[U-Boot] [PATCH v3 0/5] Update SiFive Unleashed Drivers
This series update SiFive Unleashed clock driver so that: 1. It is in sync with upstream Linux driver 2. It uses latest DT bindings as-per upstream Linux driver
With this series, we can now use latest DT bindings with U-Boot. I have tested SiFive Serial driver and Cadence MACB ethernet driver with this changes and both work fine.
The legacy FSBL will still pass DTB to U-Boot with older DT bindings which will break the updated SiFive Unleashed clock driver. To tackle this, we have embedded DTB in OpenSBI FW_PAYLOAD firmware for SiFive Unleashed so that OpenSBI will override and pass updated DTB to U-Boot.
In fact, the updated DTB passed by OpenSBI can be used by latest Linux (i.e. V5.2-rc1 or higher) as well.
The OpenSBI changes to embed SiFive Unleashed DTB can be found in sifive_unleashed_dtb_fix_v3 branch of: https://github.com/avpatel/opensbi.git
This series can be found in riscv_unleashed_clk_sync_v3 branch of: https://github.com/avpatel/u-boot.git
Changes since v2: - Dropped PATCH6 which adds new compatible string to MACB driver because more changes are required in MACB driver for different ethernet speeds
Changes since v1: - Dropped GEMGXL clock driver - Added new compatible string for SiFive MACB ethernet
Anup Patel (5): clk: sifive: Factor-out PLL library as separate module clk: sifive: Sync-up WRPLL library with upstream Linux clk: sifive: Sync-up DT bindings header with upstream Linux clk: sifive: Sync-up main driver with upstream Linux clk: sifive: Drop GEMGXL clock driver
board/sifive/fu540/Kconfig | 1 - drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/analogbits/Kconfig | 4 + drivers/clk/analogbits/Makefile | 3 + .../{sifive => analogbits}/wrpll-cln28hpc.c | 168 ++++++++---------- drivers/clk/sifive/Kconfig | 10 -- drivers/clk/sifive/Makefile | 4 - drivers/clk/sifive/fu540-prci.c | 123 +++++++------ drivers/clk/sifive/gemgxl-mgmt.c | 60 ------- include/dt-bindings/clk/sifive-fu540-prci.h | 29 --- include/dt-bindings/clock/sifive-fu540-prci.h | 18 ++ .../linux/clk}/analogbits-wrpll-cln28hpc.h | 70 +++----- 13 files changed, 195 insertions(+), 297 deletions(-) create mode 100644 drivers/clk/analogbits/Kconfig create mode 100644 drivers/clk/analogbits/Makefile rename drivers/clk/{sifive => analogbits}/wrpll-cln28hpc.c (69%) delete mode 100644 drivers/clk/sifive/gemgxl-mgmt.c delete mode 100644 include/dt-bindings/clk/sifive-fu540-prci.h create mode 100644 include/dt-bindings/clock/sifive-fu540-prci.h rename {drivers/clk/sifive => include/linux/clk}/analogbits-wrpll-cln28hpc.h (52%)
-- 2.17.1
To match SiFive clock driver with latest Linux, we factor-out PLL library as separate module under drivers/clk/analogbits.
Signed-off-by: Anup Patel anup.patel@wdc.com --- drivers/clk/Kconfig | 1 + drivers/clk/Makefile | 1 + drivers/clk/analogbits/Kconfig | 4 ++++ drivers/clk/analogbits/Makefile | 3 +++ drivers/clk/{sifive => analogbits}/wrpll-cln28hpc.c | 3 +-- drivers/clk/sifive/Kconfig | 3 --- drivers/clk/sifive/Makefile | 2 -- drivers/clk/sifive/fu540-prci.c | 3 +-- .../sifive => include/linux/clk}/analogbits-wrpll-cln28hpc.h | 0 9 files changed, 11 insertions(+), 9 deletions(-) create mode 100644 drivers/clk/analogbits/Kconfig create mode 100644 drivers/clk/analogbits/Makefile rename drivers/clk/{sifive => analogbits}/wrpll-cln28hpc.c (99%) rename {drivers/clk/sifive => include/linux/clk}/analogbits-wrpll-cln28hpc.h (100%)
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 96969b9e30..7b81eacf50 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -98,6 +98,7 @@ config CLK_STM32MP1 Enable the STM32 clock (RCC) driver. Enable support for manipulating STM32MP1's on-SoC clocks.
