[U-Boot] [PATCH v4 0/7] Add support for the SoCs found in Microsemi switches
Hello,
For the record this the fourth version of the series adding the support of 2 SoCs: Ocelot and Luton from Microsemi. Both of them belongs to the same family Vcore III.
We found them on various advanced switches product.
The support for Ocelot already have been submit to Linux, but not yet the Luton support.
The comments on v3 were fewer and quite easy to address, so I am able to send a new version right one (hopping it will be the final one :) ).
Gregory
Changelog:
v3 -> v4:
- add the support for the legacy kernel more generic and more related to the old bootloader: redboot - removed useless test on CONFIG_ARCH_MSCC in arch/mips/mach-mscc/include/ioremap.h - add an explanation about the cache instruction lock in hal_vcoreiii_ddr_failed() - use __raw_read/write instead of directly use pointer dereferencing - use rmb instead of asm volatile("" : : : "memory"); - remove remaining C++ style comment - use __maybe_unused instead of __attribute__ ((unused)) - indent by an extra space the instructions in the delay slot
v2 -> v3: - Added n entry in the MAINTAINER file for the SoCs - Fixup the last errors from checkpatch, the remaining ones are only about volatile, long line and Kconfig, but each ones have good reason to be here. - Add SPI NAND flash support in device tree and configuration files, the driver are already be merged in U-Boot. - In order to improve boot time, setup the TLB to allow using cache in the memory mapped to the SPI NOR. - Removed all the macro REG_CFG to only keep direct access to memory. - Put back the setting of the interrupt map as it is needed by mainline kernel (without it the kernel doesn't finish to boot) - During DDR training, prevent the compiler reordering the instruction. - Add early debug support to Ocelot (it was already done for Luton)
v1 -> v2: - a big clean-up for indentation and some style issue - usage of the clrsetbits family functions where it was possible - split the patches for Ocelot and Luton - add a new patch to introduce the icache_lock function which was in the mscc directory in the first version - remove more unused define in the platform header files - use the automatic cache size detection instead of hard coding it - reduce the tlb init to only two entries for the IO as needed by the kernel - remove the interrupt disabling - fix the ddr init for luton
Gregory CLEMENT (7): MIPS: move create_tlb() in an proper header: mipsregs.h MIPS: Allow to prefetch and lock instructions into cache MSCC: add support for Ocelot SoCs MSCC: add support for Luton SoCs MSCC: add board support for the Ocelots based evaluation boards MSCC: add board support for the Luton based evaluation board MIPS: bootm: Add support for compatibility with redboot
MAINTAINERS | 13 + arch/mips/Kconfig | 10 + arch/mips/Makefile | 1 + arch/mips/cpu/cpu.c | 10 - arch/mips/dts/luton_pcb091.dts | 36 + arch/mips/dts/mscc,luton.dtsi | 87 ++ arch/mips/dts/mscc,ocelot.dtsi | 152 ++++ arch/mips/dts/mscc,ocelot_pcb.dtsi | 42 + arch/mips/dts/ocelot_pcb120.dts | 12 + arch/mips/dts/ocelot_pcb123.dts | 12 + arch/mips/include/asm/cacheops.h | 19 + arch/mips/include/asm/mipsregs.h | 11 + arch/mips/lib/bootm.c | 76 +- arch/mips/mach-mscc/Kconfig | 86 ++ arch/mips/mach-mscc/Makefile | 6 + arch/mips/mach-mscc/cpu.c | 102 +++ arch/mips/mach-mscc/dram.c | 73 ++ arch/mips/mach-mscc/include/ioremap.h | 49 ++ arch/mips/mach-mscc/include/mach/common.h | 28 + arch/mips/mach-mscc/include/mach/ddr.h | 814 ++++++++++++++++++ .../mips/mach-mscc/include/mach/luton/luton.h | 24 + .../include/mach/luton/luton_devcpu_gcb.h | 14 + .../include/mach/luton/luton_icpu_cfg.h | 245 ++++++ .../mach-mscc/include/mach/ocelot/ocelot.h | 24 + .../include/mach/ocelot/ocelot_devcpu_gcb.h | 21 + .../include/mach/ocelot/ocelot_icpu_cfg.h | 274 ++++++ arch/mips/mach-mscc/include/mach/tlb.h | 55 ++ arch/mips/mach-mscc/lowlevel_init.S | 30 + arch/mips/mach-mscc/lowlevel_init_luton.S | 62 ++ arch/mips/mach-mscc/reset.c | 30 + board/mscc/luton/Kconfig | 14 + board/mscc/luton/Makefile | 3 + board/mscc/luton/luton.c | 28 + board/mscc/ocelot/Kconfig | 14 + board/mscc/ocelot/Makefile | 4 + board/mscc/ocelot/ocelot.c | 58 ++ configs/mscc_luton_defconfig | 66 ++ configs/mscc_ocelot_defconfig | 73 ++ configs/mscc_ocelot_pcb120_defconfig | 66 ++ include/configs/vcoreiii.h | 82 ++ 40 files changed, 2796 insertions(+), 30 deletions(-) create mode 100644 arch/mips/dts/luton_pcb091.dts create mode 100644 arch/mips/dts/mscc,luton.dtsi create mode 100644 arch/mips/dts/mscc,ocelot.dtsi create mode 100644 arch/mips/dts/mscc,ocelot_pcb.dtsi create mode 100644 arch/mips/dts/ocelot_pcb120.dts create mode 100644 arch/mips/dts/ocelot_pcb123.dts create mode 100644 arch/mips/mach-mscc/Kconfig create mode 100644 arch/mips/mach-mscc/Makefile create mode 100644 arch/mips/mach-mscc/cpu.c create mode 100644 arch/mips/mach-mscc/dram.c create mode 100644 arch/mips/mach-mscc/include/ioremap.h create mode 100644 arch/mips/mach-mscc/include/mach/common.h create mode 100644 arch/mips/mach-mscc/include/mach/ddr.h create mode 100644 arch/mips/mach-mscc/include/mach/luton/luton.h create mode 100644 arch/mips/mach-mscc/include/mach/luton/luton_devcpu_gcb.h create mode 100644 arch/mips/mach-mscc/include/mach/luton/luton_icpu_cfg.h create mode 100644 arch/mips/mach-mscc/include/mach/ocelot/ocelot.h create mode 100644 arch/mips/mach-mscc/include/mach/ocelot/ocelot_devcpu_gcb.h create mode 100644 arch/mips/mach-mscc/include/mach/ocelot/ocelot_icpu_cfg.h create mode 100644 arch/mips/mach-mscc/include/mach/tlb.h create mode 100644 arch/mips/mach-mscc/lowlevel_init.S create mode 100644 arch/mips/mach-mscc/lowlevel_init_luton.S create mode 100644 arch/mips/mach-mscc/reset.c create mode 100644 board/mscc/luton/Kconfig create mode 100644 board/mscc/luton/Makefile create mode 100644 board/mscc/luton/luton.c create mode 100644 board/mscc/ocelot/Kconfig create mode 100644 board/mscc/ocelot/Makefile create mode 100644 board/mscc/ocelot/ocelot.c create mode 100644 configs/mscc_luton_defconfig create mode 100644 configs/mscc_ocelot_defconfig create mode 100644 configs/mscc_ocelot_pcb120_defconfig create mode 100644 include/configs/vcoreiii.h
Export create_tlb() as an inline function in mipsregs.h. It allows to remove the declaration of the function from the board files.
Then it will allow also to use this function very early in the boot when the stack is not usable.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- arch/mips/cpu/cpu.c | 10 ---------- arch/mips/include/asm/mipsregs.h | 11 +++++++++++ 2 files changed, 11 insertions(+), 10 deletions(-)
diff --git a/arch/mips/cpu/cpu.c b/arch/mips/cpu/cpu.c index 5c56ab0289..a403ff729b 100644 --- a/arch/mips/cpu/cpu.c +++ b/arch/mips/cpu/cpu.c @@ -28,16 +28,6 @@ int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } #endif
-void write_one_tlb(int index, u32 pagemask, u32 hi, u32 low0, u32 low1) -{ - write_c0_entrylo0(low0); - write_c0_pagemask(pagemask); - write_c0_entrylo1(low1); - write_c0_entryhi(hi); - write_c0_index(index); - tlb_write_indexed(); -} - int arch_cpu_init(void) { mips_cache_probe(); diff --git a/arch/mips/include/asm/mipsregs.h b/arch/mips/include/asm/mipsregs.h index 48fa1f1f7f..930562ebb2 100644 --- a/arch/mips/include/asm/mipsregs.h +++ b/arch/mips/include/asm/mipsregs.h @@ -2005,6 +2005,17 @@ static inline unsigned int get_ebase_cpunum(void) return read_c0_ebase() & 0x3ff; }
+static inline void write_one_tlb(int index, u32 pagemask, u32 hi, u32 low0, + u32 low1) +{ + write_c0_entrylo0(low0); + write_c0_pagemask(pagemask); + write_c0_entrylo1(low1); + write_c0_entryhi(hi); + write_c0_index(index); + tlb_write_indexed(); +} + #endif /* !__ASSEMBLY__ */
#endif /* _ASM_MIPSREGS_H */
This path add a new helper allowing to prefetch and lock instructions into cache. This is useful very early in the boot when no RAM is available yet.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- arch/mips/include/asm/cacheops.h | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/arch/mips/include/asm/cacheops.h b/arch/mips/include/asm/cacheops.h index 3161875441..98b67ccc8e 100644 --- a/arch/mips/include/asm/cacheops.h +++ b/arch/mips/include/asm/cacheops.h @@ -19,6 +19,25 @@ static inline void mips_cache(int op, const volatile void *addr) #endif }
+#define MIPS32_WHICH_ICACHE 0x0 +#define MIPS32_FETCH_AND_LOCK 0x7 + +#define ICACHE_LOAD_LOCK (MIPS32_WHICH_ICACHE | (MIPS32_FETCH_AND_LOCK << 2)) + +/* Prefetch and lock instructions into cache */ +static inline void icache_lock(void *func, size_t len) +{ + int i, lines = ((len - 1) / ARCH_DMA_MINALIGN) + 1; + + for (i = 0; i < lines; i++) { + asm volatile (" cache %0, %1(%2)" + : /* No Output */ + : "I" ICACHE_LOAD_LOCK, + "n" (i * ARCH_DMA_MINALIGN), + "r" (func) + : /* No Clobbers */); + } +} #endif /* !__ASSEMBLY__ */
This family of SoCs are found in the Microsemi Switches solution and have already a support in the linux kernel.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- MAINTAINERS | 7 + arch/mips/Kconfig | 6 + arch/mips/Makefile | 1 + arch/mips/mach-mscc/Kconfig | 69 ++ arch/mips/mach-mscc/Makefile | 5 + arch/mips/mach-mscc/cpu.c | 90 +++ arch/mips/mach-mscc/dram.c | 71 ++ arch/mips/mach-mscc/include/ioremap.h | 49 ++ arch/mips/mach-mscc/include/mach/common.h | 24 + arch/mips/mach-mscc/include/mach/ddr.h | 708 ++++++++++++++++++ .../mach-mscc/include/mach/ocelot/ocelot.h | 24 + .../include/mach/ocelot/ocelot_devcpu_gcb.h | 21 + .../include/mach/ocelot/ocelot_icpu_cfg.h | 274 +++++++ arch/mips/mach-mscc/include/mach/tlb.h | 55 ++ arch/mips/mach-mscc/lowlevel_init.S | 23 + arch/mips/mach-mscc/reset.c | 30 + 16 files changed, 1457 insertions(+) create mode 100644 arch/mips/mach-mscc/Kconfig create mode 100644 arch/mips/mach-mscc/Makefile create mode 100644 arch/mips/mach-mscc/cpu.c create mode 100644 arch/mips/mach-mscc/dram.c create mode 100644 arch/mips/mach-mscc/include/ioremap.h create mode 100644 arch/mips/mach-mscc/include/mach/common.h create mode 100644 arch/mips/mach-mscc/include/mach/ddr.h create mode 100644 arch/mips/mach-mscc/include/mach/ocelot/ocelot.h create mode 100644 arch/mips/mach-mscc/include/mach/ocelot/ocelot_devcpu_gcb.h create mode 100644 arch/mips/mach-mscc/include/mach/ocelot/ocelot_icpu_cfg.h create mode 100644 arch/mips/mach-mscc/include/mach/tlb.h create mode 100644 arch/mips/mach-mscc/lowlevel_init.S create mode 100644 arch/mips/mach-mscc/reset.c
diff --git a/MAINTAINERS b/MAINTAINERS index abdb6dcdb5..53a3c5bec6 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -484,6 +484,13 @@ S: Maintained T: git git://git.denx.de/u-boot-mips.git F: arch/mips/
+MIPS MSCC +M: Gregory CLEMENT gregory.clement@bootlin.com +M: Lars Povlsen lars.povlsen@microchip.com +M: Horatiu Vultur horatiu.vultur@microchip.com +S: Maintained +F: arch/mips/mach-mscc/ + MMC M: Jaehoon Chung jh80.chung@samsung.com S: Maintained diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 6d646ef999..bfe9c11069 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -59,6 +59,11 @@ config ARCH_ATH79 select OF_CONTROL imply CMD_DM
+config ARCH_MSCC + bool "Support MSCC VCore-III" + select OF_CONTROL + select DM + config ARCH_BMIPS bool "Support BMIPS SoCs" select CLK @@ -135,6 +140,7 @@ source "board/imgtec/xilfpga/Kconfig" source "board/micronas/vct/Kconfig" source "board/qemu-mips/Kconfig" source "arch/mips/mach-ath79/Kconfig" +source "arch/mips/mach-mscc/Kconfig" source "arch/mips/mach-bmips/Kconfig" source "arch/mips/mach-pic32/Kconfig" source "arch/mips/mach-mt7620/Kconfig" diff --git a/arch/mips/Makefile b/arch/mips/Makefile index 802244a06e..124e93fa26 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -15,6 +15,7 @@ machine-$(CONFIG_ARCH_ATH79) += ath79 machine-$(CONFIG_ARCH_BMIPS) += bmips machine-$(CONFIG_MACH_PIC32) += pic32 machine-$(CONFIG_ARCH_MT7620) += mt7620 +machine-$(CONFIG_ARCH_MSCC) += mscc
machdirs := $(patsubst %,arch/mips/mach-%/,$(machine-y)) libs-y += $(machdirs) diff --git a/arch/mips/mach-mscc/Kconfig b/arch/mips/mach-mscc/Kconfig new file mode 100644 index 0000000000..7f1b270207 --- /dev/null +++ b/arch/mips/mach-mscc/Kconfig @@ -0,0 +1,69 @@ +# SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +menu "MSCC VCore-III platforms" + depends on ARCH_MSCC + +config SOC_VCOREIII + select MIPS_TUNE_24KC + select ROM_EXCEPTION_VECTORS + select SUPPORTS_BIG_ENDIAN + select SUPPORTS_CPU_MIPS32_R1 + select SUPPORTS_CPU_MIPS32_R2 + select SUPPORTS_LITTLE_ENDIAN + bool + +config SYS_SOC + default "mscc" + +config SOC_OCELOT + bool + select SOC_VCOREIII + help + This supports MSCC Ocelot family of SOCs. + +config SYS_CONFIG_NAME + default "vcoreiii" + +choice + prompt "Board select" + +config TARGET_OCELOT_PCB120 + bool "MSCC PCB120 Reference Board (aka VSC5635EV)" + select SOC_OCELOT + help + When selected, CONFIG_DEFAULT_DEVICE_TREE should be set to + ocelot_pcb120 + +config TARGET_OCELOT_PCB123 + bool "MSCC PCB123 Reference Board (aka VSC7514EV))" + select SOC_OCELOT + help + When selected, CONFIG_DEFAULT_DEVICE_TREE should be set to + ocelot_pcb123 + +endchoice + +choice + prompt "DDR type" + +config DDRTYPE_H5TQ4G63MFR + bool "Hynix H5TQ4G63MFR-PBC (4Gbit, DDR3-800, 256Mbitx16)" + +config DDRTYPE_MT41K256M16 + bool "Micron MT41K256M16 (4Gbit, DDR3L-800, 256Mbitx16)" + +config DDRTYPE_H5TQ1G63BFA + bool "Hynix H5TQ1G63BFA (1Gbit DDR3, x16)" + +config DDRTYPE_MT41J128M16HA + bool "Micron MT41J128M16HA-15E:D (2Gbit DDR3, x16)" + +config DDRTYPE_MT41K128M16JT + bool "Micron MT41K128M16JT-125 (2Gbit DDR3L, 128Mbitx16)" + +config DDRTYPE_MT47H128M8HQ + bool "Micron MT47H128M8-3 (1Gbit, DDR-533@CL4 @ 4.80ns 16Mbisx8x8)" + +endchoice + +endmenu diff --git a/arch/mips/mach-mscc/Makefile b/arch/mips/mach-mscc/Makefile new file mode 100644 index 0000000000..d14ec33838 --- /dev/null +++ b/arch/mips/mach-mscc/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +CFLAGS_cpu.o += -finline-limit=64000 + +obj-y += cpu.o dram.o reset.o lowlevel_init.o diff --git a/arch/mips/mach-mscc/cpu.c b/arch/mips/mach-mscc/cpu.c new file mode 100644 index 0000000000..b503e1407b --- /dev/null +++ b/arch/mips/mach-mscc/cpu.c @@ -0,0 +1,90 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <common.h> + +#include <asm/io.h> +#include <asm/types.h> + +#include <mach/tlb.h> +#include <mach/ddr.h> + +DECLARE_GLOBAL_DATA_PTR; + +#if CONFIG_SYS_SDRAM_SIZE <= SZ_64M +#define MSCC_RAM_TLB_SIZE SZ_64M +#define MSCC_ATTRIB2 MMU_REGIO_INVAL +#elif CONFIG_SYS_SDRAM_SIZE <= SZ_128M +#define MSCC_RAM_TLB_SIZE SZ_64M +#define MSCC_ATTRIB2 MMU_REGIO_RW +#elif CONFIG_SYS_SDRAM_SIZE <= SZ_256M +#define MSCC_RAM_TLB_SIZE SZ_256M +#define MSCC_ATTRIB2 MMU_REGIO_INVAL +#elif CONFIG_SYS_SDRAM_SIZE <= SZ_512M +#define MSCC_RAM_TLB_SIZE SZ_256M +#define MSCC_ATTRIB2 MMU_REGIO_RW +#else +#define MSCC_RAM_TLB_SIZE SZ_512M +#define MSCC_ATTRIB2 MMU_REGIO_RW +#endif + +/* NOTE: lowlevel_init() function does not have access to the + * stack. Thus, all called functions must be inlined, and (any) local + * variables must be kept in registers. + */ +void vcoreiii_tlb_init(void) +{ + register int tlbix = 0; + + /* + * Unlike most of the MIPS based SoCs, the IO register address + * are not in KSEG0. The mainline linux kernel built in legacy + * mode needs to access some of the registers very early in + * the boot and make the assumption that the bootloader has + * already configured them, so we have to match this + * expectation. + */ + create_tlb(tlbix++, MSCC_IO_ORIGIN1_OFFSET, SZ_16M, MMU_REGIO_RW, + MMU_REGIO_RW); + +#if CONFIG_SYS_TEXT_BASE == MSCC_FLASH_TO + /* + * If U-Boot is located in NOR then we want to be able to use + * the data cache in order to boot in a decent duration + */ + create_tlb(tlbix++, MSCC_FLASH_TO, SZ_16M, MMU_REGIO_RO_C, + MMU_REGIO_RO_C); + create_tlb(tlbix++, MSCC_FLASH_TO + SZ_32M, SZ_16M, MMU_REGIO_RO_C, + MMU_REGIO_RO_C); + + /* + * Using cache for RAM also helps to improve boot time. Thanks + * to this the time to relocate U-Boot in RAM went from 2.092 + * secs to 0.104 secs. + */ + create_tlb(tlbix++, MSCC_DDR_TO, MSCC_RAM_TLB_SIZE, MMU_REGIO_RW, + MSCC_ATTRIB2); + + /* Enable caches by clearing the bit ERL, which is set on reset */ + write_c0_status(read_c0_status() & ~BIT(2)); +#endif /* CONFIG_SYS_TEXT_BASE */ +} + +int mach_cpu_init(void) +{ + /* Speed up NOR flash access */ + writel(ICPU_SPI_MST_CFG_CS_DESELECT_TIME(0x19) + + ICPU_SPI_MST_CFG_CLK_DIV(9), BASE_CFG + ICPU_SPI_MST_CFG); + /* + * Legacy and mainline linux kernel expect that the + * interruption map was set as it was done by redboot. + */ + writel(~0, BASE_CFG + ICPU_DST_INTR_MAP(0)); + writel(0, BASE_CFG + ICPU_DST_INTR_MAP(1)); + writel(0, BASE_CFG + ICPU_DST_INTR_MAP(2)); + writel(0, BASE_CFG + ICPU_DST_INTR_MAP(3)); + + return 0; +} diff --git a/arch/mips/mach-mscc/dram.c b/arch/mips/mach-mscc/dram.c new file mode 100644 index 0000000000..5acee6f918 --- /dev/null +++ b/arch/mips/mach-mscc/dram.c @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <common.h> + +#include <asm/io.h> +#include <asm/types.h> + +#include <mach/tlb.h> +#include <mach/ddr.h> + +DECLARE_GLOBAL_DATA_PTR; + +static inline int vcoreiii_train_bytelane(void) +{ + int ret; + + ret = hal_vcoreiii_train_bytelane(0); + + if (ret) + return ret; + ret = hal_vcoreiii_train_bytelane(1); + + return ret; +} + +int vcoreiii_ddr_init(void) +{ + int res; + + if (!