[U-Boot] [PATCH v1 0/5] imx: dm: Update mccmon6 board to only use DM/DTS in U-Boot proper
This patch series converts mccmon6 to use Driver Model and Device Tree in U-Boot proper.
As the SPL is size constrained (and most notably the device has a strict boot time requirements) for this board (and uses falcon boot) - its conversion to DM/DTB will be added with separate patch series.
The SPL/U-Boot proper now uses fitImage instead of legacy uImage and DTB.
Some notable changes: - Use fitImage to boot Linux kernel (and also use of SPL's Falcon mode when running from parallel NOR flash) - DTS sync with kernel (tag: v4.20) - Decoupling SPL and U-Boot proper for easy future SPL DM/DTS conversion - Conversion to DM_MMC, DM_SPI, and BLK (U-Boot proper)
Dependencies (on top of 2019.07-rc2): "imx: Cleanup i.MX6Q mccmon6 boardconfiguration" http://patchwork.ozlabs.org/cover/1100398/
then: http://patchwork.ozlabs.org/patch/1100580/ http://patchwork.ozlabs.org/patch/1100582/ http://patchwork.ozlabs.org/patch/1100584/ http://patchwork.ozlabs.org/patch/1100583/
On top of above patches this series shall be applied.
Lukasz Majewski (5): ARM: imx: Covnert mccmon6 to use DM/DTS in the u-boot proper ARM: imx: Decouple mccmon6's SPL and u-boot proper code spl: nor: Provide falcon boot support for NOR memories ARM: imx: Convert mccmon6 to use fitImage instead of uImage+DTB mccmon6: defconfig: nor: Enable usage of *_TINY_* drivers in SPL
arch/arm/dts/Makefile | 1 + arch/arm/dts/imx6q-mccmon6.dts | 382 +++++++++++++++++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 7 + board/liebherr/mccmon6/Makefile | 7 +- board/liebherr/mccmon6/mccmon6.c | 446 --------------------------------------- board/liebherr/mccmon6/spl.c | 279 +++++++++++++++++++++++- common/spl/spl_nor.c | 5 + configs/mccmon6_nor_defconfig | 42 +++- configs/mccmon6_sd_defconfig | 35 ++- include/configs/mccmon6.h | 70 ++---- 10 files changed, 769 insertions(+), 505 deletions(-) create mode 100644 arch/arm/dts/imx6q-mccmon6.dts
This commit converts mccmon6's u-boot proper (in a single commit to avoid build breaks) to use solely DM/DTS.
The DTS description of the mccmon6 has been ported from Linux kernel (v4.20, SHA1: 8fe28cb58bcb235034b64cbbb7550a8a43fd88be)
Signed-off-by: Lukasz Majewski lukma@denx.de ---
arch/arm/dts/Makefile | 1 + arch/arm/dts/imx6q-mccmon6.dts | 382 +++++++++++++++++++++++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 7 + board/liebherr/mccmon6/mccmon6.c | 161 ----------------- configs/mccmon6_nor_defconfig | 31 +++- configs/mccmon6_sd_defconfig | 29 ++- include/configs/mccmon6.h | 13 -- 7 files changed, 444 insertions(+), 180 deletions(-) create mode 100644 arch/arm/dts/imx6q-mccmon6.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 83058c4452..0a5b13c35d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -548,6 +548,7 @@ dtb-$(CONFIG_MX6QDL) += \ imx6q-icore.dtb \ imx6q-icore-mipi.dtb \ imx6q-icore-rqs.dtb \ + imx6q-mccmon6.dtb \ imx6q-sabreauto.dtb \ imx6q-sabresd.dtb \ imx6dl-sabreauto.dtb \ diff --git a/arch/arm/dts/imx6q-mccmon6.dts b/arch/arm/dts/imx6q-mccmon6.dts new file mode 100644 index 0000000000..27cde56115 --- /dev/null +++ b/arch/arm/dts/imx6q-mccmon6.dts @@ -0,0 +1,382 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ or X11 + */ + +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include "imx6q.dtsi" + +/ { + model = "Liebherr Nenzig (LWN) iMX6Q"; + compatible = "lwn,imx6-mccmon6", "fsl,imx6"; + + aliases { + mmc0 = &usdhc3; + mmc1 = &usdhc2; + spi0 = &ecspi3; + }; + + chosen { + stdout-path = &uart1; + }; + + memory@10000000 { + reg = <0x10000000 0x80000000>; + }; +}; + +&ecspi3 { + cs-gpios = <&gpio4 24 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi3 &pinctrl_ecspi3_cs &pinctrl_ecspi3_flwp>; + spi-max-frequency = <25000000>; + status = "okay"; + + s25sl032p: flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <40000000>; + reg = <0>; + }; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet>; + phy-mode = "rgmii"; + phy-reset-gpios = <&gpio1 27 GPIO_ACTIVE_LOW>; + phy-reset-duration = <10>; + phy-reset-post-delay = <1>; + /* KSZ9031 PHY SKEW setup - old values * 60 ps */ + rxc-skew-ps = <1860>; + txc-skew-ps = <1860>; + txen-skew-ps = <900>; + rxdv-skew-ps = <900>; + rxd0-skew-ps = <180>; + rxd1-skew-ps = <180>; + rxd2-skew-ps = <180>; + rxd3-skew-ps = <180>; + txd0-skew-ps = <120>; + txd1-skew-ps = <300>; + txd2-skew-ps = <0>; + txd3-skew-ps = <120>; + status = "okay"; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + pfuze100: pmic@8 { + compatible = "fsl,pfuze100"; + reg = <0x08>; + + regulators { + sw1a_reg: sw1ab { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw1c_reg: sw1c { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw2_reg: sw2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3950000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3a_reg: sw3a { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3b_reg: sw3b { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw4_reg: sw4 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + }; + + swbst_reg: swbst { + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + vgen1_reg: vgen1 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen2_reg: vgen2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen3_reg: vgen3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + vgen4_reg: vgen4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen5_reg: vgen5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen6_reg: vgen6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; +}; + +&weim { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_weim_nor &pinctrl_weim_cs0>; + ranges = <0 0 0x08000000 0x08000000>; + status = "okay"; + + nor@0,0 { + compatible = "cfi-flash"; + reg = <0 0 0x02000000>; + #address-cells = <1>; + #size-cells = <1>; + bank-width = <2>; + use-advanced-sector-protection; + fsl,weim-cs-timing = <0x00620081 0x00000001 0x1c022000 + 0x0000c000 0x1404a38e 0x00000000>; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_ecspi3: ecspi3grp { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT2__ECSPI3_MISO 0x100b1 + MX6QDL_PAD_DISP0_DAT1__ECSPI3_MOSI 0x100b1 + MX6QDL_PAD_DISP0_DAT0__ECSPI3_SCLK 0x100b1 + >; + }; + + pinctrl_ecspi3_cs: ecspi3csgrp { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT3__GPIO4_IO24 0x80000000 + >; + }; + + pinctrl_ecspi3_flwp: