[U-Boot] [PATCH 1/2] libfdt: Add support for appending the values to a existing property
Some properties may contain multiple values, these values may need to be added to the property respectively. this patch provides this functionality. The main purpose of fdt_append_prop() is to append the values to a existing property, or create a new property if it dose not exist.
Signed-off-by: Minghuan Lian Minghuan.Lian@freescale.com Signed-off-by: David Gibson david@gibson.dropbear.id.au --- include/libfdt.h | 95 +++++++++++++++++++++++++++++++++++++++++++++++++++++ lib/libfdt/fdt_rw.c | 27 +++++++++++++++ 2 files changed, 122 insertions(+)
diff --git a/include/libfdt.h b/include/libfdt.h index de82ed5..78798e8 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -1134,6 +1134,101 @@ static inline int fdt_setprop_cell(void *fdt, int nodeoffset, const char *name, fdt_setprop((fdt), (nodeoffset), (name), (str), strlen(str)+1)
/** + * fdt_appendprop - append to or create a property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to append to + * @val: pointer to data to append to the property value + * @len: length of the data to append to the property value + * + * fdt_appendprop() appends the value to the named property in the + * given node, creating the property if it does not already exist. + * + * This function may insert data into the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_appendprop(void *fdt, int nodeoffset, const char *name, + const void *val, int len); + +/** + * fdt_appendprop_cell - append a single cell value to a property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: 32-bit integer value to append to the property (native endian) + * + * fdt_appendprop_cell() appends the given cell value (converting to + * big-endian if necessary) to the value of the named property in the + * given node, or creates a new property with that value if it does + * not already exist. + * + * This function may insert data into the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +static inline int fdt_appendprop_cell(void *fdt, int nodeoffset, + const char *name, uint32_t val) +{ + val = cpu_to_fdt32(val); + return fdt_appendprop(fdt, nodeoffset, name, &val, sizeof(val)); +} + +/** + * fdt_appendprop_string - append a string to a property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @str: string value to append to the property + * + * fdt_appendprop_string() appends the given string to the value of + * the named property in the given node, or creates a new property + * with that value if it does not already exist. + * + * This function may insert data into the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +#define fdt_appendprop_string(fdt, nodeoffset, name, str) \ + fdt_appendprop((fdt), (nodeoffset), (name), (str), strlen(str)+1) + +/** * fdt_delprop - delete a property * @fdt: pointer to the device tree blob * @nodeoffset: offset of the node whose property to nop diff --git a/lib/libfdt/fdt_rw.c b/lib/libfdt/fdt_rw.c index 5c27a67..5ed23d6 100644 --- a/lib/libfdt/fdt_rw.c +++ b/lib/libfdt/fdt_rw.c @@ -293,6 +293,33 @@ int fdt_setprop(void *fdt, int nodeoffset, const char *name, return 0; }
+int fdt_appendprop(void *fdt, int nodeoffset, const char *name, + const void *val, int len) +{ + struct fdt_property *prop; + int err, oldlen, newlen; + + FDT_RW_CHECK_HEADER(fdt); + + prop = fdt_get_property_w(fdt, nodeoffset, name, &oldlen); + if (prop) { + newlen = len + oldlen; + err = _fdt_splice_struct(fdt, prop->data, + FDT_TAGALIGN(oldlen), + FDT_TAGALIGN(newlen)); + if (err) + return err; + prop->len = cpu_to_fdt32(newlen); + memcpy(prop->data + oldlen, val, len); + } else { + err = _fdt_add_property(fdt, nodeoffset, name, len, &prop); + if (err) + return err; + memcpy(prop->data, val, len); + } + return 0; +} + int fdt_delprop(void *fdt, int nodeoffset, const char *name) { struct fdt_property *prop;
In device trees in the world, properties consisting of a single 64-bit integer are not as common as those consisting of a single 32-bit, cell sized integer, but they're common enough that they're worth including convenience functions for.
This patch adds helper wrappers of fdt_setprop_inplace(), fdt_setprop() and fdt_appendprop() for handling 64-bit integer quantities in properties. For better consistency with the names of these new *_u64() functions we also add *_u32() functions as alternative names for the existing *_cell() functions handling 32-bit integers.