(readl(BASE_CFG + ICPU_MEMCTRL_STAT) + & ICPU_MEMCTRL_STAT_INIT_DONE)) { + hal_vcoreiii_init_memctl(); + hal_vcoreiii_wait_memctl(); + if (hal_vcoreiii_init_dqs() || vcoreiii_train_bytelane()) + hal_vcoreiii_ddr_failed(); + } +#if (CONFIG_SYS_TEXT_BASE != 0x20000000) + res = dram_check(); + if (res == 0) + hal_vcoreiii_ddr_verified(); + else + hal_vcoreiii_ddr_failed(); + + /* Clear boot-mode and read-back to activate/verify */ + clrbits_le32(BASE_CFG + ICPU_GENERAL_CTRL, + ICPU_GENERAL_CTRL_BOOT_MODE_ENA); + readl(BASE_CFG + ICPU_GENERAL_CTRL); +#else + res = 0; +#endif + return res; +} + +int print_cpuinfo(void) +{ + printf("MSCC VCore-III MIPS 24Kec\n"); + + return 0; +} + +int dram_init(void) +{ + while (vcoreiii_ddr_init()) + ; + + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + return 0; +} diff --git a/arch/mips/mach-mscc/include/ioremap.h b/arch/mips/mach-mscc/include/ioremap.h new file mode 100644 index 0000000000..9024364a57 --- /dev/null +++ b/arch/mips/mach-mscc/include/ioremap.h @@ -0,0 +1,49 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef __ASM_MACH_MSCC_IOREMAP_H +#define __ASM_MACH_MSCC_IOREMAP_H + +#include <linux/types.h> +#include <mach/common.h> + +/* + * Allow physical addresses to be fixed up to help peripherals located + * outside the low 32-bit range -- generic pass-through version. + */ +static inline phys_addr_t fixup_bigphys_addr(phys_addr_t phys_addr, + phys_addr_t size) +{ + return phys_addr; +} + +static inline int is_vcoreiii_internal_registers(phys_addr_t offset) +{ + if ((offset >= MSCC_IO_ORIGIN1_OFFSET && + offset < (MSCC_IO_ORIGIN1_OFFSET + MSCC_IO_ORIGIN1_SIZE)) || + (offset >= MSCC_IO_ORIGIN2_OFFSET && + offset < (MSCC_IO_ORIGIN2_OFFSET + MSCC_IO_ORIGIN2_SIZE))) + return 1; + + return 0; +} + +static inline void __iomem *plat_ioremap(phys_addr_t offset, unsigned long size, + unsigned long flags) +{ + if (is_vcoreiii_internal_registers(offset)) + return (void __iomem *)offset; + + return NULL; +} + +static inline int plat_iounmap(const volatile void __iomem *addr) +{ + return is_vcoreiii_internal_registers((unsigned long)addr); +} + +#define _page_cachable_default _CACHE_CACHABLE_NONCOHERENT + +#endif /* __ASM_MACH_MSCC_IOREMAP_H */ diff --git a/arch/mips/mach-mscc/include/mach/common.h b/arch/mips/mach-mscc/include/mach/common.h new file mode 100644 index 0000000000..842462aeed --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/common.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef __ASM_MACH_COMMON_H +#define __ASM_MACH_COMMON_H + +#if defined(CONFIG_SOC_OCELOT) +#include <mach/ocelot/ocelot.h> +#include <mach/ocelot/ocelot_devcpu_gcb.h> +#include <mach/ocelot/ocelot_icpu_cfg.h> +#else +#error Unsupported platform +#endif + +#define MSCC_DDR_TO 0x20000000 /* DDR RAM base offset */ +#define MSCC_MEMCTL1_TO 0x40000000 /* SPI/PI base offset */ +#define MSCC_MEMCTL2_TO 0x50000000 /* SPI/PI base offset */ +#define MSCC_FLASH_TO MSCC_MEMCTL1_TO /* Flash base offset */ + +#define VCOREIII_TIMER_DIVIDER 25 /* Clock tick ~ 0.1 us */ + +#endif /* __ASM_MACH_COMMON_H */ diff --git a/arch/mips/mach-mscc/include/mach/ddr.h b/arch/mips/mach-mscc/include/mach/ddr.h new file mode 100644 index 0000000000..262985c8c9 --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/ddr.h @@ -0,0 +1,708 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef __ASM_MACH_DDR_H +#define __ASM_MACH_DDR_H + +#include <asm/cacheops.h> +#include <asm/io.h> +#include <asm/reboot.h> +#include <mach/common.h> + +#define MIPS_VCOREIII_MEMORY_DDR3 +#define MIPS_VCOREIII_DDR_SIZE CONFIG_SYS_SDRAM_SIZE + +#if defined(CONFIG_DDRTYPE_H5TQ1G63BFA) /* Serval1 Refboard */ + +/* Hynix H5TQ1G63BFA (1Gbit DDR3, x16) @ 3.20ns */ +#define VC3_MPAR_bank_addr_cnt 3 +#define VC3_MPAR_row_addr_cnt 13 +#define VC3_MPAR_col_addr_cnt 10 +#define VC3_MPAR_tREFI 2437 +#define VC3_MPAR_tRAS_min 12 +#define VC3_MPAR_CL 6 +#define VC3_MPAR_tWTR 4 +#define VC3_MPAR_tRC 16 +#define VC3_MPR_tFAW 16 +#define VC3_MPAR_tRP 5 +#define VC3_MPAR_tRRD 4 +#define VC3_MPAR_tRCD 5 +#define VC3_MPAR_tMRD 4 +#define VC3_MPAR_tRFC 35 +#define VC3_MPAR_CWL 5 +#define VC3_MPAR_tXPR 38 +#define VC3_MPAR_tMOD 12 +#define VC3_MPAR_tDLLK 512 +#define VC3_MPAR_tWR 5 + +#elif defined(CONFIG_DDRTYPE_MT41J128M16HA) /* Validation board */ + +/* Micron MT41J128M16HA-15E:D (2Gbit DDR3, x16) @ 3.20ns */ +#define VC3_MPAR_bank_addr_cnt 3 +#define VC3_MPAR_row_addr_cnt 14 +#define VC3_MPAR_col_addr_cnt 10 +#define VC3_MPAR_tREFI 2437 +#define VC3_MPAR_tRAS_min 12 +#define VC3_MPAR_CL 5 +#define VC3_MPAR_tWTR 4 +#define VC3_MPAR_tRC 16 +#define VC3_MPAR_tFAW 16 +#define VC3_MPAR_tRP 5 +#define VC3_MPAR_tRRD 4 +#define VC3_MPAR_tRCD 5 +#define VC3_MPAR_tMRD 4 +#define VC3_MPAR_tRFC 50 +#define VC3_MPAR_CWL 5 +#define VC3_MPAR_tXPR 54 +#define VC3_MPAR_tMOD 12 +#define VC3_MPAR_tDLLK 512 +#define VC3_MPAR_tWR 5 + +#elif defined(CONFIG_DDRTYPE_MT41K256M16) /* JR2 Validation board */ + +/* Micron MT41K256M16 (4Gbit, DDR3L-800, 256Mbitx16) @ 3.20ns */ +#define VC3_MPAR_bank_addr_cnt 3 +#define VC3_MPAR_row_addr_cnt 15 +#define VC3_MPAR_col_addr_cnt 10 +#define VC3_MPAR_tREFI 2437 +#define VC3_MPAR_tRAS_min 12 +#define VC3_MPAR_CL 5 +#define VC3_MPAR_tWTR 4 +#define VC3_MPAR_tRC 16 +#define VC3_MPAR_tFAW 16 +#define VC3_MPAR_tRP 5 +#define VC3_MPAR_tRRD 4 +#define VC3_MPAR_tRCD 5 +#define VC3_MPAR_tMRD 4 +#define VC3_MPAR_tRFC 82 +#define VC3_MPAR_CWL 5 +#define VC3_MPAR_tXPR 85 +#define VC3_MPAR_tMOD 12 +#define VC3_MPAR_tDLLK 512 +#define VC3_MPAR_tWR 5 + +#elif defined(CONFIG_DDRTYPE_H5TQ4G63MFR) /* JR2 Reference board */ + +/* Hynix H5TQ4G63MFR-PBC (4Gbit, DDR3-800, 256Mbitx16) - 2kb pages @ 3.20ns */ +#define VC3_MPAR_bank_addr_cnt 3 +#define VC3_MPAR_row_addr_cnt 15 +#define VC3_MPAR_col_addr_cnt 10 +#define VC3_MPAR_tREFI 2437 +#define VC3_MPAR_tRAS_min 12 +#define VC3_MPAR_CL 6 +#define VC3_MPAR_tWTR 4 +#define VC3_MPAR_tRC 17 +#define VC3_MPAR_tFAW 16 +#define VC3_MPAR_tRP 5 +#define VC3_MPAR_tRRD 4 +#define VC3_MPAR_tRCD 5 +#define VC3_MPAR_tMRD 4 +#define VC3_MPAR_tRFC 82 +#define VC3_MPAR_CWL 5 +#define VC3_MPAR_tXPR 85 +#define VC3_MPAR_tMOD 12 +#define VC3_MPAR_tDLLK 512 +#define VC3_MPAR_tWR 5 + +#elif defined(CONFIG_DDRTYPE_MT41K128M16JT) + +/* Micron Micron MT41K128M16JT-125 (2Gbit DDR3L, 128Mbitx16) @ 3.20ns */ +#define VC3_MPAR_bank_addr_cnt 3 +#define VC3_MPAR_row_addr_cnt 14 +#define VC3_MPAR_col_addr_cnt 10 +#define VC3_MPAR_tREFI 2437 +#define VC3_MPAR_tRAS_min 12 +#define VC3_MPAR_CL 6 +#define VC3_MPAR_tWTR 4 +#define VC3_MPAR_tRC 16 +#define VC3_MPAR_tFAW 16 +#define VC3_MPAR_tRP 5 +#define VC3_MPAR_tRRD 4 +#define VC3_MPAR_tRCD 5 +#define VC3_MPAR_tMRD 4 +#define VC3_MPAR_tRFC 82 +#define VC3_MPAR_CWL 5 +#define VC3_MPAR_tXPR 85 +#define VC3_MPAR_tMOD 12 +#define VC3_MPAR_tDLLK 512 +#define VC3_MPAR_tWR 5 + +#elif defined(CONFIG_DDRTYPE_MT47H128M8HQ) /* Luton10/26 Refboards */ + +/* Micron 1Gb MT47H128M8-3 16Meg x 8 x 8 banks, DDR-533@CL4 @ 4.80ns */ +#define VC3_MPAR_bank_addr_cnt 3 +#define VC3_MPAR_row_addr_cnt 14 +#define VC3_MPAR_col_addr_cnt 10 +#define VC3_MPAR_tREFI 1625 +#define VC3_MPAR_tRAS_min 9 +#define VC3_MPAR_CL 4 +#define VC3_MPAR_tWTR 2 +#define VC3_MPAR_tRC 12 +#define VC3_MPAR_tFAW 8 +#define VC3_MPAR_tRP 4 +#define VC3_MPAR_tRRD 2 +#define VC3_MPAR_tRCD 4 + +#define VC3_MPAR_tRPA 4 +#define VC3_MPAR_tRP 4 + +#define VC3_MPAR_tMRD 2 +#define VC3_MPAR_tRFC 27 + +#define VC3_MPAR__400_ns_dly 84 + +#define VC3_MPAR_tWR 4 +#undef MIPS_VCOREIII_MEMORY_DDR3 +#else + +#error Unknown DDR system configuration - please add! + +#endif + +#ifdef CONFIG_SOC_OCELOT +#define MIPS_VCOREIII_MEMORY_16BIT 1 +#endif + +#define MIPS_VCOREIII_MEMORY_SSTL_ODT 7 +#define MIPS_VCOREIII_MEMORY_SSTL_DRIVE 7 +#define VCOREIII_DDR_DQS_MODE_CALIBRATE + +#ifdef MIPS_VCOREIII_MEMORY_16BIT +#define VC3_MPAR_16BIT 1 +#else +#define VC3_MPAR_16BIT 0 +#endif + +#ifdef MIPS_VCOREIII_MEMORY_DDR3 +#define VC3_MPAR_DDR3_MODE 1 /* DDR3 */ +#define VC3_MPAR_BURST_LENGTH 8 /* Always 8 (1) for DDR3 */ +#ifdef MIPS_VCOREIII_MEMORY_16BIT +#define VC3_MPAR_BURST_SIZE 1 /* Always 1 for DDR3/16bit */ +#else +#define VC3_MPAR_BURST_SIZE 0 +#endif +#else +#define VC3_MPAR_DDR3_MODE 0 /* DDR2 */ +#ifdef MIPS_VCOREIII_MEMORY_16BIT +#define VC3_MPAR_BURST_LENGTH 4 /* in DDR2 16-bit mode, use burstlen 4 */ +#else +#define VC3_MPAR_BURST_LENGTH 8 /* For 8-bit IF we must run burst-8 */ +#endif +#define VC3_MPAR_BURST_SIZE 0 /* Always 0 for DDR2 */ +#endif + +#define VC3_MPAR_RL VC3_MPAR_CL +#if !defined(MIPS_VCOREIII_MEMORY_DDR3) +#define VC3_MPAR_WL (VC3_MPAR_RL - 1) +#define VC3_MPAR_MD VC3_MPAR_tMRD +#define VC3_MPAR_ID VC3_MPAR__400_ns_dly +#define VC3_MPAR_SD VC3_MPAR_tXSRD +#define VC3_MPAR_OW (VC3_MPAR_WL - 2) +#define VC3_MPAR_OR (VC3_MPAR_WL - 3) +#define VC3_MPAR_RP (VC3_MPAR_bank_addr_cnt < 3 ? VC3_MPAR_tRP : VC3_MPAR_tRPA) +#define VC3_MPAR_FAW (VC3_MPAR_bank_addr_cnt < 3 ? 1 : VC3_MPAR_tFAW) +#define VC3_MPAR_BL (VC3_MPAR_BURST_LENGTH == 4 ? 2 : 4) +#define MSCC_MEMPARM_MR0 \ + (VC3_MPAR_BURST_LENGTH == 8 ? 3 : 2) | (VC3_MPAR_CL << 4) | \ + ((VC3_MPAR_tWR - 1) << 9) +/* DLL-on, Full-OD, AL=0, RTT=off, nDQS-on, RDQS-off, out-en */ +#define MSCC_MEMPARM_MR1 0x382 +#define MSCC_MEMPARM_MR2 0 +#define MSCC_MEMPARM_MR3 0 +#else +#define VC3_MPAR_WL VC3_MPAR_CWL +#define VC3_MPAR_MD VC3_MPAR_tMOD +#define VC3_MPAR_ID VC3_MPAR_tXPR +#define VC3_MPAR_SD VC3_MPAR_tDLLK +#define VC3_MPAR_OW 2 +#define VC3_MPAR_OR 2 +#define VC3_MPAR_RP VC3_MPAR_tRP +#define VC3_MPAR_FAW VC3_MPAR_tFAW +#define VC3_MPAR_BL 4 +#define MSCC_MEMPARM_MR0 ((VC3_MPAR_RL - 4) << 4) | ((VC3_MPAR_tWR - 4) << 9) +/* ODT_RTT: “0x0040” for 120ohm, and “0x0004” for 60ohm. */ +#define MSCC_MEMPARM_MR1 0x0040 +#define MSCC_MEMPARM_MR2 ((VC3_MPAR_WL - 5) << 3) +#define MSCC_MEMPARM_MR3 0 +#endif /* MIPS_VCOREIII_MEMORY_DDR3 */ + +#define MSCC_MEMPARM_MEMCFG \ + ((MIPS_VCOREIII_DDR_SIZE > SZ_512M) ? \ + ICPU_MEMCTRL_CFG_DDR_512MBYTE_PLUS : 0) | \ + (VC3_MPAR_16BIT ? ICPU_MEMCTRL_CFG_DDR_WIDTH : 0) | \ + (VC3_MPAR_DDR3_MODE ? ICPU_MEMCTRL_CFG_DDR_MODE : 0) | \ + (VC3_MPAR_BURST_SIZE ? ICPU_MEMCTRL_CFG_BURST_SIZE : 0) | \ + (VC3_MPAR_BURST_LENGTH == 8 ? ICPU_MEMCTRL_CFG_BURST_LEN : 0) | \ + (VC3_MPAR_bank_addr_cnt == 3 ? ICPU_MEMCTRL_CFG_BANK_CNT : 0) | \ + ICPU_MEMCTRL_CFG_MSB_ROW_ADDR(VC3_MPAR_row_addr_cnt - 1) | \ + ICPU_MEMCTRL_CFG_MSB_COL_ADDR(VC3_MPAR_col_addr_cnt - 1) + +#ifdef CONFIG_SOC_OCELOT +#define MSCC_MEMPARM_PERIOD \ + ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF(8) | \ + ICPU_MEMCTRL_REF_PERIOD_REF_PERIOD(VC3_MPAR_tREFI) + +#define MSCC_MEMPARM_TIMING0 \ + ICPU_MEMCTRL_TIMING0_RD_TO_WR_DLY(VC3_MPAR_RL + VC3_MPAR_BL + 1 - \ + VC3_MPAR_WL) | \ + ICPU_MEMCTRL_TIMING0_WR_CS_CHANGE_DLY(VC3_MPAR_BL - 1) | \ + ICPU_MEMCTRL_TIMING0_RD_CS_CHANGE_DLY(VC3_MPAR_BL) | \ + ICPU_MEMCTRL_TIMING0_RAS_TO_PRECH_DLY(VC3_MPAR_tRAS_min - 1) | \ + ICPU_MEMCTRL_TIMING0_WR_TO_PRECH_DLY(VC3_MPAR_WL + \ + VC3_MPAR_BL + \ + VC3_MPAR_tWR - 1) | \ + ICPU_MEMCTRL_TIMING0_RD_TO_PRECH_DLY(VC3_MPAR_BL - 1) | \ + ICPU_MEMCTRL_TIMING0_WR_DATA_XFR_DLY(VC3_MPAR_WL - 1) | \ + ICPU_MEMCTRL_TIMING0_RD_DATA_XFR_DLY(VC3_MPAR_RL - 3) + +#define MSCC_MEMPARM_TIMING1 \ + ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_SAME_BANK_DLY(VC3_MPAR_tRC - 1) | \ + ICPU_MEMCTRL_TIMING1_BANK8_FAW_DLY(VC3_MPAR_FAW - 1) | \ + ICPU_MEMCTRL_TIMING1_PRECH_TO_RAS_DLY(VC3_MPAR_RP - 1) | \ + ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_DLY(VC3_MPAR_tRRD - 1) | \ + ICPU_MEMCTRL_TIMING1_RAS_TO_CAS_DLY(VC3_MPAR_tRCD - 1) | \ + ICPU_MEMCTRL_TIMING1_WR_TO_RD_DLY(VC3_MPAR_WL + \ + VC3_MPAR_BL + \ + VC3_MPAR_tWTR - 1) + +#define MSCC_MEMPARM_TIMING2 \ + ICPU_MEMCTRL_TIMING2_PRECH_ALL_DLY(VC3_MPAR_RP - 1) | \ + ICPU_MEMCTRL_TIMING2_MDSET_DLY(VC3_MPAR_MD - 1) | \ + ICPU_MEMCTRL_TIMING2_REF_DLY(VC3_MPAR_tRFC - 1) | \ + ICPU_MEMCTRL_TIMING2_INIT_DLY(VC3_MPAR_ID - 1) + +#define MSCC_MEMPARM_TIMING3 \ + ICPU_MEMCTRL_TIMING3_WR_TO_RD_CS_CHANGE_DLY(VC3_MPAR_WL + \ + VC3_MPAR_tWTR - 1) |\ + ICPU_MEMCTRL_TIMING3_ODT_RD_DLY(VC3_MPAR_OR - 1) | \ + ICPU_MEMCTRL_TIMING3_ODT_WR_DLY(VC3_MPAR_OW - 1) | \ + ICPU_MEMCTRL_TIMING3_LOCAL_ODT_RD_DLY(VC3_MPAR_RL - 3) + +#else +#define MSCC_MEMPARM_PERIOD \ + ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF(1) | \ + ICPU_MEMCTRL_REF_PERIOD_REF_PERIOD(VC3_MPAR_tREFI) + +#define MSCC_MEMPARM_TIMING0 \ + ICPU_MEMCTRL_TIMING0_RAS_TO_PRECH_DLY(VC3_MPAR_tRAS_min - 1) | \ + ICPU_MEMCTRL_TIMING0_WR_TO_PRECH_DLY(VC3_MPAR_CL + \ + (VC3_MPAR_BURST_LENGTH == 8 ? 2 : 0) + \ + VC3_MPAR_tWR) | \ + ICPU_MEMCTRL_TIMING0_RD_TO_PRECH_DLY(VC3_MPAR_BURST_LENGTH == 8 ? 3 : 1) | \ + ICPU_MEMCTRL_TIMING0_WR_DATA_XFR_DLY(VC3_MPAR_CL - 3) | \ + ICPU_MEMCTRL_TIMING0_RD_DATA_XFR_DLY(VC3_MPAR_CL - 3) + +#define MSCC_MEMPARM_TIMING1 \ + ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_SAME_BANK_DLY(VC3_MPAR_tRC - 1) | \ + ICPU_MEMCTRL_TIMING1_BANK8_FAW_DLY(VC3_MPAR_tFAW - 1) | \ + ICPU_MEMCTRL_TIMING1_PRECH_TO_RAS_DLY(VC3_MPAR_tRP - 1) | \ + ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_DLY(VC3_MPAR_tRRD - 1) | \ + ICPU_MEMCTRL_TIMING1_RAS_TO_CAS_DLY(VC3_MPAR_tRCD - 1) | \ + ICPU_MEMCTRL_TIMING1_WR_TO_RD_DLY(VC3_MPAR_CL + \ + (VC3_MPAR_BURST_LENGTH == 8 ? 