+source "drivers/clk/analogbits/Kconfig" source "drivers/clk/at91/Kconfig" source "drivers/clk/exynos/Kconfig" source "drivers/clk/imx/Kconfig" diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 719b9b8e02..f0ced49e5a 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -8,6 +8,7 @@ obj-$(CONFIG_$(SPL_TPL_)CLK) += clk-uclass.o obj-$(CONFIG_$(SPL_TPL_)CLK) += clk_fixed_rate.o obj-$(CONFIG_$(SPL_TPL_)CLK) += clk_fixed_factor.o
+obj-y += analogbits/ obj-y += imx/ obj-y += tegra/ obj-$(CONFIG_ARCH_ASPEED) += aspeed/ diff --git a/drivers/clk/analogbits/Kconfig b/drivers/clk/analogbits/Kconfig new file mode 100644 index 0000000000..1d25e6f124 --- /dev/null +++ b/drivers/clk/analogbits/Kconfig @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0 + +config CLK_ANALOGBITS_WRPLL_CLN28HPC + bool diff --git a/drivers/clk/analogbits/Makefile b/drivers/clk/analogbits/Makefile new file mode 100644 index 0000000000..ec1bb4092b --- /dev/null +++ b/drivers/clk/analogbits/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-$(CONFIG_CLK_ANALOGBITS_WRPLL_CLN28HPC) += wrpll-cln28hpc.o diff --git a/drivers/clk/sifive/wrpll-cln28hpc.c b/drivers/clk/analogbits/wrpll-cln28hpc.c similarity index 99% rename from drivers/clk/sifive/wrpll-cln28hpc.c rename to drivers/clk/analogbits/wrpll-cln28hpc.c index d377849693..68eb1148b9 100644 --- a/drivers/clk/sifive/wrpll-cln28hpc.c +++ b/drivers/clk/analogbits/wrpll-cln28hpc.c @@ -35,8 +35,7 @@ #include <linux/err.h> #include <linux/log2.h> #include <linux/math64.h> - -#include "analogbits-wrpll-cln28hpc.h" +#include <linux/clk/analogbits-wrpll-cln28hpc.h>
/* MIN_INPUT_FREQ: minimum input clock frequency, in Hz (Fref_min) */ #define MIN_INPUT_FREQ 7000000 diff --git a/drivers/clk/sifive/Kconfig b/drivers/clk/sifive/Kconfig index 644881b948..d90be1943f 100644 --- a/drivers/clk/sifive/Kconfig +++ b/drivers/clk/sifive/Kconfig @@ -1,8 +1,5 @@ # SPDX-License-Identifier: GPL-2.0
-config CLK_ANALOGBITS_WRPLL_CLN28HPC - bool - config CLK_SIFIVE bool "SiFive SoC driver support" depends on CLK diff --git a/drivers/clk/sifive/Makefile b/drivers/clk/sifive/Makefile index f8263e79b7..0813360ca7 100644 --- a/drivers/clk/sifive/Makefile +++ b/drivers/clk/sifive/Makefile @@ -1,7 +1,5 @@ # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_CLK_ANALOGBITS_WRPLL_CLN28HPC) += wrpll-cln28hpc.o - obj-$(CONFIG_CLK_SIFIVE_FU540_PRCI) += fu540-prci.o
obj-$(CONFIG_CLK_SIFIVE_GEMGXL_MGMT) += gemgxl-mgmt.o diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index 2d47ebc6b1..56084db2e6 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -37,10 +37,9 @@ #include <errno.h>
#include <linux/math64.h> +#include <linux/clk/analogbits-wrpll-cln28hpc.h> #include <dt-bindings/clk/sifive-fu540-prci.h>
-#include "analogbits-wrpll-cln28hpc.h" - /* * EXPECTED_CLK_PARENT_COUNT: how many parent clocks this driver expects: * hfclk and rtcclk diff --git a/drivers/clk/sifive/analogbits-wrpll-cln28hpc.h b/include/linux/clk/analogbits-wrpll-cln28hpc.h similarity index 100% rename from drivers/clk/sifive/analogbits-wrpll-cln28hpc.h rename to include/linux/clk/analogbits-wrpll-cln28hpc.h
Now that SiFive clock driver is merged in upstream Linux, we sync-up WRPLL library used by SiFive clock driver with upstream Linux sources.
Signed-off-by: Anup Patel anup.patel@wdc.com --- drivers/clk/analogbits/wrpll-cln28hpc.c | 165 ++++++++---------- drivers/clk/sifive/fu540-prci.c | 26 +-- include/linux/clk/analogbits-wrpll-cln28hpc.h | 70 +++----- 3 files changed, 107 insertions(+), 154 deletions(-)
diff --git a/drivers/clk/analogbits/wrpll-cln28hpc.c b/drivers/clk/analogbits/wrpll-cln28hpc.c index 68eb1148b9..776ead319a 100644 --- a/drivers/clk/analogbits/wrpll-cln28hpc.c +++ b/drivers/clk/analogbits/wrpll-cln28hpc.c @@ -1,20 +1,9 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (c) 2019 Western Digital Corporation or its affiliates. - * - * Copyright (C) 2018 SiFive, Inc. + * Copyright (C) 2018-2019 SiFive, Inc. * Wesley Terpstra * Paul Walmsley * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * * This library supports configuration parsing and reprogramming of * the CLN28HPC variant of the Analog Bits Wide Range PLL. The * intention is for this library to be reusable for any device that @@ -29,6 +18,7 @@ * References: * - Analog Bits "Wide Range PLL Datasheet", version 2015.10.01 * - SiFive FU540-C000 Manual v1p0, Chapter 7 "Clocking and Reset" + * https://static.dev.sifive.com/FU540-C000-v1.0.pdf */
#include <linux/bug.h> @@ -84,40 +74,38 @@ * range selection. * * Return: The RANGE value to be presented to the PLL configuration inputs, - * or -1 upon error. + * or a negative return code upon error. */ static int __wrpll_calc_filter_range(unsigned long post_divr_freq) { - u8 range; - if (post_divr_freq < MIN_POST_DIVR_FREQ || post_divr_freq > MAX_POST_DIVR_FREQ) { WARN(1, "%s: post-divider reference freq out of range: %lu", __func__, post_divr_freq); - return -1; + return -ERANGE; }
- if (post_divr_freq < 11000000) - range = 1; - else if (post_divr_freq < 18000000) - range = 2; - else if (post_divr_freq < 30000000) - range = 3; - else if (post_divr_freq < 50000000) - range = 4; - else if (post_divr_freq < 80000000) - range = 5; - else if (post_divr_freq < 130000000) - range = 6; - else - range = 7; - - return range; + switch (post_divr_freq) { + case 0 ... 10999999: + return 1; + case 11000000 ... 17999999: + return 2; + case 18000000 ... 29999999: + return 3; + case 30000000 ... 49999999: + return 4; + case 50000000 ... 79999999: + return 5; + case 80000000 ... 129999999: + return 6; + } + + return 7; }
