[U-Boot] [PATCH] nios2: zap nios2-generic board dir
As we use device tree to control u-boot now, the generic board can be removed.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/Kconfig | 16 ++---- arch/nios2/config.mk | 3 +- board/altera/common/cfide.c | 33 ----------- board/altera/nios2-generic/Kconfig | 12 ---- board/altera/nios2-generic/MAINTAINERS | 6 -- board/altera/nios2-generic/Makefile | 10 ---- board/altera/nios2-generic/config.mk | 12 ---- board/altera/nios2-generic/custom_fpga.h | 89 ------------------------------ board/altera/nios2-generic/nios2-generic.c | 76 ------------------------- configs/nios2-generic_defconfig | 2 +- include/configs/nios2-generic.h | 23 +++++--- 11 files changed, 24 insertions(+), 258 deletions(-) delete mode 100644 board/altera/common/cfide.c delete mode 100644 board/altera/nios2-generic/Kconfig delete mode 100644 board/altera/nios2-generic/MAINTAINERS delete mode 100644 board/altera/nios2-generic/Makefile delete mode 100644 board/altera/nios2-generic/config.mk delete mode 100644 board/altera/nios2-generic/custom_fpga.h delete mode 100644 board/altera/nios2-generic/nios2-generic.c
diff --git a/arch/nios2/Kconfig b/arch/nios2/Kconfig index 8ae7f6e..bb4fb2a 100644 --- a/arch/nios2/Kconfig +++ b/arch/nios2/Kconfig @@ -4,15 +4,11 @@ menu "Nios II architecture" config SYS_ARCH default "nios2"
-choice - prompt "Target select" - optional - -config TARGET_NIOS2_GENERIC - bool "Support nios2-generic" - -endchoice - -source "board/altera/nios2-generic/Kconfig" +config SYS_CONFIG_NAME + string "Board header file" + help + This option should contain the base name of board header file. + The header file include/configs/<CONFIG_SYS_CONFIG_NAME>.h + should be included from include/config.h.
endmenu diff --git a/arch/nios2/config.mk b/arch/nios2/config.mk index 82bd887..2abad3f 100644 --- a/arch/nios2/config.mk +++ b/arch/nios2/config.mk @@ -10,10 +10,11 @@ ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := nios2-elf- endif
-CONFIG_STANDALONE_LOAD_ADDR ?= 0x02000000 +CONFIG_STANDALONE_LOAD_ADDR ?= 0xd2000000
PLATFORM_CPPFLAGS += -D__NIOS2__ PLATFORM_CPPFLAGS += -G0 +PLATFORM_CPPFLAGS += -mno-hw-div -mno-hw-mul
LDFLAGS_FINAL += --gc-sections PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections diff --git a/board/altera/common/cfide.c b/board/altera/common/cfide.c deleted file mode 100644 index 40d6a12..0000000 --- a/board/altera/common/cfide.c +++ /dev/null @@ -1,33 +0,0 @@ -/* - * Altera CF drvier - * - * (C) Copyright 2010, Thomas Chou thomas@wytron.com.tw - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ -#include <common.h> -#include <asm/io.h> - -#if defined(CONFIG_IDE_RESET) && defined(CONFIG_SYS_CF_CTL_BASE) -/* ide_set_reset for Altera CF interface */ -#define ALTERA_CF_CTL_STATUS 0 -#define ALTERA_CF_IDE_CTL 4 -#define ALTERA_CF_CTL_STATUS_PRESENT_MSK (0x1) -#define ALTERA_CF_CTL_STATUS_POWER_MSK (0x2) -#define ALTERA_CF_CTL_STATUS_RESET_MSK (0x4) -#define ALTERA_CF_CTL_STATUS_IRQ_EN_MSK (0x8) -#define ALTERA_CF_IDE_CTL_IRQ_EN_MSK (0x1) - -void ide_set_reset(int idereset) -{ - int i; - writel(idereset ? ALTERA_CF_CTL_STATUS_RESET_MSK : - ALTERA_CF_CTL_STATUS_POWER_MSK, - CONFIG_SYS_CF_CTL_BASE + ALTERA_CF_CTL_STATUS); - /* wait 500 ms for power to stabilize */ - for (i = 0; i < 