[U-Boot] [PATCH 00/12] various fixes mainly for pxa and colibri_pxa270
The following is a set of various fixes mainly for PXA and the Toradex Colibri PXA270 introducing it to generic board to save it from becoming obsolete as those modules are still on sale for another 3 to 4 years.
Marcel Ziswiler (12): pxa: fix wrong comment about vpac270 being the arch number remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZ pxa: balloon3: remove nowhere used symbol CONFIG_SYS_MEM_BUF_IMP pxa: balloon3: fix comment about sdram banks pxa: balloon3/colibri_pxa270: fix environment optionally being nowhere pxa: colibri_pxa270: migrate to generic board pxa: colibri_pxa270: disable loadb/s commands and long help pxa: colibri_pxa270: avoid overwriting factory configuration block pxa: colibri_pax270: fix CONFIG_BOOTCOMMAND pxa: colibri_pxa270: fix wrong comment about voipac ethernet chip pxa: colibri_pxa270: remove CONFIG_ENV_ADDR_REDUND pxa: colibri_pxa270: integrate latest validated register settings
board/balloon3/balloon3.c | 2 +- board/toradex/colibri_pxa270/colibri_pxa270.c | 2 +- include/configs/balloon3.h | 10 ++-- include/configs/colibri_pxa270.h | 77 ++++++++++++++------------- include/configs/flea3.h | 2 - include/configs/mx35pdk.h | 2 - include/configs/palmld.h | 1 - include/configs/palmtc.h | 1 - include/configs/palmtreo680.h | 1 - include/configs/snowball.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/u8500_href.h | 1 - include/configs/vexpress_common.h | 1 - include/configs/vpac270.h | 3 +- include/configs/woodburn_common.h | 2 - include/configs/zipitz2.h | 1 - 16 files changed, 47 insertions(+), 61 deletions(-)
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- board/balloon3/balloon3.c | 2 +- board/toradex/colibri_pxa270/colibri_pxa270.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/balloon3/balloon3.c b/board/balloon3/balloon3.c index aa108ca..458d90c 100644 --- a/board/balloon3/balloon3.c +++ b/board/balloon3/balloon3.c @@ -29,7 +29,7 @@ int board_init(void) dcache_disable(); icache_disable();
- /* arch number of vpac270 */ + /* arch number of balloon3 */ gd->bd->bi_arch_number = MACH_TYPE_BALLOON3;
/* adress of boot parameters */ diff --git a/board/toradex/colibri_pxa270/colibri_pxa270.c b/board/toradex/colibri_pxa270/colibri_pxa270.c index 8d95e4d..3def0a6 100644 --- a/board/toradex/colibri_pxa270/colibri_pxa270.c +++ b/board/toradex/colibri_pxa270/colibri_pxa270.c @@ -23,7 +23,7 @@ int board_init(void) dcache_disable(); icache_disable();
- /* arch number of vpac270 */ + /* arch number of Toradex Colibri PXA270 */ gd->bd->bi_arch_number = MACH_TYPE_COLIBRI;
Basically finish what the following commit started a long time ago:
488f5d8790c451fc527fe5d2ef218f2a5e40ea17
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- include/configs/balloon3.h | 1 - include/configs/flea3.h | 2 -- include/configs/mx35pdk.h | 2 -- include/configs/palmld.h | 1 - include/configs/palmtc.h | 1 - include/configs/palmtreo680.h | 1 - include/configs/snowball.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/u8500_href.h | 1 - include/configs/vexpress_common.h | 1 - include/configs/woodburn_common.h | 2 -- include/configs/zipitz2.h | 1 - 12 files changed, 15 deletions(-)
diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h index 2f5a660..8dabc80 100644 --- a/include/configs/balloon3.h +++ b/include/configs/balloon3.h @@ -84,7 +84,6 @@ /* * Clock Configuration */ -#undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_SYS_CPUSPEED 0x290 /* 520MHz */
/* diff --git a/include/configs/flea3.h b/include/configs/flea3.h index bf02829..edff0f5 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -124,8 +124,6 @@ #define CONFIG_SYS_MEMTEST_START 0 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x10000
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
/* diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index a145f08..603d17c 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -146,8 +146,6 @@ #define CONFIG_SYS_MEMTEST_START 0 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x10000
/* diff --git a/include/configs/palmld.h b/include/configs/palmld.h index 9480d8d..7dbc9ae 100644 --- a/include/configs/palmld.h +++ b/include/configs/palmld.h @@ -114,7 +114,6 @@ /* * Clock Configuration */ -#undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_SYS_CPUSPEED 0x210 /* 416MHz ; N=2,L=16 */