/** * __wrpll_calc_fbdiv() - return feedback fixed divide value - * @c: ptr to a struct analogbits_wrpll_cfg record to read from + * @c: ptr to a struct wrpll_cfg record to read from * * The internal feedback path includes a fixed by-two divider; the * external feedback path does not. Return the appropriate divider @@ -132,7 +120,7 @@ static int __wrpll_calc_filter_range(unsigned long post_divr_freq) * Return: 2 if internal feedback is enabled or 1 if external feedback * is enabled. */ -static u8 __wrpll_calc_fbdiv(struct analogbits_wrpll_cfg *c) +static u8 __wrpll_calc_fbdiv(const struct wrpll_cfg *c) { return (c->flags & WRPLL_FLAGS_INT_FEEDBACK_MASK) ? 2 : 1; } @@ -172,7 +160,7 @@ static u8 __wrpll_calc_divq(u32 target_rate, u64 *vco_rate) *vco_rate = MIN_VCO_FREQ; } else { divq = ilog2(s); - *vco_rate = target_rate << divq; + *vco_rate = (u64)target_rate << divq; }
wcd_out: @@ -181,7 +169,7 @@ wcd_out:
/** * __wrpll_update_parent_rate() - update PLL data when parent rate changes - * @c: ptr to a struct analogbits_wrpll_cfg record to write PLL data to + * @c: ptr to a struct wrpll_cfg record to write PLL data to * @parent_rate: PLL input refclk rate (pre-R-divider) * * Pre-compute some data used by the PLL configuration algorithm when @@ -189,46 +177,40 @@ wcd_out: * computation when the parent rate remains constant - expected to be * the common case. * - * Returns: 0 upon success or -1 if the reference clock rate is out of range. + * Returns: 0 upon success or -ERANGE if the reference clock rate is + * out of range. */ -static int __wrpll_update_parent_rate(struct analogbits_wrpll_cfg *c, +static int __wrpll_update_parent_rate(struct wrpll_cfg *c, unsigned long parent_rate) { u8 max_r_for_parent;
if (parent_rate > MAX_INPUT_FREQ || parent_rate < MIN_POST_DIVR_FREQ) - return -1; + return -ERANGE;
- c->_parent_rate = parent_rate; + c->parent_rate = parent_rate; max_r_for_parent = div_u64(parent_rate, MIN_POST_DIVR_FREQ); - c->_max_r = min_t(u8, MAX_DIVR_DIVISOR, max_r_for_parent); + c->max_r = min_t(u8, MAX_DIVR_DIVISOR, max_r_for_parent);
- /* Round up */ - c->_init_r = div_u64(parent_rate + MAX_POST_DIVR_FREQ - 1, - MAX_POST_DIVR_FREQ); + c->init_r = DIV_ROUND_UP_ULL(parent_rate, MAX_POST_DIVR_FREQ);
return 0; }
-/* - * Public functions - */ - /** - * analogbits_wrpll_configure() - compute PLL configuration for a target rate - * @c: ptr to a struct analogbits_wrpll_cfg record to write into + * wrpll_configure() - compute PLL configuration for a target rate + * @c: ptr to a struct wrpll_cfg record to write into * @target_rate: target PLL output clock rate (post-Q-divider) * @parent_rate: PLL input refclk rate (pre-R-divider) * - * Given a pointer to a PLL context @c, a desired PLL target output - * rate @target_rate, and a reference clock input rate @parent_rate, - * compute the appropriate PLL signal configuration values. PLL - * reprogramming is not glitchless, so the caller should switch any - * downstream logic to a different clock source or clock-gate it - * before presenting these values to the PLL configuration signals. + * Compute the appropriate PLL signal configuration values and store + * in PLL context @c. PLL reprogramming is not glitchless, so the + * caller should switch any downstream logic to a different clock + * source or clock-gate it before presenting these values to the PLL + * configuration signals. * * The caller must pass this function a pre-initialized struct - * analogbits_wrpll_cfg record: either initialized to zero (with the + * wrpll_cfg record: either initialized to zero (with the * exception of the .name and .flags fields) or read from the PLL. * * Context: Any context. Caller must protect the memory pointed to by @c @@ -236,41 +218,26 @@ static int __wrpll_update_parent_rate(struct analogbits_wrpll_cfg *c, * * Return: 0 upon success; anything else upon failure. */ -int analogbits_wrpll_configure_for_rate(struct analogbits_wrpll_cfg *c, - u32 target_rate, - unsigned long parent_rate) +int wrpll_configure_for_rate(struct wrpll_cfg *c, u32 target_rate, + unsigned long parent_rate) { unsigned long ratio; u64 target_vco_rate, delta, best_delta, f_pre_div, vco, vco_pre; - u32 best_f, f, post_divr_freq, fbcfg; + u32 best_f, f, post_divr_freq; u8 fbdiv, divq, best_r, r; - - if (!c) - return -1; + int range;
if (c->flags == 0) { WARN(1, "%s called with uninitialized PLL config", __func__); - return -1; - } - - fbcfg = WRPLL_FLAGS_INT_FEEDBACK_MASK | WRPLL_FLAGS_EXT_FEEDBACK_MASK; - if ((c->flags & fbcfg) == fbcfg) { - WARN(1, "%s called with invalid PLL config", __func__); - return -1; - } - - if (c->flags == WRPLL_FLAGS_EXT_FEEDBACK_MASK) { - WARN(1, "%s: external feedback mode not currently supported", - __func__); - return -1; + return -EINVAL; }
/* Initialize rounding data if it hasn't been initialized already */ - if (parent_rate != c->_parent_rate) { + if (parent_rate != c->parent_rate) { if (__wrpll_update_parent_rate(c, parent_rate)) { pr_err("%s: PLL input rate is out of range\n", __func__); - return -1; + return -ERANGE; } }
@@ -281,11 +248,12 @@ int analogbits_wrpll_configure_for_rate(struct analogbits_wrpll_cfg *c, c->flags |= WRPLL_FLAGS_BYPASS_MASK; return 0; } + c->flags &= ~WRPLL_FLAGS_BYPASS_MASK;
/* Calculate the Q shift and target VCO rate */ divq = __wrpll_calc_divq(target_rate, &target_vco_rate); - if (divq == 0) + if (!divq) return -1; c->divq = divq;