500; i++) - udelay(1000); -} -#endif diff --git a/board/altera/nios2-generic/Kconfig b/board/altera/nios2-generic/Kconfig deleted file mode 100644 index cd3d098..0000000 --- a/board/altera/nios2-generic/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_NIOS2_GENERIC - -config SYS_BOARD - default "nios2-generic" - -config SYS_VENDOR - default "altera" - -config SYS_CONFIG_NAME - default "nios2-generic" - -endif diff --git a/board/altera/nios2-generic/MAINTAINERS b/board/altera/nios2-generic/MAINTAINERS deleted file mode 100644 index 9cbcba9..0000000 --- a/board/altera/nios2-generic/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -NIOS2-GENERIC BOARD -M: Scott McNutt smcnutt@psyent.com -S: Maintained -F: board/altera/nios2-generic/ -F: include/configs/nios2-generic.h -F: configs/nios2-generic_defconfig diff --git a/board/altera/nios2-generic/Makefile b/board/altera/nios2-generic/Makefile deleted file mode 100644 index 5e4192c..0000000 --- a/board/altera/nios2-generic/Makefile +++ /dev/null @@ -1,10 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# (C) Copyright 2010, Thomas Chou thomas@wytron.com.tw -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := nios2-generic.o -obj-$(CONFIG_CMD_IDE) += ../common/cfide.o diff --git a/board/altera/nios2-generic/config.mk b/board/altera/nios2-generic/config.mk deleted file mode 100644 index a673525..0000000 --- a/board/altera/nios2-generic/config.mk +++ /dev/null @@ -1,12 +0,0 @@ -# -# (C) Copyright 2005, Psyent Corporation <www.psyent.com> -# Scott McNutt smcnutt@psyent.com -# -# SPDX-License-Identifier: GPL-2.0+ -# - -PLATFORM_CPPFLAGS += -mno-hw-div -mno-hw-mul - -ifeq ($(debug),1) -PLATFORM_CPPFLAGS += -DDEBUG -endif diff --git a/board/altera/nios2-generic/custom_fpga.h b/board/altera/nios2-generic/custom_fpga.h deleted file mode 100644 index cf75d35..0000000 --- a/board/altera/nios2-generic/custom_fpga.h +++ /dev/null @@ -1,89 +0,0 @@ -/* - * This header is generated by sopc2dts - * Sopc2dts is written by Walter Goossens waltergoossens@home.nl - * in cooperation with the nios2 community Nios2-dev@sopc.et.ntust.edu.tw - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef _CUSTOM_FPGA_H_ -#define _CUSTOM_FPGA_H_ - -/* generated from qsys_ghrd_3c120.sopcinfo */ - -/* Dumping slaves of cpu.data_master */ - -/* cpu.jtag_debug_module is a altera_nios2_qsys */ -#define CONFIG_SYS_CLK_FREQ 125000000 -#define CONFIG_SYS_DCACHE_SIZE 32768 -#define CONFIG_SYS_DCACHELINE_SIZE 32 -#define CONFIG_SYS_ICACHELINE_SIZE 32 -#define CONFIG_SYS_EXCEPTION_ADDR 0xd0000020 -#define CONFIG_SYS_ICACHE_SIZE 32768 -#define CONFIG_SYS_RESET_ADDR 0xc2800000 -#define IO_REGION_BASE 0xE0000000 - -/* pb_cpu_to_ddr2_bot.s0 is a altera_avalon_mm_bridge */ -/* Dumping slaves of pb_cpu_to_ddr2_bot.m0 */ - -/* ddr2_bot.s1 is a altmemddr2 */ -#define CONFIG_SYS_SDRAM_BASE 0xD0000000 -#define CONFIG_SYS_SDRAM_SIZE 0x08000000 - -/* pb_cpu_to_io.s0 is a altera_avalon_mm_bridge */ -/* Dumping slaves of pb_cpu_to_io.m0 */ - -/* timer_1ms.s1 is a altera_avalon_timer */ -#define CONFIG_SYS_TIMER_IRQ 11 -#define CONFIG_SYS_TIMER_FREQ 125000000 -#define CONFIG_SYS_TIMER_BASE 0xE8400000 - -/* sysid.control_slave is a altera_avalon_sysid_qsys */ -#define CONFIG_SYS_SYSID_BASE 0xE8004D40 - -/* jtag_uart.avalon_jtag_slave is a