2 : 0) + \ + VC3_MPAR_tWTR) +#define MSCC_MEMPARM_TIMING2 \ + ICPU_MEMCTRL_TIMING2_PRECH_ALL_DLY(VC3_MPAR_tRPA - 1) | \ + ICPU_MEMCTRL_TIMING2_MDSET_DLY(VC3_MPAR_tMRD - 1) | \ + ICPU_MEMCTRL_TIMING2_REF_DLY(VC3_MPAR_tRFC - 1) | \ + ICPU_MEMCTRL_TIMING2_FOUR_HUNDRED_NS_DLY(VC3_MPAR__400_ns_dly) + +#define MSCC_MEMPARM_TIMING3 \ + ICPU_MEMCTRL_TIMING3_WR_TO_RD_CS_CHANGE_DLY(VC3_MPAR_CL - 1) | \ + ICPU_MEMCTRL_TIMING3_ODT_WR_DLY(VC3_MPAR_CL - 1) | \ + ICPU_MEMCTRL_TIMING3_LOCAL_ODT_RD_DLY(VC3_MPAR_CL - 1) + +#endif + +enum { + DDR_TRAIN_OK, + DDR_TRAIN_CONTINUE, + DDR_TRAIN_ERROR, +}; + +/* + * We actually have very few 'pause' possibilities apart from + * these assembly nops (at this very early stage). + */ +#define PAUSE() asm volatile("nop; nop; nop; nop; nop; nop; nop; nop") + +/* NB: Assumes inlining as no stack is available! */ +static inline void set_dly(u32 bytelane, u32 dly) +{ + register u32 r = readl(BASE_CFG + ICPU_MEMCTRL_DQS_DLY(bytelane)); + + r &= ~ICPU_MEMCTRL_DQS_DLY_DQS_DLY_M; + r |= ICPU_MEMCTRL_DQS_DLY_DQS_DLY(dly); + writel(r, BASE_CFG + ICPU_MEMCTRL_DQS_DLY(bytelane)); +} + +static inline bool incr_dly(u32 bytelane) +{ + register u32 r = readl(BASE_CFG + ICPU_MEMCTRL_DQS_DLY(bytelane)); + + if (ICPU_MEMCTRL_DQS_DLY_DQS_DLY(r) < 31) { + writel(r + 1, BASE_CFG + ICPU_MEMCTRL_DQS_DLY(bytelane)); + return true; + } + + return false; +} + +static inline bool adjust_dly(int adjust) +{ + register u32 r = readl(BASE_CFG + ICPU_MEMCTRL_DQS_DLY(0)); + + if (ICPU_MEMCTRL_DQS_DLY_DQS_DLY(r) < 31) { + writel(r + adjust, BASE_CFG + ICPU_MEMCTRL_DQS_DLY(0)); + return true; + } + + return false; +} + +/* NB: Assumes inlining as no stack is available! */ +static inline void center_dly(u32 bytelane, u32 start) +{ + register u32 r = readl(BASE_CFG + ICPU_MEMCTRL_DQS_DLY(bytelane)) - start; + + writel(start + (r >> 1), BASE_CFG + ICPU_MEMCTRL_DQS_DLY(bytelane)); +} + +static inline void memphy_soft_reset(void) +{ + setbits_le32(BASE_CFG + ICPU_MEMPHY_CFG, ICPU_MEMPHY_CFG_PHY_FIFO_RST); + PAUSE(); + clrbits_le32(BASE_CFG + ICPU_MEMPHY_CFG, ICPU_MEMPHY_CFG_PHY_FIFO_RST); + PAUSE(); +} + +#ifdef CONFIG_SOC_OCELOT +static u8 training_data[] = { 0xfe, 0x11, 0x33, 0x55, 0x77, 0x99, 0xbb, 0xdd }; + +static inline void sleep_100ns(u32 val) +{ + /* Set the timer tick generator to 100 ns */ + writel(VCOREIII_TIMER_DIVIDER - 1, BASE_CFG + ICPU_TIMER_TICK_DIV); + + /* Set the timer value */ + writel(val, BASE_CFG + ICPU_TIMER_VALUE(0)); + + /* Enable timer 0 for one-shot */ + writel(ICPU_TIMER_CTRL_ONE_SHOT_ENA | ICPU_TIMER_CTRL_TIMER_ENA, + BASE_CFG + ICPU_TIMER_CTRL(0)); + + /* Wait for timer 0 to reach 0 */ + while (readl(BASE_CFG + ICPU_TIMER_VALUE(0)) != 0) + ; +} + +static inline void hal_vcoreiii_ddr_reset_assert(void) +{ + /* DDR has reset pin on GPIO 19 toggle Low-High to release */ + setbits_le32(BASE_DEVCPU_GCB + PERF_GPIO_OE, BIT(19)); + writel(BIT(19), BASE_DEVCPU_GCB + PERF_GPIO_OUT_CLR); + sleep_100ns(10000); +} + +static inline void hal_vcoreiii_ddr_reset_release(void) +{ + /* DDR has reset pin on GPIO 19 toggle Low-High to release */ + setbits_le32(BASE_DEVCPU_GCB + PERF_GPIO_OE, BIT(19)); + writel(BIT(19), BASE_DEVCPU_GCB + PERF_GPIO_OUT_SET); + sleep_100ns(10000); +} + +/* + * DDR memory sanity checking failed, tally and do hard reset + * + * NB: Assumes inlining as no stack is available! + */ +static inline void hal_vcoreiii_ddr_failed(void) +{ + register u32 reset; + + writel(readl(BASE_CFG + ICPU_GPR(6)) + 1, BASE_CFG + ICPU_GPR(6)); + + clrbits_le32(BASE_DEVCPU_GCB + PERF_GPIO_OE, BIT(19)); + + /* We have to execute the reset function from cache. Indeed, + * the reboot workaround in _machine_restart() will change the + * SPI NOR into SW bitbang. + * + * This will render the CPU unable to execute directly from + * the NOR, which is why the reset instructions are prefetched + * into the I-cache. + * + * When failing the DDR initialization we are executing from + * NOR. + * + * The last instruction in _machine_restart() will reset the + * MIPS CPU (and the cache), and the CPU will start executing + * from the reset vector. + */ + reset = KSEG0ADDR(_machine_restart); + icache_lock((void *)reset, 128); + asm volatile ("jr %0"::"r" (reset)); + + panic("DDR init failed\n"); +} + +/* + * DDR memory sanity checking done, possibly enable ECC. + * + * NB: Assumes inlining as no stack is available! + */ +static inline void hal_vcoreiii_ddr_verified(void) +{ +#ifdef MIPS_VCOREIII_MEMORY_ECC + /* Finally, enable ECC */ + register u32 val = readl(BASE_CFG + ICPU_MEMCTRL_CFG); + + val |= ICPU_MEMCTRL_CFG_DDR_ECC_ERR_ENA; + val &= ~ICPU_MEMCTRL_CFG_BURST_SIZE; + + writel(val, BASE_CFG + ICPU_MEMCTRL_CFG); +#endif + + /* Reset Status register - sticky bits */ + writel(readl(BASE_CFG + ICPU_MEMCTRL_STAT), BASE_CFG + ICPU_MEMCTRL_STAT); +} + +/* NB: Assumes inlining as no stack is available! */ +static inline int look_for(u32 bytelane) +{ + register u32 i; + + /* Reset FIFO in case any previous access failed */ + for (i = 0; i < sizeof(training_data); i++) { + register u32 byte; + + memphy_soft_reset(); + /* Reset sticky bits */ + writel(readl(BASE_CFG + ICPU_MEMCTRL_STAT), + BASE_CFG + ICPU_MEMCTRL_STAT); + /* Read data */ + byte = __raw_readb((void __iomem *)MSCC_DDR_TO + bytelane + + (i * 4)); + + /* + * Prevent the compiler reordering the instruction so + * the read of RAM happens after the check of the + * errors. + */ + rmb(); + if (readl(BASE_CFG + ICPU_MEMCTRL_STAT) & + (ICPU_MEMCTRL_STAT_RDATA_MASKED | + ICPU_MEMCTRL_STAT_RDATA_DUMMY)) { + /* Noise on the line */ + goto read_error; + } + /* If mismatch, increment DQS - if possible */ + if (byte != training_data[i]) { + read_error: + if (!incr_dly(bytelane)) + return DDR_TRAIN_ERROR; + return DDR_TRAIN_CONTINUE; + } + } + return DDR_TRAIN_OK; +} + +/* NB: Assumes inlining as no stack is available! */ +static inline int look_past(u32 bytelane) +{ + register u32 i; + + /* Reset FIFO in case any previous access failed */ + for (i = 0; i < sizeof(training_data); i++) { + register u32 byte; + + memphy_soft_reset(); + /* Ack sticky bits */ + writel(readl(BASE_CFG + ICPU_MEMCTRL_STAT), + BASE_CFG + ICPU_MEMCTRL_STAT); + byte = __raw_readb((void __iomem *)MSCC_DDR_TO + bytelane + + (i * 4)); + /* + * Prevent the compiler reordering the instruction so + * the read of RAM happens after the check of the + * errors. + */ + rmb(); + if (readl(BASE_CFG + ICPU_MEMCTRL_STAT) & + (ICPU_MEMCTRL_STAT_RDATA_MASKED | + ICPU_MEMCTRL_STAT_RDATA_DUMMY)) { + /* Noise on the line */ + goto read_error; + } + /* Bail out when we see first mismatch */ + if (byte != training_data[i]) { + read_error: + return DDR_TRAIN_OK; + } + } + /* All data compares OK, increase DQS and retry */ + if (!incr_dly(bytelane)) + return DDR_TRAIN_ERROR; + + return DDR_TRAIN_CONTINUE; +} + +static inline int hal_vcoreiii_train_bytelane(u32 bytelane) +{ + register int res; + register u32 dqs_s; + + set_dly(bytelane, 0); /* Start training at DQS=0 */ + while ((res = look_for(bytelane)) == DDR_TRAIN_CONTINUE) + ; + if (res != DDR_TRAIN_OK) + return res; + + dqs_s = readl(BASE_CFG + ICPU_MEMCTRL_DQS_DLY(bytelane)); + while ((res = look_past(bytelane)) == DDR_TRAIN_CONTINUE) + ; + if (res != DDR_TRAIN_OK) + return res; + /* Reset FIFO - for good measure */ + memphy_soft_reset(); + /* Adjust to center [dqs_s;cur] */ + center_dly(bytelane, dqs_s); + return DDR_TRAIN_OK; +} + +/* This algorithm is converted from the TCL training algorithm used + * during silicon simulation. + * NB: Assumes inlining as no stack is available! + */ +static inline int hal_vcoreiii_init_dqs(void) +{ +#define MAX_DQS 32 + register u32 i, j; + + for (i = 0; i < MAX_DQS; i++) { + set_dly(0, i); /* Byte-lane 0 */ + for (j = 0; j < MAX_DQS; j++) { + __maybe_unused register u32 byte; + + set_dly(1, j); /* Byte-lane 1 */ + /* Reset FIFO in case any previous access failed */ + memphy_soft_reset(); + writel(readl(BASE_CFG + ICPU_MEMCTRL_STAT), + BASE_CFG + ICPU_MEMCTRL_STAT); + byte = __raw_readb((void __iomem *)MSCC_DDR_TO); + byte = __raw_readb((void __iomem *)(MSCC_DDR_TO + 1)); + if (!(readl(BASE_CFG + ICPU_MEMCTRL_STAT) & + (ICPU_MEMCTRL_STAT_RDATA_MASKED | + ICPU_MEMCTRL_STAT_RDATA_DUMMY))) + return 0; + } + } + return -1; +} + +static inline int dram_check(void) +{ + register u32 i; + + for (i = 0; i < 8; i++) { + __raw_writel(~i, (void __iomem *)(MSCC_DDR_TO + (i * 4))); + if (__raw_readl((void __iomem *)(MSCC_DDR_TO + (i * 4))) != ~i) + return 1; + } + return 0; +} + +/* + * NB: Called *early* to init memory controller - assumes inlining as + * no stack is available! + */ +static inline void hal_vcoreiii_init_memctl(void) +{ + /* Ensure DDR is in reset */ + hal_vcoreiii_ddr_reset_assert(); + + /* Wait maybe not needed, but ... */ + PAUSE(); + + /* Drop sys ctl memory controller forced reset */ + clrbits_le32(BASE_CFG + ICPU_RESET, ICPU_RESET_MEM_RST_FORCE); + + PAUSE(); + + /* Drop Reset, enable SSTL */ + writel(ICPU_MEMPHY_CFG_PHY_SSTL_ENA, BASE_CFG + ICPU_MEMPHY_CFG); + PAUSE(); + + /* Start the automatic SSTL output and ODT drive-strength calibration */ + writel(ICPU_MEMPHY_ZCAL_ZCAL_PROG_ODT(MIPS_VCOREIII_MEMORY_SSTL_ODT) | + /* drive strength */ + ICPU_MEMPHY_ZCAL_ZCAL_PROG(MIPS_VCOREIII_MEMORY_SSTL_DRIVE) | + /* Start calibration process */ + ICPU_MEMPHY_ZCAL_ZCAL_ENA, BASE_CFG + ICPU_MEMPHY_ZCAL); + + /* Wait for ZCAL to clear */ + while (readl(BASE_CFG + ICPU_MEMPHY_ZCAL) & ICPU_MEMPHY_ZCAL_ZCAL_ENA) + ; + + /* Check no ZCAL_ERR */ + if (readl(BASE_CFG + ICPU_MEMPHY_ZCAL_STAT) + & ICPU_MEMPHY_ZCAL_STAT_ZCAL_ERR) + hal_vcoreiii_ddr_failed(); + + /* Drive CL, CK, ODT */ + setbits_le32(BASE_CFG + ICPU_MEMPHY_CFG, ICPU_MEMPHY_CFG_PHY_ODT_OE | + ICPU_MEMPHY_CFG_PHY_CK_OE | ICPU_MEMPHY_CFG_PHY_CL_OE); + + /* Initialize memory controller */ + writel(MSCC_MEMPARM_MEMCFG, BASE_CFG + ICPU_MEMCTRL_CFG); + writel(MSCC_MEMPARM_PERIOD, BASE_CFG + ICPU_MEMCTRL_REF_PERIOD); + + writel(MSCC_MEMPARM_TIMING0, BASE_CFG + ICPU_MEMCTRL_TIMING0); + + writel(MSCC_MEMPARM_TIMING1, BASE_CFG + ICPU_MEMCTRL_TIMING1); + writel(MSCC_MEMPARM_TIMING2, BASE_CFG + ICPU_MEMCTRL_TIMING2); + writel(MSCC_MEMPARM_TIMING3, BASE_CFG + ICPU_MEMCTRL_TIMING3); + writel(MSCC_MEMPARM_MR0, BASE_CFG + ICPU_MEMCTRL_MR0_VAL); + writel(MSCC_MEMPARM_MR1, BASE_CFG + ICPU_MEMCTRL_MR1_VAL); + writel(MSCC_MEMPARM_MR2, BASE_CFG + ICPU_MEMCTRL_MR2_VAL); + writel(MSCC_MEMPARM_MR3, BASE_CFG + ICPU_MEMCTRL_MR3_VAL); + + /* Termination setup - enable ODT */ + writel(ICPU_MEMCTRL_TERMRES_CTRL_LOCAL_ODT_RD_ENA | + /* Assert ODT0 for any write */ + ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_ENA(3), + BASE_CFG + ICPU_MEMCTRL_TERMRES_CTRL); + + /* Release Reset from DDR */ + hal_vcoreiii_ddr_reset_release(); + + writel(readl(BASE_CFG + ICPU_GPR(7)) + 1, BASE_CFG + ICPU_GPR(7)); +} + +static inline void hal_vcoreiii_wait_memctl(void) +{ + /* Now, rip it! */ + writel(ICPU_MEMCTRL_CTRL_INITIALIZE, BASE_CFG + ICPU_MEMCTRL_CTRL); + + while (!(readl(BASE_CFG + ICPU_MEMCTRL_STAT) + & ICPU_MEMCTRL_STAT_INIT_DONE)) + ; + + /* Settle...? */ + sleep_100ns(10000); + + /* Establish data contents in DDR RAM for training */ + + __raw_writel(0xcacafefe, ((void __iomem *)MSCC_DDR_TO)); + __raw_writel(0x22221111, ((void __iomem *)MSCC_DDR_TO + 0x4)); + __raw_writel(0x44443333, ((void __iomem *)MSCC_DDR_TO + 0x8)); + __raw_writel(0x66665555, ((void __iomem *)MSCC_DDR_TO + 0xC)); + __raw_writel(0x88887777, ((void __iomem *)MSCC_DDR_TO + 0x10)); + __raw_writel(0xaaaa9999, ((void __iomem *)MSCC_DDR_TO + 0x14)); + __raw_writel(0xccccbbbb, ((void __iomem *)MSCC_DDR_TO + 0x18)); + __raw_writel(0xeeeedddd, ((void __iomem *)MSCC_DDR_TO + 0x1C)); +} +#endif /* __ASM_MACH_DDR_H */ diff --git a/arch/mips/mach-mscc/include/mach/ocelot/ocelot.h b/arch/mips/mach-mscc/include/mach/ocelot/ocelot.h new file mode 100644 index 0000000000..2cb2135d37 --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/ocelot/ocelot.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Microsemi Ocelot Switch driver + * + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef _MSCC_OCELOT_H_ +#define _MSCC_OCELOT_H_ + +#include <linux/bitops.h> +#include <dm.h> + +/* + * Target offset base(s) + */ +#define MSCC_IO_ORIGIN1_OFFSET 0x70000000 +#define MSCC_IO_ORIGIN1_SIZE 0x00200000 +#define MSCC_IO_ORIGIN2_OFFSET 0x71000000 +#define MSCC_IO_ORIGIN2_SIZE 0x01000000 +#define BASE_CFG ((void __iomem *)0x70000000) +#define BASE_DEVCPU_GCB ((void __iomem *)0x71070000) + +#endif diff --git a/arch/mips/mach-mscc/include/mach/ocelot/ocelot_devcpu_gcb.h b/arch/mips/mach-mscc/include/mach/ocelot/ocelot_devcpu_gcb.h new file mode 100644 index 0000000000..f8aa97ba26 --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/ocelot/ocelot_devcpu_gcb.