@@ -301,8 +269,7 @@ int analogbits_wrpll_configure_for_rate(struct analogbits_wrpll_cfg *c, * Consider all values for R which land within * [MIN_POST_DIVR_FREQ, MAX_POST_DIVR_FREQ]; prefer smaller R */ - for (r = c->_init_r; r <= c->_max_r; ++r) { - /* What is the best F we can pick in this case? */ + for (r = c->init_r; r <= c->max_r; ++r) { f_pre_div = ratio * r; f = (f_pre_div + (1 << ROUND_SHIFT)) >> ROUND_SHIFT; f >>= (fbdiv - 1); @@ -334,46 +301,54 @@ int analogbits_wrpll_configure_for_rate(struct analogbits_wrpll_cfg *c, post_divr_freq = div_u64(parent_rate, best_r);
/* Pick the best PLL jitter filter */ - c->range = __wrpll_calc_filter_range(post_divr_freq); + range = __wrpll_calc_filter_range(post_divr_freq); + if (range < 0) + return range; + c->range = range;
return 0; }
/** - * analogbits_wrpll_calc_output_rate() - calculate the PLL's target output rate - * @c: ptr to a struct analogbits_wrpll_cfg record to read from + * wrpll_calc_output_rate() - calculate the PLL's target output rate + * @c: ptr to a struct wrpll_cfg record to read from * @parent_rate: PLL refclk rate * * Given a pointer to the PLL's current input configuration @c and the * PLL's input reference clock rate @parent_rate (before the R * pre-divider), calculate the PLL's output clock rate (after the Q - * post-divider) + * post-divider). * * Context: Any context. Caller must protect the memory pointed to by @c * from simultaneous modification. * - * Return: the PLL's output clock rate, in Hz. + * Return: the PLL's output clock rate, in Hz. The return value from + * this function is intended to be convenient to pass directly + * to the Linux clock framework; thus there is no explicit + * error return value. */ -unsigned long analogbits_wrpll_calc_output_rate(struct analogbits_wrpll_cfg *c, - unsigned long parent_rate) +unsigned long wrpll_calc_output_rate(const struct wrpll_cfg *c, + unsigned long parent_rate) { u8 fbdiv; u64 n;
- WARN(c->flags & WRPLL_FLAGS_EXT_FEEDBACK_MASK, - "external feedback mode not yet supported"); + if (c->flags & WRPLL_FLAGS_EXT_FEEDBACK_MASK) { + WARN(1, "external feedback mode not yet supported"); + return ULONG_MAX; + }
fbdiv = __wrpll_calc_fbdiv(c); n = parent_rate * fbdiv * (c->divf + 1); - n = div_u64(n, (c->divr + 1)); + n = div_u64(n, c->divr + 1); n >>= c->divq;
return n; }
/** - * analogbits_wrpll_calc_max_lock_us() - return the time for the PLL to lock - * @c: ptr to a struct analogbits_wrpll_cfg record to read from + * wrpll_calc_max_lock_us() - return the time for the PLL to lock + * @c: ptr to a struct wrpll_cfg record to read from * * Return the minimum amount of time (in microseconds) that the caller * must wait after reprogramming the PLL to ensure that it is locked @@ -383,7 +358,7 @@ unsigned long analogbits_wrpll_calc_output_rate(struct analogbits_wrpll_cfg *c, * Return: the minimum amount of time the caller must wait for the PLL * to lock (in microseconds) */ -unsigned int analogbits_wrpll_calc_max_lock_us(struct analogbits_wrpll_cfg *c) +unsigned int wrpll_calc_max_lock_us(const struct wrpll_cfg *c) { return MAX_LOCK_US; } diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index 56084db2e6..cdbf35e871 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -174,7 +174,7 @@ struct __prci_data { * bypass mux is not glitchless. */ struct __prci_wrpll_data { - struct analogbits_wrpll_cfg c; + struct wrpll_cfg c; void (*bypass)(struct __prci_data *pd); void (*no_bypass)(struct __prci_data *pd); u8 cfg0_offs; @@ -244,7 +244,7 @@ static void __prci_writel(u32 v, u32 offs, struct __prci_data *pd)
/** * __prci_wrpll_unpack() - unpack WRPLL configuration registers into parameters - * @c: ptr to a struct analogbits_wrpll_cfg record to write config into + * @c: ptr to a struct wrpll_cfg record to write config into * @r: value read from the PRCI PLL configuration register * * Given a value @r read from an FU540 PRCI PLL configuration register, @@ -256,7 +256,7 @@ static void __prci_writel(u32 v, u32 offs, struct __prci_data *pd) * * Context: Any context. */ -static void __prci_wrpll_unpack(struct analogbits_wrpll_cfg *c, u32 r) +static void __prci_wrpll_unpack(struct wrpll_cfg *c, u32 r) { u32 v;
@@ -287,7 +287,7 @@ static void __prci_wrpll_unpack(struct analogbits_wrpll_cfg *c, u32 r)
/** * __prci_wrpll_pack() - pack PLL configuration parameters into a register value - * @c: pointer to a struct analogbits_wrpll_cfg record containing the PLL's cfg + * @c: pointer to a struct wrpll_cfg record containing the PLL's cfg * * Using a set of WRPLL configuration values pointed to by @c, * assemble a PRCI PLL configuration register value, and return it to @@ -300,7 +300,7 @@ static void __prci_wrpll_unpack(struct analogbits_wrpll_cfg *c, u32 r) * Returns: a value suitable for writing into a PRCI PLL configuration * register */ -static u32 __prci_wrpll_pack(struct analogbits_wrpll_cfg *c) +static u32 __prci_wrpll_pack(struct wrpll_cfg *c) { u32 r = 0;
@@ -348,11 +348,11 @@ static void __prci_wrpll_read_cfg(struct __prci_data *pd, */ static void __prci_wrpll_write_cfg(struct __prci_data *pd, struct __prci_wrpll_data *pwd, - struct analogbits_wrpll_cfg *c) + struct wrpll_cfg *c) { __prci_writel(__prci_wrpll_pack(c), pwd->cfg0_offs, pd);
- memcpy(&pwd->c, c, sizeof(struct analogbits_wrpll_cfg)); + memcpy(&pwd->c, c, sizeof(struct wrpll_cfg)); }
/* Core clock mux control */ @@ -403,7 +403,7 @@ static unsigned long sifive_fu540_prci_wrpll_recalc_rate( { struct __prci_wrpll_data *pwd = pc->pwd;
- return analogbits_wrpll_calc_output_rate(&pwd->c, parent_rate); + return wrpll_calc_output_rate(&pwd->c, parent_rate); }