ecspi3flwpgrp { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT6__GPIO4_IO27 0x80000000 + >; + }; + + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x1b0b0 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b0b0 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b0b0 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b0b0 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b0b0 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b0b0 + MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1b0b0 + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b0b0 + MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b0b0 + MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b0b0 + MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b0b0 + MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b0b0 + MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b0b0 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + MX6QDL_PAD_GPIO_6__ENET_IRQ 0x000b1 + MX6QDL_PAD_ENET_RXD0__GPIO1_IO27 0x1b0b0 + >; + }; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x1b0b0 + MX6QDL_PAD_GPIO_1__GPIO1_IO01 0x1b0b0 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x4001b8b1 + MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17059 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10059 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17059 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17059 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17059 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17059 + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1b0b1 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x17059 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x17059 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x17059 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x17059 + MX6QDL_PAD_SD3_RST__SD3_RESET 0x17059 + >; + }; + + pinctrl_weim_cs0: weimcs0grp { + fsl,pins = < + MX6QDL_PAD_EIM_CS0__EIM_CS0_B 0xb0b1 + >; + }; + + pinctrl_weim_nor: weimnorgrp { + fsl,pins = < + MX6QDL_PAD_EIM_OE__EIM_OE_B 0xb0b1 + MX6QDL_PAD_EIM_RW__EIM_RW 0xb0b1 + MX6QDL_PAD_EIM_WAIT__EIM_WAIT_B 0xb060 + MX6QDL_PAD_EIM_D16__EIM_DATA16 0x1b0b0 + MX6QDL_PAD_EIM_D17__EIM_DATA17 0x1b0b0 + MX6QDL_PAD_EIM_D18__EIM_DATA18 0x1b0b0 + MX6QDL_PAD_EIM_D19__EIM_DATA19 0x1b0b0 + MX6QDL_PAD_EIM_D20__EIM_DATA20 0x1b0b0 + MX6QDL_PAD_EIM_D21__EIM_DATA21 0x1b0b0 + MX6QDL_PAD_EIM_D22__EIM_DATA22 0x1b0b0 + MX6QDL_PAD_EIM_D23__EIM_DATA23 0x1b0b0 + MX6QDL_PAD_EIM_D24__EIM_DATA24 0x1b0b0 + MX6QDL_PAD_EIM_D25__EIM_DATA25 0x1b0b0 + MX6QDL_PAD_EIM_D26__EIM_DATA26 0x1b0b0 + MX6QDL_PAD_EIM_D27__EIM_DATA27 0x1b0b0 + MX6QDL_PAD_EIM_D28__EIM_DATA28 0x1b0b0 + MX6QDL_PAD_EIM_D29__EIM_DATA29 0x1b0b0 + MX6QDL_PAD_EIM_D30__EIM_DATA30 0x1b0b0 + MX6QDL_PAD_EIM_D31__EIM_DATA31 0x1b0b0 + MX6QDL_PAD_EIM_A23__EIM_ADDR23 0xb0b1 + MX6QDL_PAD_EIM_A22__EIM_ADDR22 0xb0b1 + MX6QDL_PAD_EIM_A21__EIM_ADDR21 0xb0b1 + MX6QDL_PAD_EIM_A20__EIM_ADDR20 0xb0b1 + MX6QDL_PAD_EIM_A19__EIM_ADDR19 0xb0b1 + MX6QDL_PAD_EIM_A18__EIM_ADDR18 0xb0b1 + MX6QDL_PAD_EIM_A17__EIM_ADDR17 0xb0b1 + MX6QDL_PAD_EIM_A16__EIM_ADDR16 0xb0b1 + MX6QDL_PAD_EIM_DA15__EIM_AD15 0xb0b1 + MX6QDL_PAD_EIM_DA14__EIM_AD14 0xb0b1 + MX6QDL_PAD_EIM_DA13__EIM_AD13 0xb0b1 + MX6QDL_PAD_EIM_DA12__EIM_AD12 0xb0b1 + MX6QDL_PAD_EIM_DA11__EIM_AD11 0xb0b1 + MX6QDL_PAD_EIM_DA10__EIM_AD10 0xb0b1 + MX6QDL_PAD_EIM_DA9__EIM_AD09 0xb0b1 + MX6QDL_PAD_EIM_DA8__EIM_AD08 0xb0b1 + MX6QDL_PAD_EIM_DA7__EIM_AD07 0xb0b1 + MX6QDL_PAD_EIM_DA6__EIM_AD06 0xb0b1 + MX6QDL_PAD_EIM_DA5__EIM_AD05 0xb0b1 + MX6QDL_PAD_EIM_DA4__EIM_AD04 0xb0b1 + MX6QDL_PAD_EIM_DA3__EIM_AD03 0xb0b1 + MX6QDL_PAD_EIM_DA2__EIM_AD02 0xb0b1 + MX6QDL_PAD_EIM_DA1__EIM_AD01 0xb0b1 + MX6QDL_PAD_EIM_DA0__EIM_AD00 0xb0b1 + >; + }; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + bus-width = <4>; + cd-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc3>; + bus-width = <8>; + non-removable; + no-1-8-v; + keep-power-in-suspend; + status = "okay"; +}; diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index f513c4c06f..2703c7bf21 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -217,6 +217,13 @@ config TARGET_MCCMON6 bool "mccmon6" select MX6QDL select SUPPORT_SPL + select DM + select DM_GPIO + select DM_ETH + select DM_SERIAL + select DM_I2C + select DM_SPI + imply CMD_DM
config TARGET_MX6CUBOXI bool "Solid-run mx6 boards" diff --git a/board/liebherr/mccmon6/mccmon6.c b/board/liebherr/mccmon6/mccmon6.c index 946b91f3a1..497095572e 100644 --- a/board/liebherr/mccmon6/mccmon6.c +++ b/board/liebherr/mccmon6/mccmon6.c @@ -12,17 +12,13 @@ #include <asm/arch/sys_proto.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> -#include <asm/mach-imx/mxc_i2c.h> -#include <asm/mach-imx/spi.h> #include <asm/mach-imx/boot_mode.h> #include <asm/io.h> #include <fsl_esdhc.h> #include <mmc.h> #include <netdev.h> -#include <micrel.h> #include <phy.h> #include <input.h> -#include <i2c.h> #include <spl.h>
DECLARE_GLOBAL_DATA_PTR; @@ -35,24 +31,11 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - -#define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) - -#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_ODE | PAD_CTL_SRE_FAST) - #define WEIM_NOR_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST)
#define USDHC2_CD_GPIO IMX_GPIO_NR(1, 4) -#define ETH_PHY_RESET IMX_GPIO_NR(1, 27) -#define ECSPI3_CS0 IMX_GPIO_NR(4, 24) -#define ECSPI3_FLWP IMX_GPIO_NR(4, 27) #define NOR_WP IMX_GPIO_NR(1, 1) #define DISPLAY_EN IMX_GPIO_NR(1, 2)
@@ -93,45 +76,11 @@ static iomux_v3_cfg_t const usdhc3_pads[] = { IOMUX_PADS(PAD_SD3_RST__SD3_RESET | MUX_PAD_CTRL(USDHC_PAD_CTRL)), };
-static iomux_v3_cfg_t const enet_pads[] = { - IOMUX_PADS(PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_TX_CTL__RGMII_TX_CTL - | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_REF_CLK__ENET_TX_CLK - | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_RGMII_RX_CTL__RGMII_RX_CTL - | MUX_PAD_CTRL(ENET_PAD_CTRL)), - /* KSZ9031 PHY Reset */ - IOMUX_PADS(PAD_ENET_RXD0__GPIO1_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - static void setup_iomux_uart(void) { SETUP_IOMUX_PADS(uart1_pads); }
-static void setup_iomux_enet(void) -{ - SETUP_IOMUX_PADS(enet_pads); - - /* Reset KSZ9031 PHY */ - gpio_direction_output(ETH_PHY_RESET, 0); - mdelay(10); - gpio_set_value(ETH_PHY_RESET, 1); - udelay(100); -} - static struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC3_BASE_ADDR}, {USDHC2_BASE_ADDR}, @@ -273,74 +222,6 @@ static void setup_eimnor(void) eimnor_cs_setup(); }
