Re: [U-Boot-Users] [PATCH] (Resubmit) ADD ARM AMBA PL031 RTCSupport
Are you going to add a board which will use it? Right now i am using it on arm Versatile board. Should i send a
patch
to that also
If you do I can test it
Regards Peter
Please find attached my changes to arm versatile config & board file to enable rtc module This is for test only. If you find it acceptable then i will send a final patch.
Comments are welcome.
TIA
Regards Gururaja
patch
to that also
Regards Peter
Could you please send your patch as inline, otherwise it's really difficult to comment use git-send-email as example
and also please read this http://www.denx.de/wiki/UBoot/Patches and http://lwn.net/Articles/139918/
Best Regads, J.
Hi j,
Sorry for the whitespace mistakes. i have now corrected it.
But regarding sending patch inline i am finding it very difficult. I am using MS Off Outlook to send patches to uboot and other mailing lists. I also pasted the same code that i copied from patch files to the mail. Since i think it wraps and creates other issues, i am attaching the patch that i generated using " diff -purN ".
Since our proxy server has some issue, i am not to clone from uboot git server. So here is the thing.
I have downloaded uboot-1.3.3.tar.bz2 and extracted to local system. I have copied to the same to a diff directory on which i work.
so,
u-boot-1.3.3/ ---> original unmodified source uboot/ ---> modified source
I take a diff of these two folders and send it as patch. Now from past few days i am trying to use git to create and send patch to mailing list.
Here is what i do,
1. 1st i tried diff -purN u-boot-1.3.3/drivers/rtc uboot/drivers/rtc/ > new_pl031_rtc_drvr.patch to create a well known patch creation command
2. then i tried git-diff -p --summary --stat u-boot-1.3.3/drivers/rtc/ uboot/drivers/rtc > new_pl031_rtc_drvr_v2.patch to create another patch.
Both didnt have match difference except the 2nd give me few more info. I sent 2 mail to uboot mailing list, each time picking patch from each step and also pasting from the patch file
3. Now i tried git-format-patch
$ git-format-patch.exe u-boot-1.3.3/drivers/rtc/ uboot/drivers/rtc/ fatal: Not a git repository
So kindly know how to solve this.
Regards Gururaja
I think nabble wont truncate or line wrap my mail. So i am giving it a try.
I have added changes required for versatile board to call rtc_init & defines in include/configs/versatile.h to include pl031 rtc definitions
Kindly comment
TIA
Regards Gururaja
- Add ARM AMBA PL031 RTC Support - Call rtc_init function to start pl031 rtc if enabled from versatile.c - Define rtc base address and date command support in versatile.h
Signed-off-by: Gururaja gururajakr@sanyo.co.in
diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile old mode 100644 new mode 100755 index 2e0c118..f888a31 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -56,6 +56,7 @@ COBJS-y += rs5c372.o COBJS-y += rx8025.o COBJS-y += s3c24x0_rtc.o COBJS-y += x1205.o +COBJS-y += rtc_pl031.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/rtc/rtc_pl031.c b/drivers/rtc/rtc_pl031.c new file mode 100755 index 0000000..7136fed --- /dev/null +++ b/drivers/rtc/rtc_pl031.c @@ -0,0 +1,121 @@ +/* + * (C) Copyright 2008 + * Gururaja Hebbar gururajakr@sanyo.co.in + * + * reference linux-2.6.20.6/drivers/rtc/rtc-pl031.c + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <rtc.h> + +#if defined(CONFIG_RTC_PL031) && defined(CONFIG_CMD_DATE) + +#ifndef CFG_RTC_PL031_BASE +#error CFG_RTC_PL031_BASE is not defined! +#endif + +/* + * Register definitions + */ +#define RTC_DR 0x00 /* Data read register */ +#define RTC_MR 0x04 /* Match register */ +#define RTC_LR 0x08 /* Data load register */ +#define RTC_CR 0x0c /* Control register */ +#define RTC_IMSC 0x10 /* Interrupt mask and set register */ +#define RTC_RIS 0x14 /* Raw interrupt status register */ +#define RTC_MIS 0x18 /* Masked interrupt status register */ +#define RTC_ICR 0x1c /* Interrupt clear register */ + +#define RTC_CR_START (1 << 0) + +#define RTC_WRITE_REG(addr, val) (*(volatile unsigned int *)(CFG_RTC_PL031_BASE + (addr)) = (val)) +#define RTC_READ_REG(addr) (*(volatile unsigned int *)(CFG_RTC_PL031_BASE + (addr))) + +static int pl031_initted = 0; + +/* Enable RTC Start in Control register*/ +void rtc_init(void) +{ + RTC_WRITE_REG(RTC_CR,RTC_CR_START); + + pl031_initted = 1; +} + +/* + * Reset the RTC. We set the date back to 1970-01-01. + */ +void rtc_reset(void) +{ + RTC_WRITE_REG(RTC_LR,0x00); + if(!pl031_initted) + rtc_init(); +} + +/* + * Set the RTC +*/ +void rtc_set(struct rtc_time *tmp) +{ + unsigned long tim; + + if(!pl031_initted) + rtc_init(); + + if (tmp == NULL) { + puts("Error setting the date/time\n"); + return; + } + + /* Calculate number of seconds this incoming time represents */ + tim = mktime(tmp->tm_year, tmp->tm_mon, tmp->tm_mday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + + RTC_WRITE_REG(RTC_LR,tim); +} + +/* + * Get the current time from the RTC + */ +int rtc_get(struct rtc_time *tmp) +{ + ulong tim; + + if(!pl031_initted) + rtc_init(); + + if (tmp == NULL) { + puts("Error getting the date/time\n"); + return -1; + } + + tim = RTC_READ_REG(RTC_DR); + + to_tm (tim, tmp); + + debug ( "Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + + return 0; +} + +#endif
Don't think - test before sending to public mailing lists.
Line wrapped. Unusable.
Sorry for that.
Now i have generated the patch using below command. Update me if this is not correct $ git format-patch -p -o ../ -C -M -N --summary --stat=80 --no-color --signoff master workingbranch
TIA
Regards Gururaja
- Add ARM AMBA PL031 RTC Support - Call rtc_init function to start pl031 rtc if enabled from versatile.c - Define rtc base address and date command support in versatile.h - Coding Style Changes/Updates
Signed-off-by: Gururaja Hebbar gururajakr@sanyo.co.in --- drivers/rtc/Makefile | 1 + drivers/rtc/rtc_pl031.c | 123 +++++++++++++++++++++++++++++++++++++++++++++++ board/versatile/versatile.c | 9 +++++++++ include/configs/versatile.h | 7 +++++++
diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index 2e0c118..f888a31 100755 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -56,6 +56,7 @@ COBJS-y += rs5c372.o COBJS-y += rx8025.o COBJS-y += s3c24x0_rtc.o COBJS-y += x1205.o +COBJS-y += rtc_pl031.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/rtc/rtc_pl031.c b/drivers/rtc/rtc_pl031.c new file mode 100755 index 0000000..ff8926d --- /dev/null +++ b/drivers/rtc/rtc_pl031.c @@ -0,0 +1,123 @@ +/* + * (C) Copyright 2008 + * Gururaja Hebbar gururajakr@sanyo.co.in + * + * reference linux-2.6.20.6/drivers/rtc/rtc-pl031.c + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <rtc.h> + +#if defined(CONFIG_RTC_PL031) && defined(CONFIG_CMD_DATE) + +#ifndef CFG_RTC_PL031_BASE +#error CFG_RTC_PL031_BASE is not defined! +#endif + +/* + * Register definitions + */ +#define RTC_DR 0x00 /* Data read register */ +#define RTC_MR 0x04 /* Match register */ +#define RTC_LR 0x08 /* Data load register */ +#define RTC_CR 0x0c /* Control register */ +#define RTC_IMSC 0x10 /* Interrupt mask and set register */ +#define RTC_RIS 