static unsigned long sifive_fu540_prci_wrpll_round_rate( @@ -412,13 +412,13 @@ static unsigned long sifive_fu540_prci_wrpll_round_rate( unsigned long *parent_rate) { struct __prci_wrpll_data *pwd = pc->pwd; - struct analogbits_wrpll_cfg c; + struct wrpll_cfg c;
memcpy(&c, &pwd->c, sizeof(c));
- analogbits_wrpll_configure_for_rate(&c, rate, *parent_rate); + wrpll_configure_for_rate(&c, rate, *parent_rate);
- return analogbits_wrpll_calc_output_rate(&c, *parent_rate); + return wrpll_calc_output_rate(&c, *parent_rate); }
static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc, @@ -429,7 +429,7 @@ static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc, struct __prci_data *pd = pc->pd; int r;
- r = analogbits_wrpll_configure_for_rate(&pwd->c, rate, parent_rate); + r = wrpll_configure_for_rate(&pwd->c, rate, parent_rate); if (r) return -ERANGE;
@@ -438,7 +438,7 @@ static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc,
__prci_wrpll_write_cfg(pd, pwd, &pwd->c);
- udelay(analogbits_wrpll_calc_max_lock_us(&pwd->c)); + udelay(wrpll_calc_max_lock_us(&pwd->c));
if (pwd->no_bypass) pwd->no_bypass(pd); diff --git a/include/linux/clk/analogbits-wrpll-cln28hpc.h b/include/linux/clk/analogbits-wrpll-cln28hpc.h index 4432e24749..03279097e1 100644 --- a/include/linux/clk/analogbits-wrpll-cln28hpc.h +++ b/include/linux/clk/analogbits-wrpll-cln28hpc.h @@ -1,19 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * Copyright (c) 2019 Western Digital Corporation or its affiliates. - * - * Copyright (C) 2018 SiFive, Inc. + * Copyright (C) 2018-2019 SiFive, Inc. * Wesley Terpstra * Paul Walmsley - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. */
#ifndef __LINUX_CLK_ANALOGBITS_WRPLL_CLN28HPC_H @@ -25,7 +14,7 @@ #define DIVQ_VALUES 6
/* - * Bit definitions for struct analogbits_wrpll_cfg.flags + * Bit definitions for struct wrpll_cfg.flags * * WRPLL_FLAGS_BYPASS_FLAG: if set, the PLL is either in bypass, or should be * programmed to enter bypass @@ -34,10 +23,6 @@ * feedback mode * WRPLL_FLAGS_EXT_FEEDBACK_FLAG: if set, the PLL is configured for external * feedback mode (not yet supported by this driver) - * - * The flags WRPLL_FLAGS_INT_FEEDBACK_FLAG and WRPLL_FLAGS_EXT_FEEDBACK_FLAG are - * mutually exclusive. If both bits are set, or both are zero, the struct - * analogbits_wrpll_cfg record is uninitialized or corrupt. */ #define WRPLL_FLAGS_BYPASS_SHIFT 0 #define WRPLL_FLAGS_BYPASS_MASK BIT(WRPLL_FLAGS_BYPASS_SHIFT) @@ -49,53 +34,46 @@ #define WRPLL_FLAGS_EXT_FEEDBACK_MASK BIT(WRPLL_FLAGS_EXT_FEEDBACK_SHIFT)
/** - * struct analogbits_wrpll_cfg - WRPLL configuration values - * @divr: reference divider value (6 bits), as presented to the PLL signals. - * @divf: feedback divider value (9 bits), as presented to the PLL signals. - * @divq: output divider value (3 bits), as presented to the PLL signals. - * @flags: PLL configuration flags. See above for more information. - * @range: PLL loop filter range. See below for more information. - * @_output_rate_cache: cached output rates, swept across DIVQ. - * @_parent_rate: PLL refclk rate for which values are valid - * @_max_r: maximum possible R divider value, given @parent_rate - * @_init_r: initial R divider value to start the search from + * struct wrpll_cfg - WRPLL configuration values + * @divr: reference divider value (6 bits), as presented to the PLL signals + * @divf: feedback divider value (9 bits), as presented to the PLL signals + * @divq: output divider value (3 bits), as presented to the PLL signals + * @flags: PLL configuration flags. See above for more information + * @range: PLL loop filter range. See below for more information + * @output_rate_cache: cached output rates, swept across DIVQ + * @parent_rate: PLL refclk rate for which values are valid + * @max_r: maximum possible R divider value, given @parent_rate + * @init_r: initial R divider value to start the search from * * @divr, @divq, @divq, @range represent what the PLL expects to see * on its input signals. Thus @divr and @divf are the actual divisors * minus one. @divq is a power-of-two divider; for example, 1 = * divide-by-2 and 6 = divide-by-64. 0 is an invalid @divq value. * - * When initially passing a struct analogbits_wrpll_cfg record, the + * When initially passing a struct wrpll_cfg record, the * record should be zero-initialized with the exception of the @flags * field. The only flag bits that need to be set are either * WRPLL_FLAGS_INT_FEEDBACK or WRPLL_FLAGS_EXT_FEEDBACK. - * - * Field names beginning with an underscore should be considered - * private to the wrpll-cln28hpc.c code. */ -struct analogbits_wrpll_cfg { +struct wrpll_cfg { u8 divr; u8 divq; u8 range; u8 flags; u16 divf; - u32 _output_rate_cache[DIVQ_VALUES]; - unsigned long _parent_rate; - u8 _max_r; - u8 _init_r; +/* private: */ + u32 output_rate_cache[DIVQ_VALUES]; + unsigned long parent_rate; + u8 max_r; + u8 init_r; };
-/* - * Function prototypes - */ - -int analogbits_wrpll_configure_for_rate(struct analogbits_wrpll_cfg *c, - u32 target_rate, - unsigned long parent_rate); +int wrpll_configure_for_rate(struct wrpll_cfg *c, u32 target_rate, + unsigned long parent_rate);
-unsigned int analogbits_wrpll_calc_max_lock_us(struct analogbits_wrpll_cfg *c); +unsigned int wrpll_calc_max_lock_us(const struct wrpll_cfg *c);
-unsigned long analogbits_wrpll_calc_output_rate(struct analogbits_wrpll_cfg *c, - unsigned long parent_rate); +unsigned long wrpll_calc_output_rate(const struct wrpll_cfg *c, + unsigned long parent_rate);
#endif /* __LINUX_CLK_ANALOGBITS_WRPLL_CLN28HPC_H */
The location and license header of DT bindings header for SiFive clock driver has changed in upstream Linux hence this patch.
