_PAD_SD4_DATA0__LCDIF2_DATA_12 = IOMUX_PAD(0x05C8, 0x0280, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DATA0__GPIO6_IO_14 = IOMUX_PAD(0x05C8, 0x0280, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DATA0__ECSPI3_SS3 = IOMUX_PAD(0x05C8, 0x0280, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DATA0__TPSMP_HDATA_21 = IOMUX_PAD(0x05C8, 0x0280, 7, 0x0000, 0, 0), + MX6_PAD_SD4_DATA0__VDEC_DEBUG_13 = IOMUX_PAD(0x05C8, 0x0280, 8, 0x0000, 0, 0), + MX6_PAD_SD4_DATA0__SDMA_DEBUG_MODE = IOMUX_PAD(0x05C8, 0x0280, 9, 0x0000, 0, 0), + + MX6_PAD_SD4_DATA1__USDHC4_DATA1 = IOMUX_PAD(0x05CC, 0x0284, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DATA1__RAWNAND_DATA11 = IOMUX_PAD(0x05CC, 0x0284, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DATA1__ECSPI2_SCLK = IOMUX_PAD(0x05CC, 0x0284, 2, 0x0720, 1, 0), + MX6_PAD_SD4_DATA1__AUDMUX_AUD3_TXC = IOMUX_PAD(0x05CC, 0x0284, 3, 0x063C, 0, 0), + MX6_PAD_SD4_DATA1__LCDIF2_DATA_11 = IOMUX_PAD(0x05CC, 0x0284, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DATA1__GPIO6_IO_15 = IOMUX_PAD(0x05CC, 0x0284, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DATA1__ECSPI3_RDY = IOMUX_PAD(0x05CC, 0x0284, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DATA1__TPSMP_HDATA_22 = IOMUX_PAD(0x05CC, 0x0284, 7, 0x0000, 0, 0), + MX6_PAD_SD4_DATA1__VDEC_DEBUG_14 = IOMUX_PAD(0x05CC, 0x0284, 8, 0x0000, 0, 0), + MX6_PAD_SD4_DATA1__SDMA_DEBUG_BUS_ERROR = IOMUX_PAD(0x05CC, 0x0284, 9, 0x0000, 0, 0), + + MX6_PAD_SD4_DATA2__USDHC4_DATA2 = IOMUX_PAD(0x05D0, 0x0288, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DATA2__RAWNAND_DATA12 = IOMUX_PAD(0x05D0, 0x0288, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DATA2__I2C2_SDA = IOMUX_PAD(0x05D0, 0x0288, 2, 0x07B4, 0, 0), + MX6_PAD_SD4_DATA2__AUDMUX_AUD3_TXFS = IOMUX_PAD(0x05D0, 0x0288, 3, 0x0640, 0, 0), + MX6_PAD_SD4_DATA2__LCDIF2_DATA_10 = IOMUX_PAD(0x05D0, 0x0288, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DATA2__GPIO6_IO_16 = IOMUX_PAD(0x05D0, 0x0288, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DATA2__ECSPI2_SS3 = IOMUX_PAD(0x05D0, 0x0288, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DATA2__TPSMP_HDATA_23 = IOMUX_PAD(0x05D0, 0x0288, 7, 0x0000, 0, 0), + MX6_PAD_SD4_DATA2__VDEC_DEBUG_15 = IOMUX_PAD(0x05D0, 0x0288, 8, 0x0000, 0, 0), + MX6_PAD_SD4_DATA2__SDMA_DEBUG_BUS_RWB = IOMUX_PAD(0x05D0, 0x0288, 9, 0x0000, 0, 0), + + MX6_PAD_SD4_DATA3__USDHC4_DATA3 = IOMUX_PAD(0x05D4, 0x028C, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DATA3__RAWNAND_DATA13 = IOMUX_PAD(0x05D4, 0x028C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DATA3__I2C2_SCL = IOMUX_PAD(0x05D4, 0x028C, 2, 0x07B0, 0, 0), + MX6_PAD_SD4_DATA3__AUDMUX_AUD3_TXD = IOMUX_PAD(0x05D4, 0x028C, 3, 0x0630, 0, 0), + MX6_PAD_SD4_DATA3__LCDIF2_DATA_9 = IOMUX_PAD(0x05D4, 0x028C, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DATA3__GPIO6_IO_17 = IOMUX_PAD(0x05D4, 0x028C, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DATA3__ECSPI2_RDY = IOMUX_PAD(0x05D4, 0x028C, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DATA3__TPSMP_HDATA_24 = IOMUX_PAD(0x05D4, 0x028C, 7, 0x0000, 0, 0), + MX6_PAD_SD4_DATA3__VDEC_DEBUG_16 = IOMUX_PAD(0x05D4, 0x028C, 8, 0x0000, 0, 0), + MX6_PAD_SD4_DATA3__SDMA_DEBUG_MATCHED_DMBUS = IOMUX_PAD(0x05D4, 0x028C, 9, 0x0000, 0, 0), + + MX6_PAD_SD4_DATA4__USDHC4_DATA4 = IOMUX_PAD(0x05D8, 0x0290, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DATA4__RAWNAND_DATA09 = IOMUX_PAD(0x05D8, 0x0290, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DATA4__UART5_RX = IOMUX_PAD(0x05D8, 0x0290, 2, 0x0850, 0, 0), + MX6_PAD_SD4_DATA4__ECSPI3_SCLK = IOMUX_PAD(0x05D8, 0x0290, 3, 0x0730, 0, 0), + MX6_PAD_SD4_DATA4__LCDIF2_DATA_8 = IOMUX_PAD(0x05D8, 0x0290, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DATA4__GPIO6_IO_18 = IOMUX_PAD(0x05D8, 0x0290, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DATA4__SPDIF_OUT = IOMUX_PAD(0x05D8, 0x0290, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DATA4__TPSMP_HDATA_16 = IOMUX_PAD(0x05D8, 0x0290, 7, 0x0000, 0, 0), + MX6_PAD_SD4_DATA4__USB_OTG_HOST_MODE = IOMUX_PAD(0x05D8, 0x0290, 8, 0x0000, 0, 0), + MX6_PAD_SD4_DATA4__SDMA_DEBUG_RTBUFFER_WRITE = IOMUX_PAD(0x05D8, 0x0290, 9, 0x0000, 0, 0), + + MX6_PAD_SD4_DATA5__USDHC4_DATA5 = IOMUX_PAD(0x05DC, 0x0294, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DATA5__RAWNAND_CE2_B = IOMUX_PAD(0x05DC, 0x0294, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DATA5__UART5_TX = IOMUX_PAD(0x05DC, 0x0294, 2, 0x0850, 1, 0), + MX6_PAD_SD4_DATA5__ECSPI3_MOSI = IOMUX_PAD(0x05DC, 0x0294, 3, 0x0738, 0, 0), + MX6_PAD_SD4_DATA5__LCDIF2_DATA_7 = IOMUX_PAD(0x05DC, 0x0294, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DATA5__GPIO6_IO_19 = IOMUX_PAD(0x05DC, 0x0294, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DATA5__SPDIF_IN = IOMUX_PAD(0x05DC, 0x0294, 6, 0x0824, 0, 0), + MX6_PAD_SD4_DATA5__TPSMP_HDATA_17 = IOMUX_PAD(0x05DC, 0x0294, 7, 0x0000, 0, 0), + MX6_PAD_SD4_DATA5__VDEC_DEBUG_9 = IOMUX_PAD(0x05DC, 0x0294, 8, 0x0000, 0, 0), + MX6_PAD_SD4_DATA5__SDMA_DEBUG_EVENT_CHANNEL_0 = IOMUX_PAD(0x05DC, 0x0294, 9, 0x0000, 0, 0), + + MX6_PAD_SD4_DATA6__USDHC4_DATA6 = IOMUX_PAD(0x05E0, 0x0298, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DATA6__RAWNAND_CE3_B = IOMUX_PAD(0x05E0, 0x0298, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DATA6__UART5_RTS_B = IOMUX_PAD(0x05E0, 0x0298, 2, 0x084C, 0, 0), + MX6_PAD_SD4_DATA6__ECSPI3_MISO = IOMUX_PAD(0x05E0, 0x0298, 3, 0x0734, 0, 0), + MX6_PAD_SD4_DATA6__LCDIF2_DATA_6 = IOMUX_PAD(0x05E0, 0x0298, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DATA6__GPIO6_IO_20 = IOMUX_PAD(0x05E0, 0x0298, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DATA6__USDHC4_WP = IOMUX_PAD(0x05E0, 0x0298, 6, 0x0878, 0, 0), + MX6_PAD_SD4_DATA6__TPSMP_HDATA_18 = IOMUX_PAD(0x05E0, 0x0298, 7, 0x0000, 0, 0), + MX6_PAD_SD4_DATA6__VDEC_DEBUG_10 = IOMUX_PAD(0x05E0, 0x0298, 8, 0x0000, 0, 0), + MX6_PAD_SD4_DATA6__SDMA_DEBUG_EVENT_CHANNEL_1 = IOMUX_PAD(0x05E0, 0x0298, 9, 0x0000, 0, 0), + + MX6_PAD_SD4_DATA7__USDHC4_DATA7 = IOMUX_PAD(0x05E4, 0x029C, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DATA7__RAWNAND_DATA08 = IOMUX_PAD(0x05E4, 0x029C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DATA7__UART5_CTS_B = IOMUX_PAD(0x05E4, 0x029C, 2, 0x084C, 1, 0), + MX6_PAD_SD4_DATA7__ECSPI3_SS0 = IOMUX_PAD(0x05E4, 0x029C, 3, 0x073C, 0, 0), + MX6_PAD_SD4_DATA7__LCDIF2_DATA_15 = IOMUX_PAD(0x05E4, 0x029C, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DATA7__GPIO6_IO_21 = IOMUX_PAD(0x05E4, 0x029C, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DATA7__USDHC4_CD_B = IOMUX_PAD(0x05E4, 0x029C, 6, 0x0874, 0, 0), + MX6_PAD_SD4_DATA7__TPSMP_HDATA_15 = IOMUX_PAD(0x05E4, 0x029C, 7, 0x0000, 0, 0), + MX6_PAD_SD4_DATA7__USB_OTG_PWR_WAKE = IOMUX_PAD(0x05E4, 0x029C, 8, 0x0000, 0, 0), + MX6_PAD_SD4_DATA7__SDMA_DEBUG_YIELD = IOMUX_PAD(0x05E4, 0x029C, 9, 0x0000, 0, 0), + + MX6_PAD_SD4_RESET_B__USDHC4_RESET_B = IOMUX_PAD(0x05E8, 0x02A0, 0, 0x0000, 0, 0), + MX6_PAD_SD4_RESET_B__RAWNAND_DQS = IOMUX_PAD(0x05E8, 0x02A0, 1, 0x0000, 0, 0), + MX6_PAD_SD4_RESET_B__USDHC4_RESET = IOMUX_PAD(0x05E8, 0x02A0, 2, 0x0000, 0, 0), + MX6_PAD_SD4_RESET_B__AUDMUX_MCLK = IOMUX_PAD(0x05E8, 0x02A0, 3, 0x0000, 0, 0), + MX6_PAD_SD4_RESET_B__LCDIF2_RESET = IOMUX_PAD(0x05E8, 0x02A0, 4, 0x0000, 0, 0), + MX6_PAD_SD4_RESET_B__GPIO6_IO_22 = IOMUX_PAD(0x05E8, 0x02A0, 5, 0x0000, 0, 0), + MX6_PAD_SD4_RESET_B__LCDIF2_CS = IOMUX_PAD(0x05E8, 0x02A0, 6, 0x0000, 0, 0), + MX6_PAD_SD4_RESET_B__TPSMP_HDATA_25 = IOMUX_PAD(0x05E8, 0x02A0, 7, 0x0000, 0, 0), + MX6_PAD_SD4_RESET_B__VDEC_DEBUG_17 = IOMUX_PAD(0x05E8, 0x02A0, 8, 0x0000, 0, 0), + MX6_PAD_SD4_RESET_B__SDMA_DEBUG_BUS_DEVICE_2 = IOMUX_PAD(0x05E8, 0x02A0, 9, 0x0000, 0, 0), + + MX6_PAD_USB_H_DATA__USB_H_DATA = IOMUX_PAD(0x05EC, 0x02A4, 0, 0x0000, 0, 0), + MX6_PAD_USB_H_DATA__PWM2_OUT = IOMUX_PAD(0x05EC, 0x02A4, 1, 0x0000, 0, 0), + MX6_PAD_USB_H_DATA__ANATOP_24M_OUT = IOMUX_PAD(0x05EC, 0x02A4, 2, 0x0000, 0, 0), + MX6_PAD_USB_H_DATA__I2C4_SDA = IOMUX_PAD(0x05EC, 0x02A4, 3, 0x07C4, 1, 0), + MX6_PAD_USB_H_DATA__WDOG3_WDOG_B = IOMUX_PAD(0x05EC, 0x02A4, 4, 0x0000, 0, 0), + MX6_PAD_USB_H_DATA__GPIO7_IO_10 = IOMUX_PAD(0x05EC, 0x02A4, 5, 0x0000, 0, 0), + + MX6_PAD_USB_H_STROBE__USB_H_STROBE = IOMUX_PAD(0x05F0, 0x02A8, 0, 0x0000, 0, 0), + MX6_PAD_USB_H_STROBE__PWM1_OUT = IOMUX_PAD(0x05F0, 0x02A8, 1, 0x0000, 0, 0), + MX6_PAD_USB_H_STROBE__ANATOP_32K_OUT = IOMUX_PAD(0x05F0, 0x02A8, 2, 0x0000, 0, 0), + MX6_PAD_USB_H_STROBE__I2C4_SCL = IOMUX_PAD(0x05F0, 0x02A8, 3, 0x07C0, 1, 0), + MX6_PAD_USB_H_STROBE__WDOG3_WDOG_RST_B_DEB = IOMUX_PAD(0x05F0, 0x02A8, 4, 0x0000, 0, 0), + MX6_PAD_USB_H_STROBE__GPIO7_IO_11 = IOMUX_PAD(0x05F0, 0x02A8, 5, 0x0000, 0, 0), +}; +#endif /* __ASM_ARCH_MX6_ MX6_PINS_H__ */
Hi Fabio,
On 14/06/2014 22:29, Fabio Estevam wrote:
Add the pin definitions for mx6sx.
A base question. There was a lot of work to try to abstract the pin definitions for the i.MX6 SOCs. For QUAD and DUAL, the pins are defined with the MX6_PAD_DECL macro. It works differently according to the selected CPU. If more as one CPU is supported in the same image, the check is done at runtime.
Previously, we had IOMUX_PAD, I know. Is there any special reason we cannot use MX6_PAD_DECL even for this new SOC ? I will not want to go back ignoring a lot of work that was done to merge the SOCs together.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com
arch/arm/include/asm/arch-mx6/mx6-pins.h | 2 + arch/arm/include/asm/arch-mx6/mx6sx_pins.h | 1675 ++++++++++++++++++++++++++++ 2 files changed, 1677 insertions(+) create mode 100644 arch/arm/include/asm/arch-mx6/mx6sx_pins.h
diff --git a/arch/arm/include/asm/arch-mx6/mx6-pins.h b/arch/arm/include/asm/arch-mx6/mx6-pins.h index dcd7f8f..534f780 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6-pins.h @@ -35,6 +35,8 @@ enum { }; #elif defined(CONFIG_MX6SL) #include "mx6sl_pins.h" +#elif defined(CONFIG_MX6SX) +#include "mx6sx_pins.h" #else #error "Please select cpu" #endif /* CONFIG_MX6Q */ diff --git a/arch/arm/include/asm/arch-mx6/mx6sx_pins.h b/arch/arm/include/asm/arch-mx6/mx6sx_pins.h new file mode 100644 index 0000000..7c6c1e8 --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6sx_pins.h @@ -0,0 +1,1675 @@ +/*
- Copyright (C) 2014 Freescale Semiconductor, Inc. All Rights Reserved.
+#ifndef __ASM_ARCH_MX6_MX6_PINS_H__ +#define __ASM_ARCH_MX6_MX6_PINS_H__
+#include <asm/imx-common/iomux-v3.h>
+enum {
MX6_PAD_GPIO1_IO00__I2C1_SCL = IOMUX_PAD(0x035C, 0x0014, IOMUX_CONFIG_SION | 0, 0x07A8, 1, 0),
MX6_PAD_GPIO1_IO00__USDHC1_VSELECT = IOMUX_PAD(0x035C, 0x0014, 1, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO00__SPDIF_LOCK = IOMUX_PAD(0x035C, 0x0014, 2, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO00__CCM_WAIT = IOMUX_PAD(0x035C, 0x0014, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO00__WDOG1_WDOG_ANY = IOMUX_PAD(0x035C, 0x0014, 4, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO00__GPIO1_IO_0 = IOMUX_PAD(0x035C, 0x0014, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO00__SNVS_HP_WRAPPER_VIO_5 = IOMUX_PAD(0x035C, 0x0014, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO00__PHY_DTB_1 = IOMUX_PAD(0x035C, 0x0014, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO01__I2C1_SDA = IOMUX_PAD(0x0360, 0x0018, IOMUX_CONFIG_SION | 0, 0x07AC, 1, 0),
MX6_PAD_GPIO1_IO01__USDHC1_RESET_B = IOMUX_PAD(0x0360, 0x0018, 1, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO01__SPDIF_SR_CLK = IOMUX_PAD(0x0360, 0x0018, 2, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO01__CCM_STOP = IOMUX_PAD(0x0360, 0x0018, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO01__WDOG3_WDOG_B = IOMUX_PAD(0x0360, 0x0018, 4, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO01__GPIO1_IO_1 = IOMUX_PAD(0x0360, 0x0018, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO01__SNVS_HP_WRAPPER_VIO_5_CTL = IOMUX_PAD(0x0360, 0x0018, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO01__PHY_DTB_0 = IOMUX_PAD(0x0360, 0x0018, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO02__I2C2_SCL = IOMUX_PAD(0x0364, 0x001C, IOMUX_CONFIG_SION | 0, 0x07B0, 1, 0),
MX6_PAD_GPIO1_IO02__USDHC1_CD_B = IOMUX_PAD(0x0364, 0x001C, 1, 0x0864, 1, 0),
MX6_PAD_GPIO1_IO02__CSI2_MCLK = IOMUX_PAD(0x0364, 0x001C, 2, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO02__CCM_DI0_EXT_CLK = IOMUX_PAD(0x0364, 0x001C, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO02__WDOG1_WDOG_B = IOMUX_PAD(0x0364, 0x001C, 4, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO02__GPIO1_IO_2 = IOMUX_PAD(0x0364, 0x001C, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO02__CCM_REF_EN_B = IOMUX_PAD(0x0364, 0x001C, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO02__PHY_TDI = IOMUX_PAD(0x0364, 0x001C, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO03__I2C2_SDA = IOMUX_PAD(0x0368, 0x0020, IOMUX_CONFIG_SION | 0, 0x07B4, 1, 0),
MX6_PAD_GPIO1_IO03__USDHC1_WP = IOMUX_PAD(0x0368, 0x0020, 1, 0x0868, 1, 0),
MX6_PAD_GPIO1_IO03__ENET1_REF_CLK_25M = IOMUX_PAD(0x0368, 0x0020, 2, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO03__CCM_DI1_EXT_CLK = IOMUX_PAD(0x0368, 0x0020, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO03__WDOG2_WDOG_B = IOMUX_PAD(0x0368, 0x0020, 4, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO03__GPIO1_IO_3 = IOMUX_PAD(0x0368, 0x0020, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO03__CCM_PLL3_BYP = IOMUX_PAD(0x0368, 0x0020, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO03__PHY_TCK = IOMUX_PAD(0x0368, 0x0020, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO04__UART1_TX = IOMUX_PAD(0x036C, 0x0024, 0, 0x0830, 0, 0),
MX6_PAD_GPIO1_IO04__USDHC2_RESET_B = IOMUX_PAD(0x036C, 0x0024, 1, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO04__ENET1_MDC = IOMUX_PAD(0x036C, 0x0024, 2, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO04__OSC32K_32K_OUT = IOMUX_PAD(0x036C, 0x0024, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO04__ENET2_REF_CLK2 = IOMUX_PAD(0x036C, 0x0024, 4, 0x076C, 0, 0),
MX6_PAD_GPIO1_IO04__GPIO1_IO_4 = IOMUX_PAD(0x036C, 0x0024, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO04__CCM_PLL2_BYP = IOMUX_PAD(0x036C, 0x0024, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO04__PHY_TMS = IOMUX_PAD(0x036C, 0x0024, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO05__UART1_RX = IOMUX_PAD(0x0370, 0x0028, 0, 0x0830, 1, 0),
MX6_PAD_GPIO1_IO05__USDHC2_VSELECT = IOMUX_PAD(0x0370, 0x0028, 1, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO05__ENET1_MDIO = IOMUX_PAD(0x0370, 0x0028, 2, 0x0764, 0, 0),
MX6_PAD_GPIO1_IO05__ASRC_ASRC_EXT_CLK = IOMUX_PAD(0x0370, 0x0028, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO05__ENET1_REF_CLK1 = IOMUX_PAD(0x0370, 0x0028, 4, 0x0760, 0, 0),
MX6_PAD_GPIO1_IO05__GPIO1_IO_5 = IOMUX_PAD(0x0370, 0x0028, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO05__SRC_TESTER_ACK = IOMUX_PAD(0x0370, 0x0028, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO05__PHY_TDO = IOMUX_PAD(0x0370, 0x0028, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO06__UART2_TX = IOMUX_PAD(0x0374, 0x002C, 0, 0x0838, 0, 0),
MX6_PAD_GPIO1_IO06__USDHC2_CD_B = IOMUX_PAD(0x0374, 0x002C, 1, 0x086C, 1, 0),
MX6_PAD_GPIO1_IO06__ENET2_MDC = IOMUX_PAD(0x0374, 0x002C, 2, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO06__CSI1_MCLK = IOMUX_PAD(0x0374, 0x002C, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO06__UART1_RTS_B = IOMUX_PAD(0x0374, 0x002C, 4, 0x082C, 0, 0),
MX6_PAD_GPIO1_IO06__GPIO1_IO_6 = IOMUX_PAD(0x0374, 0x002C, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO06__SRC_ANY_PU_RESET = IOMUX_PAD(0x0374, 0x002C, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO06__OCOTP_CTRL_WRAPPER_FUSE_LATCHED = IOMUX_PAD(0x0374, 0x002C, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO07__UART2_RX = IOMUX_PAD(0x0378, 0x0030, 0, 0x0838, 1, 0),
MX6_PAD_GPIO1_IO07__USDHC2_WP = IOMUX_PAD(0x0378, 0x0030, 1, 0x0870, 1, 0),
MX6_PAD_GPIO1_IO07__ENET2_MDIO = IOMUX_PAD(0x0378, 0x0030, 2, 0x0770, 0, 0),
MX6_PAD_GPIO1_IO07__AUDMUX_MCLK = IOMUX_PAD(0x0378, 0x0030, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO07__UART1_CTS_B = IOMUX_PAD(0x0378, 0x0030, 4, 0x082C, 1, 0),
MX6_PAD_GPIO1_IO07__GPIO1_IO_7 = IOMUX_PAD(0x0378, 0x0030, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO07__SRC_EARLY_RESET = IOMUX_PAD(0x0378, 0x0030, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO07__DCIC2_OUT = IOMUX_PAD(0x0378, 0x0030, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO07__VDEC_DEBUG_44 = IOMUX_PAD(0x0378, 0x0030, 8, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO08__USB_OTG1_OC = IOMUX_PAD(0x037C, 0x0034, 0, 0x0860, 0, 0),
MX6_PAD_GPIO1_IO08__WDOG1_WDOG_B = IOMUX_PAD(0x037C, 0x0034, 1, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO08__SDMA_EXT_EVENT_0 = IOMUX_PAD(0x037C, 0x0034, 2, 0x081C, 0, 0),
MX6_PAD_GPIO1_IO08__CCM_PMIC_RDY = IOMUX_PAD(0x037C, 0x0034, 3, 0x069C, 1, 0),
MX6_PAD_GPIO1_IO08__UART2_RTS_B = IOMUX_PAD(0x037C, 0x0034, 4, 0x0834, 0, 0),
MX6_PAD_GPIO1_IO08__GPIO1_IO_8 = IOMUX_PAD(0x037C, 0x0034, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO08__SRC_SYSTEM_RESET = IOMUX_PAD(0x037C, 0x0034, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO08__DCIC1_OUT = IOMUX_PAD(0x037C, 0x0034, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO08__VDEC_DEBUG_43 = IOMUX_PAD(0x037C, 0x0034, 8, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO09__USB_OTG1_PWR = IOMUX_PAD(0x0380, 0x0038, 0, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO09__WDOG2_WDOG_B = IOMUX_PAD(0x0380, 0x0038, 1, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO09__SDMA_EXT_EVENT_1 = IOMUX_PAD(0x0380, 0x0038, 2, 0x0820, 0, 0),
MX6_PAD_GPIO1_IO09__CCM_OUT0 = IOMUX_PAD(0x0380, 0x0038, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO09__UART2_CTS_B = IOMUX_PAD(0x0380, 0x0038, 4, 0x0834, 1, 0),
MX6_PAD_GPIO1_IO09__GPIO1_IO_9 = IOMUX_PAD(0x0380, 0x0038, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO09__SRC_INT_BOOT = IOMUX_PAD(0x0380, 0x0038, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO09__OBSERVE_MUX_OUT_4 = IOMUX_PAD(0x0380, 0x0038, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO09__VDEC_DEBUG_42 = IOMUX_PAD(0x0380, 0x0038, 8, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO10__ANATOP_OTG1_ID = IOMUX_PAD(0x0384, 0x003C, 0, 0x0624, 0, 0),
MX6_PAD_GPIO1_IO10__SPDIF_EXT_CLK = IOMUX_PAD(0x0384, 0x003C, 1, 0x0828, 0, 0),
MX6_PAD_GPIO1_IO10__PWM1_OUT = IOMUX_PAD(0x0384, 0x003C, 2, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO10__CCM_OUT1 = IOMUX_PAD(0x0384, 0x003C, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO10__CSI1_FIELD = IOMUX_PAD(0x0384, 0x003C, 4, 0x070C, 1, 0),
MX6_PAD_GPIO1_IO10__GPIO1_IO_10 = IOMUX_PAD(0x0384, 0x003C, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO10__CSU_CSU_INT_DEB = IOMUX_PAD(0x0384, 0x003C, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO10__OBSERVE_MUX_OUT_3 = IOMUX_PAD(0x0384, 0x003C, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO10__VDEC_DEBUG_41 = IOMUX_PAD(0x0384, 0x003C, 8, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO11__USB_OTG2_OC = IOMUX_PAD(0x0388, 0x0040, 0, 0x085C, 0, 0),
MX6_PAD_GPIO1_IO11__SPDIF_IN = IOMUX_PAD(0x0388, 0x0040, 1, 0x0824, 2, 0),
MX6_PAD_GPIO1_IO11__PWM2_OUT = IOMUX_PAD(0x0388, 0x0040, 2, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO11__CCM_CLKO1 = IOMUX_PAD(0x0388, 0x0040, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO11__MLB_DATA = IOMUX_PAD(0x0388, 0x0040, 4, 0x07EC, 0, 0),
MX6_PAD_GPIO1_IO11__GPIO1_IO_11 = IOMUX_PAD(0x0388, 0x0040, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO11__CSU_CSU_ALARM_AUT_0 = IOMUX_PAD(0x0388, 0x0040, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO11__OBSERVE_MUX_OUT_2 = IOMUX_PAD(0x0388, 0x0040, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO11__VDEC_DEBUG_40 = IOMUX_PAD(0x0388, 0x0040, 8, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO12__USB_OTG2_PWR = IOMUX_PAD(0x038C, 0x0044, 0, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO12__SPDIF_OUT = IOMUX_PAD(0x038C, 0x0044, 1, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO12__PWM3_OUT = IOMUX_PAD(0x038C, 0x0044, 2, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO12__CCM_CLKO2 = IOMUX_PAD(0x038C, 0x0044, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO12__MLB_CLK = IOMUX_PAD(0x038C, 0x0044, 4, 0x07E8, 0, 0),
MX6_PAD_GPIO1_IO12__GPIO1_IO_12 = IOMUX_PAD(0x038C, 0x0044, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO12__CSU_CSU_ALARM_AUT_1 = IOMUX_PAD(0x038C, 0x0044, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO12__OBSERVE_MUX_OUT_1 = IOMUX_PAD(0x038C, 0x0044, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO12__VDEC_DEBUG_39 = IOMUX_PAD(0x038C, 0x0044, 8, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO13__WDOG1_WDOG_ANY = IOMUX_PAD(0x0390, 0x0048, 0, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO13__ANATOP_OTG2_ID = IOMUX_PAD(0x0390, 0x0048, 1, 0x0628, 0, 0),
MX6_PAD_GPIO1_IO13__PWM4_OUT = IOMUX_PAD(0x0390, 0x0048, 2, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO13__CCM_OUT2 = IOMUX_PAD(0x0390, 0x0048, 3, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO13__MLB_SIG = IOMUX_PAD(0x0390, 0x0048, 4, 0x07F0, 0, 0),
MX6_PAD_GPIO1_IO13__GPIO1_IO_13 = IOMUX_PAD(0x0390, 0x0048, 5, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO13__CSU_CSU_ALARM_AUT_2 = IOMUX_PAD(0x0390, 0x0048, 6, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO13__OBSERVE_MUX_OUT_0 = IOMUX_PAD(0x0390, 0x0048, 7, 0x0000, 0, 0),
MX6_PAD_GPIO1_IO13__VDEC_DEBUG_38 = IOMUX_PAD(0x0390, 0x0048, 8, 0x0000, 0, 0),
MX6_PAD_CSI_DATA00__CSI1_DATA_2 = IOMUX_PAD(0x0394, 0x004C, 0, 0x06A8, 0, 0),
MX6_PAD_CSI_DATA00__ESAI_TX_CLK = IOMUX_PAD(0x0394, 0x004C, 1, 0x078C, 1, 0),
MX6_PAD_CSI_DATA00__AUDMUX_AUD6_TXC = IOMUX_PAD(0x0394, 0x004C, 2, 0x0684, 1, 0),
MX6_PAD_CSI_DATA00__I2C1_SCL = IOMUX_PAD(0x0394, 0x004C, 3, 0x07A8, 0, 0),
MX6_PAD_CSI_DATA00__UART6_RI_B = IOMUX_PAD(0x0394, 0x004C, 4, 0x0000, 0, 0),
MX6_PAD_CSI_DATA00__GPIO1_IO_14 = IOMUX_PAD(0x0394, 0x004C, 5, 0x0000, 0, 0),
MX6_PAD_CSI_DATA00__WEIM_DATA_23 = IOMUX_PAD(0x0394, 0x004C, 6, 0x0000, 0, 0),
MX6_PAD_CSI_DATA00__SAI1_TX_BCLK = IOMUX_PAD(0x0394, 0x004C, 7, 0x0800, 0, 0),
MX6_PAD_CSI_DATA00__VADC_DATA_4 = IOMUX_PAD(0x0394, 0x004C, 8, 0x0000, 0, 0),
MX6_PAD_CSI_DATA00__MMDC_DEBUG_37 = IOMUX_PAD(0x0394, 0x004C, 9, 0x0000, 0, 0),
MX6_PAD_CSI_DATA01__CSI1_DATA_3 = IOMUX_PAD(0x0398, 0x0050, 0, 0x06AC, 0, 0),
MX6_PAD_CSI_DATA01__ESAI_TX_FS = IOMUX_PAD(0x0398, 0x0050, 1, 0x077C, 1, 0),
MX6_PAD_CSI_DATA01__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x0398, 0x0050, 2, 0x0688, 1, 0),
MX6_PAD_CSI_DATA01__I2C1_SDA = IOMUX_PAD(0x0398, 0x0050, 3, 0x07AC, 0, 0),
MX6_PAD_CSI_DATA01__UART6_DSR_B = IOMUX_PAD(0x0398, 0x0050, 4, 0x0000, 0, 0),
MX6_PAD_CSI_DATA01__GPIO1_IO_15 = IOMUX_PAD(0x0398, 0x0050, 5, 0x0000, 0, 0),
MX6_PAD_CSI_DATA01__WEIM_DATA_22 = IOMUX_PAD(0x0398, 0x0050, 6, 0x0000, 0, 0),
MX6_PAD_CSI_DATA01__SAI1_TX_SYNC = IOMUX_PAD(0x0398, 0x0050, 7, 0x0804, 0, 0),
MX6_PAD_CSI_DATA01__VADC_DATA_5 = IOMUX_PAD(0x0398, 0x0050, 8, 0x0000, 0, 0),
MX6_PAD_CSI_DATA01__MMDC_DEBUG_38 = IOMUX_PAD(0x0398, 0x0050, 9, 0x0000, 0, 0),
MX6_PAD_CSI_DATA02__CSI1_DATA_4 = IOMUX_PAD(0x039C, 0x0054, 0, 0x06B0, 0, 0),
MX6_PAD_CSI_DATA02__ESAI_RX_CLK = IOMUX_PAD(0x039C, 0x0054, 1, 0x0788, 1, 0),