Signed-off-by: David Gibson david@gibson.dropbear.id.au --- include/libfdt.h | 193 ++++++++++++++++++++++++++++++++++++++++++++++++------- 1 file changed, 170 insertions(+), 23 deletions(-)
diff --git a/include/libfdt.h b/include/libfdt.h index 78798e8..4589c5f 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -852,17 +852,17 @@ int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name, const void *val, int len);
/** - * fdt_setprop_inplace_cell - change the value of a single-cell property + * fdt_setprop_inplace_u32 - change the value of a 32-bit integer property * @fdt: pointer to the device tree blob * @nodeoffset: offset of the node whose property to change * @name: name of the property to change - * @val: cell (32-bit integer) value to replace the property with + * @val: 32-bit integer value to replace the property with * - * fdt_setprop_inplace_cell() replaces the value of a given property - * with the 32-bit integer cell value in val, converting val to - * big-endian if necessary. This function cannot change the size of a - * property, and so will only work if the property already exists and - * has length 4. + * fdt_setprop_inplace_u32() replaces the value of a given property + * with the 32-bit integer value in val, converting val to big-endian + * if necessary. This function cannot change the size of a property, + * and so will only work if the property already exists and has length + * 4. * * This function will alter only the bytes in the blob which contain * the given property value, and will not alter or move any other part @@ -871,7 +871,7 @@ int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name, * returns: * 0, on success * -FDT_ERR_NOSPACE, if the property's length is not equal to 4 - * -FDT_ERR_NOTFOUND, node does not have the named property + * -FDT_ERR_NOTFOUND, node does not have the named property * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag * -FDT_ERR_BADMAGIC, * -FDT_ERR_BADVERSION, @@ -879,14 +879,60 @@ int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name, * -FDT_ERR_BADSTRUCTURE, * -FDT_ERR_TRUNCATED, standard meanings */ -static inline int fdt_setprop_inplace_cell(void *fdt, int nodeoffset, - const char *name, uint32_t val) +static inline int fdt_setprop_inplace_u32(void *fdt, int nodeoffset, + const char *name, uint32_t val) { val = cpu_to_fdt32(val); return fdt_setprop_inplace(fdt, nodeoffset, name, &val, sizeof(val)); }
/** + * fdt_setprop_inplace_u64 - change the value of a 64-bit integer property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: 64-bit integer value to replace the property with + * + * fdt_setprop_inplace_u64() replaces the value of a given property + * with the 64-bit integer value in val, converting val to big-endian + * if necessary. This function cannot change the size of a property, + * and so will only work if the property already exists and has length + * 8. + * + * This function will alter only the bytes in the blob which contain + * the given property value, and will not alter or move any other part + * of the tree. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, if the property's length is not equal to 8 + * -FDT_ERR_NOTFOUND, node does not have the named property + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +static inline int fdt_setprop_inplace_u64(void *fdt, int nodeoffset, + const char *name, uint64_t val) +{ + val = cpu_to_fdt64(val); + return fdt_setprop_inplace(fdt, nodeoffset, name, &val, sizeof(val)); +} + +/** + * fdt_setprop_inplace_cell - change the value of a single-cell property + * + * This is an alternative name for fdt_setprop_inplace_u32() + */ +static inline int fdt_setprop_inplace_cell(void *fdt, int nodeoffset, + const char *name, uint32_t val) +{ + return fdt_setprop_inplace_u32(fdt, nodeoffset, name, val); +} + +/** * fdt_nop_property - replace a property with nop tags * @fdt: pointer to the device tree blob * @nodeoffset: offset of the node whose property to nop @@ -945,11 +991,20 @@ int fdt_add_reservemap_entry(void *fdt, uint64_t addr, uint64_t size); int fdt_finish_reservemap(void *fdt); int fdt_begin_node(void *fdt, const char *name); int fdt_property(void *fdt, const char *name, const void *val, int len); -static inline int fdt_property_cell(void *fdt, const char *name, uint32_t val) +static inline int fdt_property_u32(void *fdt, const char *name, uint32_t val) { val = cpu_to_fdt32(val); return fdt_property(fdt, name, &val, sizeof(val)); } +static inline int fdt_property_u64(void *fdt, const char *name, uint64_t val) +{ + val = cpu_to_fdt64(val); + return fdt_property(fdt, name, &val, sizeof(val)); +} +static inline int fdt_property_cell(void *fdt, const char *name, uint32_t val) +{ + return fdt_property_u32(fdt, name, val); +} #define fdt_property_string(fdt, name, str) \ fdt_property(fdt, name, str, strlen(str)+1) int fdt_end_node(void *fdt); @@ -1068,14 +1123,14 @@ int fdt_setprop(void *fdt, int nodeoffset, const char *name, const void *val, int len);
