[U-Boot] [PATCH 1/2] riscv: configs: Separate ax25-ae350 for 32/64 bit.
Separate ax25-ae350 from one to two for 32 and 64 bit individually. And also select different dts for 32 and 64 bit.
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com --- configs/ax25-ae350-32_defconfig | 33 +++++++++++++++++++++++++++++++++ configs/ax25-ae350-64_defconfig | 34 ++++++++++++++++++++++++++++++++++ configs/ax25-ae350_defconfig | 34 ---------------------------------- 3 files changed, 67 insertions(+), 34 deletions(-) create mode 100644 configs/ax25-ae350-32_defconfig create mode 100644 configs/ax25-ae350-64_defconfig delete mode 100644 configs/ax25-ae350_defconfig
diff --git a/configs/ax25-ae350-32_defconfig b/configs/ax25-ae350-32_defconfig new file mode 100644 index 0000000..9126c39 --- /dev/null +++ b/configs/ax25-ae350-32_defconfig @@ -0,0 +1,33 @@ +CONFIG_RISCV=y +CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_TARGET_AX25_AE350=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_FIT=y +CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SYS_PROMPT="RISC-V # " +CONFIG_CMD_IMLS=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SF_TEST=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_PREFER_SERVERIP=y +CONFIG_CMD_CACHE=y +CONFIG_OF_BOARD=y +CONFIG_DEFAULT_DEVICE_TREE="ae350_32" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_MMC=y +CONFIG_FTSDC010=y +CONFIG_FTSDC010_SDIO=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_CFI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_FTMAC100=y +CONFIG_BAUDRATE=38400 +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_ATCSPI200_SPI=y +CONFIG_ATCPIT100_TIMER=y diff --git a/configs/ax25-ae350-64_defconfig b/configs/ax25-ae350-64_defconfig new file mode 100644 index 0000000..7923050 --- /dev/null +++ b/configs/ax25-ae350-64_defconfig @@ -0,0 +1,34 @@ +CONFIG_RISCV=y +CONFIG_SYS_TEXT_BASE=0x00000000 +CONFIG_TARGET_AX25_AE350=y +CONFIG_CPU_RISCV_64=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_FIT=y +CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SYS_PROMPT="RISC-V # " +CONFIG_CMD_IMLS=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SF_TEST=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_PREFER_SERVERIP=y +CONFIG_CMD_CACHE=y +CONFIG_OF_BOARD=y +CONFIG_DEFAULT_DEVICE_TREE="ae350_64" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_MMC=y +CONFIG_FTSDC010=y +CONFIG_FTSDC010_SDIO=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_CFI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_FTMAC100=y +CONFIG_BAUDRATE=38400 +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_ATCSPI200_SPI=y +CONFIG_ATCPIT100_TIMER=y diff --git a/configs/ax25-ae350_defconfig b/configs/ax25-ae350_defconfig deleted file mode 100644 index 614ef15..0000000 --- a/configs/ax25-ae350_defconfig +++ /dev/null @@ -1,34 +0,0 @@ -CONFIG_RISCV=y -CONFIG_SYS_TEXT_BASE=0x00000000 -CONFIG_TARGET_AX25_AE350=y -CONFIG_CPU_RISCV_64=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_FIT=y -CONFIG_BOOTDELAY=3 -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_PROMPT="RISC-V # " -CONFIG_CMD_IMLS=y -CONFIG_CMD_MMC=y -CONFIG_CMD_SF=y -CONFIG_CMD_SF_TEST=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_BOOTP_PREFER_SERVERIP=y -CONFIG_CMD_CACHE=y -CONFIG_OF_BOARD=y -CONFIG_DEFAULT_DEVICE_TREE="ae350" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_MMC=y -CONFIG_FTSDC010=y -CONFIG_FTSDC010_SDIO=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_CFI_FLASH=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_FTMAC100=y -CONFIG_BAUDRATE=38400 -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_ATCSPI200_SPI=y -CONFIG_ATCPIT100_TIMER=y
Hi Rick,
I believe the convention is to use _32 / _64 instead of -32 / -64 here.
Regards, Bin
Bin Meng bmeng.cn@gmail.com 於 2018年10月8日 週一 下午11:51寫道:
Hi Rick,
Hi Bin
I will rename it.
Thanks for your remind.
Rick
Regards, Bin
Andes
Bin Meng
Rick Chen
