[U-Boot] [BUG] H2+/H3 : SPI driver : error: ‘AHB_GATE_OFFSET_SPI0’ undeclared (first use in this function)
Version: u-boot-2018.09
Configuration : orangepi_zero_defconfig
In file included from include/wait_bit.h:15:0, from drivers/spi/sun4i_spi.c:26: drivers/spi/sun4i_spi.c: In function 'sun4i_spi_enable_clock': LD drivers/usb/musb-new/built-in.o drivers/spi/sun4i_spi.c:246:38: error: 'AHB_GATE_OFFSET_SPI0' undeclared (first use in this function); did you mean 'AHB_GATE_OFFSET_MMC0'? setbits_le32(&ccm->ahb_gate0, (1 << AHB_GATE_OFFSET_SPI0));
AHB_GATE_OFFSET_SPI0 can be found in:
./arch/arm/include/asm/arch-sunxi/clock_sun4i.h:#define AHB_GATE_OFFSET_SPI0 20 ./arch/arm/include/asm/arch-sunxi/clock_sun8i_a83t.h:#define AHB_GATE_OFFSET_SPI0 20
~/uboot/u-boot-2018.09$ grep -a CONFIG_MACH_SUN8I .config # CONFIG_MACH_SUN8I_A23 is not set # CONFIG_MACH_SUN8I_A33 is not set # CONFIG_MACH_SUN8I_A83T is not set CONFIG_MACH_SUN8I_H3=y # CONFIG_MACH_SUN8I_R40 is not set # CONFIG_MACH_SUN8I_V3S is not set CONFIG_MACH_SUN8I=y
With arch/arm/include/asm/arch/clock.h
#if defined(CONFIG_MACH_SUN8I_A83T) #include <asm/arch/clock_sun8i_a83t.h> #elif defined(CONFIG_MACH_SUN50I_H6) #include <asm/arch/clock_sun50i_h6.h> #elif defined(CONFIG_MACH_SUN6I) || defined(CONFIG_MACH_SUN8I) || \ defined(CONFIG_MACH_SUN50I) #include <asm/arch/clock_sun6i.h> #elif defined(CONFIG_MACH_SUN9I) #include <asm/arch/clock_sun9i.h> #else #include <asm/arch/clock_sun4i.h> #endif
The AHB_GATE_OFFSET_SPI0 should be defined in asm/arch/clock_sun6i.h
- Arjan
Arjan van Vught