/* diff --git a/include/configs/palmtc.h b/include/configs/palmtc.h index 8abce1b..75506b2 100644 --- a/include/configs/palmtc.h +++ b/include/configs/palmtc.h @@ -116,7 +116,6 @@ /* * Clock Configuration */ -#undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_SYS_CPUSPEED 0x161 /* 400MHz;L=1 M=3 T=1 */
/* diff --git a/include/configs/palmtreo680.h b/include/configs/palmtreo680.h index 6490be5..bd0f44b 100644 --- a/include/configs/palmtreo680.h +++ b/include/configs/palmtreo680.h @@ -117,7 +117,6 @@ /* * Clock Configuration */ -#undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_SYS_CPUSPEED 0x210 /* 416MHz ; N=2,L=16 */
/* diff --git a/include/configs/snowball.h b/include/configs/snowball.h index dacb560..126201c 100644 --- a/include/configs/snowball.h +++ b/include/configs/snowball.h @@ -175,7 +175,6 @@ #define CONFIG_SYS_MAXARGS 32 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Arg Buffer Size */
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ #define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1
diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 87a4efc..f69a559 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -58,7 +58,6 @@ + sizeof(CONFIG_SYS_PROMPT) + 16) /* print buffer size */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* boot arg buffer size */
-#undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */
#define CONFIG_CMD_ASKEN diff --git a/include/configs/u8500_href.h b/include/configs/u8500_href.h index 8d7970a..5302b1f 100644 --- a/include/configs/u8500_href.h +++ b/include/configs/u8500_href.h @@ -131,7 +131,6 @@ #define CONFIG_SYS_MAXARGS 32 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Arg Buffer Size */
diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index 2dea921..989e755 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -188,7 +188,6 @@ #define CONFIG_BOOTP_PXE_CLIENTARCH 0x100
/* Miscellaneous configurable options */ -#undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_SYS_LOAD_ADDR (V2M_BASE + 0x8000) #define LINUX_BOOT_PARAM_ADDR (V2M_BASE + 0x2000) #define CONFIG_BOOTDELAY 2 diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index c7a17f7..8e1c7a4 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -146,8 +146,6 @@ #define CONFIG_SYS_MEMTEST_START 0 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x10000
/* diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index fe331bc..1dbbc15 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -136,7 +136,6 @@ unsigned char zipitz2_spi_read(void); /* * Clock Configuration */ -#undef CONFIG_SYS_CLKS_IN_HZ #define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */
Hi Marcel,
For mx35pdk/woodburn:
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- include/configs/balloon3.h | 1 - include/configs/vpac270.h | 1 - 2 files changed, 2 deletions(-)
diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h index 8dabc80..f20a631 100644 --- a/include/configs/balloon3.h +++ b/include/configs/balloon3.h @@ -190,7 +190,6 @@ #define CONFIG_SYS_MDMRS_VAL 0x00220022 #define CONFIG_SYS_FLYCNFG_VAL 0x00000000 #define CONFIG_SYS_SXCNFG_VAL 0x00000000 -#define CONFIG_SYS_MEM_BUF_IMP 0x0f
/* * PCMCIA and CF Interfaces diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index 2fb91a8..e54601d 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -297,7 +297,6 @@ #define CONFIG_SYS_MDMRS_VAL 0x00000000 #define CONFIG_SYS_FLYCNFG_VAL 0x00000000 #define CONFIG_SYS_SXCNFG_VAL 0x40044004 -#define CONFIG_SYS_MEM_BUF_IMP 0x0f
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- include/configs/balloon3.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h index f20a631..e7f0345 100644 --- a/include/configs/balloon3.h +++ b/include/configs/balloon3.h @@ -13,7 +13,7 @@ * High Level Board Configuration Options */ #define CONFIG_CPU_PXA27X 1 /* Marvell PXA270 CPU */ -#define CONFIG_BALLOON3 1 /* Balloon3 board */ +#define CONFIG_BALLOON3 1 /* Balloon3 board */
/* * Environment settings @@ -89,12 +89,12 @@ /* * DRAM Map */ -#define CONFIG_NR_DRAM_BANKS 3 /* 2 banks of DRAM */ +#define CONFIG_NR_DRAM_BANKS 3 /* 3 banks of DRAM */ #define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ #define PHYS_SDRAM_2 0xb0000000 /* SDRAM Bank #2 */ #define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ -#define PHYS_SDRAM_3 0x80000000 /* SDRAM Bank #2 */ +#define PHYS_SDRAM_3 0x80000000 /* SDRAM Bank #3 */ #define PHYS_SDRAM_3_SIZE 0x08000000 /* 128 MB */
#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */
I couldn't quite figure out whether or not CONFIG_SYS_ENV_IS_NOWHERE actually ever worked but nowadays this is called CONFIG_ENV_IS_NOWHERE.