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef _MSCC_OCELOT_DEVCPU_GCB_H_ +#define _MSCC_OCELOT_DEVCPU_GCB_H_ + +#define PERF_SOFT_RST 0x8 + +#define PERF_SOFT_RST_SOFT_NON_CFG_RST BIT(2) +#define PERF_SOFT_RST_SOFT_SWC_RST BIT(1) +#define PERF_SOFT_RST_SOFT_CHIP_RST BIT(0) + +#define PERF_GPIO_OUT_SET 0x34 + +#define PERF_GPIO_OUT_CLR 0x38 + +#define PERF_GPIO_OE 0x44 + +#endif diff --git a/arch/mips/mach-mscc/include/mach/ocelot/ocelot_icpu_cfg.h b/arch/mips/mach-mscc/include/mach/ocelot/ocelot_icpu_cfg.h new file mode 100644 index 0000000000..04cf70bec3 --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/ocelot/ocelot_icpu_cfg.h @@ -0,0 +1,274 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef _MSCC_OCELOT_ICPU_CFG_H_ +#define _MSCC_OCELOT_ICPU_CFG_H_ + +#define ICPU_GPR(x) (0x4 * (x)) +#define ICPU_GPR_RSZ 0x4 + +#define ICPU_RESET 0x20 + +#define ICPU_RESET_CORE_RST_CPU_ONLY BIT(3) +#define ICPU_RESET_CORE_RST_PROTECT BIT(2) +#define ICPU_RESET_CORE_RST_FORCE BIT(1) +#define ICPU_RESET_MEM_RST_FORCE BIT(0) + +#define ICPU_GENERAL_CTRL 0x24 + +#define ICPU_GENERAL_CTRL_CPU_BUSIF_SLEEP_DIS BIT(14) +#define ICPU_GENERAL_CTRL_CPU_BUSIF_WERR_ENA BIT(13) +#define ICPU_GENERAL_CTRL_CPU_8051_IROM_ENA BIT(12) +#define ICPU_GENERAL_CTRL_CPU_MIPS_DIS BIT(11) +#define ICPU_GENERAL_CTRL_IF_MIIM_SLV_ADDR_SEL BIT(10) +#define ICPU_GENERAL_CTRL_IF_MIIM_SLV_ENA BIT(9) +#define ICPU_GENERAL_CTRL_IF_PI_SLV_DONEPOL BIT(8) +#define ICPU_GENERAL_CTRL_IF_PI_MST_ENA BIT(7) +#define ICPU_GENERAL_CTRL_IF_PI_SLV_ENA BIT(6) +#define ICPU_GENERAL_CTRL_IF_SI_OWNER(x) (((x) << 4) & GENMASK(5, 4)) +#define ICPU_GENERAL_CTRL_IF_SI_OWNER_M GENMASK(5, 4) +#define ICPU_GENERAL_CTRL_IF_SI_OWNER_X(x) (((x) & GENMASK(5, 4)) >> 4) +#define ICPU_GENERAL_CTRL_SSI_MST_CONTENTION BIT(3) +#define ICPU_GENERAL_CTRL_CPU_BE_ENA BIT(2) +#define ICPU_GENERAL_CTRL_CPU_DIS BIT(1) +#define ICPU_GENERAL_CTRL_BOOT_MODE_ENA BIT(0) +#define ICPU_SPI_MST_CFG 0x3c + +#define ICPU_SPI_MST_CFG_A32B_ENA BIT(11) +#define ICPU_SPI_MST_CFG_FAST_READ_ENA BIT(10) +#define ICPU_SPI_MST_CFG_CS_DESELECT_TIME(x) (((x) << 5) & GENMASK(9, 5)) +#define ICPU_SPI_MST_CFG_CS_DESELECT_TIME_M GENMASK(9, 5) +#define ICPU_SPI_MST_CFG_CS_DESELECT_TIME_X(x) (((x) & GENMASK(9, 5)) >> 5) +#define ICPU_SPI_MST_CFG_CLK_DIV(x) ((x) & GENMASK(4, 0)) +#define ICPU_SPI_MST_CFG_CLK_DIV_M GENMASK(4, 0) + +#define ICPU_SW_MODE 0x50 + +#define ICPU_SW_MODE_SW_PIN_CTRL_MODE BIT(13) +#define ICPU_SW_MODE_SW_SPI_SCK BIT(12) +#define ICPU_SW_MODE_SW_SPI_SCK_OE BIT(11) +#define ICPU_SW_MODE_SW_SPI_SDO BIT(10) +#define ICPU_SW_MODE_SW_SPI_SDO_OE BIT(9) +#define ICPU_SW_MODE_SW_SPI_CS(x) (((x) << 5) & GENMASK(8, 5)) +#define ICPU_SW_MODE_SW_SPI_CS_M GENMASK(8, 5) +#define ICPU_SW_MODE_SW_SPI_CS_X(x) (((x) & GENMASK(8, 5)) >> 5) +#define ICPU_SW_MODE_SW_SPI_CS_OE(x) (((x) << 1) & GENMASK(4, 1)) +#define ICPU_SW_MODE_SW_SPI_CS_OE_M GENMASK(4, 1) +#define ICPU_SW_MODE_SW_SPI_CS_OE_X(x) (((x) & GENMASK(4, 1)) >> 1) +#define ICPU_SW_MODE_SW_SPI_SDI BIT(0) + +#define ICPU_INTR_ENA 0x88 + +#define ICPU_DST_INTR_MAP(x) (0x98 + 0x4 * (x)) +#define ICPU_DST_INTR_MAP_RSZ 0x4 + +#define ICPU_DST_INTR_IDENT 0xa8 +#define ICPU_DST_INTR_IDENT_RSZ 0x4 + +#define ICPU_TIMER_TICK_DIV 0xe8 +#define ICPU_TIMER_VALUE(x) (0xec + 0x4 * (x)) + +#define ICPU_TIMER_CTRL(x) (0x104 + 0x4 * (x)) +#define ICPU_TIMER_CTRL_MAX_FREQ_ENA BIT(3) +#define ICPU_TIMER_CTRL_ONE_SHOT_ENA BIT(2) +#define ICPU_TIMER_CTRL_TIMER_ENA BIT(1) +#define ICPU_TIMER_CTRL_FORCE_RELOAD BIT(0) + +#define ICPU_MEMCTRL_CTRL 0x110 +#define ICPU_MEMCTRL_CTRL_PWR_DOWN BIT(3) +#define ICPU_MEMCTRL_CTRL_MDSET BIT(2) +#define ICPU_MEMCTRL_CTRL_STALL_REF_ENA BIT(1) +#define ICPU_MEMCTRL_CTRL_INITIALIZE BIT(0) + +#define ICPU_MEMCTRL_CFG 0x114 + +#define ICPU_MEMCTRL_CFG_DDR_512MBYTE_PLUS BIT(16) +#define ICPU_MEMCTRL_CFG_DDR_ECC_ERR_ENA BIT(15) +#define ICPU_MEMCTRL_CFG_DDR_ECC_COR_ENA BIT(14) +#define ICPU_MEMCTRL_CFG_DDR_ECC_ENA BIT(13) +#define ICPU_MEMCTRL_CFG_DDR_WIDTH BIT(12) +#define ICPU_MEMCTRL_CFG_DDR_MODE BIT(11) +#define ICPU_MEMCTRL_CFG_BURST_SIZE BIT(10) +#define ICPU_MEMCTRL_CFG_BURST_LEN BIT(9) +#define ICPU_MEMCTRL_CFG_BANK_CNT BIT(8) +#define ICPU_MEMCTRL_CFG_MSB_ROW_ADDR(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_CFG_MSB_ROW_ADDR_M GENMASK(7, 4) +#define ICPU_MEMCTRL_CFG_MSB_ROW_ADDR_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_CFG_MSB_COL_ADDR(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_CFG_MSB_COL_ADDR_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_STAT 0x118 + +#define ICPU_MEMCTRL_STAT_RDATA_MASKED BIT(5) +#define ICPU_MEMCTRL_STAT_RDATA_DUMMY BIT(4) +#define ICPU_MEMCTRL_STAT_RDATA_ECC_ERR BIT(3) +#define ICPU_MEMCTRL_STAT_RDATA_ECC_COR BIT(2) +#define ICPU_MEMCTRL_STAT_PWR_DOWN_ACK BIT(1) +#define ICPU_MEMCTRL_STAT_INIT_DONE BIT(0) + +#define ICPU_MEMCTRL_REF_PERIOD 0x11c + +#define ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF(x) (((x) << 16) & GENMASK(19, 16)) +#define ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF_M GENMASK(19, 16) +#define ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF_X(x) (((x) & GENMASK(19, 16)) >> 16) +#define ICPU_MEMCTRL_REF_PERIOD_REF_PERIOD(x) ((x) & GENMASK(15, 0)) +#define ICPU_MEMCTRL_REF_PERIOD_REF_PERIOD_M GENMASK(15, 0) + +#define ICPU_MEMCTRL_TIMING0 0x124 + +#define ICPU_MEMCTRL_TIMING0_RD_TO_WR_DLY(x) (((x) << 28) & GENMASK(31, 28)) +#define ICPU_MEMCTRL_TIMING0_RD_TO_WR_DLY_M GENMASK(31, 28) +#define ICPU_MEMCTRL_TIMING0_RD_TO_WR_DLY_X(x) (((x) & GENMASK(31, 28)) >> 28) +#define ICPU_MEMCTRL_TIMING0_WR_CS_CHANGE_DLY(x) (((x) << 24) & GENMASK(27, 24)) +#define ICPU_MEMCTRL_TIMING0_WR_CS_CHANGE_DLY_M GENMASK(27, 24) +#define ICPU_MEMCTRL_TIMING0_WR_CS_CHANGE_DLY_X(x) (((x) & GENMASK(27, 24)) >> 24) +#define ICPU_MEMCTRL_TIMING0_RD_CS_CHANGE_DLY(x) (((x) << 20) & GENMASK(23, 20)) +#define ICPU_MEMCTRL_TIMING0_RD_CS_CHANGE_DLY_M GENMASK(23, 20) +#define ICPU_MEMCTRL_TIMING0_RD_CS_CHANGE_DLY_X(x) (((x) & GENMASK(23, 20)) >> 20) +#define ICPU_MEMCTRL_TIMING0_RAS_TO_PRECH_DLY(x) (((x) << 16) & GENMASK(19, 16)) +#define ICPU_MEMCTRL_TIMING0_RAS_TO_PRECH_DLY_M GENMASK(19, 16) +#define ICPU_MEMCTRL_TIMING0_RAS_TO_PRECH_DLY_X(x) (((x) & GENMASK(19, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING0_WR_TO_PRECH_DLY(x) (((x) << 12) & GENMASK(15, 12)) +#define ICPU_MEMCTRL_TIMING0_WR_TO_PRECH_DLY_M GENMASK(15, 12) +#define ICPU_MEMCTRL_TIMING0_WR_TO_PRECH_DLY_X(x) (((x) & GENMASK(15, 12)) >> 12) +#define ICPU_MEMCTRL_TIMING0_RD_TO_PRECH_DLY(x) (((x) << 8) & GENMASK(11, 8)) +#define ICPU_MEMCTRL_TIMING0_RD_TO_PRECH_DLY_M GENMASK(11, 8) +#define ICPU_MEMCTRL_TIMING0_RD_TO_PRECH_DLY_X(x) (((x) & GENMASK(11, 8)) >> 8) +#define ICPU_MEMCTRL_TIMING0_WR_DATA_XFR_DLY(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_TIMING0_WR_DATA_XFR_DLY_M GENMASK(7, 4) +#define ICPU_MEMCTRL_TIMING0_WR_DATA_XFR_DLY_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_TIMING0_RD_DATA_XFR_DLY(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_TIMING0_RD_DATA_XFR_DLY_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_TIMING1 0x128 + +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_SAME_BANK_DLY(x) (((x) << 24) & GENMASK(31, 24)) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_SAME_BANK_DLY_M GENMASK(31, 24) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_SAME_BANK_DLY_X(x) (((x) & GENMASK(31, 24)) >> 24) +#define ICPU_MEMCTRL_TIMING1_BANK8_FAW_DLY(x) (((x) << 16) & GENMASK(23, 16)) +#define ICPU_MEMCTRL_TIMING1_BANK8_FAW_DLY_M GENMASK(23, 16) +#define ICPU_MEMCTRL_TIMING1_BANK8_FAW_DLY_X(x) (((x) & GENMASK(23, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING1_PRECH_TO_RAS_DLY(x) (((x) << 12) & GENMASK(15, 12)) +#define ICPU_MEMCTRL_TIMING1_PRECH_TO_RAS_DLY_M GENMASK(15, 12) +#define ICPU_MEMCTRL_TIMING1_PRECH_TO_RAS_DLY_X(x) (((x) & GENMASK(15, 12)) >> 12) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_DLY(x) (((x) << 8) & GENMASK(11, 8)) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_DLY_M GENMASK(11, 8) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_DLY_X(x) (((x) & GENMASK(11, 8)) >> 8) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_CAS_DLY(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_CAS_DLY_M GENMASK(7, 4) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_CAS_DLY_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_TIMING1_WR_TO_RD_DLY(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_TIMING1_WR_TO_RD_DLY_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_TIMING2 0x12c + +#define ICPU_MEMCTRL_TIMING2_PRECH_ALL_DLY(x) (((x) << 28) & GENMASK(31, 28)) +#define ICPU_MEMCTRL_TIMING2_PRECH_ALL_DLY_M GENMASK(31, 28) +#define ICPU_MEMCTRL_TIMING2_PRECH_ALL_DLY_X(x) (((x) & GENMASK(31, 28)) >> 28) +#define ICPU_MEMCTRL_TIMING2_MDSET_DLY(x) (((x) << 24) & GENMASK(27, 24)) +#define ICPU_MEMCTRL_TIMING2_MDSET_DLY_M GENMASK(27, 24) +#define ICPU_MEMCTRL_TIMING2_MDSET_DLY_X(x) (((x) & GENMASK(27, 24)) >> 24) +#define ICPU_MEMCTRL_TIMING2_REF_DLY(x) (((x) << 16) & GENMASK(23, 16)) +#define ICPU_MEMCTRL_TIMING2_REF_DLY_M GENMASK(23, 16) +#define ICPU_MEMCTRL_TIMING2_REF_DLY_X(x) (((x) & GENMASK(23, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING2_INIT_DLY(x) ((x) & GENMASK(15, 0)) +#define ICPU_MEMCTRL_TIMING2_INIT_DLY_M GENMASK(15, 0) + +#define ICPU_MEMCTRL_TIMING3 0x130 + +#define ICPU_MEMCTRL_TIMING3_RMW_DLY(x) (((x) << 16) & GENMASK(19, 16)) +#define ICPU_MEMCTRL_TIMING3_RMW_DLY_M GENMASK(19, 16) +#define ICPU_MEMCTRL_TIMING3_RMW_DLY_X(x) (((x) & GENMASK(19, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING3_ODT_RD_DLY(x) (((x) << 12) & GENMASK(15, 12)) +#define ICPU_MEMCTRL_TIMING3_ODT_RD_DLY_M GENMASK(15, 12) +#define ICPU_MEMCTRL_TIMING3_ODT_RD_DLY_X(x) (((x) & GENMASK(15, 12)) >> 12) +#define ICPU_MEMCTRL_TIMING3_ODT_WR_DLY(x) (((x) << 8) & GENMASK(11, 8)) +#define ICPU_MEMCTRL_TIMING3_ODT_WR_DLY_M GENMASK(11, 8) +#define ICPU_MEMCTRL_TIMING3_ODT_WR_DLY_X(x) (((x) & GENMASK(11, 8)) >> 8) +#define ICPU_MEMCTRL_TIMING3_LOCAL_ODT_RD_DLY(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_TIMING3_LOCAL_ODT_RD_DLY_M GENMASK(7, 4) +#define ICPU_MEMCTRL_TIMING3_LOCAL_ODT_RD_DLY_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_TIMING3_WR_TO_RD_CS_CHANGE_DLY(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_TIMING3_WR_TO_RD_CS_CHANGE_DLY_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_MR0_VAL 0x138 + +#define ICPU_MEMCTRL_MR1_VAL 0x13c + +#define ICPU_MEMCTRL_MR2_VAL 0x140 + +#define ICPU_MEMCTRL_MR3_VAL 0x144 + +#define ICPU_MEMCTRL_TERMRES_CTRL 0x148 + +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_EXT BIT(11) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_ENA(x) (((x) << 7) & GENMASK(10, 7)) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_ENA_M GENMASK(10, 7) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_ENA_X(x) (((x) & GENMASK(10, 7)) >> 7) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_EXT BIT(6) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_ENA(x) (((x) << 2) & GENMASK(5, 2)) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_ENA_M GENMASK(5, 2) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_ENA_X(x) (((x) & GENMASK(5, 2)) >> 2) +#define ICPU_MEMCTRL_TERMRES_CTRL_LOCAL_ODT_RD_EXT BIT(1) +#define ICPU_MEMCTRL_TERMRES_CTRL_LOCAL_ODT_RD_ENA BIT(0) + +#define ICPU_MEMCTRL_DQS_DLY(x) (0x150 + 0x4 * (x)) +#define ICPU_MEMCTRL_DQS_DLY_RSZ 0x4 + +#define ICPU_MEMCTRL_DQS_DLY_TRAIN_DQ_ENA BIT(11) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM1(x) (((x) << 8) & GENMASK(10, 8)) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM1_M GENMASK(10, 8) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM1_X(x) (((x) & GENMASK(10, 8)) >> 8) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM0(x) (((x) << 5) & GENMASK(7, 5)) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM0_M GENMASK(7, 5) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM0_X(x) (((x) & GENMASK(7, 5)) >> 5) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY(x) ((x) & GENMASK(4, 0)) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_M GENMASK(4, 0) + +#define ICPU_MEMPHY_CFG 0x160 + +#define ICPU_MEMPHY_CFG_PHY_FLUSH_DIS BIT(10) +#define ICPU_MEMPHY_CFG_PHY_RD_ADJ_DIS BIT(9) +#define ICPU_MEMPHY_CFG_PHY_DQS_EXT BIT(8) +#define ICPU_MEMPHY_CFG_PHY_FIFO_RST BIT(7) +#define ICPU_MEMPHY_CFG_PHY_DLL_BL_RST BIT(6) +#define ICPU_MEMPHY_CFG_PHY_DLL_CL_RST BIT(5) +#define ICPU_MEMPHY_CFG_PHY_ODT_OE BIT(4) +#define ICPU_MEMPHY_CFG_PHY_CK_OE BIT(3) +#define ICPU_MEMPHY_CFG_PHY_CL_OE BIT(2) +#define ICPU_MEMPHY_CFG_PHY_SSTL_ENA BIT(1) +#define ICPU_MEMPHY_CFG_PHY_RST BIT(0) + +#define ICPU_MEMPHY_ZCAL 0x188 + +#define ICPU_MEMPHY_ZCAL_ZCAL_CLK_SEL BIT(9) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_ODT(x) (((x) << 5) & GENMASK(8, 5)) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_ODT_M GENMASK(8, 5) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_ODT_X(x) (((x) & GENMASK(8, 5)) >> 5) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG(x) (((x) << 1) & GENMASK(4, 1)) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_M GENMASK(4, 1) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_X(x) (((x) & GENMASK(4, 1)) >> 1) +#define ICPU_MEMPHY_ZCAL_ZCAL_ENA BIT(0) + +#define ICPU_MEMPHY_ZCAL_STAT 0x18c + +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_ZCTRL(x) (((x) << 12) & GENMASK(31, 12)) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_ZCTRL_M GENMASK(31, 12) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_ZCTRL_X(x) (((x) & GENMASK(31, 12)) >> 12) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPU(x) (((x) << 8) & GENMASK(9, 8)) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPU_M GENMASK(9, 8) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPU_X(x) (((x) & GENMASK(9, 8)) >> 8) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPD(x) (((x) << 6) & GENMASK(7, 6)) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPD_M GENMASK(7, 6) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_ODTPD_X(x) (((x) & GENMASK(7, 6)) >> 6) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PU(x) (((x) << 4) & GENMASK(5, 4)) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PU_M GENMASK(5, 4) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PU_X(x) (((x) & GENMASK(5, 4)) >> 4) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PD(x) (((x) << 2) & GENMASK(3, 2)) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PD_M GENMASK(3, 2) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_STAT_PD_X(x) (((x) & GENMASK(3, 2)) >> 2) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_ERR BIT(1) +#define ICPU_MEMPHY_ZCAL_STAT_ZCAL_DONE BIT(0) +#endif diff --git a/arch/mips/mach-mscc/include/mach/tlb.h b/arch/mips/mach-mscc/include/mach/tlb.h new file mode 100644 index 0000000000..fdb554f551 --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/tlb.h @@ -0,0 +1,55 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef __ASM_MACH_TLB_H +#define __ASM_MACH_TLB_H + +#include <asm/mipsregs.h> +#include <mach/common.h> +#include <linux/sizes.h> + +#define TLB_HI_MASK 0xffffe000 +#define TLB_LO_MASK 0x3fffffff /* Masks off Fill bits */ +#define TLB_LO_SHIFT 6 /* PFN Start bit */ + +#define PAGEMASK_SHIFT 13 + +#define MMU_PAGE_CACHED (3 << 3) /* C(5:3) Cache Coherency Attributes */ +#define MMU_PAGE_UNCACHED (2 << 3) /* C(5:3) Cache Coherency Attributes */ +#define MMU_PAGE_DIRTY BIT(2) /* = Writeable */ +#define MMU_PAGE_VALID BIT(1) +#define MMU_PAGE_GLOBAL BIT(0) +#define MMU_REGIO_RO_C (MMU_PAGE_CACHED | MMU_PAGE_VALID | MMU_PAGE_GLOBAL) +#define MMU_REGIO_RO (MMU_PAGE_UNCACHED | MMU_PAGE_VALID | MMU_PAGE_GLOBAL) +#define MMU_REGIO_RW (MMU_PAGE_DIRTY | MMU_REGIO_RO) +#define MMU_REGIO_INVAL (MMU_PAGE_GLOBAL) + +#define TLB_COUNT_MASK GENMASK(5, 0) +#define TLB_COUNT_OFF 25 + +static inline u32 get_tlb_count(void) +{ + register u32 config1; + + config1 = read_c0_config1(); + config1 >>= TLB_COUNT_OFF; + config1 &= TLB_COUNT_MASK; + + return 1 + config1; +} + +static inline void create_tlb(int index, u32 offset, u32 size, u32 tlb_attrib1, + u32 tlb_attrib2) +{ + register u32 tlb_mask, tlb_lo0, tlb_lo1; + + tlb_mask = ((size >> 12) - 1) << PAGEMASK_SHIFT; + tlb_lo0 = tlb_attrib1 | (offset >> TLB_LO_SHIFT); + tlb_lo1 = tlb_attrib2 | ((offset + size) >> TLB_LO_SHIFT); + + write_one_tlb(index, tlb_mask, offset & TLB_HI_MASK, + tlb_lo0 & TLB_LO_MASK, tlb_lo1 & TLB_LO_MASK); +} +#endif /* __ASM_MACH_TLB_H */ diff --git a/arch/mips/mach-mscc/lowlevel_init.S b/arch/mips/mach-mscc/lowlevel_init.S new file mode 100644 index 0000000000..f8f14adf61 --- /dev/null +++ b/arch/mips/mach-mscc/lowlevel_init.S @@ -0,0 +1,23 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <asm/asm.h> +#include <asm/regdef.h> + + .set noreorder + .extern vcoreiii_tlb_init + +LEAF(lowlevel_init) + /* + * As we have no stack yet, we can assume the restricted + * luxury of the sX-registers without saving them + */ + move s0,ra + + jal vcoreiii_tlb_init + nop + jr s0 + nop + END(lowlevel_init) diff --git a/arch/mips/mach-mscc/reset.c b/arch/mips/mach-mscc/reset.c new file mode 100644 index 0000000000..390bbd086a --- /dev/null +++ b/arch/mips/mach-mscc/reset.c @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <common.h> + +#include <asm/sections.h> +#include <asm/io.h> + +#include <asm/reboot.h> + +void _machine_restart(void) +{ + register u32 resetbits = PERF_SOFT_RST_SOFT_CHIP_RST; + (void)readl(BASE_DEVCPU_GCB + PERF_SOFT_RST); + + /* Make sure VCore is NOT protected from reset */ + clrbits_le32(BASE_CFG + ICPU_RESET, ICPU_RESET_CORE_RST_PROTECT); + + /* Change to SPI bitbang for SPI reset workaround... */ + writel(ICPU_SW_MODE_SW_SPI_CS_OE(1) | ICPU_SW_MODE_SW_SPI_CS(1) | + ICPU_SW_MODE_SW_PIN_CTRL_MODE, BASE_CFG + ICPU_SW_MODE); + + /* Do the global reset */ + writel(resetbits, BASE_DEVCPU_GCB + PERF_SOFT_RST); + + while (1) + ; /* NOP */ +}