/** - * fdt_setprop_cell - set a property to a single cell value + * fdt_setprop_u32 - set a property to a 32-bit integer * @fdt: pointer to the device tree blob * @nodeoffset: offset of the node whose property to change * @name: name of the property to change * @val: 32-bit integer value for the property (native endian) * - * fdt_setprop_cell() sets the value of the named property in the - * given node to the given cell value (converting to big-endian if + * fdt_setprop_u32() sets the value of the named property in the given + * node to the given 32-bit integer value (converting to big-endian if * necessary), or creates a new property with that value if it does * not already exist. * @@ -1095,14 +1150,60 @@ int fdt_setprop(void *fdt, int nodeoffset, const char *name, * -FDT_ERR_BADLAYOUT, * -FDT_ERR_TRUNCATED, standard meanings */ -static inline int fdt_setprop_cell(void *fdt, int nodeoffset, const char *name, - uint32_t val) +static inline int fdt_setprop_u32(void *fdt, int nodeoffset, const char *name, + uint32_t val) { val = cpu_to_fdt32(val); return fdt_setprop(fdt, nodeoffset, name, &val, sizeof(val)); }
/** + * fdt_setprop_u64 - set a property to a 64-bit integer + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: 64-bit integer value for the property (native endian) + * + * fdt_setprop_u64() sets the value of the named property in the given + * node to the given 64-bit integer value (converting to big-endian if + * necessary), or creates a new property with that value if it does + * not already exist. + * + * This function may insert or delete data from the blob, and will + * therefore change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +static inline int fdt_setprop_u64(void *fdt, int nodeoffset, const char *name, + uint64_t val) +{ + val = cpu_to_fdt64(val); + return fdt_setprop(fdt, nodeoffset, name, &val, sizeof(val)); +} + +/** + * fdt_setprop_cell - set a property to a single cell value + * + * This is an alternative name for fdt_setprop_u32() + */ +static inline int fdt_setprop_cell(void *fdt, int nodeoffset, const char *name, + uint32_t val) +{ + return fdt_setprop_u32(fdt, nodeoffset, name, val); +} + +/** * fdt_setprop_string - set a property to a string value * @fdt: pointer to the device tree blob * @nodeoffset: offset of the node whose property to change @@ -1164,16 +1265,16 @@ int fdt_appendprop(void *fdt, int nodeoffset, const char *name, const void *val, int len);
/** - * fdt_appendprop_cell - append a single cell value to a property + * fdt_appendprop_u32 - append a 32-bit integer value to a property * @fdt: pointer to the device tree blob * @nodeoffset: offset of the node whose property to change * @name: name of the property to change * @val: 32-bit integer value to append to the property (native endian) * - * fdt_appendprop_cell() appends the given cell value (converting to - * big-endian if necessary) to the value of the named property in the - * given node, or creates a new property with that value if it does - * not already exist. + * fdt_appendprop_u32() appends the given 32-bit integer value + * (converting to big-endian if necessary) to the value of the named + * property in the given node, or creates a new property with that + * value if it does not already exist. * * This function may insert data into the blob, and will therefore * change the offsets of some existing nodes. @@ -1191,14 +1292,60 @@ int fdt_appendprop(void *fdt, int nodeoffset, const char *name, * -FDT_ERR_BADLAYOUT, * -FDT_ERR_TRUNCATED, standard meanings */ -static inline int fdt_appendprop_cell(void *fdt, int nodeoffset, - const char *name, uint32_t val) +static inline int fdt_appendprop_u32(void *fdt, int nodeoffset, + const char *name, uint32_t val) { val = cpu_to_fdt32(val); return fdt_appendprop(fdt, nodeoffset, name, &val, sizeof(val)); }