Signed-off-by: Anup Patel anup.patel@wdc.com --- drivers/clk/sifive/fu540-prci.c | 2 +- include/dt-bindings/clk/sifive-fu540-prci.h | 29 ------------------- include/dt-bindings/clock/sifive-fu540-prci.h | 18 ++++++++++++ 3 files changed, 19 insertions(+), 30 deletions(-) delete mode 100644 include/dt-bindings/clk/sifive-fu540-prci.h create mode 100644 include/dt-bindings/clock/sifive-fu540-prci.h
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index cdbf35e871..ceb318e062 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -38,7 +38,7 @@
#include <linux/math64.h> #include <linux/clk/analogbits-wrpll-cln28hpc.h> -#include <dt-bindings/clk/sifive-fu540-prci.h> +#include <dt-bindings/clock/sifive-fu540-prci.h>
/* * EXPECTED_CLK_PARENT_COUNT: how many parent clocks this driver expects: diff --git a/include/dt-bindings/clk/sifive-fu540-prci.h b/include/dt-bindings/clk/sifive-fu540-prci.h deleted file mode 100644 index 531523ea62..0000000000 --- a/include/dt-bindings/clk/sifive-fu540-prci.h +++ /dev/null @@ -1,29 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2019 Western Digital Corporation or its affiliates. - * - * Copyright (C) 2018 SiFive, Inc. - * Wesley Terpstra - * Paul Walmsley - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef __LINUX_CLK_SIFIVE_FU540_PRCI_H -#define __LINUX_CLK_SIFIVE_FU540_PRCI_H - -/* Clock indexes for use by Device Tree data */ - -#define PRCI_CLK_COREPLL 0 -#define PRCI_CLK_DDRPLL 1 -#define PRCI_CLK_GEMGXLPLL 2 -#define PRCI_CLK_TLCLK 3 - -#endif diff --git a/include/dt-bindings/clock/sifive-fu540-prci.h b/include/dt-bindings/clock/sifive-fu540-prci.h new file mode 100644 index 0000000000..6a0b70a37d --- /dev/null +++ b/include/dt-bindings/clock/sifive-fu540-prci.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2019 SiFive, Inc. + * Wesley Terpstra + * Paul Walmsley + */ + +#ifndef __DT_BINDINGS_CLOCK_SIFIVE_FU540_PRCI_H +#define __DT_BINDINGS_CLOCK_SIFIVE_FU540_PRCI_H + +/* Clock indexes for use by Device Tree data and the PRCI driver */ + +#define PRCI_CLK_COREPLL 0 +#define PRCI_CLK_DDRPLL 1 +#define PRCI_CLK_GEMGXLPLL 2 +#define PRCI_CLK_TLCLK 3 + +#endif
The DT bindings of SiFive clock driver in upstream Linux has changes. As-per latest DT bindings, the clock driver takes two parent clocks and compatible string has also changed.
This patch sync-up SiFive clock driver implementation as-per upstream Linux so that we now use latest DT bindings.
Signed-off-by: Anup Patel anup.patel@wdc.com --- drivers/clk/sifive/fu540-prci.c | 96 ++++++++++++++++++++------------- 1 file changed, 60 insertions(+), 36 deletions(-)
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index ceb318e062..ce0769f2d1 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -158,30 +158,32 @@ * PRCI per-device instance data */ struct __prci_data { - void *base; - struct clk parent; + void *va; + struct clk parent_hfclk; + struct clk parent_rtcclk; };
/** * struct __prci_wrpll_data - WRPLL configuration and integration data * @c: WRPLL current configuration record - * @bypass: fn ptr to code to bypass the WRPLL (if applicable; else NULL) - * @no_bypass: fn ptr to code to not bypass the WRPLL (if applicable; else NULL) + * @enable_bypass: fn ptr to code to bypass the WRPLL (if applicable; else NULL) + * @disable_bypass: fn ptr to code to not bypass the WRPLL (or NULL) * @cfg0_offs: WRPLL CFG0 register offset (in bytes) from the PRCI base address * - * @bypass and @no_bypass are used for WRPLL instances that contain a separate - * external glitchless clock mux downstream from the PLL. The WRPLL internal - * bypass mux is not glitchless. + * @enable_bypass and @disable_bypass are used for WRPLL instances + * that contain a separate external glitchless clock mux downstream + * from the PLL. The WRPLL internal bypass mux is not glitchless. */ struct __prci_wrpll_data { struct wrpll_cfg c; - void (*bypass)(struct __prci_data *pd); - void (*no_bypass)(struct __prci_data *pd); + void (*enable_bypass)(struct __prci_data *pd); + void (*disable_bypass)(struct __prci_data *pd); u8 cfg0_offs; };
struct __prci_clock;
+/* struct __prci_clock_ops - clock operations */ struct __prci_clock_ops { int (*set_rate)(struct __prci_clock *pc, unsigned long rate, @@ -197,8 +199,7 @@ struct __prci_clock_ops { * struct __prci_clock - describes a clock device managed by PRCI * @name: user-readable clock name string - should match the manual * @parent_name: parent name for this clock - * @ops: struct clk_ops for the Linux clock framework to use for control - * @hw: Linux-private clock data + * @ops: struct __prci_clock_ops for control * @pwd: WRPLL-specific data, associated with this clock (if not NULL) * @pd: PRCI-specific data associated with this clock (if not NULL) * @@ -232,12 +233,12 @@ struct __prci_clock { */ static u32 __prci_readl(struct __prci_data *pd, u32 offs) { - return readl(pd->base + offs); + return readl(pd->va + offs); }