-/* mccmon6 board has SPI Flash is connected to SPI3 */ -int board_spi_cs_gpio(unsigned bus, unsigned cs) -{ - return (bus == 2 && cs == 0) ? ECSPI3_CS0 : -1; -} - -static iomux_v3_cfg_t const ecspi3_pads[] = { - /* SPI3 */ - IOMUX_PADS(PAD_DISP0_DAT3__GPIO4_IO24 | MUX_PAD_CTRL(NO_PAD_CTRL)), - IOMUX_PADS(PAD_DISP0_DAT2__ECSPI3_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL)), - IOMUX_PADS(PAD_DISP0_DAT1__ECSPI3_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL)), - IOMUX_PADS(PAD_DISP0_DAT0__ECSPI3_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL)), -}; - -void setup_spi(void) -{ - SETUP_IOMUX_PADS(ecspi3_pads); - - enable_spi_clk(true, 2); - - /* set cs0 to high */ - gpio_direction_output(ECSPI3_CS0, 1); - - /* set flwp to high */ - gpio_direction_output(ECSPI3_FLWP, 1); -} - -struct i2c_pads_info mx6q_i2c1_pad_info = { - .scl = { - .i2c_mode = MX6Q_PAD_CSI0_DAT9__I2C1_SCL - | MUX_PAD_CTRL(I2C_PAD_CTRL), - .gpio_mode = MX6Q_PAD_CSI0_DAT9__GPIO5_IO27 - | MUX_PAD_CTRL(I2C_PAD_CTRL), - .gp = IMX_GPIO_NR(5, 27) - }, - .sda = { - .i2c_mode = MX6Q_PAD_CSI0_DAT8__I2C1_SDA - | MUX_PAD_CTRL(I2C_PAD_CTRL), - .gpio_mode = MX6Q_PAD_CSI0_DAT8__GPIO5_IO26 - | MUX_PAD_CTRL(I2C_PAD_CTRL), - .gp = IMX_GPIO_NR(5, 26) - } -}; - -struct i2c_pads_info mx6q_i2c2_pad_info = { - .scl = { - .i2c_mode = MX6Q_PAD_KEY_COL3__I2C2_SCL - | MUX_PAD_CTRL(I2C_PAD_CTRL), - .gpio_mode = MX6Q_PAD_KEY_COL3__GPIO4_IO12 - | MUX_PAD_CTRL(I2C_PAD_CTRL), - .gp = IMX_GPIO_NR(4, 12) - }, - .sda = { - .i2c_mode = MX6Q_PAD_KEY_ROW3__I2C2_SDA - | MUX_PAD_CTRL(I2C_PAD_CTRL), - .gpio_mode = MX6Q_PAD_KEY_ROW3__GPIO4_IO13 - | MUX_PAD_CTRL(I2C_PAD_CTRL), - .gp = IMX_GPIO_NR(4, 13) - } -}; - -int board_eth_init(bd_t *bis) -{ - setup_iomux_enet(); - - return cpu_eth_init(bis); -} - int board_early_init_f(void) { setup_iomux_uart(); @@ -356,10 +237,6 @@ int board_init(void) gpio_direction_output(DISPLAY_EN, 1);
setup_eimnor(); - setup_spi(); - - setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c1_pad_info); - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c2_pad_info);
return 0; } @@ -378,44 +255,6 @@ int checkboard(void) return 0; }
-int board_phy_config(struct phy_device *phydev) -{ - /* - * Default setting for GMII Clock Pad Skew Register 0x1EF: - * MMD Address 0x2h, Register 0x8h - * - * GTX_CLK Pad Skew 0xF -> 0.9 nsec skew - * RX_CLK Pad Skew 0xF -> 0.9 nsec skew - * - * Adjustment -> write 0x3FF: - * GTX_CLK Pad Skew 0x1F -> 1.8 nsec skew - * RX_CLK Pad Skew 0x1F -> 1.8 nsec skew - * - */ - ksz9031_phy_extended_write(phydev, 0x2, - MII_KSZ9031_EXT_RGMII_CLOCK_SKEW, - MII_KSZ9031_MOD_DATA_NO_POST_INC, 0x3FF); - - ksz9031_phy_extended_write(phydev, 0x02, - MII_KSZ9031_EXT_RGMII_CTRL_SIG_SKEW, - MII_KSZ9031_MOD_DATA_NO_POST_INC, 0x00FF); - - ksz9031_phy_extended_write(phydev, 0x2, - MII_KSZ9031_EXT_RGMII_RX_DATA_SKEW, - MII_KSZ9031_MOD_DATA_NO_POST_INC, - 0x3333); - - ksz9031_phy_extended_write(phydev, 0x2, - MII_KSZ9031_EXT_RGMII_TX_DATA_SKEW, - MII_KSZ9031_MOD_DATA_NO_POST_INC, - 0x2052); - - if (phydev->drv->config) - phydev->drv->config(phydev); - - return 0; -} - #ifdef CONFIG_SPL_BOARD_INIT void spl_board_init(void) { diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index ddbcd69316..770ef9bed6 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y # CONFIG_CMD_BMODE is not set CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_nor.cfg" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_BOUNCE_BUFFER=y @@ -16,18 +17,28 @@ CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y +CONFIG_CMD_CLK=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +# CONFIG_CMD_PINMUX is not set CONFIG_CMD_SF=y CONFIG_CMD_CACHE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x40000(u-boot-env.nor),1m@0x80000(u-boot.nor),8m@0x180000(kernel.nor),8m@0x980000(swupdate-kernel.nor),8m@0x1180000(swupdate-rootfs.nor),128k@0x1980000(kernel-dtb.nor),128k@0x19C0000(swupdate-kernel-dtb.nor)" +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6q-mccmon6" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_DM=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_SYS_I2C_MXC=y +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y @@ -37,16 +48,30 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y -CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_BUS=0 CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +# CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PFUZE100=y +# CONFIG_REQUIRE_SERIAL_CONSOLE is not set +# CONFIG_SPECIFY_CONSOLE_INDEX is not set +# CONFIG_SPL_SERIAL_PRESENT is not set +# CONFIG_TPL_SERIAL_PRESENT is not set +CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y -CONFIG_OF_LIBFDT=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index a018d804f8..9a11b59738 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -10,6 +10,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y # CONFIG_CMD_BMODE is not set CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_sd.cfg" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_BOUNCE_BUFFER=y @@ -17,18 +18,28 @@ CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y +CONFIG_CMD_CLK=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +# CONFIG_CMD_PINMUX is not set CONFIG_CMD_SF=y CONFIG_CMD_CACHE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=8000000.nor" CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x40000(u-boot-env.nor),1m@0x80000(u-boot.nor),8m@0x180000(kernel.nor),8m@0x980000(swupdate-kernel.nor),8m@0x1180000(swupdate-rootfs.nor),128k@0x1980000(kernel-dtb.nor),128k@0x19C0000(swupdate-kernel-dtb.nor)" +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6q-mccmon6" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_DM=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_SYS_I2C_MXC=y +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y @@ -38,16 +49,28 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y -CONFIG_SF_DEFAULT_BUS=2 CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_FEC_MXC=y +CONFIG_RGMII=y CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +# CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PFUZE100=y +# CONFIG_REQUIRE_SERIAL_CONSOLE is not set +# CONFIG_SPL_SERIAL_PRESENT is not set +# CONFIG_TPL_SERIAL_PRESENT is not set +CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index 667dac7340..b25aacbf41 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -34,22 +34,12 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
