[U-Boot] A minor question on a Driver Model function
Hi Simon,
I have a qustion about lists_driver_lookup_name() function.
for (entry = drv; entry != drv + n_ents; entry++) { if (strncmp(name, entry->name, len)) continue;
/* Full match */ if (len == strlen(entry->name)) return entry; }
Why is this not like follows?
for (entry = drv; entry != drv + n_ents; entry++) { if (!strcmp(name, entry->name)) return entry; }
It seems equivalent to the former and simpler.
Am I missing something?
Best Regards Masahiro Yamada
Hi Masahiro,
On 12 September 2014 05:25, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hi Simon,
for (entry = drv; entry != drv + n_ents; entry++) { if (strncmp(name, entry->name, len)) continue; /* Full match */ if (len == strlen(entry->name)) return entry; }
I think that code was there from the beginning. Marek might have written it...the original series that I did as an RFC was here.
http://patchwork.ozlabs.org/patch/239255/
Might worth a patch.
On 09/14/14 21:28, Simon Glass wrote:
Hi Masahiro,
Hi Simon,
I would suggest still using strncmp as it is safer, but count also the '\0', so something like:
for (entry = drv; entry != drv + n_ents; entry++) { if (!strncmp(name, entry->name, len + 1)) return entry; }
Hi Igor,
On Mon, 15 Sep 2014 11:04:20 +0300 Igor Grinberg grinberg@compulab.co.il wrote:
Hi Masahiro,
Hi Simon,
Why safer?
Could you give me more detailed explanation?
On 09/17/14 11:18, Masahiro Yamada wrote:
Hi Igor,
Hi Masahiro,
Hi Simon,
Why safer?
Well, I'm not an expert in s/w security, but I'll try to explain...
strcmp() walks the strings and never stops until it reaches '\0' in either of strings. In theory (or by mistake), you can supply strings that are not '\0' terminated and strcmp() will continue running on addresses where it is not supposed to. This can lead to exceptions, crashes, etc..
Since this is a library code, I would expect it to be immune to that kind of problem.
But, again, I'm not an expert in this area, so its only a suggestion.
On 17 Sep 2014, grinberg@compulab.co.il wrote:
Why safer?
[snip]
I thought it was fairly apparent that the current code supports passing a string that is *NOT* null terminated. This can be convenient if you extract a sub-string from a command line and do not need to make a copy that is NULL terminate or perform 'strtok()' type magic.
Fwiw, Bill Pringlemeir.
Hi Bill,
Why safer?
[snip]
Here is the whole function:
------------------------------cut-------------------------- struct driver *lists_driver_lookup_name(const char *name) { struct driver *drv = ll_entry_start(struct driver, driver); const int n_ents = ll_entry_count(struct driver, driver); struct driver *entry; int len;
if (!drv || !n_ents) return NULL;
len = strlen(name);
/* Not found */ return NULL; } ------------------------------cut--------------------------
and... no, the code does not support passing a string that is not null terminated.
Why safer?
[snip]
len = strlen(name);
Then using the strncmp() seems useless for security reasons? The 'len' is not passed in by the caller and 'strlen()' will have the same problems that 'strcmp()' would for read buffer overflows? I would guess the code was cribbed from where 'len' was passed? In that case, it would support strings that are not null terminated.
Sorry, I didn't look and understand your query now.
Why safer?
[snip]
len = strlen(name);
Yes, that is correct.
Since we are dealing with device/driver names here. I think the best would be to define a sane name length limit (say 20 or more characters) and use it as the maximal length if no '\0' found before the limit.
On Fri, 19 Sep 2014 09:34:53 +0300 Igor Grinberg grinberg@compulab.co.il wrote:
> I would suggest still using strncmp as it is safer, > but count also the '\0', so something like:
Why safer?
[snip]
len = strlen(name);
I disagre.
The argument "name" of this function may be derived from a device tree, that is, it is possibly not NULL-terminated if U-Boot is accidentally given a corrupted device tree.
On the other hand, "entry->name" originates in a U_BOOT_DRIVER() instance.
For example, something like this
U_BOOT_DRIVER(root_driver) = { .name = "root_driver", .id = UCLASS_ROOT, };
The .name member of U_BOOT_DRIVER is guaranteed to be NULL-terminated.
I'd say, strcmp(name, entry->name) is always safe.
(In the current code,
len = strlen(name); is *NOT* safe,
but,
len = strlen(entry->name); is safe
>> I would suggest still using strncmp as it is safer, >> but count also the '\0', so something like:
> Why safer?
[snip]
len = strlen(name);
I disagre.
If this can happen, then the name length limit is even more sensible...
I'd say the chances for _not_ having .name null terminated are quite low, but I fail to find something that guarantees this. May be I'm missing something, but you still can mess with the .name field, right?
but,
Yes, this was actually the first though that came into my mind, but I wanted to take it a step further.
I agree that running strlen(entry->name) is better than running it with name argument.
Yet, having a strong limit will prevent various corner cases.
Or, I'm just being too much paranoid/pedantic, and using entry->name as an argument would be enough...
Bill Pringlemeir
Igor Grinberg
Masahiro Yamada