MX6_PAD_CSI_DATA02__AUDMUX_AUD6_RXC = IOMUX_PAD(0x039C, 0x0054, 2, 0x067C, 1, 0),
MX6_PAD_CSI_DATA02__KPP_COL_5 = IOMUX_PAD(0x039C, 0x0054, 3, 0x07C8, 0, 0),
MX6_PAD_CSI_DATA02__UART6_DTR_B = IOMUX_PAD(0x039C, 0x0054, 4, 0x0000, 0, 0),
MX6_PAD_CSI_DATA02__GPIO1_IO_16 = IOMUX_PAD(0x039C, 0x0054, 5, 0x0000, 0, 0),
MX6_PAD_CSI_DATA02__WEIM_DATA_21 = IOMUX_PAD(0x039C, 0x0054, 6, 0x0000, 0, 0),
MX6_PAD_CSI_DATA02__SAI1_RX_BCLK = IOMUX_PAD(0x039C, 0x0054, 7, 0x07F4, 0, 0),
MX6_PAD_CSI_DATA02__VADC_DATA_6 = IOMUX_PAD(0x039C, 0x0054, 8, 0x0000, 0, 0),
MX6_PAD_CSI_DATA02__MMDC_DEBUG_39 = IOMUX_PAD(0x039C, 0x0054, 9, 0x0000, 0, 0),
MX6_PAD_CSI_DATA03__CSI1_DATA_5 = IOMUX_PAD(0x03A0, 0x0058, 0, 0x06B4, 0, 0),
MX6_PAD_CSI_DATA03__ESAI_RX_FS = IOMUX_PAD(0x03A0, 0x0058, 1, 0x0778, 1, 0),
MX6_PAD_CSI_DATA03__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x03A0, 0x0058, 2, 0x0680, 1, 0),
MX6_PAD_CSI_DATA03__KPP_ROW_5 = IOMUX_PAD(0x03A0, 0x0058, 3, 0x07D4, 0, 0),
MX6_PAD_CSI_DATA03__UART6_DCD_B = IOMUX_PAD(0x03A0, 0x0058, 4, 0x0000, 0, 0),
MX6_PAD_CSI_DATA03__GPIO1_IO_17 = IOMUX_PAD(0x03A0, 0x0058, 5, 0x0000, 0, 0),
MX6_PAD_CSI_DATA03__WEIM_DATA_20 = IOMUX_PAD(0x03A0, 0x0058, 6, 0x0000, 0, 0),
MX6_PAD_CSI_DATA03__SAI1_RX_SYNC = IOMUX_PAD(0x03A0, 0x0058, 7, 0x07FC, 0, 0),
MX6_PAD_CSI_DATA03__VADC_DATA_7 = IOMUX_PAD(0x03A0, 0x0058, 8, 0x0000, 0, 0),
MX6_PAD_CSI_DATA03__MMDC_DEBUG_40 = IOMUX_PAD(0x03A0, 0x0058, 9, 0x0000, 0, 0),
MX6_PAD_CSI_DATA04__CSI1_DATA_6 = IOMUX_PAD(0x03A4, 0x005C, 0, 0x06B8, 0, 0),
MX6_PAD_CSI_DATA04__ESAI_TX1 = IOMUX_PAD(0x03A4, 0x005C, 1, 0x0794, 1, 0),
MX6_PAD_CSI_DATA04__SPDIF_OUT = IOMUX_PAD(0x03A4, 0x005C, 2, 0x0000, 0, 0),
MX6_PAD_CSI_DATA04__KPP_COL_6 = IOMUX_PAD(0x03A4, 0x005C, 3, 0x07CC, 0, 0),
MX6_PAD_CSI_DATA04__UART6_RX = IOMUX_PAD(0x03A4, 0x005C, 4, 0x0858, 0, 0),
MX6_PAD_CSI_DATA04__GPIO1_IO_18 = IOMUX_PAD(0x03A4, 0x005C, 5, 0x0000, 0, 0),
MX6_PAD_CSI_DATA04__WEIM_DATA_19 = IOMUX_PAD(0x03A4, 0x005C, 6, 0x0000, 0, 0),
MX6_PAD_CSI_DATA04__PWM5_OUT = IOMUX_PAD(0x03A4, 0x005C, 7, 0x0000, 0, 0),
MX6_PAD_CSI_DATA04__VADC_DATA_8 = IOMUX_PAD(0x03A4, 0x005C, 8, 0x0000, 0, 0),
MX6_PAD_CSI_DATA04__MMDC_DEBUG_41 = IOMUX_PAD(0x03A4, 0x005C, 9, 0x0000, 0, 0),
MX6_PAD_CSI_DATA05__CSI1_DATA_7 = IOMUX_PAD(0x03A8, 0x0060, 0, 0x06BC, 0, 0),
MX6_PAD_CSI_DATA05__ESAI_TX4_RX1 = IOMUX_PAD(0x03A8, 0x0060, 1, 0x07A0, 1, 0),
MX6_PAD_CSI_DATA05__SPDIF_IN = IOMUX_PAD(0x03A8, 0x0060, 2, 0x0824, 1, 0),
MX6_PAD_CSI_DATA05__KPP_ROW_6 = IOMUX_PAD(0x03A8, 0x0060, 3, 0x07D8, 0, 0),
MX6_PAD_CSI_DATA05__UART6_TX = IOMUX_PAD(0x03A8, 0x0060, 4, 0x0858, 1, 0),
MX6_PAD_CSI_DATA05__GPIO1_IO_19 = IOMUX_PAD(0x03A8, 0x0060, 5, 0x0000, 0, 0),
MX6_PAD_CSI_DATA05__WEIM_DATA_18 = IOMUX_PAD(0x03A8, 0x0060, 6, 0x0000, 0, 0),
MX6_PAD_CSI_DATA05__PWM6_OUT = IOMUX_PAD(0x03A8, 0x0060, 7, 0x0000, 0, 0),
MX6_PAD_CSI_DATA05__VADC_DATA_9 = IOMUX_PAD(0x03A8, 0x0060, 8, 0x0000, 0, 0),
MX6_PAD_CSI_DATA05__MMDC_DEBUG_42 = IOMUX_PAD(0x03A8, 0x0060, 9, 0x0000, 0, 0),
MX6_PAD_CSI_DATA06__CSI1_DATA_8 = IOMUX_PAD(0x03AC, 0x0064, 0, 0x06C0, 0, 0),
MX6_PAD_CSI_DATA06__ESAI_TX2_RX3 = IOMUX_PAD(0x03AC, 0x0064, 1, 0x0798, 1, 0),
MX6_PAD_CSI_DATA06__I2C4_SCL = IOMUX_PAD(0x03AC, 0x0064, 2, 0x07C0, 2, 0),
MX6_PAD_CSI_DATA06__KPP_COL_7 = IOMUX_PAD(0x03AC, 0x0064, 3, 0x07D0, 0, 0),
MX6_PAD_CSI_DATA06__UART6_RTS_B = IOMUX_PAD(0x03AC, 0x0064, 4, 0x0854, 0, 0),
MX6_PAD_CSI_DATA06__GPIO1_IO_20 = IOMUX_PAD(0x03AC, 0x0064, 5, 0x0000, 0, 0),
MX6_PAD_CSI_DATA06__WEIM_DATA_17 = IOMUX_PAD(0x03AC, 0x0064, 6, 0x0000, 0, 0),
MX6_PAD_CSI_DATA06__DCIC2_OUT = IOMUX_PAD(0x03AC, 0x0064, 7, 0x0000, 0, 0),
MX6_PAD_CSI_DATA06__VADC_DATA_10 = IOMUX_PAD(0x03AC, 0x0064, 8, 0x0000, 0, 0),
MX6_PAD_CSI_DATA06__MMDC_DEBUG_43 = IOMUX_PAD(0x03AC, 0x0064, 9, 0x0000, 0, 0),
MX6_PAD_CSI_DATA07__CSI1_DATA_9 = IOMUX_PAD(0x03B0, 0x0068, 0, 0x06C4, 0, 0),
MX6_PAD_CSI_DATA07__ESAI_TX3_RX2 = IOMUX_PAD(0x03B0, 0x0068, 1, 0x079C, 1, 0),
MX6_PAD_CSI_DATA07__I2C4_SDA = IOMUX_PAD(0x03B0, 0x0068, 2, 0x07C4, 2, 0),
MX6_PAD_CSI_DATA07__KPP_ROW_7 = IOMUX_PAD(0x03B0, 0x0068, 3, 0x07DC, 0, 0),
MX6_PAD_CSI_DATA07__UART6_CTS_B = IOMUX_PAD(0x03B0, 0x0068, 4, 0x0854, 1, 0),
MX6_PAD_CSI_DATA07__GPIO1_IO_21 = IOMUX_PAD(0x03B0, 0x0068, 5, 0x0000, 0, 0),
MX6_PAD_CSI_DATA07__WEIM_DATA_16 = IOMUX_PAD(0x03B0, 0x0068, 6, 0x0000, 0, 0),
MX6_PAD_CSI_DATA07__DCIC1_OUT = IOMUX_PAD(0x03B0, 0x0068, 7, 0x0000, 0, 0),
MX6_PAD_CSI_DATA07__VADC_DATA_11 = IOMUX_PAD(0x03B0, 0x0068, 8, 0x0000, 0, 0),
MX6_PAD_CSI_DATA07__MMDC_DEBUG_44 = IOMUX_PAD(0x03B0, 0x0068, 9, 0x0000, 0, 0),
MX6_PAD_CSI_HSYNC__CSI1_HSYNC = IOMUX_PAD(0x03B4, 0x006C, 0, 0x0700, 0, 0),
MX6_PAD_CSI_HSYNC__ESAI_TX0 = IOMUX_PAD(0x03B4, 0x006C, 1, 0x0790, 1, 0),
MX6_PAD_CSI_HSYNC__AUDMUX_AUD6_TXD = IOMUX_PAD(0x03B4, 0x006C, 2, 0x0678, 1, 0),
MX6_PAD_CSI_HSYNC__UART4_RTS_B = IOMUX_PAD(0x03B4, 0x006C, 3, 0x0844, 2, 0),
MX6_PAD_CSI_HSYNC__MQS_LEFT = IOMUX_PAD(0x03B4, 0x006C, 4, 0x0000, 0, 0),
MX6_PAD_CSI_HSYNC__GPIO1_IO_22 = IOMUX_PAD(0x03B4, 0x006C, 5, 0x0000, 0, 0),
MX6_PAD_CSI_HSYNC__WEIM_DATA_25 = IOMUX_PAD(0x03B4, 0x006C, 6, 0x0000, 0, 0),
MX6_PAD_CSI_HSYNC__SAI1_TX_DATA_0 = IOMUX_PAD(0x03B4, 0x006C, 7, 0x0000, 0, 0),
MX6_PAD_CSI_HSYNC__VADC_DATA_2 = IOMUX_PAD(0x03B4, 0x006C, 8, 0x0000, 0, 0),
MX6_PAD_CSI_HSYNC__MMDC_DEBUG_35 = IOMUX_PAD(0x03B4, 0x006C, 9, 0x0000, 0, 0),
MX6_PAD_CSI_MCLK__CSI1_MCLK = IOMUX_PAD(0x03B8, 0x0070, 0, 0x0000, 0, 0),
MX6_PAD_CSI_MCLK__ESAI_TX_HF_CLK = IOMUX_PAD(0x03B8, 0x0070, 1, 0x0784, 1, 0),
MX6_PAD_CSI_MCLK__OSC32K_32K_OUT = IOMUX_PAD(0x03B8, 0x0070, 2, 0x0000, 0, 0),
MX6_PAD_CSI_MCLK__UART4_RX = IOMUX_PAD(0x03B8, 0x0070, 3, 0x0848, 2, 0),
MX6_PAD_CSI_MCLK__ANATOP_32K_OUT = IOMUX_PAD(0x03B8, 0x0070, 4, 0x0000, 0, 0),
MX6_PAD_CSI_MCLK__GPIO1_IO_23 = IOMUX_PAD(0x03B8, 0x0070, 5, 0x0000, 0, 0),
MX6_PAD_CSI_MCLK__WEIM_DATA_26 = IOMUX_PAD(0x03B8, 0x0070, 6, 0x0000, 0, 0),
MX6_PAD_CSI_MCLK__CSI1_FIELD = IOMUX_PAD(0x03B8, 0x0070, 7, 0x070C, 0, 0),
MX6_PAD_CSI_MCLK__VADC_DATA_1 = IOMUX_PAD(0x03B8, 0x0070, 8, 0x0000, 0, 0),
MX6_PAD_CSI_MCLK__MMDC_DEBUG_34 = IOMUX_PAD(0x03B8, 0x0070, 9, 0x0000, 0, 0),
MX6_PAD_CSI_PIXCLK__CSI1_PIXCLK = IOMUX_PAD(0x03BC, 0x0074, 0, 0x0704, 0, 0),
MX6_PAD_CSI_PIXCLK__ESAI_RX_HF_CLK = IOMUX_PAD(0x03BC, 0x0074, 1, 0x0780, 1, 0),
MX6_PAD_CSI_PIXCLK__AUDMUX_MCLK = IOMUX_PAD(0x03BC, 0x0074, 2, 0x0000, 0, 0),
MX6_PAD_CSI_PIXCLK__UART4_TX = IOMUX_PAD(0x03BC, 0x0074, 3, 0x0848, 3, 0),
MX6_PAD_CSI_PIXCLK__ANATOP_24M_OUT = IOMUX_PAD(0x03BC, 0x0074, 4, 0x0000, 0, 0),
MX6_PAD_CSI_PIXCLK__GPIO1_IO_24 = IOMUX_PAD(0x03BC, 0x0074, 5, 0x0000, 0, 0),
MX6_PAD_CSI_PIXCLK__WEIM_DATA_27 = IOMUX_PAD(0x03BC, 0x0074, 6, 0x0000, 0, 0),
MX6_PAD_CSI_PIXCLK__ESAI_TX_HF_CLK = IOMUX_PAD(0x03BC, 0x0074, 7, 0x0784, 2, 0),
MX6_PAD_CSI_PIXCLK__VADC_CLK = IOMUX_PAD(0x03BC, 0x0074, 8, 0x0000, 0, 0),
MX6_PAD_CSI_PIXCLK__MMDC_DEBUG_33 = IOMUX_PAD(0x03BC, 0x0074, 9, 0x0000, 0, 0),
MX6_PAD_CSI_VSYNC__CSI1_VSYNC = IOMUX_PAD(0x03C0, 0x0078, 0, 0x0708, 0, 0),
MX6_PAD_CSI_VSYNC__ESAI_TX5_RX0 = IOMUX_PAD(0x03C0, 0x0078, 1, 0x07A4, 1, 0),
MX6_PAD_CSI_VSYNC__AUDMUX_AUD6_RXD = IOMUX_PAD(0x03C0, 0x0078, 2, 0x0674, 1, 0),
MX6_PAD_CSI_VSYNC__UART4_CTS_B = IOMUX_PAD(0x03C0, 0x0078, 3, 0x0844, 3, 0),
MX6_PAD_CSI_VSYNC__MQS_RIGHT = IOMUX_PAD(0x03C0, 0x0078, 4, 0x0000, 0, 0),
MX6_PAD_CSI_VSYNC__GPIO1_IO_25 = IOMUX_PAD(0x03C0, 0x0078, 5, 0x0000, 0, 0),
MX6_PAD_CSI_VSYNC__WEIM_DATA_24 = IOMUX_PAD(0x03C0, 0x0078, 6, 0x0000, 0, 0),
MX6_PAD_CSI_VSYNC__SAI1_RX_DATA_0 = IOMUX_PAD(0x03C0, 0x0078, 7, 0x07F8, 0, 0),
MX6_PAD_CSI_VSYNC__VADC_DATA_3 = IOMUX_PAD(0x03C0, 0x0078, 8, 0x0000, 0, 0),
MX6_PAD_CSI_VSYNC__MMDC_DEBUG_36 = IOMUX_PAD(0x03C0, 0x0078, 9, 0x0000, 0, 0),
MX6_PAD_ENET1_COL__ENET1_COL = IOMUX_PAD(0x03C4, 0x007C, 0, 0x0000, 0, 0),
MX6_PAD_ENET1_COL__ENET2_MDC = IOMUX_PAD(0x03C4, 0x007C, 1, 0x0000, 0, 0),
MX6_PAD_ENET1_COL__AUDMUX_AUD4_TXC = IOMUX_PAD(0x03C4, 0x007C, 2, 0x0654, 1, 0),
MX6_PAD_ENET1_COL__UART1_RI_B = IOMUX_PAD(0x03C4, 0x007C, 3, 0x0000, 0, 0),
MX6_PAD_ENET1_COL__SPDIF_EXT_CLK = IOMUX_PAD(0x03C4, 0x007C, 4, 0x0828, 1, 0),
MX6_PAD_ENET1_COL__GPIO2_IO_0 = IOMUX_PAD(0x03C4, 0x007C, 5, 0x0000, 0, 0),
MX6_PAD_ENET1_COL__CSI2_DATA_23 = IOMUX_PAD(0x03C4, 0x007C, 6, 0x0000, 0, 0),
MX6_PAD_ENET1_COL__LCDIF2_DATA_16 = IOMUX_PAD(0x03C4, 0x007C, 7, 0x0000, 0, 0),
MX6_PAD_ENET1_COL__VDEC_DEBUG_37 = IOMUX_PAD(0x03C4, 0x007C, 8, 0x0000, 0, 0),
MX6_PAD_ENET1_COL__PCIE_CTRL_DEBUG_31 = IOMUX_PAD(0x03C4, 0x007C, 9, 0x0000, 0, 0),
MX6_PAD_ENET1_CRS__ENET1_CRS = IOMUX_PAD(0x03C8, 0x0080, 0, 0x0000, 0, 0),
MX6_PAD_ENET1_CRS__ENET2_MDIO = IOMUX_PAD(0x03C8, 0x0080, 1, 0x0770, 1, 0),
MX6_PAD_ENET1_CRS__AUDMUX_AUD4_TXD = IOMUX_PAD(0x03C8, 0x0080, 2, 0x0648, 1, 0),
MX6_PAD_ENET1_CRS__UART1_DCD_B = IOMUX_PAD(0x03C8, 0x0080, 3, 0x0000, 0, 0),
MX6_PAD_ENET1_CRS__SPDIF_LOCK = IOMUX_PAD(0x03C8, 0x0080, 4, 0x0000, 0, 0),
MX6_PAD_ENET1_CRS__GPIO2_IO_1 = IOMUX_PAD(0x03C8, 0x0080, 5, 0x0000, 0, 0),
MX6_PAD_ENET1_CRS__CSI2_DATA_22 = IOMUX_PAD(0x03C8, 0x0080, 6, 0x0000, 0, 0),
MX6_PAD_ENET1_CRS__LCDIF2_DATA_17 = IOMUX_PAD(0x03C8, 0x0080, 7, 0x0000, 0, 0),
MX6_PAD_ENET1_CRS__VDEC_DEBUG_36 = IOMUX_PAD(0x03C8, 0x0080, 8, 0x0000, 0, 0),
MX6_PAD_ENET1_CRS__PCIE_CTRL_DEBUG_30 = IOMUX_PAD(0x03C8, 0x0080, 9, 0x0000, 0, 0),
MX6_PAD_ENET1_MDC__ENET1_MDC = IOMUX_PAD(0x03CC, 0x0084, 0, 0x0000, 0, 0),
MX6_PAD_ENET1_MDC__ENET2_MDC = IOMUX_PAD(0x03CC, 0x0084, 1, 0x0000, 0, 0),
MX6_PAD_ENET1_MDC__AUDMUX_AUD3_RXFS = IOMUX_PAD(0x03CC, 0x0084, 2, 0x0638, 1, 0),
MX6_PAD_ENET1_MDC__ANATOP_24M_OUT = IOMUX_PAD(0x03CC, 0x0084, 3, 0x0000, 0, 0),
MX6_PAD_ENET1_MDC__EPIT2_OUT = IOMUX_PAD(0x03CC, 0x0084, 4, 0x0000, 0, 0),
MX6_PAD_ENET1_MDC__GPIO2_IO_2 = IOMUX_PAD(0x03CC, 0x0084, 5, 0x0000, 0, 0),
MX6_PAD_ENET1_MDC__USB_OTG1_PWR = IOMUX_PAD(0x03CC, 0x0084, 6, 0x0000, 0, 0),
MX6_PAD_ENET1_MDC__PWM7_OUT = IOMUX_PAD(0x03CC, 0x0084, 7, 0x0000, 0, 0),
MX6_PAD_ENET1_MDIO__ENET1_MDIO = IOMUX_PAD(0x03D0, 0x0088, 0, 0x0764, 1, 0),
MX6_PAD_ENET1_MDIO__ENET2_MDIO = IOMUX_PAD(0x03D0, 0x0088, 1, 0x0770, 2, 0),
MX6_PAD_ENET1_MDIO__AUDMUX_MCLK = IOMUX_PAD(0x03D0, 0x0088, 2, 0x0000, 0, 0),
MX6_PAD_ENET1_MDIO__OSC32K_32K_OUT = IOMUX_PAD(0x03D0, 0x0088, 3, 0x0000, 0, 0),
MX6_PAD_ENET1_MDIO__EPIT1_OUT = IOMUX_PAD(0x03D0, 0x0088, 4, 0x0000, 0, 0),
MX6_PAD_ENET1_MDIO__GPIO2_IO_3 = IOMUX_PAD(0x03D0, 0x0088, 5, 0x0000, 0, 0),
MX6_PAD_ENET1_MDIO__USB_OTG1_OC = IOMUX_PAD(0x03D0, 0x0088, 6, 0x0860, 1, 0),
MX6_PAD_ENET1_MDIO__PWM8_OUT = IOMUX_PAD(0x03D0, 0x0088, 7, 0x0000, 0, 0),
MX6_PAD_ENET1_RX_CLK__ENET1_RX_CLK = IOMUX_PAD(0x03D4, 0x008C, 0, 0x0768, 0, 0),
MX6_PAD_ENET1_RX_CLK__ENET1_REF_CLK_25M = IOMUX_PAD(0x03D4, 0x008C, 1, 0x0000, 0, 0),
MX6_PAD_ENET1_RX_CLK__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x03D4, 0x008C, 2, 0x0658, 1, 0),
MX6_PAD_ENET1_RX_CLK__UART1_DSR_B = IOMUX_PAD(0x03D4, 0x008C, 3, 0x0000, 0, 0),
MX6_PAD_ENET1_RX_CLK__SPDIF_OUT = IOMUX_PAD(0x03D4, 0x008C, 4, 0x0000, 0, 0),
MX6_PAD_ENET1_RX_CLK__GPIO2_IO_4 = IOMUX_PAD(0x03D4, 0x008C, 5, 0x0000, 0, 0),
MX6_PAD_ENET1_RX_CLK__CSI2_DATA_21 = IOMUX_PAD(0x03D4, 0x008C, 6, 0x0000, 0, 0),
MX6_PAD_ENET1_RX_CLK__LCDIF2_DATA_18 = IOMUX_PAD(0x03D4, 0x008C, 7, 0x0000, 0, 0),
MX6_PAD_ENET1_RX_CLK__VDEC_DEBUG_35 = IOMUX_PAD(0x03D4, 0x008C, 8, 0x0000, 0, 0),
MX6_PAD_ENET1_RX_CLK__PCIE_CTRL_DEBUG_29 = IOMUX_PAD(0x03D4, 0x008C, 9, 0x0000, 0, 0),
MX6_PAD_ENET1_TX_CLK__ENET1_TX_CLK = IOMUX_PAD(0x03D8, 0x0090, 0, 0x0000, 0, 0),
MX6_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 = IOMUX_PAD(0x03D8, 0x0090, 1, 0x0760, 1, 0),
MX6_PAD_ENET1_TX_CLK__AUDMUX_AUD4_RXD = IOMUX_PAD(0x03D8, 0x0090, 2, 0x0644, 1, 0),
MX6_PAD_ENET1_TX_CLK__UART1_DTR_B = IOMUX_PAD(0x03D8, 0x0090, 3, 0x0000, 0, 0),
MX6_PAD_ENET1_TX_CLK__SPDIF_SR_CLK = IOMUX_PAD(0x03D8, 0x0090, 4, 0x0000, 0, 0),
MX6_PAD_ENET1_TX_CLK__GPIO2_IO_5 = IOMUX_PAD(0x03D8, 0x0090, 5, 0x0000, 0, 0),
MX6_PAD_ENET1_TX_CLK__CSI2_DATA_20 = IOMUX_PAD(0x03D8, 0x0090, 6, 0x0000, 0, 0),
MX6_PAD_ENET1_TX_CLK__LCDIF2_DATA_19 = IOMUX_PAD(0x03D8, 0x0090, 7, 0x0000, 0, 0),
MX6_PAD_ENET1_TX_CLK__VDEC_DEBUG_34 = IOMUX_PAD(0x03D8, 0x0090, 8, 0x0000, 0, 0),
MX6_PAD_ENET1_TX_CLK__PCIE_CTRL_DEBUG_28 = IOMUX_PAD(0x03D8, 0x0090, 9, 0x0000, 0, 0),
MX6_PAD_ENET2_COL__ENET2_COL = IOMUX_PAD(0x03DC, 0x0094, 0, 0x0000, 0, 0),
MX6_PAD_ENET2_COL__ENET1_MDC = IOMUX_PAD(0x03DC, 0x0094, 1, 0x0000, 0, 0),
MX6_PAD_ENET2_COL__AUDMUX_AUD4_RXC = IOMUX_PAD(0x03DC, 0x0094, 2, 0x064C, 1, 0),
MX6_PAD_ENET2_COL__UART1_RX = IOMUX_PAD(0x03DC, 0x0094, 3, 0x0830, 2, 0),
MX6_PAD_ENET2_COL__SPDIF_IN = IOMUX_PAD(0x03DC, 0x0094, 4, 0x0824, 3, 0),
MX6_PAD_ENET2_COL__GPIO2_IO_6 = IOMUX_PAD(0x03DC, 0x0094, 5, 0x0000, 0, 0),
MX6_PAD_ENET2_COL__ANATOP_OTG1_ID = IOMUX_PAD(0x03DC, 0x0094, 6, 0x0624, 1, 0),
MX6_PAD_ENET2_COL__LCDIF2_DATA_20 = IOMUX_PAD(0x03DC, 0x0094, 7, 0x0000, 0, 0),
MX6_PAD_ENET2_COL__VDEC_DEBUG_33 = IOMUX_PAD(0x03DC, 0x0094, 8, 0x0000, 0, 0),
MX6_PAD_ENET2_COL__PCIE_CTRL_DEBUG_27 = IOMUX_PAD(0x03DC, 0x0094, 9, 0x0000, 0, 0),
MX6_PAD_ENET2_CRS__ENET2_CRS = IOMUX_PAD(0x03E0, 0x0098, 0, 0x0000, 0, 0),
MX6_PAD_ENET2_CRS__ENET1_MDIO = IOMUX_PAD(0x03E0, 0x0098, 1, 0x0764, 2, 0),
MX6_PAD_ENET2_CRS__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x03E0, 0x0098, 2, 0x0650, 1, 0),
MX6_PAD_ENET2_CRS__UART1_TX = IOMUX_PAD(0x03E0, 0x0098, 3, 0x0830, 3, 0),
MX6_PAD_ENET2_CRS__MLB_SIG = IOMUX_PAD(0x03E0, 0x0098, 4, 0x07F0, 1, 0),
MX6_PAD_ENET2_CRS__GPIO2_IO_7 = IOMUX_PAD(0x03E0, 0x0098, 5, 0x0000, 0, 0),
MX6_PAD_ENET2_CRS__ANATOP_OTG2_ID = IOMUX_PAD(0x03E0, 0x0098, 6, 0x0628, 1, 0),
MX6_PAD_ENET2_CRS__LCDIF2_DATA_21 = IOMUX_PAD(0x03E0, 0x0098, 7, 0x0000, 0, 0),
MX6_PAD_ENET2_CRS__VDEC_DEBUG_32 = IOMUX_PAD(0x03E0, 0x0098, 8, 0x0000, 0, 0),
MX6_PAD_ENET2_CRS__PCIE_CTRL_DEBUG_26 = IOMUX_PAD(0x03E0, 0x0098, 9, 0x0000, 0, 0),
MX6_PAD_ENET2_RX_CLK__ENET2_RX_CLK = IOMUX_PAD(0x03E4, 0x009C, 0, 0x0774, 0, 0),
MX6_PAD_ENET2_RX_CLK__ENET2_REF_CLK_25M = IOMUX_PAD(0x03E4, 0x009C, 1, 0x0000, 0, 0),
MX6_PAD_ENET2_RX_CLK__I2C3_SCL = IOMUX_PAD(0x03E4, 0x009C, 2, 0x07B8, 1, 0),
MX6_PAD_ENET2_RX_CLK__UART1_RTS_B = IOMUX_PAD(0x03E4, 0x009C, 3, 0x082C, 2, 0),
MX6_PAD_ENET2_RX_CLK__MLB_DATA = IOMUX_PAD(0x03E4, 0x009C, 4, 0x07EC, 1, 0),
MX6_PAD_ENET2_RX_CLK__GPIO2_IO_8 = IOMUX_PAD(0x03E4, 0x009C, 5, 0x0000, 0, 0),
MX6_PAD_ENET2_RX_CLK__USB_OTG2_OC = IOMUX_PAD(0x03E4, 0x009C, 6, 0x085C, 1, 0),
MX6_PAD_ENET2_RX_CLK__LCDIF2_DATA_22 = IOMUX_PAD(0x03E4, 0x009C, 7, 0x0000, 0, 0),
MX6_PAD_ENET2_RX_CLK__VDEC_DEBUG_31 = IOMUX_PAD(0x03E4, 0x009C, 8, 0x0000, 0, 0),
MX6_PAD_ENET2_RX_CLK__PCIE_CTRL_DEBUG_25 = IOMUX_PAD(0x03E4, 0x009C, 9, 0x0000, 0, 0),
MX6_PAD_ENET2_TX_CLK__ENET2_TX_CLK = IOMUX_PAD(0x03E8, 0x00A0, 0, 0x0000, 0, 0),
MX6_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 = IOMUX_PAD(0x03E8, 0x00A0, 1, 0x076C, 1, 0),
MX6_PAD_ENET2_TX_CLK__I2C3_SDA = IOMUX_PAD(0x03E8, 0x00A0, 2, 0x07BC, 1, 0),
MX6_PAD_ENET2_TX_CLK__UART1_CTS_B = IOMUX_PAD(0x03E8, 0x00A0, 3, 0x082C, 3, 0),
MX6_PAD_ENET2_TX_CLK__MLB_CLK = IOMUX_PAD(0x03E8, 0x00A0, 4, 0x07E8, 1, 0),
MX6_PAD_ENET2_TX_CLK__GPIO2_IO_9 = IOMUX_PAD(0x03E8, 0x00A0, 5, 0x0000, 0, 0),
MX6_PAD_ENET2_TX_CLK__USB_OTG2_PWR = IOMUX_PAD(0x03E8, 0x00A0, 6, 0x0000, 0, 0),
MX6_PAD_ENET2_TX_CLK__LCDIF2_DATA_23 = IOMUX_PAD(0x03E8, 0x00A0, 7, 0x0000, 0, 0),
MX6_PAD_ENET2_TX_CLK__VDEC_DEBUG_30 = IOMUX_PAD(0x03E8, 0x00A0, 8, 0x0000, 0, 0),
MX6_PAD_ENET2_TX_CLK__PCIE_CTRL_DEBUG_24 = IOMUX_PAD(0x03E8, 0x00A0, 9, 0x0000, 0, 0),
MX6_PAD_KEY_COL0__KPP_COL_0 = IOMUX_PAD(0x03EC, 0x00A4, 0, 0x0000, 0, 0),
MX6_PAD_KEY_COL0__USDHC3_CD_B = IOMUX_PAD(0x03EC, 0x00A4, 1, 0x0000, 0, 0),
MX6_PAD_KEY_COL0__UART6_RTS_B = IOMUX_PAD(0x03EC, 0x00A4, 2, 0x0854, 2, 0),
MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x03EC, 0x00A4, 3, 0x0710, 0, 0),
MX6_PAD_KEY_COL0__AUDMUX_AUD5_TXC = IOMUX_PAD(0x03EC, 0x00A4, 4, 0x066C, 0, 0),
MX6_PAD_KEY_COL0__GPIO2_IO_10 = IOMUX_PAD(0x03EC, 0x00A4, 5, 0x0000, 0, 0),
MX6_PAD_KEY_COL0__SDMA_EXT_EVENT_1 = IOMUX_PAD(0x03EC, 0x00A4, 6, 0x0820, 1, 0),
MX6_PAD_KEY_COL0__SAI2_TX_BCLK = IOMUX_PAD(0x03EC, 0x00A4, 7, 0x0814, 0, 0),
MX6_PAD_KEY_COL0__VADC_DATA_0 = IOMUX_PAD(0x03EC, 0x00A4, 8, 0x0000, 0, 0),
MX6_PAD_KEY_COL1__KPP_COL_1 = IOMUX_PAD(0x03F0, 0x00A8, 0, 0x0000, 0, 0),
MX6_PAD_KEY_COL1__USDHC3_RESET_B = IOMUX_PAD(0x03F0, 0x00A8, 1, 0x0000, 0, 0),
MX6_PAD_KEY_COL1__UART6_TX = IOMUX_PAD(0x03F0, 0x00A8, 2, 0x0858, 2, 0),
MX6_PAD_KEY_COL1__ECSPI1_MISO = IOMUX_PAD(0x03F0, 0x00A8, 3, 0x0714, 0, 0),
MX6_PAD_KEY_COL1__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x03F0, 0x00A8, 4, 0x0670, 0, 0),
MX6_PAD_KEY_COL1__GPIO2_IO_11 = IOMUX_PAD(0x03F0, 0x00A8, 5, 0x0000, 0, 0),
MX6_PAD_KEY_COL1__USDHC3_RESET = IOMUX_PAD(0x03F0, 0x00A8, 6, 0x0000, 0, 0),
MX6_PAD_KEY_COL1__SAI2_TX_SYNC = IOMUX_PAD(0x03F0, 0x00A8, 7, 0x0818, 0, 0),
MX6_PAD_KEY_COL2__KPP_COL_2 = IOMUX_PAD(0x03F4, 0x00AC, 0, 0x0000, 0, 0),
MX6_PAD_KEY_COL2__USDHC4_CD_B = IOMUX_PAD(0x03F4, 0x00AC, 1, 0x0874, 1, 0),
MX6_PAD_KEY_COL2__UART5_RTS_B = IOMUX_PAD(0x03F4, 0x00AC, 2, 0x084C, 2, 0),
MX6_PAD_KEY_COL2__CAN1_TX = IOMUX_PAD(0x03F4, 0x00AC, 3, 0x0000, 0, 0),
MX6_PAD_KEY_COL2__CANFD_TX1 = IOMUX_PAD(0x03F4, 0x00AC, 4, 0x0000, 0, 0),
MX6_PAD_KEY_COL2__GPIO2_IO_12 = IOMUX_PAD(0x03F4, 0x00AC, 5, 0x0000, 0, 0),
MX6_PAD_KEY_COL2__WEIM_DATA_30 = IOMUX_PAD(0x03F4, 0x00AC, 6, 0x0000, 0, 0),
MX6_PAD_KEY_COL2__ECSPI1_RDY = IOMUX_PAD(0x03F4, 0x00AC, 7, 0x0000, 0, 0),
MX6_PAD_KEY_COL3__KPP_COL_3 = IOMUX_PAD(0x03F8, 0x00B0, 0, 0x0000, 0, 0),
MX6_PAD_KEY_COL3__USDHC4_LCTL = IOMUX_PAD(0x03F8, 0x00B0, 1, 0x0000, 0, 0),
MX6_PAD_KEY_COL3__UART5_TX = IOMUX_PAD(0x03F8, 0x00B0, 2, 0x0850, 2, 0),
MX6_PAD_KEY_COL3__CAN2_TX = IOMUX_PAD(0x03F8, 0x00B0, 3, 0x0000, 0, 0),
MX6_PAD_KEY_COL3__CANFD_TX2 = IOMUX_PAD(0x03F8, 0x00B0, 4, 0x0000, 0, 0),
MX6_PAD_KEY_COL3__GPIO2_IO_13 = IOMUX_PAD(0x03F8, 0x00B0, 5, 0x0000, 0, 0),
MX6_PAD_KEY_COL3__WEIM_DATA_28 = IOMUX_PAD(0x03F8, 0x00B0, 6, 0x0000, 0, 0),
MX6_PAD_KEY_COL3__ECSPI1_SS2 = IOMUX_PAD(0x03F8, 0x00B0, 7, 0x0000, 0, 0),
MX6_PAD_KEY_COL4__KPP_COL_4 = IOMUX_PAD(0x03FC, 0x00B4, 0, 0x0000, 0, 0),
MX6_PAD_KEY_COL4__ENET2_MDC = IOMUX_PAD(0x03FC, 0x00B4, 1, 0x0000, 0, 0),
MX6_PAD_KEY_COL4__I2C3_SCL = IOMUX_PAD(0x03FC, 0x00B4, 2, 0x07B8, 2, 0),
MX6_PAD_KEY_COL4__USDHC2_LCTL = IOMUX_PAD(0x03FC, 0x00B4, 3, 0x0000, 0, 0),
MX6_PAD_KEY_COL4__AUDMUX_AUD5_RXC = IOMUX_PAD(0x03FC, 0x00B4, 4, 0x0664, 0, 0),
MX6_PAD_KEY_COL4__GPIO2_IO_14 = IOMUX_PAD(0x03FC, 0x00B4, 5, 0x0000, 0, 0),
MX6_PAD_KEY_COL4__WEIM_CRE = IOMUX_PAD(0x03FC, 0x00B4, 6, 0x0000, 0, 0),
MX6_PAD_KEY_COL4__SAI2_RX_BCLK = IOMUX_PAD(0x03FC, 0x00B4, 7, 0x0808, 0, 0),
MX6_PAD_KEY_ROW0__KPP_ROW_0 = IOMUX_PAD(0x0400, 0x00B8, 0, 0x0000, 0, 0),
MX6_PAD_KEY_ROW0__USDHC3_WP = IOMUX_PAD(0x0400, 0x00B8, 1, 0x0000, 0, 0),
MX6_PAD_KEY_ROW0__UART6_CTS_B = IOMUX_PAD(0x0400, 0x00B8, 2, 0x0854, 3, 0),
MX6_PAD_KEY_ROW0__ECSPI1_MOSI = IOMUX_PAD(0x0400, 0x00B8, 3, 0x0718, 0, 0),
MX6_PAD_KEY_ROW0__AUDMUX_AUD5_TXD = IOMUX_PAD(0x0400, 0x00B8, 4, 0x0660, 0, 0),
MX6_PAD_KEY_ROW0__GPIO2_IO_15 = IOMUX_PAD(0x0400, 0x00B8, 5, 0x0000, 0, 0),
MX6_PAD_KEY_ROW0__SDMA_EXT_EVENT_0 = IOMUX_PAD(0x0400, 0x00B8, 6, 0x081C, 1, 0),
MX6_PAD_KEY_ROW0__SAI2_TX_DATA_0 = IOMUX_PAD(0x0400, 0x00B8, 7, 0x0000, 0, 0),
MX6_PAD_KEY_ROW0__GPU_IDLE = IOMUX_PAD(0x0400, 0x00B8, 8, 0x0000, 0, 0),
MX6_PAD_KEY_ROW1__KPP_ROW_1 = IOMUX_PAD(0x0404, 0x00BC, 0, 0x0000, 0, 0),
MX6_PAD_KEY_ROW1__USDHC4_VSELECT = IOMUX_PAD(0x0404, 0x00BC, 1, 0x0000, 0, 0),
MX6_PAD_KEY_ROW1__UART6_RX = IOMUX_PAD(0x0404, 0x00BC, 2, 0x0858, 3, 0),
MX6_PAD_KEY_ROW1__ECSPI1_SS0 = IOMUX_PAD(0x0404, 0x00BC, 3, 0x071C, 0, 0),
MX6_PAD_KEY_ROW1__AUDMUX_AUD5_RXD = IOMUX_PAD(0x0404, 0x00BC, 4, 0x065C, 0, 0),
MX6_PAD_KEY_ROW1__GPIO2_IO_16 = IOMUX_PAD(0x0404, 0x00BC, 5, 0x0000, 0, 0),
MX6_PAD_KEY_ROW1__WEIM_DATA_31 = IOMUX_PAD(0x0404, 0x00BC, 6, 0x0000, 0, 0),
MX6_PAD_KEY_ROW1__SAI2_RX_DATA_0 = IOMUX_PAD(0x0404, 0x00BC, 7, 0x080C, 0, 0),
MX6_PAD_KEY_ROW1__M4_NMI = IOMUX_PAD(0x0404, 0x00BC, 8, 0x0000, 0, 0),
MX6_PAD_KEY_ROW2__KPP_ROW_2 = IOMUX_PAD(0x0408, 0x00C0, 0, 0x0000, 0, 0),
MX6_PAD_KEY_ROW2__USDHC4_WP = IOMUX_PAD(0x0408, 0x00C0, 1, 0x0878, 1, 0),
MX6_PAD_KEY_ROW2__UART5_CTS_B = IOMUX_PAD(0x0408, 0x00C0, 2, 0x084C, 3, 0),
MX6_PAD_KEY_ROW2__CAN1_RX = IOMUX_PAD(0x0408, 0x00C0, 3, 0x068C, 1, 0),
MX6_PAD_KEY_ROW2__CANFD_RX1 = IOMUX_PAD(0x0408, 0x00C0, 4, 0x0694, 1, 0),
MX6_PAD_KEY_ROW2__GPIO2_IO_17 = IOMUX_PAD(0x0408, 0x00C0, 5, 0x0000, 0, 0),
MX6_PAD_KEY_ROW2__WEIM_DATA_29 = IOMUX_PAD(0x0408, 0x00C0, 6, 0x0000, 0, 0),
MX6_PAD_KEY_ROW2__ECSPI1_SS3 = IOMUX_PAD(0x0408, 0x00C0, 7, 0x0000, 0, 0),
MX6_PAD_KEY_ROW3__KPP_ROW_3 = IOMUX_PAD(0x040C, 0x00C4, 0, 0x0000, 0, 0),
MX6_PAD_KEY_ROW3__USDHC3_LCTL = IOMUX_PAD(0x040C, 0x00C4, 1, 0x0000, 0, 0),
MX6_PAD_KEY_ROW3__UART5_RX = IOMUX_PAD(0x040C, 0x00C4, 2, 0x0850, 3, 0),
MX6_PAD_KEY_ROW3__CAN2_RX = IOMUX_PAD(0x040C, 0x00C4, 3, 0x0690, 1, 0),
MX6_PAD_KEY_ROW3__CANFD_RX2 = IOMUX_PAD(0x040C, 0x00C4, 4, 0x0698, 1, 0),
MX6_PAD_KEY_ROW3__GPIO2_IO_18 = IOMUX_PAD(0x040C, 0x00C4, 5, 0x0000, 0, 0),
MX6_PAD_KEY_ROW3__WEIM_DTACK_B = IOMUX_PAD(0x040C, 0x00C4, 6, 0x0000, 0, 0),
MX6_PAD_KEY_ROW3__ECSPI1_SS1 = IOMUX_PAD(0x040C, 0x00C4, 7, 0x0000, 0, 0),
MX6_PAD_KEY_ROW4__KPP_ROW_4 = IOMUX_PAD(0x0410, 0x00C8, 0, 0x0000, 0, 0),
MX6_PAD_KEY_ROW4__ENET2_MDIO = IOMUX_PAD(0x0410, 0x00C8, 1, 0x0770, 3, 0),
MX6_PAD_KEY_ROW4__I2C3_SDA = IOMUX_PAD(0x0410, 0x00C8, 2, 0x07BC, 2, 0),
MX6_PAD_KEY_ROW4__USDHC1_LCTL = IOMUX_PAD(0x0410, 0x00C8, 3, 0x0000, 0, 0),
MX6_PAD_KEY_ROW4__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x0410, 0x00C8, 4, 0x0668, 0, 0),
MX6_PAD_KEY_ROW4__GPIO2_IO_19 = IOMUX_PAD(0x0410, 0x00C8, 5, 0x0000, 0, 0),
MX6_PAD_KEY_ROW4__WEIM_ACLK_FREERUN = IOMUX_PAD(0x0410, 0x00C8, 6, 0x0000, 0, 0),
MX6_PAD_KEY_ROW4__SAI2_RX_SYNC = IOMUX_PAD(0x0410, 0x00C8, 7, 0x0810, 0, 0),
MX6_PAD_LCD1_CLK__LCDIF1_CLK = IOMUX_PAD(0x0414, 0x00CC, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_CLK__LCDIF1_WR_RWN = IOMUX_PAD(0x0414, 0x00CC, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_CLK__AUDMUX_AUD3_RXC = IOMUX_PAD(0x0414, 0x00CC, 2, 0x0634, 1, 0),
MX6_PAD_LCD1_CLK__ENET1_1588_EVENT2_IN = IOMUX_PAD(0x0414, 0x00CC, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_CLK__CSI1_DATA_16 = IOMUX_PAD(0x0414, 0x00CC, 4, 0x06DC, 0, 0),
MX6_PAD_LCD1_CLK__GPIO3_IO_0 = IOMUX_PAD(0x0414, 0x00CC, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_CLK__USDHC1_WP = IOMUX_PAD(0x0414, 0x00CC, 6, 0x0868, 0, 0),
MX6_PAD_LCD1_CLK__SIM_M_HADDR_16 = IOMUX_PAD(0x0414, 0x00CC, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_CLK__VADC_TEST_0 = IOMUX_PAD(0x0414, 0x00CC, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_CLK__MMDC_DEBUG_0 = IOMUX_PAD(0x0414, 0x00CC, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA00__LCDIF1_DATA_0 = IOMUX_PAD(0x0418, 0x00D0, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA00__WEIM_CS1_B = IOMUX_PAD(0x0418, 0x00D0, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA00__M4_TRACE_0 = IOMUX_PAD(0x0418, 0x00D0, 2, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA00__KITTEN_TRACE_0 = IOMUX_PAD(0x0418, 0x00D0, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA00__CSI1_DATA_20 = IOMUX_PAD(0x0418, 0x00D0, 4, 0x06EC, 0, 0),
