[U-Boot] [PATCH 1/2] ARM: mxs: Enable DCDC converter for battery boot
In case the board detected sufficient voltage for battery boot, make sure the DCDC converter is ON and the board is not running only from linregs, otherwise an instability will be observed.
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/arm926ejs/mxs/spl_power_init.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c index 8ea45be..d25019a 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c @@ -654,6 +654,8 @@ static void mxs_batt_boot(void) clrsetbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_CHARGE_4P2_ILIMIT_MASK, 0x8 << POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET); + + mxs_power_enable_4p2(); }
The BG0900 module has 2Gbit DRAM module on it, adjust the DataBahn DRAM controller registers so the DRAM module will be correctly recognised.
Signed-off-by: Christoph G. Baumann c.baumann@ppc-ag.de Cc: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com --- board/ppcag/bg0900/spl_boot.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/board/ppcag/bg0900/spl_boot.c b/board/ppcag/bg0900/spl_boot.c index 2616e1f..a04c955 100644 --- a/board/ppcag/bg0900/spl_boot.c +++ b/board/ppcag/bg0900/spl_boot.c @@ -118,6 +118,19 @@ const iomux_cfg_t iomux_setup[] = {
void mxs_adjust_memory_params(uint32_t *dram_vals) { + /* + * DDR Controller Registers + * Manufacturer: Winbond + * Device Part Number: W972GG6JB-25I + * Clock Freq.: 200MHz + * Density: 2Gb + * Chip Selects: 1 + * Number of Banks: 8 + * Row address: 14 + * Column address: 10 + */ + + dram_vals[0x74 / 4] = 0x0102010A; dram_vals[0x98 / 4] = 0x04005003; dram_vals[0x9c / 4] = 0x090000c8;
Best regards, Stefano Babic
Hi Marek,
Shouldn't this be conditional?
#if defined CONFIG_MXS_ENABLE_4P2 mxs_power_enable_4p2(); #endif
Then the boards that need this power supply enable CONFIG_MXS_ENABLE_4P2 in its config file.
Regards,
Fabio Estevam
Dear Fabio Estevam,
Hi Marek,
No, we want to start the DCDC converter unconditionally when running on battery power to increase efficiency.
Best regards, Marek Vasut
Hi Marek, and Fabio
battery
I just stumbled upon this, because our board does not boot reliably any more with this change. Perhaps we have a special situation in that our board is powered via DCDC_BATT only by an external power source (no battery).
I am currently working on creating a patch to only conditionally enabling this feature, or to enable it by default and have it conditionally be disabled for boards that are known to have problems with this.
Which approach seems to be more feasible to you?
Regards Michael
Hi Michael,
On Thu, Oct 23, 2014 at 5:07 AM, Michael Thalmeier michael.thalmeier@hale.at wrote:
Hi Marek, and Fabio
battery
Initially I proposed something like:
,but Marek was not happy about it, so let's wait for his thoughts. Marek?
Regards,
Fabio Estevam
On Saturday, October 25, 2014 at 11:43:05 PM, Fabio Estevam wrote:
Hi Michael,
Hi Marek, and Fabio
battery
Can you share the schematic of your power distribution network ? I would like to check a couple of things in there. I suspect there is a common problem with MX23 and MX28 based designs discovered by Juha and I'd like to make sure you don't suffer from it.
It's OK to send the schematic off-list.
Thanks!
Fabio Estevam
Michael Thalmeier
Stefano Babic