As the Ocelots SoCs, this family of SoCs are found in the Microsemi Switches solution.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- arch/mips/mach-mscc/Kconfig | 13 + arch/mips/mach-mscc/Makefile | 1 + arch/mips/mach-mscc/cpu.c | 14 +- arch/mips/mach-mscc/dram.c | 2 + arch/mips/mach-mscc/include/mach/common.h | 4 + arch/mips/mach-mscc/include/mach/ddr.h | 112 +++++++- .../mips/mach-mscc/include/mach/luton/luton.h | 24 ++ .../include/mach/luton/luton_devcpu_gcb.h | 14 + .../include/mach/luton/luton_icpu_cfg.h | 245 ++++++++++++++++++ arch/mips/mach-mscc/lowlevel_init.S | 7 + arch/mips/mach-mscc/lowlevel_init_luton.S | 62 +++++ 11 files changed, 494 insertions(+), 4 deletions(-) create mode 100644 arch/mips/mach-mscc/include/mach/luton/luton.h create mode 100644 arch/mips/mach-mscc/include/mach/luton/luton_devcpu_gcb.h create mode 100644 arch/mips/mach-mscc/include/mach/luton/luton_icpu_cfg.h create mode 100644 arch/mips/mach-mscc/lowlevel_init_luton.S
diff --git a/arch/mips/mach-mscc/Kconfig b/arch/mips/mach-mscc/Kconfig index 7f1b270207..a8cace0e79 100644 --- a/arch/mips/mach-mscc/Kconfig +++ b/arch/mips/mach-mscc/Kconfig @@ -21,6 +21,12 @@ config SOC_OCELOT help This supports MSCC Ocelot family of SOCs.
+config SOC_LUTON + bool + select SOC_VCOREIII + help + This supports MSCC Luton family of SOCs. + config SYS_CONFIG_NAME default "vcoreiii"
@@ -41,6 +47,13 @@ config TARGET_OCELOT_PCB123 When selected, CONFIG_DEFAULT_DEVICE_TREE should be set to ocelot_pcb123
+config TARGET_LUTON_PCB091 + bool "MSCC PCB091 Reference Board" + select SOC_LUTON + select MSCC_BITBANG_SPI_GPIO + help + When selected, CONFIG_DEFAULT_DEVICE_TREE should be set to + luton_pcb091 endchoice
choice diff --git a/arch/mips/mach-mscc/Makefile b/arch/mips/mach-mscc/Makefile index d14ec33838..6c60f26ca4 100644 --- a/arch/mips/mach-mscc/Makefile +++ b/arch/mips/mach-mscc/Makefile @@ -3,3 +3,4 @@ CFLAGS_cpu.o += -finline-limit=64000
obj-y += cpu.o dram.o reset.o lowlevel_init.o +obj-$(CONFIG_SOC_LUTON) += lowlevel_init_luton.o diff --git a/arch/mips/mach-mscc/cpu.c b/arch/mips/mach-mscc/cpu.c index b503e1407b..5be8ff69d5 100644 --- a/arch/mips/mach-mscc/cpu.c +++ b/arch/mips/mach-mscc/cpu.c @@ -48,6 +48,10 @@ void vcoreiii_tlb_init(void) */ create_tlb(tlbix++, MSCC_IO_ORIGIN1_OFFSET, SZ_16M, MMU_REGIO_RW, MMU_REGIO_RW); +#ifdef CONFIG_SOC_LUTON + create_tlb(tlbix++, MSCC_IO_ORIGIN2_OFFSET, SZ_16M, MMU_REGIO_RW, + MMU_REGIO_RW); +#endif
#if CONFIG_SYS_TEXT_BASE == MSCC_FLASH_TO /* @@ -75,6 +79,14 @@ void vcoreiii_tlb_init(void) int mach_cpu_init(void) { /* Speed up NOR flash access */ +#ifdef CONFIG_SOC_LUTON + writel(ICPU_PI_MST_CFG_TRISTATE_CTRL + + ICPU_PI_MST_CFG_CLK_DIV(4), BASE_CFG + ICPU_PI_MST_CFG); + + writel(ICPU_SPI_MST_CFG_FAST_READ_ENA + + ICPU_SPI_MST_CFG_CS_DESELECT_TIME(0x19) + + ICPU_SPI_MST_CFG_CLK_DIV(9), BASE_CFG + ICPU_SPI_MST_CFG); +#else writel(ICPU_SPI_MST_CFG_CS_DESELECT_TIME(0x19) + ICPU_SPI_MST_CFG_CLK_DIV(9), BASE_CFG + ICPU_SPI_MST_CFG); /* @@ -85,6 +97,6 @@ int mach_cpu_init(void) writel(0, BASE_CFG + ICPU_DST_INTR_MAP(1)); writel(0, BASE_CFG + ICPU_DST_INTR_MAP(2)); writel(0, BASE_CFG + ICPU_DST_INTR_MAP(3)); - +#endif return 0; } diff --git a/arch/mips/mach-mscc/dram.c b/arch/mips/mach-mscc/dram.c index 5acee6f918..309007c14e 100644 --- a/arch/mips/mach-mscc/dram.c +++ b/arch/mips/mach-mscc/dram.c @@ -19,9 +19,11 @@ static inline int vcoreiii_train_bytelane(void)
+#ifdef CONFIG_SOC_OCELOT if (ret) return ret; ret = hal_vcoreiii_train_bytelane(1); +#endif
return ret; } diff --git a/arch/mips/mach-mscc/include/mach/common.h b/arch/mips/mach-mscc/include/mach/common.h index 842462aeed..931ecd7985 100644 --- a/arch/mips/mach-mscc/include/mach/common.h +++ b/arch/mips/mach-mscc/include/mach/common.h @@ -10,6 +10,10 @@ #include <mach/ocelot/ocelot.h> #include <mach/ocelot/ocelot_devcpu_gcb.h> #include <mach/ocelot/ocelot_icpu_cfg.h> +#elif defined(CONFIG_SOC_LUTON) +#include <mach/luton/luton.h> +#include <mach/luton/luton_devcpu_gcb.h> +#include <mach/luton/luton_icpu_cfg.h> #else #error Unsupported platform #endif diff --git a/arch/mips/mach-mscc/include/mach/ddr.h b/arch/mips/mach-mscc/include/mach/ddr.h index 262985c8c9..f445e63a35 100644 --- a/arch/mips/mach-mscc/include/mach/ddr.h +++ b/arch/mips/mach-mscc/include/mach/ddr.h @@ -614,6 +614,98 @@ static inline int dram_check(void) } return 0; } +#else /* Luton */ + +static inline void sleep_100ns(u32 val) +{ +} + +static inline void hal_vcoreiii_ddr_reset_assert(void) +{ + setbits_le32(BASE_CFG + ICPU_MEMPHY_CFG, ICPU_MEMPHY_CFG_PHY_RST); + setbits_le32(BASE_CFG + ICPU_RESET, ICPU_RESET_MEM_RST_FORCE); +} + +static inline void hal_vcoreiii_ddr_reset_release(void) +{ +} + +static inline void hal_vcoreiii_ddr_failed(void) +{ + register u32 memphy_cfg = readl(BASE_CFG + ICPU_MEMPHY_CFG); + + /* Do a fifo reset and start over */ + writel(memphy_cfg | ICPU_MEMPHY_CFG_PHY_FIFO_RST, + BASE_CFG + ICPU_MEMPHY_CFG); + writel(memphy_cfg & ~ICPU_MEMPHY_CFG_PHY_FIFO_RST, + BASE_CFG + ICPU_MEMPHY_CFG); + writel(memphy_cfg | ICPU_MEMPHY_CFG_PHY_FIFO_RST, + BASE_CFG + ICPU_MEMPHY_CFG); +} + +static inline void hal_vcoreiii_ddr_verified(void) +{ +} + +static inline int look_for(u32 data) +{ + register u32 byte = __raw_readb((void __iomem *)MSCC_DDR_TO); + + if (data != byte) { + if (!incr_dly(0)) + return DDR_TRAIN_ERROR; + return DDR_TRAIN_CONTINUE; + } + + return DDR_TRAIN_OK; +} + +/* This algorithm is converted from the TCL training algorithm used + * during silicon simulation. + * NB: Assumes inlining as no stack is available! + */ +static inline int hal_vcoreiii_train_bytelane(u32 bytelane) +{ + register int res; + + set_dly(bytelane, 0); /* Start training at DQS=0 */ + while ((res = look_for(0xff)) == DDR_TRAIN_CONTINUE) + ; + if (res != DDR_TRAIN_OK) + return res; + + set_dly(bytelane, 0); /* Start training at DQS=0 */ + while ((res = look_for(0x00)) == DDR_TRAIN_CONTINUE) + + ; + + if (res != DDR_TRAIN_OK) + return res; + + adjust_dly(-3); + + return DDR_TRAIN_OK; +} + +static inline int hal_vcoreiii_init_dqs(void) +{ + return 0; +} + +static inline int dram_check(void) +{ + register u32 i; + + for (i = 0; i < 8; i++) { + __raw_writel(~i, (void __iomem *)(MSCC_DDR_TO + (i * 4))); + + if (__raw_readl((void __iomem *)(MSCC_DDR_TO + (i * 4))) != ~i) + return 1; + } + + return 0; +} +#endif
/* * NB: Called *early* to init memory controller - assumes inlining as @@ -646,12 +738,12 @@ static inline void hal_vcoreiii_init_memctl(void) /* Wait for ZCAL to clear */ while (readl(BASE_CFG + ICPU_MEMPHY_ZCAL) & ICPU_MEMPHY_ZCAL_ZCAL_ENA) ; - +#ifdef CONFIG_SOC_OCELOT /* Check no ZCAL_ERR */ if (readl(BASE_CFG + ICPU_MEMPHY_ZCAL_STAT) & ICPU_MEMPHY_ZCAL_STAT_ZCAL_ERR) hal_vcoreiii_ddr_failed(); - +#endif /* Drive CL, CK, ODT */ setbits_le32(BASE_CFG + ICPU_MEMPHY_CFG, ICPU_MEMPHY_CFG_PHY_ODT_OE | ICPU_MEMPHY_CFG_PHY_CK_OE | ICPU_MEMPHY_CFG_PHY_CL_OE); @@ -660,7 +752,12 @@ static inline void hal_vcoreiii_init_memctl(void) writel(MSCC_MEMPARM_MEMCFG, BASE_CFG + ICPU_MEMCTRL_CFG); writel(MSCC_MEMPARM_PERIOD, BASE_CFG + ICPU_MEMCTRL_REF_PERIOD);
+#ifdef CONFIG_SOC_OCELOT writel(MSCC_MEMPARM_TIMING0, BASE_CFG + ICPU_MEMCTRL_TIMING0); +#else /* Luton */ + clrbits_le32(BASE_CFG + ICPU_MEMCTRL_TIMING0, ((1 << 20) - 1)); + setbits_le32(BASE_CFG + ICPU_MEMCTRL_TIMING0, MSCC_MEMPARM_TIMING0); +#endif
writel(MSCC_MEMPARM_TIMING1, BASE_CFG + ICPU_MEMCTRL_TIMING1); writel(MSCC_MEMPARM_TIMING2, BASE_CFG + ICPU_MEMCTRL_TIMING2); @@ -670,6 +767,7 @@ static inline void hal_vcoreiii_init_memctl(void) writel(MSCC_MEMPARM_MR2, BASE_CFG + ICPU_MEMCTRL_MR2_VAL); writel(MSCC_MEMPARM_MR3, BASE_CFG + ICPU_MEMCTRL_MR3_VAL);
+#ifdef CONFIG_SOC_OCELOT /* Termination setup - enable ODT */ writel(ICPU_MEMCTRL_TERMRES_CTRL_LOCAL_ODT_RD_ENA | /* Assert ODT0 for any write */ @@ -680,6 +778,11 @@ static inline void hal_vcoreiii_init_memctl(void) hal_vcoreiii_ddr_reset_release();
writel(readl(BASE_CFG + ICPU_GPR(7)) + 1, BASE_CFG + ICPU_GPR(7)); +#else /* Luton */ + /* Termination setup - disable ODT */ + writel(0, BASE_CFG + ICPU_MEMCTRL_TERMRES_CTRL); + +#endif }
static inline void hal_vcoreiii_wait_memctl(void) @@ -693,7 +796,7 @@ static inline void hal_vcoreiii_wait_memctl(void)
/* Settle...? */ sleep_100ns(10000); - +#ifdef CONFIG_SOC_OCELOT /* Establish data contents in DDR RAM for training */
__raw_writel(0xcacafefe, ((void __iomem *)MSCC_DDR_TO)); @@ -704,5 +807,8 @@ static inline void hal_vcoreiii_wait_memctl(void) __raw_writel(0xaaaa9999, ((void __iomem *)MSCC_DDR_TO + 0x14)); __raw_writel(0xccccbbbb, ((void __iomem *)MSCC_DDR_TO + 0x18)); __raw_writel(0xeeeedddd, ((void __iomem *)MSCC_DDR_TO + 0x1C)); +#else + __raw_writel(0xff, ((void __iomem *)MSCC_DDR_TO)); +#endif } #endif /* __ASM_MACH_DDR_H */ diff --git a/arch/mips/mach-mscc/include/mach/luton/luton.h b/arch/mips/mach-mscc/include/mach/luton/luton.h new file mode 100644 index 0000000000..19f02ede66 --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/luton/luton.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Microsemi Ocelot Switch driver + * + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef _MSCC_OCELOT_H_ +#define _MSCC_OCELOT_H_ + +#include <linux/bitops.h> +#include <dm.h> + +/* + * Target offset base(s) + */ +#define MSCC_IO_ORIGIN1_OFFSET 0x60000000 +#define MSCC_IO_ORIGIN1_SIZE 0x01000000 +#define MSCC_IO_ORIGIN2_OFFSET 0x70000000 +#define MSCC_IO_ORIGIN2_SIZE 0x00200000 +#define BASE_CFG ((void __iomem *)0x70000000) +#define BASE_DEVCPU_GCB ((void __iomem *)0x60070000) + +#endif diff --git a/arch/mips/mach-mscc/include/mach/luton/luton_devcpu_gcb.h b/arch/mips/mach-mscc/include/mach/luton/luton_devcpu_gcb.h new file mode 100644 index 0000000000..8c0b612325 --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/luton/luton_devcpu_gcb.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef _MSCC_OCELOT_DEVCPU_GCB_H_ +#define _MSCC_OCELOT_DEVCPU_GCB_H_ + +#define PERF_SOFT_RST 0x90 + +#define PERF_SOFT_RST_SOFT_SWC_RST BIT(1) +#define PERF_SOFT_RST_SOFT_CHIP_RST BIT(0) + +#endif diff --git a/arch/mips/mach-mscc/include/mach/luton/luton_icpu_cfg.h b/arch/mips/mach-mscc/include/mach/luton/luton_icpu_cfg.h new file mode 100644 index 0000000000..9233f037bb --- /dev/null +++ b/arch/mips/mach-mscc/include/mach/luton/luton_icpu_cfg.h @@ -0,0 +1,245 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef _MSCC_OCELOT_ICPU_CFG_H_ +#define _MSCC_OCELOT_ICPU_CFG_H_ + +#define ICPU_GPR(x) (0x4 * (x)) +#define ICPU_GPR_RSZ 0x4 + +#define ICPU_RESET 0x20 + +#define ICPU_RESET_CORE_RST_CPU_ONLY BIT(3) +#define ICPU_RESET_CORE_RST_PROTECT BIT(2) +#define ICPU_RESET_CORE_RST_FORCE BIT(1) +#define ICPU_RESET_MEM_RST_FORCE BIT(0) + +#define ICPU_GENERAL_CTRL 0x24 + +#define ICPU_GENERAL_CTRL_SWC_CLEAR_IF BIT(6) +#define ICPU_GENERAL_CTRL_CPU_BUSIF_SLEEP_DIS BIT(5) +#define ICPU_GENERAL_CTRL_CPU_BUSIF_WERR_ENA BIT(4) +#define ICPU_GENERAL_CTRL_IF_MASTER_DIS BIT(3) +#define ICPU_GENERAL_CTRL_IF_MASTER_SPI_ENA BIT(2) +#define ICPU_GENERAL_CTRL_IF_MASTER_PI_ENA BIT(1) + +#define ICPU_GENERAL_CTRL_BOOT_MODE_ENA BIT(0) + +#define ICPU_PI_MST_CFG 0x2c + +#define ICPU_PI_MST_CFG_ATE_MODE_DIS BIT(7) +#define ICPU_PI_MST_CFG_CLK_POL BIT(6) +#define ICPU_PI_MST_CFG_TRISTATE_CTRL BIT(5) +#define ICPU_PI_MST_CFG_CLK_DIV(x) ((x) & GENMASK(4, 0)) +#define ICPU_PI_MST_CFG_CLK_DIV_M GENMASK(4, 0) + +#define ICPU_SPI_MST_CFG 0x50 + +#define ICPU_SPI_MST_CFG_FAST_READ_ENA BIT(10) +#define ICPU_SPI_MST_CFG_CS_DESELECT_TIME(x) (((x) << 5) & GENMASK(9, 5)) +#define ICPU_SPI_MST_CFG_CS_DESELECT_TIME_M GENMASK(9, 5) +#define ICPU_SPI_MST_CFG_CS_DESELECT_TIME_X(x) (((x) & GENMASK(9, 5)) >> 5) +#define ICPU_SPI_MST_CFG_CLK_DIV(x) ((x) & GENMASK(4, 0)) +#define ICPU_SPI_MST_CFG_CLK_DIV_M GENMASK(4, 0) + +#define ICPU_SW_MODE 0x64 + +#define ICPU_SW_MODE_SW_PIN_CTRL_MODE BIT(13) +#define ICPU_SW_MODE_SW_SPI_SCK BIT(12) +#define ICPU_SW_MODE_SW_SPI_SCK_OE BIT(11) +#define ICPU_SW_MODE_SW_SPI_SDO BIT(10) +#define ICPU_SW_MODE_SW_SPI_SDO_OE BIT(9) +#define ICPU_SW_MODE_SW_SPI_CS(x) (((x) << 5) & GENMASK(8, 5)) +#define ICPU_SW_MODE_SW_SPI_CS_M GENMASK(8, 5) +#define ICPU_SW_MODE_SW_SPI_CS_X(x) (((x) & GENMASK(8, 5)) >> 5) +#define ICPU_SW_MODE_SW_SPI_CS_OE(x) (((x) << 1) & GENMASK(4, 1)) +#define ICPU_SW_MODE_SW_SPI_CS_OE_M GENMASK(4, 1) +#define ICPU_SW_MODE_SW_SPI_CS_OE_X(x) (((x) & GENMASK(4, 1)) >> 1) +#define ICPU_SW_MODE_SW_SPI_SDI BIT(0) + +#define ICPU_INTR_ENA 0x88 + +#define ICPU_INTR_IRQ0_ENA 0x98 +#define ICPU_INTR_IRQ0_ENA_IRQ0_ENA BIT(0) + +#define ICPU_MEMCTRL_CTRL 0x234 + +#define ICPU_MEMCTRL_CTRL_PWR_DOWN BIT(3) +#define ICPU_MEMCTRL_CTRL_MDSET BIT(2) +#define ICPU_MEMCTRL_CTRL_STALL_REF_ENA BIT(1) +#define ICPU_MEMCTRL_CTRL_INITIALIZE BIT(0) + +#define ICPU_MEMCTRL_CFG 0x238 + +#define ICPU_MEMCTRL_CFG_DDR_512MBYTE_PLUS BIT(16) +#define ICPU_MEMCTRL_CFG_DDR_ECC_ERR_ENA BIT(15) +#define ICPU_MEMCTRL_CFG_DDR_ECC_COR_ENA BIT(14) +#define ICPU_MEMCTRL_CFG_DDR_ECC_ENA BIT(13) +#define ICPU_MEMCTRL_CFG_DDR_WIDTH BIT(12) +#define ICPU_MEMCTRL_CFG_DDR_MODE BIT(11) +#define ICPU_MEMCTRL_CFG_BURST_SIZE BIT(10) +#define ICPU_MEMCTRL_CFG_BURST_LEN BIT(9) +#define ICPU_MEMCTRL_CFG_BANK_CNT BIT(8) +#define ICPU_MEMCTRL_CFG_MSB_ROW_ADDR(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_CFG_MSB_ROW_ADDR_M GENMASK(7, 4) +#define ICPU_MEMCTRL_CFG_MSB_ROW_ADDR_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_CFG_MSB_COL_ADDR(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_CFG_MSB_COL_ADDR_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_STAT 0x23C + +#define ICPU_MEMCTRL_STAT_RDATA_MASKED BIT(5) +#define ICPU_MEMCTRL_STAT_RDATA_DUMMY BIT(4) +#define ICPU_MEMCTRL_STAT_RDATA_ECC_ERR BIT(3) +#define ICPU_MEMCTRL_STAT_RDATA_ECC_COR BIT(2) +#define ICPU_MEMCTRL_STAT_PWR_DOWN_ACK BIT(1) +#define ICPU_MEMCTRL_STAT_INIT_DONE BIT(0) + +#define ICPU_MEMCTRL_REF_PERIOD 0x240 + +#define ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF(x) (((x) << 16) & GENMASK(19, 16)) +#define ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF_M GENMASK(19, 16) +#define ICPU_MEMCTRL_REF_PERIOD_MAX_PEND_REF_X(x) (((x) & GENMASK(19, 16)) >> 16) +#define ICPU_MEMCTRL_REF_PERIOD_REF_PERIOD(x) ((x) & GENMASK(15, 0)) +#define ICPU_MEMCTRL_REF_PERIOD_REF_PERIOD_M GENMASK(15, 0) + +#define ICPU_MEMCTRL_TIMING0 0x248 + +#define ICPU_MEMCTRL_TIMING0_RD_TO_WR_DLY(x) (((x) << 28) & GENMASK(31, 28)) +#define ICPU_MEMCTRL_TIMING0_RD_TO_WR_DLY_M GENMASK(31, 28) +#define ICPU_MEMCTRL_TIMING0_RD_TO_WR_DLY_X(x) (((x) & GENMASK(31, 28)) >> 28) +#define ICPU_MEMCTRL_TIMING0_WR_CS_CHANGE_DLY(x) (((x) << 24) & GENMASK(27, 24)) +#define ICPU_MEMCTRL_TIMING0_WR_CS_CHANGE_DLY_M GENMASK(27, 24) +#define ICPU_MEMCTRL_TIMING0_WR_CS_CHANGE_DLY_X(x) (((x) & GENMASK(27, 