-#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_LATE_INIT - -#define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE
#define CONFIG_SYS_MEMTEST_START 0x10000000 #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 500 * SZ_1M)
-/* I2C Configs */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ -#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ -#define CONFIG_SYS_I2C_SPEED 100000 - /* MMC Configuration */ #define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_SYS_FSL_ESDHC_ADDR 0 @@ -66,10 +56,7 @@ #define CONFIG_SYS_FLASH_BANKS_SIZES { (32 * SZ_1M) }
/* Ethernet Configuration */ -#define CONFIG_FEC_MXC #define IMX_FEC_BASE ENET_BASE_ADDR -#define CONFIG_FEC_XCV_TYPE RGMII -#define CONFIG_ETHPRIME "FEC" #define CONFIG_FEC_MXC_PHYADDR 1
#define CONFIG_EXTRA_ENV_SETTINGS \
The mccmon6 has been used a "mixed" approach between SPL and U-Boot proper sources.
This commit decoupes SPL and u-boot proper, which allows clear distinction between those two code bases and facilitates conversion to DM/DTS on this particular board.
board/liebherr/mccmon6/Makefile | 7 +- board/liebherr/mccmon6/mccmon6.c | 285 --------------------------------------- board/liebherr/mccmon6/spl.c | 274 ++++++++++++++++++++++++++++++++++++- 3 files changed, 276 insertions(+), 290 deletions(-)
diff --git a/board/liebherr/mccmon6/Makefile b/board/liebherr/mccmon6/Makefile index ead6750ebf..3c9786c6b7 100644 --- a/board/liebherr/mccmon6/Makefile +++ b/board/liebherr/mccmon6/Makefile @@ -2,5 +2,8 @@ # # (C) Copyright 2016-2017 # Lukasz Majewski, DENX Software Engineering, lukma@denx.de - -obj-y := mccmon6.o spl.o +ifdef CONFIG_SPL_BUILD +obj-y := spl.o +else +obj-y := mccmon6.o +endif diff --git a/board/liebherr/mccmon6/mccmon6.c b/board/liebherr/mccmon6/mccmon6.c index 497095572e..33b28aca11 100644 --- a/board/liebherr/mccmon6/mccmon6.c +++ b/board/liebherr/mccmon6/mccmon6.c @@ -8,37 +8,11 @@ #include <asm/arch/clock.h> #include <asm/arch/iomux.h> #include <asm/arch/imx-regs.h> -#include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> #include <asm/gpio.h> -#include <asm/mach-imx/iomux-v3.h> -#include <asm/mach-imx/boot_mode.h> -#include <asm/io.h> -#include <fsl_esdhc.h> -#include <mmc.h> -#include <netdev.h> -#include <phy.h> -#include <input.h> -#include <spl.h>
-#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ - PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ - PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ - PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -#define WEIM_NOR_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) - -#define USDHC2_CD_GPIO IMX_GPIO_NR(1, 4) -#define NOR_WP IMX_GPIO_NR(1, 1) -#define DISPLAY_EN IMX_GPIO_NR(1, 2) - int dram_init(void) { gd->ram_size = imx_ddr_size(); @@ -46,198 +20,11 @@ int dram_init(void) return 0; }
-static iomux_v3_cfg_t const uart1_pads[] = { - IOMUX_PADS(PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), - IOMUX_PADS(PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), -}; - -static iomux_v3_cfg_t const usdhc2_pads[] = { - IOMUX_PADS(PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - /* Carrier MicroSD Card Detect */ - IOMUX_PADS(PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - -static iomux_v3_cfg_t const usdhc3_pads[] = { - IOMUX_PADS(PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - IOMUX_PADS(PAD_SD3_RST__SD3_RESET | MUX_PAD_CTRL(USDHC_PAD_CTRL)), -}; - -static void setup_iomux_uart(void) -{ - SETUP_IOMUX_PADS(uart1_pads); -} - -static struct fsl_esdhc_cfg usdhc_cfg[2] = { - {USDHC3_BASE_ADDR}, - {USDHC2_BASE_ADDR}, -}; - -int board_mmc_getcd(struct mmc *mmc) -{ - struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; - int ret = 0; - - switch (cfg->esdhc_base) { - case USDHC2_BASE_ADDR: - ret = !gpio_get_value(USDHC2_CD_GPIO); - break; - case USDHC3_BASE_ADDR: - /* - * eMMC don't have card detect pin - since it is soldered to the - * PCB board - */ - ret = 1; - break; - } - return ret; -} - -int board_mmc_init(bd_t *bis) -{ - int ret; - u32 index = 0; - - /* - * MMC MAP - * (U-Boot device node) (Physical Port) - * mmc0 Soldered on board eMMC device - * mmc1 MicroSD card - */ - for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { - switch (index) { - case 0: - SETUP_IOMUX_PADS(usdhc3_pads); - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - usdhc_cfg[0].max_bus_width = 8; - break; - case 1: - SETUP_IOMUX_PADS(usdhc2_pads); - usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); - usdhc_cfg[1].max_bus_width = 4; - gpio_direction_input(USDHC2_CD_GPIO); - break; - default: - printf("Warning: More USDHC controllers (%d) than supported (%d)\n", - index + 1, CONFIG_SYS_FSL_USDHC_NUM); - return -EINVAL; - } - - ret = fsl_esdhc_initialize(bis, &usdhc_cfg[index]); - if (ret) - return ret; - } - - return 0; -} - -static iomux_v3_cfg_t const eimnor_pads[] = { - IOMUX_PADS(PAD_EIM_D16__EIM_DATA16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D17__EIM_DATA17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D18__EIM_DATA18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D19__EIM_DATA19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D20__EIM_DATA20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D21__EIM_DATA21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D22__EIM_DATA22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D23__EIM_DATA23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D24__EIM_DATA24 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D25__EIM_DATA25 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D26__EIM_DATA26 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D27__EIM_DATA27 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D28__EIM_DATA28 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D29__EIM_DATA29 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D30__EIM_DATA30 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_D31__EIM_DATA31 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA0__EIM_AD00 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA1__EIM_AD01 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA2__EIM_AD02 