MX6_PAD_LCD1_DATA00__GPIO3_IO_1 = IOMUX_PAD(0x0418, 0x00D0, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA00__SRC_BT_CFG_0 = IOMUX_PAD(0x0418, 0x00D0, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA00__SIM_M_HADDR_21 = IOMUX_PAD(0x0418, 0x00D0, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA00__VADC_TEST_5 = IOMUX_PAD(0x0418, 0x00D0, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA00__MMDC_DEBUG_5 = IOMUX_PAD(0x0418, 0x00D0, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA01__LCDIF1_DATA_1 = IOMUX_PAD(0x041C, 0x00D4, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA01__WEIM_CS2_B = IOMUX_PAD(0x041C, 0x00D4, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA01__M4_TRACE_1 = IOMUX_PAD(0x041C, 0x00D4, 2, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA01__KITTEN_TRACE_1 = IOMUX_PAD(0x041C, 0x00D4, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA01__CSI1_DATA_21 = IOMUX_PAD(0x041C, 0x00D4, 4, 0x06F0, 0, 0),
MX6_PAD_LCD1_DATA01__GPIO3_IO_2 = IOMUX_PAD(0x041C, 0x00D4, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA01__SRC_BT_CFG_1 = IOMUX_PAD(0x041C, 0x00D4, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA01__SIM_M_HADDR_22 = IOMUX_PAD(0x041C, 0x00D4, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA01__VADC_TEST_6 = IOMUX_PAD(0x041C, 0x00D4, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA01__MMDC_DEBUG_6 = IOMUX_PAD(0x041C, 0x00D4, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA02__LCDIF1_DATA_2 = IOMUX_PAD(0x0420, 0x00D8, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA02__WEIM_CS3_B = IOMUX_PAD(0x0420, 0x00D8, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA02__M4_TRACE_2 = IOMUX_PAD(0x0420, 0x00D8, 2, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA02__KITTEN_TRACE_2 = IOMUX_PAD(0x0420, 0x00D8, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA02__CSI1_DATA_22 = IOMUX_PAD(0x0420, 0x00D8, 4, 0x06F4, 0, 0),
MX6_PAD_LCD1_DATA02__GPIO3_IO_3 = IOMUX_PAD(0x0420, 0x00D8, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA02__SRC_BT_CFG_2 = IOMUX_PAD(0x0420, 0x00D8, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA02__SIM_M_HADDR_23 = IOMUX_PAD(0x0420, 0x00D8, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA02__VADC_TEST_7 = IOMUX_PAD(0x0420, 0x00D8, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA02__MMDC_DEBUG_7 = IOMUX_PAD(0x0420, 0x00D8, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA03__LCDIF1_DATA_3 = IOMUX_PAD(0x0424, 0x00DC, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA03__WEIM_ADDR_24 = IOMUX_PAD(0x0424, 0x00DC, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA03__M4_TRACE_3 = IOMUX_PAD(0x0424, 0x00DC, 2, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA03__KITTEN_TRACE_3 = IOMUX_PAD(0x0424, 0x00DC, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA03__CSI1_DATA_23 = IOMUX_PAD(0x0424, 0x00DC, 4, 0x06F8, 0, 0),
MX6_PAD_LCD1_DATA03__GPIO3_IO_4 = IOMUX_PAD(0x0424, 0x00DC, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA03__SRC_BT_CFG_3 = IOMUX_PAD(0x0424, 0x00DC, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA03__SIM_M_HADDR_24 = IOMUX_PAD(0x0424, 0x00DC, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA03__VADC_TEST_8 = IOMUX_PAD(0x0424, 0x00DC, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA03__MMDC_DEBUG_8 = IOMUX_PAD(0x0424, 0x00DC, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA04__LCDIF1_DATA_4 = IOMUX_PAD(0x0428, 0x00E0, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA04__WEIM_ADDR_25 = IOMUX_PAD(0x0428, 0x00E0, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA04__KITTEN_TRACE_4 = IOMUX_PAD(0x0428, 0x00E0, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA04__CSI1_VSYNC = IOMUX_PAD(0x0428, 0x00E0, 4, 0x0708, 1, 0),
MX6_PAD_LCD1_DATA04__GPIO3_IO_5 = IOMUX_PAD(0x0428, 0x00E0, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA04__SRC_BT_CFG_4 = IOMUX_PAD(0x0428, 0x00E0, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA04__SIM_M_HADDR_25 = IOMUX_PAD(0x0428, 0x00E0, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA04__VADC_TEST_9 = IOMUX_PAD(0x0428, 0x00E0, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA04__MMDC_DEBUG_9 = IOMUX_PAD(0x0428, 0x00E0, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA05__LCDIF1_DATA_5 = IOMUX_PAD(0x042C, 0x00E4, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA05__WEIM_ADDR_26 = IOMUX_PAD(0x042C, 0x00E4, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA05__KITTEN_TRACE_5 = IOMUX_PAD(0x042C, 0x00E4, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA05__CSI1_HSYNC = IOMUX_PAD(0x042C, 0x00E4, 4, 0x0700, 1, 0),
MX6_PAD_LCD1_DATA05__GPIO3_IO_6 = IOMUX_PAD(0x042C, 0x00E4, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA05__SRC_BT_CFG_5 = IOMUX_PAD(0x042C, 0x00E4, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA05__SIM_M_HADDR_26 = IOMUX_PAD(0x042C, 0x00E4, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA05__VADC_TEST_10 = IOMUX_PAD(0x042C, 0x00E4, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA05__MMDC_DEBUG_10 = IOMUX_PAD(0x042C, 0x00E4, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA06__LCDIF1_DATA_6 = IOMUX_PAD(0x0430, 0x00E8, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA06__WEIM_EB_B_2 = IOMUX_PAD(0x0430, 0x00E8, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA06__KITTEN_TRACE_6 = IOMUX_PAD(0x0430, 0x00E8, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA06__CSI1_PIXCLK = IOMUX_PAD(0x0430, 0x00E8, 4, 0x0704, 1, 0),
MX6_PAD_LCD1_DATA06__GPIO3_IO_7 = IOMUX_PAD(0x0430, 0x00E8, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA06__SRC_BT_CFG_6 = IOMUX_PAD(0x0430, 0x00E8, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA06__SIM_M_HADDR_27 = IOMUX_PAD(0x0430, 0x00E8, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA06__VADC_TEST_11 = IOMUX_PAD(0x0430, 0x00E8, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA06__MMDC_DEBUG_11 = IOMUX_PAD(0x0430, 0x00E8, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA07__LCDIF1_DATA_7 = IOMUX_PAD(0x0434, 0x00EC, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA07__WEIM_EB_B_3 = IOMUX_PAD(0x0434, 0x00EC, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA07__KITTEN_TRACE_7 = IOMUX_PAD(0x0434, 0x00EC, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA07__CSI1_MCLK = IOMUX_PAD(0x0434, 0x00EC, 4, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA07__GPIO3_IO_8 = IOMUX_PAD(0x0434, 0x00EC, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA07__SRC_BT_CFG_7 = IOMUX_PAD(0x0434, 0x00EC, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA07__SIM_M_HADDR_28 = IOMUX_PAD(0x0434, 0x00EC, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA07__VADC_TEST_12 = IOMUX_PAD(0x0434, 0x00EC, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA07__MMDC_DEBUG_12 = IOMUX_PAD(0x0434, 0x00EC, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA08__LCDIF1_DATA_8 = IOMUX_PAD(0x0438, 0x00F0, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA08__WEIM_AD_8 = IOMUX_PAD(0x0438, 0x00F0, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA08__KITTEN_TRACE_8 = IOMUX_PAD(0x0438, 0x00F0, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA08__CSI1_DATA_9 = IOMUX_PAD(0x0438, 0x00F0, 4, 0x06C4, 1, 0),
MX6_PAD_LCD1_DATA08__GPIO3_IO_9 = IOMUX_PAD(0x0438, 0x00F0, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA08__SRC_BT_CFG_8 = IOMUX_PAD(0x0438, 0x00F0, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA08__SIM_M_HADDR_29 = IOMUX_PAD(0x0438, 0x00F0, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA08__VADC_TEST_13 = IOMUX_PAD(0x0438, 0x00F0, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA08__MMDC_DEBUG_13 = IOMUX_PAD(0x0438, 0x00F0, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA09__LCDIF1_DATA_9 = IOMUX_PAD(0x043C, 0x00F4, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA09__WEIM_AD_9 = IOMUX_PAD(0x043C, 0x00F4, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA09__KITTEN_TRACE_9 = IOMUX_PAD(0x043C, 0x00F4, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA09__CSI1_DATA_8 = IOMUX_PAD(0x043C, 0x00F4, 4, 0x06C0, 1, 0),
MX6_PAD_LCD1_DATA09__GPIO3_IO_10 = IOMUX_PAD(0x043C, 0x00F4, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA09__SRC_BT_CFG_9 = IOMUX_PAD(0x043C, 0x00F4, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA09__SIM_M_HADDR_30 = IOMUX_PAD(0x043C, 0x00F4, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA09__VADC_TEST_14 = IOMUX_PAD(0x043C, 0x00F4, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA09__MMDC_DEBUG_14 = IOMUX_PAD(0x043C, 0x00F4, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA10__LCDIF1_DATA_10 = IOMUX_PAD(0x0440, 0x00F8, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA10__WEIM_AD_10 = IOMUX_PAD(0x0440, 0x00F8, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA10__KITTEN_TRACE_10 = IOMUX_PAD(0x0440, 0x00F8, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA10__CSI1_DATA_7 = IOMUX_PAD(0x0440, 0x00F8, 4, 0x06BC, 1, 0),
MX6_PAD_LCD1_DATA10__GPIO3_IO_11 = IOMUX_PAD(0x0440, 0x00F8, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA10__SRC_BT_CFG_10 = IOMUX_PAD(0x0440, 0x00F8, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA10__SIM_M_HADDR_31 = IOMUX_PAD(0x0440, 0x00F8, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA10__VADC_TEST_15 = IOMUX_PAD(0x0440, 0x00F8, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA10__MMDC_DEBUG_15 = IOMUX_PAD(0x0440, 0x00F8, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA11__LCDIF1_DATA_11 = IOMUX_PAD(0x0444, 0x00FC, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA11__WEIM_AD_11 = IOMUX_PAD(0x0444, 0x00FC, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA11__KITTEN_TRACE_11 = IOMUX_PAD(0x0444, 0x00FC, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA11__CSI1_DATA_6 = IOMUX_PAD(0x0444, 0x00FC, 4, 0x06B8, 1, 0),
MX6_PAD_LCD1_DATA11__GPIO3_IO_12 = IOMUX_PAD(0x0444, 0x00FC, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA11__SRC_BT_CFG_11 = IOMUX_PAD(0x0444, 0x00FC, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA11__SIM_M_HBURST_0 = IOMUX_PAD(0x0444, 0x00FC, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA11__VADC_TEST_16 = IOMUX_PAD(0x0444, 0x00FC, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA11__MMDC_DEBUG_16 = IOMUX_PAD(0x0444, 0x00FC, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA12__LCDIF1_DATA_12 = IOMUX_PAD(0x0448, 0x0100, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA12__WEIM_AD_12 = IOMUX_PAD(0x0448, 0x0100, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA12__KITTEN_TRACE_12 = IOMUX_PAD(0x0448, 0x0100, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA12__CSI1_DATA_5 = IOMUX_PAD(0x0448, 0x0100, 4, 0x06B4, 1, 0),
MX6_PAD_LCD1_DATA12__GPIO3_IO_13 = IOMUX_PAD(0x0448, 0x0100, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA12__SRC_BT_CFG_12 = IOMUX_PAD(0x0448, 0x0100, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA12__SIM_M_HBURST_1 = IOMUX_PAD(0x0448, 0x0100, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA12__VADC_TEST_17 = IOMUX_PAD(0x0448, 0x0100, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA12__MMDC_DEBUG_17 = IOMUX_PAD(0x0448, 0x0100, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA13__LCDIF1_DATA_13 = IOMUX_PAD(0x044C, 0x0104, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA13__WEIM_AD_13 = IOMUX_PAD(0x044C, 0x0104, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA13__KITTEN_TRACE_13 = IOMUX_PAD(0x044C, 0x0104, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA13__CSI1_DATA_4 = IOMUX_PAD(0x044C, 0x0104, 4, 0x06B0, 1, 0),
MX6_PAD_LCD1_DATA13__GPIO3_IO_14 = IOMUX_PAD(0x044C, 0x0104, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA13__SRC_BT_CFG_13 = IOMUX_PAD(0x044C, 0x0104, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA13__SIM_M_HBURST_2 = IOMUX_PAD(0x044C, 0x0104, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA13__VADC_TEST_18 = IOMUX_PAD(0x044C, 0x0104, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA13__MMDC_DEBUG_18 = IOMUX_PAD(0x044C, 0x0104, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA14__LCDIF1_DATA_14 = IOMUX_PAD(0x0450, 0x0108, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA14__WEIM_AD_14 = IOMUX_PAD(0x0450, 0x0108, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA14__KITTEN_TRACE_14 = IOMUX_PAD(0x0450, 0x0108, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA14__CSI1_DATA_3 = IOMUX_PAD(0x0450, 0x0108, 4, 0x06AC, 1, 0),
MX6_PAD_LCD1_DATA14__GPIO3_IO_15 = IOMUX_PAD(0x0450, 0x0108, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA14__SRC_BT_CFG_14 = IOMUX_PAD(0x0450, 0x0108, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA14__SIM_M_HMASTLOCK = IOMUX_PAD(0x0450, 0x0108, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA14__VADC_TEST_19 = IOMUX_PAD(0x0450, 0x0108, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA14__MMDC_DEBUG_19 = IOMUX_PAD(0x0450, 0x0108, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA15__LCDIF1_DATA_15 = IOMUX_PAD(0x0454, 0x010C, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA15__WEIM_AD_15 = IOMUX_PAD(0x0454, 0x010C, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA15__KITTEN_TRACE_15 = IOMUX_PAD(0x0454, 0x010C, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA15__CSI1_DATA_2 = IOMUX_PAD(0x0454, 0x010C, 4, 0x06A8, 1, 0),
MX6_PAD_LCD1_DATA15__GPIO3_IO_16 = IOMUX_PAD(0x0454, 0x010C, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA15__SRC_BT_CFG_15 = IOMUX_PAD(0x0454, 0x010C, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA15__SIM_M_HPROT_0 = IOMUX_PAD(0x0454, 0x010C, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA15__VDEC_DEBUG_0 = IOMUX_PAD(0x0454, 0x010C, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA15__MMDC_DEBUG_20 = IOMUX_PAD(0x0454, 0x010C, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA16__LCDIF1_DATA_16 = IOMUX_PAD(0x0458, 0x0110, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA16__WEIM_ADDR_16 = IOMUX_PAD(0x0458, 0x0110, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA16__M4_TRACE_CLK = IOMUX_PAD(0x0458, 0x0110, 2, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA16__KITTEN_TRACE_CLK = IOMUX_PAD(0x0458, 0x0110, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA16__CSI1_DATA_1 = IOMUX_PAD(0x0458, 0x0110, 4, 0x06A4, 0, 0),
MX6_PAD_LCD1_DATA16__GPIO3_IO_17 = IOMUX_PAD(0x0458, 0x0110, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA16__SRC_BT_CFG_24 = IOMUX_PAD(0x0458, 0x0110, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA16__SIM_M_HPROT_1 = IOMUX_PAD(0x0458, 0x0110, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA16__VDEC_DEBUG_1 = IOMUX_PAD(0x0458, 0x0110, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA16__MMDC_DEBUG_21 = IOMUX_PAD(0x0458, 0x0110, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA17__LCDIF1_DATA_17 = IOMUX_PAD(0x045C, 0x0114, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA17__WEIM_ADDR_17 = IOMUX_PAD(0x045C, 0x0114, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA17__KITTEN_TRACE_CTL = IOMUX_PAD(0x045C, 0x0114, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA17__CSI1_DATA_0 = IOMUX_PAD(0x045C, 0x0114, 4, 0x06A0, 0, 0),
MX6_PAD_LCD1_DATA17__GPIO3_IO_18 = IOMUX_PAD(0x045C, 0x0114, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA17__SRC_BT_CFG_25 = IOMUX_PAD(0x045C, 0x0114, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA17__SIM_M_HPROT_2 = IOMUX_PAD(0x045C, 0x0114, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA17__VDEC_DEBUG_2 = IOMUX_PAD(0x045C, 0x0114, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA17__MMDC_DEBUG_22 = IOMUX_PAD(0x045C, 0x0114, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA18__LCDIF1_DATA_18 = IOMUX_PAD(0x0460, 0x0118, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA18__WEIM_ADDR_18 = IOMUX_PAD(0x0460, 0x0118, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA18__M4_EVENTO = IOMUX_PAD(0x0460, 0x0118, 2, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA18__KITTEN_EVENTO = IOMUX_PAD(0x0460, 0x0118, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA18__CSI1_DATA_15 = IOMUX_PAD(0x0460, 0x0118, 4, 0x06D8, 0, 0),
MX6_PAD_LCD1_DATA18__GPIO3_IO_19 = IOMUX_PAD(0x0460, 0x0118, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA18__SRC_BT_CFG_26 = IOMUX_PAD(0x0460, 0x0118, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA18__SIM_M_HPROT_3 = IOMUX_PAD(0x0460, 0x0118, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA18__VDEC_DEBUG_3 = IOMUX_PAD(0x0460, 0x0118, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA18__MMDC_DEBUG_23 = IOMUX_PAD(0x0460, 0x0118, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA19__LCDIF1_DATA_19 = IOMUX_PAD(0x0464, 0x011C, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA19__WEIM_ADDR_19 = IOMUX_PAD(0x0464, 0x011C, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA19__M4_TRACE_SWO = IOMUX_PAD(0x0464, 0x011C, 2, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA19__CSI1_DATA_14 = IOMUX_PAD(0x0464, 0x011C, 4, 0x06D4, 0, 0),
MX6_PAD_LCD1_DATA19__GPIO3_IO_20 = IOMUX_PAD(0x0464, 0x011C, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA19__SRC_BT_CFG_27 = IOMUX_PAD(0x0464, 0x011C, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA19__SIM_M_HREADYOUT = IOMUX_PAD(0x0464, 0x011C, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA19__VDEC_DEBUG_4 = IOMUX_PAD(0x0464, 0x011C, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA19__MMDC_DEBUG_24 = IOMUX_PAD(0x0464, 0x011C, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA20__LCDIF1_DATA_20 = IOMUX_PAD(0x0468, 0x0120, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA20__WEIM_ADDR_20 = IOMUX_PAD(0x0468, 0x0120, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA20__PWM8_OUT = IOMUX_PAD(0x0468, 0x0120, 2, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA20__ENET1_1588_EVENT2_OUT = IOMUX_PAD(0x0468, 0x0120, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA20__CSI1_DATA_13 = IOMUX_PAD(0x0468, 0x0120, 4, 0x06D0, 0, 0),
MX6_PAD_LCD1_DATA20__GPIO3_IO_21 = IOMUX_PAD(0x0468, 0x0120, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA20__SRC_BT_CFG_28 = IOMUX_PAD(0x0468, 0x0120, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA20__SIM_M_HRESP = IOMUX_PAD(0x0468, 0x0120, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA20__VDEC_DEBUG_5 = IOMUX_PAD(0x0468, 0x0120, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA20__MMDC_DEBUG_25 = IOMUX_PAD(0x0468, 0x0120, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA21__LCDIF1_DATA_21 = IOMUX_PAD(0x046C, 0x0124, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA21__WEIM_ADDR_21 = IOMUX_PAD(0x046C, 0x0124, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA21__PWM7_OUT = IOMUX_PAD(0x046C, 0x0124, 2, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA21__ENET1_1588_EVENT3_OUT = IOMUX_PAD(0x046C, 0x0124, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA21__CSI1_DATA_12 = IOMUX_PAD(0x046C, 0x0124, 4, 0x06CC, 0, 0),
MX6_PAD_LCD1_DATA21__GPIO3_IO_22 = IOMUX_PAD(0x046C, 0x0124, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA21__SRC_BT_CFG_29 = IOMUX_PAD(0x046C, 0x0124, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA21__SIM_M_HSIZE_0 = IOMUX_PAD(0x046C, 0x0124, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA21__VDEC_DEBUG_6 = IOMUX_PAD(0x046C, 0x0124, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA21__MMDC_DEBUG_26 = IOMUX_PAD(0x046C, 0x0124, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA22__LCDIF1_DATA_22 = IOMUX_PAD(0x0470, 0x0128, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA22__WEIM_ADDR_22 = IOMUX_PAD(0x0470, 0x0128, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA22__PWM6_OUT = IOMUX_PAD(0x0470, 0x0128, 2, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA22__ENET2_1588_EVENT2_OUT = IOMUX_PAD(0x0470, 0x0128, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA22__CSI1_DATA_11 = IOMUX_PAD(0x0470, 0x0128, 4, 0x06C8, 0, 0),
MX6_PAD_LCD1_DATA22__GPIO3_IO_23 = IOMUX_PAD(0x0470, 0x0128, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA22__SRC_BT_CFG_30 = IOMUX_PAD(0x0470, 0x0128, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA22__SIM_M_HSIZE_1 = IOMUX_PAD(0x0470, 0x0128, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA22__VDEC_DEBUG_7 = IOMUX_PAD(0x0470, 0x0128, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA22__MMDC_DEBUG_27 = IOMUX_PAD(0x0470, 0x0128, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA23__LCDIF1_DATA_23 = IOMUX_PAD(0x0474, 0x012C, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA23__WEIM_ADDR_23 = IOMUX_PAD(0x0474, 0x012C, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA23__PWM5_OUT = IOMUX_PAD(0x0474, 0x012C, 2, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA23__ENET2_1588_EVENT3_OUT = IOMUX_PAD(0x0474, 0x012C, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA23__CSI1_DATA_10 = IOMUX_PAD(0x0474, 0x012C, 4, 0x06FC, 0, 0),
MX6_PAD_LCD1_DATA23__GPIO3_IO_24 = IOMUX_PAD(0x0474, 0x012C, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA23__SRC_BT_CFG_31 = IOMUX_PAD(0x0474, 0x012C, 6, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA23__SIM_M_HSIZE_2 = IOMUX_PAD(0x0474, 0x012C, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA23__VDEC_DEBUG_8 = IOMUX_PAD(0x0474, 0x012C, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_DATA23__MMDC_DEBUG_28 = IOMUX_PAD(0x0474, 0x012C, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_ENABLE__LCDIF1_ENABLE = IOMUX_PAD(0x0478, 0x0130, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_ENABLE__LCDIF1_RD_E = IOMUX_PAD(0x0478, 0x0130, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_ENABLE__AUDMUX_AUD3_TXC = IOMUX_PAD(0x0478, 0x0130, 2, 0x063C, 1, 0),
MX6_PAD_LCD1_ENABLE__ENET1_1588_EVENT3_IN = IOMUX_PAD(0x0478, 0x0130, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_ENABLE__CSI1_DATA_17 = IOMUX_PAD(0x0478, 0x0130, 4, 0x06E0, 0, 0),
MX6_PAD_LCD1_ENABLE__GPIO3_IO_25 = IOMUX_PAD(0x0478, 0x0130, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_ENABLE__USDHC1_CD_B = IOMUX_PAD(0x0478, 0x0130, 6, 0x0864, 0, 0),
MX6_PAD_LCD1_ENABLE__SIM_M_HADDR_17 = IOMUX_PAD(0x0478, 0x0130, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_ENABLE__VADC_TEST_1 = IOMUX_PAD(0x0478, 0x0130, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_ENABLE__MMDC_DEBUG_1 = IOMUX_PAD(0x0478, 0x0130, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_HSYNC__LCDIF1_HSYNC = IOMUX_PAD(0x047C, 0x0134, 0, 0x07E0, 0, 0),
MX6_PAD_LCD1_HSYNC__LCDIF1_RS = IOMUX_PAD(0x047C, 0x0134, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_HSYNC__AUDMUX_AUD3_TXD = IOMUX_PAD(0x047C, 0x0134, 2, 0x0630, 1, 0),
MX6_PAD_LCD1_HSYNC__ENET2_1588_EVENT2_IN = IOMUX_PAD(0x047C, 0x0134, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_HSYNC__CSI1_DATA_18 = IOMUX_PAD(0x047C, 0x0134, 4, 0x06E4, 0, 0),
MX6_PAD_LCD1_HSYNC__GPIO3_IO_26 = IOMUX_PAD(0x047C, 0x0134, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_HSYNC__USDHC2_WP = IOMUX_PAD(0x047C, 0x0134, 6, 0x0870, 0, 0),
MX6_PAD_LCD1_HSYNC__SIM_M_HADDR_18 = IOMUX_PAD(0x047C, 0x0134, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_HSYNC__VADC_TEST_2 = IOMUX_PAD(0x047C, 0x0134, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_HSYNC__MMDC_DEBUG_2 = IOMUX_PAD(0x047C, 0x0134, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_RESET__LCDIF1_RESET = IOMUX_PAD(0x0480, 0x0138, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_RESET__LCDIF1_CS = IOMUX_PAD(0x0480, 0x0138, 1, 0x0000, 0, 0),
MX6_PAD_LCD1_RESET__AUDMUX_AUD3_RXD = IOMUX_PAD(0x0480, 0x0138, 2, 0x062C, 1, 0),