24)) >> 24) +#define ICPU_MEMCTRL_TIMING0_RD_CS_CHANGE_DLY(x) (((x) << 20) & GENMASK(23, 20)) +#define ICPU_MEMCTRL_TIMING0_RD_CS_CHANGE_DLY_M GENMASK(23, 20) +#define ICPU_MEMCTRL_TIMING0_RD_CS_CHANGE_DLY_X(x) (((x) & GENMASK(23, 20)) >> 20) +#define ICPU_MEMCTRL_TIMING0_RAS_TO_PRECH_DLY(x) (((x) << 16) & GENMASK(19, 16)) +#define ICPU_MEMCTRL_TIMING0_RAS_TO_PRECH_DLY_M GENMASK(19, 16) +#define ICPU_MEMCTRL_TIMING0_RAS_TO_PRECH_DLY_X(x) (((x) & GENMASK(19, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING0_WR_TO_PRECH_DLY(x) (((x) << 12) & GENMASK(15, 12)) +#define ICPU_MEMCTRL_TIMING0_WR_TO_PRECH_DLY_M GENMASK(15, 12) +#define ICPU_MEMCTRL_TIMING0_WR_TO_PRECH_DLY_X(x) (((x) & GENMASK(15, 12)) >> 12) +#define ICPU_MEMCTRL_TIMING0_RD_TO_PRECH_DLY(x) (((x) << 8) & GENMASK(11, 8)) +#define ICPU_MEMCTRL_TIMING0_RD_TO_PRECH_DLY_M GENMASK(11, 8) +#define ICPU_MEMCTRL_TIMING0_RD_TO_PRECH_DLY_X(x) (((x) & GENMASK(11, 8)) >> 8) +#define ICPU_MEMCTRL_TIMING0_WR_DATA_XFR_DLY(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_TIMING0_WR_DATA_XFR_DLY_M GENMASK(7, 4) +#define ICPU_MEMCTRL_TIMING0_WR_DATA_XFR_DLY_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_TIMING0_RD_DATA_XFR_DLY(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_TIMING0_RD_DATA_XFR_DLY_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_TIMING1 0x24c + +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_SAME_BANK_DLY(x) (((x) << 24) & GENMASK(31, 24)) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_SAME_BANK_DLY_M GENMASK(31, 24) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_SAME_BANK_DLY_X(x) (((x) & GENMASK(31, 24)) >> 24) +#define ICPU_MEMCTRL_TIMING1_BANK8_FAW_DLY(x) (((x) << 16) & GENMASK(23, 16)) +#define ICPU_MEMCTRL_TIMING1_BANK8_FAW_DLY_M GENMASK(23, 16) +#define ICPU_MEMCTRL_TIMING1_BANK8_FAW_DLY_X(x) (((x) & GENMASK(23, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING1_PRECH_TO_RAS_DLY(x) (((x) << 12) & GENMASK(15, 12)) +#define ICPU_MEMCTRL_TIMING1_PRECH_TO_RAS_DLY_M GENMASK(15, 12) +#define ICPU_MEMCTRL_TIMING1_PRECH_TO_RAS_DLY_X(x) (((x) & GENMASK(15, 12)) >> 12) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_DLY(x) (((x) << 8) & GENMASK(11, 8)) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_DLY_M GENMASK(11, 8) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_RAS_DLY_X(x) (((x) & GENMASK(11, 8)) >> 8) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_CAS_DLY(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_CAS_DLY_M GENMASK(7, 4) +#define ICPU_MEMCTRL_TIMING1_RAS_TO_CAS_DLY_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_TIMING1_WR_TO_RD_DLY(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_TIMING1_WR_TO_RD_DLY_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_TIMING2 0x250 + +#define ICPU_MEMCTRL_TIMING2_PRECH_ALL_DLY(x) (((x) << 28) & GENMASK(31, 28)) +#define ICPU_MEMCTRL_TIMING2_PRECH_ALL_DLY_M GENMASK(31, 28) +#define ICPU_MEMCTRL_TIMING2_PRECH_ALL_DLY_X(x) (((x) & GENMASK(31, 28)) >> 28) +#define ICPU_MEMCTRL_TIMING2_MDSET_DLY(x) (((x) << 24) & GENMASK(27, 24)) +#define ICPU_MEMCTRL_TIMING2_MDSET_DLY_M GENMASK(27, 24) +#define ICPU_MEMCTRL_TIMING2_MDSET_DLY_X(x) (((x) & GENMASK(27, 24)) >> 24) +#define ICPU_MEMCTRL_TIMING2_REF_DLY(x) (((x) << 16) & GENMASK(23, 16)) +#define ICPU_MEMCTRL_TIMING2_REF_DLY_M GENMASK(23, 16) +#define ICPU_MEMCTRL_TIMING2_REF_DLY_X(x) (((x) & GENMASK(23, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING2_FOUR_HUNDRED_NS_DLY(x) ((x) & GENMASK(15, 0)) +#define ICPU_MEMCTRL_TIMING2_FOUR_HUNDRED_NS_DLY_M GENMASK(15, 0) + +#define ICPU_MEMCTRL_TIMING3 0x254 + +#define ICPU_MEMCTRL_TIMING3_RMW_DLY(x) (((x) << 16) & GENMASK(19, 16)) +#define ICPU_MEMCTRL_TIMING3_RMW_DLY_M GENMASK(19, 16) +#define ICPU_MEMCTRL_TIMING3_RMW_DLY_X(x) (((x) & GENMASK(19, 16)) >> 16) +#define ICPU_MEMCTRL_TIMING3_ODT_RD_DLY(x) (((x) << 12) & GENMASK(15, 12)) +#define ICPU_MEMCTRL_TIMING3_ODT_RD_DLY_M GENMASK(15, 12) +#define ICPU_MEMCTRL_TIMING3_ODT_RD_DLY_X(x) (((x) & GENMASK(15, 12)) >> 12) +#define ICPU_MEMCTRL_TIMING3_ODT_WR_DLY(x) (((x) << 8) & GENMASK(11, 8)) +#define ICPU_MEMCTRL_TIMING3_ODT_WR_DLY_M GENMASK(11, 8) +#define ICPU_MEMCTRL_TIMING3_ODT_WR_DLY_X(x) (((x) & GENMASK(11, 8)) >> 8) +#define ICPU_MEMCTRL_TIMING3_LOCAL_ODT_RD_DLY(x) (((x) << 4) & GENMASK(7, 4)) +#define ICPU_MEMCTRL_TIMING3_LOCAL_ODT_RD_DLY_M GENMASK(7, 4) +#define ICPU_MEMCTRL_TIMING3_LOCAL_ODT_RD_DLY_X(x) (((x) & GENMASK(7, 4)) >> 4) +#define ICPU_MEMCTRL_TIMING3_WR_TO_RD_CS_CHANGE_DLY(x) ((x) & GENMASK(3, 0)) +#define ICPU_MEMCTRL_TIMING3_WR_TO_RD_CS_CHANGE_DLY_M GENMASK(3, 0) + +#define ICPU_MEMCTRL_MR0_VAL 0x258 + +#define ICPU_MEMCTRL_MR1_VAL 0x25c + +#define ICPU_MEMCTRL_MR2_VAL 0x260 + +#define ICPU_MEMCTRL_MR3_VAL 0x264 + +#define ICPU_MEMCTRL_TERMRES_CTRL 0x268 + +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_EXT BIT(11) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_ENA(x) (((x) << 7) & GENMASK(10, 7)) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_ENA_M GENMASK(10, 7) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_RD_ENA_X(x) (((x) & GENMASK(10, 7)) >> 7) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_EXT BIT(6) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_ENA(x) (((x) << 2) & GENMASK(5, 2)) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_ENA_M GENMASK(5, 2) +#define ICPU_MEMCTRL_TERMRES_CTRL_ODT_WR_ENA_X(x) (((x) & GENMASK(5, 2)) >> 2) +#define ICPU_MEMCTRL_TERMRES_CTRL_LOCAL_ODT_RD_EXT BIT(1) +#define ICPU_MEMCTRL_TERMRES_CTRL_LOCAL_ODT_RD_ENA BIT(0) + +#define ICPU_MEMCTRL_DQS_DLY(x) (0x270) + +#define ICPU_MEMCTRL_DQS_DLY_TRAIN_DQ_ENA BIT(11) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM1(x) (((x) << 8) & GENMASK(10, 8)) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM1_M GENMASK(10, 8) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM1_X(x) (((x) & GENMASK(10, 8)) >> 8) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM0(x) (((x) << 5) & GENMASK(7, 5)) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM0_M GENMASK(7, 5) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_TRM0_X(x) (((x) & GENMASK(7, 5)) >> 5) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY(x) ((x) & GENMASK(4, 0)) +#define ICPU_MEMCTRL_DQS_DLY_DQS_DLY_M GENMASK(4, 0) + +#define ICPU_MEMPHY_CFG 0x278 + +#define ICPU_MEMPHY_CFG_PHY_FLUSH_DIS BIT(10) +#define ICPU_MEMPHY_CFG_PHY_RD_ADJ_DIS BIT(9) +#define ICPU_MEMPHY_CFG_PHY_DQS_EXT BIT(8) +#define ICPU_MEMPHY_CFG_PHY_FIFO_RST BIT(7) +#define ICPU_MEMPHY_CFG_PHY_DLL_BL_RST BIT(6) +#define ICPU_MEMPHY_CFG_PHY_DLL_CL_RST BIT(5) +#define ICPU_MEMPHY_CFG_PHY_ODT_OE BIT(4) +#define ICPU_MEMPHY_CFG_PHY_CK_OE BIT(3) +#define ICPU_MEMPHY_CFG_PHY_CL_OE BIT(2) +#define ICPU_MEMPHY_CFG_PHY_SSTL_ENA BIT(1) +#define ICPU_MEMPHY_CFG_PHY_RST BIT(0) +#define ICPU_MEMPHY_DQ_DLY_TRM 0x180 +#define ICPU_MEMPHY_DQ_DLY_TRM_RSZ 0x4 + +#define ICPU_MEMPHY_ZCAL 0x294 + +#define ICPU_MEMPHY_ZCAL_ZCAL_CLK_SEL BIT(9) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_ODT(x) (((x) << 5) & GENMASK(8, 5)) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_ODT_M GENMASK(8, 5) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_ODT_X(x) (((x) & GENMASK(8, 5)) >> 5) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG(x) (((x) << 1) & GENMASK(4, 1)) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_M GENMASK(4, 1) +#define ICPU_MEMPHY_ZCAL_ZCAL_PROG_X(x) (((x) & GENMASK(4, 1)) >> 1) +#define ICPU_MEMPHY_ZCAL_ZCAL_ENA BIT(0) + +#endif diff --git a/arch/mips/mach-mscc/lowlevel_init.S b/arch/mips/mach-mscc/lowlevel_init.S index f8f14adf61..dfbe06766c 100644 --- a/arch/mips/mach-mscc/lowlevel_init.S +++ b/arch/mips/mach-mscc/lowlevel_init.S @@ -8,6 +8,9 @@
.set noreorder .extern vcoreiii_tlb_init +#ifdef CONFIG_SOC_LUTON + .extern pll_init +#endif
LEAF(lowlevel_init) /* @@ -18,6 +21,10 @@ LEAF(lowlevel_init)
jal vcoreiii_tlb_init nop +#ifdef CONFIG_SOC_LUTON + jal pll_init + nop +#endif jr s0 nop END(lowlevel_init) diff --git a/arch/mips/mach-mscc/lowlevel_init_luton.S b/arch/mips/mach-mscc/lowlevel_init_luton.S new file mode 100644 index 0000000000..8a528fa83a --- /dev/null +++ b/arch/mips/mach-mscc/lowlevel_init_luton.S @@ -0,0 +1,62 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <asm/asm.h> +#include <asm/regdef.h> + +#define BASE_MACRO 0x600a0000 +#define REG_OFFSET(t, o) (t + (o*4)) +#define REG_MACRO(x) REG_OFFSET(BASE_MACRO, x) +#define BIT(nr) (1 << (nr)) + +#define MACRO_CTRL_PLL5G_STATUS_PLL5G_STATUS0 REG_MACRO(6) +#define MACRO_CTRL_PLL5G_STATUS_PLL5G_STATUS0_LOCK_STATUS BIT(0) +#define MACRO_CTRL_PLL5G_CFG_PLL5G_CFG2 REG_MACRO(2) +#define MACRO_CTRL_PLL5G_CFG_PLL5G_CFG0 REG_MACRO(0) +#define MACRO_CTRL_PLL5G_CFG_PLL5G_CFG0_CPU_CLK_DIV (0x3F << 6) +#define MACRO_CTRL_PLL5G_CFG_PLL5G_CFG0_CPU_CLK_DIV_ENC(x) (x << 6) + + .set noreorder +LEAF(pll_init) + /* Make sure PLL is locked */ + lw v0, MACRO_CTRL_PLL5G_STATUS_PLL5G_STATUS0 + andi v1, v0, MACRO_CTRL_PLL5G_STATUS_PLL5G_STATUS0_LOCK_STATUS + bne v1, zero, 1f + nop + + /* Black magic from frontend */ + li v1, 0x00610400 + sw v1, MACRO_CTRL_PLL5G_CFG_PLL5G_CFG2 + + li v1, 0x00610c00 + sw v1, MACRO_CTRL_PLL5G_CFG_PLL5G_CFG2 + + li v1, 0x00610800 + sw v1, MACRO_CTRL_PLL5G_CFG_PLL5G_CFG2 + + li v1, 0x00610000 + sw v1, MACRO_CTRL_PLL5G_CFG_PLL5G_CFG2 + + /* Wait for lock */ +2: lw v0, MACRO_CTRL_PLL5G_STATUS_PLL5G_STATUS0 + andi v1, v0, MACRO_CTRL_PLL5G_STATUS_PLL5G_STATUS0_LOCK_STATUS + /* Keep looping if zero (no lock bit yet) */ + beq v1, zero, 2b + nop + + /* Setup PLL CPU clock divider for 416MHz */ +1: lw v0, MACRO_CTRL_PLL5G_CFG_PLL5G_CFG0 + + /* Keep reserved bits */ + li v1, ~MACRO_CTRL_PLL5G_CFG_PLL5G_CFG0_CPU_CLK_DIV + and v0, v0, v1 + + /* Set code 6 ~ 416.66 MHz */ + ori v0, v0, MACRO_CTRL_PLL5G_CFG_PLL5G_CFG0_CPU_CLK_DIV_ENC(6) + + sw v0, MACRO_CTRL_PLL5G_CFG_PLL5G_CFG0 + jr ra + nop + END(pll_init)
Adding the support for 2 boards sharing common code for Ocelot chip: PCB120 and PCB123
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- MAINTAINERS | 5 + arch/mips/dts/mscc,ocelot.dtsi | 152 +++++++++++++++++++++++++++ arch/mips/dts/mscc,ocelot_pcb.dtsi | 42 ++++++++ arch/mips/dts/ocelot_pcb120.dts | 12 +++ arch/mips/dts/ocelot_pcb123.dts | 12 +++ arch/mips/mach-mscc/Kconfig | 2 + board/mscc/ocelot/Kconfig | 14 +++ board/mscc/ocelot/Makefile | 4 + board/mscc/ocelot/ocelot.c | 58 ++++++++++ configs/mscc_ocelot_defconfig | 73 +++++++++++++ configs/mscc_ocelot_pcb120_defconfig | 66 ++++++++++++ include/configs/vcoreiii.h | 82 +++++++++++++++ 12 files changed, 522 insertions(+) create mode 100644 arch/mips/dts/mscc,ocelot.dtsi create mode 100644 arch/mips/dts/mscc,ocelot_pcb.dtsi create mode 100644 arch/mips/dts/ocelot_pcb120.dts create mode 100644 arch/mips/dts/ocelot_pcb123.dts create mode 100644 board/mscc/ocelot/Kconfig create mode 100644 board/mscc/ocelot/Makefile create mode 100644 board/mscc/ocelot/ocelot.c create mode 100644 configs/mscc_ocelot_defconfig create mode 100644 configs/mscc_ocelot_pcb120_defconfig create mode 100644 include/configs/vcoreiii.h
diff --git a/MAINTAINERS b/MAINTAINERS index 53a3c5bec6..c906ca006b 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -490,6 +490,11 @@ M: Lars Povlsen lars.povlsen@microchip.com M: Horatiu Vultur horatiu.vultur@microchip.com S: Maintained F: arch/mips/mach-mscc/ +F: arch/mips/dts/mscc* +F: arch/mips/dts/ocelot* +F: board/mscc/ +F: configs/mscc* +F: include/configs/vcoreiii.h
MMC M: Jaehoon Chung jh80.chung@samsung.com diff --git a/arch/mips/dts/mscc,ocelot.dtsi b/arch/mips/dts/mscc,ocelot.dtsi new file mode 100644 index 0000000000..87b4736285 --- /dev/null +++ b/arch/mips/dts/mscc,ocelot.dtsi @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +/ { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mscc,ocelot"; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "mips,mips24KEc"; + device_type = "cpu"; + clocks = <&cpu_clk>; + reg = <0>; + }; + }; + + aliases { + serial0 = &uart0; + }; + + cpuintc: interrupt-controller@0 { + #address-cells = <0>; + #interrupt-cells = <1>; + interrupt-controller; + compatible = "mti,cpu-interrupt-controller"; + }; + + cpu_clk: cpu-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <500000000>; + }; + + ahb_clk: ahb-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <250000000>; + }; + + ahb { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x70000000 0x2000000>; + + interrupt-parent = <&intc>; + + cpu_ctrl: syscon@0 { + compatible = "mscc,ocelot-cpu-syscon", "syscon"; + reg = <0x0 0x2c>; + }; + + intc: interrupt-controller@70 { + compatible = "mscc,ocelot-icpu-intr"; + reg = <0x70 0x70>; + #interrupt-cells = <1>; + interrupt-controller; + interrupt-parent = <&cpuintc>; + interrupts = <2>; + }; + + uart0: serial@100000 { + pinctrl-0 = <&uart_pins>; + pinctrl-names = "default"; + compatible = "ns16550a"; + reg = <0x100000 0x20>; + interrupts = <6>; + clocks = <&ahb_clk>; + reg-io-width = <4>; + reg-shift = <2>; + + status = "disabled"; + }; + + uart2: serial@100800 { + pinctrl-0 = <&uart2_pins>; + pinctrl-names = "default"; + compatible = "ns16550a"; + reg = <0x100800 0x20>; + interrupts = <7>; + clocks = <&ahb_clk>; + reg-io-width = <4>; + reg-shift = <2>; + + status = "disabled"; + }; + + spi0: spi-master@101000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dw-apb-ssi"; + reg = <0x101000 0x40>; + num-chipselect = <4>; + bus-num = <0>; + reg-io-width = <4>; + reg-shift = <2>; + spi-max-frequency = <18000000>; /* input clock */ + clocks = <&ahb_clk>; + + status = "disabled"; + }; + + reset@1070008 { + compatible = "mscc,ocelot-chip-reset"; + reg = <0x1070008 0x4>; + }; + + gpio: pinctrl@1070034 { + compatible = "mscc,ocelot-pinctrl"; + reg = <0x1070034 0x68>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&gpio 0 0 22>; + + uart_pins: uart-pins { + pins = "GPIO_6", "GPIO_7"; + function = "uart"; + }; + + uart2_pins: uart2-pins { + pins = "GPIO_12", "GPIO_13"; + function = "uart2"; + }; + + spi_cs1_pin: spi-cs1-pin { + pins = "GPIO_8"; + function = "si"; + }; + + spi_cs2_pin: spi-cs2-pin { + pins = "GPIO_9"; + function = "si"; + }; + + spi_cs3_pin: spi-cs3-pin { + pins = "GPIO_16"; + function = "si"; + }; + + spi_cs4_pin: spi-cs4-pin { + pins = "GPIO_17"; + function = "si"; + }; + }; + }; +}; diff --git a/arch/mips/dts/mscc,ocelot_pcb.dtsi b/arch/mips/dts/mscc,ocelot_pcb.dtsi new file mode 100644 index 0000000000..90725d3b94 --- /dev/null +++ b/arch/mips/dts/mscc,ocelot_pcb.dtsi @@ -0,0 +1,42 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +/dts-v1/; +#include "mscc,ocelot.dtsi" + +/ { + compatible = "mscc,ocelot"; + + aliases { + spi0 = &spi0; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&uart0 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + pinctrl-0 = <&spi_cs1_pin>; + pinctrl-names = "default"; + + spi-flash@0 { + compatible = "spi-flash"; + spi-max-frequency = <18000000>; /* input clock */ + reg = <0>; /* CS0 */ + }; + + spi-nand@1 { + compatible = "spi-nand"; + spi-max-frequency = <18000000>; /* input clock */ + reg = <1>; /* CS1 */ + }; +}; diff --git a/arch/mips/dts/ocelot_pcb120.dts b/arch/mips/dts/ocelot_pcb120.dts new file mode 100644 index 0000000000..47d305a614 --- /dev/null +++ b/arch/mips/dts/ocelot_pcb120.dts @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +/dts-v1/; +#include "mscc,ocelot_pcb.dtsi" + +/ { + model = "Ocelot PCB120 Reference Board"; + compatible = "mscc,ocelot-pcb120", "mscc,ocelot"; +}; diff --git a/arch/mips/dts/ocelot_pcb123.dts b/arch/mips/dts/ocelot_pcb123.dts new file mode 100644 index 0000000000..17d8d326ce --- /dev/null +++ b/arch/mips/dts/ocelot_pcb123.dts @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +/dts-v1/; +#include "mscc,ocelot_pcb.dtsi" + +/ { + model = "Ocelot PCB123 Reference Board"; + compatible = "mscc,ocelot-pcb123", "mscc,ocelot"; +}; diff --git a/arch/mips/mach-mscc/Kconfig b/arch/mips/mach-mscc/Kconfig index a8cace0e79..fc806fc1f3 100644 --- a/arch/mips/mach-mscc/Kconfig +++ b/arch/mips/mach-mscc/Kconfig @@ -79,4 +79,6 @@ config DDRTYPE_MT47H128M8HQ
