[U-Boot] [PATCH] board_f: Do not mark pre-relocated fdt space as reserved
SPL while copying u-boot and dtb it does the following: - Copy u-boot - Copy right dtb. - mark dtb location as reserved in dtb.
U-Boot when copying images at U-Boot prompt, is not able to copy to the above dtb location as it sees the region as reserved. But at this stage dtb is re located to end of DDR. And the above dtb region is not reserved anymore. So delete this reserved region when re locating dtb.
Reported-by: Keerthy j-keerthy@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- common/board_f.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/common/board_f.c b/common/board_f.c index 149a7229e8..e4383ae3fa 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -651,10 +651,23 @@ static int init_post(void) static int reloc_fdt(void) { #ifndef CONFIG_OF_EMBED + uint64_t addr, size; + int i, cnt, err; + if (gd->flags & GD_FLG_SKIP_RELOC) return 0; if (gd->new_fdt) { memcpy(gd->new_fdt, gd->fdt_blob, gd->fdt_size); + + /* Deleting the previously marked FDT reserved region */ + cnt = fdt_num_mem_rsv(gd->new_fdt); + for (i = 0; i < cnt ; i++) { + err = fdt_get_mem_rsv(gd->new_fdt, i, &addr, &size); + if (!err && addr == (uintptr_t)gd->fdt_blob) { + fdt_del_mem_rsv(gd->new_fdt, i); + break; + } + } gd->fdt_blob = gd->new_fdt; } #endif
[This is a follow-up to https://patchwork.ozlabs.org/patch/1033584/ right?]
Am 16.04.2019 um 10:43 schrieb Lokesh Vutla:
- Copy u-boot
- Copy right dtb.
Hmm, why does it do that? Reserving space when U-Boot starts Linux *might* make sense, but why should SPL add this reservation when starting U-Boot? These steps are for U-Boot in a fit-image, right? Because I can't see this for U-Boot as uImage.
Am I correct that 'fdt_shrink_to_minimum()' adds this reservation? The name of that function doesn't suggest that to me. Would it make more sense to let this funtion only *change* the reservation, i.e. only add it if it is removed at the beginning of said function? Would that fix your issue?
Something like this:
diff --git a/common/fdt_support.c b/common/fdt_support.c index ab08a0114f..4e7cf6ebe9 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -597,6 +597,7 @@ int fdt_shrink_to_minimum(void *blob, uint extrasize) uint64_t addr, size; int total, ret; uint actualsize; + int fdt_memrsv = 0;
if (!blob) return 0; @@ -606,6 +607,7 @@ int fdt_shrink_to_minimum(void *blob, uint extrasize) fdt_get_mem_rsv(blob, i, &addr, &size); if (addr == (uintptr_t)blob) { fdt_del_mem_rsv(blob, i); + fdt_memrsv = 1; break; } } @@ -627,10 +629,12 @@ int fdt_shrink_to_minimum(void *blob, uint extrasize) /* Change the fdt header to reflect the correct size */ fdt_set_totalsize(blob, actualsize);
- /* Add the new reservation */ - ret = fdt_add_mem_rsv(blob, map_to_sysmem(blob), actualsize); - if (ret < 0) - return ret; + if (fdt_memrsv) { + /* Add the new reservation */ + ret = fdt_add_mem_rsv(blob, map_to_sysmem(blob), actualsize); + if (ret < 0) + return ret; + }
return actualsize; }
- uint64_t addr, size;
- int i, cnt, err;
- if (gd->flags & GD_FLG_SKIP_RELOC) return 0; if (gd->new_fdt) { memcpy(gd->new_fdt, gd->fdt_blob, gd->fdt_size);
break;
That code should work, but it's a bit unexpected in this location
} #endif
Right.
- Copy u-boot
- Copy right dtb.
Agreed. This works and more appropriate place to fix it. Will you post a separate patch or do you want me to post it on your behalf?
Thanks and regards, Lokesh
Right.
- Copy u-boot
- Copy right dtb.
int fdt_memrsv = 0; if (!blob) return 0;
if (ret < 0)
return ret;
if (fdt_memrsv) {
if (ret < 0)
return ret;
While it's good to know this fixes your issue, I'm not sure this doesn't break anything else.
Tom, Simon, can you add anything here? Why is the dtb memory added as reserved to itself? It seems to me this is redundant, as the code using the dtb should well know the pointer to it...
Lokesh, I can send a patch once this is discussed.
return actualsize;
- int i, cnt, err;
break;
#endif
Right.
- Copy u-boot
- Copy right dtb.
if (ret < 0)
return ret;
if (fdt_memrsv) {
if (ret < 0)
return ret;
OK, so the history of that call is really what's seen in: commit 41c5eaa7253ed82bbae1eda5667755872c615164 Author: Andy Fleming afleming@freescale.com Date: Mon Jun 16 13:58:56 2008 -0500
Resize device tree to allow space for board changes and the chosen node
Current code requires that a compiled device tree have space added to the end to leave room for extra nodes added by board code (and the chosen node). This requires that device tree creators anticipate how much space U-Boot will add to the tree, which is absurd. Ideally, the code would resize and/or relocate the tree when it needed more space, but this would require a systemic change to the fdt code, which is non-trivial. Instead, we resize the tree inside boot_relocate_fdt, reserving either the remainder of the bootmap (in the case where the fdt is inside the bootmap), or adding CFG_FDT_PAD bytes to the size.
Signed-off-by: Andy Fleming afleming@freescale.com
Which is all about preparing things for passing the device tree we loaded specifically for Linux. In: commit 3082d2348c8e13342f5fdd10e9b3f7408062dbf9 Author: Kumar Gala galak@kernel.crashing.org Date: Fri Aug 15 08:24:42 2008 -0500
fdt: refactor fdt resize code
Move the fdt resizing code out of ppc specific boot code and into common fdt support code.
Signed-off-by: Kumar Gala galak@kernel.crashing.org
The code was moved to a more common area. So the intent on "reserve" was to make sure that we had enough space set aside for the dtb to be able to be updated at runtime, by U-Boot, for various needs and that we wouldn't give that memory away to something else / allow it to be clobbered.
Simon,
Right.
- Copy u-boot
- Copy right dtb.
if (ret < 0)
return ret;
if (fdt_memrsv) {
if (ret < 0)
return ret;
Resize device tree to allow space for board changes and the chosen node Current code requires that a compiled device tree have space added to the end to leave room for extra nodes added by board code (and the chosen node). This requires that device tree creators anticipate how much space U-Boot will add to the tree, which is absurd. Ideally, the code would resize and/or relocate the tree when it needed more space, but this would require a systemic change to the fdt code, which is non-trivial. Instead, we resize the tree inside boot_relocate_fdt, reserving either the remainder of the bootmap (in the case where the fdt is inside the bootmap), or adding CFG_FDT_PAD bytes to the size. Signed-off-by: Andy Fleming <afleming@freescale.com>
fdt: refactor fdt resize code Move the fdt resizing code out of ppc specific boot code and into common fdt support code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
Any update on this? Any chance you will be posting your changes?
Hi Lokesh,
On 03.05.19 16:24, Lokesh Vutla wrote:
Simon,
Right.
- Copy u-boot
- Copy right dtb.
if (ret < 0)
return ret;
if (fdt_memrsv) {
if (ret < 0)
return ret;
No, sorry, not update. I'll send the patch I suggested above and we'll see how the discussion continues.
Lokesh Vutla
Simon Goldschmidt
