[U-Boot] [PATCH v2] PQ2FADS: Enable PCI.
PCI on PQ2FADS is very similar to PCI on MPC8272ADS.
Signed-off-by: Scott Wood scottwood@freescale.com --- Removed an inadvertent change to an 8272ads ifdef.
cpu/mpc8260/pci.c | 2 ++ include/configs/MPC8260ADS.h | 17 +++++++++++++---- 2 files changed, 15 insertions(+), 4 deletions(-)
diff --git a/cpu/mpc8260/pci.c b/cpu/mpc8260/pci.c index f1e9bb4..6a14ba4 100644 --- a/cpu/mpc8260/pci.c +++ b/cpu/mpc8260/pci.c @@ -258,6 +258,8 @@ void pci_mpc8250_init (struct pci_controller *hose) immap->im_siu_conf.sc_siumcr = (immap->im_siu_conf.sc_siumcr & ~SIUMCR_LBPC11) | SIUMCR_LBPC01; +#elif defined(CONFIG_ADSTYPE) && CONFIG_ADSTYPE == CONFIG_SYS_PQ2FADS +/* nothing to do for this board here */ #elif defined CONFIG_MPC8272 immap->im_siu_conf.sc_siumcr = (immap->im_siu_conf.sc_siumcr & ~SIUMCR_BBD & diff --git a/include/configs/MPC8260ADS.h b/include/configs/MPC8260ADS.h index 21210eb..c75fbb4 100644 --- a/include/configs/MPC8260ADS.h +++ b/include/configs/MPC8260ADS.h @@ -69,6 +69,13 @@
#if CONFIG_ADSTYPE == CONFIG_SYS_8272ADS #define CONFIG_MPC8272 1 +#elif CONFIG_ADSTYPE == CONFIG_SYS_PQ2FADS +/* + * Actually MPC8275, but the code is littered with ifdefs that + * apply to both, or which use this ifdef to assume board-specific + * details. :-( + */ +#define CONFIG_MPC8272 1 #else #define CONFIG_MPC8260 1 #endif /* CONFIG_ADSTYPE == CONFIG_SYS_8272ADS */ @@ -178,7 +185,7 @@ #endif /* CONFIG_ADSTYPE >= CONFIG_SYS_PQ2FADS */
/*PCI*/ -#ifdef CONFIG_MPC8272 +#if CONFIG_ADSTYPE >= CONFIG_SYS_PQ2FADS #define CONFIG_PCI #define CONFIG_PCI_PNP #define CONFIG_PCI_BOOTDELAY 0 @@ -246,7 +253,6 @@ #elif CONFIG_ADSTYPE >= CONFIG_SYS_PQ2FADS #undef CONFIG_CMD_SDRAM #undef CONFIG_CMD_I2C - #undef CONFIG_CMD_PCI
#else #undef CONFIG_CMD_PCI @@ -320,7 +326,7 @@
#define CONFIG_SYS_IMMR 0xF0000000 #define CONFIG_SYS_BCSR 0xF4500000 -#if CONFIG_ADSTYPE == CONFIG_SYS_8272ADS +#if CONFIG_ADSTYPE >= CONFIG_SYS_PQ2FADS #define CONFIG_SYS_PCI_INT 0xF8200000 #endif #define CONFIG_SYS_SDRAM_BASE 0x00000000 @@ -415,6 +421,9 @@ #if CONFIG_ADSTYPE == CONFIG_SYS_8272ADS #define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_PCI_INT | 0x1801) /* PCI interrupt controller */ #define CONFIG_SYS_OR3_PRELIM 0xFFFF8010 +#elif CONFIG_ADSTYPE == CONFIG_SYS_PQ2FADS +#define CONFIG_SYS_BR8_PRELIM (CONFIG_SYS_PCI_INT | 0x1801) /* PCI interrupt controller */ +#define CONFIG_SYS_OR8_PRELIM 0xFFFF8010 #endif
#define CONFIG_SYS_RMR RMR_CSRE @@ -449,7 +458,7 @@
#define CONFIG_SYS_RESET_ADDRESS 0x04400000
/* PCI Memory map (if different from default map */ #define CONFIG_SYS_PCI_SLV_MEM_LOCAL CONFIG_SYS_SDRAM_BASE /* Local base */
Dear Scott Wood,
Applied, thanks.
Scott Wood
