[PATCH] sandbox: Support signal handling only when requested
At present if sandbox crashes it prints a message and tries to exit. But with the recently introduced signal handler, it often seems to get stuck in a loop until the stack overflows:
Segmentation violation
Segmentation violation ...
The signal handler is only useful for a few tests, as I understand it. Make it optional.
arch/sandbox/cpu/start.c | 18 +++++++++++++++--- arch/sandbox/include/asm/state.h | 1 + 2 files changed, 16 insertions(+), 3 deletions(-)
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index e87365e800d..72fe293e8bc 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -389,6 +389,16 @@ static int sandbox_cmdline_cb_select_unittests(struct sandbox_state *state, } SANDBOX_CMDLINE_OPT_SHORT(select_unittests, 'k', 1, "Select unit tests to run");
+static int sandbox_cmdline_cb_signals(struct sandbox_state *state, + const char *arg) +{ + state->handle_signals = true; + + return 0; +} +SANDBOX_CMDLINE_OPT_SHORT(signals, 'S', 0, + "Handle signals (such as SIGSEGV) in sandbox"); + static void setup_ram_buf(struct sandbox_state *state) { /* Zero the RAM buffer if we didn't read it, to keep valgrind happy */ @@ -472,9 +482,11 @@ int main(int argc, char *argv[]) if (ret) goto err;
- ret = os_setup_signal_handlers(); - if (ret) - goto err; + if (state->handle_signals) { + ret = os_setup_signal_handlers(); + if (ret) + goto err; + }
#if CONFIG_VAL(SYS_MALLOC_F_LEN) gd->malloc_base = CONFIG_MALLOC_F_ADDR; diff --git a/arch/sandbox/include/asm/state.h b/arch/sandbox/include/asm/state.h index bca13069824..1c4c571e28d 100644 --- a/arch/sandbox/include/asm/state.h +++ b/arch/sandbox/include/asm/state.h @@ -93,6 +93,7 @@ struct sandbox_state { bool ram_buf_read; /* true if we read the RAM buffer */ bool run_unittests; /* Run unit tests */ const char *select_unittests; /* Unit test to run */ + bool handle_signals; /* Handle signals within sandbox */
/* Pointer to information for each SPI bus/cs */ struct sandbox_spi_info spi[CONFIG_SANDBOX_SPI_MAX_BUS]
Hello Simon,
do you have a reproducible example? I never have seen this.
Corrupting gd could cause an endless recursive loop, as these lines follow printing the observed string:
printf("pc = 0x%lx, ", pc); printf("pc_reloc = 0x%lx\n\n", pc - gd->reloc_off);
If we remove SA_NODEFER from the signal mask in arch/sandbox/cpu/os.c, recursion cannot occur anymore. If a segmentation violation occurs inside the handler it will be delegated to the default handler.
Furthermore we could consider removing the signal handler at the start of os_signal_action().
Best regards
Heinrich
const char *arg)
- state->handle_signals = true;
- if (ret)
goto err;
- if (state->handle_signals) {
if (ret)
goto err;
Hi Heinrich,
Hello Simon,
https://source.denx.de/u-boot/custodians/u-boot-dm/-/jobs/242433
You need to run that commit with pytest though...it does not happen when run directly.
BTW this sems to expose some rather nasty bug in dlmalloc or how it is used. I notice that as soon as the first test is run, the 'top' value in dlmalloc is outside the range of the malloc pool, which seems wrong. I wonder if there is something broken with how dm_test_pre_run() and dm_test_post_run() work.
Yes I suspect printf() is dead.
The issue is that if you get a segfault you really don't know if you can continue and do anything else.
What is the goal with the signal handler? I don't think the user can do anything about it.
Hi Heinrich,
On Mon, 22 Mar 2021 at 18:56, Simon Glass sjg@chromium.org wrote:
Hi Heinrich,
Hello Simon,
I keep hitting this problem during development with sandbox, so I think I need to apply this patch.
Does anything need to be updated in the tests?
On 6/6/21 6:44 PM, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
Hello Simon,
Hello Simon,
the signal handler prints out the crash location and this makes analyzing problems much easier. It proved valuable to me several times.
Did you try removing SA_NODEFER as proposed?
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
Hello Simon,
Hello Simon,
Well I think we are at a draw on that point, as the patch has caused me pain many times!
But what is the goal here...do you mean you want it to crash later? I just want it to crash immediately.
What's actually wrong with putting this behaviour behind a flag? You could always run with the flag enabled if needed. But I just don't think it makes sense for the default behaviour to be to try to continue operation.
On 6/6/21 7:37 PM, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
Hello Simon,
Hello Simon,
If you have not messed up gd, U-Boot will print the program counter address and the program will exit. You can try this with the exception command.
If you have messed up gd, you will still exit but you will get a SIGSEGV warning from the operating system.
I want to know the relocated PC counter when the sandbox crashes. Why do you want to hide it by default?
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
Hello Simon,
Hello Simon,
Can't you just rerun with gdb?