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA3__EIM_AD03 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA4__EIM_AD04 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA5__EIM_AD05 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA6__EIM_AD06 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA7__EIM_AD07 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA8__EIM_AD08 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA9__EIM_AD09 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA10__EIM_AD10 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA11__EIM_AD11 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA12__EIM_AD12 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA13__EIM_AD13 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA14__EIM_AD14 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_DA15__EIM_AD15 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_A16__EIM_ADDR16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_A17__EIM_ADDR17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_A18__EIM_ADDR18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_A19__EIM_ADDR19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_A20__EIM_ADDR20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_A21__EIM_ADDR21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_A22__EIM_ADDR22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_A23__EIM_ADDR23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_A24__EIM_ADDR24 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_A25__EIM_ADDR25 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_OE__EIM_OE_B | MUX_PAD_CTRL(NO_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_RW__EIM_RW | MUX_PAD_CTRL(NO_PAD_CTRL)), - IOMUX_PADS(PAD_EIM_CS0__EIM_CS0_B | MUX_PAD_CTRL(NO_PAD_CTRL)), - IOMUX_PADS(PAD_GPIO_1__GPIO1_IO01 | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - -static void eimnor_cs_setup(void) -{ - struct weim *weim_regs = (struct weim *)WEIM_BASE_ADDR; - - - /* NOR configuration */ - writel(0x00620181, &weim_regs->cs0gcr1); - writel(0x00000001, &weim_regs->cs0gcr2); - writel(0x0b020000, &weim_regs->cs0rcr1); - writel(0x0000b000, &weim_regs->cs0rcr2); - writel(0x0804a240, &weim_regs->cs0wcr1); - writel(0x00000000, &weim_regs->cs0wcr2); - - writel(0x00000120, &weim_regs->wcr); - writel(0x00000010, &weim_regs->wiar); - writel(0x00000000, &weim_regs->ear); - - set_chipselect_size(CS0_128); -} - -static void setup_eimnor(void) -{ - SETUP_IOMUX_PADS(eimnor_pads); - gpio_direction_output(NOR_WP, 1); - - enable_eim_clk(1); - eimnor_cs_setup(); -} - -int board_early_init_f(void) -{ - setup_iomux_uart(); - - return 0; -} - int board_init(void) { /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- gpio_direction_output(DISPLAY_EN, 1); - - setup_eimnor(); - return 0; }
@@ -254,75 +41,3 @@ int checkboard(void)
return 0; } - -#ifdef CONFIG_SPL_BOARD_INIT -void spl_board_init(void) -{ - setup_eimnor(); - - gpio_direction_output(DISPLAY_EN, 1); -} -#endif /* CONFIG_SPL_BOARD_INIT */ - -#ifdef CONFIG_SPL_BUILD -void board_boot_order(u32 *spl_boot_list) -{ - switch (spl_boot_device()) { - case BOOT_DEVICE_MMC2: - case BOOT_DEVICE_MMC1: - spl_boot_list[0] = BOOT_DEVICE_MMC2; - spl_boot_list[1] = BOOT_DEVICE_MMC1; - break; - - case BOOT_DEVICE_NOR: - spl_boot_list[0] = BOOT_DEVICE_NOR; - break; - } -} -#endif /* CONFIG_SPL_BUILD */ - -#ifdef CONFIG_SPL_OS_BOOT -int spl_start_uboot(void) -{ - char s[16]; - int ret; - /* - * We use BOOT_DEVICE_MMC1, but SD card is connected - * to MMC2 - * - * Correct "mapping" is delivered in board defined - * board_boot_order() function. - * - * SD card boot is regarded as a "development" one, - * hence we _always_ go through the u-boot. - * - */ - if (spl_boot_device() == BOOT_DEVICE_MMC1) - return 1; - - /* break into full u-boot on 'c' */ - if (serial_tstc() && serial_getc() == 'c') - return 1; - - env_init(); - ret = env_get_f("boot_os", s, sizeof(s)); - if ((ret != -1) && (strcmp(s, "no") == 0)) - return 1; - - /* - * Check if SWUpdate recovery needs to be started - * - * recovery_status = NULL (not set - ret == -1) -> normal operation - * - * recovery_status = progress or - * recovery_status = failed or - * recovery_status = <any value> -> start SWUpdate - * - */ - ret = env_get_f("recovery_status", s, sizeof(s)); - if (ret != -1) - return 1; - - return 0; -} -#endif /* CONFIG_SPL_OS_BOOT */ diff --git a/board/liebherr/mccmon6/spl.c b/board/liebherr/mccmon6/spl.c index acfc4902c1..da28a22f84 100644 --- a/board/liebherr/mccmon6/spl.c +++ b/board/liebherr/mccmon6/spl.c @@ -20,7 +20,6 @@ #include <asm/arch/sys_proto.h> #include <spl.h>
-#if defined(CONFIG_SPL_BUILD) #include <asm/arch/mx6-ddr.h> /* * Driving strength: @@ -274,6 +273,25 @@ static void spl_dram_init(void) udelay(100); }
+static void setup_spi(void) +{ + enable_spi_clk(true, 2); +} + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart1_pads[] = { + IOMUX_PADS(PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +}; + +static void setup_iomux_uart(void) +{ + SETUP_IOMUX_PADS(uart1_pads); +} + void board_init_f(ulong dummy) { ccgr_init(); @@ -284,7 +302,7 @@ void board_init_f(ulong dummy) gpr_init();
/* iomux */ - board_early_init_f(); + setup_iomux_uart();
/* setup GP timer */ timer_init(); @@ -292,7 +310,257 @@ void board_init_f(ulong dummy) /* UART clocks enabled and gd valid - init serial console */ preloader_console_init();
