[RESEND PATCH v10 0/9] Add EFI HTTP boot support
This series adds the EFI HTTP boot support. User can add the URI device path with "efidebug boot add" command. efibootmgr handles the URI device path, download the specified file using wget, mount the downloaded image with blkmap, then boot with the default file(e.g. EFI/BOOT/BOOTAA64.EFI) by selecting automatically created boot option when the new disk is detected.
This version still does not include the test.
To enable EFI HTTP boot, we need to enable the following Kconfig options. CONFIG_CMD_DNS CONFIG_CMD_WGET CONFIG_BLKMAP CONFIG_EFI_HTTP_BOOT
On the Socionext Developerbox, enter the following commands then debian installer is downloaded into "loadaddr" and installer automatically starts. => dhcp => setenv serverip 192.168.1.1 => efidebug boot add -u 3 debian-netinst http://ftp.riken.jp/Linux/debian/debian-cd/12.1.0/arm64/iso-cd/debian-12.1.0... => efidebug boot order 3 => bootefi bootmgr
Note that this debian installer can not proceed the installation bacause RAM disk of installer image is not recogniged by the kernel. I'm still investigating this issue, but drivers/nvdimm/of_pmem.c in linux will be one of the solution to recognize RAM disk from kernel. (In EDK2, the equivalent solution is called ACPI NFIT.)
On QEMU, I can not make DNS work from the QEMU guest. The following commands work on qemu_arm64(manually set the http server ip in URI). => dhcp => setenv gatewayip 10.0.2.2 => setenv httpserverip 134.160.38.1 => efidebug boot add -u 3 debian-netinst http://134.160.38.1/Linux/debian/debian-cd/12.1.0/arm64/iso-cd/debian-12.1.0... => efidebug boot order 3 => bootefi bootmgr
[TODO] - add test - stricter wget uri check - omit the dns process if the given uri has ip address -> this will be supported when the lwip migration completes - uri device path support in eficonfig - expose ramdisk to OS
[change log] v9 -> v10 - fix failure in erofs python test - refactor try_load_from_uri_path(), call efi_load_image() in single location - missing free of file_path for EFI application - fix blkmap_create_ramdisk() size type from int to ulong
v8 -> v9 - implement new EFI event to notify that loaded image returns and back to the efibootmgr - ramdisk cleanup is done in event callback - refactor error handling
v7 -> v8 - search the default file on the fly, instead of creating the boot option with default file - delete blkmap and reserved memory in case of error or when the EFI application returns - update the subject "Boot var automatic management for removable medias" since this automatic boot option management is also applied for non-removable medias - update error handling in efidebug command - call efi_add_memory_map() instead of exposing efi_reserve_memory()
v6 -> v7 - rename the funtion name from load_default_file_boot_option() to load_mounted_image() - move some fix from patch #5 "efi_loader: support boot from URI device path" to patch #4 "efi_loader: create default file boot option". - fix missing free() of default_file_path
v5 -> v6 - add patch #4 "Boot var automatic management for removable medias" - boot from automatically created boot option rather than searching default file on the fly - introduce new CONFIG_EFI_HTTP_BOOT Kconfig option - comment in one place - use log_err() rather than printf() - use env_get_hex("filesize", 0) instead of return value of net_loop() - use more suitable error code - blkmap can be build for SPL/TPL - add CDROM short-form device path support
v4 -> v5 - add missing else statement - add NULL check of efi_dp_find_obj() call - update document to remove "limitation"
v3 -> v4 - patch#8 is added to simplify the bootmgr default boot process - add function comments
v2 -> v3 - Patch#6 is added, reserve the whole ramdisk memory region - remove .efi file extension check for PE-COFF image - use "if IS_ENABLED(..)" as much as possible - 1024 should be sizeof(net_boot_file_name) - call net_set_state(NETLOOP_FAIL) when wget encounters error - describe DNS ip address host name limitation in document
v1 -> v2 - carve out the network handling(wget and dns code) under net/wget.c - carve out ramdisk creation code under drivers/block/blkmap_helper.c - wget supports the valid range check to store the received blocks using lmb - support when the downloaded image have no partiton table but a file system - not start the .efi file in try_load_entry() - call efi_check_pe() for .efi file to check the file is PE-COFF image - add documentation for EFI HTTP Boot
Masahisa Kojima (8): net: wget: prevent overwriting reserved memory net: wget: add wget with dns utility function blk: blkmap: add ramdisk creation utility function efi_loader: add missing const classifier for event service efi_loader: add return to efibootmgr event group efi_loader: support boot from URI device path cmd: efidebug: add uri device path doc: uefi: add HTTP Boot support
Raymond Mao (1): efi_loader: Boot var automatic management
cmd/bootefi.c | 12 + cmd/efidebug.c | 51 +++ doc/develop/uefi/uefi.rst | 30 ++ drivers/block/Makefile | 3 +- drivers/block/blkmap.c | 15 - drivers/block/blkmap_helper.c | 53 +++ include/blkmap.h | 29 ++ include/efi_api.h | 5 +- include/efi_loader.h | 4 +- include/net.h | 17 + lib/efi_loader/Kconfig | 9 + lib/efi_loader/efi_bootmgr.c | 337 ++++++++++++++++++ lib/efi_loader/efi_boottime.c | 7 +- lib/efi_loader/efi_disk.c | 18 + lib/efi_loader/efi_setup.c | 7 + net/wget.c | 205 ++++++++++- test/py/tests/test_efi_secboot/test_signed.py | 42 +-- .../test_efi_secboot/test_signed_intca.py | 14 +- .../tests/test_efi_secboot/test_unsigned.py | 14 +- test/py/tests/test_fs/test_erofs.py | 9 + .../test_fs/test_squashfs/test_sqfs_ls.py | 9 + 21 files changed, 828 insertions(+), 62 deletions(-) create mode 100644 drivers/block/blkmap_helper.c
This introduces the valid range check to store the received blocks using lmb. The same logic is implemented in tftp.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ramon Fried rfried.dev@gmail.com --- net/wget.c | 80 +++++++++++++++++++++++++++++++++++++++++++++++++----- 1 file changed, 73 insertions(+), 7 deletions(-)
diff --git a/net/wget.c b/net/wget.c index 8bb4d72db1..6f97eb1d12 100644 --- a/net/wget.c +++ b/net/wget.c @@ -4,16 +4,20 @@ * Copyright Duncan Hare dh@synoia.com 2017 */
+#include <asm/global_data.h> #include <command.h> #include <common.h> #include <display_options.h> #include <env.h> #include <image.h> +#include <lmb.h> #include <mapmem.h> #include <net.h> #include <net/tcp.h> #include <net/wget.h>
+DECLARE_GLOBAL_DATA_PTR; + static const char bootfile1[] = "GET "; static const char bootfile3[] = " HTTP/1.0\r\n\r\n"; static const char http_eom[] = "\r\n\r\n"; @@ -56,6 +60,29 @@ static unsigned int retry_tcp_ack_num; /* TCP retry acknowledge number*/ static unsigned int retry_tcp_seq_num; /* TCP retry sequence number */ static int retry_len; /* TCP retry length */
+static ulong wget_load_size; + +/** + * wget_init_max_size() - initialize maximum load size + * + * Return: 0 if success, -1 if fails + */ +static int wget_init_load_size(void) +{ + struct lmb lmb; + phys_size_t max_size; + + lmb_init_and_reserve(&lmb, gd->bd, (void *)gd->fdt_blob); + + max_size = lmb_get_free_size(&lmb, image_load_addr); + if (!max_size) + return -1; + + wget_load_size = max_size; + + return 0; +} + /** * store_block() - store block in memory * @src: source of data @@ -64,10 +91,25 @@ static int retry_len; /* TCP retry length */ */ static inline int store_block(uchar *src, unsigned int offset, unsigned int len) { + ulong store_addr = image_load_addr + offset; ulong newsize = offset + len; uchar *ptr;
