[PATCH 0/3] Support pwm driver for aspeed ast26xx
This series adds driver support for the PWM controller found in Aspeed's AST2600 BMC SoCs, but isn't compatible with the AST2400 and AST2500.
Billy Tsai (3): pwm: Add Aspeed ast2600 PWM support pinctrl: Add the pinctrl setting for PWM. ARM: dts: ast2600: Add PWM to device tree
arch/arm/dts/ast2600-evb.dts | 20 ++ arch/arm/dts/ast2600.dtsi | 95 +++++++++ drivers/pinctrl/aspeed/pinctrl_ast2600.c | 120 +++++++++++ drivers/pwm/Kconfig | 8 + drivers/pwm/Makefile | 1 + drivers/pwm/pwm-aspeed.c | 251 +++++++++++++++++++++++ 6 files changed, 495 insertions(+) create mode 100644 drivers/pwm/pwm-aspeed.c
This patch add the support of PWM controller which can be found at aspeed ast2600 soc. The pwm supoorts up to 16 channels and it's part function of multi-function device "pwm-tach controller".
Signed-off-by: Billy Tsai billy_tsai@aspeedtech.com --- drivers/pwm/Kconfig | 8 ++ drivers/pwm/Makefile | 1 + drivers/pwm/pwm-aspeed.c | 251 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 260 insertions(+) create mode 100644 drivers/pwm/pwm-aspeed.c
diff --git a/drivers/pwm/Kconfig b/drivers/pwm/Kconfig index 669d3fa4fc..6be612d58a 100644 --- a/drivers/pwm/Kconfig +++ b/drivers/pwm/Kconfig @@ -9,6 +9,14 @@ config DM_PWM frequency/period can be controlled along with the proportion of that time that the signal is high.
+config PWM_ASPEED + bool "Enable support for the Aspeed PWM" + depends on DM_PWM + help + This PWM is found on Ast2600 SoCs. It supports a programmable period + and duty cycle. It provides 16 channels which can be independently + programmed. + config PWM_AT91 bool "Enable support for PWM found on AT91 SoC's" depends on DM_PWM && ARCH_AT91 diff --git a/drivers/pwm/Makefile b/drivers/pwm/Makefile index 55f2bc081d..5d31812d52 100644 --- a/drivers/pwm/Makefile +++ b/drivers/pwm/Makefile @@ -10,6 +10,7 @@
obj-$(CONFIG_DM_PWM) += pwm-uclass.o
+obj-$(CONFIG_PWM_ASPEED) += pwm-aspeed.o obj-$(CONFIG_PWM_AT91) += pwm-at91.o obj-$(CONFIG_PWM_CROS_EC) += cros_ec_pwm.o obj-$(CONFIG_PWM_EXYNOS) += exynos_pwm.o diff --git a/drivers/pwm/pwm-aspeed.c b/drivers/pwm/pwm-aspeed.c new file mode 100644 index 0000000000..ba98641c86 --- /dev/null +++ b/drivers/pwm/pwm-aspeed.c @@ -0,0 +1,251 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Aspeed Technology Inc. + * + * PWM controller driver for Aspeed ast2600 SoCs. + * This drivers doesn't support earlier version of the IP. + * + * The formula of pwm period duration: + * period duration = ((DIV_L + 1) * (PERIOD + 1) << DIV_H) / input-clk + * + * The formula of pwm duty cycle duration: + * duty cycle duration = period duration * DUTY_CYCLE_FALLING_POINT / (PERIOD + 1) + * = ((DIV_L + 1) * DUTY_CYCLE_FALLING_POINT << DIV_H) / input-clk + * + * The software driver fixes the period to 255, which causes the high-frequency + * precision of the PWM to be coarse, in exchange for the fineness of