[PATCH v2] arm: xea: Modify board code to generate single binary u-boot
This change provides the possibility to build XEA (imx287 based) board U-Boot as a single binary (without support for CONFIG_SPL_FRAMEWORK).
The generated u-boot.sb can be used in the factory environment to for example perform initial setup or HW testing.
It can be used with 'uuu' utility (SDPS: boot -f /srv/tftp/xea/u-boot.sb)
In the configs/imx28_xea_defconfig one needs to disable following configs: # CONFIG_SPL_BLK is not set # CONFIG_SPL_FRAMEWORK is not set
The board_init_ll() is used in arch/arm/cpu/arm926ejs/mxs/start.S, which is utilized when CONFIG_SPL_FRAMEWORK is disabled.
However, when it is enabled - the arch/arm/cpu/arm926ejs/start.S is used, which requires the lowlevel_init() function.
Signed-off-by: Lukasz Majewski lukma@denx.de
Changes in v2: - Use CONFIG_IS_ENABLED(FRAMEWORK) instead of #ifdef CONFIG_SPL_FRAMEWORK (previous version used CONFIG_IS_ENABLED(SPL_FRAMEWORK), which was wrong). - Restructure spl_xea.c code to be more readable
board/liebherr/xea/spl_xea.c | 8 ++++++++ board/liebherr/xea/xea.c | 3 ++- 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/board/liebherr/xea/spl_xea.c b/board/liebherr/xea/spl_xea.c index 192f68fca5f..5ee561b8b78 100644 --- a/board/liebherr/xea/spl_xea.c +++ b/board/liebherr/xea/spl_xea.c @@ -290,6 +290,13 @@ u32 mxs_dram_vals[] = { 0x00000000, 0xffffffff };
+/* #ifndef CONFIG_SPL_FRAMEWORK */ +#if !CONFIG_IS_ENABLED(FRAMEWORK) +void board_init_ll(const u32 arg, const uint32_t *resptr) +{ + mxs_common_spl_init(arg, resptr, iomux_setup, ARRAY_SIZE(iomux_setup)); +} +#else void lowlevel_init(void) { struct mxs_pinctrl_regs *pinctrl_regs = @@ -301,3 +308,4 @@ void lowlevel_init(void)
mxs_common_spl_init(0, NULL, iomux_setup, ARRAY_SIZE(iomux_setup)); } +#endif diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c index cd11b0ada77..685e2e26a18 100644 --- a/board/liebherr/xea/xea.c +++ b/board/liebherr/xea/xea.c @@ -58,7 +58,8 @@ static void init_clocks(void) mxs_set_sspclk(MXC_SSPCLK3, 96000, 0); }
-#ifdef CONFIG_SPL_BUILD +/* #if CONFIG_SPL_BUILD && CONFIG_SPL_FRAMEWORK */ +#if CONFIG_IS_ENABLED(BUILD) && CONFIG_IS_ENABLED(FRAMEWORK) void board_init_f(ulong arg) { init_clocks();
Changes in v2:
Lukasz Majewski