--Sean
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
Hello Simon,
printf("pc = 0x%lx, ", pc); printf("pc_reloc =0x%lx\n\n", pc - gd->reloc_off);
Hello Simon,
This would require that the problem is easily reproducible which may not be the case.
Best regards
Heinrich
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
On 22.03.21 06:21, Simon Glass wrote: > At present if sandbox crashes it prints a message and tries to > exit. But > with the recently introduced signal handler, it often seems to get > stuck > in a loop until the stack overflows: > > Segmentation violation > > Segmentation violation > > Segmentation violation > > Segmentation violation > > Segmentation violation > > Segmentation violation > > Segmentation violation > ...
Hello Simon,
Hello Simon,
Hm, perhaps you could keep track of how many times we've tried to catch a signal, and bail if this is the second time around. E.g. something like
static void os_signal_handler(int sig, siginfo_t *info, void *con) { /* other variables */ static int level = 0;
switch (level++) { case 0: break; case 1: sandbox_exit(); default: os_exit(0); }
/* rest of the handler */ }
--Sean
Best regards
Heinrich
Best regards
Heinrich
Am 6. Juni 2021 20:07:31 MESZ schrieb Sean Anderson seanga2@gmail.com:
Hi Heinrich,
wrote:
Hi Heinrich,
On Mon, 22 Mar 2021 at 23:02, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > On 22.03.21 06:21, Simon Glass wrote: >> At present if sandbox crashes it prints a message and tries to >> exit. But >> with the recently introduced signal handler, it often seems to
get
>> stuck >> in a loop until the stack overflows: >> >> Segmentation violation >> >> Segmentation violation >> >> Segmentation violation >> >> Segmentation violation >> >> Segmentation violation >> >> Segmentation violation >> >> Segmentation violation >> ... > > Hello Simon, > > do you have a reproducible example? I never have seen this.
happen
when run directly.
it is
value
lines
> follow printing the observed string: > > printf("pc = 0x%lx, ", pc); > printf("pc_reloc =0x%lx\n\n", pc - gd->reloc_off);
occurs
> inside the handler it will be delegated to the default handler. > > Furthermore we could consider removing the signal handler at the
start
you
can
Hello Simon,
times.
not
be the case.
Removing SA_NODEFER from the signal mask will let the OS kick in if an exception occurs in a signal handler.
No counter is needed.
Best regards
Heinrich
--Sean
Best regards
Heinrich
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
wrote:
> > Hi Heinrich, > > On Mon, 22 Mar 2021 at 23:02, Heinrich Schuchardt > xypron.glpk@gmx.de wrote: >> >> On 22.03.21 06:21, Simon Glass wrote: >>> At present if sandbox crashes it prints a message and tries to >>> exit. But >>> with the recently introduced signal handler, it often seems to
get
>>> stuck >>> in a loop until the stack overflows: >>> >>> Segmentation violation >>> >>> Segmentation violation >>> >>> Segmentation violation >>> >>> Segmentation violation >>> >>> Segmentation violation >>> >>> Segmentation violation >>> >>> Segmentation violation >>> ... >> >> Hello Simon, >> >> do you have a reproducible example? I never have seen this. > > https://source.denx.de/u-boot/custodians/u-boot-dm/-/jobs/242433 > > You need to run that commit with pytest though...it does not
happen
> when run directly. > > BTW this sems to expose some rather nasty bug in dlmalloc or how
it is
value
> in dlmalloc is outside the range of the malloc pool, which seems > wrong. I wonder if there is something broken with how > dm_test_pre_run() and dm_test_post_run() work. > >> >> Corrupting gd could cause an endless recursive loop, as these
lines
>> follow printing the observed string: >> >> printf("pc = 0x%lx, ", pc); >> printf("pc_reloc =0x%lx\n\n", pc - gd->reloc_off); > > Yes I suspect printf() is dead. > >> >> If we remove SA_NODEFER from the signal mask in
occurs
>> inside the handler it will be delegated to the default handler. >> >> Furthermore we could consider removing the signal handler at the
start
>> of os_signal_action(). > > The issue is that if you get a segfault you really don't know if
you
> can continue and do anything else. > > What is the goal with the signal handler? I don't think the user
can
Hello Simon,
times.
not
be the case.
Yes that is correct.
However I am still going to apply this patch, since I would prefer that the default behaviour is to exit with a signal, rather than continue. It indicates some sort of error (except if we are running a strange test), so it seems wrong to try to continue. It may produce other issues and sandbox is in an unknown state.
I am happy to discuss another way / patch for doing what you need.
Hi Heinrich,
Hi Heinrich,
get
happen
it is
value
lines
occurs
start
you
can
Hello Simon,
times.
not
be the case.
Applied to u-boot-dm/next, thanks!
