[PATCH] lz4: fix decompressor on big-endian powerpc
Booting an lz4-compressed kernel image fails on our powerpc board with -EPROTONOSUPPORT. Adding a bit of debug prints, we get
magic: 0x184d2204 flags: 0x64 reserved0: 1 has_content_checksum: 1 has_content_size: 0 has_block_checksum: 0 independent_blocks: 1 version: 0 block_descriptor: 70 reserved1: 7 max_block_size: 0 reserved2: 0
So the magic is ok, but the version check fails, also some reserved bits are apparently set. But that's because the code interprets the "flags" and "block_descriptor" bytes wrongly:
Using bit-fields to access individual bits of an "on the wire" format is not portable, not even when restricted to the C flavour implemented by gcc. Quoting the gcc manual:
* 'The order of allocation of bit-fields within a unit (C90 6.5.2.1, C99 and C11 6.7.2.1).'
Determined by ABI.
and indeed, the PPC Processor ABI supplement says
* Bit-fields are allocated from right to left (least to most significant) on Little-Endian implementations and from left to right (most to least significant) on Big-Endian implementations.
I'm a bit puzzled about the github.com/Cyan4973/lz4 reference. Cyan4973 is Yann Collet, the author of lz4, and nowadays at least that github url redirects to the upstream repo, github.com/lz4/lz4. Grepping through all available tags and branches there, the identifiers "has_content_checksum" and "lz4_frame_header" have never appeared anywhere in the source (and he uses camelCase).
In any case, the upstream code at least now uses explicit shifts and masks for encoding/decoding:
/* FLG Byte */ *dstPtr++ = (BYTE)(((1 & _2BITS) << 6) /* Version('01') */ + ((cctxPtr->prefs.frameInfo.blockMode & _1BIT ) << 5) + ((cctxPtr->prefs.frameInfo.blockChecksumFlag & _1BIT ) << 4) + ((unsigned)(cctxPtr->prefs.frameInfo.contentSize > 0) << 3) + ((cctxPtr->prefs.frameInfo.contentChecksumFlag & _1BIT ) << 2) + (cctxPtr->prefs.frameInfo.dictID > 0) );
/* Flags */ { U32 const FLG = srcPtr[4]; U32 const version = (FLG>>6) & _2BITS; blockChecksumFlag = (FLG>>4) & _1BIT; blockMode = (FLG>>5) & _1BIT; contentSizeFlag = (FLG>>3) & _1BIT; contentChecksumFlag = (FLG>>2) & _1BIT; dictIDFlag = FLG & _1BIT; /* validate */ if (((FLG>>1)&_1BIT) != 0) return err0r(LZ4F_ERROR_reservedFlag_set); /* Reserved bit */ if (version != 1) return err0r(LZ4F_ERROR_headerVersion_wrong); /* Version Number, only supported value */ }
Do the same here, and while at it, be more careful to use unaligned accessors to what is most likely unaligned.
This has been tested partly, of course, by seeing that my lz4-compressed kernel now boots, partly by running the (de)compression test-suite in the (x86_64) sandbox - i.e., it should still work just fine on little-endian hosts.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- lib/lz4_wrapper.c | 96 ++++++++++++++++++++--------------------------- 1 file changed, 40 insertions(+), 56 deletions(-)
diff --git a/lib/lz4_wrapper.c b/lib/lz4_wrapper.c index 1e1e8d5085..16ffff5acb 100644 --- a/lib/lz4_wrapper.c +++ b/lib/lz4_wrapper.c @@ -9,6 +9,7 @@ #include <lz4.h> #include <linux/kernel.h> #include <linux/types.h> +#include <asm/unaligned.h>
static u16 LZ4_readLE16(const void *src) { return le16_to_cpu(*(u16 *)src); } static void LZ4_copy4(void *dst, const void *src) { *(u32 *)dst = *(u32 *)src; } @@ -22,45 +23,11 @@ typedef uint64_t U64;
#define FORCE_INLINE static inline __attribute__((always_inline))
-/* Unaltered (except removing unrelated code) from github.com/Cyan4973/lz4. */ +/* Originally from github.com/Cyan4973/lz4, fixed to avoid relying on bit-field ordering. */ + #include "lz4.c" /* #include for inlining, do not link! */