- ptr = map_sysmem(image_load_addr + offset, len); + if (IS_ENABLED(CONFIG_LMB)) { + ulong end_addr = image_load_addr + wget_load_size; + + if (!end_addr) + end_addr = ULONG_MAX; + + if (store_addr < image_load_addr || + store_addr + len > end_addr) { + printf("\nwget error: "); + printf("trying to overwrite reserved memory...\n"); + return -1; + } + } + + ptr = map_sysmem(store_addr, len); memcpy(ptr, src, len); unmap_sysmem(ptr);
@@ -248,25 +290,39 @@ static void wget_connected(uchar *pkt, unsigned int tcp_seq_num,
net_boot_file_size = 0;
- if (len > hlen) - store_block(pkt + hlen, 0, len - hlen); + if (len > hlen) { + if (store_block(pkt + hlen, 0, len - hlen) != 0) { + wget_loop_state = NETLOOP_FAIL; + wget_fail("wget: store error\n", tcp_seq_num, tcp_ack_num, action); + net_set_state(NETLOOP_FAIL); + return; + } + }
debug_cond(DEBUG_WGET, "wget: Connected Pkt %p hlen %x\n", pkt, hlen);
for (i = 0; i < pkt_q_idx; i++) { + int err; + ptr1 = map_sysmem( (phys_addr_t)(pkt_q[i].pkt), pkt_q[i].len); - store_block(ptr1, - pkt_q[i].tcp_seq_num - - initial_data_seq_num, - pkt_q[i].len); + err = store_block(ptr1, + pkt_q[i].tcp_seq_num - + initial_data_seq_num, + pkt_q[i].len); unmap_sysmem(ptr1); debug_cond(DEBUG_WGET, "wget: Connctd pkt Q %p len %x\n", pkt_q[i].pkt, pkt_q[i].len); + if (err) { + wget_loop_state = NETLOOP_FAIL; + wget_fail("wget: store error\n", tcp_seq_num, tcp_ack_num, action); + net_set_state(NETLOOP_FAIL); + return; + } } } } @@ -338,6 +394,7 @@ static void wget_handler(uchar *pkt, u16 dport, len) != 0) { wget_fail("wget: store error\n", tcp_seq_num, tcp_ack_num, action); + net_set_state(NETLOOP_FAIL); return; }
@@ -428,6 +485,15 @@ void wget_start(void) debug_cond(DEBUG_WGET, "\nwget:Load address: 0x%lx\nLoading: *\b", image_load_addr);
+ if (IS_ENABLED(CONFIG_LMB)) { + if (wget_init_load_size()) { + printf("\nwget error: "); + printf("trying to overwrite reserved memory...\n"); + net_set_state(NETLOOP_FAIL); + return; + } + } + net_set_timeout_handler(wget_timeout, wget_timeout_handler); tcp_set_tcp_handler(wget_handler);
Current wget takes the target uri in this format: "<http server ip>:<file path>" e.g.) 192.168.1.1:/bar The http server ip address must be resolved before calling wget.
This commit adds the utility function runs wget with dhs. User can call wget with the uri like "http://foo/bar".
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Ramon Fried rfried.dev@gmail.com --- include/net.h | 9 +++++++++ net/wget.c | 54 +++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 63 insertions(+)
diff --git a/include/net.h b/include/net.h index e254df7d7f..57889d8b7a 100644 --- a/include/net.h +++ b/include/net.h @@ -926,4 +926,13 @@ void eth_set_enable_bootdevs(bool enable); static inline void eth_set_enable_bootdevs(bool enable) {} #endif
+/** + * wget_with_dns() - runs dns host IP address resulution before wget + * + * @dst_addr: destination address to download the file + * @uri: uri string of target file of wget + * Return: downloaded file size, negative if failed + */ +int wget_with_dns(ulong dst_addr, char *uri); + #endif /* __NET_H__ */ diff --git a/net/wget.c b/net/wget.c index 6f97eb1d12..2087146b37 100644 --- a/net/wget.c +++ b/net/wget.c @@ -15,6 +15,7 @@ #include <net.h> #include <net/tcp.h> #include <net/wget.h> +#include <stdlib.h>
@@ -512,3 +513,56 @@ void wget_start(void)
wget_send(TCP_SYN, 0, 0, 0); } + +#if (IS_ENABLED(CONFIG_CMD_DNS)) +int wget_with_dns(ulong dst_addr, char *uri) +{ + int ret; + char *s, *host_name, *file_name, *str_copy; + + /* + * Download file using wget. + * + * U-Boot wget takes the target uri in this format. + * "<http server ip>:<file path>" e.g.) 192.168.1.1:/sample/test.iso + * Need to resolve the http server ip address before starting wget. + */ + str_copy = strdup(uri); + if (!str_copy) + return -ENOMEM; + + s = str_copy + strlen("http://"); + host_name = strsep(&s, "/"); + if (!s) { + log_err("Error: invalied uri, no file path\n"); + ret = -EINVAL; + goto out; + } + file_name = s; + + /* TODO: If the given uri has ip address for the http server, skip dns */ + net_dns_resolve = host_name; + net_dns_env_var = "httpserverip"; + if (net_loop(DNS) < 0) { + log_err("Error: dns lookup of %s failed, check setup\n", net_dns_resolve); + ret = -EINVAL; + goto out; + } + s = env_get("httpserverip"); + if (!s) { + ret = -EINVAL; + goto out; + } + + strlcpy(net_boot_file_name, s, sizeof(net_boot_file_name)); + strlcat(net_boot_file_name, ":/", sizeof(net_boot_file_name)); /* append '/' which is removed by strsep() */ + strlcat(net_boot_file_name, file_name, sizeof(net_boot_file_name)); + image_load_addr = dst_addr; + ret = net_loop(WGET); + +out: + free(str_copy); + + return ret; +} +#endif
User needs to call several functions to create the ramdisk with blkmap. This adds the utility function to create blkmap device and mount the ramdisk.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- drivers/block/Makefile | 3 +- drivers/block/blkmap.c | 15 ---------- drivers/block/blkmap_helper.c | 53 +++++++++++++++++++++++++++++++++++ include/blkmap.h | 29 +++++++++++++++++++ 4 files changed, 84 insertions(+), 16 deletions(-) create mode 100644 drivers/block/blkmap_helper.c
diff --git a/drivers/block/Makefile b/drivers/block/Makefile index a161d145fd..ec0575d135 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -14,7 +14,8 @@ obj-$(CONFIG_IDE) += ide.o endif obj-$(CONFIG_SANDBOX) += sandbox.o host-uclass.o host_dev.o obj-$(CONFIG_$(SPL_TPL_)BLOCK_CACHE) += blkcache.o -obj-$(CONFIG_BLKMAP) += blkmap.o +obj-$(CONFIG_$(SPL_TPL_)BLKMAP) += blkmap.o +obj-$(CONFIG_$(SPL_TPL_)BLKMAP) += blkmap_helper.o
obj-$(CONFIG_EFI_MEDIA) += efi-media-uclass.o obj-$(CONFIG_EFI_MEDIA_SANDBOX) += sb_efi_media.o diff --git a/drivers/block/blkmap.c b/drivers/block/blkmap.c index 149a4cac3e..21201409ed 100644 --- a/drivers/block/blkmap.c +++ b/drivers/block/blkmap.c @@ -66,21 +66,6 @@ struct blkmap_slice { void (*destroy)(struct blkmap *bm, struct blkmap_slice *bms); };
-/** - * struct blkmap - Block map - * - * Data associated with a blkmap. - * - * @label: Human readable name of this blkmap - * @blk: Underlying block device - * @slices: List of slices associated with this blkmap - */ -struct blkmap { - char *label; - struct udevice *blk; - struct list_head slices; -}; - static bool blkmap_slice_contains(struct blkmap_slice *bms, lbaint_t blknr) { return (blknr >= bms->blknr) && (blknr < (bms->blknr + bms->blkcnt)); diff --git a/drivers/block/blkmap_helper.c b/drivers/block/blkmap_helper.c new file mode 100644 index 0000000000..bfba14110d --- /dev/null +++ b/drivers/block/blkmap_helper.c @@ -0,0 +1,53 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * blkmap helper function + * + * Copyright (c) 2023, Linaro Limited + */ + +#include <blk.h> +#include <blkmap.h> +#include <dm/device.h> +#include <dm/device-internal.h> + +int blkmap_create_ramdisk(const char *label, ulong image_addr, ulong image_size, + struct udevice **devp) +{ + int ret; + lbaint_t blknum; + struct blkmap *bm; + struct blk_desc *desc; + struct udevice *bm_dev; + + ret = blkmap_create(label, &bm_dev); + if (ret) { + log_err("failed to create blkmap\n"); + return ret; + } + + bm = dev_get_plat(bm_dev); + desc = dev_get_uclass_plat(bm->blk); + blknum = image_size >> desc->log2blksz; + ret = blkmap_map_pmem(bm_dev, 0, blknum, image_addr); + if (ret) { + log_err("Unable to map %#llx at block %d : %d\n", + (unsigned long long)image_addr, 0, ret); + goto err; + } + log_info("Block %d+0x" LBAF " mapped to %#llx\n", 0, blknum, + (unsigned long long)image_addr); + + ret = device_probe(bm->blk); + if (ret) + goto err; + + if (devp) + *devp = bm_dev; + + return 0; + +err: + blkmap_destroy(bm_dev); + + return ret; +} diff --git a/include/blkmap.h b/include/blkmap.h index af54583c7d..30dc84a7da 100644 --- a/include/blkmap.h +++ b/include/blkmap.h @@ -7,6 +7,23 @@ #ifndef _BLKMAP_H #define _BLKMAP_H