0x14 /* Raw interrupt status register */ +#define RTC_MIS 0x18 /* Masked interrupt status register */ +#define RTC_ICR 0x1c /* Interrupt clear register */ + +#define RTC_CR_START (1 << 0) + +#define RTC_WRITE_REG(addr, val) \ + (*(volatile unsigned int *)(CFG_RTC_PL031_BASE + (addr)) = (val)) +#define RTC_READ_REG(addr) \ + (*(volatile unsigned int *)(CFG_RTC_PL031_BASE + (addr))) + +static int pl031_initted = 0; + +/* Enable RTC Start in Control register*/ +void rtc_init(void) +{ + RTC_WRITE_REG(RTC_CR,RTC_CR_START); + + pl031_initted = 1; +} + +/* + * Reset the RTC. We set the date back to 1970-01-01. + */ +void rtc_reset(void) +{ + RTC_WRITE_REG(RTC_LR,0x00); + if(!pl031_initted) + rtc_init(); +} + +/* + * Set the RTC +*/ +void rtc_set(struct rtc_time *tmp) +{ + unsigned long tim; + + if(!pl031_initted) + rtc_init(); + + if (tmp == NULL) { + puts("Error setting the date/time\n"); + return; + } + + /* Calculate number of seconds this incoming time represents */ + tim = mktime(tmp->tm_year, tmp->tm_mon, tmp->tm_mday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + + RTC_WRITE_REG(RTC_LR,tim); +} + +/* + * Get the current time from the RTC + */ +int rtc_get(struct rtc_time *tmp) +{ + ulong tim; + + if(!pl031_initted) + rtc_init(); + + if (tmp == NULL) { + puts("Error getting the date/time\n"); + return -1; + } + + tim = RTC_READ_REG(RTC_DR); + + to_tm (tim, tmp); + + debug ( "Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + + return 0; +} + +#endif
Please move such comments *below* the '---' line. Anything ABOVE '---' will become the commit message that goes into the repository, only stuff below the '---' gets ignores as comment.
So this is actually not a single patch, but TWO:
- the first one adds support for the PL031 RTC (files drivers/rtc/Makefile and drivers/rtc/rtc_pl031.c) - the second one uses it for the "versatile" board (files board/versatile/versatile.c and include/configs/versatile.h).
So please split your patch and submit as two separate patches.
diff --git a/board/versatile/versatile.c b/board/versatile/versatile.c index 9d1a25e..5bf7e85 100644 --- a/board/versatile/versatile.c +++ b/board/versatile/versatile.c
+#if defined(CONFIG_RTC_PL031) && defined(CONFIG_CMD_DATE) +extern int rtc_init(void); +#endif
#if defined(CONFIG_SHOW_BOOT_PROGRESS) void show_boot_progress(int progress) { @@ -84,6 +88,11 @@ int board_init (void)
flash__init (); ether__init ();
- rtc_init();
Why do we need the #ifdef's here? It seems this is a board specific configuration anyway, i. e. we don't expect for example other RTC chips to be used on this board, or do we?
Yes i will do & re-submit
Peter Pearse & Jean-Christophe PLAGNIOL-VILLARD had asked me to the board details which will be using it. So i added it here. I already sent a separate Versatile Board Update Only Code to Peter Pearse but not received any update from him.
Ok will do that
- rtc_init();
If the user doesn't Need to Use RTC, He can Just disable it from Versatile Board Config file versatile.h. This was my Idea. Isn't it required
Regards Gururaja
Also I Just Checked u-boot-1.3.3/board/bc3450/bc3450.c. Even here it has a declaration for RTC @ line 47
#ifdef CONFIG_RTC_MPC5200 #include <rtc.h> #endif
@ line 371
#ifdef CONFIG_RTC_MPC5200 struct rtc_time t;
/* set to Wed Dec 31 19:00:00 1969 */ t.tm_sec = t.tm_min = 0; t.tm_hour = 19; t.tm_mday = 31; t.tm_mon = 12; t.tm_year = 1969; t.tm_wday = 3;
rtc_set(&t); #endif /* CONFIG_RTC_MPC5200 */
So i think its correct. Please Update me if i am wrong
Regards Gururaja
Gururaja Hebbar K R
Hebbar