On 7/4/21 10:15 PM, Simon Glass wrote:
Hi Heinrich,
On 6/6/21 6:44 PM, Simon Glass wrote: > Hi Heinrich, > > On Mon, 22 Mar 2021 at 18:56, Simon Glass sjg@chromium.org
wrote:
>> >> Hi Heinrich, >> >> On Mon, 22 Mar 2021 at 23:02, Heinrich Schuchardt >> xypron.glpk@gmx.de wrote: >>> >>> On 22.03.21 06:21, Simon Glass wrote: >>>> At present if sandbox crashes it prints a message and tries to >>>> exit. But >>>> with the recently introduced signal handler, it often seems to
get
>>>> stuck >>>> in a loop until the stack overflows: >>>> >>>> Segmentation violation >>>> >>>> Segmentation violation >>>> >>>> Segmentation violation >>>> >>>> Segmentation violation >>>> >>>> Segmentation violation >>>> >>>> Segmentation violation >>>> >>>> Segmentation violation >>>> ... >>> >>> Hello Simon, >>> >>> do you have a reproducible example? I never have seen this. >> >> https://source.denx.de/u-boot/custodians/u-boot-dm/-/jobs/242433 >> >> You need to run that commit with pytest though...it does not
happen
>> when run directly. >> >> BTW this sems to expose some rather nasty bug in dlmalloc or how
it is
value
>> in dlmalloc is outside the range of the malloc pool, which seems >> wrong. I wonder if there is something broken with how >> dm_test_pre_run() and dm_test_post_run() work. >> >>> >>> Corrupting gd could cause an endless recursive loop, as these
lines
>>> follow printing the observed string: >>> >>> printf("pc = 0x%lx, ", pc); >>> printf("pc_reloc =0x%lx\n\n", pc - gd->reloc_off); >> >> Yes I suspect printf() is dead. >> >>> >>> If we remove SA_NODEFER from the signal mask in
occurs
>>> inside the handler it will be delegated to the default handler. >>> >>> Furthermore we could consider removing the signal handler at the
start
>>> of os_signal_action(). >> >> The issue is that if you get a segfault you really don't know if
you
>> can continue and do anything else. >> >> What is the goal with the signal handler? I don't think the user
can
Hello Simon,
times.
not
be the case.
Your patch is not needed to exit if a signal occurs. If the U-Boot sandbox resets or exits is controlled by SANDBOX_CRASH_RESET.
As said, to solve your problem just remove SA_NODEFER from the signal mask.
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
On 6/6/21 1:28 PM, Heinrich Schuchardt wrote: > On 6/6/21 6:44 PM, Simon Glass wrote: >> Hi Heinrich, >> >> On Mon, 22 Mar 2021 at 18:56, Simon Glass sjg@chromium.org
wrote:
>>> >>> Hi Heinrich, >>> >>> On Mon, 22 Mar 2021 at 23:02, Heinrich Schuchardt >>> xypron.glpk@gmx.de wrote: >>>> >>>> On 22.03.21 06:21, Simon Glass wrote: >>>>> At present if sandbox crashes it prints a message and tries to >>>>> exit. But >>>>> with the recently introduced signal handler, it often seems to
get
>>>>> stuck >>>>> in a loop until the stack overflows: >>>>> >>>>> Segmentation violation >>>>> >>>>> Segmentation violation >>>>> >>>>> Segmentation violation >>>>> >>>>> Segmentation violation >>>>> >>>>> Segmentation violation >>>>> >>>>> Segmentation violation >>>>> >>>>> Segmentation violation >>>>> ... >>>> >>>> Hello Simon, >>>> >>>> do you have a reproducible example? I never have seen this. >>> >>> https://source.denx.de/u-boot/custodians/u-boot-dm/-/jobs/242433 >>> >>> You need to run that commit with pytest though...it does not
happen
>>> when run directly. >>> >>> BTW this sems to expose some rather nasty bug in dlmalloc or how
it is
value
>>> in dlmalloc is outside the range of the malloc pool, which seems >>> wrong. I wonder if there is something broken with how >>> dm_test_pre_run() and dm_test_post_run() work. >>> >>>> >>>> Corrupting gd could cause an endless recursive loop, as these
lines
>>>> follow printing the observed string: >>>> >>>> printf("pc = 0x%lx, ", pc); >>>> printf("pc_reloc =0x%lx\n\n", pc - gd->reloc_off); >>> >>> Yes I suspect printf() is dead. >>> >>>> >>>> If we remove SA_NODEFER from the signal mask in
occurs
>>>> inside the handler it will be delegated to the default handler. >>>> >>>> Furthermore we could consider removing the signal handler at the
start
>>>> of os_signal_action(). >>> >>> The issue is that if you get a segfault you really don't know if
you
>>> can continue and do anything else. >>> >>> What is the goal with the signal handler? I don't think the user
can
>>> do anything about it. > > Hello Simon, > > the signal handler prints out the crash location and this makes > analyzing problems much easier. It proved valuable to me several
times.
not
be the case.
Perhaps we should discuss this on a contributor call. This thread is getting too long...!
Sean Anderson