endchoice
+source "board/mscc/ocelot/Kconfig" + endmenu diff --git a/board/mscc/ocelot/Kconfig b/board/mscc/ocelot/Kconfig new file mode 100644 index 0000000000..9ddc0880b1 --- /dev/null +++ b/board/mscc/ocelot/Kconfig @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +config SYS_VENDOR + default "mscc" + +if SOC_OCELOT + +config SYS_BOARD + default "ocelot" + +config SYS_CONFIG_NAME + default "ocelot" + +endif diff --git a/board/mscc/ocelot/Makefile b/board/mscc/ocelot/Makefile new file mode 100644 index 0000000000..9f28c81268 --- /dev/null +++ b/board/mscc/ocelot/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +obj-$(CONFIG_SOC_OCELOT) := ocelot.o + diff --git a/board/mscc/ocelot/ocelot.c b/board/mscc/ocelot/ocelot.c new file mode 100644 index 0000000000..d521a61957 --- /dev/null +++ b/board/mscc/ocelot/ocelot.c @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <environment.h> +#include <spi.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define MSCC_GPIO_ALT0 0x54 +#define MSCC_GPIO_ALT1 0x58 + +void external_cs_manage(struct udevice *dev, bool enable) +{ + u32 cs = spi_chip_select(dev); + /* IF_SI0_OWNER, select the owner of the SI interface + * Encoding: 0: SI Slave + * 1: SI Boot Master + * 2: SI Master Controller + */ + if (!enable) { + writel(ICPU_SW_MODE_SW_PIN_CTRL_MODE | + ICPU_SW_MODE_SW_SPI_CS(BIT(cs)), BASE_CFG + ICPU_SW_MODE); + clrsetbits_le32(BASE_CFG + ICPU_GENERAL_CTRL, + ICPU_GENERAL_CTRL_IF_SI_OWNER_M, + ICPU_GENERAL_CTRL_IF_SI_OWNER(2)); + } else { + writel(0, BASE_CFG + ICPU_SW_MODE); + clrsetbits_le32(BASE_CFG + ICPU_GENERAL_CTRL, + ICPU_GENERAL_CTRL_IF_SI_OWNER_M, + ICPU_GENERAL_CTRL_IF_SI_OWNER(1)); + } +} + +void board_debug_uart_init(void) +{ + /* too early for the pinctrl driver, so configure the UART pins here */ + setbits_le32(BASE_DEVCPU_GCB + MSCC_GPIO_ALT0, BIT(6) | BIT(7)); + clrbits_le32(BASE_DEVCPU_GCB + MSCC_GPIO_ALT1, BIT(6) | BIT(7)); +} + +int board_early_init_r(void) +{ + /* Prepare SPI controller to be used in master mode */ + writel(0, BASE_CFG + ICPU_SW_MODE); + clrsetbits_le32(BASE_CFG + ICPU_GENERAL_CTRL, + ICPU_GENERAL_CTRL_IF_SI_OWNER_M, + ICPU_GENERAL_CTRL_IF_SI_OWNER(2)); + + /* Address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE; + return 0; +} diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig new file mode 100644 index 0000000000..6de047a8de --- /dev/null +++ b/configs/mscc_ocelot_defconfig @@ -0,0 +1,73 @@ +CONFIG_MIPS=y +CONFIG_SYS_TEXT_BASE=0x40000000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_BASE=0x70100000 +CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_ARCH_MSCC=y +CONFIG_TARGET_OCELOT_PCB123=y +CONFIG_SYS_LITTLE_ENDIAN=y +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200" +CONFIG_LOGLEVEL=7 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_SYS_PROMPT="pcb123 # " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_MD5SUM=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_MTD=y +CONFIG_CMD_UBI=y +# CONFIG_CMD_UBIFS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_DHCP=y +# CONFIG_NET_TFTP_VARS is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi_flash:512k(UBoot),256k(Env),256k(conf),15m(linux),15m(linux.bk)" +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_EMBED=y +CONFIG_DEFAULT_DEVICE_TREE="ocelot_pcb123" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_DM_GPIO=y +CONFIG_MTD_PARTITIONS=y +CONFIG_MTD=y +CONFIG_MTD_NAND_CORE=y +CONFIG_MTD_SPI_NAND=y +CONFIG_MTD_UBI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +CONFIG_PINCONF=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_SPI_MEM=y +CONFIG_DESIGNWARE_SPI=y +CONFIG_LZMA=y diff --git a/configs/mscc_ocelot_pcb120_defconfig b/configs/mscc_ocelot_pcb120_defconfig new file mode 100644 index 0000000000..3ba7ea91f9 --- /dev/null +++ b/configs/mscc_ocelot_pcb120_defconfig @@ -0,0 +1,66 @@ +CONFIG_MIPS=y +CONFIG_SYS_TEXT_BASE=0x40000000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ARCH_MSCC=y +CONFIG_SYS_LITTLE_ENDIAN=y +CONFIG_DEFAULT_DEVICE_TREE="ocelot_pcb120" +CONFIG_FIT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200" +CONFIG_LOGLEVEL=7 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_SYS_PROMPT="pcb120 # " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_MD5SUM=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_MTD=y +CONFIG_CMD_UBI=y +# CONFIG_CMD_UBIFS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_DHCP=y +# CONFIG_NET_TFTP_VARS is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi_flash:512k(UBoot),256k(Env),256k(conf),15m(linux),15m(linux.bk)" +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_DM_GPIO=y +CONFIG_MTD_PARTITIONS=y +CONFIG_MTD=y +CONFIG_MTD_NAND_CORE=y +CONFIG_MTD_SPI_NAND=y +CONFIG_MTD_UBI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +CONFIG_PINCONF=y +CONFIG_DM_SERIAL=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_SPI_MEM=y +CONFIG_DESIGNWARE_SPI=y +CONFIG_LZMA=y diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h new file mode 100644 index 0000000000..df89cdaebf --- /dev/null +++ b/include/configs/vcoreiii.h @@ -0,0 +1,82 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#ifndef __VCOREIII_H +#define __VCOREIII_H + +#include <linux/sizes.h> + +/* Onboard devices */ + +#define CONFIG_SYS_MALLOC_LEN 0x100000 +#define CONFIG_SYS_LOAD_ADDR 0x00100000 +#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 + +#define CPU_CLOCK_RATE 500000000 /* Clock for the MIPS core */ +#ifdef CONFIG_SOC_LUTON +#define CONFIG_SYS_MIPS_TIMER_FREQ 208333333 +#else +#define CONFIG_SYS_MIPS_TIMER_FREQ (CPU_CLOCK_RATE / 2) +#endif +#define CONFIG_SYS_NS16550_CLK CONFIG_SYS_MIPS_TIMER_FREQ + +#if defined(CONFIG_ENV_IS_IN_SPI_FLASH) && !defined(CONFIG_ENV_OFFSET) +#define CONFIG_ENV_OFFSET (1024 * 1024) +#define CONFIG_ENV_SIZE (256 * 1024) +#define CONFIG_ENV_SECT_SIZE (256 * 1024) + +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE) + +#define CONFIG_ENV_SPI_MAX_HZ 0 /* This force to read from DT */ +#define CONFIG_ENV_SPI_MODE 0 /* This force to read from DT */ +#endif + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#if defined(CONFIG_DDRTYPE_H5TQ1G63BFA) || defined(CONFIG_DDRTYPE_MT47H128M8HQ) +#define CONFIG_SYS_SDRAM_SIZE (128 * SZ_1M) +#elif defined(CONFIG_DDRTYPE_MT41J128M16HA) || defined(CONFIG_DDRTYPE_MT41K128M16JT) +#define CONFIG_SYS_SDRAM_SIZE (256 * SZ_1M) +#elif defined(CONFIG_DDRTYPE_H5TQ4G63MFR) || defined(CONFIG_DDRTYPE_MT41K256M16) +#define CONFIG_SYS_SDRAM_SIZE (512 * SZ_1M) +#else +#error Unknown DDR size - please add! +#endif + +#define CONFIG_CONS_INDEX 1 + +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_SDRAM_SIZE - SZ_1M) + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_BOARD_EARLY_INIT_R +#if defined(CONFIG_MTDIDS_DEFAULT) && defined(CONFIG_MTDPARTS_DEFAULT) +#define VCOREIII_DEFAULT_MTD_ENV \ + "mtdparts="CONFIG_MTDPARTS_DEFAULT"\0" \ + "mtdids="CONFIG_MTDIDS_DEFAULT"\0" +#else +#define VCOREIII_DEFAULT_MTD_ENV /* Go away */ +#endif + +#define CONFIG_SYS_BOOTM_LEN (16 << 20) /* Increase max gunzip size */ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + VCOREIII_DEFAULT_MTD_ENV \ + "loadaddr=0x81000000\0" \ + "spi_image_off=0x00100000\0" \ + "console=ttyS0,115200\0" \ + "setup=setenv bootargs console=${console} ${mtdparts}" \ + "${bootargs_extra}\0" \ + "spiboot=run setup; sf probe; sf read ${loadaddr}" \ + "${spi_image_off} 0x600000; bootm ${loadaddr}\0" \ + "ubootfile=u-boot.bin\0" \ + "update=sf probe;mtdparts;dhcp ${loadaddr} ${ubootfile};" \ + "sf erase UBoot 0x100000;" \ + "sf write ${loadaddr} UBoot ${filesize}\0" \ + "bootcmd=run spiboot\0" \ + "" +#endif /* __VCOREIII_H */
Adding the support for the Luton boards PCB91 which share common code with the Ocelots boards, including board code, device tree and configuration.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- MAINTAINERS | 1 + arch/mips/dts/luton_pcb091.dts | 36 ++++++++++++++ arch/mips/dts/mscc,luton.dtsi | 87 ++++++++++++++++++++++++++++++++++ arch/mips/mach-mscc/Kconfig | 2 + board/mscc/luton/Kconfig | 14 ++++++ board/mscc/luton/Makefile | 3 ++ board/mscc/luton/luton.c | 28 +++++++++++ configs/mscc_luton_defconfig | 66 ++++++++++++++++++++++++++ 8 files changed, 237 insertions(+) create mode 100644 arch/mips/dts/luton_pcb091.dts create mode 100644 arch/mips/dts/mscc,luton.dtsi create mode 100644 board/mscc/luton/Kconfig create mode 100644 board/mscc/luton/Makefile create mode 100644 board/mscc/luton/luton.c create mode 100644 configs/mscc_luton_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index c906ca006b..4ce19aef11 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -490,6 +490,7 @@ M: Lars Povlsen lars.povlsen@microchip.com M: Horatiu Vultur horatiu.vultur@microchip.com S: Maintained F: arch/mips/mach-mscc/ +F: arch/mips/dts/luton* F: arch/mips/dts/mscc* F: arch/mips/dts/ocelot* F: board/mscc/ diff --git a/arch/mips/dts/luton_pcb091.dts b/arch/mips/dts/luton_pcb091.dts new file mode 100644 index 0000000000..74f9274c21 --- /dev/null +++ b/arch/mips/dts/luton_pcb091.dts @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +/dts-v1/; +#include "mscc,luton.dtsi" + +/ { + model = "Luton10 PCB091 Reference Board"; + compatible = "mscc,luton-pcb091", "mscc,luton"; + + aliases { + serial0 = &uart0; + spi0 = &spi0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&uart0 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + spi-flash@0 { + compatible = "spi-flash"; + spi-max-frequency = <18000000>; /* input clock */ + reg = <0>; /* CS0 */ + spi-cs-high; + }; +}; + diff --git a/arch/mips/dts/mscc,luton.dtsi b/arch/mips/dts/mscc,luton.dtsi new file mode 100644 index 0000000000..6a4ad2a5be --- /dev/null +++ b/arch/mips/dts/mscc,luton.dtsi @@ -0,0 +1,87 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <dt-bindings/gpio/gpio.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mscc,luton"; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "mips,mips24KEc"; + device_type = "cpu"; + reg = <0>; + }; + }; + + aliases { + serial0 = &uart0; + }; + + ahb_clk: ahb-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <208333333>; + }; + + ahb { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x60000000 0x10200000>; + + uart0: serial@10100000 { + pinctrl-0 = <&uart_pins>; + pinctrl-names = "default"; + + compatible = "ns16550a"; + reg = <0x10100000 0x20>; + clocks = <&ahb_clk>; + reg-io-width = <4>; + reg-shift = <2>; + + status = "disabled"; + }; + + gpio: pinctrl@70068 { + compatible = "mscc,luton-pinctrl"; + reg = <0x70068 0x68>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&gpio 0 0 32>; + + uart_pins: uart-pins { + pins = "GPIO_30", "GPIO_31"; + function = "uart"; + }; + + }; + + gpio_spi_bitbang: gpio@10000064 { + compatible = "mscc,spi-bitbang-gpio"; + reg = <0x10000064 0x4>; + gpio-controller; + #gpio-cells = <2>; + + }; + + spi0: spi-bitbang { + compatible = "spi-gpio"; + status = "okay"; + gpio-sck = <&gpio_spi_bitbang 6 0>; + gpio-miso = <&gpio_spi_bitbang 0 0>; + gpio-mosi = <&gpio_spi_bitbang 5 0>; + cs-gpios = <&gpio_spi_bitbang 1 0>; + num-chipselects = <1>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; +}; diff --git a/arch/mips/mach-mscc/Kconfig b/arch/mips/mach-mscc/Kconfig index fc806fc1f3..0e35b77c9d 100644 --- a/arch/mips/mach-mscc/Kconfig +++ b/arch/mips/mach-mscc/Kconfig @@ -81,4 +81,6 @@ endchoice
+source "board/mscc/luton/Kconfig" + endmenu diff --git a/board/mscc/luton/Kconfig b/board/mscc/luton/Kconfig new file mode 100644 index 0000000000..e1199808d5 --- /dev/null +++ b/board/mscc/luton/Kconfig @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +if SOC_LUTON + +config SYS_VENDOR + default "mscc" + +config SYS_BOARD + default "luton" + +config SYS_CONFIG_NAME + default "luton" + +endif diff --git a/board/mscc/luton/Makefile b/board/mscc/luton/Makefile new file mode 100644 index 0000000000..b27f7c7739 --- /dev/null +++ b/board/mscc/luton/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +obj-$(CONFIG_SOC_LUTON) := luton.o diff --git a/board/mscc/luton/luton.c b/board/mscc/luton/luton.c new file mode 100644 index 0000000000..41fc6d56a7 --- /dev/null +++ b/board/mscc/luton/luton.c @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <common.h> +#include <asm/io.h> + +#define MSCC_GPIO_ALT0 0x88 +#define MSCC_GPIO_ALT1 0x8C + +DECLARE_GLOBAL_DATA_PTR; + +void board_debug_uart_init(void) +{ + /* too early for the pinctrl driver, so configure the UART pins here */ + setbits_le32(BASE_DEVCPU_GCB + MSCC_GPIO_ALT0, BIT(30) | BIT(31)); +} + +int board_early_init_r(void) +{ + /* Prepare SPI controller to be used in master mode */ + writel(0, BASE_CFG + ICPU_SW_MODE); + + /* Address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE; + return 0; +} diff --git a/configs/mscc_luton_defconfig b/configs/mscc_luton_defconfig new file mode 100644 index 0000000000..47fe12b6ee --- /dev/null +++ b/configs/mscc_luton_defconfig @@ -0,0 +1,66 @@ +CONFIG_MIPS=y +CONFIG_SYS_TEXT_BASE=0x40000000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_BASE=0x70100000 +CONFIG_DEBUG_UART_CLOCK=208333333 +CONFIG_ARCH_MSCC=y +CONFIG_TARGET_LUTON_PCB091=y +CONFIG_DDRTYPE_MT47H128M8HQ=y +CONFIG_SYS_LITTLE_ENDIAN=y +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEFAULT_DEVICE_TREE="luton_pcb091" +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200" +CONFIG_LOGLEVEL=7 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_SYS_PROMPT="pcb091 # " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_MD5SUM=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_DHCP=y +# CONFIG_NET_TFTP_VARS is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi_flash:512k(UBoot),256k(Env),256k(conf),6m@1m(linux)" +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_CLK=y +CONFIG_DM_GPIO=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +CONFIG_PINCONF=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_SOFT_SPI=y +CONFIG_LZMA=y +CONFIG_XZ=y
Am 14.12.18 um 16:16 schrieb Gregory CLEMENT:
this gives now a build warning
===================== WARNING ====================== CONFIG_OF_EMBED is enabled. This option should only be used for debugging purposes. Please use CONFIG_OF_SEPARATE for boards in mainline. See doc/README.fdt-control for more info. ====================================================
Shall I change it when applying or do you want to test it first and send a follow-up patch?
