[U-Boot] [PATCH v4] armv7: ls102xa: Enable snooping on transactions from CAAM
CAAM IP lies behind SMMU in the system. Configure SMMU to do the following: a) Program SCR to bypass transactions with stream ID other than that of CAAM b) Program S2CR to change memroy attributes of transactions with CAAM's stream ID (0x10) to cacheable.
CC: Alison Wang alison.wang@nxp.com Signed-off-by: Ruchika Gupta ruchika.gupta@nxp.com Signed-off-by: Nitesh Narayan Lal nitesh.lal@nxp.com Signed-off-by: Aneesh Bansal aneesh.bansal@nxp.com --- Changes in v4: - Modified the Commit message - Functionality moved to SoC Specific file
The patch is dependent on http://patchwork.ozlabs.org/patch/579377/
arch/arm/cpu/armv7/ls102xa/soc.c | 5 +++ arch/arm/include/asm/arch-ls102xa/config.h | 2 ++ arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 35 ++++++++++++++++++++ .../include/asm/arch-ls102xa/ls102xa_stream_id.h | 1 + board/freescale/common/ls102xa_stream_id.c | 37 +++++++++++++++++++++- 5 files changed, 79 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/soc.c b/arch/arm/cpu/armv7/ls102xa/soc.c index b1b0c71..42cd31a 100644 --- a/arch/arm/cpu/armv7/ls102xa/soc.c +++ b/arch/arm/cpu/armv7/ls102xa/soc.c @@ -134,5 +134,10 @@ int ls102xa_smmu_stream_id_init(void) ls102xa_config_smmu_stream_id(dev_stream_id, ARRAY_SIZE(dev_stream_id));
+ /* Configure SMMU to make transactions with CAAM stream ID + * as cacheable + */ + ls1021x_config_smmu_caam_cacheable(0x10); + return 0; } diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 424fe87..f189ea8 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -62,6 +62,8 @@
#define LPUART_BASE (CONFIG_SYS_IMMR + 0x01950000)
+#define SMMU_BASE (CONFIG_SYS_IMMR + 0x300000) + #define CONFIG_SYS_PCIE1_ADDR (CONFIG_SYS_IMMR + 0x2400000) #define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_IMMR + 0x2500000)
diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index 0a80772..61da884 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -435,4 +435,39 @@ struct ccsr_ahci {
uint get_svr(void);
+/* MMU 400 */ +#define SMMU_NSCR (SMMU_BASE + 0x400) +#define SMMU_SMR (SMMU_BASE + 0x800) +#define SMMU_S2CR (SMMU_BASE + 0xc00) + +#define SMMU_NSCR_CLIENTPD_SHIFT 0 +#define SMMU_NSCR_MTCFG_SHIFT 20 + +#define SMR_SMR_VALID_SHIFT 31 +#define SMR_ID_MASK 0x7fff +#define SMR_MASK_SHIFT 16 + +#define S2CR_WACFG_SHIFT 22 +#define S2CR_WACFG_MASK 0x3 +#define S2CR_WACFG_WRITE_ALLOCATE 0x2 + +#define S2CR_RACFG_SHIFT 20 +#define S2CR_RACFG_MASK 0x3 +#define S2CR_RACFG_READ_ALLOCATE 0x2 + +#define S2CR_TYPE_SHIFT 16 +#define S2CR_TYPE_MASK 0x3 +#define S2CR_TYPE_BYPASS 0x01 + +#define S2CR_MEM_ATTR_SHIFT 12 +#define S2CR_MEM_ATTR_MASK 0xf +#define S2CR_MEM_ATTR_CACHEABLE 0xa + +#define S2CR_MTCFG 0x00000800 + +#define S2CR_SHCFG_SHIFT 8 +#define S2CR_SHCFG_MASK 0x3 +#define S2CR_SHCFG_OUTER_CACHEABLE 0x1 +#define S2CR_SHCFG_INNER_CACHEABLE 0x2 + #endif /* __ASM_ARCH_LS102XA_IMMAP_H_ */ diff --git a/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h b/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h index fa571b3..c1d22bf 100644 --- a/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h +++ b/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h @@ -71,4 +71,5 @@ struct smmu_stream_id {
void ls1021x_config_caam_stream_id(struct liodn_id_table *tbl, int size); void ls102xa_config_smmu_stream_id(struct smmu_stream_id *id, uint32_t num); +void ls1021x_config_smmu_caam_cacheable(uint32_t liodn); #endif diff --git a/board/freescale/common/ls102xa_stream_id.c b/board/freescale/common/ls102xa_stream_id.c index f434269..8e28d64 100644 --- a/board/freescale/common/ls102xa_stream_id.c +++ b/board/freescale/common/ls102xa_stream_id.c @@ -7,6 +7,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/ls102xa_stream_id.h> +#include <asm/arch/immap_ls102xa.h>
void ls102xa_config_smmu_stream_id(struct smmu_stream_id *id, uint32_t num) { @@ -20,7 +21,7 @@ void ls102xa_config_smmu_stream_id(struct smmu_stream_id *id, uint32_t num) void ls1021x_config_caam_stream_id(struct liodn_id_table *tbl, int size) { int i; - u32 liodn; + uint32_t liodn;
for (i = 0; i < size; i++) { if (tbl[i].num_ids == 2) @@ -31,3 +32,37 @@ void ls1021x_config_caam_stream_id(struct liodn_id_table *tbl, int size) out_le32((uint32_t *)(tbl[i].reg_offset), liodn); } } + +void ls1021x_config_smmu_caam_cacheable(uint32_t liodn) +{ + uint32_t *addr; + uint32_t smr, s2cr, nscr; + + addr = (uint32_t *)(SMMU_NSCR); + /* SMMU NSCR configuration */ + nscr = in_le32(addr); + + nscr = nscr & ~(1 << SMMU_NSCR_CLIENTPD_SHIFT | + 1 << SMMU_NSCR_MTCFG_SHIFT); + out_le32(addr, nscr); + + /* SMMU SMR configuration */ + addr = (uint32_t *)(SMMU_SMR); + + smr = 0; + smr = smr & (~(SMR_ID_MASK << SMR_MASK_SHIFT)); + smr = smr | (1 << SMR_SMR_VALID_SHIFT) | liodn; + + out_le32(addr, smr); + + /* SMMU S2CR configuration */ + addr = (uint32_t *)(SMMU_S2CR); + s2cr = (S2CR_WACFG_WRITE_ALLOCATE << S2CR_WACFG_SHIFT) | + (S2CR_RACFG_READ_ALLOCATE << S2CR_RACFG_SHIFT) | + (S2CR_TYPE_BYPASS << S2CR_TYPE_SHIFT) | + (S2CR_MEM_ATTR_CACHEABLE << S2CR_MEM_ATTR_SHIFT) | + S2CR_MTCFG | + (S2CR_SHCFG_OUTER_CACHEABLE << S2CR_SHCFG_SHIFT); + + out_le32(addr, s2cr); +}
Aneesh Bansal
