Re: [U-Boot] ppc_4xx-objcopy: u-boot.bin: Bad value
Dear "alan A. A",
Please keep the list on Cc: (re-added).
In message COL123-W25AD9B8538C84F0BB9C44E9EA00@phx.gbl you wrote:
Which board is this? And which tool chain are you using?
This is a STBx25xx board and it is not included in the mainline U-Boot tree.
...which means that we don;t see the code and thus cannot help you.
I am using the standard ELDK tool chain, and i have successfully ported to U-Boot 1.3.2 but i want to have the latest U-Boot on this board.
U-Boot 1.3.2 is more on a year old. You really should use current code instead.
Ok, i have noticed that u-boot is greater than 4GB and this is the error message i am getting:
ppc_4xx-objcopy -O srec u-boot u-boot.srec ppc_4xx-objcopy --gap-fill=0xff -O binary u-boot u-boot.bin ppc_4xx-objcopy: u-boot.bin: Bad value ppc_4xx-objcopy: u-boot.bin: No space left on device make: *** [u-boot.bin] Error 1
So the address counter wrpas around at the end of the (32 bit) memory, which means your image is too big and/or your TEXT_BASE is too high - you might want to check your memory map in genral, and especially the setting of TEXT_BASE in your board/<name>/config.mk file.