altera_avalon_jtag_uart */ -#define CONFIG_SYS_JTAG_UART_BASE 0xE8004D50 - -/* tse_mac.control_port is a triple_speed_ethernet */ -#define CONFIG_SYS_ALTERA_TSE_RX_FIFO 2048 -#define CONFIG_SYS_ALTERA_TSE_SGDMA_TX_BASE 0xE8004800 -#define CONFIG_SYS_ALTERA_TSE_SGDMA_RX_BASE 0xE8004400 -#define CONFIG_SYS_ALTERA_TSE_TX_FIFO 2048 -#define CONFIG_SYS_ALTERA_TSE_DESC_SIZE 0x00002000 -#define CONFIG_SYS_ALTERA_TSE_MAC_BASE 0xE8004000 -#define CONFIG_SYS_ALTERA_TSE_DESC_BASE 0xE8002000 -#define CONFIG_ALTERA_TSE -#define CONFIG_MII -#define CONFIG_CMD_MII -#define CONFIG_SYS_ALTERA_TSE_PHY_ADDR 18 -#define CONFIG_SYS_ALTERA_TSE_FLAGS 1 - -/* uart.s1 is a altera_avalon_uart */ -#define CONFIG_SYS_UART_BAUD 115200 -#define CONFIG_SYS_UART_BASE 0xE8004C80 -#define CONFIG_SYS_UART_FREQ 62500000 - -/* user_led_pio_8out.s1 is a altera_avalon_pio */ -#define USER_LED_PIO_8OUT_BASE 0xE8004CC0 - -/* user_dipsw_pio_8in.s1 is a altera_avalon_pio */ -#define USER_DIPSW_PIO_8IN_BASE 0xE8004CE0 -#define USER_DIPSW_PIO_8IN_IRQ 8 - -/* user_pb_pio_4in.s1 is a altera_avalon_pio */ -#define USER_PB_PIO_4IN_BASE 0xE8004D00 -#define USER_PB_PIO_4IN_IRQ 9 - -/* cfi_flash_64m.uas is a altera_generic_tristate_controller */ -#define CFI_FLASH_64M_BASE 0xE0000000 - -/* ext_flash.s1 is a altera_avalon_cfi_flash */ -#define CONFIG_SYS_FLASH_BASE CFI_FLASH_64M_BASE -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_CFI_FLASH_STATUS_POLL /* fix amd flash issue */ -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE -#define CONFIG_SYS_FLASH_PROTECTION -#define CONFIG_SYS_MAX_FLASH_BANKS 1 -#define CONFIG_SYS_MAX_FLASH_SECT 512 - -#endif /* _CUSTOM_FPGA_H_ */ diff --git a/board/altera/nios2-generic/nios2-generic.c b/board/altera/nios2-generic/nios2-generic.c deleted file mode 100644 index e7fecd2..0000000 --- a/board/altera/nios2-generic/nios2-generic.c +++ /dev/null @@ -1,76 +0,0 @@ -/* - * (C) Copyright 2005, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * (C) Copyright 2010, Thomas Chou thomas@wytron.com.tw - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <netdev.h> -#if defined(CONFIG_CFI_FLASH_MTD) -#include <mtd/cfi_flash.h> -#endif -#include <asm/io.h> -#include <asm/gpio.h> - -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) && \ - defined(CONFIG_CFI_FLASH_MTD) -static void __early_flash_cmd_reset(void) -{ - /* reset flash before we read env */ - writeb(AMD_CMD_RESET, CONFIG_ENV_ADDR); - writeb(FLASH_CMD_RESET, CONFIG_ENV_ADDR); -} -void early_flash_cmd_reset(void) - __attribute__((weak,alias("__early_flash_cmd_reset"))); -#endif - -int board_early_init_f(void) -{ -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) && \ - defined(CONFIG_CFI_FLASH_MTD) - early_flash_cmd_reset(); -#endif - return 0; -} - -int checkboard(void) -{ -#ifdef CONFIG_ALTERA_SYSID - display_sysid(); -#endif - printf("BOARD: %s\n", CONFIG_BOARD_NAME); - return 0; -} - -#ifdef CONFIG_CMD_NET -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_SMC91111 - rc += smc91111_initialize(0, CONFIG_SMC91111_BASE); -#endif -#ifdef CONFIG_DRIVER_DM9000 - rc += dm9000_initialize(bis); -#endif -#ifdef CONFIG_ALTERA_TSE - rc += altera_tse_initialize(0, - CONFIG_SYS_ALTERA_TSE_MAC_BASE, - CONFIG_SYS_ALTERA_TSE_SGDMA_RX_BASE, - CONFIG_SYS_ALTERA_TSE_SGDMA_TX_BASE, -#if