[PATCH v8 0/3] BOOTP/DHCPv4 enhancements
In our datacenter application, a single DHCP server is servicing 36000+ clients. Improvements are required to the DHCPv4 retransmission behavior to align with RFC and ensure less pressure is exerted on the server: - retransmission backoff interval maximum is configurable (environment variable bootpretransmitperiodmax) - initial retransmission backoff interval is configurable (environment variable bootpretransmitperiodinit) - transaction ID is kept the same for each BOOTP/DHCPv4 request (not recreated on each retry)
For our application we'll use: - bootpretransmitperiodmax=16000 - bootpretransmitperiodinit=2000
A new configuration BOOTP_RANDOM_XID has been added to enable a randomized BOOTP/DHCPv4 transaction ID.
Enhance DHCPv4 sending/parsing option 209 (PXE config file). A previous patch was accepted. A new patch fixes a possible double free() and addresses latest review comments.
Changes in v8: - remove unused variable "char *ep" from bootp_reset()
Changes in v7: - Remove "depends on LIB_RAND || LIB_HW_RAND" from CMD_BOOTP - Add CMD_BOOTP/CMD_DHCP/CMD_DHCP6 to LIB_RAND menu choice - Add space after "config CMD_DHCP"
Changes in v6: - CMD_BOOTP should "depends on LIB_RAND || LIB_HW_RAND"
Changes in v5: - add change log to individual patches - fix depends for BOOTP_RANDOM_XID: "depends on CMD_BOOTP && (LIB_RAND || LIB_HW_RAND)"
Changes in v4: - rebase master and resolve conflicts - default y for BOOTP_PXE_DHCP_OPTION (feedback from review) - Add "select LIB_RAND" for "config CMD_BOOTP" (retransmission improvements require rand())
Changes in v3: - add define for option 209 and rfc5071 reference - Set RETRANSMIT_PERIOD_MAX_MS=60000 - Add randomization factor to retransmission timeout - Add depends for BOOTP_RANDOM_XID
Changes in v2: - use env_get_ulong() to get environment variables
Sean Edmond (3): net: Enhancements for dhcp option 209 net: bootp: BOOTP/DHCPv4 retransmission improvements net: bootp: add config option BOOTP_RANDOM_XID
cmd/Kconfig | 8 ++++++ cmd/pxe.c | 2 ++ lib/Kconfig | 3 ++- net/bootp.c | 73 ++++++++++++++++++++++++++++++++++++++++------------- net/bootp.h | 2 ++ 5 files changed, 70 insertions(+), 18 deletions(-)
- Enable option 209 by default - Set pxelinux_configfile to NULL to avoid potential double free - change hardcoded 209 to a define
Signed-off-by: Sean Edmond seanedmond@microsoft.com
(no changes since v7)
Changes in v7: - Reword this commit
Changes in v6: - Reword this commit
Changes in v4: - rebase master and resolve conflicts - default y for BOOTP_PXE_DHCP_OPTION (feedback from review) - change commit description for this patch (this is now an enhancement patch)
cmd/Kconfig | 1 + cmd/pxe.c | 2 ++ net/bootp.c | 4 ++-- net/bootp.h | 2 ++ 4 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index c182d73ddbd..54c4ab8570c 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1898,6 +1898,7 @@ config BOOTP_PXE_CLIENTARCH
config BOOTP_PXE_DHCP_OPTION bool "Request & store 'pxe_configfile' from BOOTP/DHCP server" + default y depends on BOOTP_PXE
config BOOTP_VCI_STRING diff --git a/cmd/pxe.c b/cmd/pxe.c index 21134eb7a30..9404f445187 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -65,6 +65,8 @@ static int pxe_dhcp_option_path(struct pxe_context *ctx, unsigned long pxefile_a int ret = get_pxe_file(ctx, pxelinux_configfile, pxefile_addr_r);