MX6_PAD_LCD1_RESET__KITTEN_EVENTI = IOMUX_PAD(0x0480, 0x0138, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_RESET__M4_EVENTI = IOMUX_PAD(0x0480, 0x0138, 4, 0x0000, 0, 0),
MX6_PAD_LCD1_RESET__GPIO3_IO_27 = IOMUX_PAD(0x0480, 0x0138, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_RESET__CCM_PMIC_RDY = IOMUX_PAD(0x0480, 0x0138, 6, 0x069C, 0, 0),
MX6_PAD_LCD1_RESET__SIM_M_HADDR_20 = IOMUX_PAD(0x0480, 0x0138, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_RESET__VADC_TEST_4 = IOMUX_PAD(0x0480, 0x0138, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_RESET__MMDC_DEBUG_4 = IOMUX_PAD(0x0480, 0x0138, 9, 0x0000, 0, 0),
MX6_PAD_LCD1_VSYNC__LCDIF1_VSYNC = IOMUX_PAD(0x0484, 0x013C, 0, 0x0000, 0, 0),
MX6_PAD_LCD1_VSYNC__LCDIF1_BUSY = IOMUX_PAD(0x0484, 0x013C, 1, 0x07E0, 1, 0),
MX6_PAD_LCD1_VSYNC__AUDMUX_AUD3_TXFS = IOMUX_PAD(0x0484, 0x013C, 2, 0x0640, 1, 0),
MX6_PAD_LCD1_VSYNC__ENET2_1588_EVENT3_IN = IOMUX_PAD(0x0484, 0x013C, 3, 0x0000, 0, 0),
MX6_PAD_LCD1_VSYNC__CSI1_DATA_19 = IOMUX_PAD(0x0484, 0x013C, 4, 0x06E8, 0, 0),
MX6_PAD_LCD1_VSYNC__GPIO3_IO_28 = IOMUX_PAD(0x0484, 0x013C, 5, 0x0000, 0, 0),
MX6_PAD_LCD1_VSYNC__USDHC2_CD_B = IOMUX_PAD(0x0484, 0x013C, 6, 0x086C, 0, 0),
MX6_PAD_LCD1_VSYNC__SIM_M_HADDR_19 = IOMUX_PAD(0x0484, 0x013C, 7, 0x0000, 0, 0),
MX6_PAD_LCD1_VSYNC__VADC_TEST_3 = IOMUX_PAD(0x0484, 0x013C, 8, 0x0000, 0, 0),
MX6_PAD_LCD1_VSYNC__MMDC_DEBUG_3 = IOMUX_PAD(0x0484, 0x013C, 9, 0x0000, 0, 0),
MX6_PAD_NAND_ALE__RAWNAND_ALE = IOMUX_PAD(0x0488, 0x0140, 0, 0x0000, 0, 0),
MX6_PAD_NAND_ALE__I2C3_SDA = IOMUX_PAD(0x0488, 0x0140, 1, 0x07BC, 0, 0),
MX6_PAD_NAND_ALE__QSPI2_A_SS0_B = IOMUX_PAD(0x0488, 0x0140, 2, 0x0000, 0, 0),
MX6_PAD_NAND_ALE__ECSPI2_SS0 = IOMUX_PAD(0x0488, 0x0140, 3, 0x072C, 0, 0),
MX6_PAD_NAND_ALE__ESAI_TX3_RX2 = IOMUX_PAD(0x0488, 0x0140, 4, 0x079C, 0, 0),
MX6_PAD_NAND_ALE__GPIO4_IO_0 = IOMUX_PAD(0x0488, 0x0140, 5, 0x0000, 0, 0),
MX6_PAD_NAND_ALE__WEIM_CS0_B = IOMUX_PAD(0x0488, 0x0140, 6, 0x0000, 0, 0),
MX6_PAD_NAND_ALE__TPSMP_HDATA_0 = IOMUX_PAD(0x0488, 0x0140, 7, 0x0000, 0, 0),
MX6_PAD_NAND_ALE__ANATOP_USBPHY1_TSTI_TX_EN = IOMUX_PAD(0x0488, 0x0140, 8, 0x0000, 0, 0),
MX6_PAD_NAND_ALE__SDMA_DEBUG_PC_12 = IOMUX_PAD(0x0488, 0x0140, 9, 0x0000, 0, 0),
MX6_PAD_NAND_CE0_B__RAWNAND_CE0_B = IOMUX_PAD(0x048C, 0x0144, 0, 0x0000, 0, 0),
MX6_PAD_NAND_CE0_B__USDHC2_VSELECT = IOMUX_PAD(0x048C, 0x0144, 1, 0x0000, 0, 0),
MX6_PAD_NAND_CE0_B__QSPI2_A_DATA_2 = IOMUX_PAD(0x048C, 0x0144, 2, 0x0000, 0, 0),
MX6_PAD_NAND_CE0_B__AUDMUX_AUD4_TXC = IOMUX_PAD(0x048C, 0x0144, 3, 0x0654, 0, 0),
MX6_PAD_NAND_CE0_B__ESAI_TX_CLK = IOMUX_PAD(0x048C, 0x0144, 4, 0x078C, 0, 0),
MX6_PAD_NAND_CE0_B__GPIO4_IO_1 = IOMUX_PAD(0x048C, 0x0144, 5, 0x0000, 0, 0),
MX6_PAD_NAND_CE0_B__WEIM_LBA_B = IOMUX_PAD(0x048C, 0x0144, 6, 0x0000, 0, 0),
MX6_PAD_NAND_CE0_B__TPSMP_HDATA_3 = IOMUX_PAD(0x048C, 0x0144, 7, 0x0000, 0, 0),
MX6_PAD_NAND_CE0_B__ANATOP_USBPHY1_TSTI_TX_HIZ = IOMUX_PAD(0x048C, 0x0144, 8, 0x0000, 0, 0),
MX6_PAD_NAND_CE0_B__SDMA_DEBUG_PC_9 = IOMUX_PAD(0x048C, 0x0144, 9, 0x0000, 0, 0),
MX6_PAD_NAND_CE1_B__RAWNAND_CE1_B = IOMUX_PAD(0x0490, 0x0148, 0, 0x0000, 0, 0),
MX6_PAD_NAND_CE1_B__USDHC3_RESET_B = IOMUX_PAD(0x0490, 0x0148, 1, 0x0000, 0, 0),
MX6_PAD_NAND_CE1_B__QSPI2_A_DATA_3 = IOMUX_PAD(0x0490, 0x0148, 2, 0x0000, 0, 0),
MX6_PAD_NAND_CE1_B__AUDMUX_AUD4_TXD = IOMUX_PAD(0x0490, 0x0148, 3, 0x0648, 0, 0),
MX6_PAD_NAND_CE1_B__ESAI_TX0 = IOMUX_PAD(0x0490, 0x0148, 4, 0x0790, 0, 0),
MX6_PAD_NAND_CE1_B__GPIO4_IO_2 = IOMUX_PAD(0x0490, 0x0148, 5, 0x0000, 0, 0),
MX6_PAD_NAND_CE1_B__WEIM_OE = IOMUX_PAD(0x0490, 0x0148, 6, 0x0000, 0, 0),
MX6_PAD_NAND_CE1_B__TPSMP_HDATA_4 = IOMUX_PAD(0x0490, 0x0148, 7, 0x0000, 0, 0),
MX6_PAD_NAND_CE1_B__ANATOP_USBPHY1_TSTI_TX_LS_MODE = IOMUX_PAD(0x0490, 0x0148, 8, 0x0000, 0, 0),
MX6_PAD_NAND_CE1_B__SDMA_DEBUG_PC_8 = IOMUX_PAD(0x0490, 0x0148, 9, 0x0000, 0, 0),
MX6_PAD_NAND_CLE__RAWNAND_CLE = IOMUX_PAD(0x0494, 0x014C, 0, 0x0000, 0, 0),
MX6_PAD_NAND_CLE__I2C3_SCL = IOMUX_PAD(0x0494, 0x014C, 1, 0x07B8, 0, 0),
MX6_PAD_NAND_CLE__QSPI2_A_SCLK = IOMUX_PAD(0x0494, 0x014C, 2, 0x0000, 0, 0),
MX6_PAD_NAND_CLE__ECSPI2_SCLK = IOMUX_PAD(0x0494, 0x014C, 3, 0x0720, 0, 0),
MX6_PAD_NAND_CLE__ESAI_TX2_RX3 = IOMUX_PAD(0x0494, 0x014C, 4, 0x0798, 0, 0),
MX6_PAD_NAND_CLE__GPIO4_IO_3 = IOMUX_PAD(0x0494, 0x014C, 5, 0x0000, 0, 0),
MX6_PAD_NAND_CLE__WEIM_BCLK = IOMUX_PAD(0x0494, 0x014C, 6, 0x0000, 0, 0),
MX6_PAD_NAND_CLE__TPSMP_CLK = IOMUX_PAD(0x0494, 0x014C, 7, 0x0000, 0, 0),
MX6_PAD_NAND_CLE__ANATOP_USBPHY1_TSTI_TX_DP = IOMUX_PAD(0x0494, 0x014C, 8, 0x0000, 0, 0),
MX6_PAD_NAND_CLE__SDMA_DEBUG_PC_13 = IOMUX_PAD(0x0494, 0x014C, 9, 0x0000, 0, 0),
MX6_PAD_NAND_DATA00__RAWNAND_DATA00 = IOMUX_PAD(0x0498, 0x0150, 0, 0x0000, 0, 0),
MX6_PAD_NAND_DATA00__USDHC1_DATA4 = IOMUX_PAD(0x0498, 0x0150, 1, 0x0000, 0, 0),
MX6_PAD_NAND_DATA00__QSPI2_B_DATA_1 = IOMUX_PAD(0x0498, 0x0150, 2, 0x0000, 0, 0),
MX6_PAD_NAND_DATA00__ECSPI5_MISO = IOMUX_PAD(0x0498, 0x0150, 3, 0x0754, 0, 0),
MX6_PAD_NAND_DATA00__ESAI_RX_CLK = IOMUX_PAD(0x0498, 0x0150, 4, 0x0788, 0, 0),
MX6_PAD_NAND_DATA00__GPIO4_IO_4 = IOMUX_PAD(0x0498, 0x0150, 5, 0x0000, 0, 0),
MX6_PAD_NAND_DATA00__WEIM_AD_0 = IOMUX_PAD(0x0498, 0x0150, 6, 0x0000, 0, 0),
MX6_PAD_NAND_DATA00__TPSMP_HDATA_7 = IOMUX_PAD(0x0498, 0x0150, 7, 0x0000, 0, 0),
MX6_PAD_NAND_DATA00__ANATOP_USBPHY1_TSTO_RX_DISCON_DET = IOMUX_PAD(0x0498, 0x0150, 8, 0x0000, 0, 0),
MX6_PAD_NAND_DATA00__SDMA_DEBUG_EVT_CHN_LINES_5 = IOMUX_PAD(0x0498, 0x0150, 9, 0x0000, 0, 0),
MX6_PAD_NAND_DATA01__RAWNAND_DATA01 = IOMUX_PAD(0x049C, 0x0154, 0, 0x0000, 0, 0),
MX6_PAD_NAND_DATA01__USDHC1_DATA5 = IOMUX_PAD(0x049C, 0x0154, 1, 0x0000, 0, 0),
MX6_PAD_NAND_DATA01__QSPI2_B_DATA_0 = IOMUX_PAD(0x049C, 0x0154, 2, 0x0000, 0, 0),
MX6_PAD_NAND_DATA01__ECSPI5_MOSI = IOMUX_PAD(0x049C, 0x0154, 3, 0x0758, 0, 0),
MX6_PAD_NAND_DATA01__ESAI_RX_FS = IOMUX_PAD(0x049C, 0x0154, 4, 0x0778, 0, 0),
MX6_PAD_NAND_DATA01__GPIO4_IO_5 = IOMUX_PAD(0x049C, 0x0154, 5, 0x0000, 0, 0),
MX6_PAD_NAND_DATA01__WEIM_AD_1 = IOMUX_PAD(0x049C, 0x0154, 6, 0x0000, 0, 0),
MX6_PAD_NAND_DATA01__TPSMP_HDATA_8 = IOMUX_PAD(0x049C, 0x0154, 7, 0x0000, 0, 0),
MX6_PAD_NAND_DATA01__ANATOP_USBPHY1_TSTO_RX_HS_RXD = IOMUX_PAD(0x049C, 0x0154, 8, 0x0000, 0, 0),
MX6_PAD_NAND_DATA01__SDMA_DEBUG_EVT_CHN_LINES_4 = IOMUX_PAD(0x049C, 0x0154, 9, 0x0000, 0, 0),
MX6_PAD_NAND_DATA02__RAWNAND_DATA02 = IOMUX_PAD(0x04A0, 0x0158, 0, 0x0000, 0, 0),
MX6_PAD_NAND_DATA02__USDHC1_DATA6 = IOMUX_PAD(0x04A0, 0x0158, 1, 0x0000, 0, 0),
MX6_PAD_NAND_DATA02__QSPI2_B_SCLK = IOMUX_PAD(0x04A0, 0x0158, 2, 0x0000, 0, 0),
MX6_PAD_NAND_DATA02__ECSPI5_SCLK = IOMUX_PAD(0x04A0, 0x0158, 3, 0x0750, 0, 0),
MX6_PAD_NAND_DATA02__ESAI_TX_HF_CLK = IOMUX_PAD(0x04A0, 0x0158, 4, 0x0784, 0, 0),
MX6_PAD_NAND_DATA02__GPIO4_IO_6 = IOMUX_PAD(0x04A0, 0x0158, 5, 0x0000, 0, 0),
MX6_PAD_NAND_DATA02__WEIM_AD_2 = IOMUX_PAD(0x04A0, 0x0158, 6, 0x0000, 0, 0),
MX6_PAD_NAND_DATA02__TPSMP_HDATA_9 = IOMUX_PAD(0x04A0, 0x0158, 7, 0x0000, 0, 0),
MX6_PAD_NAND_DATA02__ANATOP_USBPHY2_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x04A0, 0x0158, 8, 0x0000, 0, 0),
MX6_PAD_NAND_DATA02__SDMA_DEBUG_EVT_CHN_LINES_3 = IOMUX_PAD(0x04A0, 0x0158, 9, 0x0000, 0, 0),
MX6_PAD_NAND_DATA03__RAWNAND_DATA03 = IOMUX_PAD(0x04A4, 0x015C, 0, 0x0000, 0, 0),
MX6_PAD_NAND_DATA03__USDHC1_DATA7 = IOMUX_PAD(0x04A4, 0x015C, 1, 0x0000, 0, 0),
MX6_PAD_NAND_DATA03__QSPI2_B_SS0_B = IOMUX_PAD(0x04A4, 0x015C, 2, 0x0000, 0, 0),
MX6_PAD_NAND_DATA03__ECSPI5_SS0 = IOMUX_PAD(0x04A4, 0x015C, 3, 0x075C, 0, 0),
MX6_PAD_NAND_DATA03__ESAI_RX_HF_CLK = IOMUX_PAD(0x04A4, 0x015C, 4, 0x0780, 0, 0),
MX6_PAD_NAND_DATA03__GPIO4_IO_7 = IOMUX_PAD(0x04A4, 0x015C, 5, 0x0000, 0, 0),
MX6_PAD_NAND_DATA03__WEIM_AD_3 = IOMUX_PAD(0x04A4, 0x015C, 6, 0x0000, 0, 0),
MX6_PAD_NAND_DATA03__TPSMP_HDATA_10 = IOMUX_PAD(0x04A4, 0x015C, 7, 0x0000, 0, 0),
MX6_PAD_NAND_DATA03__ANATOP_USBPHY1_TSTO_RX_SQUELCH = IOMUX_PAD(0x04A4, 0x015C, 8, 0x0000, 0, 0),
MX6_PAD_NAND_DATA03__SDMA_DEBUG_EVT_CHN_LINES_6 = IOMUX_PAD(0x04A4, 0x015C, 9, 0x0000, 0, 0),
MX6_PAD_NAND_DATA04__RAWNAND_DATA04 = IOMUX_PAD(0x04A8, 0x0160, 0, 0x0000, 0, 0),
MX6_PAD_NAND_DATA04__USDHC2_DATA4 = IOMUX_PAD(0x04A8, 0x0160, 1, 0x0000, 0, 0),
MX6_PAD_NAND_DATA04__QSPI2_B_SS1_B = IOMUX_PAD(0x04A8, 0x0160, 2, 0x0000, 0, 0),
MX6_PAD_NAND_DATA04__UART3_RTS_B = IOMUX_PAD(0x04A8, 0x0160, 3, 0x083C, 0, 0),
MX6_PAD_NAND_DATA04__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x04A8, 0x0160, 4, 0x0650, 0, 0),
MX6_PAD_NAND_DATA04__GPIO4_IO_8 = IOMUX_PAD(0x04A8, 0x0160, 5, 0x0000, 0, 0),
MX6_PAD_NAND_DATA04__WEIM_AD_4 = IOMUX_PAD(0x04A8, 0x0160, 6, 0x0000, 0, 0),
MX6_PAD_NAND_DATA04__TPSMP_HDATA_11 = IOMUX_PAD(0x04A8, 0x0160, 7, 0x0000, 0, 0),
MX6_PAD_NAND_DATA04__ANATOP_USBPHY2_TSTO_RX_SQUELCH = IOMUX_PAD(0x04A8, 0x0160, 8, 0x0000, 0, 0),
MX6_PAD_NAND_DATA04__SDMA_DEBUG_CORE_STATE_0 = IOMUX_PAD(0x04A8, 0x0160, 9, 0x0000, 0, 0),
MX6_PAD_NAND_DATA05__RAWNAND_DATA05 = IOMUX_PAD(0x04AC, 0x0164, 0, 0x0000, 0, 0),
MX6_PAD_NAND_DATA05__USDHC2_DATA5 = IOMUX_PAD(0x04AC, 0x0164, 1, 0x0000, 0, 0),
MX6_PAD_NAND_DATA05__QSPI2_B_DQS = IOMUX_PAD(0x04AC, 0x0164, 2, 0x0000, 0, 0),
MX6_PAD_NAND_DATA05__UART3_CTS_B = IOMUX_PAD(0x04AC, 0x0164, 3, 0x083C, 1, 0),
MX6_PAD_NAND_DATA05__AUDMUX_AUD4_RXC = IOMUX_PAD(0x04AC, 0x0164, 4, 0x064C, 0, 0),
MX6_PAD_NAND_DATA05__GPIO4_IO_9 = IOMUX_PAD(0x04AC, 0x0164, 5, 0x0000, 0, 0),
MX6_PAD_NAND_DATA05__WEIM_AD_5 = IOMUX_PAD(0x04AC, 0x0164, 6, 0x0000, 0, 0),
MX6_PAD_NAND_DATA05__TPSMP_HDATA_12 = IOMUX_PAD(0x04AC, 0x0164, 7, 0x0000, 0, 0),
MX6_PAD_NAND_DATA05__ANATOP_USBPHY2_TSTO_RX_DISCON_DET = IOMUX_PAD(0x04AC, 0x0164, 8, 0x0000, 0, 0),
MX6_PAD_NAND_DATA05__SDMA_DEBUG_CORE_STATE_1 = IOMUX_PAD(0x04AC, 0x0164, 9, 0x0000, 0, 0),
MX6_PAD_NAND_DATA06__RAWNAND_DATA06 = IOMUX_PAD(0x04B0, 0x0168, 0, 0x0000, 0, 0),
MX6_PAD_NAND_DATA06__USDHC2_DATA6 = IOMUX_PAD(0x04B0, 0x0168, 1, 0x0000, 0, 0),
MX6_PAD_NAND_DATA06__QSPI2_A_SS1_B = IOMUX_PAD(0x04B0, 0x0168, 2, 0x0000, 0, 0),
MX6_PAD_NAND_DATA06__UART3_RX = IOMUX_PAD(0x04B0, 0x0168, 3, 0x0840, 0, 0),
MX6_PAD_NAND_DATA06__PWM3_OUT = IOMUX_PAD(0x04B0, 0x0168, 4, 0x0000, 0, 0),
MX6_PAD_NAND_DATA06__GPIO4_IO_10 = IOMUX_PAD(0x04B0, 0x0168, 5, 0x0000, 0, 0),
MX6_PAD_NAND_DATA06__WEIM_AD_6 = IOMUX_PAD(0x04B0, 0x0168, 6, 0x0000, 0, 0),
MX6_PAD_NAND_DATA06__TPSMP_HDATA_13 = IOMUX_PAD(0x04B0, 0x0168, 7, 0x0000, 0, 0),
MX6_PAD_NAND_DATA06__ANATOP_USBPHY2_TSTO_RX_FS_RXD = IOMUX_PAD(0x04B0, 0x0168, 8, 0x0000, 0, 0),
MX6_PAD_NAND_DATA06__SDMA_DEBUG_CORE_STATE_2 = IOMUX_PAD(0x04B0, 0x0168, 9, 0x0000, 0, 0),
MX6_PAD_NAND_DATA07__RAWNAND_DATA07 = IOMUX_PAD(0x04B4, 0x016C, 0, 0x0000, 0, 0),
MX6_PAD_NAND_DATA07__USDHC2_DATA7 = IOMUX_PAD(0x04B4, 0x016C, 1, 0x0000, 0, 0),
MX6_PAD_NAND_DATA07__QSPI2_A_DQS = IOMUX_PAD(0x04B4, 0x016C, 2, 0x0000, 0, 0),
MX6_PAD_NAND_DATA07__UART3_TX = IOMUX_PAD(0x04B4, 0x016C, 3, 0x0840, 1, 0),
MX6_PAD_NAND_DATA07__PWM4_OUT = IOMUX_PAD(0x04B4, 0x016C, 4, 0x0000, 0, 0),
MX6_PAD_NAND_DATA07__GPIO4_IO_11 = IOMUX_PAD(0x04B4, 0x016C, 5, 0x0000, 0, 0),
MX6_PAD_NAND_DATA07__WEIM_AD_7 = IOMUX_PAD(0x04B4, 0x016C, 6, 0x0000, 0, 0),
MX6_PAD_NAND_DATA07__TPSMP_HDATA_14 = IOMUX_PAD(0x04B4, 0x016C, 7, 0x0000, 0, 0),
MX6_PAD_NAND_DATA07__ANATOP_USBPHY1_TSTO_RX_FS_RXD = IOMUX_PAD(0x04B4, 0x016C, 8, 0x0000, 0, 0),
MX6_PAD_NAND_DATA07__SDMA_DEBUG_CORE_STATE_3 = IOMUX_PAD(0x04B4, 0x016C, 9, 0x0000, 0, 0),
MX6_PAD_NAND_RE_B__RAWNAND_RE_B = IOMUX_PAD(0x04B8, 0x0170, 0, 0x0000, 0, 0),
MX6_PAD_NAND_RE_B__USDHC2_RESET_B = IOMUX_PAD(0x04B8, 0x0170, 1, 0x0000, 0, 0),
MX6_PAD_NAND_RE_B__QSPI2_B_DATA_3 = IOMUX_PAD(0x04B8, 0x0170, 2, 0x0000, 0, 0),
MX6_PAD_NAND_RE_B__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x04B8, 0x0170, 3, 0x0658, 0, 0),
MX6_PAD_NAND_RE_B__ESAI_TX_FS = IOMUX_PAD(0x04B8, 0x0170, 4, 0x077C, 0, 0),
MX6_PAD_NAND_RE_B__GPIO4_IO_12 = IOMUX_PAD(0x04B8, 0x0170, 5, 0x0000, 0, 0),
MX6_PAD_NAND_RE_B__WEIM_RW = IOMUX_PAD(0x04B8, 0x0170, 6, 0x0000, 0, 0),
MX6_PAD_NAND_RE_B__TPSMP_HDATA_5 = IOMUX_PAD(0x04B8, 0x0170, 7, 0x0000, 0, 0),
MX6_PAD_NAND_RE_B__ANATOP_USBPHY2_TSTO_RX_HS_RXD = IOMUX_PAD(0x04B8, 0x0170, 8, 0x0000, 0, 0),
MX6_PAD_NAND_RE_B__SDMA_DEBUG_PC_7 = IOMUX_PAD(0x04B8, 0x0170, 9, 0x0000, 0, 0),
MX6_PAD_NAND_READY_B__RAWNAND_READY_B = IOMUX_PAD(0x04BC, 0x0174, 0, 0x0000, 0, 0),
MX6_PAD_NAND_READY_B__USDHC1_VSELECT = IOMUX_PAD(0x04BC, 0x0174, 1, 0x0000, 0, 0),
MX6_PAD_NAND_READY_B__QSPI2_A_DATA_1 = IOMUX_PAD(0x04BC, 0x0174, 2, 0x0000, 0, 0),
MX6_PAD_NAND_READY_B__ECSPI2_MISO = IOMUX_PAD(0x04BC, 0x0174, 3, 0x0724, 0, 0),
MX6_PAD_NAND_READY_B__ESAI_TX1 = IOMUX_PAD(0x04BC, 0x0174, 4, 0x0794, 0, 0),
MX6_PAD_NAND_READY_B__GPIO4_IO_13 = IOMUX_PAD(0x04BC, 0x0174, 5, 0x0000, 0, 0),
MX6_PAD_NAND_READY_B__WEIM_EB_B_1 = IOMUX_PAD(0x04BC, 0x0174, 6, 0x0000, 0, 0),
MX6_PAD_NAND_READY_B__TPSMP_HDATA_2 = IOMUX_PAD(0x04BC, 0x0174, 7, 0x0000, 0, 0),
MX6_PAD_NAND_READY_B__ANATOP_USBPHY1_TSTI_TX_DN = IOMUX_PAD(0x04BC, 0x0174, 8, 0x0000, 0, 0),
MX6_PAD_NAND_READY_B__SDMA_DEBUG_PC_10 = IOMUX_PAD(0x04BC, 0x0174, 9, 0x0000, 0, 0),
MX6_PAD_NAND_WE_B__RAWNAND_WE_B = IOMUX_PAD(0x04C0, 0x0178, 0, 0x0000, 0, 0),
MX6_PAD_NAND_WE_B__USDHC4_VSELECT = IOMUX_PAD(0x04C0, 0x0178, 1, 0x0000, 0, 0),
MX6_PAD_NAND_WE_B__QSPI2_B_DATA_2 = IOMUX_PAD(0x04C0, 0x0178, 2, 0x0000, 0, 0),
MX6_PAD_NAND_WE_B__AUDMUX_AUD4_RXD = IOMUX_PAD(0x04C0, 0x0178, 3, 0x0644, 0, 0),
MX6_PAD_NAND_WE_B__ESAI_TX5_RX0 = IOMUX_PAD(0x04C0, 0x0178, 4, 0x07A4, 0, 0),
MX6_PAD_NAND_WE_B__GPIO4_IO_14 = IOMUX_PAD(0x04C0, 0x0178, 5, 0x0000, 0, 0),
MX6_PAD_NAND_WE_B__WEIM_WAIT = IOMUX_PAD(0x04C0, 0x0178, 6, 0x0000, 0, 0),
MX6_PAD_NAND_WE_B__TPSMP_HDATA_6 = IOMUX_PAD(0x04C0, 0x0178, 7, 0x0000, 0, 0),
MX6_PAD_NAND_WE_B__ANATOP_USBPHY1_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x04C0, 0x0178, 8, 0x0000, 0, 0),
MX6_PAD_NAND_WE_B__SDMA_DEBUG_PC_6 = IOMUX_PAD(0x04C0, 0x0178, 9, 0x0000, 0, 0),
MX6_PAD_NAND_WP_B__RAWNAND_WP_B = IOMUX_PAD(0x04C4, 0x017C, 0, 0x0000, 0, 0),
MX6_PAD_NAND_WP_B__USDHC1_RESET_B = IOMUX_PAD(0x04C4, 0x017C, 1, 0x0000, 0, 0),
MX6_PAD_NAND_WP_B__QSPI2_A_DATA_0 = IOMUX_PAD(0x04C4, 0x017C, 2, 0x0000, 0, 0),
MX6_PAD_NAND_WP_B__ECSPI2_MOSI = IOMUX_PAD(0x04C4, 0x017C, 3, 0x0728, 0, 0),
MX6_PAD_NAND_WP_B__ESAI_TX4_RX1 = IOMUX_PAD(0x04C4, 0x017C, 4, 0x07A0, 0, 0),
MX6_PAD_NAND_WP_B__GPIO4_IO_15 = IOMUX_PAD(0x04C4, 0x017C, 5, 0x0000, 0, 0),
MX6_PAD_NAND_WP_B__WEIM_EB_B_0 = IOMUX_PAD(0x04C4, 0x017C, 6, 0x0000, 0, 0),
MX6_PAD_NAND_WP_B__TPSMP_HDATA_1 = IOMUX_PAD(0x04C4, 0x017C, 7, 0x0000, 0, 0),
MX6_PAD_NAND_WP_B__ANATOP_USBPHY1_TSTI_TX_HS_MODE = IOMUX_PAD(0x04C4, 0x017C, 8, 0x0000, 0, 0),
MX6_PAD_NAND_WP_B__SDMA_DEBUG_PC_11 = IOMUX_PAD(0x04C4, 0x017C, 9, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA0__QSPI1_A_DATA_0 = IOMUX_PAD(0x04C8, 0x0180, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA0__USB_OTG2_OC = IOMUX_PAD(0x04C8, 0x0180, 1, 0x085C, 2, 0),
MX6_PAD_QSPI1A_DATA0__ECSPI1_MOSI = IOMUX_PAD(0x04C8, 0x0180, 2, 0x0718, 1, 0),
MX6_PAD_QSPI1A_DATA0__ESAI_TX4_RX1 = IOMUX_PAD(0x04C8, 0x0180, 3, 0x07A0, 2, 0),
MX6_PAD_QSPI1A_DATA0__CSI1_DATA_14 = IOMUX_PAD(0x04C8, 0x0180, 4, 0x06D4, 1, 0),
MX6_PAD_QSPI1A_DATA0__GPIO4_IO_16 = IOMUX_PAD(0x04C8, 0x0180, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA0__WEIM_DATA_6 = IOMUX_PAD(0x04C8, 0x0180, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA0__SIM_M_HADDR_3 = IOMUX_PAD(0x04C8, 0x0180, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA0__SDMA_DEBUG_BUS_DEVICE_3 = IOMUX_PAD(0x04C8, 0x0180, 9, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA1__QSPI1_A_DATA_1 = IOMUX_PAD(0x04CC, 0x0184, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA1__ANATOP_OTG1_ID = IOMUX_PAD(0x04CC, 0x0184, 1, 0x0624, 2, 0),
MX6_PAD_QSPI1A_DATA1__ECSPI1_MISO = IOMUX_PAD(0x04CC, 0x0184, 2, 0x0714, 1, 0),
MX6_PAD_QSPI1A_DATA1__ESAI_TX1 = IOMUX_PAD(0x04CC, 0x0184, 3, 0x0794, 2, 0),
MX6_PAD_QSPI1A_DATA1__CSI1_DATA_13 = IOMUX_PAD(0x04CC, 0x0184, 4, 0x06D0, 1, 0),
MX6_PAD_QSPI1A_DATA1__GPIO4_IO_17 = IOMUX_PAD(0x04CC, 0x0184, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA1__WEIM_DATA_5 = IOMUX_PAD(0x04CC, 0x0184, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA1__SIM_M_HADDR_4 = IOMUX_PAD(0x04CC, 0x0184, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA1__SDMA_DEBUG_PC_0 = IOMUX_PAD(0x04CC, 0x0184, 9, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA2__QSPI1_A_DATA_2 = IOMUX_PAD(0x04D0, 0x0188, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA2__USB_OTG1_PWR = IOMUX_PAD(0x04D0, 0x0188, 1, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA2__ECSPI5_SS1 = IOMUX_PAD(0x04D0, 0x0188, 2, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA2__ESAI_TX_CLK = IOMUX_PAD(0x04D0, 0x0188, 3, 0x078C, 2, 0),
MX6_PAD_QSPI1A_DATA2__CSI1_DATA_12 = IOMUX_PAD(0x04D0, 0x0188, 4, 0x06CC, 1, 0),
MX6_PAD_QSPI1A_DATA2__GPIO4_IO_18 = IOMUX_PAD(0x04D0, 0x0188, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA2__WEIM_DATA_4 = IOMUX_PAD(0x04D0, 0x0188, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA2__SIM_M_HADDR_6 = IOMUX_PAD(0x04D0, 0x0188, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA2__SDMA_DEBUG_PC_1 = IOMUX_PAD(0x04D0, 0x0188, 9, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA3__QSPI1_A_DATA_3 = IOMUX_PAD(0x04D4, 0x018C, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA3__USB_OTG1_OC = IOMUX_PAD(0x04D4, 0x018C, 1, 0x0860, 2, 0),
MX6_PAD_QSPI1A_DATA3__ECSPI5_SS2 = IOMUX_PAD(0x04D4, 0x018C, 2, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA3__ESAI_TX0 = IOMUX_PAD(0x04D4, 0x018C, 3, 0x0790, 2, 0),
MX6_PAD_QSPI1A_DATA3__CSI1_DATA_11 = IOMUX_PAD(0x04D4, 0x018C, 4, 0x06C8, 1, 0),
MX6_PAD_QSPI1A_DATA3__GPIO4_IO_19 = IOMUX_PAD(0x04D4, 0x018C, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA3__WEIM_DATA_3 = IOMUX_PAD(0x04D4, 0x018C, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA3__SIM_M_HADDR_7 = IOMUX_PAD(0x04D4, 0x018C, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DATA3__SDMA_DEBUG_PC_2 = IOMUX_PAD(0x04D4, 0x018C, 9, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DQS__QSPI1_A_DQS = IOMUX_PAD(0x04D8, 0x0190, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DQS__CAN2_TX = IOMUX_PAD(0x04D8, 0x0190, 1, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DQS__CANFD_TX2 = IOMUX_PAD(0x04D8, 0x0190, 2, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DQS__ECSPI5_MOSI = IOMUX_PAD(0x04D8, 0x0190, 3, 0x0758, 1, 0),
MX6_PAD_QSPI1A_DQS__CSI1_DATA_15 = IOMUX_PAD(0x04D8, 0x0190, 4, 0x06D8, 1, 0),
MX6_PAD_QSPI1A_DQS__GPIO4_IO_20 = IOMUX_PAD(0x04D8, 0x0190, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DQS__WEIM_DATA_7 = IOMUX_PAD(0x04D8, 0x0190, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DQS__SIM_M_HADDR_13 = IOMUX_PAD(0x04D8, 0x0190, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1A_DQS__SDMA_DEBUG_BUS_DEVICE_4 = IOMUX_PAD(0x04D8, 0x0190, 9, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SCLK__QSPI1_A_SCLK = IOMUX_PAD(0x04DC, 0x0194, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SCLK__ANATOP_OTG2_ID = IOMUX_PAD(0x04DC, 0x0194, 1, 0x0628, 2, 0),
MX6_PAD_QSPI1A_SCLK__ECSPI1_SCLK = IOMUX_PAD(0x04DC, 0x0194, 2, 0x0710, 1, 0),
MX6_PAD_QSPI1A_SCLK__ESAI_TX2_RX3 = IOMUX_PAD(0x04DC, 0x0194, 3, 0x0798, 2, 0),
MX6_PAD_QSPI1A_SCLK__CSI1_DATA_1 = IOMUX_PAD(0x04DC, 0x0194, 4, 0x06A4, 1, 0),
MX6_PAD_QSPI1A_SCLK__GPIO4_IO_21 = IOMUX_PAD(0x04DC, 0x0194, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SCLK__WEIM_DATA_0 = IOMUX_PAD(0x04DC, 0x0194, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SCLK__SIM_M_HADDR_0 = IOMUX_PAD(0x04DC, 0x0194, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SCLK__SDMA_DEBUG_PC_5 = IOMUX_PAD(0x04DC, 0x0194, 9, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SS0_B__QSPI1_A_SS0_B = IOMUX_PAD(0x04E0, 0x0198, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SS0_B__USB_OTG2_PWR = IOMUX_PAD(0x04E0, 0x0198, 1, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SS0_B__ECSPI1_SS0 = IOMUX_PAD(0x04E0, 0x0198, 2, 0x071C, 1, 0),
MX6_PAD_QSPI1A_SS0_B__ESAI_TX3_RX2 = IOMUX_PAD(0x04E0, 0x0198, 3, 0x079C, 2, 0),
MX6_PAD_QSPI1A_SS0_B__CSI1_DATA_0 = IOMUX_PAD(0x04E0, 0x0198, 4, 0x06A0, 1, 0),
MX6_PAD_QSPI1A_SS0_B__GPIO4_IO_22 = IOMUX_PAD(0x04E0, 0x0198, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SS0_B__WEIM_DATA_1 = IOMUX_PAD(0x04E0, 0x0198, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SS0_B__SIM_M_HADDR_1 = IOMUX_PAD(0x04E0, 0x0198, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SS0_B__SDMA_DEBUG_PC_4 = IOMUX_PAD(0x04E0, 0x0198, 9, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SS1_B__QSPI1_A_SS1_B = IOMUX_PAD(0x04E4, 0x019C, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SS1_B__CAN1_RX = IOMUX_PAD(0x04E4, 0x019C, 1, 0x068C, 2, 0),
MX6_PAD_QSPI1A_SS1_B__CANFD_RX1 = IOMUX_PAD(0x04E4, 0x019C, 2, 0x0694, 2, 0),
MX6_PAD_QSPI1A_SS1_B__ECSPI5_MISO = IOMUX_PAD(0x04E4, 0x019C, 3, 0x0754, 1, 0),
MX6_PAD_QSPI1A_SS1_B__CSI1_DATA_10 = IOMUX_PAD(0x04E4, 0x019C, 4, 0x06FC, 1, 0),
MX6_PAD_QSPI1A_SS1_B__GPIO4_IO_23 = IOMUX_PAD(0x04E4, 0x019C, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SS1_B__WEIM_DATA_2 = IOMUX_PAD(0x04E4, 0x019C, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SS1_B__SIM_M_HADDR_12 = IOMUX_PAD(0x04E4, 0x019C, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1A_SS1_B__SDMA_DEBUG_PC_3 = IOMUX_PAD(0x04E4, 0x019C, 9, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA0__QSPI1_B_DATA_0 = IOMUX_PAD(0x04E8, 0x01A0, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA0__UART3_CTS_B = IOMUX_PAD(0x04E8, 0x01A0, 1, 0x083C, 4, 0),
MX6_PAD_QSPI1B_DATA0__ECSPI3_MOSI = IOMUX_PAD(0x04E8, 0x01A0, 2, 0x0738, 1, 0),
MX6_PAD_QSPI1B_DATA0__ESAI_RX_FS = IOMUX_PAD(0x04E8, 0x01A0, 3, 0x0778, 2, 0),
MX6_PAD_QSPI1B_DATA0__CSI1_DATA_22 = IOMUX_PAD(0x04E8, 0x01A0, 4, 0x06F4, 1, 0),
MX6_PAD_QSPI1B_DATA0__GPIO4_IO_24 = IOMUX_PAD(0x04E8, 0x01A0, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA0__WEIM_DATA_14 = IOMUX_PAD(0x04E8, 0x01A0, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA0__SIM_M_HADDR_9 = IOMUX_PAD(0x04E8, 0x01A0, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA1__QSPI1_B_DATA_1 = IOMUX_PAD(0x04EC, 0x01A4, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA1__UART3_RTS_B = IOMUX_PAD(0x04EC, 0x01A4, 1, 0x083C, 5, 0),
MX6_PAD_QSPI1B_DATA1__ECSPI3_MISO = IOMUX_PAD(0x04EC, 0x01A4, 2, 0x0734, 1, 0),
MX6_PAD_QSPI1B_DATA1__ESAI_RX_CLK = IOMUX_PAD(0x04EC, 0x01A4, 3, 0x0788, 2, 0),
MX6_PAD_QSPI1B_DATA1__CSI1_DATA_21 = IOMUX_PAD(0x04EC, 0x01A4, 4, 0x06F0, 1, 0),
MX6_PAD_QSPI1B_DATA1__GPIO4_IO_25 = IOMUX_PAD(0x04EC, 0x01A4, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA1__WEIM_DATA_13 = IOMUX_PAD(0x04EC, 0x01A4, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA1__SIM_M_HADDR_8 = IOMUX_PAD(0x04EC, 0x01A4, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA2__QSPI1_B_DATA_2 = IOMUX_PAD(0x04F0, 0x01A8, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA2__I2C2_SDA = IOMUX_PAD(0x04F0, 0x01A8, 1, 0x07B4, 2, 0),
MX6_PAD_QSPI1B_DATA2__ECSPI5_RDY = IOMUX_PAD(0x04F0, 0x01A8, 2, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA2__ESAI_TX5_RX0 = IOMUX_PAD(0x04F0, 0x01A8, 3, 0x07A4, 2, 0),
MX6_PAD_QSPI1B_DATA2__CSI1_DATA_20 = IOMUX_PAD(0x04F0, 0x01A8, 4, 0x06EC, 1, 0),
