[U-Boot] [PATCH 1/1] lcd: align fb writing address for horizontal display offset
CONFIG_SPLASH_SCREEN_ALIGN makes uboot support display offset for splashimage. The framebuffer writing address should be calculated according to different kinds of framebuffer pixel format, i.e., bits per pixel value.
Signed-off-by: Liu Ying Ying.Liu@freescale.com --- common/lcd.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index d854c21..0555ab4 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -731,7 +731,7 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y)
bmap = (uchar *)bmp + le32_to_cpu (bmp->header.data_offset); fb = (uchar *) (lcd_base + - (y + height - 1) * lcd_line_length + x); + (y + height - 1) * lcd_line_length + x * bpix / 8);
switch (bmp_bpix) { case 1: /* pass through */
Hello,
I sent the following patch for view about 2 weeks ago and haven't got any comment till now. Could anyone help to give comments? Thanks.
Best Regards, Liu Ying -----Original Message----- From: Liu Ying-B17645 Sent: Tuesday, January 11, 2011 3:30 PM To: u-boot@lists.denx.de Cc: Liu Ying-B17645 Subject: [U-Boot][PATCH 1/1] lcd: align fb writing address for horizontal display offset
switch (bmp_bpix) { case 1: /* pass through */ -- 1.6.3.3
Dear Liu Ying-B17645,
In message D62B998DB8EFB547B4D75C9E57658A7F0BED86@039-SN1MPN1-006.039d.mgd.msft.net you wrote:
Hello,
I sent the following patch for view about 2 weeks ago and haven't got any c= omment till now. Could anyone help to give comments? Thanks.
It would definitely help if you put the responsible custodian on Cc:
[Done now.]
Hello,
On Wed, 26 Jan 2011 01:52:33 +0000 Liu Ying-B17645 B17645@freescale.com wrote:
Hello,
Thanks! Your patch is delegated to me and is currently under review, please see [1]. Sorry it takes so long, I'm quite busy now, but I'll have a look at it soon. Please put me on Cc: next time when submitting video related patches, it should help.
Best regards, Anatolij
Hello,
Applied to u-boot-video/master. Thanks!
Anatolij
Hello, Anatolij,
Thanks for your review!
Best Regards, Liu Ying -----Original Message----- From: Anatolij Gustschin [mailto:agust@denx.de] Sent: Thursday, January 27, 2011 7:29 AM To: Liu Ying-B17645 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH 1/1] lcd: align fb writing address for horizontal display offset
Hello,
Anatolij
Anatolij Gustschin
Liu Ying
Liu Ying-B17645