defined(CONFIG_SYS_ALTERA_TSE_SGDMA_DESC_BASE) && \ - (CONFIG_SYS_ALTERA_TSE_SGDMA_DESC_SIZE > 0) - CONFIG_SYS_ALTERA_TSE_SGDMA_DESC_BASE, - CONFIG_SYS_ALTERA_TSE_SGDMA_DESC_SIZE); -#else - 0, - 0); -#endif -#endif -#ifdef CONFIG_ETHOC - rc += ethoc_initialize(0, CONFIG_SYS_ETHOC_BASE); -#endif - return rc; -} -#endif diff --git a/configs/nios2-generic_defconfig b/configs/nios2-generic_defconfig index 7b504ba..a3e4b51 100644 --- a/configs/nios2-generic_defconfig +++ b/configs/nios2-generic_defconfig @@ -1,7 +1,7 @@ CONFIG_NIOS2=y +CONFIG_SYS_CONFIG_NAME="nios2-generic" CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y -CONFIG_TARGET_NIOS2_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="3c120_devboard" CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index e4b5abb..11be6e1 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -12,12 +12,8 @@ /* * BOARD/CPU */ -#include "../board/altera/nios2-generic/custom_fpga.h" /* fpga parameters */ -#define CONFIG_BOARD_NAME "nios2-generic" /* custom board name */ -#define CONFIG_BOARD_EARLY_INIT_F /* enable early board-spec. init */ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO_LATE -#define CONFIG_SYS_NIOS_SYSID_BASE CONFIG_SYS_SYSID_BASE
/* * SERIAL @@ -26,6 +22,17 @@ #define CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress console info */
/* + * CFI Flash + */ +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_CFI_FLASH_STATUS_POLL /* fix amd flash issue */ +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 512 + +/* * BOOTP options */ #define CONFIG_BOOTP_BOOTFILESIZE @@ -49,11 +56,9 @@ */ #define CONFIG_ENV_IS_IN_FLASH
-#define CONFIG_ENV_SIZE 0x20000 /* 128k, 1 sector */ +#define CONFIG_ENV_SIZE 0x20000 /* 128k, 1 sector */ #define CONFIG_ENV_OVERWRITE /* Serial change Ok */ -#define CONFIG_ENV_ADDR ((CONFIG_SYS_RESET_ADDR + \ - CONFIG_SYS_MONITOR_LEN) | \ - CONFIG_SYS_FLASH_BASE) +#define CONFIG_ENV_ADDR 0xe2840000
/* * MEMORY ORGANIZATION @@ -61,6 +66,8 @@ * -The heap is placed below the monitor * -The stack is placed below the heap (&grows down). */ +#define CONFIG_SYS_SDRAM_BASE 0xD0000000 +#define CONFIG_SYS_SDRAM_SIZE 0x08000000 #define CONFIG_MONITOR_IS_IN_RAM #define CONFIG_SYS_MONITOR_LEN 0x40000 /* Reserve 256k */ #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_SDRAM_BASE + \
Hi!
-choice
- optional
-endchoice
- string "Board header file"
- help
I suspect we don't want this, since we're probing from DT. This option should default to something like include/configs/nios2.h , no ?
This doesn't look like a removal of generic board ;-)
This doesn't look that way either, you might want to split this patch into a series.
I'm really happy to see the generic board go, thanks!
Hi Marek,
- help
This is needed as the Kconfig doesn't cover every config option yet. We still need a per board file. But this is supposed to be removed when Kconfig is done for every option.
Now, the legacy board header, defconfig and dts are all that we need to add a new board to nios2. I should add a README.nios2 after I finished the conversion of altera_tse to driver model.
Yes. I will split them. Thanks a lot for your review.
Best regards, Thomas
On Monday, October 19, 2015 at 01:41:48 AM, Thomas Chou wrote:
Hi Marek,
- help
Don't we support just nios2-generic board ?
Yeah :) Thanks!