MX6_PAD_QSPI1B_DATA2__GPIO4_IO_26 = IOMUX_PAD(0x04F0, 0x01A8, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA2__WEIM_DATA_12 = IOMUX_PAD(0x04F0, 0x01A8, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA2__SIM_M_HADDR_5 = IOMUX_PAD(0x04F0, 0x01A8, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA3__QSPI1_B_DATA_3 = IOMUX_PAD(0x04F4, 0x01AC, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA3__I2C2_SCL = IOMUX_PAD(0x04F4, 0x01AC, 1, 0x07B0, 2, 0),
MX6_PAD_QSPI1B_DATA3__ECSPI5_SS3 = IOMUX_PAD(0x04F4, 0x01AC, 2, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA3__ESAI_TX_FS = IOMUX_PAD(0x04F4, 0x01AC, 3, 0x077C, 2, 0),
MX6_PAD_QSPI1B_DATA3__CSI1_DATA_19 = IOMUX_PAD(0x04F4, 0x01AC, 4, 0x06E8, 1, 0),
MX6_PAD_QSPI1B_DATA3__GPIO4_IO_27 = IOMUX_PAD(0x04F4, 0x01AC, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA3__WEIM_DATA_11 = IOMUX_PAD(0x04F4, 0x01AC, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DATA3__SIM_M_HADDR_2 = IOMUX_PAD(0x04F4, 0x01AC, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DQS__QSPI1_B_DQS = IOMUX_PAD(0x04F8, 0x01B0, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DQS__CAN1_TX = IOMUX_PAD(0x04F8, 0x01B0, 1, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DQS__CANFD_TX1 = IOMUX_PAD(0x04F8, 0x01B0, 2, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DQS__ECSPI5_SS0 = IOMUX_PAD(0x04F8, 0x01B0, 3, 0x075C, 1, 0),
MX6_PAD_QSPI1B_DQS__CSI1_DATA_23 = IOMUX_PAD(0x04F8, 0x01B0, 4, 0x06F8, 1, 0),
MX6_PAD_QSPI1B_DQS__GPIO4_IO_28 = IOMUX_PAD(0x04F8, 0x01B0, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DQS__WEIM_DATA_15 = IOMUX_PAD(0x04F8, 0x01B0, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1B_DQS__SIM_M_HADDR_15 = IOMUX_PAD(0x04F8, 0x01B0, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SCLK__QSPI1_B_SCLK = IOMUX_PAD(0x04FC, 0x01B4, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SCLK__UART3_RX = IOMUX_PAD(0x04FC, 0x01B4, 1, 0x0840, 4, 0),
MX6_PAD_QSPI1B_SCLK__ECSPI3_SCLK = IOMUX_PAD(0x04FC, 0x01B4, 2, 0x0730, 1, 0),
MX6_PAD_QSPI1B_SCLK__ESAI_RX_HF_CLK = IOMUX_PAD(0x04FC, 0x01B4, 3, 0x0780, 2, 0),
MX6_PAD_QSPI1B_SCLK__CSI1_DATA_16 = IOMUX_PAD(0x04FC, 0x01B4, 4, 0x06DC, 1, 0),
MX6_PAD_QSPI1B_SCLK__GPIO4_IO_29 = IOMUX_PAD(0x04FC, 0x01B4, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SCLK__WEIM_DATA_8 = IOMUX_PAD(0x04FC, 0x01B4, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SCLK__SIM_M_HADDR_11 = IOMUX_PAD(0x04FC, 0x01B4, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SS0_B__QSPI1_B_SS0_B = IOMUX_PAD(0x0500, 0x01B8, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SS0_B__UART3_TX = IOMUX_PAD(0x0500, 0x01B8, 1, 0x0840, 5, 0),
MX6_PAD_QSPI1B_SS0_B__ECSPI3_SS0 = IOMUX_PAD(0x0500, 0x01B8, 2, 0x073C, 1, 0),
MX6_PAD_QSPI1B_SS0_B__ESAI_TX_HF_CLK = IOMUX_PAD(0x0500, 0x01B8, 3, 0x0784, 3, 0),
MX6_PAD_QSPI1B_SS0_B__CSI1_DATA_17 = IOMUX_PAD(0x0500, 0x01B8, 4, 0x06E0, 1, 0),
MX6_PAD_QSPI1B_SS0_B__GPIO4_IO_30 = IOMUX_PAD(0x0500, 0x01B8, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SS0_B__WEIM_DATA_9 = IOMUX_PAD(0x0500, 0x01B8, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SS0_B__SIM_M_HADDR_10 = IOMUX_PAD(0x0500, 0x01B8, 7, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SS1_B__QSPI1_B_SS1_B = IOMUX_PAD(0x0504, 0x01BC, 0, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SS1_B__CAN2_RX = IOMUX_PAD(0x0504, 0x01BC, 1, 0x0690, 2, 0),
MX6_PAD_QSPI1B_SS1_B__CANFD_RX2 = IOMUX_PAD(0x0504, 0x01BC, 2, 0x0698, 2, 0),
MX6_PAD_QSPI1B_SS1_B__ECSPI5_SCLK = IOMUX_PAD(0x0504, 0x01BC, 3, 0x0750, 1, 0),
MX6_PAD_QSPI1B_SS1_B__CSI1_DATA_18 = IOMUX_PAD(0x0504, 0x01BC, 4, 0x06E4, 1, 0),
MX6_PAD_QSPI1B_SS1_B__GPIO4_IO_31 = IOMUX_PAD(0x0504, 0x01BC, 5, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SS1_B__WEIM_DATA_10 = IOMUX_PAD(0x0504, 0x01BC, 6, 0x0000, 0, 0),
MX6_PAD_QSPI1B_SS1_B__SIM_M_HADDR_14 = IOMUX_PAD(0x0504, 0x01BC, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD0__ENET1_RX_DATA_0 = IOMUX_PAD(0x0508, 0x01C0, 0, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD0__GPIO5_IO_0 = IOMUX_PAD(0x0508, 0x01C0, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD0__CSI2_DATA_10 = IOMUX_PAD(0x0508, 0x01C0, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD0__ANATOP_TESTI_0 = IOMUX_PAD(0x0508, 0x01C0, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD0__RAWNAND_TESTER_TRIGGER = IOMUX_PAD(0x0508, 0x01C0, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD0__PCIE_CTRL_DEBUG_0 = IOMUX_PAD(0x0508, 0x01C0, 9, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD1__ENET1_RX_DATA_1 = IOMUX_PAD(0x050C, 0x01C4, 0, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD1__GPIO5_IO_1 = IOMUX_PAD(0x050C, 0x01C4, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD1__CSI2_DATA_11 = IOMUX_PAD(0x050C, 0x01C4, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD1__ANATOP_TESTI_1 = IOMUX_PAD(0x050C, 0x01C4, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD1__USDHC1_TESTER_TRIGGER = IOMUX_PAD(0x050C, 0x01C4, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD1__PCIE_CTRL_DEBUG_1 = IOMUX_PAD(0x050C, 0x01C4, 9, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD2__ENET1_RX_DATA_2 = IOMUX_PAD(0x0510, 0x01C8, 0, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD2__GPIO5_IO_2 = IOMUX_PAD(0x0510, 0x01C8, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD2__CSI2_DATA_12 = IOMUX_PAD(0x0510, 0x01C8, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD2__ANATOP_TESTI_2 = IOMUX_PAD(0x0510, 0x01C8, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD2__USDHC2_TESTER_TRIGGER = IOMUX_PAD(0x0510, 0x01C8, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD2__PCIE_CTRL_DEBUG_2 = IOMUX_PAD(0x0510, 0x01C8, 9, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD3__ENET1_RX_DATA_3 = IOMUX_PAD(0x0514, 0x01CC, 0, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD3__GPIO5_IO_3 = IOMUX_PAD(0x0514, 0x01CC, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD3__CSI2_DATA_13 = IOMUX_PAD(0x0514, 0x01CC, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD3__ANATOP_TESTI_3 = IOMUX_PAD(0x0514, 0x01CC, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD3__USDHC3_TESTER_TRIGGER = IOMUX_PAD(0x0514, 0x01CC, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_RD3__PCIE_CTRL_DEBUG_3 = IOMUX_PAD(0x0514, 0x01CC, 9, 0x0000, 0, 0),
MX6_PAD_RGMII1_RX_CTL__ENET1_RX_EN = IOMUX_PAD(0x0518, 0x01D0, 0, 0x0000, 0, 0),
MX6_PAD_RGMII1_RX_CTL__GPIO5_IO_4 = IOMUX_PAD(0x0518, 0x01D0, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_RX_CTL__CSI2_DATA_14 = IOMUX_PAD(0x0518, 0x01D0, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_RX_CTL__ANATOP_TESTO_0 = IOMUX_PAD(0x0518, 0x01D0, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_RX_CTL__USDHC4_TESTER_TRIGGER = IOMUX_PAD(0x0518, 0x01D0, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_RX_CTL__PCIE_CTRL_DEBUG_4 = IOMUX_PAD(0x0518, 0x01D0, 9, 0x0000, 0, 0),
MX6_PAD_RGMII1_RXC__ENET1_RX_CLK = IOMUX_PAD(0x051C, 0x01D4, 0, 0x0768, 1, 0),
MX6_PAD_RGMII1_RXC__ENET1_RX_ER = IOMUX_PAD(0x051C, 0x01D4, 1, 0x0000, 0, 0),
MX6_PAD_RGMII1_RXC__GPIO5_IO_5 = IOMUX_PAD(0x051C, 0x01D4, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_RXC__CSI2_DATA_15 = IOMUX_PAD(0x051C, 0x01D4, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_RXC__ANATOP_TESTO_1 = IOMUX_PAD(0x051C, 0x01D4, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_RXC__ECSPI1_TESTER_TRIGGER = IOMUX_PAD(0x051C, 0x01D4, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_RXC__PCIE_CTRL_DEBUG_5 = IOMUX_PAD(0x051C, 0x01D4, 9, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD0__ENET1_TX_DATA_0 = IOMUX_PAD(0x0520, 0x01D8, 0, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD0__SAI2_RX_SYNC = IOMUX_PAD(0x0520, 0x01D8, 2, 0x0810, 1, 0),
MX6_PAD_RGMII1_TD0__GPIO5_IO_6 = IOMUX_PAD(0x0520, 0x01D8, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD0__CSI2_DATA_16 = IOMUX_PAD(0x0520, 0x01D8, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD0__ANATOP_TESTO_2 = IOMUX_PAD(0x0520, 0x01D8, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD0__ECSPI2_TESTER_TRIGGER = IOMUX_PAD(0x0520, 0x01D8, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD0__PCIE_CTRL_DEBUG_6 = IOMUX_PAD(0x0520, 0x01D8, 9, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD1__ENET1_TX_DATA_1 = IOMUX_PAD(0x0524, 0x01DC, 0, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD1__SAI2_RX_BCLK = IOMUX_PAD(0x0524, 0x01DC, 2, 0x0808, 1, 0),
MX6_PAD_RGMII1_TD1__GPIO5_IO_7 = IOMUX_PAD(0x0524, 0x01DC, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD1__CSI2_DATA_17 = IOMUX_PAD(0x0524, 0x01DC, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD1__ANATOP_TESTO_3 = IOMUX_PAD(0x0524, 0x01DC, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD1__ECSPI3_TESTER_TRIGGER = IOMUX_PAD(0x0524, 0x01DC, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD1__PCIE_CTRL_DEBUG_7 = IOMUX_PAD(0x0524, 0x01DC, 9, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD2__ENET1_TX_DATA_2 = IOMUX_PAD(0x0528, 0x01E0, 0, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD2__SAI2_TX_SYNC = IOMUX_PAD(0x0528, 0x01E0, 2, 0x0818, 1, 0),
MX6_PAD_RGMII1_TD2__GPIO5_IO_8 = IOMUX_PAD(0x0528, 0x01E0, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD2__CSI2_DATA_18 = IOMUX_PAD(0x0528, 0x01E0, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD2__ANATOP_TESTO_4 = IOMUX_PAD(0x0528, 0x01E0, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD2__ECSPI4_TESTER_TRIGGER = IOMUX_PAD(0x0528, 0x01E0, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD2__PCIE_CTRL_DEBUG_8 = IOMUX_PAD(0x0528, 0x01E0, 9, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD3__ENET1_TX_DATA_3 = IOMUX_PAD(0x052C, 0x01E4, 0, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD3__SAI2_TX_BCLK = IOMUX_PAD(0x052C, 0x01E4, 2, 0x0814, 1, 0),
MX6_PAD_RGMII1_TD3__GPIO5_IO_9 = IOMUX_PAD(0x052C, 0x01E4, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD3__CSI2_DATA_19 = IOMUX_PAD(0x052C, 0x01E4, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD3__ANATOP_TESTO_5 = IOMUX_PAD(0x052C, 0x01E4, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD3__ECSPI5_TESTER_TRIGGER = IOMUX_PAD(0x052C, 0x01E4, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_TD3__PCIE_CTRL_DEBUG_9 = IOMUX_PAD(0x052C, 0x01E4, 9, 0x0000, 0, 0),
MX6_PAD_RGMII1_TX_CTL__ENET1_TX_EN = IOMUX_PAD(0x0530, 0x01E8, 0, 0x0000, 0, 0),
MX6_PAD_RGMII1_TX_CTL__SAI2_RX_DATA_0 = IOMUX_PAD(0x0530, 0x01E8, 2, 0x080C, 1, 0),
MX6_PAD_RGMII1_TX_CTL__GPIO5_IO_10 = IOMUX_PAD(0x0530, 0x01E8, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_TX_CTL__CSI2_DATA_0 = IOMUX_PAD(0x0530, 0x01E8, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_TX_CTL__ANATOP_TESTO_6 = IOMUX_PAD(0x0530, 0x01E8, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_TX_CTL__QSPI1_TESTER_TRIGGER = IOMUX_PAD(0x0530, 0x01E8, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_TX_CTL__PCIE_CTRL_DEBUG_10 = IOMUX_PAD(0x0530, 0x01E8, 9, 0x0000, 0, 0),
MX6_PAD_RGMII1_TXC__ENET1_RGMII_TXC = IOMUX_PAD(0x0534, 0x01EC, 0, 0x0000, 0, 0),
MX6_PAD_RGMII1_TXC__ENET1_TX_ER = IOMUX_PAD(0x0534, 0x01EC, 1, 0x0000, 0, 0),
MX6_PAD_RGMII1_TXC__SAI2_TX_DATA_0 = IOMUX_PAD(0x0534, 0x01EC, 2, 0x0000, 0, 0),
MX6_PAD_RGMII1_TXC__GPIO5_IO_11 = IOMUX_PAD(0x0534, 0x01EC, 5, 0x0000, 0, 0),
MX6_PAD_RGMII1_TXC__CSI2_DATA_1 = IOMUX_PAD(0x0534, 0x01EC, 6, 0x0000, 0, 0),
MX6_PAD_RGMII1_TXC__ANATOP_TESTO_7 = IOMUX_PAD(0x0534, 0x01EC, 7, 0x0000, 0, 0),
MX6_PAD_RGMII1_TXC__QSPI2_TESTER_TRIGGER = IOMUX_PAD(0x0534, 0x01EC, 8, 0x0000, 0, 0),
MX6_PAD_RGMII1_TXC__PCIE_CTRL_DEBUG_11 = IOMUX_PAD(0x0534, 0x01EC, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD0__ENET2_RX_DATA_0 = IOMUX_PAD(0x0538, 0x01F0, 0, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD0__PWM4_OUT = IOMUX_PAD(0x0538, 0x01F0, 2, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD0__GPIO5_IO_12 = IOMUX_PAD(0x0538, 0x01F0, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD0__CSI2_DATA_2 = IOMUX_PAD(0x0538, 0x01F0, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD0__ANATOP_TESTO_8 = IOMUX_PAD(0x0538, 0x01F0, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD0__VDEC_DEBUG_18 = IOMUX_PAD(0x0538, 0x01F0, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD0__PCIE_CTRL_DEBUG_12 = IOMUX_PAD(0x0538, 0x01F0, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD1__ENET2_RX_DATA_1 = IOMUX_PAD(0x053C, 0x01F4, 0, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD1__PWM3_OUT = IOMUX_PAD(0x053C, 0x01F4, 2, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD1__GPIO5_IO_13 = IOMUX_PAD(0x053C, 0x01F4, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD1__CSI2_DATA_3 = IOMUX_PAD(0x053C, 0x01F4, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD1__ANATOP_TESTO_9 = IOMUX_PAD(0x053C, 0x01F4, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD1__VDEC_DEBUG_19 = IOMUX_PAD(0x053C, 0x01F4, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD1__PCIE_CTRL_DEBUG_13 = IOMUX_PAD(0x053C, 0x01F4, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD2__ENET2_RX_DATA_2 = IOMUX_PAD(0x0540, 0x01F8, 0, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD2__PWM2_OUT = IOMUX_PAD(0x0540, 0x01F8, 2, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD2__GPIO5_IO_14 = IOMUX_PAD(0x0540, 0x01F8, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD2__CSI2_DATA_4 = IOMUX_PAD(0x0540, 0x01F8, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD2__ANATOP_TESTO_10 = IOMUX_PAD(0x0540, 0x01F8, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD2__VDEC_DEBUG_20 = IOMUX_PAD(0x0540, 0x01F8, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD2__PCIE_CTRL_DEBUG_14 = IOMUX_PAD(0x0540, 0x01F8, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD3__ENET2_RX_DATA_3 = IOMUX_PAD(0x0544, 0x01FC, 0, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD3__PWM1_OUT = IOMUX_PAD(0x0544, 0x01FC, 2, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD3__GPIO5_IO_15 = IOMUX_PAD(0x0544, 0x01FC, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD3__CSI2_DATA_5 = IOMUX_PAD(0x0544, 0x01FC, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD3__ANATOP_TESTO_11 = IOMUX_PAD(0x0544, 0x01FC, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD3__VDEC_DEBUG_21 = IOMUX_PAD(0x0544, 0x01FC, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_RD3__PCIE_CTRL_DEBUG_15 = IOMUX_PAD(0x0544, 0x01FC, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_RX_CTL__ENET2_RX_EN = IOMUX_PAD(0x0548, 0x0200, 0, 0x0000, 0, 0),
MX6_PAD_RGMII2_RX_CTL__GPIO5_IO_16 = IOMUX_PAD(0x0548, 0x0200, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_RX_CTL__CSI2_DATA_6 = IOMUX_PAD(0x0548, 0x0200, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_RX_CTL__ANATOP_TESTO_12 = IOMUX_PAD(0x0548, 0x0200, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_RX_CTL__VDEC_DEBUG_22 = IOMUX_PAD(0x0548, 0x0200, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_RX_CTL__PCIE_CTRL_DEBUG_16 = IOMUX_PAD(0x0548, 0x0200, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_RXC__ENET2_RX_CLK = IOMUX_PAD(0x054C, 0x0204, 0, 0x0774, 1, 0),
MX6_PAD_RGMII2_RXC__ENET2_RX_ER = IOMUX_PAD(0x054C, 0x0204, 1, 0x0000, 0, 0),
MX6_PAD_RGMII2_RXC__GPIO5_IO_17 = IOMUX_PAD(0x054C, 0x0204, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_RXC__CSI2_DATA_7 = IOMUX_PAD(0x054C, 0x0204, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_RXC__ANATOP_TESTO_13 = IOMUX_PAD(0x054C, 0x0204, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_RXC__VDEC_DEBUG_23 = IOMUX_PAD(0x054C, 0x0204, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_RXC__PCIE_CTRL_DEBUG_17 = IOMUX_PAD(0x054C, 0x0204, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD0__ENET2_TX_DATA_0 = IOMUX_PAD(0x0550, 0x0208, 0, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD0__SAI1_RX_SYNC = IOMUX_PAD(0x0550, 0x0208, 2, 0x07FC, 1, 0),
MX6_PAD_RGMII2_TD0__PWM8_OUT = IOMUX_PAD(0x0550, 0x0208, 3, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD0__GPIO5_IO_18 = IOMUX_PAD(0x0550, 0x0208, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD0__CSI2_DATA_8 = IOMUX_PAD(0x0550, 0x0208, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD0__ANATOP_TESTO_14 = IOMUX_PAD(0x0550, 0x0208, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD0__VDEC_DEBUG_24 = IOMUX_PAD(0x0550, 0x0208, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD0__PCIE_CTRL_DEBUG_18 = IOMUX_PAD(0x0550, 0x0208, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD1__ENET2_TX_DATA_1 = IOMUX_PAD(0x0554, 0x020C, 0, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD1__SAI1_RX_BCLK = IOMUX_PAD(0x0554, 0x020C, 2, 0x07F4, 1, 0),
MX6_PAD_RGMII2_TD1__PWM7_OUT = IOMUX_PAD(0x0554, 0x020C, 3, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD1__GPIO5_IO_19 = IOMUX_PAD(0x0554, 0x020C, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD1__CSI2_DATA_9 = IOMUX_PAD(0x0554, 0x020C, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD1__ANATOP_TESTO_15 = IOMUX_PAD(0x0554, 0x020C, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD1__VDEC_DEBUG_25 = IOMUX_PAD(0x0554, 0x020C, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD1__PCIE_CTRL_DEBUG_19 = IOMUX_PAD(0x0554, 0x020C, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD2__ENET2_TX_DATA_2 = IOMUX_PAD(0x0558, 0x0210, 0, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD2__SAI1_TX_SYNC = IOMUX_PAD(0x0558, 0x0210, 2, 0x0804, 1, 0),
MX6_PAD_RGMII2_TD2__PWM6_OUT = IOMUX_PAD(0x0558, 0x0210, 3, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD2__GPIO5_IO_20 = IOMUX_PAD(0x0558, 0x0210, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD2__CSI2_VSYNC = IOMUX_PAD(0x0558, 0x0210, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD2__SJC_FAIL = IOMUX_PAD(0x0558, 0x0210, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD2__VDEC_DEBUG_26 = IOMUX_PAD(0x0558, 0x0210, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD2__PCIE_CTRL_DEBUG_20 = IOMUX_PAD(0x0558, 0x0210, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD3__ENET2_TX_DATA_3 = IOMUX_PAD(0x055C, 0x0214, 0, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD3__SAI1_TX_BCLK = IOMUX_PAD(0x055C, 0x0214, 2, 0x0800, 1, 0),
MX6_PAD_RGMII2_TD3__PWM5_OUT = IOMUX_PAD(0x055C, 0x0214, 3, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD3__GPIO5_IO_21 = IOMUX_PAD(0x055C, 0x0214, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD3__CSI2_HSYNC = IOMUX_PAD(0x055C, 0x0214, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD3__SJC_JTAG_ACT = IOMUX_PAD(0x055C, 0x0214, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD3__VDEC_DEBUG_27 = IOMUX_PAD(0x055C, 0x0214, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_TD3__PCIE_CTRL_DEBUG_21 = IOMUX_PAD(0x055C, 0x0214, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_TX_CTL__ENET2_TX_EN = IOMUX_PAD(0x0560, 0x0218, 0, 0x0000, 0, 0),
MX6_PAD_RGMII2_TX_CTL__SAI1_RX_DATA_0 = IOMUX_PAD(0x0560, 0x0218, 2, 0x07F8, 1, 0),
MX6_PAD_RGMII2_TX_CTL__GPIO5_IO_22 = IOMUX_PAD(0x0560, 0x0218, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_TX_CTL__CSI2_FIELD = IOMUX_PAD(0x0560, 0x0218, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_TX_CTL__SJC_DE_B = IOMUX_PAD(0x0560, 0x0218, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_TX_CTL__VDEC_DEBUG_28 = IOMUX_PAD(0x0560, 0x0218, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_TX_CTL__PCIE_CTRL_DEBUG_22 = IOMUX_PAD(0x0560, 0x0218, 9, 0x0000, 0, 0),
MX6_PAD_RGMII2_TXC__ENET2_RGMII_TXC = IOMUX_PAD(0x0564, 0x021C, 0, 0x0000, 0, 0),
MX6_PAD_RGMII2_TXC__ENET2_TX_ER = IOMUX_PAD(0x0564, 0x021C, 1, 0x0000, 0, 0),
MX6_PAD_RGMII2_TXC__SAI1_TX_DATA_0 = IOMUX_PAD(0x0564, 0x021C, 2, 0x0000, 0, 0),
MX6_PAD_RGMII2_TXC__GPIO5_IO_23 = IOMUX_PAD(0x0564, 0x021C, 5, 0x0000, 0, 0),
MX6_PAD_RGMII2_TXC__CSI2_PIXCLK = IOMUX_PAD(0x0564, 0x021C, 6, 0x0000, 0, 0),
MX6_PAD_RGMII2_TXC__SJC_DONE = IOMUX_PAD(0x0564, 0x021C, 7, 0x0000, 0, 0),
MX6_PAD_RGMII2_TXC__VDEC_DEBUG_29 = IOMUX_PAD(0x0564, 0x021C, 8, 0x0000, 0, 0),
MX6_PAD_RGMII2_TXC__PCIE_CTRL_DEBUG_23 = IOMUX_PAD(0x0564, 0x021C, 9, 0x0000, 0, 0),
MX6_PAD_SD1_CLK__USDHC1_CLK = IOMUX_PAD(0x0568, 0x0220, 0, 0x0000, 0, 0),
MX6_PAD_SD1_CLK__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x0568, 0x0220, 1, 0x0668, 1, 0),
MX6_PAD_SD1_CLK__WDOG2_WDOG_B = IOMUX_PAD(0x0568, 0x0220, 2, 0x0000, 0, 0),
MX6_PAD_SD1_CLK__GPT_CLK = IOMUX_PAD(0x0568, 0x0220, 3, 0x0000, 0, 0),
MX6_PAD_SD1_CLK__WDOG2_WDOG_RST_B_DEB = IOMUX_PAD(0x0568, 0x0220, 4, 0x0000, 0, 0),
MX6_PAD_SD1_CLK__GPIO6_IO_0 = IOMUX_PAD(0x0568, 0x0220, 5, 0x0000, 0, 0),
MX6_PAD_SD1_CLK__ENET2_1588_EVENT1_OUT = IOMUX_PAD(0x0568, 0x0220, 6, 0x0000, 0, 0),
MX6_PAD_SD1_CLK__CCM_OUT1 = IOMUX_PAD(0x0568, 0x0220, 7, 0x0000, 0, 0),
MX6_PAD_SD1_CLK__VADC_ADC_PROC_CLK = IOMUX_PAD(0x0568, 0x0220, 8, 0x0000, 0, 0),
MX6_PAD_SD1_CLK__MMDC_DEBUG_45 = IOMUX_PAD(0x0568, 0x0220, 9, 0x0000, 0, 0),
MX6_PAD_SD1_CMD__USDHC1_CMD = IOMUX_PAD(0x056C, 0x0224, 0, 0x0000, 0, 0),
MX6_PAD_SD1_CMD__AUDMUX_AUD5_RXC = IOMUX_PAD(0x056C, 0x0224, 1, 0x0664, 1, 0),
MX6_PAD_SD1_CMD__WDOG1_WDOG_B = IOMUX_PAD(0x056C, 0x0224, 2, 0x0000, 0, 0),
MX6_PAD_SD1_CMD__GPT_COMPARE1 = IOMUX_PAD(0x056C, 0x0224, 3, 0x0000, 0, 0),
MX6_PAD_SD1_CMD__WDOG1_WDOG_RST_B_DEB = IOMUX_PAD(0x056C, 0x0224, 4, 0x0000, 0, 0),
MX6_PAD_SD1_CMD__GPIO6_IO_1 = IOMUX_PAD(0x056C, 0x0224, 5, 0x0000, 0, 0),
MX6_PAD_SD1_CMD__ENET2_1588_EVENT1_IN = IOMUX_PAD(0x056C, 0x0224, 6, 0x0000, 0, 0),
MX6_PAD_SD1_CMD__CCM_CLKO1 = IOMUX_PAD(0x056C, 0x0224, 7, 0x0000, 0, 0),
MX6_PAD_SD1_CMD__VADC_EXT_SYSCLK = IOMUX_PAD(0x056C, 0x0224, 8, 0x0000, 0, 0),
MX6_PAD_SD1_CMD__MMDC_DEBUG_46 = IOMUX_PAD(0x056C, 0x0224, 9, 0x0000, 0, 0),
MX6_PAD_SD1_DATA0__USDHC1_DATA0 = IOMUX_PAD(0x0570, 0x0228, 0, 0x0000, 0, 0),
MX6_PAD_SD1_DATA0__AUDMUX_AUD5_RXD = IOMUX_PAD(0x0570, 0x0228, 1, 0x065C, 1, 0),
MX6_PAD_SD1_DATA0__CAAM_WRAPPER_RNG_OSC_OBS = IOMUX_PAD(0x0570, 0x0228, 2, 0x0000, 0, 0),
MX6_PAD_SD1_DATA0__GPT_CAPTURE1 = IOMUX_PAD(0x0570, 0x0228, 3, 0x0000, 0, 0),
MX6_PAD_SD1_DATA0__UART2_RX = IOMUX_PAD(0x0570, 0x0228, 4, 0x0838, 2, 0),
MX6_PAD_SD1_DATA0__GPIO6_IO_2 = IOMUX_PAD(0x0570, 0x0228, 5, 0x0000, 0, 0),
MX6_PAD_SD1_DATA0__ENET1_1588_EVENT1_IN = IOMUX_PAD(0x0570, 0x0228, 6, 0x0000, 0, 0),
MX6_PAD_SD1_DATA0__CCM_OUT2 = IOMUX_PAD(0x0570, 0x0228, 7, 0x0000, 0, 0),
MX6_PAD_SD1_DATA0__VADC_CLAMP_UP = IOMUX_PAD(0x0570, 0x0228, 8, 0x0000, 0, 0),
MX6_PAD_SD1_DATA0__MMDC_DEBUG_48 = IOMUX_PAD(0x0570, 0x0228, 9, 0x0000, 0, 0),
MX6_PAD_SD1_DATA1__USDHC1_DATA1 = IOMUX_PAD(0x0574, 0x022C, 0, 0x0000, 0, 0),
MX6_PAD_SD1_DATA1__AUDMUX_AUD5_TXC = IOMUX_PAD(0x0574, 0x022C, 1, 0x066C, 1, 0),
MX6_PAD_SD1_DATA1__PWM4_OUT = IOMUX_PAD(0x0574, 0x022C, 2, 0x0000, 0, 0),
MX6_PAD_SD1_DATA1__GPT_CAPTURE2 = IOMUX_PAD(0x0574, 0x022C, 3, 0x0000, 0, 0),
MX6_PAD_SD1_DATA1__UART2_TX = IOMUX_PAD(0x0574, 0x022C, 4, 0x0838, 3, 0),
MX6_PAD_SD1_DATA1__GPIO6_IO_3 = IOMUX_PAD(0x0574, 0x022C, 5, 0x0000, 0, 0),
MX6_PAD_SD1_DATA1__ENET1_1588_EVENT1_OUT = IOMUX_PAD(0x0574, 0x022C, 6, 0x0000, 0, 0),
MX6_PAD_SD1_DATA1__CCM_CLKO2 = IOMUX_PAD(0x0574, 0x022C, 7, 0x0000, 0, 0),
MX6_PAD_SD1_DATA1__VADC_CLAMP_DOWN = IOMUX_PAD(0x0574, 0x022C, 8, 0x0000, 0, 0),
MX6_PAD_SD1_DATA1__MMDC_DEBUG_47 = IOMUX_PAD(0x0574, 0x022C, 9, 0x0000, 0, 0),
MX6_PAD_SD1_DATA2__USDHC1_DATA2 = IOMUX_PAD(0x0578, 0x0230, 0, 0x0000, 0, 0),
MX6_PAD_SD1_DATA2__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x0578, 0x0230, 1, 0x0670, 1, 0),
MX6_PAD_SD1_DATA2__PWM3_OUT = IOMUX_PAD(0x0578, 0x0230, 2, 0x0000, 0, 0),
MX6_PAD_SD1_DATA2__GPT_COMPARE2 = IOMUX_PAD(0x0578, 0x0230, 3, 0x0000, 0, 0),
MX6_PAD_SD1_DATA2__UART2_CTS_B = IOMUX_PAD(0x0578, 0x0230, 4, 0x0834, 2, 0),