+#include <dm/lists.h> + +/** + * struct blkmap - Block map + * + * Data associated with a blkmap. + * + * @label: Human readable name of this blkmap + * @blk: Underlying block device + * @slices: List of slices associated with this blkmap + */ +struct blkmap { + char *label; + struct udevice *blk; + struct list_head slices; +}; + /** * blkmap_map_linear() - Map region of other block device * @@ -74,4 +91,16 @@ int blkmap_create(const char *label, struct udevice **devp); */ int blkmap_destroy(struct udevice *dev);
+/** + * blkmap_create_ramdisk() - Create new ramdisk with blkmap + * + * @label: Label of the new blkmap + * @image_addr: Target memory start address of this mapping + * @image_size: Target memory size of this mapping + * @devp: Updated with the address of the created blkmap device + * Returns: 0 on success, negative error code on failure + */ +int blkmap_create_ramdisk(const char *label, ulong image_addr, ulong image_size, + struct udevice **devp); + #endif /* _BLKMAP_H */
Changes for complying to EFI spec ยง3.5.1.1 'Removable Media Boot Behavior'. Boot variables can be automatically generated during a removable media is probed. At the same time, unused boot variables will be detected and removed.
Please note that currently the function 'efi_disk_remove' has no ability to distinguish below two scenarios a) Unplugging of a removable media under U-Boot b) U-Boot exiting and booting an OS Thus currently the boot variables management is not added into 'efi_disk_remove' to avoid boot options being added/erased repeatedly under scenario b) during power cycles See TODO comments under function 'efi_disk_remove' for more details
The original efi_secboot tests expect that BootOrder EFI variable is not defined. With this commit, the BootOrder EFI variable is automatically added when the disk is detected. The original efi_secboot tests end up with unexpected failure. The efi_secboot tests need to be modified to explicitly set the BootOrder EFI variable.
squashfs and erofs ls tests are also affected by this modification, need to clear the previous state before squashfs ls test starts.
Co-developed-by: Masahisa Kojima masahisa.kojima@linaro.org Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Signed-off-by: Raymond Mao raymond.mao@linaro.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Joao Marcos Costa jmcosta944@gmail.com --- lib/efi_loader/efi_disk.c | 18 ++++++++ lib/efi_loader/efi_setup.c | 7 ++++ test/py/tests/test_efi_secboot/test_signed.py | 42 +++++++++---------- .../test_efi_secboot/test_signed_intca.py | 14 +++---- .../tests/test_efi_secboot/test_unsigned.py | 14 +++---- test/py/tests/test_fs/test_erofs.py | 9 ++++ .../test_fs/test_squashfs/test_sqfs_ls.py | 9 ++++ 7 files changed, 78 insertions(+), 35 deletions(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index f0d76113b0..b808a7fe62 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -690,6 +690,13 @@ int efi_disk_probe(void *ctx, struct event *event) return -1; }
+ /* only do the boot option management when UEFI sub-system is initialized */ + if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR) && efi_obj_list_initialized == EFI_SUCCESS) { + ret = efi_bootmgr_update_media_device_boot_option(); + if (ret != EFI_SUCCESS) + return -1; + } + return 0; }
@@ -742,6 +749,17 @@ int efi_disk_remove(void *ctx, struct event *event) dev_tag_del(dev, DM_TAG_EFI);
return 0; + + /* + * TODO A flag to distinguish below 2 different scenarios of this + * function call is needed: + * a) Unplugging of a removable media under U-Boot + * b) U-Boot exiting and booting an OS + * In case of scenario a), efi_bootmgr_update_media_device_boot_option() + * needs to be invoked here to update the boot options and remove the + * unnecessary ones. + */ + }
/** diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index ad719afd63..c02569cb6d 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -245,6 +245,13 @@ efi_status_t efi_init_obj_list(void) if (ret != EFI_SUCCESS) goto out;
+ if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR)) { + /* update boot option after variable service initialized */ + ret = efi_bootmgr_update_media_device_boot_option(); + if (ret != EFI_SUCCESS) + goto out; + } + /* Define supported languages */ ret = efi_init_platform_lang(); if (ret != EFI_SUCCESS) diff --git a/test/py/tests/test_efi_secboot/test_signed.py b/test/py/tests/test_efi_secboot/test_signed.py index ca52e853d8..2f862a259a 100644 --- a/test/py/tests/test_efi_secboot/test_signed.py +++ b/test/py/tests/test_efi_secboot/test_signed.py @@ -29,7 +29,7 @@ class TestEfiSignedImage(object): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, 'efidebug boot add -b 1 HELLO1 host 0:1 /helloworld.efi.signed -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'bootefi bootmgr']) assert 'Hello, world!' in ''.join(output)
@@ -37,7 +37,7 @@ class TestEfiSignedImage(object): # Test Case 1b, run unsigned image if no PK output = u_boot_console.run_command_list([ 'efidebug boot add -b 2 HELLO2 host 0:1 /helloworld.efi -s ""', - 'efidebug boot next 2', + 'efidebug boot order 2', 'bootefi bootmgr']) assert 'Hello, world!' in ''.join(output)
@@ -59,13 +59,13 @@ class TestEfiSignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO1 host 0:1 /helloworld.efi.signed -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert(''HELLO1' failed' in ''.join(output)) assert('efi_start_image() returned: 26' in ''.join(output)) output = u_boot_console.run_command_list([ 'efidebug boot add -b 2 HELLO2 host 0:1 /helloworld.efi -s ""', - 'efidebug boot next 2', + 'efidebug boot order 2', 'efidebug test bootmgr']) assert ''HELLO2' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -77,12 +77,12 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000:$filesize db']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 2', + 'efidebug boot order 2', 'efidebug test bootmgr']) assert ''HELLO2' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 1', + 'efidebug boot order 1', 'bootefi bootmgr']) assert 'Hello, world!' in ''.join(output)
@@ -105,7 +105,7 @@ class TestEfiSignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -117,7 +117,7 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000:$filesize db']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -143,7 +143,7 @@ class TestEfiSignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -170,7 +170,7 @@ class TestEfiSignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed_2sigs -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert 'Hello, world!' in ''.join(output)
@@ -181,7 +181,7 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -a -i 4000000:$filesize db']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert 'Hello, world!' in ''.join(output)