Hi Daniel,
On sam., déc. 15 2018, Daniel Schwierzeck daniel.schwierzeck@gmail.com wrote:
I did not get this warning. For now I base my series on v2018.11, should I base it on v2019.01-rc1 (i didn't realized it was already released) ?
I'd like to test it to be sure it continue to work.
Thanks,
Gregory
- Daniel
Hi Daniel,
On dim., déc. 16 2018, Gregory CLEMENT gregory.clement@bootlin.com wrote:
Hi Daniel,
I had a closer look on this issue and actually we have already a patch series to apply which it is planned to be sent very soon. With this new series we will be able to support multiple boards with this series CONFIG_OF_SEPARATE will be used instead of CONFIG_OF_EMBED.
Would it be possible to keep this series as is ?
Thanks,
Gregory
Thanks,
Gregory
- Daniel
-- Gregory Clement, Bootlin Embedded Linux and Kernel engineering http://bootlin.com _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Am 17.12.18 um 10:55 schrieb Gregory CLEMENT:
Hi Daniel,
Hi Daniel,
I asked because I had to fix some minor merge conflicts when applying and I had to re-sync the defconfig files due to various changes in mainline. Thus I need to update your patches anyway and a simply removing CONFIG_OF_EMBED=y would be a trivial fix.
You can review the current patch queue at u-boot-mips/microsemi which is based on u-boot-mips/next.
Hi Daniel,
On lun., déc. 17 2018, Daniel Schwierzeck daniel.schwierzeck@gmail.com wrote:
Hi Daniel,
Hi Daniel,
I tested you branch and it worked on both Ocelot and Luton. So I'm fine with your changes.
Thanks !
Gregory
- Daniel
The kernels built to be launch by redboot (such as the Vcore III) have different expectation in the way the data were passed.
Unlike with yamon, the command line is expected to be a single string passed in argv[1]. An other expectation is that the arguments are located in the cached address space.
However, like yamon, they expect that rd_start and rd_size was passed by the bootloader in the command line of the kernel.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- arch/mips/Kconfig | 4 +++ arch/mips/lib/bootm.c | 76 +++++++++++++++++++++++++++++++------------ 2 files changed, 60 insertions(+), 20 deletions(-)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index bfe9c11069..eae5cb0f99 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -63,6 +63,7 @@ config ARCH_MSCC bool "Support MSCC VCore-III" select OF_CONTROL select DM + select MIPS_BOOT_CMDLINE_SINGLESTRING
config ARCH_BMIPS bool "Support BMIPS SoCs" @@ -466,6 +467,9 @@ config MIPS_BOOT_CONFIG_WORD1 help Value which is inserted as boot config word 1.
+config MIPS_BOOT_CMDLINE_SINGLESTRING + bool + endif
endmenu diff --git a/arch/mips/lib/bootm.c b/arch/mips/lib/bootm.c index deca5189e3..38243cfa92 100644 --- a/arch/mips/lib/bootm.c +++ b/arch/mips/lib/bootm.c @@ -15,6 +15,11 @@ DECLARE_GLOBAL_DATA_PTR; #define LINUX_MAX_ENVS 256 #define LINUX_MAX_ARGS 256
+enum legacy_boot_type { + LEGACY_BOOT_YAML, + LEGACY_BOOT_CMDLINE_SINGLESTRING, +}; + static int linux_argc; static char **linux_argv; static char *linux_argp; @@ -44,22 +49,47 @@ void arch_lmb_reserve(struct lmb *lmb) lmb_reserve(lmb, sp, gd->ram_top - sp); }
-static void linux_cmdline_init(void) +static void linux_cmdline_init(enum legacy_boot_type boot_type) { + switch (boot_type) { + /* + * Vcore III linux kernels expect arguments in the cached + * address space. They also expect the command line being a + * single string in the first argument + */ + case LEGACY_BOOT_CMDLINE_SINGLESTRING: + linux_argv = (char **)(gd->bd->bi_boot_params); + linux_argp = (char *)(linux_argv + LINUX_MAX_ARGS); + linux_argv[1] = linux_argp; + break; + case LEGACY_BOOT_YAML: + /* fall-through */ + default: + linux_argv = (char **)UNCACHED_SDRAM(gd->bd->bi_boot_params); + linux_argp = (char *)(linux_argv + LINUX_MAX_ARGS); + } linux_argc = 1; - linux_argv = (char **)UNCACHED_SDRAM(gd->bd->bi_boot_params); linux_argv[0] = 0; - linux_argp = (char *)(linux_argv + LINUX_MAX_ARGS); }
-static void linux_cmdline_set(const char *value, size_t len) +static void linux_cmdline_set(const char *value, size_t len, + enum legacy_boot_type boot_type) { - linux_argv[linux_argc] = linux_argp; memcpy(linux_argp, value, len); - linux_argp[len] = 0; - + switch (boot_type) { + case LEGACY_BOOT_CMDLINE_SINGLESTRING: + linux_argv[linux_argc] = linux_argp; + linux_argp[len] = 0; + linux_argc++; + break; + case LEGACY_BOOT_YAML: + /* fall-through */ + default: + linux_argp[len] = ' '; + linux_argp[len + 1] = 0; + linux_argc = 2; + } linux_argp += len + 1; - linux_argc++; }
static void linux_cmdline_dump(void) @@ -73,12 +103,11 @@ static void linux_cmdline_dump(void) debug(" arg %03d: %s\n", i, linux_argv[i]); }
-static void linux_cmdline_legacy(bootm_headers_t *images) +static void linux_cmdline_legacy(bootm_headers_t *images, + enum legacy_boot_type boot_type) { const char *bootargs, *next, *quote; - - linux_cmdline_init(); - + linux_cmdline_init(boot_type); bootargs = env_get("bootargs"); if (!bootargs) return; @@ -104,7 +133,7 @@ static void linux_cmdline_legacy(bootm_headers_t *images) if (!next) next = bootargs + strlen(bootargs);
- linux_cmdline_set(bootargs, next - bootargs); + linux_cmdline_set(bootargs, next - bootargs, boot_type);
if (*next) next++; @@ -113,7 +142,8 @@ static void linux_cmdline_legacy(bootm_headers_t *images) } }
-static void linux_cmdline_append(bootm_headers_t *images) +static void linux_cmdline_append(bootm_headers_t *images, + enum legacy_boot_type boot_type) { char buf[24]; ulong mem, rd_start, rd_size; @@ -121,7 +151,7 @@ static void linux_cmdline_append(bootm_headers_t *images) /* append mem */ mem = gd->ram_size >> 20; sprintf(buf, "mem=%luM", mem); - linux_cmdline_set(buf, strlen(buf)); + linux_cmdline_set(buf, strlen(buf), boot_type);
/* append rd_start and rd_size */ rd_start = images->initrd_start; @@ -129,9 +159,9 @@ static void linux_cmdline_append(bootm_headers_t *images)
if (rd_size) { sprintf(buf, "rd_start=0x%08lX", rd_start); - linux_cmdline_set(buf, strlen(buf)); + linux_cmdline_set(buf, strlen(buf), boot_type); sprintf(buf, "rd_size=0x%lX", rd_size); - linux_cmdline_set(buf, strlen(buf)); + linux_cmdline_set(buf, strlen(buf), boot_type); } }
@@ -276,11 +306,17 @@ static void boot_prep_linux(bootm_headers_t *images) boot_reloc_fdt(images); boot_setup_fdt(images); } else { - if (CONFIG_IS_ENABLED(MIPS_BOOT_CMDLINE_LEGACY)) { - linux_cmdline_legacy(images); + if (CONFIG_IS_ENABLED(MIPS_BOOT_CMDLINE_SINGLESTRING)) { + linux_cmdline_legacy(images, + LEGACY_BOOT_CMDLINE_SINGLESTRING); + linux_cmdline_append(images, + LEGACY_BOOT_CMDLINE_SINGLESTRING); + linux_cmdline_dump(); + } else if (CONFIG_IS_ENABLED(MIPS_BOOT_CMDLINE_LEGACY)) { + linux_cmdline_legacy(images, 0);
if (!CONFIG_IS_ENABLED(MIPS_BOOT_ENV_LEGACY)) - linux_cmdline_append(images); + linux_cmdline_append(images, LEGACY_BOOT_YAML);
linux_cmdline_dump(); }
Hello,
For the record this the fourth version of the series adding the support of 2 SoCs: Ocelot and Luton from Microsemi. Both of them belongs to the same family Vcore III.
We found them on various advanced switches product.
The support for Ocelot already have been submit to Linux, but not yet the Luton support.
The comments on v3 were fewer and quite easy to address, so I am able to send a new version right one (hopping it will be the final one :) ).
Gregory
Changelog:
v3 -> v4:
- add the support for the legacy kernel more generic and more related to the old bootloader: redboot
- removed useless test on CONFIG_ARCH_MSCC in arch/mips/mach-mscc/include/ioremap.h
- add an explanation about the cache instruction lock in hal_vcoreiii_ddr_failed()
- use __raw_read/write instead of directly use pointer dereferencing
- use rmb instead of asm volatile("" : : : "memory");
- remove remaining C++ style comment
- use __maybe_unused instead of __attribute__ ((unused))
- indent by an extra space the instructions in the delay slot
v2 -> v3:
- Added n entry in the MAINTAINER file for the SoCs
- Fixup the last errors from checkpatch, the remaining ones are only about volatile, long line and Kconfig, but each ones have good reason to be here.
- Add SPI NAND flash support in device tree and configuration files, the driver are already be merged in U-Boot.
- In order to improve boot time, setup the TLB to allow using cache in the memory mapped to the SPI NOR.
- Removed all the macro REG_CFG to only keep direct access to memory.
- Put back the setting of the interrupt map as it is needed by mainline kernel (without it the kernel doesn't finish to boot)
- During DDR training, prevent the compiler reordering the instruction.
- Add early debug support to Ocelot (it was already done for Luton)
v1 -> v2:
- a big clean-up for indentation and some style issue
- usage of the clrsetbits family functions where it was possible
- split the patches for Ocelot and Luton
- add a new patch to introduce the icache_lock function which was in the mscc directory in the first version
- remove more unused define in the platform header files
- use the automatic cache size detection instead of hard coding it
- reduce the tlb init to only two entries for the IO as needed by the kernel
- remove the interrupt disabling
- fix the ddr init for luton
Gregory CLEMENT (7): MIPS: move create_tlb() in an proper header: mipsregs.h MIPS: Allow to prefetch and lock instructions into cache MSCC: add support for Ocelot SoCs MSCC: add support for Luton SoCs MSCC: add board support for the Ocelots based evaluation boards MSCC: add board support for the Luton based evaluation board MIPS: bootm: Add support for compatibility with redboot
MAINTAINERS | 13 + arch/mips/Kconfig | 10 + arch/mips/Makefile | 1 + arch/mips/cpu/cpu.c | 10 - arch/mips/dts/luton_pcb091.dts | 36 + arch/mips/dts/mscc,luton.dtsi | 87 ++ arch/mips/dts/mscc,ocelot.dtsi | 152 ++++ arch/mips/dts/mscc,ocelot_pcb.dtsi | 42 + arch/mips/dts/ocelot_pcb120.dts | 12 + arch/mips/dts/ocelot_pcb123.dts | 12 + arch/mips/include/asm/cacheops.h | 19 + arch/mips/include/asm/mipsregs.h | 11 + arch/mips/lib/bootm.c | 76 +- arch/mips/mach-mscc/Kconfig | 86 ++ arch/mips/mach-mscc/Makefile | 6 + arch/mips/mach-mscc/cpu.c | 102 +++ arch/mips/mach-mscc/dram.c | 73 ++ arch/mips/mach-mscc/include/ioremap.h | 49 ++ arch/mips/mach-mscc/include/mach/common.h | 28 + arch/mips/mach-mscc/include/mach/ddr.h | 814 ++++++++++++++++++ .../mips/mach-mscc/include/mach/luton/luton.h | 24 + .../include/mach/luton/luton_devcpu_gcb.h | 14 + .../include/mach/luton/luton_icpu_cfg.h | 245 ++++++ .../mach-mscc/include/mach/ocelot/ocelot.h | 24 + .../include/mach/ocelot/ocelot_devcpu_gcb.h | 21 + .../include/mach/ocelot/ocelot_icpu_cfg.h | 274 ++++++ arch/mips/mach-mscc/include/mach/tlb.h | 55 ++ arch/mips/mach-mscc/lowlevel_init.S | 30 + arch/mips/mach-mscc/lowlevel_init_luton.S | 62 ++ arch/mips/mach-mscc/reset.c | 30 + board/mscc/luton/Kconfig | 14 + board/mscc/luton/Makefile | 3 + board/mscc/luton/luton.c | 28 + board/mscc/ocelot/Kconfig | 14 + board/mscc/ocelot/Makefile | 4 + board/mscc/ocelot/ocelot.c | 58 ++ configs/mscc_luton_defconfig | 66 ++ configs/mscc_ocelot_defconfig | 73 ++ configs/mscc_ocelot_pcb120_defconfig | 66 ++ include/configs/vcoreiii.h | 82 ++ 40 files changed, 2796 insertions(+), 30 deletions(-) create mode 100644 arch/mips/dts/luton_pcb091.dts create mode 100644 arch/mips/dts/mscc,luton.dtsi create mode 100644 arch/mips/dts/mscc,ocelot.dtsi create mode 100644 arch/mips/dts/mscc,ocelot_pcb.dtsi create mode 100644 arch/mips/dts/ocelot_pcb120.dts create mode 100644 arch/mips/dts/ocelot_pcb123.dts create mode 100644 arch/mips/mach-mscc/Kconfig create mode 100644 arch/mips/mach-mscc/Makefile create mode 100644 arch/mips/mach-mscc/cpu.c create mode 100644 arch/mips/mach-mscc/dram.c create mode 100644 arch/mips/mach-mscc/include/ioremap.h create mode 100644 arch/mips/mach-mscc/include/mach/common.h create mode 100644 arch/mips/mach-mscc/include/mach/ddr.h create mode 100644 arch/mips/mach-mscc/include/mach/luton/luton.h create mode 100644 arch/mips/mach-mscc/include/mach/luton/luton_devcpu_gcb.h create mode 100644 arch/mips/mach-mscc/include/mach/luton/luton_icpu_cfg.h create mode 100644 arch/mips/mach-mscc/include/mach/ocelot/ocelot.h create mode 100644 arch/mips/mach-mscc/include/mach/ocelot/ocelot_devcpu_gcb.h create mode 100644 arch/mips/mach-mscc/include/mach/ocelot/ocelot_icpu_cfg.h create mode 100644 arch/mips/mach-mscc/include/mach/tlb.h create mode 100644 arch/mips/mach-mscc/lowlevel_init.S create mode 100644 arch/mips/mach-mscc/lowlevel_init_luton.S create mode 100644 arch/mips/mach-mscc/reset.c create mode 100644 board/mscc/luton/Kconfig create mode 100644 board/mscc/luton/Makefile create mode 100644 board/mscc/luton/luton.c create mode 100644 board/mscc/ocelot/Kconfig create mode 100644 board/mscc/ocelot/Makefile create mode 100644 board/mscc/ocelot/ocelot.c create mode 100644 configs/mscc_luton_defconfig create mode 100644 configs/mscc_ocelot_defconfig create mode 100644 configs/mscc_ocelot_pcb120_defconfig create mode 100644 include/configs/vcoreiii.h
series applied to u-boot-mips, thanks.
I left out the last patch to avoid patching generic code at this point of the 2019.01 release cycle. Also I'm still not happy with it, some further comments will follow.
As discussed I did a resync of the defconfig files and removed CONFIG_OF_EMBED.
Daniel Schwierzeck
Gregory CLEMENT