-struct lz4_frame_header { - u32 magic; - union { - u8 flags; - struct { - u8 reserved0:2; - u8 has_content_checksum:1; - u8 has_content_size:1; - u8 has_block_checksum:1; - u8 independent_blocks:1; - u8 version:2; - }; - }; - union { - u8 block_descriptor; - struct { - u8 reserved1:4; - u8 max_block_size:3; - u8 reserved2:1; - }; - }; - /* + u64 content_size iff has_content_size is set */ - /* + u8 header_checksum */ -} __packed; - -struct lz4_block_header { - union { - u32 raw; - struct { - u32 size:31; - u32 not_compressed:1; - }; - }; - /* + size bytes of data */ - /* + u32 block_checksum iff has_block_checksum is set */ -} __packed; +#define LZ4F_BLOCKUNCOMPRESSED_FLAG 0x80000000U
int ulz4fn(const void *src, size_t srcn, void *dst, size_t *dstn) { @@ -72,53 +39,70 @@ int ulz4fn(const void *src, size_t srcn, void *dst, size_t *dstn) *dstn = 0;
{ /* With in-place decompression the header may become invalid later. */ - const struct lz4_frame_header *h = in; + u32 magic; + u8 flags, version, independent_blocks, has_content_size; + u8 block_desc;
- if (srcn < sizeof(*h) + sizeof(u64) + sizeof(u8)) + if (srcn < sizeof(u32) + 3*sizeof(u8)) return -EINVAL; /* input overrun */
+ magic = get_unaligned_le32(in); + in += sizeof(u32); + flags = *(u8 *)in; + in += sizeof(u8); + block_desc = *(u8 *)in; + in += sizeof(u8); + + version = (flags >> 6) & 0x3; + independent_blocks = (flags >> 5) & 0x1; + has_block_checksum = (flags >> 4) & 0x1; + has_content_size = (flags >> 3) & 0x1; + /* We assume there's always only a single, standard frame. */ - if (le32_to_cpu(h->magic) != LZ4F_MAGIC || h->version != 1) + if (magic != LZ4F_MAGIC || version != 1) return -EPROTONOSUPPORT; /* unknown format */ - if (h->reserved0 || h->reserved1 || h->reserved2) - return -EINVAL; /* reserved must be zero */ - if (!h->independent_blocks) + if ((flags & 0x03) || (block_desc & 0x8f)) + return -EINVAL; /* reserved bits must be zero */ + if (!independent_blocks) return -EPROTONOSUPPORT; /* we can't support this yet */ - has_block_checksum = h->has_block_checksum;
- in += sizeof(*h); - if (h->has_content_size) + if (has_content_size) { + if (srcn < sizeof(u32) + 3*sizeof(u8) + sizeof(u64)) + return -EINVAL; /* input overrun */ in += sizeof(u64); + } + /* Header checksum byte */ in += sizeof(u8); }
while (1) { - struct lz4_block_header b; + u32 block_header, block_size;
- b.raw = le32_to_cpu(*(u32 *)in); - in += sizeof(struct lz4_block_header); + block_header = get_unaligned_le32(in); + in += sizeof(u32); + block_size = block_header & ~LZ4F_BLOCKUNCOMPRESSED_FLAG;
- if (in - src + b.size > srcn) { + if (in - src + block_size > srcn) { ret = -EINVAL; /* input overrun */ break; }
- if (!b.size) { + if (!block_size) { ret = 0; /* decompression successful */ break; }
- if (b.not_compressed) { - size_t size = min((ptrdiff_t)b.size, end - out); + if (block_header & LZ4F_BLOCKUNCOMPRESSED_FLAG) { + size_t size = min((ptrdiff_t)block_size, end - out); memcpy(out, in, size); out += size; - if (size < b.size) { + if (size < block_size) { ret = -ENOBUFS; /* output overrun */ break; } } else { /* constant folding essential, do not touch params! */ - ret = LZ4_decompress_generic(in, out, b.size, + ret = LZ4_decompress_generic(in, out, block_size, end - out, endOnInputSize, full, 0, noDict, out, NULL, 0); if (ret < 0) { @@ -128,7 +112,7 @@ int ulz4fn(const void *src, size_t srcn, void *dst, size_t *dstn) out += ret; }
- in += b.size; + in += block_size; if (has_block_checksum) in += sizeof(u32); }
That comment refers to the lz4.c file that's included by the line right below it. That was copied 1-to-1 from Yann's code. The lz4_wrapper.c file was written from scratch by me.