@@ -193,7 +193,7 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000:$filesize dbx']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -205,7 +205,7 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -a -i 4000000:$filesize dbx']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -230,7 +230,7 @@ class TestEfiSignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed_2sigs -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -254,7 +254,7 @@ class TestEfiSignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'bootefi bootmgr']) assert 'Hello, world!' in ''.join(output)
@@ -265,7 +265,7 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000:$filesize dbx']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -279,7 +279,7 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000:$filesize dbx']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -307,7 +307,7 @@ class TestEfiSignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed_2sigs -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -330,7 +330,7 @@ class TestEfiSignedImage(object): assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi.signed_2sigs -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -349,7 +349,7 @@ class TestEfiSignedImage(object): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, 'efidebug boot add -b 1 HELLO1 host 0:1 /helloworld_forged.efi.signed -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert('hELLO, world!' in ''.join(output))
@@ -364,7 +364,7 @@ class TestEfiSignedImage(object): 'setenv -e -nv -bs -rt -at -i 4000000:$filesize PK']) assert 'Failed to set EFI variable' not in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert(not 'hELLO, world!' in ''.join(output)) assert(''HELLO1' failed' in ''.join(output)) diff --git a/test/py/tests/test_efi_secboot/test_signed_intca.py b/test/py/tests/test_efi_secboot/test_signed_intca.py index d8d599d22f..8d9a5f3e7f 100644 --- a/test/py/tests/test_efi_secboot/test_signed_intca.py +++ b/test/py/tests/test_efi_secboot/test_signed_intca.py @@ -40,7 +40,7 @@ class TestEfiSignedImageIntca(object):
output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO_a host 0:1 /helloworld.efi.signed_a -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO_a' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -49,7 +49,7 @@ class TestEfiSignedImageIntca(object): # Test Case 1b, signed and authenticated by root CA output = u_boot_console.run_command_list([ 'efidebug boot add -b 2 HELLO_ab host 0:1 /helloworld.efi.signed_ab -s ""', - 'efidebug boot next 2', + 'efidebug boot order 2', 'bootefi bootmgr']) assert 'Hello, world!' in ''.join(output)
@@ -71,7 +71,7 @@ class TestEfiSignedImageIntca(object):
output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO_abc host 0:1 /helloworld.efi.signed_abc -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO_abc' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -81,7 +81,7 @@ class TestEfiSignedImageIntca(object): output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db_b.auth', 'setenv -e -nv -bs -rt -at -i 4000000:$filesize db', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO_abc' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) @@ -91,7 +91,7 @@ class TestEfiSignedImageIntca(object): output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 db_c.auth', 'setenv -e -nv -bs -rt -at -i 4000000:$filesize db', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert 'Hello, world!' in ''.join(output)
@@ -117,7 +117,7 @@ class TestEfiSignedImageIntca(object):
output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO_abc host 0:1 /helloworld.efi.signed_abc -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert 'Hello, world!' in ''.join(output) # Or, @@ -129,7 +129,7 @@ class TestEfiSignedImageIntca(object): output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 dbx_c.auth', 'setenv -e -nv -bs -rt -at -i 4000000:$filesize dbx', - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert ''HELLO_abc' failed' in ''.join(output) assert 'efi_start_image() returned: 26' in ''.join(output) diff --git a/test/py/tests/test_efi_secboot/test_unsigned.py b/test/py/tests/test_efi_secboot/test_unsigned.py index df63f0df08..7c078f220d 100644 --- a/test/py/tests/test_efi_secboot/test_unsigned.py +++ b/test/py/tests/test_efi_secboot/test_unsigned.py @@ -36,11 +36,11 @@ class TestEfiUnsignedImage(object):
output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'bootefi bootmgr']) assert ''HELLO' failed' in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert 'efi_start_image() returned: 26' in ''.join(output) assert 'Hello, world!' not in ''.join(output) @@ -65,7 +65,7 @@ class TestEfiUnsignedImage(object):
output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'bootefi bootmgr']) assert 'Hello, world!' in ''.join(output)
@@ -89,11 +89,11 @@ class TestEfiUnsignedImage(object):
output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'bootefi bootmgr']) assert ''HELLO' failed' in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert 'efi_start_image() returned: 26' in ''.join(output) assert 'Hello, world!' not in ''.join(output) @@ -107,11 +107,11 @@ class TestEfiUnsignedImage(object):
output = u_boot_console.run_command_list([ 'efidebug boot add -b 1 HELLO host 0:1 /helloworld.efi -s ""', - 'efidebug boot next 1', + 'efidebug boot order 1', 'bootefi bootmgr']) assert ''HELLO' failed' in ''.join(output) output = u_boot_console.run_command_list([ - 'efidebug boot next 1', + 'efidebug boot order 1', 'efidebug test bootmgr']) assert 'efi_start_image() returned: 26' in ''.join(output) assert 'Hello, world!' not in ''.join(output) diff --git a/test/py/tests/test_fs/test_erofs.py b/test/py/tests/test_fs/test_erofs.py index 458a52ba79..87ad8f2d5f 100644 --- a/test/py/tests/test_fs/test_erofs.py +++ b/test/py/tests/test_fs/test_erofs.py @@ -196,6 +196,15 @@ def test_erofs(u_boot_console): """ build_dir = u_boot_console.config.build_dir
+ # If the EFI subsystem is enabled and initialized, EFI subsystem tries to + # add EFI boot option when the new disk is detected. If there is no EFI + # System Partition exists, EFI subsystem outputs error messages and + # it ends up with test failure. + # Restart U-Boot to clear the previous state. + # TODO: Ideally EFI test cases need to be fixed, but it will + # increase the number of system reset. + u_boot_console.restart_uboot() + try: # setup test environment make_erofs_image(build_dir) diff --git a/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py b/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py index 527a556ed8..a20a7d1a66 100644 --- a/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py +++ b/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py @@ -118,6 +118,15 @@ def test_sqfs_ls(u_boot_console): """ build_dir = u_boot_console.config.build_dir
+ # If the EFI subsystem is enabled and initialized, EFI subsystem tries to + # add EFI boot option when the new disk is detected. If there is no EFI + # System Partition exists, EFI subsystem outputs error messages and + # it ends up with test failure. + # Restart U-Boot to clear the previous state. + # TODO: Ideally EFI test cases need to be fixed, but it will + # increase the number of system reset. + u_boot_console.restart_uboot() + # setup test environment check_mksquashfs_version() generate_sqfs_src_dir(build_dir)
const classifier is missing in EventGroup parameter of CreateEventEx(). Fix it to remove the compiler warning.