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- include/configs/balloon3.h | 2 +- include/configs/colibri_pxa270.h | 2 +- include/configs/vpac270.h | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h index e7f0345..848a158 100644 --- a/include/configs/balloon3.h +++ b/include/configs/balloon3.h @@ -134,7 +134,7 @@ #define CONFIG_ENV_IS_IN_FLASH #else #define CONFIG_SYS_NO_FLASH -#define CONFIG_SYS_ENV_IS_NOWHERE +#define CONFIG_ENV_IS_NOWHERE #endif
#define CONFIG_SYS_MONITOR_BASE 0x000000 diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index 08bd276..b8df89c 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -142,7 +142,7 @@
#else /* No flash */ #define CONFIG_SYS_NO_FLASH -#define CONFIG_SYS_ENV_IS_NOWHERE +#define CONFIG_ENV_IS_NOWHERE #endif
#define CONFIG_SYS_MONITOR_BASE 0x0 diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index e54601d..887433b 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -221,7 +221,7 @@
Migrate Toradex Colibri PXA270 to use CONFIG_SYS_GENERIC_BOARD.
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- include/configs/colibri_pxa270.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index b8df89c..bb48419 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -2,6 +2,7 @@ * Toradex Colibri PXA270 configuration file * * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * Copyright (C) 2015 Marcel Ziswiler marcel@ziswiler.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -13,6 +14,7 @@ * High Level Board Configuration Options */ #define CONFIG_CPU_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_SYS_GENERIC_BOARD #define CONFIG_SYS_TEXT_BASE 0x0
To save more than 20 KB of precious space in NOR flash get rid of the following configuration options:
CONFIG_CMD_LOADB CONFIG_CMD_LOADS CONFIG_SYS_LONGHELP
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- include/configs/colibri_pxa270.h | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index bb48419..c2714f7 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -52,6 +52,8 @@ */ #include <config_cmd_default.h>
+#undef CONFIG_CMD_LOADB /* Both together */ +#undef CONFIG_CMD_LOADS /* saves 10 KB */ #define CONFIG_CMD_NET #define CONFIG_CMD_ENV #undef CONFIG_CMD_IMLS @@ -84,7 +86,7 @@ */ #define CONFIG_SYS_HUSH_PARSER 1
-#define CONFIG_SYS_LONGHELP +#undef CONFIG_SYS_LONGHELP /* Saves 10 KB */ #ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT "$ " #else
Specify a CONFIG_BOARD_SIZE_LIMIT of 256 KB in order to avoid overwriting the factory configuration block located at offset 0x40000 in NOR flash.