static void __prci_writel(u32 v, u32 offs, struct __prci_data *pd) { - return writel(v, pd->base + offs); + writel(v, pd->va + offs); }
/* WRPLL-related private functions */ @@ -279,10 +280,8 @@ static void __prci_wrpll_unpack(struct wrpll_cfg *c, u32 r) c->flags &= (WRPLL_FLAGS_INT_FEEDBACK_MASK | WRPLL_FLAGS_EXT_FEEDBACK_MASK);
- if (r & PRCI_COREPLLCFG0_FSE_MASK) - c->flags |= WRPLL_FLAGS_INT_FEEDBACK_MASK; - else - c->flags |= WRPLL_FLAGS_EXT_FEEDBACK_MASK; + /* external feedback mode not supported */ + c->flags |= WRPLL_FLAGS_INT_FEEDBACK_MASK; }
/** @@ -300,7 +299,7 @@ static void __prci_wrpll_unpack(struct wrpll_cfg *c, u32 r) * Returns: a value suitable for writing into a PRCI PLL configuration * register */ -static u32 __prci_wrpll_pack(struct wrpll_cfg *c) +static u32 __prci_wrpll_pack(const struct wrpll_cfg *c) { u32 r = 0;
@@ -308,8 +307,9 @@ static u32 __prci_wrpll_pack(struct wrpll_cfg *c) r |= c->divf << PRCI_COREPLLCFG0_DIVF_SHIFT; r |= c->divq << PRCI_COREPLLCFG0_DIVQ_SHIFT; r |= c->range << PRCI_COREPLLCFG0_RANGE_SHIFT; - if (c->flags & WRPLL_FLAGS_INT_FEEDBACK_MASK) - r |= PRCI_COREPLLCFG0_FSE_MASK; + + /* external feedback mode not supported */ + r |= PRCI_COREPLLCFG0_FSE_MASK;
return r; } @@ -352,7 +352,7 @@ static void __prci_wrpll_write_cfg(struct __prci_data *pd, { __prci_writel(__prci_wrpll_pack(c), pwd->cfg0_offs, pd);
- memcpy(&pwd->c, c, sizeof(struct wrpll_cfg)); + memcpy(&pwd->c, c, sizeof(*c)); }
/* Core clock mux control */ @@ -431,17 +431,17 @@ static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc,
r = wrpll_configure_for_rate(&pwd->c, rate, parent_rate); if (r) - return -ERANGE; + return r;
- if (pwd->bypass) - pwd->bypass(pd); + if (pwd->enable_bypass) + pwd->enable_bypass(pd);
- if (pwd->no_bypass) - pwd->no_bypass(pd); + if (pwd->disable_bypass) + pwd->disable_bypass(pd);
return 0; } @@ -483,8 +483,8 @@ static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = {
static struct __prci_wrpll_data __prci_corepll_data = { .cfg0_offs = PRCI_COREPLLCFG0_OFFSET, - .bypass = __prci_coreclksel_use_hfclk, - .no_bypass = __prci_coreclksel_use_corepll, + .enable_bypass = __prci_coreclksel_use_hfclk, + .disable_bypass = __prci_coreclksel_use_corepll, };
static struct __prci_wrpll_data __prci_ddrpll_data = { @@ -525,6 +525,27 @@ static struct __prci_clock __prci_init_clocks[] = { }, };
+static ulong sifive_fu540_prci_parent_rate(struct __prci_clock *pc) +{ + ulong parent_rate; + struct __prci_clock *p; + + if (strcmp(pc->parent_name, "corepll") == 0) { + p = &__prci_init_clocks[PRCI_CLK_COREPLL]; + if (!p->pd || !p->ops->recalc_rate) + return -ENXIO; + + return p->ops->recalc_rate(p, sifive_fu540_prci_parent_rate(p)); + } + + if (strcmp(pc->parent_name, "rtcclk") == 0) + parent_rate = clk_get_rate(&pc->pd->parent_rtcclk); + else + parent_rate = clk_get_rate(&pc->pd->parent_hfclk); + + return parent_rate; +} + static ulong sifive_fu540_prci_get_rate(struct clk *clk) { struct __prci_clock *pc; @@ -536,7 +557,7 @@ static ulong sifive_fu540_prci_get_rate(struct clk *clk) if (!pc->pd || !pc->ops->recalc_rate) return -ENXIO;
- return pc->ops->recalc_rate(pc, clk_get_rate(&pc->pd->parent)); + return pc->ops->recalc_rate(pc, sifive_fu540_prci_parent_rate(pc)); }
static ulong sifive_fu540_prci_set_rate(struct clk *clk, ulong rate) @@ -551,7 +572,7 @@ static ulong sifive_fu540_prci_set_rate(struct clk *clk, ulong rate) if (!pc->pd || !pc->ops->set_rate) return -ENXIO;
- err = pc->ops->set_rate(pc, rate, clk_get_rate(&pc->pd->parent)); + err = pc->ops->set_rate(pc, rate, sifive_fu540_prci_parent_rate(pc)); if (err) return err;
@@ -564,11 +585,15 @@ static int sifive_fu540_prci_probe(struct udevice *dev) struct __prci_clock *pc; struct __prci_data *pd = dev_get_priv(dev);
- pd->base = (void *)dev_read_addr(dev); - if (IS_ERR(pd->base)) - return PTR_ERR(pd->base); + pd->va = (void *)dev_read_addr(dev); + if (IS_ERR(pd->va)) + return PTR_ERR(pd->va); + + err = clk_get_by_index(dev, 0, &pd->parent_hfclk); + if (err) + return err;
- err = clk_get_by_index(dev, 0, &pd->parent); + err = clk_get_by_index(dev, 1, &pd->parent_rtcclk); if (err) return err;
@@ -588,8 +613,7 @@ static struct clk_ops sifive_fu540_prci_ops = { };
static const struct udevice_id sifive_fu540_prci_ids[] = { - { .compatible = "sifive,fu540-c000-prci0" }, - { .compatible = "sifive,aloeprci0" }, + { .compatible = "sifive,fu540-c000-prci" }, { } };
The GEMGXL clock driver is now directly part of Cadence MACB ethernet driver in upstream Linux kernel. There is no separate GEMGXL clock driver in upstream Linux kernel hence we drop GEMGXL clock driver from U-Boot as well.