MX6_PAD_SD1_DATA2__GPIO6_IO_4 = IOMUX_PAD(0x0578, 0x0230, 5, 0x0000, 0, 0),
MX6_PAD_SD1_DATA2__ECSPI4_RDY = IOMUX_PAD(0x0578, 0x0230, 6, 0x0000, 0, 0),
MX6_PAD_SD1_DATA2__CCM_OUT0 = IOMUX_PAD(0x0578, 0x0230, 7, 0x0000, 0, 0),
MX6_PAD_SD1_DATA2__VADC_EXT_PD_N = IOMUX_PAD(0x0578, 0x0230, 8, 0x0000, 0, 0),
MX6_PAD_SD1_DATA3__USDHC1_DATA3 = IOMUX_PAD(0x057C, 0x0234, 0, 0x0000, 0, 0),
MX6_PAD_SD1_DATA3__AUDMUX_AUD5_TXD = IOMUX_PAD(0x057C, 0x0234, 1, 0x0660, 1, 0),
MX6_PAD_SD1_DATA3__AUDMUX_AUD5_RXD = IOMUX_PAD(0x057C, 0x0234, 2, 0x065C, 2, 0),
MX6_PAD_SD1_DATA3__GPT_COMPARE3 = IOMUX_PAD(0x057C, 0x0234, 3, 0x0000, 0, 0),
MX6_PAD_SD1_DATA3__UART2_RTS_B = IOMUX_PAD(0x057C, 0x0234, 4, 0x0834, 3, 0),
MX6_PAD_SD1_DATA3__GPIO6_IO_5 = IOMUX_PAD(0x057C, 0x0234, 5, 0x0000, 0, 0),
MX6_PAD_SD1_DATA3__ECSPI4_SS1 = IOMUX_PAD(0x057C, 0x0234, 6, 0x0000, 0, 0),
MX6_PAD_SD1_DATA3__CCM_PMIC_RDY = IOMUX_PAD(0x057C, 0x0234, 7, 0x069C, 2, 0),
MX6_PAD_SD1_DATA3__VADC_RST_N = IOMUX_PAD(0x057C, 0x0234, 8, 0x0000, 0, 0),
MX6_PAD_SD2_CLK__USDHC2_CLK = IOMUX_PAD(0x0580, 0x0238, 0, 0x0000, 0, 0),
MX6_PAD_SD2_CLK__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x0580, 0x0238, 1, 0x0680, 2, 0),
MX6_PAD_SD2_CLK__KPP_COL_5 = IOMUX_PAD(0x0580, 0x0238, 2, 0x07C8, 1, 0),
MX6_PAD_SD2_CLK__ECSPI4_SCLK = IOMUX_PAD(0x0580, 0x0238, 3, 0x0740, 1, 0),
MX6_PAD_SD2_CLK__MLB_SIG = IOMUX_PAD(0x0580, 0x0238, 4, 0x07F0, 2, 0),
MX6_PAD_SD2_CLK__GPIO6_IO_6 = IOMUX_PAD(0x0580, 0x0238, 5, 0x0000, 0, 0),
MX6_PAD_SD2_CLK__MQS_RIGHT = IOMUX_PAD(0x0580, 0x0238, 6, 0x0000, 0, 0),
MX6_PAD_SD2_CLK__WDOG1_WDOG_ANY = IOMUX_PAD(0x0580, 0x0238, 7, 0x0000, 0, 0),
MX6_PAD_SD2_CLK__VADC_CLAMP_CURRENT_5 = IOMUX_PAD(0x0580, 0x0238, 8, 0x0000, 0, 0),
MX6_PAD_SD2_CLK__MMDC_DEBUG_29 = IOMUX_PAD(0x0580, 0x0238, 9, 0x0000, 0, 0),
MX6_PAD_SD2_CMD__USDHC2_CMD = IOMUX_PAD(0x0584, 0x023C, 0, 0x0000, 0, 0),
MX6_PAD_SD2_CMD__AUDMUX_AUD6_RXC = IOMUX_PAD(0x0584, 0x023C, 1, 0x067C, 2, 0),
MX6_PAD_SD2_CMD__KPP_ROW_5 = IOMUX_PAD(0x0584, 0x023C, 2, 0x07D4, 1, 0),
MX6_PAD_SD2_CMD__ECSPI4_MOSI = IOMUX_PAD(0x0584, 0x023C, 3, 0x0748, 1, 0),
MX6_PAD_SD2_CMD__MLB_CLK = IOMUX_PAD(0x0584, 0x023C, 4, 0x07E8, 2, 0),
MX6_PAD_SD2_CMD__GPIO6_IO_7 = IOMUX_PAD(0x0584, 0x023C, 5, 0x0000, 0, 0),
MX6_PAD_SD2_CMD__MQS_LEFT = IOMUX_PAD(0x0584, 0x023C, 6, 0x0000, 0, 0),
MX6_PAD_SD2_CMD__WDOG3_WDOG_B = IOMUX_PAD(0x0584, 0x023C, 7, 0x0000, 0, 0),
MX6_PAD_SD2_CMD__VADC_CLAMP_CURRENT_4 = IOMUX_PAD(0x0584, 0x023C, 8, 0x0000, 0, 0),
MX6_PAD_SD2_CMD__MMDC_DEBUG_30 = IOMUX_PAD(0x0584, 0x023C, 9, 0x0000, 0, 0),
MX6_PAD_SD2_DATA0__USDHC2_DATA0 = IOMUX_PAD(0x0588, 0x0240, 0, 0x0000, 0, 0),
MX6_PAD_SD2_DATA0__AUDMUX_AUD6_RXD = IOMUX_PAD(0x0588, 0x0240, 1, 0x0674, 2, 0),
MX6_PAD_SD2_DATA0__KPP_ROW_7 = IOMUX_PAD(0x0588, 0x0240, 2, 0x07DC, 1, 0),
MX6_PAD_SD2_DATA0__PWM1_OUT = IOMUX_PAD(0x0588, 0x0240, 3, 0x0000, 0, 0),
MX6_PAD_SD2_DATA0__I2C4_SDA = IOMUX_PAD(0x0588, 0x0240, 4, 0x07C4, 3, 0),
MX6_PAD_SD2_DATA0__GPIO6_IO_8 = IOMUX_PAD(0x0588, 0x0240, 5, 0x0000, 0, 0),
MX6_PAD_SD2_DATA0__ECSPI4_SS3 = IOMUX_PAD(0x0588, 0x0240, 6, 0x0000, 0, 0),
MX6_PAD_SD2_DATA0__UART4_RX = IOMUX_PAD(0x0588, 0x0240, 7, 0x0848, 4, 0),
MX6_PAD_SD2_DATA0__VADC_CLAMP_CURRENT_0 = IOMUX_PAD(0x0588, 0x0240, 8, 0x0000, 0, 0),
MX6_PAD_SD2_DATA0__MMDC_DEBUG_50 = IOMUX_PAD(0x0588, 0x0240, 9, 0x0000, 0, 0),
MX6_PAD_SD2_DATA1__USDHC2_DATA1 = IOMUX_PAD(0x058C, 0x0244, 0, 0x0000, 0, 0),
MX6_PAD_SD2_DATA1__AUDMUX_AUD6_TXC = IOMUX_PAD(0x058C, 0x0244, 1, 0x0684, 2, 0),
MX6_PAD_SD2_DATA1__KPP_COL_7 = IOMUX_PAD(0x058C, 0x0244, 2, 0x07D0, 1, 0),
MX6_PAD_SD2_DATA1__PWM2_OUT = IOMUX_PAD(0x058C, 0x0244, 3, 0x0000, 0, 0),
MX6_PAD_SD2_DATA1__I2C4_SCL = IOMUX_PAD(0x058C, 0x0244, 4, 0x07C0, 3, 0),
MX6_PAD_SD2_DATA1__GPIO6_IO_9 = IOMUX_PAD(0x058C, 0x0244, 5, 0x0000, 0, 0),
MX6_PAD_SD2_DATA1__ECSPI4_SS2 = IOMUX_PAD(0x058C, 0x0244, 6, 0x0000, 0, 0),
MX6_PAD_SD2_DATA1__UART4_TX = IOMUX_PAD(0x058C, 0x0244, 7, 0x0848, 5, 0),
MX6_PAD_SD2_DATA1__VADC_CLAMP_CURRENT_1 = IOMUX_PAD(0x058C, 0x0244, 8, 0x0000, 0, 0),
MX6_PAD_SD2_DATA1__MMDC_DEBUG_49 = IOMUX_PAD(0x058C, 0x0244, 9, 0x0000, 0, 0),
MX6_PAD_SD2_DATA2__USDHC2_DATA2 = IOMUX_PAD(0x0590, 0x0248, 0, 0x0000, 0, 0),
MX6_PAD_SD2_DATA2__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x0590, 0x0248, 1, 0x0688, 2, 0),
MX6_PAD_SD2_DATA2__KPP_ROW_6 = IOMUX_PAD(0x0590, 0x0248, 2, 0x07D8, 1, 0),
MX6_PAD_SD2_DATA2__ECSPI4_SS0 = IOMUX_PAD(0x0590, 0x0248, 3, 0x074C, 1, 0),
MX6_PAD_SD2_DATA2__SDMA_EXT_EVENT_0 = IOMUX_PAD(0x0590, 0x0248, 4, 0x081C, 2, 0),
MX6_PAD_SD2_DATA2__GPIO6_IO_10 = IOMUX_PAD(0x0590, 0x0248, 5, 0x0000, 0, 0),
MX6_PAD_SD2_DATA2__SPDIF_OUT = IOMUX_PAD(0x0590, 0x0248, 6, 0x0000, 0, 0),
MX6_PAD_SD2_DATA2__UART6_RX = IOMUX_PAD(0x0590, 0x0248, 7, 0x0858, 4, 0),
MX6_PAD_SD2_DATA2__VADC_CLAMP_CURRENT_2 = IOMUX_PAD(0x0590, 0x0248, 8, 0x0000, 0, 0),
MX6_PAD_SD2_DATA2__MMDC_DEBUG_32 = IOMUX_PAD(0x0590, 0x0248, 9, 0x0000, 0, 0),
MX6_PAD_SD2_DATA3__USDHC2_DATA3 = IOMUX_PAD(0x0594, 0x024C, 0, 0x0000, 0, 0),
MX6_PAD_SD2_DATA3__AUDMUX_AUD6_TXD = IOMUX_PAD(0x0594, 0x024C, 1, 0x0678, 2, 0),
MX6_PAD_SD2_DATA3__KPP_COL_6 = IOMUX_PAD(0x0594, 0x024C, 2, 0x07CC, 1, 0),
MX6_PAD_SD2_DATA3__ECSPI4_MISO = IOMUX_PAD(0x0594, 0x024C, 3, 0x0744, 1, 0),
MX6_PAD_SD2_DATA3__MLB_DATA = IOMUX_PAD(0x0594, 0x024C, 4, 0x07EC, 2, 0),
MX6_PAD_SD2_DATA3__GPIO6_IO_11 = IOMUX_PAD(0x0594, 0x024C, 5, 0x0000, 0, 0),
MX6_PAD_SD2_DATA3__SPDIF_IN = IOMUX_PAD(0x0594, 0x024C, 6, 0x0824, 4, 0),
MX6_PAD_SD2_DATA3__UART6_TX = IOMUX_PAD(0x0594, 0x024C, 7, 0x0858, 5, 0),
MX6_PAD_SD2_DATA3__VADC_CLAMP_CURRENT_3 = IOMUX_PAD(0x0594, 0x024C, 8, 0x0000, 0, 0),
MX6_PAD_SD2_DATA3__MMDC_DEBUG_31 = IOMUX_PAD(0x0594, 0x024C, 9, 0x0000, 0, 0),
MX6_PAD_SD3_CLK__USDHC3_CLK = IOMUX_PAD(0x0598, 0x0250, 0, 0x0000, 0, 0),
MX6_PAD_SD3_CLK__UART4_CTS_B = IOMUX_PAD(0x0598, 0x0250, 1, 0x0844, 0, 0),
MX6_PAD_SD3_CLK__ECSPI4_SCLK = IOMUX_PAD(0x0598, 0x0250, 2, 0x0740, 0, 0),
MX6_PAD_SD3_CLK__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x0598, 0x0250, 3, 0x0680, 0, 0),
MX6_PAD_SD3_CLK__LCDIF2_VSYNC = IOMUX_PAD(0x0598, 0x0250, 4, 0x0000, 0, 0),
MX6_PAD_SD3_CLK__GPIO7_IO_0 = IOMUX_PAD(0x0598, 0x0250, 5, 0x0000, 0, 0),
MX6_PAD_SD3_CLK__LCDIF2_BUSY = IOMUX_PAD(0x0598, 0x0250, 6, 0x07E4, 0, 0),
MX6_PAD_SD3_CLK__TPSMP_HDATA_29 = IOMUX_PAD(0x0598, 0x0250, 7, 0x0000, 0, 0),
MX6_PAD_SD3_CLK__SDMA_DEBUG_EVENT_CHANNEL_5 = IOMUX_PAD(0x0598, 0x0250, 9, 0x0000, 0, 0),
MX6_PAD_SD3_CMD__USDHC3_CMD = IOMUX_PAD(0x059C, 0x0254, 0, 0x0000, 0, 0),
MX6_PAD_SD3_CMD__UART4_TX = IOMUX_PAD(0x059C, 0x0254, 1, 0x0848, 0, 0),
MX6_PAD_SD3_CMD__ECSPI4_MOSI = IOMUX_PAD(0x059C, 0x0254, 2, 0x0748, 0, 0),
MX6_PAD_SD3_CMD__AUDMUX_AUD6_RXC = IOMUX_PAD(0x059C, 0x0254, 3, 0x067C, 0, 0),
MX6_PAD_SD3_CMD__LCDIF2_HSYNC = IOMUX_PAD(0x059C, 0x0254, 4, 0x07E4, 1, 0),
MX6_PAD_SD3_CMD__GPIO7_IO_1 = IOMUX_PAD(0x059C, 0x0254, 5, 0x0000, 0, 0),
MX6_PAD_SD3_CMD__LCDIF2_RS = IOMUX_PAD(0x059C, 0x0254, 6, 0x0000, 0, 0),
MX6_PAD_SD3_CMD__TPSMP_HDATA_28 = IOMUX_PAD(0x059C, 0x0254, 7, 0x0000, 0, 0),
MX6_PAD_SD3_CMD__SDMA_DEBUG_EVENT_CHANNEL_4 = IOMUX_PAD(0x059C, 0x0254, 9, 0x0000, 0, 0),
MX6_PAD_SD3_DATA0__USDHC3_DATA0 = IOMUX_PAD(0x05A0, 0x0258, 0, 0x0000, 0, 0),
MX6_PAD_SD3_DATA0__I2C4_SCL = IOMUX_PAD(0x05A0, 0x0258, 1, 0x07C0, 0, 0),
MX6_PAD_SD3_DATA0__ECSPI2_SS1 = IOMUX_PAD(0x05A0, 0x0258, 2, 0x0000, 0, 0),
MX6_PAD_SD3_DATA0__AUDMUX_AUD6_RXD = IOMUX_PAD(0x05A0, 0x0258, 3, 0x0674, 0, 0),
MX6_PAD_SD3_DATA0__LCDIF2_DATA_1 = IOMUX_PAD(0x05A0, 0x0258, 4, 0x0000, 0, 0),
MX6_PAD_SD3_DATA0__GPIO7_IO_2 = IOMUX_PAD(0x05A0, 0x0258, 5, 0x0000, 0, 0),
MX6_PAD_SD3_DATA0__DCIC1_OUT = IOMUX_PAD(0x05A0, 0x0258, 6, 0x0000, 0, 0),
MX6_PAD_SD3_DATA0__TPSMP_HDATA_30 = IOMUX_PAD(0x05A0, 0x0258, 7, 0x0000, 0, 0),
MX6_PAD_SD3_DATA0__GPU_DEBUG_0 = IOMUX_PAD(0x05A0, 0x0258, 8, 0x0000, 0, 0),
MX6_PAD_SD3_DATA0__SDMA_DEBUG_EVT_CHN_LINES_0 = IOMUX_PAD(0x05A0, 0x0258, 9, 0x0000, 0, 0),
MX6_PAD_SD3_DATA1__USDHC3_DATA1 = IOMUX_PAD(0x05A4, 0x025C, 0, 0x0000, 0, 0),
MX6_PAD_SD3_DATA1__I2C4_SDA = IOMUX_PAD(0x05A4, 0x025C, 1, 0x07C4, 0, 0),
MX6_PAD_SD3_DATA1__ECSPI2_SS2 = IOMUX_PAD(0x05A4, 0x025C, 2, 0x0000, 0, 0),
MX6_PAD_SD3_DATA1__AUDMUX_AUD6_TXC = IOMUX_PAD(0x05A4, 0x025C, 3, 0x0684, 0, 0),
MX6_PAD_SD3_DATA1__LCDIF2_DATA_0 = IOMUX_PAD(0x05A4, 0x025C, 4, 0x0000, 0, 0),
MX6_PAD_SD3_DATA1__GPIO7_IO_3 = IOMUX_PAD(0x05A4, 0x025C, 5, 0x0000, 0, 0),
MX6_PAD_SD3_DATA1__DCIC2_OUT = IOMUX_PAD(0x05A4, 0x025C, 6, 0x0000, 0, 0),
MX6_PAD_SD3_DATA1__TPSMP_HDATA_31 = IOMUX_PAD(0x05A4, 0x025C, 7, 0x0000, 0, 0),
MX6_PAD_SD3_DATA1__GPU_DEBUG_1 = IOMUX_PAD(0x05A4, 0x025C, 8, 0x0000, 0, 0),
MX6_PAD_SD3_DATA1__SDMA_DEBUG_EVT_CHN_LINES_1 = IOMUX_PAD(0x05A4, 0x025C, 9, 0x0000, 0, 0),
MX6_PAD_SD3_DATA2__USDHC3_DATA2 = IOMUX_PAD(0x05A8, 0x0260, 0, 0x0000, 0, 0),
MX6_PAD_SD3_DATA2__UART4_RTS_B = IOMUX_PAD(0x05A8, 0x0260, 1, 0x0844, 1, 0),
MX6_PAD_SD3_DATA2__ECSPI4_SS0 = IOMUX_PAD(0x05A8, 0x0260, 2, 0x074C, 0, 0),
MX6_PAD_SD3_DATA2__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x05A8, 0x0260, 3, 0x0688, 0, 0),
MX6_PAD_SD3_DATA2__LCDIF2_CLK = IOMUX_PAD(0x05A8, 0x0260, 4, 0x0000, 0, 0),
MX6_PAD_SD3_DATA2__GPIO7_IO_4 = IOMUX_PAD(0x05A8, 0x0260, 5, 0x0000, 0, 0),
MX6_PAD_SD3_DATA2__LCDIF2_WR_RWN = IOMUX_PAD(0x05A8, 0x0260, 6, 0x0000, 0, 0),
MX6_PAD_SD3_DATA2__TPSMP_HDATA_26 = IOMUX_PAD(0x05A8, 0x0260, 7, 0x0000, 0, 0),
MX6_PAD_SD3_DATA2__GPU_DEBUG_2 = IOMUX_PAD(0x05A8, 0x0260, 8, 0x0000, 0, 0),
MX6_PAD_SD3_DATA2__SDMA_DEBUG_EVENT_CHANNEL_2 = IOMUX_PAD(0x05A8, 0x0260, 9, 0x0000, 0, 0),
MX6_PAD_SD3_DATA3__USDHC3_DATA3 = IOMUX_PAD(0x05AC, 0x0264, 0, 0x0000, 0, 0),
MX6_PAD_SD3_DATA3__UART4_RX = IOMUX_PAD(0x05AC, 0x0264, 1, 0x0848, 1, 0),
MX6_PAD_SD3_DATA3__ECSPI4_MISO = IOMUX_PAD(0x05AC, 0x0264, 2, 0x0744, 0, 0),
MX6_PAD_SD3_DATA3__AUDMUX_AUD6_TXD = IOMUX_PAD(0x05AC, 0x0264, 3, 0x0678, 0, 0),
MX6_PAD_SD3_DATA3__LCDIF2_ENABLE = IOMUX_PAD(0x05AC, 0x0264, 4, 0x0000, 0, 0),
MX6_PAD_SD3_DATA3__GPIO7_IO_5 = IOMUX_PAD(0x05AC, 0x0264, 5, 0x0000, 0, 0),
MX6_PAD_SD3_DATA3__LCDIF2_RD_E = IOMUX_PAD(0x05AC, 0x0264, 6, 0x0000, 0, 0),
MX6_PAD_SD3_DATA3__TPSMP_HDATA_27 = IOMUX_PAD(0x05AC, 0x0264, 7, 0x0000, 0, 0),
MX6_PAD_SD3_DATA3__GPU_DEBUG_3 = IOMUX_PAD(0x05AC, 0x0264, 8, 0x0000, 0, 0),
MX6_PAD_SD3_DATA3__SDMA_DEBUG_EVENT_CHANNEL_3 = IOMUX_PAD(0x05AC, 0x0264, 9, 0x0000, 0, 0),
MX6_PAD_SD3_DATA4__USDHC3_DATA4 = IOMUX_PAD(0x05B0, 0x0268, 0, 0x0000, 0, 0),
MX6_PAD_SD3_DATA4__CAN2_RX = IOMUX_PAD(0x05B0, 0x0268, 1, 0x0690, 0, 0),
MX6_PAD_SD3_DATA4__CANFD_RX2 = IOMUX_PAD(0x05B0, 0x0268, 2, 0x0698, 0, 0),
MX6_PAD_SD3_DATA4__UART3_RX = IOMUX_PAD(0x05B0, 0x0268, 3, 0x0840, 2, 0),
MX6_PAD_SD3_DATA4__LCDIF2_DATA_3 = IOMUX_PAD(0x05B0, 0x0268, 4, 0x0000, 0, 0),
MX6_PAD_SD3_DATA4__GPIO7_IO_6 = IOMUX_PAD(0x05B0, 0x0268, 5, 0x0000, 0, 0),
MX6_PAD_SD3_DATA4__ENET2_1588_EVENT0_IN = IOMUX_PAD(0x05B0, 0x0268, 6, 0x0000, 0, 0),
MX6_PAD_SD3_DATA4__TPSMP_HTRANS_1 = IOMUX_PAD(0x05B0, 0x0268, 7, 0x0000, 0, 0),
MX6_PAD_SD3_DATA4__GPU_DEBUG_4 = IOMUX_PAD(0x05B0, 0x0268, 8, 0x0000, 0, 0),
MX6_PAD_SD3_DATA4__SDMA_DEBUG_BUS_DEVICE_0 = IOMUX_PAD(0x05B0, 0x0268, 9, 0x0000, 0, 0),
MX6_PAD_SD3_DATA5__USDHC3_DATA5 = IOMUX_PAD(0x05B4, 0x026C, 0, 0x0000, 0, 0),
MX6_PAD_SD3_DATA5__CAN1_TX = IOMUX_PAD(0x05B4, 0x026C, 1, 0x0000, 0, 0),
MX6_PAD_SD3_DATA5__CANFD_TX1 = IOMUX_PAD(0x05B4, 0x026C, 2, 0x0000, 0, 0),
MX6_PAD_SD3_DATA5__UART3_TX = IOMUX_PAD(0x05B4, 0x026C, 3, 0x0840, 3, 0),
MX6_PAD_SD3_DATA5__LCDIF2_DATA_2 = IOMUX_PAD(0x05B4, 0x026C, 4, 0x0000, 0, 0),
MX6_PAD_SD3_DATA5__GPIO7_IO_7 = IOMUX_PAD(0x05B4, 0x026C, 5, 0x0000, 0, 0),
MX6_PAD_SD3_DATA5__ENET2_1588_EVENT0_OUT = IOMUX_PAD(0x05B4, 0x026C, 6, 0x0000, 0, 0),
MX6_PAD_SD3_DATA5__SIM_M_HWRITE = IOMUX_PAD(0x05B4, 0x026C, 7, 0x0000, 0, 0),
MX6_PAD_SD3_DATA5__GPU_DEBUG_5 = IOMUX_PAD(0x05B4, 0x026C, 8, 0x0000, 0, 0),
MX6_PAD_SD3_DATA5__SDMA_DEBUG_BUS_DEVICE_1 = IOMUX_PAD(0x05B4, 0x026C, 9, 0x0000, 0, 0),
MX6_PAD_SD3_DATA6__USDHC3_DATA6 = IOMUX_PAD(0x05B8, 0x0270, 0, 0x0000, 0, 0),
MX6_PAD_SD3_DATA6__CAN2_TX = IOMUX_PAD(0x05B8, 0x0270, 1, 0x0000, 0, 0),
MX6_PAD_SD3_DATA6__CANFD_TX2 = IOMUX_PAD(0x05B8, 0x0270, 2, 0x0000, 0, 0),
MX6_PAD_SD3_DATA6__UART3_RTS_B = IOMUX_PAD(0x05B8, 0x0270, 3, 0x083C, 2, 0),
MX6_PAD_SD3_DATA6__LCDIF2_DATA_4 = IOMUX_PAD(0x05B8, 0x0270, 4, 0x0000, 0, 0),
MX6_PAD_SD3_DATA6__GPIO7_IO_8 = IOMUX_PAD(0x05B8, 0x0270, 5, 0x0000, 0, 0),
MX6_PAD_SD3_DATA6__ENET1_1588_EVENT0_OUT = IOMUX_PAD(0x05B8, 0x0270, 6, 0x0000, 0, 0),
MX6_PAD_SD3_DATA6__TPSMP_HTRANS_0 = IOMUX_PAD(0x05B8, 0x0270, 7, 0x0000, 0, 0),
MX6_PAD_SD3_DATA6__GPU_DEBUG_7 = IOMUX_PAD(0x05B8, 0x0270, 8, 0x0000, 0, 0),
MX6_PAD_SD3_DATA6__SDMA_DEBUG_EVT_CHN_LINES_7 = IOMUX_PAD(0x05B8, 0x0270, 9, 0x0000, 0, 0),
MX6_PAD_SD3_DATA7__USDHC3_DATA7 = IOMUX_PAD(0x05BC, 0x0274, 0, 0x0000, 0, 0),
MX6_PAD_SD3_DATA7__CAN1_RX = IOMUX_PAD(0x05BC, 0x0274, 1, 0x068C, 0, 0),
MX6_PAD_SD3_DATA7__CANFD_RX1 = IOMUX_PAD(0x05BC, 0x0274, 2, 0x0694, 0, 0),
MX6_PAD_SD3_DATA7__UART3_CTS_B = IOMUX_PAD(0x05BC, 0x0274, 3, 0x083C, 3, 0),
MX6_PAD_SD3_DATA7__LCDIF2_DATA_5 = IOMUX_PAD(0x05BC, 0x0274, 4, 0x0000, 0, 0),
MX6_PAD_SD3_DATA7__GPIO7_IO_9 = IOMUX_PAD(0x05BC, 0x0274, 5, 0x0000, 0, 0),
MX6_PAD_SD3_DATA7__ENET1_1588_EVENT0_IN = IOMUX_PAD(0x05BC, 0x0274, 6, 0x0000, 0, 0),
MX6_PAD_SD3_DATA7__TPSMP_HDATA_DIR = IOMUX_PAD(0x05BC, 0x0274, 7, 0x0000, 0, 0),
MX6_PAD_SD3_DATA7__GPU_DEBUG_6 = IOMUX_PAD(0x05BC, 0x0274, 8, 0x0000, 0, 0),
MX6_PAD_SD3_DATA7__SDMA_DEBUG_EVT_CHN_LINES_2 = IOMUX_PAD(0x05BC, 0x0274, 9, 0x0000, 0, 0),
MX6_PAD_SD4_CLK__USDHC4_CLK = IOMUX_PAD(0x05C0, 0x0278, 0, 0x0000, 0, 0),
MX6_PAD_SD4_CLK__RAWNAND_DATA15 = IOMUX_PAD(0x05C0, 0x0278, 1, 0x0000, 0, 0),
MX6_PAD_SD4_CLK__ECSPI2_MISO = IOMUX_PAD(0x05C0, 0x0278, 2, 0x0724, 1, 0),
MX6_PAD_SD4_CLK__AUDMUX_AUD3_RXFS = IOMUX_PAD(0x05C0, 0x0278, 3, 0x0638, 0, 0),
MX6_PAD_SD4_CLK__LCDIF2_DATA_13 = IOMUX_PAD(0x05C0, 0x0278, 4, 0x0000, 0, 0),
MX6_PAD_SD4_CLK__GPIO6_IO_12 = IOMUX_PAD(0x05C0, 0x0278, 5, 0x0000, 0, 0),
MX6_PAD_SD4_CLK__ECSPI3_SS2 = IOMUX_PAD(0x05C0, 0x0278, 6, 0x0000, 0, 0),
MX6_PAD_SD4_CLK__TPSMP_HDATA_20 = IOMUX_PAD(0x05C0, 0x0278, 7, 0x0000, 0, 0),
MX6_PAD_SD4_CLK__VDEC_DEBUG_12 = IOMUX_PAD(0x05C0, 0x0278, 8, 0x0000, 0, 0),
MX6_PAD_SD4_CLK__SDMA_DEBUG_EVENT_CHANNEL_SEL = IOMUX_PAD(0x05C0, 0x0278, 9, 0x0000, 0, 0),
MX6_PAD_SD4_CMD__USDHC4_CMD = IOMUX_PAD(0x05C4, 0x027C, 0, 0x0000, 0, 0),
MX6_PAD_SD4_CMD__RAWNAND_DATA14 = IOMUX_PAD(0x05C4, 0x027C, 1, 0x0000, 0, 0),
MX6_PAD_SD4_CMD__ECSPI2_MOSI = IOMUX_PAD(0x05C4, 0x027C, 2, 0x0728, 1, 0),
MX6_PAD_SD4_CMD__AUDMUX_AUD3_RXC = IOMUX_PAD(0x05C4, 0x027C, 3, 0x0634, 0, 0),
MX6_PAD_SD4_CMD__LCDIF2_DATA_14 = IOMUX_PAD(0x05C4, 0x027C, 4, 0x0000, 0, 0),
MX6_PAD_SD4_CMD__GPIO6_IO_13 = IOMUX_PAD(0x05C4, 0x027C, 5, 0x0000, 0, 0),
MX6_PAD_SD4_CMD__ECSPI3_SS1 = IOMUX_PAD(0x05C4, 0x027C, 6, 0x0000, 0, 0),
MX6_PAD_SD4_CMD__TPSMP_HDATA_19 = IOMUX_PAD(0x05C4, 0x027C, 7, 0x0000, 0, 0),
MX6_PAD_SD4_CMD__VDEC_DEBUG_11 = IOMUX_PAD(0x05C4, 0x027C, 8, 0x0000, 0, 0),
MX6_PAD_SD4_CMD__SDMA_DEBUG_CORE_RUN = IOMUX_PAD(0x05C4, 0x027C, 9, 0x0000, 0, 0),
MX6_PAD_SD4_DATA0__USDHC4_DATA0 = IOMUX_PAD(0x05C8, 0x0280, 0, 0x0000, 0, 0),
MX6_PAD_SD4_DATA0__RAWNAND_DATA10 = IOMUX_PAD(0x05C8, 0x0280, 1, 0x0000, 0, 0),
MX6_PAD_SD4_DATA0__ECSPI2_SS0 = IOMUX_PAD(0x05C8, 0x0280, 2, 0x072C, 1, 0),
MX6_PAD_SD4_DATA0__AUDMUX_AUD3_RXD = IOMUX_PAD(0x05C8, 0x0280, 3, 0x062C, 0, 0),
MX6_PAD_SD4_DATA0__LCDIF2_DATA_12 = IOMUX_PAD(0x05C8, 0x0280, 4, 0x0000, 0, 0),
MX6_PAD_SD4_DATA0__GPIO6_IO_14 = IOMUX_PAD(0x05C8, 0x0280, 5, 0x0000, 0, 0),
MX6_PAD_SD4_DATA0__ECSPI3_SS3 = IOMUX_PAD(0x05C8, 0x0280, 6, 0x0000, 0, 0),
MX6_PAD_SD4_DATA0__TPSMP_HDATA_21 = IOMUX_PAD(0x05C8, 0x0280, 7, 0x0000, 0, 0),
MX6_PAD_SD4_DATA0__VDEC_DEBUG_13 = IOMUX_PAD(0x05C8, 0x0280, 8, 0x0000, 0, 0),
MX6_PAD_SD4_DATA0__SDMA_DEBUG_MODE = IOMUX_PAD(0x05C8, 0x0280, 9, 0x0000, 0, 0),
MX6_PAD_SD4_DATA1__USDHC4_DATA1 = IOMUX_PAD(0x05CC, 0x0284, 0, 0x0000, 0, 0),
MX6_PAD_SD4_DATA1__RAWNAND_DATA11 = IOMUX_PAD(0x05CC, 0x0284, 1, 0x0000, 0, 0),
MX6_PAD_SD4_DATA1__ECSPI2_SCLK = IOMUX_PAD(0x05CC, 0x0284, 2, 0x0720, 1, 0),
MX6_PAD_SD4_DATA1__AUDMUX_AUD3_TXC = IOMUX_PAD(0x05CC, 0x0284, 3, 0x063C, 0, 0),
MX6_PAD_SD4_DATA1__LCDIF2_DATA_11 = IOMUX_PAD(0x05CC, 0x0284, 4, 0x0000, 0, 0),
MX6_PAD_SD4_DATA1__GPIO6_IO_15 = IOMUX_PAD(0x05CC, 0x0284, 5, 0x0000, 0, 0),
MX6_PAD_SD4_DATA1__ECSPI3_RDY = IOMUX_PAD(0x05CC, 0x0284, 6, 0x0000, 0, 0),
MX6_PAD_SD4_DATA1__TPSMP_HDATA_22 = IOMUX_PAD(0x05CC, 0x0284, 7, 0x0000, 0, 0),
MX6_PAD_SD4_DATA1__VDEC_DEBUG_14 = IOMUX_PAD(0x05CC, 0x0284, 8, 0x0000, 0, 0),
MX6_PAD_SD4_DATA1__SDMA_DEBUG_BUS_ERROR = IOMUX_PAD(0x05CC, 0x0284, 9, 0x0000, 0, 0),
MX6_PAD_SD4_DATA2__USDHC4_DATA2 = IOMUX_PAD(0x05D0, 0x0288, 0, 0x0000, 0, 0),
MX6_PAD_SD4_DATA2__RAWNAND_DATA12 = IOMUX_PAD(0x05D0, 0x0288, 1, 0x0000, 0, 0),
MX6_PAD_SD4_DATA2__I2C2_SDA = IOMUX_PAD(0x05D0, 0x0288, 2, 0x07B4, 0, 0),
MX6_PAD_SD4_DATA2__AUDMUX_AUD3_TXFS = IOMUX_PAD(0x05D0, 0x0288, 3, 0x0640, 0, 0),
MX6_PAD_SD4_DATA2__LCDIF2_DATA_10 = IOMUX_PAD(0x05D0, 0x0288, 4, 0x0000, 0, 0),
MX6_PAD_SD4_DATA2__GPIO6_IO_16 = IOMUX_PAD(0x05D0, 0x0288, 5, 0x0000, 0, 0),
MX6_PAD_SD4_DATA2__ECSPI2_SS3 = IOMUX_PAD(0x05D0, 0x0288, 6, 0x0000, 0, 0),
MX6_PAD_SD4_DATA2__TPSMP_HDATA_23 = IOMUX_PAD(0x05D0, 0x0288, 7, 0x0000, 0, 0),
MX6_PAD_SD4_DATA2__VDEC_DEBUG_15 = IOMUX_PAD(0x05D0, 0x0288, 8, 0x0000, 0, 0),
MX6_PAD_SD4_DATA2__SDMA_DEBUG_BUS_RWB = IOMUX_PAD(0x05D0, 0x0288, 9, 0x0000, 0, 0),
MX6_PAD_SD4_DATA3__USDHC4_DATA3 = IOMUX_PAD(0x05D4, 0x028C, 0, 0x0000, 0, 0),
MX6_PAD_SD4_DATA3__RAWNAND_DATA13 = IOMUX_PAD(0x05D4, 0x028C, 1, 0x0000, 0, 0),
MX6_PAD_SD4_DATA3__I2C2_SCL = IOMUX_PAD(0x05D4, 0x028C, 2, 0x07B0, 0, 0),
MX6_PAD_SD4_DATA3__AUDMUX_AUD3_TXD = IOMUX_PAD(0x05D4, 0x028C, 3, 0x0630, 0, 0),
MX6_PAD_SD4_DATA3__LCDIF2_DATA_9 = IOMUX_PAD(0x05D4, 0x028C, 4, 0x0000, 0, 0),
MX6_PAD_SD4_DATA3__GPIO6_IO_17 = IOMUX_PAD(0x05D4, 0x028C, 5, 0x0000, 0, 0),
MX6_PAD_SD4_DATA3__ECSPI2_RDY = IOMUX_PAD(0x05D4, 0x028C, 6, 0x0000, 0, 0),
MX6_PAD_SD4_DATA3__TPSMP_HDATA_24 = IOMUX_PAD(0x05D4, 0x028C, 7, 0x0000, 0, 0),
MX6_PAD_SD4_DATA3__VDEC_DEBUG_16 = IOMUX_PAD(0x05D4, 0x028C, 8, 0x0000, 0, 0),
MX6_PAD_SD4_DATA3__SDMA_DEBUG_MATCHED_DMBUS = IOMUX_PAD(0x05D4, 0x028C, 9, 0x0000, 0, 0),
MX6_PAD_SD4_DATA4__USDHC4_DATA4 = IOMUX_PAD(0x05D8, 0x0290, 0, 0x0000, 0, 0),
MX6_PAD_SD4_DATA4__RAWNAND_DATA09 = IOMUX_PAD(0x05D8, 0x0290, 1, 0x0000, 0, 0),
MX6_PAD_SD4_DATA4__UART5_RX = IOMUX_PAD(0x05D8, 0x0290, 2, 0x0850, 0, 0),
MX6_PAD_SD4_DATA4__ECSPI3_SCLK = IOMUX_PAD(0x05D8, 0x0290, 3, 0x0730, 0, 0),
MX6_PAD_SD4_DATA4__LCDIF2_DATA_8 = IOMUX_PAD(0x05D8, 0x0290, 4, 0x0000, 0, 0),
MX6_PAD_SD4_DATA4__GPIO6_IO_18 = IOMUX_PAD(0x05D8, 0x0290, 5, 0x0000, 0, 0),
MX6_PAD_SD4_DATA4__SPDIF_OUT = IOMUX_PAD(0x05D8, 0x0290, 6, 0x0000, 0, 0),
MX6_PAD_SD4_DATA4__TPSMP_HDATA_16 = IOMUX_PAD(0x05D8, 0x0290, 7, 0x0000, 0, 0),
MX6_PAD_SD4_DATA4__USB_OTG_HOST_MODE = IOMUX_PAD(0x05D8, 0x0290, 8, 0x0000, 0, 0),
MX6_PAD_SD4_DATA4__SDMA_DEBUG_RTBUFFER_WRITE = IOMUX_PAD(0x05D8, 0x0290, 9, 0x0000, 0, 0),
MX6_PAD_SD4_DATA5__USDHC4_DATA5 = IOMUX_PAD(0x05DC, 0x0294, 0, 0x0000, 0, 0),
MX6_PAD_SD4_DATA5__RAWNAND_CE2_B = IOMUX_PAD(0x05DC, 0x0294, 1, 0x0000, 0, 0),
MX6_PAD_SD4_DATA5__UART5_TX = IOMUX_PAD(0x05DC, 0x0294, 2, 0x0850, 1, 0),
MX6_PAD_SD4_DATA5__ECSPI3_MOSI = IOMUX_PAD(0x05DC, 0x0294, 3, 0x0738, 0, 0),
MX6_PAD_SD4_DATA5__LCDIF2_DATA_7 = IOMUX_PAD(0x05DC, 0x0294, 4, 0x0000, 0, 0),
MX6_PAD_SD4_DATA5__GPIO6_IO_19 = IOMUX_PAD(0x05DC, 0x0294, 5, 0x0000, 0, 0),
MX6_PAD_SD4_DATA5__SPDIF_IN = IOMUX_PAD(0x05DC, 0x0294, 6, 0x0824, 0, 0),
MX6_PAD_SD4_DATA5__TPSMP_HDATA_17 = IOMUX_PAD(0x05DC, 0x0294, 7, 0x0000, 0, 0),
MX6_PAD_SD4_DATA5__VDEC_DEBUG_9 = IOMUX_PAD(0x05DC, 0x0294, 8, 0x0000, 0, 0),
MX6_PAD_SD4_DATA5__SDMA_DEBUG_EVENT_CHANNEL_0 = IOMUX_PAD(0x05DC, 0x0294, 9, 0x0000, 0, 0),
MX6_PAD_SD4_DATA6__USDHC4_DATA6 = IOMUX_PAD(0x05E0, 0x0298, 0, 0x0000, 0, 0),
MX6_PAD_SD4_DATA6__RAWNAND_CE3_B = IOMUX_PAD(0x05E0, 0x0298, 1, 0x0000, 0, 0),
MX6_PAD_SD4_DATA6__UART5_RTS_B = IOMUX_PAD(0x05E0, 0x0298, 2, 0x084C, 0, 0),
MX6_PAD_SD4_DATA6__ECSPI3_MISO = IOMUX_PAD(0x05E0, 0x0298, 3, 0x0734, 0, 0),
MX6_PAD_SD4_DATA6__LCDIF2_DATA_6 = IOMUX_PAD(0x05E0, 0x0298, 4, 0x0000, 0, 0),
MX6_PAD_SD4_DATA6__GPIO6_IO_20 = IOMUX_PAD(0x05E0, 0x0298, 5, 0x0000, 0, 0),
MX6_PAD_SD4_DATA6__USDHC4_WP = IOMUX_PAD(0x05E0, 0x0298, 6, 0x0878, 0, 0),
MX6_PAD_SD4_DATA6__TPSMP_HDATA_18 = IOMUX_PAD(0x05E0, 0x0298, 7, 0x0000, 0, 0),
MX6_PAD_SD4_DATA6__VDEC_DEBUG_10 = IOMUX_PAD(0x05E0, 0x0298, 8, 0x0000, 0, 0),
MX6_PAD_SD4_DATA6__SDMA_DEBUG_EVENT_CHANNEL_1 = IOMUX_PAD(0x05E0, 0x0298, 9, 0x0000, 0, 0),
MX6_PAD_SD4_DATA7__USDHC4_DATA7 = IOMUX_PAD(0x05E4, 0x029C, 0, 0x0000, 0, 0),
MX6_PAD_SD4_DATA7__RAWNAND_DATA08 = IOMUX_PAD(0x05E4, 0x029C, 1, 0x0000, 0, 0),
MX6_PAD_SD4_DATA7__UART5_CTS_B = IOMUX_PAD(0x05E4, 0x029C, 2, 0x084C, 1, 0),
MX6_PAD_SD4_DATA7__ECSPI3_SS0 = IOMUX_PAD(0x05E4, 0x029C, 3, 0x073C, 0, 0),
MX6_PAD_SD4_DATA7__LCDIF2_DATA_15 = IOMUX_PAD(0x05E4, 0x029C, 4, 0x0000, 0, 0),
MX6_PAD_SD4_DATA7__GPIO6_IO_21 = IOMUX_PAD(0x05E4, 0x029C, 5, 0x0000, 0, 0),
MX6_PAD_SD4_DATA7__USDHC4_CD_B = IOMUX_PAD(0x05E4, 0x029C, 6, 0x0874, 0, 0),
MX6_PAD_SD4_DATA7__TPSMP_HDATA_15 = IOMUX_PAD(0x05E4, 0x029C, 7, 0x0000, 0, 0),
MX6_PAD_SD4_DATA7__USB_OTG_PWR_WAKE = IOMUX_PAD(0x05E4, 0x029C, 8, 0x0000, 0, 0),
MX6_PAD_SD4_DATA7__SDMA_DEBUG_YIELD = IOMUX_PAD(0x05E4, 0x029C, 9, 0x0000, 0, 0),
MX6_PAD_SD4_RESET_B__USDHC4_RESET_B = IOMUX_PAD(0x05E8, 0x02A0, 0, 0x0000, 0, 0),
MX6_PAD_SD4_RESET_B__RAWNAND_DQS = IOMUX_PAD(0x05E8, 0x02A0, 1, 0x0000, 0, 0),
MX6_PAD_SD4_RESET_B__USDHC4_RESET = IOMUX_PAD(0x05E8, 0x02A0, 2, 0x0000, 0, 0),
MX6_PAD_SD4_RESET_B__AUDMUX_MCLK = IOMUX_PAD(0x05E8, 0x02A0, 3, 0x0000, 0, 0),
MX6_PAD_SD4_RESET_B__LCDIF2_RESET = IOMUX_PAD(0x05E8, 0x02A0, 4, 0x0000, 0, 0),
MX6_PAD_SD4_RESET_B__GPIO6_IO_22 = IOMUX_PAD(0x05E8, 0x02A0, 5, 0x0000, 0, 0),
MX6_PAD_SD4_RESET_B__LCDIF2_CS = IOMUX_PAD(0x05E8, 0x02A0, 6, 0x0000, 0, 0),
MX6_PAD_SD4_RESET_B__TPSMP_HDATA_25 = IOMUX_PAD(0x05E8, 0x02A0, 7, 0x0000, 0, 0),
MX6_PAD_SD4_RESET_B__VDEC_DEBUG_17 = IOMUX_PAD(0x05E8, 0x02A0, 8, 0x0000, 0, 0),
MX6_PAD_SD4_RESET_B__SDMA_DEBUG_BUS_DEVICE_2 = IOMUX_PAD(0x05E8, 0x02A0, 9, 0x0000, 0, 0),
MX6_PAD_USB_H_DATA__USB_H_DATA = IOMUX_PAD(0x05EC, 0x02A4, 0, 0x0000, 0, 0),
MX6_PAD_USB_H_DATA__PWM2_OUT = IOMUX_PAD(0x05EC, 0x02A4, 1, 0x0000, 0, 0),
MX6_PAD_USB_H_DATA__ANATOP_24M_OUT = IOMUX_PAD(0x05EC, 0x02A4, 2, 0x0000, 0, 0),
MX6_PAD_USB_H_DATA__I2C4_SDA = IOMUX_PAD(0x05EC, 0x02A4, 3, 0x07C4, 1, 0),
MX6_PAD_USB_H_DATA__WDOG3_WDOG_B = IOMUX_PAD(0x05EC, 0x02A4, 4, 0x0000, 0, 0),
MX6_PAD_USB_H_DATA__GPIO7_IO_10 = IOMUX_PAD(0x05EC, 0x02A4, 5, 0x0000, 0, 0),
MX6_PAD_USB_H_STROBE__USB_H_STROBE = IOMUX_PAD(0x05F0, 0x02A8, 0, 0x0000, 0, 0),
MX6_PAD_USB_H_STROBE__PWM1_OUT = IOMUX_PAD(0x05F0, 0x02A8, 1, 0x0000, 0, 0),
MX6_PAD_USB_H_STROBE__ANATOP_32K_OUT = IOMUX_PAD(0x05F0, 0x02A8, 2, 0x0000, 0, 0),
MX6_PAD_USB_H_STROBE__I2C4_SCL = IOMUX_PAD(0x05F0, 0x02A8, 3, 0x07C0, 1, 0),
MX6_PAD_USB_H_STROBE__WDOG3_WDOG_RST_B_DEB = IOMUX_PAD(0x05F0, 0x02A8, 4, 0x0000, 0, 0),
MX6_PAD_USB_H_STROBE__GPIO7_IO_11 = IOMUX_PAD(0x05F0, 0x02A8, 5, 0x0000, 0, 0),
+}; +#endif /* __ASM_ARCH_MX6_ MX6_PINS_H__ */
Best regards, Stefano Babic
Hi Stefano,
On 06/17/2014 08:40 AM, Stefano Babic wrote:
Hi Fabio,
On 14/06/2014 22:29, Fabio Estevam wrote:
Add the pin definitions for mx6sx.
