[U-Boot] [PATCH v4] sun50i: a64: Add Olimex A64-Teres-I board initial support
Olimex A64-Teres-I board is a mainboard (the only one so far) for Olimex Teres-I DIY laptop kit.
Key features: - Allwinner A64 Cortex-A53 - Mali-400MP2 GPU - AXP803 PMIC - 2GB DDR3 RAM - MicroSD Slot - 16GB eMMC Flash - eDP LCD display - HDMI - USB Host - Battery management - 5V DC power supply - Certified Open Source Hardware (OSHW)
Works: - i2C - MMC/SD - PWM backlight
Known broken: - Internal keyboard (seems to be because the keyboard firmware loads a bootloader first, and then disconnects bootloader and connect real keyboard). External ones connected to the USB port work fine.
This patch enables support for the A64-Teres-I board to u-boot, including enabling screen backlight (lacking from Linux device-tree).
Linux commit details about the sun50i-a64-teres-i.dts sync: "arm64: dts: allwinner: a64: Rename uart0_pins_a label to uart0_pb_pins" (sha1: d91ebb95b96c8840932dc3a10c9f243712555467)
Cosmetic warnings regarding whitespace and placement of SPDX notice for dts file was ignored.
config and .dtsi file are adapted from pinebook files.
Tested-by: Jonas Smedegaard dr@jones.dk Signed-off-by: Jonas Smedegaard dr@jones.dk Signed-off-by: Icenowy Zheng icenowy@aosc.io --- Changes for v4: * Added Vbus activision for USB. * Dropped links in the commit message. * Dropped Jonas's personal tree in MAINTAINERS item. * Moved board-related MAINTAINERS item to board/sunxi/MAINTAINERS.
Changes for v3: * Use tags sun50i a64 (not sunxi) * List key, working, and known broken features * Reference upstream pages. * Reference linux commit
Changes for v2: * List Icenowy and Jonas as MAINTAINERS * Add commit hash in linux tree for sun50i-a64-teres-i.dts * Drop superfluous and unsupported Author: tag
arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun50i-a64-teres-i-u-boot.dtsi | 41 +++ arch/arm/dts/sun50i-a64-teres-i.dts | 270 ++++++++++++++++++++ board/sunxi/MAINTAINERS | 6 + configs/teres_i_defconfig | 22 ++ 5 files changed, 341 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun50i-a64-teres-i-u-boot.dtsi create mode 100644 arch/arm/dts/sun50i-a64-teres-i.dts create mode 100644 configs/teres_i_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0aee8dfde0..eabe9e1ae3 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -483,7 +483,8 @@ dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-pine64-plus.dtb \ sun50i-a64-pine64.dtb \ sun50i-a64-pinebook.dtb \ - sun50i-a64-sopine-baseboard.dtb + sun50i-a64-sopine-baseboard.dtb \ + sun50i-a64-teres-i.dtb dtb-$(CONFIG_MACH_SUN9I) += \ sun9i-a80-optimus.dtb \ sun9i-a80-cubieboard4.dtb \ diff --git a/arch/arm/dts/sun50i-a64-teres-i-u-boot.dtsi b/arch/arm/dts/sun50i-a64-teres-i-u-boot.dtsi new file mode 100644 index 0000000000..1a64b7d09c --- /dev/null +++ b/arch/arm/dts/sun50i-a64-teres-i-u-boot.dtsi @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2019 Vasily Khoruzhick anarsoul@gmail.com + * + */ + +#include "sunxi-u-boot.dtsi" + +/ { + vdd_bl: regulator@0 { + compatible = "regulator-fixed"; + regulator-name = "bl-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&pio 7 6 GPIO_ACTIVE_HIGH>; /* PH6 */ + enable-active-high; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + pwms = <&pwm 0 50000 0>; + brightness-levels = <0 5 10 15 20 30 40 55 70 85 100>; + default-brightness-level = <2>; + enable-gpios = <&pio 3 23 GPIO_ACTIVE_HIGH>; /* PD23 */ + power-supply = <&vdd_bl>; + }; +}; + +/* The ANX6345 eDP-bridge is on i2c */ +&i2c0 { + anx6345: edp-bridge@38 { + compatible = "analogix,anx6345"; + reg = <0x38>; + reset-gpios = <&pio 3 24 GPIO_ACTIVE_LOW>; /* PD24 */ + status = "okay"; + }; +}; + +&pwm { + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-a64-teres-i.dts b/arch/arm/dts/sun50i-a64-teres-i.dts new file mode 100644 index 0000000000..c455b24dd0 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-teres-i.dts @@ -0,0 +1,270 @@ +/* + * Copyright (C) Harald Geyer harald@ccbib.org + * based on sun50i-a64-olinuxino.dts by Jagan Teki jteki@openedev.com + * + * SPDX-License-Identifier: (GPL-2.0 OR MIT) + */ + +/dts-v1/; + +#include "sun50i-a64.