free(pxelinux_configfile); + /* set to NULL to avoid double-free if DHCP is tried again */ + pxelinux_configfile = NULL;
return ret; } diff --git a/net/bootp.c b/net/bootp.c index c15472f5d37..b9e3cccb4f9 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -603,7 +603,7 @@ static int dhcp_extended(u8 *e, int message_type, struct in_addr server_ip, *cnt += 1; #endif if (IS_ENABLED(CONFIG_BOOTP_PXE_DHCP_OPTION)) { - *e++ = 209; /* PXELINUX Config File */ + *e++ = DHCP_OPTION_PXE_CONFIG_FILE; /* PXELINUX Config File */ *cnt += 1; } /* no options, so back up to avoid sending an empty request list */ @@ -922,7 +922,7 @@ static void dhcp_process_options(uchar *popt, uchar *end) net_boot_file_name[size] = 0; } break; - case 209: /* PXELINUX Config File */ + case DHCP_OPTION_PXE_CONFIG_FILE: /* PXELINUX Config File */ if (IS_ENABLED(CONFIG_BOOTP_PXE_DHCP_OPTION)) { /* In case it has already been allocated when get DHCP Offer packet, * free first to avoid memory leak. diff --git a/net/bootp.h b/net/bootp.h index 4e32b19d424..24b32c73f62 100644 --- a/net/bootp.h +++ b/net/bootp.h @@ -91,6 +91,8 @@ typedef enum { INIT, #define DHCP_NAK 6 #define DHCP_RELEASE 7
+#define DHCP_OPTION_PXE_CONFIG_FILE 209 /* "ConfigFile" option according to rfc5071 */ + /**********************************************************************/
#endif /* __BOOTP_H__ */
This patch introduces 3 improvements to align with RFC 951: - retransmission backoff interval maximum is configurable - initial retranmission backoff interval is configurable - transaction ID is kept the same for each BOOTP/DHCPv4 request
In applications where thousands of nodes are serviced by a single DHCP server, maximizing the retransmission backoff interval at 2 seconds (the current u-boot default) exerts high pressure on the DHCP server and network layer.
RFC 951 “7.2. Client Retransmission Strategy” states that the retransmission backoff interval should be limited to 60 seconds. This patch allows the interval to be configurable using the environment variable "bootpretransmitperiodmax"
The initial retranmission backoff period defaults to 250ms, which is also too small for these scenarios with many clients. This patch makes the initial retransmission interval to be configurable using the environment variable "bootpretransmitperiodinit".
Also, on a retransmission it is not expected for the transaction ID to change (only the 'secs' field should be updated). Let's save the transaction ID and use the same transaction ID for each BOOTP/DHCPv4 exchange.
Signed-off-by: Sean Edmond seanedmond@microsoft.com ---
Changes in v4: - Add "select LIB_RAND" for "config CMD_BOOTP" (retransmission improvements require rand())
Changes in v3: - Set RETRANSMIT_PERIOD_MAX_MS=60000 - Add randomization factor to retransmission timeout
lib/Kconfig | 3 ++- net/bootp.c | 68 ++++++++++++++++++++++++++++++++++++++++------------- 2 files changed, 54 insertions(+), 17 deletions(-)