+ /* enable ECSPI clocks */ + setup_spi(); + /* DDR initialization */ spl_dram_init(); } -#endif + +void board_boot_order(u32 *spl_boot_list) +{ + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC2: + case BOOT_DEVICE_MMC1: + spl_boot_list[0] = BOOT_DEVICE_MMC2; + spl_boot_list[1] = BOOT_DEVICE_MMC1; + break; + + case BOOT_DEVICE_NOR: + spl_boot_list[0] = BOOT_DEVICE_NOR; + break; + } +} + +#ifdef CONFIG_SPL_OS_BOOT +int spl_start_uboot(void) +{ + char s[16]; + int ret; + /* + * We use BOOT_DEVICE_MMC1, but SD card is connected + * to MMC2 + * + * Correct "mapping" is delivered in board defined + * board_boot_order() function. + * + * SD card boot is regarded as a "development" one, + * hence we _always_ go through the u-boot. + * + */ + if (spl_boot_device() == BOOT_DEVICE_MMC1) + return 1; + + /* break into full u-boot on 'c' */ + if (serial_tstc() && serial_getc() == 'c') + return 1; + + env_init(); + ret = env_get_f("boot_os", s, sizeof(s)); + if ((ret != -1) && (strcmp(s, "no") == 0)) + return 1; + + /* + * Check if SWUpdate recovery needs to be started + * + * recovery_status = NULL (not set - ret == -1) -> normal operation + * + * recovery_status = progress or + * recovery_status = failed or + * recovery_status = <any value> -> start SWUpdate + * + */ + ret = env_get_f("recovery_status", s, sizeof(s)); + if (ret != -1) + return 1; + + return 0; +} +#endif /* CONFIG_SPL_OS_BOOT */ + +#define WEIM_NOR_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define NOR_WP IMX_GPIO_NR(1, 1) + +static iomux_v3_cfg_t const eimnor_pads[] = { + IOMUX_PADS(PAD_EIM_D16__EIM_DATA16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D17__EIM_DATA17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D18__EIM_DATA18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D19__EIM_DATA19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D20__EIM_DATA20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D21__EIM_DATA21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D22__EIM_DATA22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D23__EIM_DATA23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D24__EIM_DATA24 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D25__EIM_DATA25 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D26__EIM_DATA26 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D27__EIM_DATA27 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D28__EIM_DATA28 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D29__EIM_DATA29 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D30__EIM_DATA30 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D31__EIM_DATA31 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA0__EIM_AD00 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA1__EIM_AD01 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA2__EIM_AD02 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA3__EIM_AD03 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA4__EIM_AD04 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA5__EIM_AD05 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA6__EIM_AD06 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA7__EIM_AD07 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA8__EIM_AD08 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA9__EIM_AD09 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA10__EIM_AD10 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA11__EIM_AD11 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA12__EIM_AD12 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA13__EIM_AD13 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA14__EIM_AD14 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA15__EIM_AD15 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A16__EIM_ADDR16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A17__EIM_ADDR17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A18__EIM_ADDR18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A19__EIM_ADDR19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A20__EIM_ADDR20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A21__EIM_ADDR21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A22__EIM_ADDR22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A23__EIM_ADDR23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A24__EIM_ADDR24 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A25__EIM_ADDR25 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_OE__EIM_OE_B | MUX_PAD_CTRL(NO_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_RW__EIM_RW | MUX_PAD_CTRL(NO_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_CS0__EIM_CS0_B | MUX_PAD_CTRL(NO_PAD_CTRL)), + IOMUX_PADS(PAD_GPIO_1__GPIO1_IO01 | MUX_PAD_CTRL(NO_PAD_CTRL)), +}; + +static void eimnor_cs_setup(void) +{ + struct weim *weim_regs = (struct weim *)WEIM_BASE_ADDR; + + /* NOR configuration */ + writel(0x00620181, &weim_regs->cs0gcr1); + writel(0x00000001, &weim_regs->cs0gcr2); + writel(0x0b020000, &weim_regs->cs0rcr1); + writel(0x0000b000, &weim_regs->cs0rcr2); + writel(0x0804a240, &weim_regs->cs0wcr1); + writel(0x00000000, &weim_regs->cs0wcr2); + + writel(0x00000120, &weim_regs->wcr); + writel(0x00000010, &weim_regs->wiar); + writel(0x00000000, &weim_regs->ear); + + set_chipselect_size(CS0_128); +} + +static void setup_eimnor(void) +{ + SETUP_IOMUX_PADS(eimnor_pads); + gpio_direction_output(NOR_WP, 1); + + enable_eim_clk(1); + eimnor_cs_setup(); +} + +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC2_CD_GPIO IMX_GPIO_NR(1, 4) + +static iomux_v3_cfg_t const usdhc2_pads[] = { + IOMUX_PADS(PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + /* Carrier MicroSD Card Detect */ + IOMUX_PADS(PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL)), +}; + +static iomux_v3_cfg_t const usdhc3_pads[] = { + IOMUX_PADS(PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_RST__SD3_RESET | MUX_PAD_CTRL(USDHC_PAD_CTRL)), +}; + +static struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC3_BASE_ADDR}, + {USDHC2_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + break; + case USDHC3_BASE_ADDR: + /* + * eMMC don't have card detect pin - since it is soldered to the + * PCB board + */ + ret = 1; + break; + } + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + int ret; + u32 index = 0; + + /* + * MMC MAP + * (U-Boot device node) (Physical Port) + * mmc0 Soldered on board eMMC device + * mmc1 MicroSD card + */ + for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { + switch (index) { + case 0: + SETUP_IOMUX_PADS(usdhc3_pads); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + usdhc_cfg[0].max_bus_width = 8; + break; + case 1: + SETUP_IOMUX_PADS(usdhc2_pads); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + usdhc_cfg[1].max_bus_width = 4; + gpio_direction_input(USDHC2_CD_GPIO); + break; + default: + printf("Warning: More USDHC controllers (%d) than supported (%d)\n", + index + 1, CONFIG_SYS_FSL_USDHC_NUM); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[index]); + if (ret) + return ret; + } + + return 0; +} + +#ifdef CONFIG_SPL_BOARD_INIT +#define DISPLAY_EN IMX_GPIO_NR(1, 2) +void spl_board_init(void) +{ + setup_eimnor(); + + gpio_direction_output(DISPLAY_EN, 1); +} +#endif /* CONFIG_SPL_BOARD_INIT */
This commit adds falcon boot support (by also copying args necessary for booting) to the SPL NOR memory driver.
