[U-Boot] [PATCH] Exynos: Make sure ps_hold gets set in the SPL
Setting ps_hold ought to be one of the first things we do when we first boot up. If we wait until the main u-boot runs we won't set it in time and the PMIC may power us back off.
Moving ps_hold setup into the generic power_init() which should contain code that's currently duplicated in the board_power_init() of several boards.
Signed-off-by: Doug Anderson dianders@chromium.org Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- arch/arm/cpu/armv7/exynos/lowlevel_init.c | 6 +++++- arch/arm/cpu/armv7/exynos/power.c | 14 ++++++++++++++ arch/arm/include/asm/arch-exynos/power.h | 8 ++++++++ 3 files changed, 27 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/exynos/lowlevel_init.c b/arch/arm/cpu/armv7/exynos/lowlevel_init.c index 11fe5b8..ed966bc 100644 --- a/arch/arm/cpu/armv7/exynos/lowlevel_init.c +++ b/arch/arm/cpu/armv7/exynos/lowlevel_init.c @@ -39,6 +39,7 @@ enum { DO_CLOCKS = 1 << 1, DO_MEM_RESET = 1 << 2, DO_UART = 1 << 3, + DO_POWER = 1 << 4, };
int do_lowlevel_init(void) @@ -60,9 +61,12 @@ int do_lowlevel_init(void) break; default: /* This is a normal boot (not a wake from sleep) */ - actions = DO_CLOCKS | DO_MEM_RESET; + actions = DO_CLOCKS | DO_MEM_RESET | DO_POWER; }
+ if (actions & DO_POWER) + power_init(); + if (actions & DO_CLOCKS) { system_clock_init(); mem_ctrl_init(actions & DO_MEM_RESET); diff --git a/arch/arm/cpu/armv7/exynos/power.c b/arch/arm/cpu/armv7/exynos/power.c index 563abd7..8999fb9 100644 --- a/arch/arm/cpu/armv7/exynos/power.c +++ b/arch/arm/cpu/armv7/exynos/power.c @@ -112,6 +112,12 @@ static void exynos5_set_ps_hold_ctrl(void) EXYNOS_PS_HOLD_CONTROL_DATA_HIGH); }
+/* + * Set ps_hold data driving value high + * This enables the machine to stay powered on + * after the initial power-on condition goes away + * (e.g. power button). + */ void set_ps_hold_ctrl(void) { if (cpu_is_exynos5()) @@ -196,3 +202,11 @@ void power_exit_wakeup(void) else exynos4_power_exit_wakeup(); } + +int power_init(void) +{ + /* Assert PS_HOLD to indicate that we're up and running */ + set_ps_hold_ctrl(); + + return 0; +} diff --git a/arch/arm/include/asm/arch-exynos/power.h b/arch/arm/include/asm/arch-exynos/power.h index c9609a2..aa32d44 100644 --- a/arch/arm/include/asm/arch-exynos/power.h +++ b/arch/arm/include/asm/arch-exynos/power.h @@ -1726,4 +1726,12 @@ uint32_t get_reset_status(void);
/* Read the resume function and call it */ void power_exit_wakeup(void); + +/** + * SoC level power init + * + * @return Return 0 if ok, else -1 + */ +int power_init(void); + #endif
Also see http://patchwork.ozlabs.org/patch/350693/ but your patch is better.
Akshay Saraswat