Reviewed-by: Julius Werner jwerner@chromium.org
Ah, that explains in. And then my update of the comment makes it more confusing. I'll resend with another change of that comment (and updated commit log), but the code changes the same.
Thanks, Rasmus
Determined by ABI.
The upstream code (github.com/lz4/lz4) uses explicit shifts and masks for encoding/decoding:
Do the same here, and while at it, be more careful to use unaligned accessors to what is most likely unaligned. Also update the comment to make it clear that it only refers to the lz4.c file, not the following code of lz4_wrapper.c.
Reviewed-by: Julius Werner jwerner@chromium.org Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- v2: Update comment more accurately, adjust commit log, add Julius' R-b.
lib/lz4_wrapper.c | 95 +++++++++++++++++++---------------------------- 1 file changed, 39 insertions(+), 56 deletions(-)
diff --git a/lib/lz4_wrapper.c b/lib/lz4_wrapper.c index 1e1e8d5085..e0f7d3688e 100644 --- a/lib/lz4_wrapper.c +++ b/lib/lz4_wrapper.c @@ -9,6 +9,7 @@ #include <lz4.h> #include <linux/kernel.h> #include <linux/types.h> +#include <asm/unaligned.h>
static u16 LZ4_readLE16(const void *src) { return le16_to_cpu(*(u16 *)src); } static void LZ4_copy4(void *dst, const void *src) { *(u32 *)dst = *(u32 *)src; } @@ -22,45 +23,10 @@ typedef uint64_t U64;
-/* Unaltered (except removing unrelated code) from github.com/Cyan4973/lz4. */ +/* lz4.c is unaltered (except removing unrelated code) from github.com/Cyan4973/lz4. */ #include "lz4.c" /* #include for inlining, do not link! */
int ulz4fn(const void *src, size_t srcn, void *dst, size_t *dstn) { @@ -72,53 +38,70 @@ int ulz4fn(const void *src, size_t srcn, void *dst, size_t *dstn) *dstn = 0;
- if (b.not_compressed) { - size_t size = min((ptrdiff_t)b.size, end - out); + if (block_header & LZ4F_BLOCKUNCOMPRESSED_FLAG) { + size_t size = min((ptrdiff_t)block_size, end - out); memcpy(out, in, size); out += size; - if (size < b.size) { + if (size < block_size) { ret = -ENOBUFS; /* output overrun */ break; } } else { /* constant folding essential, do not touch params! */ - ret = LZ4_decompress_generic(in, out, b.size, + ret = LZ4_decompress_generic(in, out, block_size, end - out, endOnInputSize, full, 0, noDict, out, NULL, 0); if (ret < 0) { @@ -128,7 +111,7 @@ int ulz4fn(const void *src, size_t srcn, void *dst, size_t *dstn) out += ret; }
Determined by ABI.
- Bit-fields are allocated from right to left (least to most significant) on Little-Endian implementations and from left to right (most to least significant) on Big-Endian implementations.
/* FLG Byte */ *dstPtr++ = (BYTE)(((1 & _2BITS) << 6) /* Version('01') */ + ((cctxPtr->prefs.frameInfo.blockMode & _1BIT ) << 5) + ((cctxPtr->prefs.frameInfo.blockChecksumFlag & _1BIT ) << 4) + ((unsigned)(cctxPtr->prefs.frameInfo.contentSize > 0) << 3) + ((cctxPtr->prefs.frameInfo.contentChecksumFlag & _1BIT ) << 2) + (cctxPtr->prefs.frameInfo.dictID > 0) ); /* Flags */ { U32 const FLG = srcPtr[4]; U32 const version = (FLG>>6) & _2BITS; blockChecksumFlag = (FLG>>4) & _1BIT; blockMode = (FLG>>5) & _1BIT; contentSizeFlag = (FLG>>3) & _1BIT; contentChecksumFlag = (FLG>>2) & _1BIT; dictIDFlag = FLG & _1BIT; /* validate */ if (((FLG>>1)&_1BIT) != 0) return err0r(LZ4F_ERROR_reservedFlag_set); /* Reserved bit */ if (version != 1) return err0r(LZ4F_ERROR_headerVersion_wrong); /* Version Number, only supported value */ }
Julius Werner
Rasmus Villemoes