After this change it is possible to use the falcon boot in the same way as on NAND memories. The necessary configs (i.e. CONFIG_CMD_SPL_NOR_OFS) are now defined in Kconfig.
common/spl/spl_nor.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index 969e319de0..de58c43101 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -48,6 +48,11 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, CONFIG_SYS_OS_BASE, (void *)header);
+#if defined CONFIG_SYS_SPL_ARGS_ADDR && defined CONFIG_CMD_SPL_NOR_OFS + memcpy((void *)CONFIG_SYS_SPL_ARGS_ADDR, + (void *)CONFIG_CMD_SPL_NOR_OFS, + CONFIG_CMD_SPL_WRITE_SIZE); +#endif return ret; } #endif
This commit enabled support for fitImage on mccmon6 when we switch to DT/DTS (including falcon mode).
board/liebherr/mccmon6/spl.c | 7 ++++++ configs/mccmon6_nor_defconfig | 8 +++++- configs/mccmon6_sd_defconfig | 6 ++++- include/configs/mccmon6.h | 57 +++++++++++++++++-------------------------- 4 files changed, 42 insertions(+), 36 deletions(-)
diff --git a/board/liebherr/mccmon6/spl.c b/board/liebherr/mccmon6/spl.c index da28a22f84..e1aa23da3e 100644 --- a/board/liebherr/mccmon6/spl.c +++ b/board/liebherr/mccmon6/spl.c @@ -332,6 +332,13 @@ void board_boot_order(u32 *spl_boot_list) } }
+#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + return 0; +} +#endif + #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 770ef9bed6..62e957c0cf 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL=y # CONFIG_CMD_BMODE is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_nor.cfg" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_BOUNCE_BUFFER=y @@ -17,6 +18,11 @@ CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y +CONFIG_SPL_OS_BOOT=y +CONFIG_SYS_OS_BASE=0x8180000 +CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NOR_OFS=0x09600000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_CLK=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y @@ -29,7 +35,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=8000000.nor" -CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x40000(u-boot-env.nor),1m@0x80000(u-boot.nor),8m@0x180000(kernel.nor),8m@0x980000(swupdate-kernel.nor),8m@0x1180000(swupdate-rootfs.nor),128k@0x1980000(kernel-dtb.nor),128k@0x19C0000(swupdate-kernel-dtb.nor)" +CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x40000(u-boot-env.nor),1m@0x80000(u-boot.nor),8m@0x180000(kernel.nor),8m@0x980000(swupdate-kernel.nor),8m@0x1180000(swupdate-rootfs.nor)" CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-mccmon6" CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 9a11b59738..c72580e362 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL=y # CONFIG_CMD_BMODE is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_sd.cfg" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_BOUNCE_BUFFER=y @@ -18,6 +19,9 @@ CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y +CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NOR_OFS=0x09600000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_CLK=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y @@ -30,7 +34,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=8000000.nor" -CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x40000(u-boot-env.nor),1m@0x80000(u-boot.nor),8m@0x180000(kernel.nor),8m@0x980000(swupdate-kernel.nor),8m@0x1180000(swupdate-rootfs.nor),128k@0x1980000(kernel-dtb.nor),128k@0x19C0000(swupdate-kernel-dtb.nor)" +CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x40000(u-boot-env.nor),1m@0x80000(u-boot.nor),8m@0x180000(kernel.nor),8m@0x980000(swupdate-kernel.nor),8m@0x1180000(swupdate-rootfs.nor)" CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-mccmon6" CONFIG_ENV_IS_IN_FLASH=y diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index b25aacbf41..c685de6551 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -14,10 +14,6 @@
#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_UBOOT_BASE (CONFIG_SYS_FLASH_BASE + 0x80000) -#define CONFIG_SPL_OS_BOOT -#define CONFIG_SYS_OS_BASE (CONFIG_SYS_FLASH_BASE + 0x180000) -#define CONFIG_SYS_FDT_BASE (CONFIG_SYS_FLASH_BASE + 0x1980000) -#define CONFIG_SYS_FDT_SIZE (48 * SZ_1K) #define CONFIG_SYS_SPL_ARGS_ADDR 0x18000000
/* @@ -28,8 +24,7 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR (0x800) #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS (0x80) #define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR (0x1000) -#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" -#define CONFIG_SPL_FS_LOAD_ARGS_NAME "imx6q-mccmon.dtb" +#define CONFIG_SPL_FS_LOAD_KERNEL_NAME "fitImage"
