[U-Boot] Please pull u-boot-dm
Hi Tom,
Here are some buildman enhancements, a new TPM driver, the beginnings of the USB gadget DM conversion along with a few fixes.
The following changes since commit 9ae0e14350758e6447c90615ff4df530549a45e2:
Merge git://www.denx.de/git/u-boot-marvell (2016-12-01 09:24:02 -0500)
git://git.denx.de/u-boot-dm.git
for you to fetch changes up to f7f191ee41c0590917f4a969b569af0a01106380:
cmd/fdt: fix uncallable systemsetup command (2016-12-02 20:53:20 -0700)
---------------------------------------------------------------- Fabien Parent (1): cmd/fdt: fix uncallable systemsetup command
George McCollister (1): tpm: tpm_tis_lpc: Add support for AT97SC3204
Michal Simek (1): dm: blk: Fix get_desc to return block device descriptor
Mugunthan V N (5): drivers: usb: gadget: ether: access network_started using local variable drivers: usb: gadget: ether: adopt to usb driver model drivers: usb: gadget: ether: consolidate global devices to single struct drivers: usb: gadget: ether: use net device priv to pass usb ether priv drivers: usb: gadget: ether: prepare driver for driver model migration
Simon Glass (7): Makefile: Add a target to create the .cfg files buildman: Add an option to just create the config buildman: Add documentation for CONFIG checking buildman: Squash useless output from -K buildman: Clean up odd characters on the terminal buildman: Rename do_build to config_only dm: core: Handle global_data moving in SPL
Stefan BrĂ¼ns (1): cmd/tpm_test: Fix misleading code indentation
Tom Rini (1): sandboxfs: Fix resource leak
Makefile | 3 + cmd/fdt.c | 22 ++++--- cmd/tpm_test.c | 12 ++-- common/spl/spl.c | 3 + drivers/block/blk-uclass.c | 2 + drivers/core/root.c | 7 +++ drivers/tpm/tpm_tis_lpc.c | 37 +++++++++--- drivers/usb/gadget/ether.c | 168 ++++++++++++++++++++++++++++++++++++----------------- fs/sandbox/sandboxfs.c | 5 +- include/dm/root.h | 10 ++++ tools/buildman/README | 49 ++++++++++++++++ tools/buildman/builder.py | 39 ++++++++----- tools/buildman/builderthread.py | 14 +++-- tools/buildman/cmdline.py | 4 ++ tools/buildman/control.py | 4 +- 15 files changed, 278 insertions(+), 101 deletions(-)
Hi Tom,
Please ignore this.
I'm going to send an updated pull request with some additional patches due to a request from Stefan Roese.