Signed-off-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- board/sifive/fu540/Kconfig | 1 - drivers/clk/sifive/Kconfig | 7 ---- drivers/clk/sifive/Makefile | 2 -- drivers/clk/sifive/gemgxl-mgmt.c | 60 -------------------------------- 4 files changed, 70 deletions(-) delete mode 100644 drivers/clk/sifive/gemgxl-mgmt.c
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 8eb5e304ab..f46437901d 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -28,7 +28,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply CMD_PING imply CLK_SIFIVE imply CLK_SIFIVE_FU540_PRCI - imply CLK_SIFIVE_GEMGXL_MGMT imply DOS_PARTITION imply EFI_PARTITION imply IP_DYN diff --git a/drivers/clk/sifive/Kconfig b/drivers/clk/sifive/Kconfig index d90be1943f..c4d0a1f9b1 100644 --- a/drivers/clk/sifive/Kconfig +++ b/drivers/clk/sifive/Kconfig @@ -14,10 +14,3 @@ config CLK_SIFIVE_FU540_PRCI Supports the Power Reset Clock interface (PRCI) IP block found in FU540 SoCs. If this kernel is meant to run on a SiFive FU540 SoC, enable this driver. - -config CLK_SIFIVE_GEMGXL_MGMT - bool "GEMGXL management for SiFive FU540 SoCs" - depends on CLK_SIFIVE - help - Supports the GEMGXL management IP block found in FU540 SoCs to - control GEM TX clock operation mode for 10/100/1000 Mbps. diff --git a/drivers/clk/sifive/Makefile b/drivers/clk/sifive/Makefile index 0813360ca7..b224279afb 100644 --- a/drivers/clk/sifive/Makefile +++ b/drivers/clk/sifive/Makefile @@ -1,5 +1,3 @@ # SPDX-License-Identifier: GPL-2.0+
obj-$(CONFIG_CLK_SIFIVE_FU540_PRCI) += fu540-prci.o - -obj-$(CONFIG_CLK_SIFIVE_GEMGXL_MGMT) += gemgxl-mgmt.o diff --git a/drivers/clk/sifive/gemgxl-mgmt.c b/drivers/clk/sifive/gemgxl-mgmt.c deleted file mode 100644 index eb37416b5e..0000000000 --- a/drivers/clk/sifive/gemgxl-mgmt.c +++ /dev/null @@ -1,60 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2019, Bin Meng bmeng.cn@gmail.com - */ - -#include <common.h> -#include <clk-uclass.h> -#include <dm.h> -#include <asm/io.h> - -struct gemgxl_mgmt_regs { - __u32 tx_clk_sel; -}; - -struct gemgxl_mgmt_platdata { - struct gemgxl_mgmt_regs *regs; -}; - -static int gemgxl_mgmt_ofdata_to_platdata(struct udevice *dev) -{ - struct gemgxl_mgmt_platdata *plat = dev_get_platdata(dev); - - plat->regs = (struct gemgxl_mgmt_regs *)dev_read_addr(dev); - - return 0; -} - -static ulong gemgxl_mgmt_set_rate(struct clk *clk, ulong rate) -{ - struct gemgxl_mgmt_platdata *plat = dev_get_platdata(clk->dev); - - /* - * GEMGXL TX clock operation mode: - * - * 0 = GMII mode. Use 125 MHz gemgxlclk from PRCI in TX logic - * and output clock on GMII output signal GTX_CLK - * 1 = MII mode. Use MII input signal TX_CLK in TX logic - */ - writel(rate != 125000000, &plat->regs->tx_clk_sel); - - return 0; -} - -const struct clk_ops gemgxl_mgmt_ops = { - .set_rate = gemgxl_mgmt_set_rate, -}; - -static const struct udevice_id gemgxl_mgmt_match[] = { - { .compatible = "sifive,cadencegemgxlmgmt0", }, - { /* sentinel */ } -}; - -U_BOOT_DRIVER(sifive_gemgxl_mgmt) = { - .name = "sifive-gemgxl-mgmt", - .id = UCLASS_CLK, - .of_match = gemgxl_mgmt_match, - .ofdata_to_platdata = gemgxl_mgmt_ofdata_to_platdata, - .platdata_auto_alloc_size = sizeof(struct gemgxl_mgmt_platdata), - .ops = &gemgxl_mgmt_ops, -};
Hi Anup,
- It is in sync with upstream Linux driver
- It uses latest DT bindings as-per upstream Linux driver
Changes since v2:
If we drop PATCH6, we should also drop PATCH5, otherwise U-Boot 10/100Mbps is broken.
Regards, Bin
On Wed, Jun 19, 2019 at 12:37 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Anup,
Changes since v2:
I think it's easier to just implement TX clock select in MACB driver. I will send v4 soon.
Regards, Anup
Anup Patel
Anup Patel
Bin Meng