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- include/configs/colibri_pxa270.h | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index c2714f7..1b1816a 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -7,8 +7,8 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_H +#define __CONFIG_H
/* * High Level Board Configuration Options @@ -16,6 +16,8 @@ #define CONFIG_CPU_PXA27X 1 /* Marvell PXA270 CPU */ #define CONFIG_SYS_GENERIC_BOARD #define CONFIG_SYS_TEXT_BASE 0x0 +/* Avoid overwriting factory configuration block */ +#define CONFIG_BOARD_SIZE_LIMIT 0x40000
/* * Environment settings @@ -100,7 +102,6 @@ #define CONFIG_CMDLINE_EDITING 1 #define CONFIG_AUTO_COMPLETE 1
- /* * Clock Configuration */ @@ -150,10 +151,11 @@ #endif
#define CONFIG_SYS_MONITOR_BASE 0x0 -#define CONFIG_SYS_MONITOR_LEN 0x80000 +#define CONFIG_SYS_MONITOR_LEN 0x40000
+/* Skip factory configuration block */ #define CONFIG_ENV_ADDR \ - (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN + 0x40000) #define CONFIG_ENV_SIZE 0x40000 #define CONFIG_ENV_SECT_SIZE 0x40000 #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) @@ -219,4 +221,4 @@
#include "pxa-common.h"
-#endif /* __CONFIG_H */ +#endif /* __CONFIG_H */
While 'mmc init' is no longer required the address to bootm the kernel from NOR flash was wrong.
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- include/configs/colibri_pxa270.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index 1b1816a..07426d1 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -26,13 +26,13 @@ #define CONFIG_SYS_MALLOC_LEN (128 * 1024) #define CONFIG_ARCH_CPU_INIT #define CONFIG_BOOTCOMMAND \ - "if mmc init && fatload mmc 0 0xa0000000 uImage; then " \ + "if fatload mmc 0 0xa0000000 uImage; then " \ "bootm 0xa0000000; " \ "fi; " \ "if usb reset && fatload usb 0 0xa0000000 uImage; then " \ "bootm 0xa0000000; " \ "fi; " \ - "bootm 0x80000;" + "bootm 0xc0000;" #define CONFIG_BOOTARGS "console=tty0 console=ttyS0,115200" #define CONFIG_TIMESTAMP #define CONFIG_BOOTDELAY 2 /* Autoboot delay */
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- include/configs/colibri_pxa270.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index 07426d1..28e57b5 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -65,7 +65,6 @@
/* * Networking Configuration - * chip on the Voipac PXA270 board */ #ifdef CONFIG_CMD_NET #define CONFIG_CMD_PING
Usually not required for NOR flash.
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- include/configs/colibri_pxa270.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index 28e57b5..ed0589a 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -157,8 +157,6 @@ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN + 0x40000) #define CONFIG_ENV_SIZE 0x40000 #define CONFIG_ENV_SECT_SIZE 0x40000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
/* * GPIO settings
Integrate latest validated register settings from Toradex WinCE BSP 4.2 working accross all module versions from early V1.x, V1.2D, V2.2B to V2.4A.
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- include/configs/colibri_pxa270.h | 48 ++++++++++++++++++++-------------------- 1 file changed, 24 insertions(+), 24 deletions(-)
diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index ed0589a..7fc364e 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -163,7 +163,7 @@ */ #define CONFIG_SYS_GPSR0_VAL 0x00000000 #define CONFIG_SYS_GPSR1_VAL 0x00020000 -#define CONFIG_SYS_GPSR2_VAL 0x0002C000 +#define CONFIG_SYS_GPSR2_VAL 0x0002c000 #define CONFIG_SYS_GPSR3_VAL 0x00000000
#define CONFIG_SYS_GPCR0_VAL 0x00000000 @@ -171,19 +171,19 @@ #define CONFIG_SYS_GPCR2_VAL 0x00000000 #define CONFIG_SYS_GPCR3_VAL 0x00000000