diff --git a/lib/Kconfig b/lib/Kconfig index 189e6eb31aa..9b62b3bbea7 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -265,7 +265,8 @@ config REGEX choice prompt "Pseudo-random library support type" depends on NET_RANDOM_ETHADDR || RANDOM_UUID || CMD_UUID || \ - RNG_SANDBOX || UT_LIB && AES || FAT_WRITE + RNG_SANDBOX || UT_LIB && AES || FAT_WRITE || CMD_BOOTP || \ + CMD_DHCP || CMD_DHCP6 default LIB_RAND help Select the library to provide pseudo-random number generator diff --git a/net/bootp.c b/net/bootp.c index b9e3cccb4f9..c34ffe27854 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -42,6 +42,22 @@ */ #define TIMEOUT_MS ((3 + (CONFIG_NET_RETRY_COUNT * 5)) * 1000)
+/* + * According to rfc951 : 7.2. Client Retransmission Strategy + * "After the 'average' backoff reaches about 60 seconds, it should be + * increased no further, but still randomized." + * + * U-Boot has saturated this backoff at 2 seconds for a long time. + * To modify, set the environment variable "bootpretransmitperiodmax" + */ +#define RETRANSMIT_PERIOD_MAX_MS 60000 + +/* Retransmission timeout for the initial packet (in milliseconds). + * This timeout will double on each retry. To modify, set the + * environment variable bootpretransmitperiodinit. + */ +#define RETRANSMIT_PERIOD_INIT_MS 250 + #ifndef CFG_DHCP_MIN_EXT_LEN /* minimal length of extension list */ #define CFG_DHCP_MIN_EXT_LEN 64 #endif @@ -53,6 +69,7 @@ u32 bootp_ids[CFG_BOOTP_ID_CACHE_SIZE]; unsigned int bootp_num_ids; int bootp_try; +u32 bootp_id; ulong bootp_start; ulong bootp_timeout; char net_nis_domain[32] = {0,}; /* Our NIS domain */ @@ -60,6 +77,7 @@ char net_hostname[32] = {0,}; /* Our hostname */ char net_root_path[CONFIG_BOOTP_MAX_ROOT_PATH_LEN] = {0,}; /* Our bootpath */
static ulong time_taken_max; +static u32 retransmit_period_max_ms;
#if defined(CONFIG_CMD_DHCP) static dhcp_state_t dhcp_state = INIT; @@ -396,6 +414,7 @@ static void bootp_handler(uchar *pkt, unsigned dest, struct in_addr sip, static void bootp_timeout_handler(void) { ulong time_taken = get_timer(bootp_start); + int rand_minus_plus_100;
if (time_taken >= time_taken_max) { #ifdef CONFIG_BOOTP_MAY_FAIL @@ -414,8 +433,17 @@ static void bootp_timeout_handler(void) } } else { bootp_timeout *= 2; - if (bootp_timeout > 2000) - bootp_timeout = 2000; + if (bootp_timeout > retransmit_period_max_ms) + bootp_timeout = retransmit_period_max_ms; + + /* Randomize by adding bootp_timeout*RAND, where RAND + * is a randomization factor between -0.1..+0.1 + */ + srand(get_ticks() + rand()); + rand_minus_plus_100 = ((rand() % 200) - 100); + bootp_timeout = bootp_timeout + + (((int)bootp_timeout * rand_minus_plus_100) / 1000); + net_set_timeout_handler(bootp_timeout, bootp_timeout_handler); bootp_request(); } @@ -714,7 +742,8 @@ void bootp_reset(void) bootp_num_ids = 0; bootp_try = 0; bootp_start = get_timer(0); - bootp_timeout = 250; + + bootp_timeout = env_get_ulong("bootpretransmitperiodinit", 10, RETRANSMIT_PERIOD_INIT_MS); }
void bootp_request(void) @@ -726,7 +755,6 @@ void bootp_request(void) #ifdef CONFIG_BOOTP_RANDOM_DELAY ulong rand_ms; #endif - u32 bootp_id; struct in_addr zero_ip; struct in_addr bcast_ip; char *ep; /* Environment pointer */ @@ -742,6 +770,9 @@ void bootp_request(void) else time_taken_max = TIMEOUT_MS;
+ retransmit_period_max_ms = env_get_ulong("bootpretransmitperiodmax", 10, + RETRANSMIT_PERIOD_MAX_MS); + #ifdef CONFIG_BOOTP_RANDOM_DELAY /* Random BOOTP delay */ if (bootp_try == 0) srand_mac(); @@ -801,18 +832,23 @@ void bootp_request(void) extlen = bootp_extended((u8 *)bp->bp_vend); #endif