NotifyContext parameter of CreateEventEx() is also defined with const in UEFI specification, but NotifyContext parameter of CreateEvent() is defined without const. Since current implementation calls the common efi_create_event() function from both CreateEventEx() and CreateEvent() services, NotifyContext parameter leaves as is.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- include/efi_api.h | 2 +- include/efi_loader.h | 2 +- lib/efi_loader/efi_boottime.c | 4 ++-- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/efi_api.h b/include/efi_api.h index 8f5ef5f680..c2d6964467 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -192,7 +192,7 @@ struct efi_boot_services { struct efi_event *event, void *context), void *notify_context, - efi_guid_t *event_group, + const efi_guid_t *event_group, struct efi_event **event); };
diff --git a/include/efi_loader.h b/include/efi_loader.h index e24410505f..e164e6067d 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -685,7 +685,7 @@ efi_status_t efi_create_event(uint32_t type, efi_uintn_t notify_tpl, void (EFIAPI *notify_function) ( struct efi_event *event, void *context), - void *notify_context, efi_guid_t *group, + void *notify_context, const efi_guid_t *group, struct efi_event **event); /* Call this to set a timer */ efi_status_t efi_set_timer(struct efi_event *event, enum efi_timer_delay type, diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 0b7579cb5a..f9b10a9763 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -712,7 +712,7 @@ efi_status_t efi_create_event(uint32_t type, efi_uintn_t notify_tpl, void (EFIAPI *notify_function) ( struct efi_event *event, void *context), - void *notify_context, efi_guid_t *group, + void *notify_context, const efi_guid_t *group, struct efi_event **event) { struct efi_event *evt; @@ -790,7 +790,7 @@ efi_status_t EFIAPI efi_create_event_ex(uint32_t type, efi_uintn_t notify_tpl, struct efi_event *event, void *context), void *notify_context, - efi_guid_t *event_group, + const efi_guid_t *event_group, struct efi_event **event) { efi_status_t ret;
When the image loaded by efibootmgr returns, efibootmgr needs to clean the resources. Adding the event of returning to efibootmgr is useful to simplify the implementation.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- cmd/bootefi.c | 12 ++++++++++++ include/efi_api.h | 3 +++ include/efi_loader.h | 2 ++ lib/efi_loader/efi_boottime.c | 3 +++ 4 files changed, 20 insertions(+)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 20e5c94a33..4d74969ad6 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -356,6 +356,7 @@ static efi_status_t do_bootefi_exec(efi_handle_t handle, void *load_options) efi_status_t ret; efi_uintn_t exit_data_size = 0; u16 *exit_data = NULL; + struct efi_event *evt;
/* On ARM switch from EL3 or secure mode to EL2 or non-secure mode */ switch_to_non_secure_mode(); @@ -394,6 +395,17 @@ out: log_err("Failed to remove loadfile2 for initrd\n"); }
+ /* Notify EFI_EVENT_GROUP_RETURN_TO_EFIBOOTMGR event group. */ + list_for_each_entry(evt, &efi_events, link) { + if (evt->group && + !guidcmp(evt->group, + &efi_guid_event_group_return_to_efibootmgr)) { + efi_signal_event(evt); + EFI_CALL(systab.boottime->close_event(evt)); + break; + } + } + /* Control is returned to U-Boot, disable EFI watchdog */ efi_set_watchdog(0);
diff --git a/include/efi_api.h b/include/efi_api.h index c2d6964467..0e92cb8a7f 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -404,6 +404,9 @@ struct efi_runtime_services { #define EFI_EVENT_GROUP_RESET_SYSTEM \ EFI_GUID(0x62da6a56, 0x13fb, 0x485a, 0xa8, 0xda, \ 0xa3, 0xdd, 0x79, 0x12, 0xcb, 0x6b) +#define EFI_EVENT_GROUP_RETURN_TO_EFIBOOTMGR \ + EFI_GUID(0xb4a40fe6, 0x9149, 0x4f29, 0x94, 0x47, \ + 0x49, 0x38, 0x7a, 0x7f, 0xab, 0x87)
/* EFI Configuration Table and GUID definitions */ #define NULL_GUID \ diff --git a/include/efi_loader.h b/include/efi_loader.h index e164e6067d..31954e84c3 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -290,6 +290,8 @@ extern const efi_guid_t efi_guid_event_group_memory_map_change; extern const efi_guid_t efi_guid_event_group_ready_to_boot; /* event group ResetSystem() invoked (before ExitBootServices) */ extern const efi_guid_t efi_guid_event_group_reset_system; +/* event group return to efibootmgr */ +extern const efi_guid_t efi_guid_event_group_return_to_efibootmgr; /* GUID of the device tree table */ extern const efi_guid_t efi_guid_fdt; extern const efi_guid_t efi_guid_loaded_image; diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index f9b10a9763..3767fa2db4 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -90,6 +90,9 @@ const efi_guid_t efi_guid_event_group_ready_to_boot = /* event group ResetSystem() invoked (before ExitBootServices) */ const efi_guid_t efi_guid_event_group_reset_system = EFI_EVENT_GROUP_RESET_SYSTEM; +/* event group return to efibootmgr */ +const efi_guid_t efi_guid_event_group_return_to_efibootmgr = + EFI_EVENT_GROUP_RETURN_TO_EFIBOOTMGR; /* GUIDs of the Load File and Load File2 protocols */ const efi_guid_t efi_guid_load_file_protocol = EFI_LOAD_FILE_PROTOCOL_GUID; const efi_guid_t efi_guid_load_file2_protocol = EFI_LOAD_FILE2_PROTOCOL_GUID;
This supports to boot from the URI device path. When user selects the URI device path, bootmgr downloads the file using wget into the address specified by loadaddr env variable. If the file is .iso or .img file, mount the image with blkmap then try to boot with the default file(e.g. EFI/BOOT/BOOTAA64.EFI). Since boot option indicating the default file is automatically created when new disk is detected, system can boot by selecting the automatically created blkmap boot option. If the file is PE-COFF file, load and start the downloaded file.
The buffer used to download the ISO image file must be reserved to avoid the unintended access to the image and expose the ramdisk to the OS. For PE-COFF file case, this memory reservation is done in LoadImage Boot Service.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- lib/efi_loader/Kconfig | 9 + lib/efi_loader/efi_bootmgr.c | 337 +++++++++++++++++++++++++++++++++++ 2 files changed, 346 insertions(+)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index d20aaab6db..5d99206dc3 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -479,4 +479,13 @@ config EFI_RISCV_BOOT_PROTOCOL replace the transfer via the device-tree. The latter is not possible on systems using ACPI.