the duty cycle. + * + * Register usage: + * PIN_ENABLE: When it is unset the pwm controller will always output low to the extern. + * Use to determine whether the PWM channel is enabled or disabled + * CLK_ENABLE: When it is unset the pwm controller will reset the duty counter to 0 and + * output low to the PIN_ENABLE mux after that the driver can still change the pwm period + * and duty and the value will apply when CLK_ENABLE be set again. + * Use to determine whether duty_cycle bigger than 0. + * PWM_ASPEED_CTRL_INVERSE: When it is toggled the output value will inverse immediately. + * PWM_ASPEED_DUTY_CYCLE_FALLING_POINT/PWM_ASPEED_DUTY_CYCLE_RISING_POINT: When these two + * values are equal it means the duty cycle = 100%. + * + * Limitations: + * - When changing both duty cycle and period, we cannot prevent in + * software that the output might produce a period with mixed + * settings. + * - Disabling the PWM doesn't complete the current period. + * + * Improvements: + * - When only changing one of duty cycle or period, our pwm controller will not + * generate the glitch, the configure will change at next cycle of pwm. + * This improvement can disable/enable through PWM_ASPEED_CTRL_DUTY_SYNC_DISABLE. + */ + +#include <common.h> +#include <div64.h> +#include <dm.h> +#include <pwm.h> +#include <clk.h> +#include <reset.h> +#include <regmap.h> +#include <syscon.h> +#include <dm/device_compat.h> +#include <linux/math64.h> +#include <linux/bitfield.h> +#include <asm/io.h> + +/* The channel number of Aspeed pwm controller */ +#define PWM_ASPEED_NR_PWMS 16 + +/* PWM Control Register */ +#define PWM_ASPEED_CTRL(ch) ((ch) * 0x10 + 0x00) +#define PWM_ASPEED_CTRL_LOAD_SEL_RISING_AS_WDT BIT(19) +#define PWM_ASPEED_CTRL_DUTY_LOAD_AS_WDT_ENABLE BIT(18) +#define PWM_ASPEED_CTRL_DUTY_SYNC_DISABLE BIT(17) +#define PWM_ASPEED_CTRL_CLK_ENABLE BIT(16) +#define PWM_ASPEED_CTRL_LEVEL_OUTPUT BIT(15) +#define PWM_ASPEED_CTRL_INVERSE BIT(14) +#define PWM_ASPEED_CTRL_OPEN_DRAIN_ENABLE BIT(13) +#define PWM_ASPEED_CTRL_PIN_ENABLE BIT(12) +#define PWM_ASPEED_CTRL_CLK_DIV_H GENMASK(11, 8) +#define PWM_ASPEED_CTRL_CLK_DIV_L GENMASK(7, 0) + +/* PWM Duty Cycle Register */ +#define PWM_ASPEED_DUTY_CYCLE(ch) ((ch) * 0x10 + 0x04) +#define PWM_ASPEED_DUTY_CYCLE_PERIOD GENMASK(31, 24) +#define PWM_ASPEED_DUTY_CYCLE_POINT_AS_WDT GENMASK(23, 16) +#define PWM_ASPEED_DUTY_CYCLE_FALLING_POINT GENMASK(15, 8) +#define PWM_ASPEED_DUTY_CYCLE_RISING_POINT GENMASK(7, 0) + +/* PWM fixed value */ +#define PWM_ASPEED_FIXED_PERIOD 0xff + +#define NSEC_PER_SEC 1000000000L + +struct aspeed_pwm_priv { + struct clk clk; + struct regmap *regmap; + struct reset_ctl reset; +}; + +static int aspeed_pwm_set_invert(struct udevice *dev, uint channel, bool polarity) +{ + struct aspeed_pwm_priv *priv = dev_get_priv(dev); + + if (channel >= PWM_ASPEED_NR_PWMS) + return -EINVAL; + + regmap_update_bits(priv->regmap, PWM_ASPEED_CTRL(channel), + PWM_ASPEED_CTRL_INVERSE, + FIELD_PREP(PWM_ASPEED_CTRL_INVERSE, + polarity)); + return 0; +} + +static int aspeed_pwm_set_enable(struct udevice *dev, uint channel, bool enable) +{ + struct aspeed_pwm_priv *priv = dev_get_priv(dev); + + if (channel >= PWM_ASPEED_NR_PWMS) + return -EINVAL; + + regmap_update_bits(priv->regmap, PWM_ASPEED_CTRL(channel), + PWM_ASPEED_CTRL_PIN_ENABLE, + enable ? PWM_ASPEED_CTRL_PIN_ENABLE : 0); + return 0; +} + +static int aspeed_pwm_set_config(struct udevice *dev, uint channel, + uint period_ns, uint duty_ns) +{ + struct aspeed_pwm_priv *priv = dev_get_priv(dev); + u32 duty_pt; + unsigned long rate; + u64 div_h, div_l, divisor; + bool clk_en; + + if (channel >= PWM_ASPEED_NR_PWMS) + return -EINVAL; + dev_dbg(dev, "expect period: %dns, duty_cycle: %dns\n", period_ns, + duty_ns); + + rate = clk_get_rate(&priv->clk); + /* + * Pick the smallest value for div_h so that div_l can be the biggest + * which results in a finer resolution near the target period value. + */ + divisor = (u64)NSEC_PER_SEC * (PWM_ASPEED_FIXED_PERIOD + 1) * + (PWM_ASPEED_CTRL_CLK_DIV_L + 1); + div_h = order_base_2(div64_u64((u64)rate * period_ns + divisor - 1, divisor)); + if (div_h > 0xf) + div_h = 0xf; + + divisor = ((u64)NSEC_PER_SEC * (PWM_ASPEED_FIXED_PERIOD + 1)) << div_h; + div_l = div64_u64((u64)rate * period_ns, divisor); + + if (div_l == 0) + return -ERANGE; + + div_l -= 1; + + if (div_l > 255) + div_l = 255; + + dev_dbg(dev, "clk source: %ld div_h %lld, div_l : %lld\n", rate, div_h, + div_l); + /* duty_pt = duty_cycle * (PERIOD + 1) / period */ + duty_pt = div64_u64(duty_ns * (u64)rate, + (u64)NSEC_PER_SEC * (div_l + 1) << div_h); + dev_dbg(dev, "duty_cycle = %d, duty_pt = %d\n", duty_ns, + duty_pt); + + if (duty_pt == 0) { + clk_en = 0; + } else { + clk_en = 1; + if (duty_pt >= (PWM_ASPEED_FIXED_PERIOD + 1)) + duty_pt = 0; + /* + * Fixed DUTY_CYCLE_PERIOD to its max value to get a + * fine-grained resolution for duty_cycle at the expense of a + * coarser period resolution. + */ + regmap_update_bits(priv->regmap, PWM_ASPEED_DUTY_CYCLE(channel), + PWM_ASPEED_DUTY_CYCLE_PERIOD | + PWM_ASPEED_DUTY_CYCLE_RISING_POINT | + PWM_ASPEED_DUTY_CYCLE_FALLING_POINT, + FIELD_PREP(PWM_ASPEED_DUTY_CYCLE_PERIOD, + PWM_ASPEED_FIXED_PERIOD) | + FIELD_PREP(PWM_ASPEED_DUTY_CYCLE_FALLING_POINT, + duty_pt)); + } + + regmap_update_bits(priv->regmap, PWM_ASPEED_CTRL(channel), + PWM_ASPEED_CTRL_CLK_DIV_H | + PWM_ASPEED_CTRL_CLK_DIV_L | + PWM_ASPEED_CTRL_CLK_ENABLE, + FIELD_PREP(PWM_ASPEED_CTRL_CLK_DIV_H, div_h) | + FIELD_PREP(PWM_ASPEED_CTRL_CLK_DIV_L, div_l) | + FIELD_PREP(PWM_ASPEED_CTRL_CLK_ENABLE, clk_en)); + return 0; +} + +static int aspeed_pwm_probe(struct udevice *dev) +{ + int ret; + struct aspeed_pwm_priv *priv = dev_get_priv(dev); + struct udevice *parent_dev = dev_get_parent(dev); + + priv->regmap = syscon_node_to_regmap(dev_ofnode(dev->parent)); + if (IS_ERR(priv->regmap)) { + dev_err(dev, "Couldn't get regmap\n"); + return PTR_ERR(priv->regmap); + } + + ret = clk_get_by_index(parent_dev, 0, &priv->clk); + if (ret < 0) { + dev_err(dev, "get clock failed\n"); + return ret; + } + + ret = reset_get_by_index(parent_dev, 0, &priv->reset); + if (ret) { + dev_err(dev, "get reset failed\n"); + return ret; + } + ret = reset_deassert(&priv->reset); + if (ret) { + dev_err(dev, "cannot deassert reset control: %pe\n", + ERR_PTR(ret)); + return ret; + } + + return 0; +} + +static int aspeed_pwm_remove(struct udevice *dev) +{ + struct aspeed_pwm_priv *priv = dev_get_priv(dev); + + reset_assert(&priv->reset); + + return 0; +} + +static const struct pwm_ops aspeed_pwm_ops = { + .set_invert = aspeed_pwm_set_invert, + .set_config = aspeed_pwm_set_config, + .set_enable = aspeed_pwm_set_enable, +}; + +static const struct udevice_id aspeed_pwm_ids[] = { + { .compatible = "aspeed,ast2600-pwm" }, + { } +}; + +U_BOOT_DRIVER(aspeed_pwm) = { + .name = "aspeed_pwm", + .id = UCLASS_PWM, + .of_match = aspeed_pwm_ids, + .ops = &aspeed_pwm_ops, + .probe = aspeed_pwm_probe, + .remove = aspeed_pwm_remove, + .priv_auto = sizeof(struct aspeed_pwm_priv), +};
From: Simon Glass sjg@chromium.org Sent: Saturday, March 12, 2022 10:44 AM
Reviewed-by: Chia-Wei Wang chiawei_wang@aspeedtech.com
Signed-off-by: Billy Tsai billy_tsai@aspeedtech.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Chia-Wei Wang chiawei_wang@aspeedtech.com
This patchs add the signal description array for PWM pinctrl settings.
Signed-off-by: Billy Tsai billy_tsai@aspeedtech.com --- arch/arm/dts/ast2600.dtsi | 80 +++++++++++++++ drivers/pinctrl/aspeed/pinctrl_ast2600.c | 120 +++++++++++++++++++++++ 2 files changed, 200 insertions(+)
diff --git a/arch/arm/dts/ast2600.dtsi b/arch/arm/dts/ast2600.dtsi index 98840ce7b0..ce006a3759 100644 --- a/arch/arm/dts/ast2600.dtsi +++ b/arch/arm/dts/ast2600.dtsi @@ -1626,6 +1626,86 @@ groups = "PWM7"; };
+ pinctrl_pwm8g0_default: pwm8g0_default { + function = "PWM8G0"; + groups = "PWM8G0"; + }; + + pinctrl_pwm8g1_default: pwm8g1_default { + function = "PWM8G1"; + groups = "PWM8G1"; + }; + + pinctrl_pwm9g0_default: pwm9g0_default { + function = "PWM9G0"; + groups = "PWM9G0"; + }; + + pinctrl_pwm9g1_default: pwm9g1_default { + function = "PWM9G1"; + groups = "PWM9G1"; + }; + + pinctrl_pwm10g0_default: pwm10g0_default { + function = "PWM10G0"; + groups = "PWM10G0"; + }; + + pinctrl_pwm10g1_default: pwm10g1_default { + function = "PWM10G1"; + groups = "PWM10G1"; + }; + + pinctrl_pwm11g0_default: pwm11g0_default { + function = "PWM11G0"; + groups = "PWM11G0"; + }; + + pinctrl_pwm11g1_default: pwm11g1_default { + function = "PWM11G1"; + groups = "PWM11G1"; + }; + + pinctrl_pwm12g0_default: pwm12g0_default { + function = "PWM12G0"; + groups = "PWM12G0"; + }; + + pinctrl_pwm12g1_default: pwm12g1_default { + function = "PWM12G1"; + groups = "PWM12G1"; + }; + + pinctrl_pwm13g0_default: pwm13g0_default { + function = "PWM13G0"; + groups = "PWM13G0"; + }; + + pinctrl_pwm13g1_default: pwm13g1_default { + function = "PWM13G1"; + groups = "PWM13G1"; + }; + + pinctrl_pwm14g0_default: pwm14g0_default { + function = "PWM14G0"; + groups = "PWM14G0"; + }; + + pinctrl_pwm14g1_default: pwm14g1_default { + function = "PWM14G1"; + groups = "PWM14G1"; + }; + + pinctrl_pwm15g0_default: pwm15g0_default { + function = "PWM15G0"; + groups = "PWM15G0"; + }; + + pinctrl_pwm15g1_default: pwm15g1_default { + function = "PWM15G1"; + groups = "PWM15G1"; + }; + pinctrl_rgmii1_default: rgmii1_default { function = "RGMII1"; groups = "RGMII1"; diff --git a/drivers/pinctrl/aspeed/pinctrl_ast2600.c b/drivers/pinctrl/aspeed/pinctrl_ast2600.c index 12cba83f6c..97e8b4ec9b 100644 --- a/drivers/pinctrl/aspeed/pinctrl_ast2600.c +++ b/drivers/pinctrl/aspeed/pinctrl_ast2600.c @@ -335,6 +335,102 @@ static struct aspeed_sig_desc pcie1rc_link[] = { { 0x500, BIT(24), 0 }, /* dedicate rc reset */ };
+static struct aspeed_sig_desc pwm0[] = { + {0x41c, BIT(16), 0}, +}; + +static struct aspeed_sig_desc pwm1[] = { + {0x41c, BIT(17), 0}, +}; + +static struct aspeed_sig_desc pwm2[] = { + {0x41c, BIT(18), 0}, +}; + +static struct aspeed_sig_desc pwm3[] = { + {0x41c, BIT(19), 0}, +}; + +static struct aspeed_sig_desc pwm4[] = { + {0x41c, BIT(20), 0}, +}; + +static struct aspeed_sig_desc pwm5[] = { + {0x41c, BIT(21), 0}, +}; + +static struct aspeed_sig_desc pwm6[] = { + {0x41c, BIT(22), 0}, +}; + +static struct aspeed_sig_desc pwm7[] = { + {0x41c, BIT(23), 0}, +}; + +static struct aspeed_sig_desc pwm8g0[] = { + {0x4B4, BIT(8), 0}, +}; + +static struct aspeed_sig_desc pwm8g1[] = { + {0x41c, BIT(24), 0}, +}; + +static struct aspeed_sig_desc pwm9g0[] = { + {0x4B4, BIT(9), 0}, +}; + +static struct aspeed_sig_desc pwm9g1[] = { + {0x41c, BIT(25), 0}, +}; + +static struct aspeed_sig_desc pwm10g0[] = { + {0x4B4, BIT(10), 0}, +}; + +static struct aspeed_sig_desc pwm10g1[] = { + {0x41c, BIT(26), 0}, +}; + +static struct aspeed_sig_desc pwm11g0[] = { + {0x4B4, BIT(11), 0}, +}; + +static struct aspeed_sig_desc pwm11g1[] = { + {0x41c, BIT(27), 0}, +}; + +static struct aspeed_sig_desc pwm12g0[] = { + {0x4B4, BIT(12), 0}, +}; + +static struct aspeed_sig_desc pwm12g1[] = { + {0x41c, BIT(28), 0}, +}; + +static struct aspeed_sig_desc pwm13g0[] = { + {0x4B4, BIT(13), 0}, +}; + +static struct aspeed_sig_desc pwm13g1[] = { + {0x41c, BIT(29), 0}, +}; + +static struct aspeed_sig_desc pwm14g0[] = { + {0x4B4, BIT(14), 0}, +}; + +static struct aspeed_sig_desc pwm14g1[] = { + {0x41c, BIT(30), 0}, +}; + +static struct aspeed_sig_desc pwm15g0[] = { + {0x4B4, BIT(15), 0}, +}; + +static struct aspeed_sig_desc pwm15g1[] = { + {0x41c, BIT(31), 0}, +}; + static const struct aspeed_group_config ast2600_groups[] = { { "MAC1LINK", ARRAY_SIZE(mac1_link), mac1_link }, { "MAC2LINK", ARRAY_SIZE(mac2_link), mac2_link }, @@ -394,6 +490,30 @@ static const struct aspeed_group_config ast2600_groups[] = { { "USB2BH", ARRAY_SIZE(usb2bh_link), usb2bh_link }, { "PCIE0RC", ARRAY_SIZE(pcie0rc_link), pcie0rc_link }, { "PCIE1RC", ARRAY_SIZE(pcie1rc_link), pcie1rc_link }, + { "PWM0", ARRAY_SIZE(pwm0), pwm0 }, + { "PWM1", ARRAY_SIZE(pwm1), pwm1 }, + { "PWM2", ARRAY_SIZE(pwm2), pwm2 }, + { "PWM3", ARRAY_SIZE(pwm3), pwm3 }, + { "PWM4", ARRAY_SIZE(pwm4), pwm4 }, + { "PWM5", ARRAY_SIZE(pwm5), pwm5 }, + { "PWM6", ARRAY_SIZE(pwm6), pwm6 }, + { "PWM7", ARRAY_SIZE(pwm7), pwm7 }, + { "PWM8G0", ARRAY_SIZE(pwm8g0), pwm8g0 }, + { "PWM8G1", ARRAY_SIZE(pwm8g1), pwm8g1 }, + { "PWM9G0", ARRAY_SIZE(pwm9g0), pwm9g0 }, + { "PWM9G1", ARRAY_SIZE(pwm9g1), pwm9g1 }, + { "PWM10G0", ARRAY_SIZE(pwm10g0), pwm10g0 }, + { "PWM10G1", ARRAY_SIZE(pwm10g1), pwm10g1 }, + { "PWM11G0", ARRAY_SIZE(pwm11g0), pwm11g0 }, + { "PWM11G1", ARRAY_SIZE(pwm11g1), pwm11g1 }, + { "PWM12G0", ARRAY_SIZE(pwm12g0), pwm12g0 }, + { "PWM12G1", ARRAY_SIZE(pwm12g1), pwm12g1 }, + { "PWM13G0", ARRAY_SIZE(pwm13g0), pwm13g0 }, + { "PWM13G1", ARRAY_SIZE(pwm13g1), pwm13g1 }, + { "PWM14G0", ARRAY_SIZE(pwm14g0), pwm14g0 }, + { "PWM14G1", ARRAY_SIZE(pwm14g1), pwm14g1 }, + { "PWM15G0", ARRAY_SIZE(pwm15g0), pwm15g0 }, + { "PWM15G1", ARRAY_SIZE(pwm15g1), pwm15g1 }, };
static int ast2600_pinctrl_get_groups_count(struct udevice *dev)
Add the PWM node and enable it for AST2600 EVB
Signed-off-by: Billy Tsai billy_tsai@aspeedtech.com --- arch/arm/dts/ast2600-evb.dts | 20 ++++++++++++++++++++ arch/arm/dts/ast2600.dtsi | 15 +++++++++++++++ 2 files changed, 35 insertions(+)
diff --git a/arch/arm/dts/ast2600-evb.dts b/arch/arm/dts/ast2600-evb.dts index c17988ec3c..0d65054313 100644 --- a/arch/arm/dts/ast2600-evb.dts +++ b/arch/arm/dts/ast2600-evb.dts @@ -37,6 +37,26 @@ }; };
+&pwm { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm0_default + &pinctrl_pwm1_default + &pinctrl_pwm2_default + &pinctrl_pwm3_default + &pinctrl_pwm4_default + &pinctrl_pwm5_default + &pinctrl_pwm6_default + &pinctrl_pwm7_default + &pinctrl_pwm8g1_default + &pinctrl_pwm9g1_default + &pinctrl_pwm10g1_default + &pinctrl_pwm11g1_default + &pinctrl_pwm12g1_default + &pinctrl_pwm13g1_default + &pinctrl_pwm14g1_default>; +}; + &uart5 { u-boot,dm-pre-reloc; status = "okay"; diff --git a/arch/arm/dts/ast2600.dtsi b/arch/arm/dts/ast2600.dtsi index ce006a3759..64074309b7 100644 --- a/arch/arm/dts/ast2600.dtsi +++ b/arch/arm/dts/ast2600.dtsi @@ -113,6 +113,21 @@ reg = < 0x1e600000 0x100>; };
+ pwm_tach: pwm_tach@1e610000 { + compatible = "aspeed,ast2600-pwm-tach", "simple-mfd", "syscon"; + reg = <0x1e610000 0x100>; + clocks = <&scu ASPEED_CLK_AHB>; + resets = <&rst ASPEED_RESET_PWM>; + + pwm: pwm { + compatible = "aspeed,ast2600-pwm"; + #pwm-cells = <3>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + }; + fmc: flash-controller@1e620000 { reg = < 0x1e620000 0xc4 0x20000000 0x10000000 >;
Billy Tsai
ChiaWei Wang