- /* - * Bootp ID is the lower 4 bytes of our ethernet address - * plus the current time in ms. - */ - bootp_id = ((u32)net_ethaddr[2] << 24) - | ((u32)net_ethaddr[3] << 16) - | ((u32)net_ethaddr[4] << 8) - | (u32)net_ethaddr[5]; - bootp_id += get_timer(0); - bootp_id = htonl(bootp_id); - bootp_add_id(bootp_id); - net_copy_u32(&bp->bp_id, &bootp_id); + /* Only generate a new transaction ID for each new BOOTP request */ + if (bootp_try == 1) { + /* + * Bootp ID is the lower 4 bytes of our ethernet address + * plus the current time in ms. + */ + bootp_id = ((u32)net_ethaddr[2] << 24) + | ((u32)net_ethaddr[3] << 16) + | ((u32)net_ethaddr[4] << 8) + | (u32)net_ethaddr[5]; + bootp_id += get_timer(0); + bootp_id = htonl(bootp_id); + bootp_add_id(bootp_id); + net_copy_u32(&bp->bp_id, &bootp_id); + } else { + net_copy_u32(&bp->bp_id, &bootp_id); + }
/* * Calculate proper packet lengths taking into account the
The new config option BOOTP_RANDOM_XID will randomize the transaction ID for each new BOOT/DHCPv4 exchange.
Signed-off-by: Sean Edmond seanedmond@microsoft.com Reviewed-by: Tom Rini trini@konsulko.com
(no changes since v5)
Changes in v5: - fix depends for BOOTP_RANDOM_XID: "depends on CMD_BOOTP && (LIB_RAND || LIB_HW_RAND)"
Changes in v3: - Add depends for BOOTP_RANDOM_XID
cmd/Kconfig | 7 +++++++ net/bootp.c | 31 +++++++++++++++++-------------- 2 files changed, 24 insertions(+), 14 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 54c4ab8570c..82f6a089586 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1909,6 +1909,13 @@ config BOOTP_VCI_STRING default "U-Boot.arm" if ARM default "U-Boot"
+config BOOTP_RANDOM_XID + bool "Send random transaction ID to BOOTP/DHCP server" + depends on CMD_BOOTP && (LIB_RAND || LIB_HW_RAND) + help + Selecting this will allow for a random transaction ID to get + selected for each BOOTP/DHCPv4 exchange. + if CMD_DHCP6
config DHCP6_PXE_CLIENTARCH diff --git a/net/bootp.c b/net/bootp.c index c34ffe27854..285fcba7348 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -834,22 +834,25 @@ void bootp_request(void)
/* Only generate a new transaction ID for each new BOOTP request */ if (bootp_try == 1) { - /* - * Bootp ID is the lower 4 bytes of our ethernet address - * plus the current time in ms. - */ - bootp_id = ((u32)net_ethaddr[2] << 24) - | ((u32)net_ethaddr[3] << 16) - | ((u32)net_ethaddr[4] << 8) - | (u32)net_ethaddr[5]; - bootp_id += get_timer(0); - bootp_id = htonl(bootp_id); - bootp_add_id(bootp_id); - net_copy_u32(&bp->bp_id, &bootp_id); - } else { - net_copy_u32(&bp->bp_id, &bootp_id); + if (IS_ENABLED(CONFIG_BOOTP_RANDOM_XID)) { + srand(get_ticks() + rand()); + bootp_id = rand(); + } else { + /* + * Bootp ID is the lower 4 bytes of our ethernet address + * plus the current time in ms. + */ + bootp_id = ((u32)net_ethaddr[2] << 24) + | ((u32)net_ethaddr[3] << 16) + | ((u32)net_ethaddr[4] << 8) + | (u32)net_ethaddr[5]; + bootp_id += get_timer(0); + bootp_id = htonl(bootp_id); + } }
+ bootp_add_id(bootp_id); + net_copy_u32(&bp->bp_id, &bootp_id); /* * Calculate proper packet lengths taking into account the * variable size of the options field
Sean Edmond