+config EFI_HTTP_BOOT + bool "EFI HTTP Boot support" + depends on CMD_DNS + depends on CMD_WGET + depends on BLKMAP + help + Enabling this option adds EFI HTTP Boot support. It allows to + directly boot from network. + endif diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index a40762c74c..e24c18215a 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -7,10 +7,14 @@
#define LOG_CATEGORY LOGC_EFI
+#include <blk.h> +#include <blkmap.h> #include <common.h> #include <charset.h> +#include <dm.h> #include <log.h> #include <malloc.h> +#include <net.h> #include <efi_default_filename.h> #include <efi_loader.h> #include <efi_variable.h> @@ -19,6 +23,11 @@ static const struct efi_boot_services *bs; static const struct efi_runtime_services *rs;
+static ulong image_size; +static ulong image_addr; +struct efi_device_path *loaded_dp; +static struct udevice *ramdisk_blk_dev; + const efi_guid_t efi_guid_bootmenu_auto_generated = EFICONFIG_AUTO_GENERATED_ENTRY_GUID;
@@ -168,6 +177,327 @@ out: return ret; }
+/** + * mount_image() - mount the image with blkmap + * + * @lo_label: u16 label string of load option + * @addr: image address + * @size: image size + * Return: pointer to the UCLASS_BLK udevice, NULL if failed + */ +static struct udevice *mount_image(u16 *lo_label, ulong addr, ulong size) +{ + int err; + struct blkmap *bm; + struct udevice *bm_dev; + char *label = NULL, *p; + + label = efi_alloc(utf16_utf8_strlen(lo_label) + 1); + if (!label) + return NULL; + + p = label; + utf16_utf8_strcpy(&p, lo_label); + err = blkmap_create_ramdisk(label, addr, size, &bm_dev); + if (err) { + efi_free_pool(label); + return NULL; + } + bm = dev_get_plat(bm_dev); + + efi_free_pool(label); + + return bm->blk; +} + +/** + * search_default_file() - search default file + * + * @dev: pointer to the UCLASS_BLK or UCLASS_PARTITION udevice + * @dp: pointer to default file device path + * Return: status code + */ +static efi_status_t search_default_file(struct udevice *dev, + struct efi_device_path **dp) +{ + efi_status_t ret; + efi_handle_t handle; + u16 *default_file_name = NULL; + struct efi_file_handle *root, *f; + struct efi_device_path *full_path; + struct efi_device_path *device_path; + struct efi_device_path *file_path = NULL; + struct efi_simple_file_system_protocol *file_system; + + if (dev_tag_get_ptr(dev, DM_TAG_EFI, (void **)&handle)) { + log_warning("DM_TAG_EFI not found\n"); + return EFI_INVALID_PARAMETER; + } + + ret = EFI_CALL(bs->open_protocol(handle, &efi_simple_file_system_protocol_guid, + (void **)&file_system, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL)); + if (ret != EFI_SUCCESS) + return ret; + + ret = EFI_CALL(file_system->open_volume(file_system, &root)); + if (ret != EFI_SUCCESS) + return ret; + + file_path = efi_dp_from_file(NULL, "/EFI/BOOT/" BOOTEFI_NAME); + default_file_name = efi_dp_str(file_path); + if (!default_file_name) { + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + + ret = EFI_CALL(root->open(root, &f, default_file_name, + EFI_FILE_MODE_READ, 0)); + efi_free_pool(default_file_name); + if (ret != EFI_SUCCESS) + goto err; + + EFI_CALL(f->close(f)); + + ret = EFI_CALL(bs->open_protocol(handle, &efi_guid_device_path, + (void **)&device_path, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL)); + if (ret != EFI_SUCCESS) + goto err; + + full_path = efi_dp_append(device_path, file_path); + if (!full_path) { + ret = EFI_OUT_OF_RESOURCES; + goto err; + } + + *dp = full_path; +err: + efi_free_pool(file_path); + + return ret; +} + +/** + * check_disk_has_default_file() - load the default file + * + * @blk: pointer to the UCLASS_BLK udevice + * @dp: pointer to default file device path + * Return: status code + */ +static efi_status_t check_disk_has_default_file(struct udevice *blk, + struct efi_device_path **dp) +{ + efi_status_t ret; + struct udevice *partition; + + /* image that has no partition table but a file system */ + ret = search_default_file(blk, dp); + if (ret == EFI_SUCCESS) + return ret; + + /* try the partitions */ + device_foreach_child(partition, blk) { + enum uclass_id id; + + id = device_get_uclass_id(partition); + if (id != UCLASS_PARTITION) + continue; + + ret = search_default_file(partition, dp); + if (ret == EFI_SUCCESS) + return ret; + } + + return EFI_NOT_FOUND; +} + +/** + * prepare_loaded_image() - prepare ramdisk for downloaded image + * + * @label: label of load option + * @addr: image address + * @size: image size + * @dp: pointer to default file device path + * Return: status code + */ +static efi_status_t prepare_loaded_image(u16 *label, ulong addr, ulong size, + struct efi_device_path **dp) +{ + efi_status_t ret; + struct udevice *blk; + + blk = mount_image(label, addr, size); + if (!blk) + return EFI_LOAD_ERROR; + + ret = check_disk_has_default_file(blk, dp); + if (ret != EFI_SUCCESS) { + log_info("Cannot boot from downloaded image\n"); + goto err; + } + + /* + * TODO: expose the ramdisk to OS. + * Need to pass the ramdisk information by the architecture-specific + * methods such as 'pmem' device-tree node. + */ + ret = efi_add_memory_map(addr, size, EFI_RESERVED_MEMORY_TYPE); + if (ret != EFI_SUCCESS) { + log_err("Memory reservation failed\n"); + goto err; + } + + ramdisk_blk_dev = blk; + + return EFI_SUCCESS; + +err: + if (blkmap_destroy(blk->parent)) + log_err("Destroying blkmap failed\n"); + + return ret; +} + +/** + * efi_bootmgr_release_uridp_resource() - cleanup uri device path resource + * + * Return: status code + */ +efi_status_t efi_bootmgr_release_uridp_resource(void) +{ + efi_status_t ret = EFI_SUCCESS; + + if (ramdisk_blk_dev) { + ret = efi_add_memory_map(image_addr, image_size, + EFI_CONVENTIONAL_MEMORY); + if (ret != EFI_SUCCESS) + log_err("Reclaiming memory failed\n"); + + if (blkmap_destroy(ramdisk_blk_dev->parent)) { + log_err("Destroying blkmap failed\n"); + ret = EFI_DEVICE_ERROR; + } + + ramdisk_blk_dev = NULL; + } + + efi_free_pool(loaded_dp); + loaded_dp = NULL; + + return ret; +} + +/** + * efi_bootmgr_image_return_notify() - return to efibootmgr callback + * + * @event: the event for which this notification function is registered + * @context: event context - not used in this function + */ +static void EFIAPI efi_bootmgr_image_return_notify(struct efi_event *event, + void *context) +{ + efi_status_t ret; + + EFI_ENTRY("%p, %p", event, context); + ret = efi_bootmgr_release_uridp_resource(); + EFI_EXIT(ret); +} + +/** + * try_load_from_uri_path() - Handle the URI device path + * + * @uridp: uri device path + * @lo_label: label of load option + * @handle: pointer to handle for newly installed image + * Return: status code + */ +static efi_status_t try_load_from_uri_path(struct efi_device_path_uri *uridp, + u16 *lo_label, + efi_handle_t *handle) +{ + char *s; + int err; + int uri_len; + efi_status_t ret; + void *source_buffer; + efi_uintn_t source_size; + struct efi_event *event = NULL; + + loaded_dp = NULL; + ramdisk_blk_dev = NULL; + + s = env_get("loadaddr"); + if (!s) { + log_err("Error: loadaddr is not set\n"); + return EFI_INVALID_PARAMETER; + } + image_addr = hextoul(s, NULL); + err = wget_with_dns(image_addr, uridp->uri); + if (err < 0) + return EFI_INVALID_PARAMETER; + image_size = env_get_hex("filesize", 0); + if (!image_size) + return EFI_INVALID_PARAMETER; + + /* + * If the file extension is ".iso" or ".img", mount it and try to load + * the default file. + * If the file is PE-COFF image, load the downloaded file. + */ + uri_len = strlen(uridp->uri); + if (!strncmp(&uridp->uri[uri_len - 4], ".iso", 4) || + !strncmp(&uridp->uri[uri_len - 4], ".img", 4)) { + ret = prepare_loaded_image(lo_label, image_addr, image_size, &loaded_dp); + if (ret != EFI_SUCCESS) + goto err; + + source_buffer = NULL; + source_size = 0; + } else if (efi_check_pe((void *)image_addr, image_size, NULL) == EFI_SUCCESS) { + efi_handle_t mem_handle = NULL; + + /* + * loaded_dp must exist until efi application returns, + * will be freed in return_to_efibootmgr event callback. + */ + loaded_dp = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, + (uintptr_t)image_addr, image_size); + ret = efi_install_multiple_protocol_interfaces( + &mem_handle, &efi_guid_device_path, loaded_dp, NULL); + if (ret != EFI_SUCCESS) + goto err; + + source_buffer = (void *)image_addr; + source_size = image_size; + } else { + log_err("Error: file type is not supported\n"); + return EFI_UNSUPPORTED; + } + + ret = EFI_CALL(efi_load_image(false, efi_root, loaded_dp, source_buffer, + source_size, handle)); + if (ret != EFI_SUCCESS) + goto err; + + /* create event for cleanup when the image returns or error occurs */ + ret = efi_create_event(EVT_NOTIFY_SIGNAL, TPL_CALLBACK, + efi_bootmgr_image_return_notify, NULL, + &efi_guid_event_group_return_to_efibootmgr, + &event); + if (ret != EFI_SUCCESS) { + log_err("Creating event failed\n"); + goto err; + } + + return ret; + +err: + efi_bootmgr_release_uridp_resource(); + + return ret; +} + /** * try_load_entry() - try to load image for boot option * @@ -211,6 +541,13 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, if (EFI_DP_TYPE(lo.file_path, MEDIA_DEVICE, FILE_PATH)) { /* file_path doesn't contain a device path */ ret = try_load_from_short_path(lo.file_path, handle); + } else if (EFI_DP_TYPE(lo.file_path, MESSAGING_DEVICE, MSG_URI)) { + if (IS_ENABLED(CONFIG_EFI_HTTP_BOOT)) + ret = try_load_from_uri_path( + (struct efi_device_path_uri *)lo.file_path, + lo.label, handle); + else + ret = EFI_LOAD_ERROR; } else { file_path = expand_media_path(lo.file_path); ret = EFI_CALL(efi_load_image(true, efi_root, file_path,
Kojima-san
On Mon, 6 Nov 2023 at 13:40, Masahisa Kojima masahisa.kojima@linaro.org wrote: [...]