A base question. There was a lot of work to try to abstract the pin definitions for the i.MX6 SOCs. For QUAD and DUAL, the pins are defined with the MX6_PAD_DECL macro. It works differently according to the selected CPU. If more as one CPU is supported in the same image, the check is done at runtime.
Previously, we had IOMUX_PAD, I know. Is there any special reason we cannot use MX6_PAD_DECL even for this new SOC ? I will not want to go back ignoring a lot of work that was done to merge the SOCs together.
The rationale for the MX6_PAD_DECL came from the fact that the i.MX6DQ and i.MX6DLS cpu variants had different address schemes, but were pin-compatible.
The i.MX6SL (and i.MX6SX) are not, so any board supporting these processors only supports that processor.
Regards,
Eric
Hi Stefano,
On Tue, Jun 17, 2014 at 3:59 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
As per Eric's explanation I plan to keep this patch unchanged for v2, if that's ok with you.
Hi Fabio,
On 20/06/2014 20:58, Fabio Estevam wrote:
Hi Stefano,
That is ok - I am sometimes more optimistic about how to simplify code as it is really physeable. Thanks both of you to have clarified the point.
Regards, Stefano
mx6sx does not have sata nor ipu blocks, so do not handle such clocks.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx6/clock.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index d31fbbd..51c964c 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -437,6 +437,7 @@ static int enable_enet_pll(uint32_t en) return 0; }
+#ifndef CONFIG_MX6SX static void ungate_sata_clock(void) { struct mxc_ccm_reg *const imx_ccm = @@ -445,6 +446,7 @@ static void ungate_sata_clock(void) /* Enable SATA clock. */ setbits_le32(&imx_ccm->CCGR5, MXC_CCM_CCGR5_SATA_MASK); } +#endif
static void ungate_pcie_clock(void) { @@ -455,11 +457,13 @@ static void ungate_pcie_clock(void) setbits_le32(&imx_ccm->CCGR4, MXC_CCM_CCGR4_PCIE_MASK); }
+#ifndef CONFIG_MX6SX int enable_sata_clock(void) { ungate_sata_clock(); return enable_enet_pll(BM_ANADIG_PLL_ENET_ENABLE_SATA); } +#endif
int enable_pcie_clock(void) { @@ -491,7 +495,9 @@ int enable_pcie_clock(void) clrbits_le32(&ccm_regs->cbcmr, MXC_CCM_CBCMR_PCIE_AXI_CLK_SEL);
/* Party time! Ungate the clock to the PCIe. */ +#ifndef CONFIG_MX6SX ungate_sata_clock(); +#endif ungate_pcie_clock();
return enable_enet_pll(BM_ANADIG_PLL_ENET_ENABLE_SATA | @@ -573,6 +579,7 @@ int do_mx6_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
+#ifndef CONFIG_MX6SX void enable_ipu_clock(void) { struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; @@ -581,6 +588,7 @@ void enable_ipu_clock(void) reg |= MXC_CCM_CCGR3_IPU1_IPU_MASK; writel(reg, &mxc_ccm->CCGR3); } +#endif /***************************************************/
U_BOOT_CMD(
Hi Fabio,
We have already a check inside setup_sata():
if (!is_cpu_type(MXC_CPU_MX6Q) && !is_cpu_type(MXC_CPU_MX6D)) return 1;
enable_sata_clock() is called only for quad and dual. I think you do not need at all to block enable_sata_clock(), it should be not called.
I would prefer we carry on with this approach: board are calling functions to set up hardware, and each peripheral (setup_sata or the ipu driver) makes the check at runtime for the running cpu.
U_BOOT_CMD(
On Tue, Jun 17, 2014 at 12:36 PM, Stefano Babic sbabic@denx.de wrote:
Hi Fabio,
Actually the problems here are build time issues:
1) MXC_CCM_CCGR5_SATA_MASK field does not exist for mx6sx (it is a reserved field)
2) MXC_CCM_CCGR3_IPU1_IPU_MASK does not exist for mx6sx (it is a reserved field)
So that's why I had to place the ifdef's.
Hi Fabio,
- MXC_CCM_CCGR5_SATA_MASK field does not exist for mx6sx (it is a
reserved field)
- MXC_CCM_CCGR3_IPU1_IPU_MASK does not exist for mx6sx (it is a reserved field)
ok, got it, thanks for explanation.
Regards, Stefano
Hi Stefano,
On Tue, Jun 24, 2014 at 9:37 AM, Stefano Babic sbabic@denx.de wrote:
Hi Fabio,
reserved field)
Please let me know if you are happy with v4.
After this initial series gets applied I plan to adding solox FEC support.
Regards,
Fabio Estevam
mx6solox is the newest member of the mx6 family.
Add the initial support for it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx6sxsabresd/Makefile | 6 + board/freescale/mx6sxsabresd/imximage.cfg | 105 ++++++++++++++++ board/freescale/mx6sxsabresd/mx6sxsabresd.c | 95 ++++++++++++++ boards.cfg | 1 + include/configs/mx6sxsabresd.h | 186 ++++++++++++++++++++++++++++ 5 files changed, 393 insertions(+) create mode 100644 board/freescale/mx6sxsabresd/Makefile create mode 100644 board/freescale/mx6sxsabresd/imximage.cfg create mode 100644 board/freescale/mx6sxsabresd/mx6sxsabresd.c create mode 100644 include/configs/mx6sxsabresd.h
diff --git a/board/freescale/mx6sxsabresd/Makefile b/board/freescale/mx6sxsabresd/Makefile new file mode 100644 index 0000000..97dbfda --- /dev/null +++ b/board/freescale/mx6sxsabresd/Makefile @@ -0,0 +1,6 @@ +# (C) Copyright 2014 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := mx6sxsabresd.o diff --git a/board/freescale/mx6sxsabresd/imximage.cfg b/board/freescale/mx6sxsabresd/imximage.cfg new file mode 100644 index 0000000..406dece --- /dev/null +++ b/board/freescale/mx6sxsabresd/imximage.cfg @@ -0,0 +1,105 @@ +/* + * Copyright (C) 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define __ASSEMBLY__ +#include <config.h> + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi/sd/nand/onenand, qspi/nor + */ + +BOOT_FROM sd + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +DATA 4 0x020c4068 0xffffffff +DATA 4 0x020c406c 0xffffffff +DATA 4 0x020c4070 0xffffffff +DATA 4 0x020c4074 0xffffffff +DATA 4 0x020c4078 0xffffffff +DATA 4 0x020c407c 0xffffffff +DATA 4 0x020c4080 0xffffffff +DATA 4 0x020c4084 0xffffffff + +DATA 4 0x020e0618 0x000c0000 +DATA 4 0x020e05fc 0x00000000 +DATA 4 0x020e032c 0x00000030 + +DATA 4 0x020e0300 0x00000030 +DATA 4 0x020e02fc 0x00000030 +DATA 4 0x020e05f4 0x00000030 +DATA 4 0x020e0340 0x00000030 + +DATA 4 0x020e0320 0x00000000 +DATA 4 0x020e0310 0x00000030 +DATA 4 0x020e0314 0x00000030 +DATA 4 0x020e0614 0x00000030 + +DATA 4 0x020e05f8 0x00020000 +DATA 4 0x020e0330 0x00000030 +DATA 4 0x020e0334 0x00000030 +DATA 4 0x020e0338 0x00000030 +DATA 4 0x020e033c 0x00000030 +DATA 4 0x020e0608 0x00020000 +DATA 4 0x020e060c 0x00000030 +DATA 4 0x020e0610 0x00000030 +DATA 4 0x020e061c 0x00000030 +DATA 4 0x020e0620 0x00000030 +DATA 4 0x020e02ec 0x00000030 +DATA 4 0x020e02f0 0x00000030 +DATA 4 0x020e02f4 0x00000030 +DATA 4 0x020e02f8 0x00000030 +DATA 4 0x021b0800 0xa1390003 +DATA 4 0x021b080c 0x00270025 +DATA 4 0x021b0810 0x001B001E +DATA 4 0x021b083c 0x4144013C +DATA 4 0x021b0840 0x01300128 +DATA 4 0x021b0848 0x4044464A +DATA 4 0x021b0850 0x3A383C34 +DATA 4 0x021b081c 0x33333333 +DATA 4 0x021b0820 0x33333333 +DATA 4 0x021b0824 0x33333333 +DATA 4 0x021b0828 0x33333333 +DATA 4 0x021b08b8 0x00000800 +DATA 4 0x021b0004 0x0002002d +DATA 4 0x021b0008 0x00333030 +DATA 4 0x021b000c 0x676b52f3 +DATA 4 0x021b0010 0xb66d8b63 +DATA 4 0x021b0014 0x01ff00db +DATA 4 0x021b0018 0x00011740 +DATA 4 0x021b001c 0x00008000 +DATA 4 0x021b002c 0x000026d2 +DATA 4 0x021b0030 0x006b1023 +DATA 4 0x021b0040 0x0000005f +DATA 4 0x021b0000 0x84190000 +DATA 4 0x021b001c 0x04008032 +DATA 4 0x021b001c 0x00008033 +DATA 4 0x021b001c 0x00068031 +DATA 4 0x021b001c 0x05208030 +DATA 4 0x021b001c 0x04008040 +DATA 4 0x021b0020 0x00000800 +DATA 4 0x021b0818 0x00011117 +DATA 4 0x021b001c 0x00000000 + +DATA 4 0x021b083c 0x41400138 +DATA 4 0x021b0840 0x012C011C +DATA 4 0x021b0848 0x3C3C4044 +DATA 4 0x021b0850 0x34343638 diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c new file mode 100644 index 0000000..ff4c88f --- /dev/null +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -0,0 +1,95 @@ +/* + * Copyright (C) 2014 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/io.h> +#include <linux/sizes.h> +#include <common.h> +#include <fsl_esdhc.h> +#include <mmc.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +int dram_init(void) +{ + gd->ram_size = PHYS_SDRAM_SIZE; + + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_GPIO1_IO04__UART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_GPIO1_IO05__UART1_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc4_pads[] = { + MX6_PAD_SD4_CLK__USDHC4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_CMD__USDHC4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DATA0__USDHC4_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DATA1__USDHC4_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DATA2__USDHC4_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DATA3__USDHC4_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DATA7__GPIO6_IO_21 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + return 0; +} + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC4_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + return 1; /* Assume boot SD always present */ +} + +int board_mmc_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(usdhc4_pads, ARRAY_SIZE(usdhc4_pads)); + + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +} + +int board_init(void) +{ + /* Address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +int checkboard(void) +{ + puts("Board: MX6SX SABRE SDB\n"); + + return 0; +} diff --git a/boards.cfg b/boards.cfg index fd4324d..b726feb 100644 --- a/boards.cfg +++ b/boards.cfg @@ -328,6 +328,7 @@ Active arm armv7 mx6 freescale mx6qsabreauto Active arm armv7 mx6 freescale mx6sabresd mx6dlsabresd mx6sabresd:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 freescale mx6sabresd mx6qsabresd mx6sabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 freescale mx6slevk mx6slevk mx6slevk:IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 freescale mx6sxsabresd mx6sxsabresd mx6sxsabresd:IMX_CONFIG=board/freescale/mx6sxsabresd/imximage.cfg,MX6SX Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 gateworks gw_ventana gwventana gw_ventana:IMX_CONFIG=board/gateworks/gw_ventana/gw_ventana.cfg,MX6QDL,SPL Tim Harvey tharvey@gateworks.com Active arm armv7 mx6 solidrun hummingboard hummingboard_solo hummingboard:IMX_CONFIG=board/solidrun/hummingboard/solo.cfg,MX6S,DDR_MB=512 Jon Nettleton jon.nettleton@gmail.com Active arm armv7 omap3 - overo omap3_overo - Steve Sakoman sakoman@gmail.com diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h new file mode 100644 index 0000000..390286b --- /dev/null +++ b/include/configs/mx6sxsabresd.h @@ -0,0 +1,186 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * Configuration settings for the Freescale i.MX6SX Sabresd board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/imx-regs.h> +#include <linux/sizes.h> +#include "mx6_common.h" + +#define CONFIG_MX6 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG +#define CONFIG_SYS_GENERIC_BOARD + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (3 * SZ_1M) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x80800000 +#define CONFIG_SYS_TEXT_BASE 0x87800000 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=zImage\0" \ + "console=ttymxc0\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=imx6sx-sdb.dtb\0" \ + "fdt_addr=0x88000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev=0\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 1024 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 256 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x10000) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_CMDLINE_EDITING +#define CONFIG_STACKSIZE SZ_128K + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define PHYS_SDRAM_SIZE SZ_1G + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* MMC Configuration */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_OFFSET (6 * SZ_64K) +#define CONFIG_ENV_SIZE SZ_8K +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +#endif /* __CONFIG_H */
Hi Fabio,
Sorry to be noisy. I have not idea which mx6solox means. Can you (I have not found any documentation on Freescale's website) spend a couple of line and introduce this new i.MX6 variation ?
Which are the main differences with other i.MX6 CPU we are already supporting, for example the Solo ?
Recently, we added several patches to make runtime detection for the cpu - see is_cpu_type(). What about to use it in your patches ?
arch/arm/cpu/armv7/mx6/clock.c | 4 +- arch/arm/cpu/armv7/mx6/soc.c | 26 +++++ arch/arm/imx-common/cpu.c | 2 + arch/arm/include/asm/arch-imx/cpu.h | 3 +- arch/arm/include/asm/arch-mx6/crm_regs.h | 170 ++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx6/imx-regs.h | 122 ++++++++++++++++++++- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 4 + arch/arm/include/asm/arch-mx6/mx6sx-ddr.h | 45 ++++++++ 8 files changed, 369 insertions(+), 7 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx6/mx6sx-ddr.h
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index bd65a08..d31fbbd 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -214,7 +214,7 @@ static u32 get_uart_clk(void) u32 reg, uart_podf; u32 freq = decode_pll(PLL_USBOTG, MXC_HCLK) / 6; /* static divider */ reg = __raw_readl(&imx_ccm->cscdr1); -#ifdef CONFIG_MX6SL +#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX)) if (reg & MXC_CCM_CSCDR1_UART_CLK_SEL) freq = MXC_HCLK; #endif @@ -282,7 +282,7 @@ static u32 get_emi_slow_clk(void) return root_freq / (emi_slow_podf + 1); }
-#ifdef CONFIG_MX6SL +#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX)) static u32 get_mmdc_ch0_clk(void) { u32 cbcmr = __raw_readl(&imx_ccm->cbcmr); diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 1725279..e394e3f 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -79,9 +79,15 @@ u32 __weak get_board_rev(void) void init_aips(void) { struct aipstz_regs *aips1, *aips2; +#ifdef CONFIG_MX6SX
- struct aipstz_regs *aips3;
aips1 = (struct aipstz_regs *)AIPS1_BASE_ADDR; aips2 = (struct aipstz_regs *)AIPS2_BASE_ADDR; +#ifdef CONFIG_MX6SX
- aips3 = (struct aipstz_regs *)AIPS3_BASE_ADDR;
/* * Set all MPROTx to be non-bufferable, trusted for R/W, @@ -107,6 +113,26 @@ void init_aips(void) writel(0x00000000, &aips2->opacr2); writel(0x00000000, &aips2->opacr3); writel(0x00000000, &aips2->opacr4);
* not forced to user-mode.
- writel(0x77777777, &aips3->mprot0);
- writel(0x77777777, &aips3->mprot1);
* Set all OPACRx to be non-bufferable, not require
* supervisor privilege level for access,allow for
* write access and untrusted master access.
- writel(0x00000000, &aips3->opacr0);
- writel(0x00000000, &aips3->opacr1);
- writel(0x00000000, &aips3->opacr2);
- writel(0x00000000, &aips3->opacr3);
- writel(0x00000000, &aips3->opacr4);
+#endif }
static void clear_ldo_ramp(void) diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 5a09107..7bb0e83 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -112,6 +112,8 @@ const char *get_imx_type(u32 imxtype) return "6SOLO"; /* Solo version of the mx6 */ case MXC_CPU_MX6SL: return "6SL"; /* Solo-Lite version of the mx6 */
- case MXC_CPU_MX6SX:
case MXC_CPU_MX51: return "51"; case MXC_CPU_MX53:return "6SX"; /* SoloX version of the mx6 */
diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index a35940e..a3cc96f 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -8,6 +8,7 @@ #define MXC_CPU_MX53 0x53 #define MXC_CPU_MX6SL 0x60 #define MXC_CPU_MX6DL 0x61 -#define MXC_CPU_MX6SOLO 0x62 +#define MXC_CPU_MX6SX 0x62 #define MXC_CPU_MX6Q 0x63 #define MXC_CPU_MX6D 0x64 +#define MXC_CPU_MX6SOLO 0x65 /* dummy ID */ diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index 7202073..0fcef69 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -113,7 +113,11 @@ struct mxc_ccm_reg { #define MXC_CCM_CCR_WB_COUNT_MASK 0x7 #define MXC_CCM_CCR_WB_COUNT_OFFSET (1 << 16) #define MXC_CCM_CCR_COSC_EN (1 << 12) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCR_OSCNT_MASK 0x7F +#else #define MXC_CCM_CCR_OSCNT_MASK 0xFF +#endif #define MXC_CCM_CCR_OSCNT_OFFSET 0
/* Define the bits in register CCDR */ @@ -146,8 +150,10 @@ struct mxc_ccm_reg { #define MXC_CCM_CBCDR_PERIPH_CLK2_PODF_OFFSET 27 #define MXC_CCM_CBCDR_PERIPH2_CLK2_SEL (1 << 26) #define MXC_CCM_CBCDR_PERIPH_CLK_SEL (1 << 25) +#ifndef CONFIG_MX6SX #define MXC_CCM_CBCDR_MMDC_CH0_PODF_MASK (0x7 << 19) #define MXC_CCM_CBCDR_MMDC_CH0_PODF_OFFSET 19 +#endif #define MXC_CCM_CBCDR_AXI_PODF_MASK (0x7 << 16) #define MXC_CCM_CBCDR_AXI_PODF_OFFSET 16 #define MXC_CCM_CBCDR_AHB_PODF_MASK (0x7 << 10) @@ -173,28 +179,40 @@ struct mxc_ccm_reg { #define MXC_CCM_CBCMR_PRE_PERIPH2_CLK2_SEL (1 << 20) #define MXC_CCM_CBCMR_PRE_PERIPH_CLK_SEL_MASK (0x3 << 18) #define MXC_CCM_CBCMR_PRE_PERIPH_CLK_SEL_OFFSET 18 +#ifndef CONFIG_MX6SX #define MXC_CCM_CBCMR_GPU2D_CLK_SEL_MASK (0x3 << 16) #define MXC_CCM_CBCMR_GPU2D_CLK_SEL_OFFSET 16 #define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_MASK (0x3 << 14) #define MXC_CCM_CBCMR_VPU_AXI_CLK_SEL_OFFSET 14 +#endif #define MXC_CCM_CBCMR_PERIPH_CLK2_SEL_MASK (0x3 << 12) #define MXC_CCM_CBCMR_PERIPH_CLK2_SEL_OFFSET 12 +#ifndef CONFIG_MX6SX #define MXC_CCM_CBCMR_VDOAXI_CLK_SEL (1 << 11) +#endif #define MXC_CCM_CBCMR_PCIE_AXI_CLK_SEL (1 << 10) #define MXC_CCM_CBCMR_GPU3D_SHADER_CLK_SEL_MASK (0x3 << 8) #define MXC_CCM_CBCMR_GPU3D_SHADER_CLK_SEL_OFFSET 8 #define MXC_CCM_CBCMR_GPU3D_CORE_CLK_SEL_MASK (0x3 << 4) #define MXC_CCM_CBCMR_GPU3D_CORE_CLK_SEL_OFFSET 4 +#ifndef CONFIG_MX6SX #define MXC_CCM_CBCMR_GPU3D_AXI_CLK_SEL (1 << 1) #define MXC_CCM_CBCMR_GPU2D_AXI_CLK_SEL (1 << 0) +#endif
/* Define the bits in register CSCMR1 */ #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_MASK (0x3 << 29) #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_OFFSET 29 +#ifdef CONFIG_MX6SX +#define MXC_CCM_CSCMR1_QSPI1_PODF_MASK (0x7 << 26) +#define MXC_CCM_CSCMR1_QSPI1_PODF_OFFSET 26 +#else #define MXC_CCM_CSCMR1_ACLK_EMI_MASK (0x3 << 27) #define MXC_CCM_CSCMR1_ACLK_EMI_OFFSET 27 +#endif #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_PODF_MASK (0x7 << 23) #define MXC_CCM_CSCMR1_ACLK_EMI_SLOW_PODF_OFFSET 23 +/* ACLK_EMI_PODF is LCFIF2_PODF on MX6SX */ #define MXC_CCM_CSCMR1_ACLK_EMI_PODF_MASK (0x7 << 20) #define MXC_CCM_CSCMR1_ACLK_EMI_PODF_OFFSET 20 #define MXC_CCM_CSCMR1_USDHC4_CLK_SEL (1 << 19) @@ -207,19 +225,38 @@ struct mxc_ccm_reg { #define MXC_CCM_CSCMR1_SSI2_CLK_SEL_OFFSET 12 #define MXC_CCM_CSCMR1_SSI1_CLK_SEL_MASK (0x3 << 10) #define MXC_CCM_CSCMR1_SSI1_CLK_SEL_OFFSET 10 +#ifdef CONFIG_MX6SX +#define MXC_CCM_CSCMR1_QSPI1_CLK_SEL_MASK (0x7 << 7) +#define MXC_CCM_CSCMR1_QSPI1_CLK_SEL_OFFSET 7 +#define MXC_CCM_CSCMR1_PER_CLK_SEL_MASK (1 << 6) +#define MXC_CCM_CSCMR1_PER_CLK_SEL_OFFSET 6 +#endif #define MXC_CCM_CSCMR1_PERCLK_PODF_MASK 0x3F
/* Define the bits in register CSCMR2 */ +#ifdef CONFIG_MX6SX +#define MXC_CCM_CSCMR2_VID_CLK_SEL_MASK (0x7 << 21) +#define MXC_CCM_CSCMR2_VID_CLK_SEL_OFFSET 21 +#endif #define MXC_CCM_CSCMR2_ESAI_PRE_SEL_MASK (0x3 << 19) #define MXC_CCM_CSCMR2_ESAI_PRE_SEL_OFFSET 19 #define MXC_CCM_CSCMR2_LDB_DI1_IPU_DIV (1 << 11) #define MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV (1 << 10) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CSCMR2_CAN_CLK_SEL_MASK (0x3 << 8) +#define MXC_CCM_CSCMR2_CAN_CLK_SEL_OFFSET 8 +#define MXC_CCM_CSCMR2_CAN_CLK_PODF_MASK (0x3F << 2) +#define MXC_CCM_CSCMR2_CAN_CLK_PODF_OFFSET 2 +#else #define MXC_CCM_CSCMR2_CAN_CLK_SEL_MASK (0x3F << 2) #define MXC_CCM_CSCMR2_CAN_CLK_SEL_OFFSET 2 +#endif
/* Define the bits in register CSCDR1 */ +#ifndef CONFIG_MX6SX #define MXC_CCM_CSCDR1_VPU_AXI_PODF_MASK (0x7 << 25) #define MXC_CCM_CSCDR1_VPU_AXI_PODF_OFFSET 25 +#endif #define MXC_CCM_CSCDR1_USDHC4_PODF_MASK (0x7 << 22) #define MXC_CCM_CSCDR1_USDHC4_PODF_OFFSET 22 #define MXC_CCM_CSCDR1_USDHC3_PODF_MASK (0x7 << 19) @@ -228,21 +265,28 @@ struct mxc_ccm_reg { #define MXC_CCM_CSCDR1_USDHC2_PODF_OFFSET 16 #define MXC_CCM_CSCDR1_USDHC1_PODF_MASK (0x7 << 11) #define MXC_CCM_CSCDR1_USDHC1_PODF_OFFSET 11 +#ifndef CONFIG_MX6SX #define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_OFFSET 8 #define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_MASK (0x7 << 8) #define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_OFFSET 6 #define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_MASK (0x3 << 6) +#endif #ifdef CONFIG_MX6SL #define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x1F #define MXC_CCM_CSCDR1_UART_CLK_SEL (1 << 6) #else #define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x3F +#ifdef CONFIG_MX6SX +#define MXC_CCM_CSCDR1_UART_CLK_SEL (1 << 6) +#endif #endif #define MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET 0
/* Define the bits in register CS1CDR */ #define MXC_CCM_CS1CDR_ESAI_CLK_PODF_MASK (0x3F << 25) #define MXC_CCM_CS1CDR_ESAI_CLK_PODF_OFFSET 25 +#define MXC_CCM_CS1CDR_SSI3_CLK_PRED_MASK (0x7 << 22) +#define MXC_CCM_CS1CDR_SSI3_CLK_PRED_OFFSET 22 #define MXC_CCM_CS1CDR_SSI3_CLK_PODF_MASK (0x3F << 16) #define MXC_CCM_CS1CDR_SSI3_CLK_PODF_OFFSET 16 #define MXC_CCM_CS1CDR_ESAI_CLK_PRED_MASK (0x3 << 9) @@ -253,6 +297,17 @@ struct mxc_ccm_reg { #define MXC_CCM_CS1CDR_SSI1_CLK_PODF_OFFSET 0
/* Define the bits in register CS2CDR */ +#ifdef CONFIG_MX6SX +#define MXC_CCM_CS2CDR_QSPI2_CLK_PODF_MASK (0x3F << 21) +#define MXC_CCM_CS2CDR_QSPI2_CLK_PODF_OFFSET 21 +#define MXC_CCM_CS2CDR_QSPI2_CLK_PODF(v) (((v) & 0x3f) << 21) +#define MXC_CCM_CS2CDR_QSPI2_CLK_PRED_MASK (0x7 << 18) +#define MXC_CCM_CS2CDR_QSPI2_CLK_PRED_OFFSET 18 +#define MXC_CCM_CS2CDR_QSPI2_CLK_PRED(v) (((v) & 0x7) << 18) +#define MXC_CCM_CS2CDR_QSPI2_CLK_SEL_MASK (0x7 << 15) +#define MXC_CCM_CS2CDR_QSPI2_CLK_SEL_OFFSET 15 +#define MXC_CCM_CS2CDR_QSPI2_CLK_SEL(v) (((v) & 0x7) << 15) +#else #define MXC_CCM_CS2CDR_ENFC_CLK_PODF_MASK (0x3F << 21) #define MXC_CCM_CS2CDR_ENFC_CLK_PODF_OFFSET 21 #define MXC_CCM_CS2CDR_ENFC_CLK_PODF(v) (((v) & 0x3f) << 21) @@ -262,6 +317,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CS2CDR_ENFC_CLK_SEL_MASK (0x3 << 16) #define MXC_CCM_CS2CDR_ENFC_CLK_SEL_OFFSET 16 #define MXC_CCM_CS2CDR_ENFC_CLK_SEL(v) (((v) & 0x3) << 16) +#endif #define MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK (0x7 << 12) #define MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET 12 #define MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK (0x7 << 9) @@ -272,9 +328,11 @@ struct mxc_ccm_reg { #define MXC_CCM_CS2CDR_SSI2_CLK_PODF_OFFSET 0
/* Define the bits in register CDCDR */ +#ifndef CONFIG_MX6SX #define MXC_CCM_CDCDR_HSI_TX_PODF_MASK (0x7 << 29) #define MXC_CCM_CDCDR_HSI_TX_PODF_OFFSET 29 #define MXC_CCM_CDCDR_HSI_TX_CLK_SEL (1 << 28) +#endif #define MXC_CCM_CDCDR_SPDIF0_CLK_PRED_MASK (0x7 << 25) #define MXC_CCM_CDCDR_SPDIF0_CLK_PRED_OFFSET 25 #define MXC_CCM_CDCDR_SPDIF0_CLK_PODF_MASK (0x7 << 19) @@ -289,6 +347,20 @@ struct mxc_ccm_reg { #define MXC_CCM_CDCDR_SPDIF1_CLK_SEL_OFFSET 7
/* Define the bits in register CHSCCDR */ +#ifdef CONFIG_MX6SX +#define MXC_CCM_CHSCCDR_ENET_PRE_CLK_SEL_MASK (0x7 << 15) +#define MXC_CCM_CHSCCDR_ENET_PRE_CLK_SEL_OFFSET 15 +#define MXC_CCM_CHSCCDR_ENET_PODF_MASK (0x7 << 12) +#define MXC_CCM_CHSCCDR_ENET_PODF_OFFSET 12 +#define MXC_CCM_CHSCCDR_ENET_CLK_SEL_MASK (0x7 << 9) +#define MXC_CCM_CHSCCDR_ENET_CLK_SEL_OFFSET 9 +#define MXC_CCM_CHSCCDR_M4_PRE_CLK_SEL_MASK (0x7 << 6) +#define MXC_CCM_CHSCCDR_M4_PRE_CLK_SEL_OFFSET 6 +#define MXC_CCM_CHSCCDR_M4_PODF_MASK (0x7 << 3) +#define MXC_CCM_CHSCCDR_M4_PODF_OFFSET 3 +#define MXC_CCM_CHSCCDR_M4_CLK_SEL_MASK (0x7) +#define MXC_CCM_CHSCCDR_M4_CLK_SEL_OFFSET 0 +#else #define MXC_CCM_CHSCCDR_IPU1_DI1_PRE_CLK_SEL_MASK (0x7 << 15) #define MXC_CCM_CHSCCDR_IPU1_DI1_PRE_CLK_SEL_OFFSET 15 #define MXC_CCM_CHSCCDR_IPU1_DI1_PODF_MASK (0x7 << 12) @@ -301,6 +373,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET 3 #define MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK (0x7) #define MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET 0 +#endif
