[U-Boot] [PATCH] mmc: Remove incorrect cmd->flags usage
There were a couple of drivers that were actually using the flags field of the cmd structure, despite the fact that no one ever *set* that field. When we removed the field, those drivers failed to compile. Replaced the references with the correct usage of resp_type.
Signed-off-by: Andy Fleming afleming@freescale.com --- I've gone and applied this to the mmc repository, as it's more correct than the current implementation. I don't anticipate any problems, but the pl180 and pxa folks should make sure their drivers still work.
drivers/mmc/arm_pl180_mmci.c | 2 +- drivers/mmc/pxa_mmc_gen.c | 8 +++++--- 2 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/arm_pl180_mmci.c b/drivers/mmc/arm_pl180_mmci.c index db2c7ab..af1380a 100644 --- a/drivers/mmc/arm_pl180_mmci.c +++ b/drivers/mmc/arm_pl180_mmci.c @@ -52,7 +52,7 @@ static int wait_for_command_end(struct mmc *dev, struct mmc_cmd *cmd) debug("CMD%d time out\n", cmd->cmdidx); return TIMEOUT; } else if ((hoststatus & SDI_STA_CCRCFAIL) && - (cmd->flags & MMC_RSP_CRC)) { + (cmd->resp_type & MMC_RSP_CRC)) { printf("CMD%d CRC error\n", cmd->cmdidx); return -EILSEQ; } diff --git a/drivers/mmc/pxa_mmc_gen.c b/drivers/mmc/pxa_mmc_gen.c index 2c5bf17..b3ec441 100644 --- a/drivers/mmc/pxa_mmc_gen.c +++ b/drivers/mmc/pxa_mmc_gen.c @@ -118,7 +118,7 @@ static int pxa_mmc_start_cmd(struct mmc *mmc, struct mmc_cmd *cmd, int ret;
/* The card can send a "busy" response */ - if (cmd->flags & MMC_RSP_BUSY) + if (cmd->resp_type & MMC_RSP_BUSY) cmdat |= MMC_CMDAT_BUSY;
/* Inform the controller about response type */ @@ -181,9 +181,11 @@ static int pxa_mmc_cmd_done(struct mmc *mmc, struct mmc_cmd *cmd) /* The command response didn't arrive */ if (stat & MMC_STAT_TIME_OUT_RESPONSE) return -ETIMEDOUT; - else if (stat & MMC_STAT_RES_CRC_ERROR && cmd->flags & MMC_RSP_CRC) { + else if (stat & MMC_STAT_RES_CRC_ERROR + && cmd->resp_type & MMC_RSP_CRC) { #ifdef PXAMMC_CRC_SKIP - if (cmd->flags & MMC_RSP_136 && cmd->response[0] & (1 << 31)) + if (cmd->resp_type & MMC_RSP_136 + && cmd->response[0] & (1 << 31)) printf("Ignoring CRC, this may be dangerous!\n"); else #endif
Dear Andy Fleming,
I'll run duts tests on this on M28, stay tuned.
printf("CMD%d CRC error\n", cmd->cmdidx); return -EILSEQ; }(cmd->resp_type & MMC_RSP_CRC)) {
else&& cmd->response[0] & (1 << 31)) printf("Ignoring CRC, this may be dangerous!\n");
#endif
Best regards, Marek Vasut
Dear Marek Vasut,
Dear Andy Fleming,
Ok, seems to work on M28.
Tested-by: Marek Vasut marex@denx.de
Andy Fleming