Best regards, Marek Vasut
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 split change to nios2/config.mk as suggested by Marek.
arch/nios2/Kconfig | 16 ++---- board/altera/common/cfide.c | 33 ----------- board/altera/nios2-generic/Kconfig | 12 ---- board/altera/nios2-generic/MAINTAINERS | 6 -- board/altera/nios2-generic/Makefile | 10 ---- board/altera/nios2-generic/config.mk | 12 ---- board/altera/nios2-generic/custom_fpga.h | 89 ------------------------------ board/altera/nios2-generic/nios2-generic.c | 76 ------------------------- configs/nios2-generic_defconfig | 2 +- include/configs/nios2-generic.h | 23 +++++--- 10 files changed, 22 insertions(+), 257 deletions(-) delete mode 100644 board/altera/common/cfide.c delete mode 100644 board/altera/nios2-generic/Kconfig delete mode 100644 board/altera/nios2-generic/MAINTAINERS delete mode 100644 board/altera/nios2-generic/Makefile delete mode 100644 board/altera/nios2-generic/config.mk delete mode 100644 board/altera/nios2-generic/custom_fpga.h delete mode 100644 board/altera/nios2-generic/nios2-generic.c
endmenu diff --git a/board/altera/common/cfide.c b/board/altera/common/cfide.c deleted file mode 100644 index 40d6a12..0000000 --- a/board/altera/common/cfide.c +++ /dev/null @@ -1,33 +0,0 @@ -/* - * Altera CF drvier - * - * (C) Copyright 2010, Thomas Chou thomas@wytron.com.tw - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ -#include <common.h> -#include <asm/io.h> - -#if defined(CONFIG_IDE_RESET) && defined(CONFIG_SYS_CF_CTL_BASE) -/* ide_set_reset for Altera CF interface */ -#define ALTERA_CF_CTL_STATUS 0 -#define ALTERA_CF_IDE_CTL 4 -#define ALTERA_CF_CTL_STATUS_PRESENT_MSK (0x1) -#define ALTERA_CF_CTL_STATUS_POWER_MSK (0x2) -#define ALTERA_CF_CTL_STATUS_RESET_MSK (0x4) -#define ALTERA_CF_CTL_STATUS_IRQ_EN_MSK (0x8) -#define ALTERA_CF_IDE_CTL_IRQ_EN_MSK (0x1) - -void ide_set_reset(int idereset) -{ - int i; - writel(idereset ? ALTERA_CF_CTL_STATUS_RESET_MSK : - ALTERA_CF_CTL_STATUS_POWER_MSK, - CONFIG_SYS_CF_CTL_BASE + ALTERA_CF_CTL_STATUS); - /* wait 500 ms for power to stabilize */ - for (i = 0; i < 500; i++) - udelay(1000); -} -#endif diff --git a/board/altera/nios2-generic/Kconfig b/board/altera/nios2-generic/Kconfig deleted file mode 100644 index cd3d098..0000000 --- a/board/altera/nios2-generic/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_NIOS2_GENERIC - -config SYS_BOARD - default "nios2-generic" - -config SYS_VENDOR - default "altera" - -config SYS_CONFIG_NAME - default "nios2-generic" - -endif diff --git a/board/altera/nios2-generic/MAINTAINERS b/board/altera/nios2-generic/MAINTAINERS deleted file mode 100644 index 9cbcba9..0000000 --- a/board/altera/nios2-generic/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -NIOS2-GENERIC BOARD -M: Scott McNutt smcnutt@psyent.com -S: Maintained -F: board/altera/nios2-generic/ -F: include/configs/nios2-generic.h -F: configs/nios2-generic_defconfig diff --git a/board/altera/nios2-generic/Makefile b/board/altera/nios2-generic/Makefile deleted file mode 100644 index 5e4192c..0000000 --- a/board/altera/nios2-generic/Makefile +++ /dev/null @@ -1,10 +0,0 @@ -# -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# (C) Copyright 2010, Thomas Chou thomas@wytron.com.tw -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := nios2-generic.o -obj-$(CONFIG_CMD_IDE) += ../common/cfide.o diff --git a/board/altera/nios2-generic/config.mk b/board/altera/nios2-generic/config.mk deleted file mode 100644 index a673525..0000000 --- a/board/altera/nios2-generic/config.mk +++ /dev/null @@ -1,12 +0,0 @@ -# -# (C) Copyright 2005, Psyent Corporation <www.psyent.com> -# Scott McNutt smcnutt@psyent.com -# -# SPDX-License-Identifier: GPL-2.0+ -# - -PLATFORM_CPPFLAGS += -mno-hw-div -mno-hw-mul - -ifeq ($(debug),1) -PLATFORM_CPPFLAGS += -DDEBUG -endif diff --git a/board/altera/nios2-generic/custom_fpga.h b/board/altera/nios2-generic/custom_fpga.h deleted file mode 100644 index cf75d35..0000000 --- a/board/altera/nios2-generic/custom_fpga.h +++ /dev/null @@ -1,89 +0,0 @@ -/* - * This header is generated by sopc2dts - * Sopc2dts is written by Walter Goossens waltergoossens@home.nl - * in cooperation with the nios2 community Nios2-dev@sopc.et.ntust.edu.tw - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef _CUSTOM_FPGA_H_ -#define _CUSTOM_FPGA_H_ - -/* generated from qsys_ghrd_3c120.sopcinfo */ - -/* Dumping slaves of cpu.data_master */ - -/* cpu.jtag_debug_module is a altera_nios2_qsys */ -#define CONFIG_SYS_CLK_FREQ 125000000 -#define CONFIG_SYS_DCACHE_SIZE 32768 -#define CONFIG_SYS_DCACHELINE_SIZE 32 -#define CONFIG_SYS_ICACHELINE_SIZE 32 -#define CONFIG_SYS_EXCEPTION_ADDR 0xd0000020 -#define CONFIG_SYS_ICACHE_SIZE 32768 -#define CONFIG_SYS_RESET_ADDR 0xc2800000 -#define IO_REGION_BASE 0xE0000000 - -/* pb_cpu_to_ddr2_bot.s0 is a altera_avalon_mm_bridge */ -/* Dumping slaves of pb_cpu_to_ddr2_bot.m0 */ - -/* ddr2_bot.s1 is a altmemddr2 */ -#define CONFIG_SYS_SDRAM_BASE 0xD0000000 -#define CONFIG_SYS_SDRAM_SIZE 0x08000000 - -/* pb_cpu_to_io.s0 is a altera_avalon_mm_bridge */ -/* Dumping slaves of pb_cpu_to_io.m0 */ - -/* timer_1ms.s1 is a altera_avalon_timer */ -#define CONFIG_SYS_TIMER_IRQ 11 -#define CONFIG_SYS_TIMER_FREQ 125000000 -#define CONFIG_SYS_TIMER_BASE 0xE8400000 - -/* sysid.control_slave is a altera_avalon_sysid_qsys */ -#define CONFIG_SYS_SYSID_BASE 0xE8004D40 - -/* jtag_uart.avalon_jtag_slave is a altera_avalon_jtag_uart */ -#define CONFIG_SYS_JTAG_UART_BASE 0xE8004D50 - -/* tse_mac.control_port is a triple_speed_ethernet */ -#define CONFIG_SYS_ALTERA_TSE_RX_FIFO 2048 -#define CONFIG_SYS_ALTERA_TSE_SGDMA_TX_BASE 0xE8004800 -#define CONFIG_SYS_ALTERA_TSE_SGDMA_RX_BASE 0xE8004400 -#define CONFIG_SYS_ALTERA_TSE_TX_FIFO 2048 -#define CONFIG_SYS_ALTERA_TSE_DESC_SIZE 0x00002000 -#define CONFIG_SYS_ALTERA_TSE_MAC_BASE 0xE8004000 -#define CONFIG_SYS_ALTERA_TSE_DESC_BASE 0xE8002000 -#define CONFIG_ALTERA_TSE -#define CONFIG_MII -#define CONFIG_CMD_MII -#define CONFIG_SYS_ALTERA_TSE_PHY_ADDR 18 -#define CONFIG_SYS_ALTERA_TSE_FLAGS 1 - -/* uart.s1 is a altera_avalon_uart */ -#define CONFIG_SYS_UART_BAUD 115200 -#define CONFIG_SYS_UART_BASE 0xE8004C80 -#define CONFIG_SYS_UART_FREQ 62500000 - -/* user_led_pio_8out.s1 is a altera_avalon_pio */ -#define USER_LED_PIO_8OUT_BASE 0xE8004CC0 - -/* user_dipsw_pio_8in.s1 is a altera_avalon_pio */ -#define USER_DIPSW_PIO_8IN_BASE 0xE8004CE0 -#define USER_DIPSW_PIO_8IN_IRQ 8 - -/* user_pb_pio_4in.s1 is a altera_avalon_pio */ -#define USER_PB_PIO_4IN_BASE 0xE8004D00 -#define USER_PB_PIO_4IN_IRQ 9 - -/* cfi_flash_64m.uas is a altera_generic_tristate_controller */ -#define CFI_FLASH_64M_BASE 0xE0000000 - -/* ext_flash.s1 is a altera_avalon_cfi_flash */ -#define CONFIG_SYS_FLASH_BASE CFI_FLASH_64M_BASE -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_CFI_FLASH_STATUS_POLL /* fix amd flash issue */ -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE -#define CONFIG_SYS_FLASH_PROTECTION -#define CONFIG_SYS_MAX_FLASH_BANKS 1 -#define CONFIG_SYS_MAX_FLASH_SECT 512 - -#endif /* _CUSTOM_FPGA_H_ */ diff --git a/board/altera/nios2-generic/nios2-generic.c b/board/altera/nios2-generic/nios2-generic.c deleted file mode 100644 index e7fecd2..0000000 --- a/board/altera/nios2-generic/nios2-generic.c +++ /dev/null @@ -1,76 +0,0 @@ -/* - * (C) Copyright 2005, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * (C) Copyright 2010, Thomas Chou thomas@wytron.com.tw - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <netdev.h> -#if defined(CONFIG_CFI_FLASH_MTD) -#include <mtd/cfi_flash.h> -#endif -#include <asm/io.h> -#include <asm/gpio.h> - -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) && \ - defined(CONFIG_CFI_FLASH_MTD) -static void __early_flash_cmd_reset(void) -{ - /* reset flash before we read env */ - writeb(AMD_CMD_RESET, CONFIG_ENV_ADDR); - writeb(FLASH_CMD_RESET, CONFIG_ENV_ADDR); -} -void early_flash_cmd_reset(void) - __attribute__((weak,alias("__early_flash_cmd_reset"))); -#endif - -int board_early_init_f(void) -{ -#if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) && \ - defined(CONFIG_CFI_FLASH_MTD) - early_flash_cmd_reset(); -#endif - return 0; -} - -int checkboard(void) -{ -#ifdef CONFIG_ALTERA_SYSID - display_sysid(); -#endif - printf("BOARD: %s\n", CONFIG_BOARD_NAME); - return 0; -} - -#ifdef CONFIG_CMD_NET -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_SMC91111 - rc += smc91111_initialize(0, CONFIG_SMC91111_BASE); -#endif -#ifdef CONFIG_DRIVER_DM9000 - rc += dm9000_initialize(bis); -#endif -#ifdef CONFIG_ALTERA_TSE - rc += altera_tse_initialize(0, - CONFIG_SYS_ALTERA_TSE_MAC_BASE, - CONFIG_SYS_ALTERA_TSE_SGDMA_RX_BASE, - CONFIG_SYS_ALTERA_TSE_SGDMA_TX_BASE, -#if defined(CONFIG_SYS_ALTERA_TSE_SGDMA_DESC_BASE) && \ - (CONFIG_SYS_ALTERA_TSE_SGDMA_DESC_SIZE > 0) - CONFIG_SYS_ALTERA_TSE_SGDMA_DESC_BASE, - CONFIG_SYS_ALTERA_TSE_SGDMA_DESC_SIZE); -#else - 0, - 0); -#endif -#endif -#ifdef CONFIG_ETHOC - rc += ethoc_initialize(0, CONFIG_SYS_ETHOC_BASE); -#endif - return rc; -} -#endif diff --git a/configs/nios2-generic_defconfig b/configs/nios2-generic_defconfig index 3d404b2..ea07b56 100644 --- a/configs/nios2-generic_defconfig +++ b/configs/nios2-generic_defconfig @@ -1,7 +1,7 @@ CONFIG_NIOS2=y +CONFIG_SYS_CONFIG_NAME="nios2-generic" CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y -CONFIG_TARGET_NIOS2_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="3c120_devboard" CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index e4b5abb..11be6e1 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -12,12 +12,8 @@ /* * BOARD/CPU */ -#include "../board/altera/nios2-generic/custom_fpga.h" /* fpga parameters */ -#define CONFIG_BOARD_NAME "nios2-generic" /* custom board name */ -#define CONFIG_BOARD_EARLY_INIT_F /* enable early board-spec. init */ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO_LATE -#define CONFIG_SYS_NIOS_SYSID_BASE CONFIG_SYS_SYSID_BASE
Applied to u-boot-nios.
v2
Champagne-opened-by: Marek Vasut marex@denx.de
Thomas Chou
