[U-Boot] [PULL] u-boot-socfpga/master
The following changes since commit 3cfb67d0419c645998b440592d8c2ce010134b8e:
Prepare v2017.01-rc1 (2016-12-05 18:36:23 -0500)
git://git.denx.de/u-boot-socfpga.git master
for you to fetch changes up to f22dede20bb57195330ef11e148ca2b5f1280b2e:
MAINTAINERS: Fix ALTERA SOCFPGA Files (2016-12-06 01:45:58 +0100)
---------------------------------------------------------------- Anatolij Gustschin (1): socfpga: add support for Terasic DE1-SoC board
Bill Randle (1): qts-filter.sh: strip DOS line endings and handle continuation lines
Dinh Nguyen (1): MAINTAINERS: socfpga: update email address for Dinh Nguyen
Jagan Teki (1): MAINTAINERS: Fix ALTERA SOCFPGA Files
Marek Vasut (1): ARM: socfpga: Add boot0 hook to prevent SPL corruption
MAINTAINERS | 3 +- arch/arm/Kconfig | 1 + arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_cyclone5_de1_soc.dts | 66 ++++++++++ arch/arm/mach-socfpga/Kconfig | 7 + arch/arm/mach-socfpga/include/mach/boot0.h | 28 ++++ arch/arm/mach-socfpga/qts-filter.sh | 47 ++++--- board/altera/arria5-socdk/MAINTAINERS | 2 +- board/altera/cyclone5-socdk/MAINTAINERS | 2 +- board/terasic/de0-nano-soc/MAINTAINERS | 2 +- board/terasic/de1-soc/MAINTAINERS | 5 +
board/terasic/de1-soc/Makefile | 9 ++
board/terasic/de1-soc/qts/iocsr_config.h | 660 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
board/terasic/de1-soc/qts/pinmux_config.h | 219 +++++++++++++++++++++++++++++++
board/terasic/de1-soc/qts/pll_config.h | 91 +++++++++++++
board/terasic/de1-soc/qts/sdram_config.h | 344 +++++++++++++++++++++++++++++++++++++++++++++++++
board/terasic/de1-soc/socfpga.c | 19 +++ configs/socfpga_de1_soc_defconfig | 50 ++++++++ doc/git-mailrc | 3 +- include/configs/socfpga_de1_soc.h | 57 +++++++++ 20 files changed, 1595 insertions(+), 21 deletions(-) create mode 100644 arch/arm/dts/socfpga_cyclone5_de1_soc.dts create mode 100644 arch/arm/mach-socfpga/include/mach/boot0.h create mode 100644 board/terasic/de1-soc/MAINTAINERS create mode 100644 board/terasic/de1-soc/Makefile create mode 100644 board/terasic/de1-soc/qts/iocsr_config.h create mode 100644 board/terasic/de1-soc/qts/pinmux_config.h create mode 100644 board/terasic/de1-soc/qts/pll_config.h create mode 100644 board/terasic/de1-soc/qts/sdram_config.h create mode 100644 board/terasic/de1-soc/socfpga.c create mode 100644 configs/socfpga_de1_soc_defconfig create mode 100644 include/configs/socfpga_de1_soc.h