- search_default_file() - search default file
- @dev: pointer to the UCLASS_BLK or UCLASS_PARTITION udevice
- @dp: pointer to default file device path
- Return: status code
efi_status_t ret;
return ret;
return ret;
goto err;
goto err;
goto err;
if (!full_path) {
goto err;
*dp = full_path;
+err:
return ret;
We discussed this offline, adding it here for completeness. What is happening here, is that we are mounting the blkmap disk and try to search boot options on the fly. Since u-boot will scan all boot options once a disk is probed, the boot option you are trying to find is already added in the EFI bootmgr. I think it's going to be easier to search for that specific boot option instead of re-scanning for it on the fly.
Thanks /Ilias
- check_disk_has_default_file() - load the default file
- @blk: pointer to the UCLASS_BLK udevice
efi_status_t ret;
return ret;
enum uclass_id id;
continue;
return ret;
- prepare_loaded_image() - prepare ramdisk for downloaded image
- @label: label of load option
- @addr: image address
- @size: image size
efi_status_t ret;
if (!blk)
goto err;
goto err;
return EFI_SUCCESS;
+err:
return ret;
- efi_bootmgr_release_uridp_resource() - cleanup uri device path resource
loaded_dp = NULL;
return ret;
- efi_bootmgr_image_return_notify() - return to efibootmgr callback
- @event: the event for which this notification function is registered
- @context: event context - not used in this function
void *context)
efi_status_t ret;
EFI_EXIT(ret);
- try_load_from_uri_path() - Handle the URI device path
- @uridp: uri device path
- @lo_label: label of load option
- @handle: pointer to handle for newly installed image
u16 *lo_label,
char *s;
int err;
int uri_len;
efi_status_t ret;
loaded_dp = NULL;
if (!s) {
if (err < 0)
if (!image_size)
* the default file.
goto err;
source_size = 0;
goto err;
} else {
goto err;
&event);
goto err;
return ret;
+err:
return ret;
- try_load_entry() - try to load image for boot option
lo.label, handle);
else
-- 2.34.1
Hi Ilias,
On Tue, 7 Nov 2023 at 18:37, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Kojima-san
efi_status_t ret;
return ret;
return ret;
goto err;
goto err;
goto err;
if (!full_path) {
goto err;
*dp = full_path;
+err:
return ret;
I'm now trying to implement loading a default file from the auto-generated boot option, I would like to consult with you.
My v9 implementation to load the default file from blkmap device is as follows.
/** * try_load_default_file() - try to load the default file * * Search the device having EFI_SIMPLE_FILE_SYSTEM_PROTOCOL, * then try to load with the default boot file(e.g. EFI/BOOT/BOOTAA64.EFI). * * @dev pointer to the UCLASS_BLK or UCLASS_PARTITION udevice * @image_handle: pointer to handle for newly installed image * Return: status code */ static efi_status_t try_load_default_file(struct udevice *dev, efi_handle_t *image_handle) { efi_status_t ret; efi_handle_t handle; struct efi_handler *handler; struct efi_device_path *file_path; struct efi_device_path *device_path;
if (dev_tag_get_ptr(dev, DM_TAG_EFI, (void **)&handle)) { log_warning("DM_TAG_EFI not found\n"); return EFI_INVALID_PARAMETER; }
ret = efi_search_protocol(handle,
&efi_simple_file_system_protocol_guid, &handler); if (ret != EFI_SUCCESS) return ret;
ret = EFI_CALL(bs->open_protocol(handle, &efi_guid_device_path, (void **)&device_path, efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL)); if (ret != EFI_SUCCESS) return ret;
file_path = expand_media_path(device_path); ret = EFI_CALL(efi_load_image(true, efi_root, file_path, NULL, 0, image_handle)); efi_free_pool(file_path);
return ret; }
Note that try_load_default_file() is repeatedly called with all child partition devices until it succeeds.
If we try to load the default file from the auto-generated boot option, we probably need to do the following steps. - search all auto-generated boot option - deserialize the boot option - check the boot option has device_path points to the blkmap blk/partition device - call expand_media_path() with the device_path of the boot option
Since we already have the devive_path of the blk/partition devices, I think it is simple we just call expand_media_path() with these device_path instead of searching for the boot option.
What do you think?
Thanks, Masahisa Kojima
Thanks /Ilias
efi_status_t ret;
return ret;
enum uclass_id id;
continue;
return ret;
- @size: image size
efi_status_t ret;
if (!blk)
goto err;
goto err;
return EFI_SUCCESS;
+err:
return ret;
loaded_dp = NULL;
return ret;
void *context)
efi_status_t ret;
EFI_EXIT(ret);
u16 *lo_label,
char *s;
int err;
int uri_len;
efi_status_t ret;
loaded_dp = NULL;
if (!s) {
if (err < 0)
if (!image_size)
* the default file.
goto err;
source_size = 0;
goto err;
} else {
goto err;
&event);
goto err;
return ret;
+err:
return ret;
lo.label, handle);
else
-- 2.34.1
Kojima-san
efi_status_t ret;
return ret;
return ret;
goto err;
goto err;
goto err;
if (!full_path) {
goto err;
*dp = full_path;
+err:
return ret;
- try_load_default_file() - try to load the default file
- Search the device having EFI_SIMPLE_FILE_SYSTEM_PROTOCOL,
- then try to load with the default boot file(e.g. EFI/BOOT/BOOTAA64.EFI).
- @dev pointer to the UCLASS_BLK or
- @image_handle: pointer to handle for newly installed image
if (dev_tag_get_ptr(dev, DM_TAG_EFI, (void **)&handle)) { log_warning("DM_TAG_EFI not found\n"); return EFI_INVALID_PARAMETER; } ret = efi_search_protocol(handle,
ret = EFI_CALL(bs->open_protocol(handle, &efi_guid_device_path, (void **)&device_path, efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL)); if (ret != EFI_SUCCESS) return ret; file_path = expand_media_path(device_path); ret = EFI_CALL(efi_load_image(true, efi_root, file_path, NULL, 0, image_handle)); efi_free_pool(file_path); return ret;
What do you think?
Fair enough, Can we then replace the open coded file_path = efi_dp_from_file(NULL, "/EFI/BOOT/" BOOTEFI_NAME); etc with expand_media_path? That function already search for the efi_simple_file_system_protocol_guid and we should avoid code duplication
Thanks /Ilias
Thanks /Ilias
efi_status_t ret;
return ret;
enum uclass_id id;
continue;
return ret;
- @size: image size
efi_status_t ret;
if (!blk)
goto err;
goto err;
return EFI_SUCCESS;
+err:
return ret;
loaded_dp = NULL;
return ret;
void *context)
efi_status_t ret;
EFI_EXIT(ret);
u16 *lo_label,
char *s;
int err;
int uri_len;
efi_status_t ret;
loaded_dp = NULL;
if (!s) {
if (err < 0)
if (!image_size)
* the default file.
goto err;
source_size = 0;
goto err;
} else {
goto err;
&event);
goto err;
return ret;
+err:
return ret;
lo.label, handle);
else
-- 2.34.1
Hi Ilias,
On Wed, 8 Nov 2023 at 17:02, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Kojima-san
efi_status_t ret;
return ret;
return ret;
goto err;
goto err;
goto err;
if (!full_path) {
goto err;
*dp = full_path;
+err:
return ret;
What do you think?