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pwm/pwm.h> + +/ { + model = "Olimex A64 Teres-I"; + compatible = "olimex,a64-teres-i", "allwinner,sun50i-a64"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + + framebuffer-lcd { + eDP25-supply = <®_dldo2>; + eDP12-supply = <®_dldo3>; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + + lid-switch { + label = "Lid Switch"; + gpios = <&r_pio 0 8 GPIO_ACTIVE_LOW>; /* PL8 */ + linux,input-type = <EV_SW>; + linux,code = <SW_LID>; + wakeup-source; + }; + }; + + leds { + compatible = "gpio-leds"; + + capslock { + label = "teres-i:green:capslock"; + gpios = <&pio 2 7 GPIO_ACTIVE_HIGH>; /* PC7 */ + }; + + numlock { + label = "teres-i:green:numlock"; + gpios = <&pio 2 4 GPIO_ACTIVE_HIGH>; /* PC4 */ + }; + }; + + reg_usb1_vbus: usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + gpio = <&r_pio 0 7 GPIO_ACTIVE_HIGH>; /* PL7 */ + status = "okay"; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ + }; +}; + +&ehci1 { + status = "okay"; +}; + + +/* The ANX6345 eDP-bridge is on i2c0. There is no linux (mainline) + * driver for this chip at the moment, the bootloader initializes it. + * However it can be accessed with the i2c-dev driver from user space. + */ +&i2c0 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_dcdc1>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_aldo2>; + vqmmc-supply = <®_dldo4>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + rtl8723bs: wifi@1 { + reg = <1>; + interrupt-parent = <&r_pio>; + interrupts = <0 3 IRQ_TYPE_LEVEL_LOW>; /* PL3 */ + interrupt-names = "host-wake"; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_dcdc1>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + wakeup-source; + }; +}; + +#include "axp803.dtsi" + +®_aldo1 { + regulator-always-on; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "vcc-pe"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1040000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-ddr3"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-hdmi"; +}; + +®_dldo2 { + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-name = "vcc-pd"; +}; + +®_dldo3 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vdd-edp"; +}; + +®_dldo4 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi-io"; +}; + +®_eldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "cpvdd"; +}; + +®_eldo2 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-dvdd-csi"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-1v2-hsic"; +}; + +/* + * The A64 chip cannot work without this regulator off, although + * it seems to be only driving the AR100 core. + * Maybe we don't still know well about CPUs domain. + */ +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + +&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&usbphy { + usb1_vbus-supply = <®_usb1_vbus>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 338f374e56..08dd809599 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -451,6 +451,12 @@ M: Maxime Ripard maxime.ripard@bootlin.com S: Maintained F: configs/tbs_a711_defconfig
+OLIMEX TERES-I BOARD +M: Jonas Smedegaard dr@jones.dk +M: Icenowy Zheng icenowy@aosc.io +S: Maintained +F: configs/teres_i_defconfig + WEXLER-TAB7200 BOARD M: Aleksei Mamlin mamlinav@gmail.com S: Maintained diff --git a/configs/teres_i_defconfig b/configs/teres_i_defconfig new file mode 100644 index 0000000000..421a8d3d40 --- /dev/null +++ b/configs/teres_i_defconfig @@ -0,0 +1,22 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN50I=y +CONFIG_DRAM_CLK=552 +CONFIG_DRAM_ZQ=3881949 +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_USB1_VBUS_PIN="PL7" +CONFIG_I2C0_ENABLE=y +# CONFIG_CMD_FLASH is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-teres-i" +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_PWM=y +CONFIG_PWM_SUNXI=y +CONFIG_USB_EHCI_HCD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +# CONFIG_USB_GADGET is not set +CONFIG_VIDEO_BRIDGE=y +CONFIG_VIDEO_BRIDGE_ANALOGIX_ANX6345=y
Key features:
- Mali-400MP2 GPU
- AXP803 PMIC
- 2GB DDR3 RAM
- MicroSD Slot
- 16GB eMMC Flash
- eDP LCD display
- HDMI
- USB Host
Works:
- i2C
- MMC/SD
- PWM backlight
Known broken:
Changes for v4:
- Added Vbus activision for USB.
- Dropped links in the commit message.
- Dropped Jonas's personal tree in MAINTAINERS item.
- Moved board-related MAINTAINERS item to board/sunxi/MAINTAINERS.
Changes for v3:
- Use tags sun50i a64 (not sunxi)
- List key, working, and known broken features
- Reference upstream pages.
- Reference linux commit
Changes for v2:
- List Icenowy and Jonas as MAINTAINERS
- Add commit hash in linux tree for sun50i-a64-teres-i.dts
- Drop superfluous and unsupported Author: tag
Moved the entry in proper loaction and
Applied to u-boot-sunxi/master
Icenowy Zheng
Jagan Teki
