[U-Boot] [Query] NET: QE: UEC: Checking patch status
Dear Ben,
Sorry to nag,
I'm just checking in to see if you plan to push the patches I submitted, the last discussion on them are listed below:
1. [U-boot] [PATCHv2 1/2] NET: QE: UEC: Make uec_miiphy_read() and uec_miiphy_write() use the devname arg. http://lists.denx.de/pipermail/u-boot/2008-August/038968.html
2. [U-Boot] [U-boot] [PATCH 2/2] NET: QE: UEC: Allow uec re-initialization based on netretry environment variable. http://lists.denx.de/pipermail/u-boot/2008-August/038976.html
Some newbie questions:
1. Is there a supposed to be a NACK e-mail if the patch is being rejected?
2. What is the proper way to check about patch status update like this?
Thanks for all your help,
Regards,
- Richard Retanubun.
Hi Richard,
richardretanubun wrote:
Dear Ben,
Sorry to nag,
- [U-boot] [PATCHv2 1/2] NET: QE: UEC: Make uec_miiphy_read() and
- [U-Boot] [U-boot] [PATCH 2/2] NET: QE: UEC: Allow uec
Sorry, I dropped the ball. I'll look at them tonight.
- Is there a supposed to be a NACK e-mail if the patch is being
rejected?
Yes, you didn't get one.
- What is the proper way to check about patch status update like this?
What you just did.
regards, Ben
Hi Richard, richardretanubun wrote:
Dear Ben,
Sorry to nag,
I apologize for not responding in a more timely fashion. Let's just say the summer's been the busiest I ever had on many fronts and I haven't handled juggling all the balls as well as I should have.
I'll ACK this one and pull it in. It's not strictly formatted properly, but no worries.
I'm not crazy about the approach here and will shortly respond directly. to the patch.
regards, Ben
Hello Stefan,
I just pulled the latest u-boot (git://git.denx.de/u-boot-ppc4xx.git) and glacier is broken. It builds, but if load the u-boot it hangs. This is far as it gets.
U-Boot 1.3.4-03965-g7deb3b3 (Sep 4 2008 - 16:26:55)
CPU: AMCC PowerPC 460GT Rev. A at 800 MHz (PLB=200, OPB=100, EBC=100 MHz) Security/Kasumi support Bootstrap Option H - Boot ROM Location I2C (Addr 0x52) Internal PCI arbiter disabled 32 kB I-Cache 32 kB D-Cache Board: Glacier - AMCC PPC460GT Evaluation Board, 2*PCIe, Rev. 13 I2C: ready DTT: 1 is 35 C DRAM: 256 MB (ECC not enabled, 400 MHz, CL3) FLASH: 64 MB NAND: 32 MiB PCI: Bus Dev VenId DevId Class Int PCIE0: link is not up. PCIE0: initialization as root-complex failed PCIE1: link is not up. PCIE1: initialization as root-complex failed
Regards,
Victor Gallardo
Stefan,
I took a quick look at this problem and tracked the problem down to the serial console initialization area for the AMCC Glacier and Canyonlands boards.
description PPC4xx U-Boot Custodian Tree owner Stefan Roese last change Wed, 3 Sep 2008 15:21:38 +0000 URL git://git.denx.de/u-boot-ppc4xx.git
The problem was introduced 4 days ago with the commit
committer Wolfgang Denk wd@denx.de Sun, 31 Aug 2008 22:16:29 +0000 (00:16 +0200) commit e99e9575bbeba1b7c48e046547cae065ec0071de tree c08553c4d06725bd6013a46068df0059c5b49a00 parent a13b2d937941f6b525abfcfad96c034f94421188 parent 08ab4e1780fa63c88dd5a5ab52f4ff4ed1ee1878
If one were to rebase their git tree to the prior commit, U-Boot will boot all the way up on the Glacier and Canyonlands boards.
committer Wolfgang Denk wd@denx.de Sun, 31 Aug 2008 22:06:05 +0000 (00:06 +0200) commit a13b2d937941f6b525abfcfad96c034f94421188 tree 56e5bdaf62397b2f8cc2be9b17a035d9b059bf8a parent e155c9e00b5f21a6de28479259c440ba71289d00 parent d6e04258be8f2408845468d3cf722a4cf0433445
The problem happens within the console_init_r() routine called from the board_init_r() function.
common/console.c #else /* CFG_CONSOLE_IS_IN_ENV */
/* Called after the relocation - use desired console functions */ int console_init_r (void) { device_t *inputdev = NULL, *outputdev = NULL; int i; struct list_head *list = device_get_list(); struct list_head *pos; device_t *dev;
#ifdef CONFIG_SPLASH_SCREEN /* suppress all output if splash screen is enabled and we have a bmp to display */ if (getenv("splashimage") != NULL) gd->flags |= GD_FLG_SILENT; #endif
/* Scan devices looking for input and output devices */ list_for_each(pos, list) { dev = list_entry(pos, device_t, list);
if ((dev->flags & DEV_FLAGS_INPUT) && (inputdev == NULL)) { inputdev = dev; } if ((dev->flags & DEV_FLAGS_OUTPUT) && (outputdev == NULL)) { outputdev = dev; } if(inputdev && outputdev) break; }
/* Initializes output console first */ if (outputdev != NULL) { console_setfile (stdout, outputdev); console_setfile (stderr, outputdev); }
/* Initializes input console */ if (inputdev != NULL) { console_setfile (stdin, inputdev); }
gd->flags |= GD_FLG_DEVINIT; /* device initialization completed */ (Problem happens here- no more console output)
There are 4 elements in the device_get_list() list. I did a quick print of their flags field: list_head 0x1ffef2a0 dev->flags = 0x80000003 dev->flags = 0x00000003 dev->flags = 0x00000003 dev->flags = 0x80000003
Is the dev->flags for each console serial device have both DEV_FLAGS_INPUT and the DEV_FLAGS_OUTPUT set?
There was a change in the e99e9575bbeba1b7c48e046547cae065ec0071de commit with the list processing of the console devices (common/console.c, common/devices.c).
Unfortunately I can not investigate further tonight (family engagement), but I hope this helps.
Adam Graham
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Victor Gallardo Sent: Thursday, September 04, 2008 4:47 PM To: Stefan Roese; u-boot@lists.denx.de Subject: [U-Boot] ppc4xx: glacier broken with latest u-boot
Hello Stefan,
Regards,
Victor Gallardo
Adam,
On Friday 05 September 2008, Adam Graham wrote:
<snip>
This problem is fixed with the patch I sent out this morning:
devices: Use list_add_tail() instead of list_add() to register a device
Thanks for reporting and initial debugging.
Wolfgang, can you please pick up this patch quickly? Thanks.
Best regards, Stefan
Dear Stefan Roese,
Done. I know that this was a critical one.
participants (6)
Adam Graham
Ben Warren
richardretanubun
Stefan Roese
Victor Gallardo