-#define CONFIG_SYS_GPDR0_VAL 0x08000000 -#define CONFIG_SYS_GPDR1_VAL 0x0002A981 -#define CONFIG_SYS_GPDR2_VAL 0x0202FC00 -#define CONFIG_SYS_GPDR3_VAL 0x00000000 +#define CONFIG_SYS_GPDR0_VAL 0xc8008000 +#define CONFIG_SYS_GPDR1_VAL 0xfc02a981 +#define CONFIG_SYS_GPDR2_VAL 0x92c3ffff +#define CONFIG_SYS_GPDR3_VAL 0x0061e804
-#define CONFIG_SYS_GAFR0_L_VAL 0x00100000 -#define CONFIG_SYS_GAFR0_U_VAL 0x00C00010 -#define CONFIG_SYS_GAFR1_L_VAL 0x999A901A -#define CONFIG_SYS_GAFR1_U_VAL 0xAAA00008 -#define CONFIG_SYS_GAFR2_L_VAL 0xAAAAAAAA -#define CONFIG_SYS_GAFR2_U_VAL 0x0109A000 -#define CONFIG_SYS_GAFR3_L_VAL 0x54000300 -#define CONFIG_SYS_GAFR3_U_VAL 0x00024001 +#define CONFIG_SYS_GAFR0_L_VAL 0x80100000 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5c00010 +#define CONFIG_SYS_GAFR1_L_VAL 0x6992901a +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa50008 +#define CONFIG_SYS_GAFR2_L_VAL 0xaaaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x4109a002 +#define CONFIG_SYS_GAFR3_L_VAL 0x54000310 +#define CONFIG_SYS_GAFR3_U_VAL 0x00005401
#define CONFIG_SYS_PSSR_VAL 0x30
@@ -196,24 +196,24 @@ /* * Memory settings */ -#define CONFIG_SYS_MSC0_VAL 0x000095f2 -#define CONFIG_SYS_MSC1_VAL 0x00007ff4 -#define CONFIG_SYS_MSC2_VAL 0x00000000 -#define CONFIG_SYS_MDCNFG_VAL 0x08000ac9 -#define CONFIG_SYS_MDREFR_VAL 0x2013e01e -#define CONFIG_SYS_MDMRS_VAL 0x00320032 -#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_MSC0_VAL 0x9ee1c5f2 +#define CONFIG_SYS_MSC1_VAL 0x9ee1f994 +#define CONFIG_SYS_MSC2_VAL 0x9ee19ee1 +#define CONFIG_SYS_MDCNFG_VAL 0x090009c9 +#define CONFIG_SYS_MDREFR_VAL 0x2003a031 +#define CONFIG_SYS_MDMRS_VAL 0x00220022 +#define CONFIG_SYS_FLYCNFG_VAL 0x00010001 #define CONFIG_SYS_SXCNFG_VAL 0x40044004
/* * PCMCIA and CF Interfaces */ -#define CONFIG_SYS_MECR_VAL 0x00000001 -#define CONFIG_SYS_MCMEM0_VAL 0x00014307 +#define CONFIG_SYS_MECR_VAL 0x00000000 +#define CONFIG_SYS_MCMEM0_VAL 0x00028307 #define CONFIG_SYS_MCMEM1_VAL 0x00014307 -#define CONFIG_SYS_MCATT0_VAL 0x0001c787 +#define CONFIG_SYS_MCATT0_VAL 0x00038787 #define CONFIG_SYS_MCATT1_VAL 0x0001c787 -#define CONFIG_SYS_MCIO0_VAL 0x0001430f +#define CONFIG_SYS_MCIO0_VAL 0x0002830f #define CONFIG_SYS_MCIO1_VAL 0x0001430f
If I again do not get any feedback from Marek the current PXA CPU and Colibri PXA270 board maintainer may I ask Tom for help in getting this resolved?
Uh, sorry about that. Next time, please just poke me in case you don't get reply in a reasonable amount of time.
Applied all, thanks!
Best regards, Marek Vasut
No problem, I guess that's what RESENDs are for (;-p). Maybe it also had to do with me initially using your gmail rather than denx email address.
BTW: I noticed PXA3xx support having been removed a while back which is kind of sad considering our still shipping Colibri PXA3xx product line. Do you know whether there are any plans to ever revive any of that? I did notice that in Linux there is lately a push to migrating the PXAs to using device-tree as well wondering what boot loader those folks are using.
Hi!
Oh. You could have just sent an reply to the previous patches, no need to explicitly repost them :)
Yeah, I have a whole collection of those PXA3xx Colibris myself. I don't plan to dig in the PXA3xx support though. In case you want to revive it, please feel free to submit patches. I might also be able to give you some pointers on how to implement the support, so feel free to ask.
Possibly an old version of U-Boot, which was hacked to support PXA3xx, the one from openpxa ?
Marcel Ziswiler
Stefano Babic