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) @@ -61,14 +56,13 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ "console=ttymxc0,115200 quiet\0" \ - "fdtfile=imx6q-mccmon6.dtb\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "boot_os=yes\0" \ + "kernelsize=0x300000\0" \ "disable_giga=yes\0" \ "download_kernel=" \ - "tftpboot ${kernel_addr} ${kernel_file};" \ - "tftpboot ${fdt_addr} ${fdtfile};\0" \ + "tftpboot ${loadaddr} ${kernel_file};\0" \ "get_boot_medium=" \ "setenv boot_medium nor;" \ "setexpr.l _src_sbmr1 *0x020d8004;" \ @@ -76,10 +70,7 @@ "if test ${_b_medium} = 40; then " \ "setenv boot_medium sdcard;" \ "fi\0" \ - "kernel_file=uImage\0" \ - "load_kernel=" \ - "load mmc ${bootdev}:${bootpart} ${kernel_addr} uImage;" \ - "load mmc ${bootdev}:${bootpart} ${fdt_addr} ${fdtfile};\0" \ + "kernel_file=fitImage\0" \ "boot_sd=" \ "echo '#######################';" \ "echo '# Factory SDcard Boot #';" \ @@ -90,12 +81,11 @@ "run factory_flash_img;\0" \ "boot_nor=" \ "setenv kernelnor 0x08180000;" \ - "setenv dtbnor 0x09980000;" \ "setenv bootargs console=${console} " \ CONFIG_MTDPARTS_DEFAULT " " \ "root=/dev/mmcblk1 rootfstype=ext4 rw rootwait noinitrd;" \ - "cp.l ${dtbnor} ${dtbloadaddr} 0x8000;" \ - "bootm ${kernelnor} - ${dtbloadaddr};\0" \ + "cp.l ${kernelnor} ${loadaddr} ${kernelsize};" \ + "bootm ${loadaddr};reset;\0" \ "boot_recovery=" \ "echo '#######################';" \ "echo '# RECOVERY SWU Boot #';" \ @@ -103,14 +93,13 @@ "setenv rootfsloadaddr 0x13000000;" \ "setenv swukernelnor 0x08980000;" \ "setenv swurootfsnor 0x09180000;" \ - "setenv swudtbnor 0x099A0000;" \ "setenv bootargs console=${console} " \ CONFIG_MTDPARTS_DEFAULT " " \ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ ":${hostname}::off root=/dev/ram rw;" \ "cp.l ${swurootfsnor} ${rootfsloadaddr} 0x200000;" \ - "cp.l ${swudtbnor} ${dtbloadaddr} 0x8000;" \ - "bootm ${swukernelnor} ${rootfsloadaddr} ${dtbloadaddr};\0" \ + "cp.l ${swukernelnor} ${loadaddr} ${kernelsize};" \ + "bootm ${loadaddr} ${rootfsloadaddr};reset;\0" \ "boot_tftp=" \ "echo '#######################';" \ "echo '# TFTP Boot #';" \ @@ -118,7 +107,7 @@ "if run download_kernel; then " \ "setenv bootargs console=${console} " \ "root=/dev/mmcblk0p2 rootwait;" \ - "bootm ${kernel_addr} - ${fdt_addr};" \ + "bootm $loadaddr};reset;" \ "fi\0" \ "bootcmd=" \ "if test -n ${recovery_status}; then " \ @@ -138,13 +127,10 @@ "fi;" \ "fi\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ - "fdt_addr=0x18000000\0" \ "bootdev=1\0" \ "bootpart=1\0" \ - "kernel_addr=" __stringify(CONFIG_LOADADDR) "\0" \ "netdev=eth0\0" \ "load_addr=0x11000000\0" \ - "dtbloadaddr=0x12000000\0" \ "uboot_file=u-boot.img\0" \ "SPL_file=SPL\0" \ "load_uboot=tftp ${load_addr} ${uboot_file}\0" \ @@ -171,6 +157,7 @@ "device ${mmcdev};" \ "run factory_nor_img;" \ "run factory_eMMC_img;" \ + "run factory_SPL_falcon_setup;" \ "fi\0" \ "factory_eMMC_img="\ "echo 'Update mccmon6 eMMC image'; " \ @@ -192,6 +179,16 @@ "erase ${nor_bank_start} +${nor_img_size};" \ "setexpr nor_img_size ${nor_img_size} / 4; " \ "cp.l ${nor_img_addr} ${nor_bank_start} ${nor_img_size}\0" \ + "factory_SPL_falcon_setup="\ + "echo 'Write Falcon boot data'; " \ + "setenv kernelnor 0x08180000;" \ + "cp.l ${kernelnor} ${loadaddr} ${kernelsize};" \ + "spl export fdt ${loadaddr};" \ + "setenv nor_img_addr ${fdtargsaddr};" \ + "setenv nor_img_size 0x20000;" \ + "setenv nor_bank_start " \ + __stringify(CONFIG_CMD_SPL_NOR_OFS)";" \ + "run nor_update\0" \ "tftp_nor_uboot="\ "echo 'Update mccmon6 NOR U-BOOT via TFTP'; " \ "setenv nor_img_file u-boot.img; " \ @@ -200,22 +197,14 @@ "if tftpboot ${nor_img_addr} ${nor_img_file}; then " \ "run nor_update;" \ "fi\0" \ - "tftp_nor_uImg="\ - "echo 'Update mccmon6 NOR uImage via TFTP'; " \ - "setenv nor_img_file uImage; " \ + "tftp_nor_fitImg="\ + "echo 'Update mccmon6 NOR fitImage via TFTP'; " \ + "setenv nor_img_file fitImage; " \ "setenv nor_img_size 0x500000; " \ "setenv nor_bank_start 0x08180000; " \ "if tftpboot ${nor_img_addr} ${nor_img_file}; then " \ "run nor_update;" \ "fi\0" \ - "tftp_nor_dtb="\ - "echo 'Update mccmon6 NOR DTB via TFTP'; " \ - "setenv nor_img_file imx6q-mccmon6.dtb; " \ - "setenv nor_img_size 0x20000; " \ - "setenv nor_bank_start 0x09980000; " \ - "if tftpboot ${nor_img_addr} ${nor_img_file}; then " \ - "run nor_update;" \ - "fi\0" \ "tftp_nor_img="\ "echo 'Update mccmon6 NOR image via TFTP'; " \ "if tftpboot ${nor_img_addr} ${nor_img_file}; then " \
After this change the SPL size has been reduced from 38K to 34K.
configs/mccmon6_nor_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 62e957c0cf..ffb1025a13 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/liebherr/mccmon6/mon6_imximage_nor.cf CONFIG_BOUNCE_BUFFER=y CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_SPL_OS_BOOT=y @@ -81,3 +82,5 @@ CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_SPL_TINY_MEMSET=y
Lukasz Majewski