/** + * fdt_appendprop_u64 - append a 64-bit integer value to a property + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to change + * @name: name of the property to change + * @val: 64-bit integer value to append to the property (native endian) + * + * fdt_appendprop_u64() appends the given 64-bit integer value + * (converting to big-endian if necessary) to the value of the named + * property in the given node, or creates a new property with that + * value if it does not already exist. + * + * This function may insert data into the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * contain the new property value + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_TRUNCATED, standard meanings + */ +static inline int fdt_appendprop_u64(void *fdt, int nodeoffset, + const char *name, uint64_t val) +{ + val = cpu_to_fdt64(val); + return fdt_appendprop(fdt, nodeoffset, name, &val, sizeof(val)); +} + +/** + * fdt_appendprop_cell - append a single cell value to a property + * + * This is an alternative name for fdt_appendprop_u32() + */ +static inline int fdt_appendprop_cell(void *fdt, int nodeoffset, + const char *name, uint32_t val) +{ + return fdt_appendprop_u32(fdt, nodeoffset, name, val); +} + +/** * fdt_appendprop_string - append a string to a property * @fdt: pointer to the device tree blob * @nodeoffset: offset of the node whose property to change
Queued up 2 of 2 patches to the u-boot-fdt "next" branch. I'll issue a pull request when the merge window opens.
Thanks, gvb
I thought libfdt patches were suppose to go to dtc.git?
That is where they came from. Since the u-boot libfdt is a subset of the whole dtc.git repository (just the libfdt part), I've been cherry picking only the libfdt/* patches (with the help of others).
I see David has another patch for the libfdt library that I probably should pick up so that we stay in sync (18 lines of code by counting semicolons).
commit be6026838e45b67800ac803f4ad8cca3cde57d6d Author: David Gibson david@gibson.dropbear.id.au Date: Fri Jun 1 14:12:38 2012 +1000
libfdt: Add helper function to create a trivial, empty tree
The libfdt read/write functions are now usable enough that it's become a moderately common pattern to use them to build and manipulate a device tree from scratch. For example, we do so ourself in our rw_tree1 testcase, and qemu is starting to use this model when building device trees for some targets such as e500.
However, the read/write functions require some sort of valid tree to begin with, so this necessitates either having a trivial canned dtb to begin with or, more commonly, creating an empty tree using the serial-write functions first.
This patch adds a helper function which uses the serial-write functions to create a trivial, empty but complete and valid tree in a supplied buffer, ready for manipulation with the read/write functions.
On Sat, 15 Sep 2012 10:36:28 -0400 Jerry Van Baren gvb.uboot@gmail.com wrote:
the merge window closed five days ago, and these didn't make it in. What's the deal?
Kim
On Thu, Nov 8, 2012 at 5:41 PM, Kim Phillips kim.phillips@freescale.com wrote:
Well it doesn't mean it won't be applied. Probably just need to wait a bit.
Kim
Kim
It's in there: http://git.denx.de/?p=u-boot.git;a=commit;h=36ad18a6db0eec546b83e6500ceb7593be53a1ed
I sent a pull request Mon, Oct 22, 2012 and Tom applied it on Oct 23: ----------------------------------------------------------------- David Gibson (1): libfdt: Add helpers for 64-bit integer properties
Gerald Van Baren (2): libfdt: Add helper function to create a trivial, empty tree Merge branch 'next'
Joe Hershberger (5): fdt: Check error codes returned from fdtlib when loading ITB fdt: Limit printed hex in fdt print and list commands fdt: Add get commands to fdt fdt: Identify scripts in ITBs as printable strings fdt: Check for a token to skip auto-hash validation
Minghuan Lian (1): libfdt: Add support for appending the values to a existing property -----------------------------------------------------------------
Best regards, gvb
On Mon, 12 Nov 2012 21:41:17 -0500 Jerry Van Baren gvb.uboot@gmail.com wrote:
right you are - don't know what I was looking at - my apologies.
Kim
Jerry Van Baren
Kim Phillips
Tabi Timur-B04825