OK, I will remove the code duplication. I will also remove global variables, then send an updated version.
Thanks /Ilias
Thanks /Ilias
efi_status_t ret;
return ret;
enum uclass_id id;
continue;
return ret;
- @size: image size
efi_status_t ret;
if (!blk)
goto err;
goto err;
return EFI_SUCCESS;
+err:
return ret;
loaded_dp = NULL;
return ret;
void *context)
efi_status_t ret;
EFI_EXIT(ret);
u16 *lo_label,
char *s;
int err;
int uri_len;
efi_status_t ret;
loaded_dp = NULL;
if (!s) {
if (err < 0)
if (!image_size)
* the default file.
goto err;
source_size = 0;
goto err;
} else {
goto err;
&event);
goto err;
return ret;
+err:
return ret;
lo.label, handle);
else
-- 2.34.1
This adds the URI device path option for 'boot add' subcommand. User can add the URI load option for downloading ISO image file or EFI application through network. Currently HTTP is only supported.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- cmd/efidebug.c | 51 ++++++++++++++++++++++++++++++++++++ include/net.h | 8 ++++++ net/wget.c | 71 ++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 130 insertions(+)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 201531ac19..42b306e708 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -19,6 +19,7 @@ #include <log.h> #include <malloc.h> #include <mapmem.h> +#include <net.h> #include <part.h> #include <search.h> #include <linux/ctype.h> @@ -829,6 +830,53 @@ static int do_efi_boot_add(struct cmd_tbl *cmdtp, int flag, argc -= 1; argv += 1; break; +#if (IS_ENABLED(CONFIG_EFI_HTTP_BOOT)) + case 'u': + { + char *pos; + int uridp_len; + struct efi_device_path_uri *uridp; + + if (argc < 3 || lo.label) { + r = CMD_RET_USAGE; + goto out; + } + + id = (int)hextoul(argv[1], &endp); + if (*endp != '\0' || id > 0xffff) + return CMD_RET_USAGE; + + label = efi_convert_string(argv[2]); + if (!label) + return CMD_RET_FAILURE; + + if (!wget_validate_uri(argv[3])) { + printf("ERROR: invalid URI\n"); + r = CMD_RET_FAILURE; + goto out; + } + + efi_create_indexed_name(var_name16, sizeof(var_name16), + "Boot", id); + lo.label = label; + + uridp_len = sizeof(struct efi_device_path) + strlen(argv[3]) + 1; + fp_size += uridp_len + sizeof(END); + fp_free = efi_alloc(fp_size); + uridp = (struct efi_device_path_uri *)fp_free; + uridp->dp.type = DEVICE_PATH_TYPE_MESSAGING_DEVICE; + uridp->dp.sub_type = DEVICE_PATH_SUB_TYPE_MSG_URI; + uridp->dp.length = uridp_len; + strcpy(uridp->uri, argv[3]); + pos = (char *)uridp + uridp_len; + memcpy(pos, &END, sizeof(END)); + file_path = (struct efi_device_path *)uridp; + argc -= 3; + argv += 3; + break; + } +#endif + default: r = CMD_RET_USAGE; goto out; @@ -1491,6 +1539,9 @@ U_BOOT_LONGHELP(efidebug, " -b|-B <bootid> <label> <interface> <devnum>[:<part>] <file path>\n" " -i|-I <interface> <devnum>[:<part>] <initrd file path>\n" " (-b, -i for short form device path)\n" +#if (IS_ENABLED(CONFIG_EFI_HTTP_BOOT)) + " -u <bootid> <label> <uri>\n" +#endif " -s '<optional data>'\n" "efidebug boot rm <bootid#1> [<bootid#2> [<bootid#3> [...]]]\n" " - delete UEFI BootXXXX variables\n" diff --git a/include/net.h b/include/net.h index 57889d8b7a..c748974573 100644 --- a/include/net.h +++ b/include/net.h @@ -935,4 +935,12 @@ static inline void eth_set_enable_bootdevs(bool enable) {} */ int wget_with_dns(ulong dst_addr, char *uri);
+/** + * wget_validate_uri() - varidate the uri + * + * @uri: uri string of target file of wget + * Return: true if uri is valid, false if uri is invalid + */ +bool wget_validate_uri(char *uri); + #endif /* __NET_H__ */ diff --git a/net/wget.c b/net/wget.c index 2087146b37..6ae2237a0a 100644 --- a/net/wget.c +++ b/net/wget.c @@ -566,3 +566,74 @@ out: return ret; } #endif + +/** + * wget_validate_uri() - validate the uri for wget + * + * @uri: uri string + * + * This function follows the current U-Boot wget implementation. + * scheme: only "http:" is supported + * authority: + * - user information: not supported + * - host: supported + * - port: not supported(always use the default port) + * + * Uri is expected to be correctly percent encoded. + * This is the minimum check, control codes(0x1-0x19, 0x7F, except '\0') + * and space character(0x20) are not allowed. + * + * TODO: stricter uri conformance check + * + * Return: true on success, false on failure + */ +bool wget_validate_uri(char *uri) +{ + char c; + bool ret = true; + char *str_copy, *s, *authority; + + for (c = 0x1; c < 0x21; c++) { + if (strchr(uri, c)) { + log_err("invalid character is used\n"); + return false; + } + } + if (strchr(uri, 0x7f)) { + log_err("invalid character is used\n"); + return false; + } + + if (strncmp(uri, "http://", 7)) { + log_err("only http:// is supported\n"); + return false; + } + str_copy = strdup(uri); + if (!str_copy) + return false; + + s = str_copy + strlen("http://"); + authority = strsep(&s, "/"); + if (!s) { + log_err("invalid uri, no file path\n"); + ret = false; + goto out; + } + s = strchr(authority, '@'); + if (s) { + log_err("user information is not supported\n"); + ret = false; + goto out; + } + s = strchr(authority, ':'); + if (s) { + log_err("user defined port is not supported\n"); + ret = false; + goto out; + } + +out: + free(str_copy); + + return ret; +}
This adds the description about HTTP Boot.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- doc/develop/uefi/uefi.rst | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/doc/develop/uefi/uefi.rst b/doc/develop/uefi/uefi.rst index fb16ac743a..ca9a573669 100644 --- a/doc/develop/uefi/uefi.rst +++ b/doc/develop/uefi/uefi.rst @@ -642,6 +642,36 @@ UEFI variables. Booting according to these variables is possible via:: As of U-Boot v2020.10 UEFI variables cannot be set at runtime. The U-Boot command 'efidebug' can be used to set the variables.
+UEFI HTTP Boot +~~~~~~~~~~~~~~ + +HTTP Boot provides the capability for system deployment and configuration +over the network. HTTP Boot can be activated by specifying:: + + CONFIG_CMD_DNS + CONFIG_CMD_WGET + CONFIG_BLKMAP + +Set up the load option specifying the target URI:: + + efidebug boot add -u 1 netinst http://foo/bar + +When this load option is selected as boot selection, resolve the +host ip address by dns, then download the file with wget. +If the downloaded file extension is .iso or .img file, efibootmgr tries to +mount the image and boot with the default file(e.g. EFI/BOOT/BOOTAA64.EFI). +If the downloaded file is PE-COFF image, load the downloaded file and +start it. + +The current implementation tries to resolve the IP address as a host name. +If the uri is like "http://192.168.1.1/foobar", +the dns process tries to resolve the host "192.168.1.1" and it will +end up with "host not found". + +We need to preset the "httpserverip" environment variable to proceed the wget:: + + setenv httpserverip 192.168.1.1 + Executing the built in hello world application ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Ilias Apalodimas
Masahisa Kojima