#define CHSCCDR_CLK_SEL_LDB_DI0 3 #define CHSCCDR_PODF_DIVIDE_BY_3 2 @@ -309,12 +382,14 @@ struct mxc_ccm_reg { /* Define the bits in register CSCDR2 */ #define MXC_CCM_CSCDR2_ECSPI_CLK_PODF_MASK (0x3F << 19) #define MXC_CCM_CSCDR2_ECSPI_CLK_PODF_OFFSET 19 +/* All IPU2_DI1 are LCDIF1 on MX6SX */ #define MXC_CCM_CHSCCDR_IPU2_DI1_PRE_CLK_SEL_MASK (0x7 << 15) #define MXC_CCM_CHSCCDR_IPU2_DI1_PRE_CLK_SEL_OFFSET 15 #define MXC_CCM_CHSCCDR_IPU2_DI1_PODF_MASK (0x7 << 12) #define MXC_CCM_CHSCCDR_IPU2_DI1_PODF_OFFSET 12 #define MXC_CCM_CHSCCDR_IPU2_DI1_CLK_SEL_MASK (0x7 << 9) #define MXC_CCM_CHSCCDR_IPU2_DI1_CLK_SEL_OFFSET 9 +/* All IPU2_DI0 are LCDIF2 on MX6SX */ #define MXC_CCM_CHSCCDR_IPU2_DI0_PRE_CLK_SEL_MASK (0x7 << 6) #define MXC_CCM_CHSCCDR_IPU2_DI0_PRE_CLK_SEL_OFFSET 6 #define MXC_CCM_CHSCCDR_IPU2_DI0_PODF_MASK (0x7 << 3) @@ -335,7 +410,9 @@ struct mxc_ccm_reg { /* Define the bits in register CDHIPR */ #define MXC_CCM_CDHIPR_ARM_PODF_BUSY (1 << 16) #define MXC_CCM_CDHIPR_PERIPH_CLK_SEL_BUSY (1 << 5) +#ifndef CONFIG_MX6SX #define MXC_CCM_CDHIPR_MMDC_CH0_PODF_BUSY (1 << 4) +#endif #define MXC_CCM_CDHIPR_PERIPH2_CLK_SEL_BUSY (1 << 3) #define MXC_CCM_CDHIPR_MMDC_CH1_PODF_BUSY (1 << 2) #define MXC_CCM_CDHIPR_AHB_PODF_BUSY (1 << 1) @@ -344,13 +421,17 @@ struct mxc_ccm_reg { /* Define the bits in register CLPCR */ #define MXC_CCM_CLPCR_MASK_L2CC_IDLE (1 << 27) #define MXC_CCM_CLPCR_MASK_SCU_IDLE (1 << 26) +#ifndef CONFIG_MX6SX #define MXC_CCM_CLPCR_MASK_CORE3_WFI (1 << 25) #define MXC_CCM_CLPCR_MASK_CORE2_WFI (1 << 24) #define MXC_CCM_CLPCR_MASK_CORE1_WFI (1 << 23) +#endif #define MXC_CCM_CLPCR_MASK_CORE0_WFI (1 << 22) #define MXC_CCM_CLPCR_BYP_MMDC_CH1_LPM_HS (1 << 21) +#ifndef CONFIG_MX6SX #define MXC_CCM_CLPCR_BYP_MMDC_CH0_LPM_HS (1 << 19) #define MXC_CCM_CLPCR_WB_CORE_AT_LPM (1 << 17) +#endif #define MXC_CCM_CLPCR_WB_PER_AT_LPM (1 << 17) #define MXC_CCM_CLPCR_COSC_PWRDOWN (1 << 11) #define MXC_CCM_CLPCR_STBY_COUNT_MASK (0x3 << 9) @@ -359,15 +440,19 @@ struct mxc_ccm_reg { #define MXC_CCM_CLPCR_DIS_REF_OSC (1 << 7) #define MXC_CCM_CLPCR_SBYOS (1 << 6) #define MXC_CCM_CLPCR_ARM_CLK_DIS_ON_LPM (1 << 5) +#ifndef CONFIG_MX6SX #define MXC_CCM_CLPCR_LPSR_CLK_SEL_MASK (0x3 << 3) #define MXC_CCM_CLPCR_LPSR_CLK_SEL_OFFSET 3 #define MXC_CCM_CLPCR_BYPASS_PMIC_VFUNC_READY (1 << 2) +#endif #define MXC_CCM_CLPCR_LPM_MASK 0x3 #define MXC_CCM_CLPCR_LPM_OFFSET 0
/* Define the bits in register CISR */ #define MXC_CCM_CISR_ARM_PODF_LOADED (1 << 26) +#ifndef CONFIG_MX6SX #define MXC_CCM_CISR_MMDC_CH0_PODF_LOADED (1 << 23) +#endif #define MXC_CCM_CISR_PERIPH_CLK_SEL_LOADED (1 << 22) #define MXC_CCM_CISR_MMDC_CH1_PODF_LOADED (1 << 21) #define MXC_CCM_CISR_AHB_PODF_LOADED (1 << 20) @@ -378,7 +463,9 @@ struct mxc_ccm_reg {
/* Define the bits in register CIMR */ #define MXC_CCM_CIMR_MASK_ARM_PODF_LOADED (1 << 26) +#ifndef CONFIG_MX6SX #define MXC_CCM_CIMR_MASK_MMDC_CH0_PODF_LOADED (1 << 23) +#endif #define MXC_CCM_CIMR_MASK_PERIPH_CLK_SEL_LOADED (1 << 22) #define MXC_CCM_CIMR_MASK_MMDC_CH1_PODF_LOADED (1 << 21) #define MXC_CCM_CIMR_MASK_AHB_PODF_LOADED (1 << 20) @@ -393,6 +480,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CCOSR_CKO2_DIV_OFFSET 21 #define MXC_CCM_CCOSR_CKO2_SEL_OFFSET 16 #define MXC_CCM_CCOSR_CKO2_SEL_MASK (0x1F << 16) +#define MXC_CCM_CCOSR_CLK_OUT_SEL (0x1 << 8) #define MXC_CCM_CCOSR_CKOL_EN (0x1 << 7) #define MXC_CCM_CCOSR_CKOL_DIV_MASK (0x7 << 4) #define MXC_CCM_CCOSR_CKOL_DIV_OFFSET 4 @@ -400,6 +488,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CCOSR_CKOL_SEL_OFFSET 0
/* Define the bits in registers CGPR */ +#define MXC_CCM_CGPR_FAST_PLL_EN (1 << 16) #define MXC_CCM_CGPR_EFUSE_PROG_SUPPLY_GATE (1 << 4) #define MXC_CCM_CGPR_MMDC_EXT_CLK_DIS (1 << 2) #define MXC_CCM_CGPR_PMIC_DELAY_SCALER 1 @@ -435,8 +524,13 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR0_DCIC1_MASK (3 << MXC_CCM_CCGR0_DCIC1_OFFSET) #define MXC_CCM_CCGR0_DCIC2_OFFSET 26 #define MXC_CCM_CCGR0_DCIC2_MASK (3 << MXC_CCM_CCGR0_DCIC2_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR0_AIPS_TZ3_OFFSET 30 +#define MXC_CCM_CCGR0_AIPS_TZ3_MASK (3 << MXC_CCM_CCGR0_AIPS_TZ3_OFFSET) +#else #define MXC_CCM_CCGR0_DTCP_OFFSET 28 #define MXC_CCM_CCGR0_DTCP_MASK (3 << MXC_CCM_CCGR0_DTCP_OFFSET) +#endif
#define MXC_CCM_CCGR1_ECSPI1S_OFFSET 0 #define MXC_CCM_CCGR1_ECSPI1S_MASK (3 << MXC_CCM_CCGR1_ECSPI1S_OFFSET) @@ -448,27 +542,48 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR1_ECSPI4S_MASK (3 << MXC_CCM_CCGR1_ECSPI4S_OFFSET) #define MXC_CCM_CCGR1_ECSPI5S_OFFSET 8 #define MXC_CCM_CCGR1_ECSPI5S_MASK (3 << MXC_CCM_CCGR1_ECSPI5S_OFFSET) +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR1_ENET_CLK_ENABLE_OFFSET 10 #define MXC_CCM_CCGR1_ENET_CLK_ENABLE_MASK (3 << MXC_CCM_CCGR1_ENET_CLK_ENABLE_OFFSET) +#endif #define MXC_CCM_CCGR1_EPIT1S_OFFSET 12 #define MXC_CCM_CCGR1_EPIT1S_MASK (3 << MXC_CCM_CCGR1_EPIT1S_OFFSET) #define MXC_CCM_CCGR1_EPIT2S_OFFSET 14 #define MXC_CCM_CCGR1_EPIT2S_MASK (3 << MXC_CCM_CCGR1_EPIT2S_OFFSET) #define MXC_CCM_CCGR1_ESAIS_OFFSET 16 #define MXC_CCM_CCGR1_ESAIS_MASK (3 << MXC_CCM_CCGR1_ESAIS_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR1_WAKEUP_OFFSET 18 +#define MXC_CCM_CCGR1_WAKEUP_MASK (3 << MXC_CCM_CCGR1_WAKEUP_OFFSET) +#endif #define MXC_CCM_CCGR1_GPT_BUS_OFFSET 20 #define MXC_CCM_CCGR1_GPT_BUS_MASK (3 << MXC_CCM_CCGR1_GPT_BUS_OFFSET) #define MXC_CCM_CCGR1_GPT_SERIAL_OFFSET 22 #define MXC_CCM_CCGR1_GPT_SERIAL_MASK (3 << MXC_CCM_CCGR1_GPT_SERIAL_OFFSET) +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR1_GPU2D_OFFSET 24 #define MXC_CCM_CCGR1_GPU2D_MASK (3 << MXC_CCM_CCGR1_GPU2D_OFFSET) +#endif #define MXC_CCM_CCGR1_GPU3D_OFFSET 26 #define MXC_CCM_CCGR1_GPU3D_MASK (3 << MXC_CCM_CCGR1_GPU3D_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR1_OCRAM_S_OFFSET 28 +#define MXC_CCM_CCGR1_OCRAM_S_MASK (3 << MXC_CCM_CCGR1_OCRAM_S_OFFSET) +#define MXC_CCM_CCGR1_CANFD_OFFSET 30 +#define MXC_CCM_CCGR1_CANFD_MASK (3 << MXC_CCM_CCGR1_CANFD_OFFSET) +#endif
+#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_OFFSET 0 #define MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK (3 << MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_OFFSET) +#else +#define MXC_CCM_CCGR2_CSI_OFFSET 2 +#define MXC_CCM_CCGR2_CSI_MASK (3 << MXC_CCM_CCGR2_CSI_OFFSET) +#endif +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_OFFSET 4 #define MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK (3 << MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_OFFSET) +#endif #define MXC_CCM_CCGR2_I2C1_SERIAL_OFFSET 6 #define MXC_CCM_CCGR2_I2C1_SERIAL_MASK (3 << MXC_CCM_CCGR2_I2C1_SERIAL_OFFSET) #define MXC_CCM_CCGR2_I2C2_SERIAL_OFFSET 8 @@ -487,17 +602,33 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR2_IPMUX3_MASK (3 << MXC_CCM_CCGR2_IPMUX3_OFFSET) #define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_OFFSET 22 #define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_MASK (3 << MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC1_IPGS_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR2_LCD_OFFSET 28 +#define MXC_CCM_CCGR2_LCD_MASK (3 << MXC_CCM_CCGR2_LCD_OFFSET) +#define MXC_CCM_CCGR2_PXP_OFFSET 30 +#define MXC_CCM_CCGR2_PXP_MASK (3 << MXC_CCM_CCGR2_PXP_OFFSET) +#else #define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_OFFSET 24 #define MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_MASK (3 << MXC_CCM_CCGR2_IPSYNC_IP2APB_TZASC2_IPG_OFFSET) #define MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_OFFSET 26 #define MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_MASK (3 << MXC_CCM_CCGR2_IPSYNC_VDOA_IPG_MASTER_CLK_OFFSET) +#endif
+#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR3_M4_OFFSET 2 +#define MXC_CCM_CCGR3_M4_MASK (3 << MXC_CCM_CCGR3_M4_OFFSET) +#define MXC_CCM_CCGR3_ENET_OFFSET 4 +#define MXC_CCM_CCGR3_ENET_MASK (3 << MXC_CCM_CCGR3_ENET_OFFSET) +#define MXC_CCM_CCGR3_QSPI_OFFSET 14 +#define MXC_CCM_CCGR3_QSPI_MASK (3 << MXC_CCM_CCGR3_QSPI_OFFSET) +#else #define MXC_CCM_CCGR3_IPU1_IPU_OFFSET 0 #define MXC_CCM_CCGR3_IPU1_IPU_MASK (3 << MXC_CCM_CCGR3_IPU1_IPU_OFFSET) #define MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET 2 #define MXC_CCM_CCGR3_IPU1_IPU_DI0_MASK (3 << MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET) #define MXC_CCM_CCGR3_IPU1_IPU_DI1_OFFSET 4 #define MXC_CCM_CCGR3_IPU1_IPU_DI1_MASK (3 << MXC_CCM_CCGR3_IPU1_IPU_DI1_OFFSET) +#endif #define MXC_CCM_CCGR3_IPU2_IPU_OFFSET 6 #define MXC_CCM_CCGR3_IPU2_IPU_MASK (3 << MXC_CCM_CCGR3_IPU2_IPU_OFFSET) #define MXC_CCM_CCGR3_IPU2_IPU_DI0_OFFSET 8 @@ -506,29 +637,43 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR3_IPU2_IPU_DI1_MASK (3 << MXC_CCM_CCGR3_IPU2_IPU_DI1_OFFSET) #define MXC_CCM_CCGR3_LDB_DI0_OFFSET 12 #define MXC_CCM_CCGR3_LDB_DI0_MASK (3 << MXC_CCM_CCGR3_LDB_DI0_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR3_QSPI1_OFFSET 14 +#define MXC_CCM_CCGR3_QSPI1_MASK (3 << MXC_CCM_CCGR3_QSPI1_OFFSET) +#else #define MXC_CCM_CCGR3_LDB_DI1_OFFSET 14 #define MXC_CCM_CCGR3_LDB_DI1_MASK (3 << MXC_CCM_CCGR3_LDB_DI1_OFFSET) #define MXC_CCM_CCGR3_MIPI_CORE_CFG_OFFSET 16 #define MXC_CCM_CCGR3_MIPI_CORE_CFG_MASK (3 << MXC_CCM_CCGR3_MIPI_CORE_CFG_OFFSET) +#endif #define MXC_CCM_CCGR3_MLB_OFFSET 18 #define MXC_CCM_CCGR3_MLB_MASK (3 << MXC_CCM_CCGR3_MLB_OFFSET) #define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_OFFSET 20 #define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_MASK (3 << MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P0_OFFSET) +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_OFFSET 22 #define MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_MASK (3 << MXC_CCM_CCGR3_MMDC_CORE_ACLK_FAST_CORE_P1_OFFSET) +#endif #define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_OFFSET 24 #define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_MASK (3 << MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P0_OFFSET) #define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_OFFSET 26 #define MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_MASK (3 << MXC_CCM_CCGR3_MMDC_CORE_IPG_CLK_P1_OFFSET) #define MXC_CCM_CCGR3_OCRAM_OFFSET 28 #define MXC_CCM_CCGR3_OCRAM_MASK (3 << MXC_CCM_CCGR3_OCRAM_OFFSET) +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR3_OPENVGAXICLK_OFFSET 30 #define MXC_CCM_CCGR3_OPENVGAXICLK_MASK (3 << MXC_CCM_CCGR3_OPENVGAXICLK_OFFSET) +#endif
#define MXC_CCM_CCGR4_PCIE_OFFSET 0 #define MXC_CCM_CCGR4_PCIE_MASK (3 << MXC_CCM_CCGR4_PCIE_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR4_QSPI2_ENFC_OFFSET 10 +#define MXC_CCM_CCGR4_QSPI2_ENFC_MASK (3 << MXC_CCM_CCGR4_QSPI2_ENFC_OFFSET) +#else #define MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_OFFSET 8 #define MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_MASK (3 << MXC_CCM_CCGR4_PL301_MX6QFAST1_S133_OFFSET) +#endif #define MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET 12 #define MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_MASK (3 << MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET) #define MXC_CCM_CCGR4_PL301_MX6QPER2_MAINCLK_ENABLE_OFFSET 14 @@ -552,8 +697,10 @@ struct mxc_ccm_reg {
#define MXC_CCM_CCGR5_ROM_OFFSET 0 #define MXC_CCM_CCGR5_ROM_MASK (3 << MXC_CCM_CCGR5_ROM_OFFSET) +#ifndef CONFIG_MX6SX #define MXC_CCM_CCGR5_SATA_OFFSET 4 #define MXC_CCM_CCGR5_SATA_MASK (3 << MXC_CCM_CCGR5_SATA_OFFSET) +#endif #define MXC_CCM_CCGR5_SDMA_OFFSET 6 #define MXC_CCM_CCGR5_SDMA_MASK (3 << MXC_CCM_CCGR5_SDMA_OFFSET) #define MXC_CCM_CCGR5_SPBA_OFFSET 12 @@ -570,6 +717,12 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR5_UART_MASK (3 << MXC_CCM_CCGR5_UART_OFFSET) #define MXC_CCM_CCGR5_UART_SERIAL_OFFSET 26 #define MXC_CCM_CCGR5_UART_SERIAL_MASK (3 << MXC_CCM_CCGR5_UART_SERIAL_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR5_SAI1_OFFSET 20 +#define MXC_CCM_CCGR5_SAI1_MASK (3 << MXC_CCM_CCGR5_SAI1_OFFSET) +#define MXC_CCM_CCGR5_SAI2_OFFSET 30 +#define MXC_CCM_CCGR5_SAI2_MASK (3 << MXC_CCM_CCGR5_SAI2_OFFSET) +#endif
#define MXC_CCM_CCGR6_USBOH3_OFFSET 0 #define MXC_CCM_CCGR6_USBOH3_MASK (3 << MXC_CCM_CCGR6_USBOH3_OFFSET) @@ -583,8 +736,25 @@ struct mxc_ccm_reg { #define MXC_CCM_CCGR6_USDHC4_MASK (3 << MXC_CCM_CCGR6_USDHC4_OFFSET) #define MXC_CCM_CCGR6_EMI_SLOW_OFFSET 10 #define MXC_CCM_CCGR6_EMI_SLOW_MASK (3 << MXC_CCM_CCGR6_EMI_SLOW_OFFSET) +#ifdef CONFIG_MX6SX +#define MXC_CCM_CCGR6_PWM8_OFFSET 16 +#define MXC_CCM_CCGR6_PWM8_MASK (3 << MXC_CCM_CCGR6_PWM8_OFFSET) +#define MXC_CCM_CCGR6_VADC_OFFSET 20 +#define MXC_CCM_CCGR6_VADC_MASK (3 << MXC_CCM_CCGR6_VADC_OFFSET) +#define MXC_CCM_CCGR6_GIS_OFFSET 22 +#define MXC_CCM_CCGR6_GIS_MASK (3 << MXC_CCM_CCGR6_GIS_OFFSET) +#define MXC_CCM_CCGR6_I2C4_OFFSET 24 +#define MXC_CCM_CCGR6_I2C4_MASK (3 << MXC_CCM_CCGR6_I2C4_OFFSET) +#define MXC_CCM_CCGR6_PWM5_OFFSET 26 +#define MXC_CCM_CCGR6_PWM5_MASK (3 << MXC_CCM_CCGR6_PWM5_OFFSET) +#define MXC_CCM_CCGR6_PWM6_OFFSET 28 +#define MXC_CCM_CCGR6_PWM6_MASK (3 << MXC_CCM_CCGR6_PWM6_OFFSET) +#define MXC_CCM_CCGR6_PWM7_OFFSET 30 +#define MXC_CCM_CCGR6_PWM7_MASK (3 << MXC_CCM_CCGR6_PWM7_OFFSET) +#else #define MXC_CCM_CCGR6_VDOAXICLK_OFFSET 12 #define MXC_CCM_CCGR6_VDOAXICLK_MASK (3 << MXC_CCM_CCGR6_VDOAXICLK_OFFSET) +#endif
#define BM_ANADIG_PLL_SYS_LOCK 0x80000000 #define BP_ANADIG_PLL_SYS_RSVD0 20 diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 1f19727..b47e039 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -19,6 +19,19 @@ #define GPU_2D_ARB_END_ADDR 0x02203FFF #define OPENVG_ARB_BASE_ADDR 0x02204000 #define OPENVG_ARB_END_ADDR 0x02207FFF +#elif CONFIG_MX6SX +#define CAAM_ARB_BASE_ADDR 0x00100000 +#define CAAM_ARB_END_ADDR 0x00107FFF +#define GPU_ARB_BASE_ADDR 0x01800000 +#define GPU_ARB_END_ADDR 0x01803FFF +#define APBH_DMA_ARB_BASE_ADDR 0x01804000 +#define APBH_DMA_ARB_END_ADDR 0x0180BFFF +#define M4_BOOTROM_BASE_ADDR 0x007F8000
+#define MXS_APBH_BASE APBH_DMA_ARB_BASE_ADDR +#define MXS_GPMI_BASE (APBH_DMA_ARB_BASE_ADDR + 0x02000) +#define MXS_BCH_BASE (APBH_DMA_ARB_BASE_ADDR + 0x04000)
#else #define CAAM_ARB_BASE_ADDR 0x00100000 #define CAAM_ARB_END_ADDR 0x00103FFF @@ -39,14 +52,27 @@ #define MXS_BCH_BASE (APBH_DMA_ARB_BASE_ADDR + 0x04000)
/* GPV - PL301 configuration ports */ -#ifdef CONFIG_MX6SL +#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX)) #define GPV2_BASE_ADDR 0x00D00000 #else #define GPV2_BASE_ADDR 0x00200000 #endif
+#ifdef CONFIG_MX6SX +#define GPV3_BASE_ADDR 0x00E00000 +#define GPV4_BASE_ADDR 0x00F00000 +#define GPV5_BASE_ADDR 0x01000000 +#define GPV6_BASE_ADDR 0x01100000 +#define PCIE_ARB_BASE_ADDR 0x08000000 +#define PCIE_ARB_END_ADDR 0x08FFFFFF
+#else #define GPV3_BASE_ADDR 0x00300000 #define GPV4_BASE_ADDR 0x00800000 +#define PCIE_ARB_BASE_ADDR 0x01000000 +#define PCIE_ARB_END_ADDR 0x01FFFFFF +#endif
#define IRAM_BASE_ADDR 0x00900000 #define SCU_BASE_ADDR 0x00A00000 #define IC_INTERFACES_BASE_ADDR 0x00A00100 @@ -56,13 +82,21 @@ #define L2_PL310_BASE 0x00A02000 #define GPV0_BASE_ADDR 0x00B00000 #define GPV1_BASE_ADDR 0x00C00000 -#define PCIE_ARB_BASE_ADDR 0x01000000 -#define PCIE_ARB_END_ADDR 0x01FFFFFF
#define AIPS1_ARB_BASE_ADDR 0x02000000 #define AIPS1_ARB_END_ADDR 0x020FFFFF #define AIPS2_ARB_BASE_ADDR 0x02100000 #define AIPS2_ARB_END_ADDR 0x021FFFFF +#ifdef CONFIG_MX6SX +#define AIPS3_BASE_ADDR 0x02200000 +#define AIPS3_END_ADDR 0x022FFFFF +#define WEIM_ARB_BASE_ADDR 0x50000000 +#define WEIM_ARB_END_ADDR 0x57FFFFFF +#define QSPI1_ARB_BASE_ADDR 0x60000000 +#define QSPI1_ARB_END_ADDR 0x6FFFFFFF +#define QSPI2_ARB_BASE_ADDR 0x70000000 +#define QSPI2_ARB_END_ADDR 0x7FFFFFFF +#else #define SATA_ARB_BASE_ADDR 0x02200000 #define SATA_ARB_END_ADDR 0x02203FFF #define OPENVG_ARB_BASE_ADDR 0x02204000 @@ -75,8 +109,9 @@ #define IPU2_ARB_END_ADDR 0x02BFFFFF #define WEIM_ARB_BASE_ADDR 0x08000000 #define WEIM_ARB_END_ADDR 0x0FFFFFFF +#endif
-#ifdef CONFIG_MX6SL +#if (defined(CONFIG_MX6SL) || defined(CONFIG_MX6SX)) #define MMDC0_ARB_BASE_ADDR 0x80000000 #define MMDC0_ARB_END_ADDR 0xFFFFFFFF #define MMDC1_ARB_BASE_ADDR 0xC0000000 @@ -88,8 +123,10 @@ #define MMDC1_ARB_END_ADDR 0xFFFFFFFF #endif
+#ifndef CONFIG_MX6SX #define IPU_SOC_BASE_ADDR IPU1_ARB_BASE_ADDR #define IPU_SOC_OFFSET 0x00200000 +#endif
/* Defines for Blocks connected via AIPS (SkyBlue) */ #define ATZ1_BASE_ADDR AIPS1_ARB_BASE_ADDR @@ -112,7 +149,9 @@ #define UART3_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x34000) #define UART4_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x38000) #else +#ifndef CONFIG_MX6SX #define ECSPI5_BASE_ADDR (ATZ1_BASE_ADDR + 0x18000) +#endif #define UART1_BASE (ATZ1_BASE_ADDR + 0x20000) #define ESAI1_BASE_ADDR (ATZ1_BASE_ADDR + 0x24000) #define SSI1_BASE_ADDR (ATZ1_BASE_ADDR + 0x28000) @@ -121,8 +160,10 @@ #define ASRC_BASE_ADDR (ATZ1_BASE_ADDR + 0x34000) #endif
+#ifndef CONFIG_MX6SX #define SPBA_BASE_ADDR (ATZ1_BASE_ADDR + 0x3C000) #define VPU_BASE_ADDR (ATZ1_BASE_ADDR + 0x40000) +#endif #define AIPS1_ON_BASE_ADDR (ATZ1_BASE_ADDR + 0x7C000)
#define AIPS1_OFF_BASE_ADDR (ATZ1_BASE_ADDR + 0x80000) @@ -157,6 +198,13 @@ #define CSI_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x64000) #define SIPIX_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x68000) #define SDMA_PORT_HOST_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x6C000) +#elif CONFIG_MX6SX +#define CANFD1_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x68000) +#define SDMA_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x6C000) +#define CANFD2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x70000) +#define SEMAPHORE1_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x74000) +#define SEMAPHORE2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x78000) +#define RDC_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x7C000) #else #define DCIC1_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x64000) #define DCIC2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x68000) @@ -193,6 +241,8 @@ #define MMDC_P0_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x30000) #ifdef CONFIG_MX6SL #define RNGB_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x34000) +#elif CONFIG_MX6SX +#define ENET2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x34000) #else #define MMDC_P1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x34000) #endif @@ -202,13 +252,28 @@ #define CSU_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x40000) #define IP2APB_PERFMON1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x44000) #define IP2APB_PERFMON2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x48000) +#ifdef CONFIG_MX6SX +#define DEBUG_MONITOR_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x4C000) +#else #define IP2APB_PERFMON3_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x4C000) +#endif #define IP2APB_TZASC1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x50000) +#ifdef CONFIG_MX6SX +#define SAI1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x54000) +#else #define IP2APB_TZASC2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x54000) +#endif #define AUDMUX_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x58000) +#define AUDMUX_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x58000) +#ifdef CONFIG_MX6SX +#define SAI2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x5C000) +#define QSPI1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x60000) +#define QSPI2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x64000) +#else #define MIPI_CSI2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x5C000) #define MIPI_DSI_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x60000) #define VDOA_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x64000) +#endif #define UART2_BASE (AIPS2_OFF_BASE_ADDR + 0x68000) #define UART3_BASE (AIPS2_OFF_BASE_ADDR + 0x6C000) #define UART4_BASE (AIPS2_OFF_BASE_ADDR + 0x70000) @@ -216,8 +281,40 @@ #define IP2APB_USBPHY1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x78000) #define IP2APB_USBPHY2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x7C000)
+#ifdef CONFIG_MX6SX +#define GIS_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x04000) +#define DCIC1_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x0C000) +#define DCIC2_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x10000) +#define CSI1_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x14000) +#define PXP_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x18000) +#define CSI2_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x1C000) +#define LCDIF1_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x20000) +#define LCDIF2_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x24000) +#define VADC_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x28000) +#define VDEC_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x2C000) +#define SPBA_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x3C000) +#define AIPS3_CONFIG_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x7C000) +#define ADC1_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x80000) +#define ADC2_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x84000) +#define WDOG3_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x88000) +#define ECSPI5_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x8C000) +#define HS_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x90000) +#define MU_MCU_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x94000) +#define CANFD_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x98000) +#define MU_DSP_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0x9C000) +#define UART6_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xA0000) +#define PWM5_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xA4000) +#define PWM6_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xA8000) +#define PWM7_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xAC000) +#define PWM8_BASE_ADDR (AIPS3_ARB_BASE_ADDR + 0xB0000) +#endif
#define CHIP_REV_1_0 0x10 +#ifndef CONFIG_MX6SX #define IRAM_SIZE 0x00040000 +#else +#define IRAM_SIZE 0x00020000 +#endif #define FEC_QUIRK_ENET_MAC
#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) @@ -471,6 +568,22 @@ struct fuse_bank0_regs { u32 rsvd7[4]; };
+#ifdef CONFIG_MX6SX +struct fuse_bank4_regs {
- u32 sjc_resp_low;
- u32 rsvd0[3];
- u32 sjc_resp_high;
- u32 rsvd1[3];
- u32 mac_addr_low;
- u32 rsvd2[3];
- u32 mac_addr_high;
- u32 rsvd3[3];
- u32 mac_addr2;
- u32 rsvd4[7];
- u32 gp1;
- u32 rsvd5[7];
+}; +#else struct fuse_bank4_regs { u32 sjc_resp_low; u32 rsvd0[3]; @@ -485,6 +598,7 @@ struct fuse_bank4_regs { u32 gp2; u32 rsvd5[3]; }; +#endif
struct aipstz_regs { u32 mprot0; diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h index d544d2e..5ebabfa 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-ddr.h +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -13,7 +13,11 @@ #if defined(CONFIG_MX6DL) || defined(CONFIG_MX6S) #include "mx6dl-ddr.h" #else +#ifdef CONFIG_MX6SX +#include "mx6sx-ddr.h" +#else #error "Please select cpu" +#endif /* CONFIG_MX6SX */ #endif /* CONFIG_MX6DL or CONFIG_MX6S */ #endif /* CONFIG_MX6Q */ #else diff --git a/arch/arm/include/asm/arch-mx6/mx6sx-ddr.h b/arch/arm/include/asm/arch-mx6/mx6sx-ddr.h new file mode 100644 index 0000000..2cc94aa --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6sx-ddr.h @@ -0,0 +1,45 @@ +/*
- Copyright (C) 2014 Freescale Semiconductor, Inc.
+#ifndef __ASM_ARCH_MX6SX_DDR_H__ +#define __ASM_ARCH_MX6SX_DDR_H__
+#ifndef CONFIG_MX6SX +#error "wrong CPU" +#endif
+#define MX6_IOM_DRAM_DQM0 0x020e02ec +#define MX6_IOM_DRAM_DQM1 0x020e02f0 +#define MX6_IOM_DRAM_DQM2 0x020e02f4 +#define MX6_IOM_DRAM_DQM3 0x020e02f8
+#define MX6_IOM_DRAM_RAS 0x020e02fc +#define MX6_IOM_DRAM_CAS 0x020e0300 +#define MX6_IOM_DRAM_SDODT0 0x020e0310 +#define MX6_IOM_DRAM_SDODT1 0x020e0314 +#define MX6_IOM_DRAM_SDBA2 0x020e0320 +#define MX6_IOM_DRAM_SDCKE0 0x020e0324 +#define MX6_IOM_DRAM_SDCKE1 0x020e0328 +#define MX6_IOM_DRAM_SDCLK_0 0x020e032c +#define MX6_IOM_DRAM_RESET 0x020e0340
+#define MX6_IOM_DRAM_SDQS0 0x020e0330 +#define MX6_IOM_DRAM_SDQS1 0x020e0334 +#define MX6_IOM_DRAM_SDQS2 0x020e0338 +#define MX6_IOM_DRAM_SDQS3 0x020e033c
+#define MX6_IOM_GRP_ADDDS 0x020e05f4 +#define MX6_IOM_DDRMODE_CTL 0x020e05f8 +#define MX6_IOM_GRP_DDRPKE 0x020e05fc +#define MX6_IOM_GRP_DDRMODE 0x020e0608 +#define MX6_IOM_GRP_B0DS 0x020e060c +#define MX6_IOM_GRP_B1DS 0x020e0610 +#define MX6_IOM_GRP_CTLDS 0x020e0614 +#define MX6_IOM_GRP_DDR_TYPE 0x020e0618 +#define MX6_IOM_GRP_B2DS 0x020e061c +#define MX6_IOM_GRP_B3DS 0x020e0620
+#endif /*__ASM_ARCH_MX6SX_DDR_H__ */
Eric Nelson
Fabio Estevam
Stefano Babic
