[PATCH 1/1] doc: add partition API to HTML documentation
* Convert comments in part.h to Sphinx style. * Create documentation page for the partition API. * Add the partition API page to the API index page.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- doc/api/index.rst | 1 + doc/api/part.rst | 6 ++ include/part.h | 210 ++++++++++++++++++++++++---------------------- 3 files changed, 119 insertions(+), 98 deletions(-) create mode 100644 doc/api/part.rst
diff --git a/doc/api/index.rst b/doc/api/index.rst index a9338cfef9..3a80ae0635 100644 --- a/doc/api/index.rst +++ b/doc/api/index.rst @@ -15,6 +15,7 @@ U-Boot API documentation lmb logging nvmem + part pinctrl rng sandbox diff --git a/doc/api/part.rst b/doc/api/part.rst new file mode 100644 index 0000000000..d1df1d8494 --- /dev/null +++ b/doc/api/part.rst @@ -0,0 +1,6 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Partition API +============= + +.. kernel-doc:: include/part.h diff --git a/include/part.h b/include/part.h index edc46f8dcb..8e451bbdff 100644 --- a/include/part.h +++ b/include/part.h @@ -98,8 +98,8 @@ struct disk_part { * @ifname: Interface name (e.g. "ide", "scsi") * @dev: Device number (0 for first device on that interface, 1 for * second, etc. - * Return: pointer to the block device, or NULL if not available, or an - * error occurred. + * Return: + * pointer to the block device, or NULL if not available, or an error occurred. */ struct blk_desc *blk_get_dev(const char *ifname, int dev);
@@ -128,6 +128,10 @@ int part_get_info(struct blk_desc *dev_desc, int part, /** * part_get_info_whole_disk() - get partition info for the special case of * a partition occupying the entire disk. + * + * @dev_desc: block device descriptor + * @info: returned partition information + * Return: 0 on success */ int part_get_info_whole_disk(struct blk_desc *dev_desc, struct disk_partition *info); @@ -170,15 +174,18 @@ int blk_get_device_by_str(const char *ifname, const char *dev_str, * This calls blk_get_device_by_str() to look up a device. It also looks up * a partition and returns information about it. * - * @dev_part_str is in the format: - * <dev>.<hw_part>:<part> where <dev> is the device number, - * <hw_part> is the optional hardware partition number and - * <part> is the partition number + * @dev_part_str is in the format <dev>.<hw_part>:<part> where + * + * * <dev> is the device number, + * + * * <hw_part> is the optional hardware partition number and * - * If ifname is "hostfs" then this function returns the sandbox host block + * * <part> is the partition number. + * + * If @ifname is "hostfs", then this function returns the sandbox host block * device. * - * If ifname is ubi, then this function returns 0, with @info set to a + * If @ifname is "ubi", then this function returns 0, with @info set to a * special UBI device. * * If @dev_part_str is NULL or empty or "-", then this function looks up @@ -187,13 +194,13 @@ int blk_get_device_by_str(const char *ifname, const char *dev_str, * If the partition string is empty then the first partition is used. If the * partition string is "auto" then the first bootable partition is used. * - * @ifname: Interface name (e.g. "ide", "scsi") + * @ifname: Interface name (e.g. "ide", "scsi") * @dev_part_str: Device and partition string - * @dev_desc: Returns a pointer to the block device on success - * @info: Returns partition information + * @dev_desc: Returns a pointer to the block device on success + * @info: Returns partition information * @allow_whole_dev: true to allow the user to select partition 0 - * (which means the whole device), false to require a valid - * partition number >= 1 + * (which means the whole device), false to require a valid + * partition number >= 1 * Return: partition number, or -1 on error * */ @@ -205,18 +212,20 @@ int blk_get_device_part_str(const char *ifname, const char *dev_part_str, * part_get_info_by_name() - Search for a partition by name * among all available registered partitions * - * @param dev_desc - block device descriptor - * @param gpt_name - the specified table entry name - * @param info - returns the disk partition info + * @dev_desc: block device descriptor + * @name: the specified table entry name + * @info: returns the disk partition info * - * Return: - the partition number on match (starting on 1), -1 on no match, + * Return: the partition number on match (starting on 1), -1 on no match, * otherwise error */ int part_get_info_by_name(struct blk_desc *dev_desc, const char *name, struct disk_partition *info);
/** - * Get partition info from dev number + part name, or dev number + part number. + * part_get_info_by_dev_and_name_or_num() - Get partition info from dev number + * and part name, or dev number and + * part number. * * Parse a device number and partition description (either name or number) * in the form of device number plus partition name separated by a "#" @@ -225,14 +234,14 @@ int part_get_info_by_name(struct blk_desc *dev_desc, * partition descriptions for a given interface. If the partition is found, sets * dev_desc and part_info accordingly with the information of the partition. * - * @param[in] dev_iface Device interface - * @param[in] dev_part_str Input partition description, like "0#misc" or "0:1" - * @param[out] dev_desc Place to store the device description pointer - * @param[out] part_info Place to store the partition information - * @param[in] allow_whole_dev true to allow the user to select partition 0 - * (which means the whole device), false to require a valid - * partition number >= 1 - * Return: the partition number on success, or negative errno on error + * @dev_iface: Device interface + * @dev_part_str: Input partition description, like "0#misc" or "0:1" + * @dev_desc: Place to store the device description pointer + * @part_info: Place to store the partition information + * @allow_whole_dev: true to allow the user to select partition 0 + * (which means the whole device), false to require a valid + * partition number >= 1 + * Return: the partition number on success, or negative errno on error */ int part_get_info_by_dev_and_name_or_num(const char *dev_iface, const char *dev_part_str, @@ -322,7 +331,7 @@ int part_create_block_devices(struct udevice *blk_dev); * @start: Start block number to read in the partition (0=first) * @blkcnt: Number of blocks to read * @buffer: Destination buffer for data read - * Returns: number of blocks read, or -ve error number (see the + * Return: number of blocks read, or -ve error number (see the * IS_ERR_VALUE() macro */ ulong disk_blk_read(struct udevice *dev, lbaint_t start, lbaint_t blkcnt, @@ -335,7 +344,7 @@ ulong disk_blk_read(struct udevice *dev, lbaint_t start, lbaint_t blkcnt, * @start: Start block number to write in the partition (0=first) * @blkcnt: Number of blocks to write * @buffer: Source buffer for data to write - * Returns: number of blocks written, or -ve error number (see the + * Return: number of blocks written, or -ve error number (see the * IS_ERR_VALUE() macro */ ulong disk_blk_write(struct udevice *dev, lbaint_t start, lbaint_t blkcnt, @@ -347,7 +356,7 @@ ulong disk_blk_write(struct udevice *dev, lbaint_t start, lbaint_t blkcnt, * @dev: Device to (partially) erase (UCLASS_PARTITION) * @start: Start block number to erase in the partition (0=first) * @blkcnt: Number of blocks to erase - * Returns: number of blocks erased, or -ve error number (see the + * Return: number of blocks erased, or -ve error number (see the * IS_ERR_VALUE() macro */ ulong disk_blk_erase(struct udevice *dev, lbaint_t start, lbaint_t blkcnt); @@ -369,35 +378,40 @@ ulong disk_blk_erase(struct udevice *dev, lbaint_t start, lbaint_t blkcnt); #define part_get_info_ptr(x) x #endif
- +/** + * struct part_driver - partition driver + */ struct part_driver { + /** @name: partition name */ const char *name; + /** @part_type: (MBR) partition type */ int part_type; - const int max_entries; /* maximum number of entries to search */ - + /** @max_entries: maximum number of partition table entries */ + const int max_entries; /** - * get_info() - Get information about a partition + * @get_info: Get information about a partition * - * @dev_desc: Block device descriptor - * @part: Partition number (1 = first) - * @info: Returns partition information + * @get_info.dev_desc: Block device descriptor + * @get_info.part: Partition number (1 = first) + * @get_info.info: Returns partition information */ int (*get_info)(struct blk_desc *dev_desc, int part, struct disk_partition *info);
/** - * print() - Print partition information + * @print: Print partition information * - * @dev_desc: Block device descriptor + * @print.dev_desc: Block device descriptor */ void (*print)(struct blk_desc *dev_desc);
/** - * test() - Test if a device contains this partition type + * @test: Test if a device contains this partition type * - * @dev_desc: Block device descriptor - * @return 0 if the block device appears to contain this partition - * type, -ve if not + * @test.dev_desc: Block device descriptor + * @test.Return: + * 0 if the block device appears to contain this partition type, + * -ve if not */ int (*test)(struct blk_desc *dev_desc); }; @@ -413,52 +427,52 @@ struct part_driver { /** * write_gpt_table() - Write the GUID Partition Table to disk * - * @param dev_desc - block device descriptor - * @param gpt_h - pointer to GPT header representation - * @param gpt_e - pointer to GPT partition table entries + * @dev_desc: block device descriptor + * @gpt_h: pointer to GPT header representation + * @gpt_e: pointer to GPT partition table entries * - * Return: - zero on success, otherwise error + * Return: zero on success, otherwise error */ int write_gpt_table(struct blk_desc *dev_desc, gpt_header *gpt_h, gpt_entry *gpt_e);
/** - * gpt_fill_pte(): Fill the GPT partition table entry + * gpt_fill_pte() - Fill the GPT partition table entry * - * @param dev_desc - block device descriptor - * @param gpt_h - GPT header representation - * @param gpt_e - GPT partition table entries - * @param partitions - list of partitions - * @param parts - number of partitions + * @dev_desc: block device descriptor + * @gpt_h: GPT header representation + * @gpt_e: GPT partition table entries + * @partitions: list of partitions + * @parts: number of partitions * - * Return: zero on success + * Return: zero on success */ int gpt_fill_pte(struct blk_desc *dev_desc, gpt_header *gpt_h, gpt_entry *gpt_e, struct disk_partition *partitions, int parts);
/** - * gpt_fill_header(): Fill the GPT header + * gpt_fill_header() - Fill the GPT header * - * @param dev_desc - block device descriptor - * @param gpt_h - GPT header representation - * @param str_guid - disk guid string representation - * @param parts_count - number of partitions + * @dev_desc: block device descriptor + * @gpt_h: GPT header representation + * @str_guid: disk guid string representation + * @parts_count: number of partitions * - * Return: - error on str_guid conversion error + * Return: error on str_guid conversion error */ int gpt_fill_header(struct blk_desc *dev_desc, gpt_header *gpt_h, char *str_guid, int parts_count);
/** - * gpt_restore(): Restore GPT partition table + * gpt_restore() - Restore GPT partition table * - * @param dev_desc - block device descriptor - * @param str_disk_guid - disk GUID - * @param partitions - list of partitions - * @param parts - number of partitions + * @dev_desc: block device descriptor + * @str_disk_guid: disk GUID + * @partitions: list of partitions + * @parts_count: number of partitions * - * Return: zero on success + * Return: 0 on success */ int gpt_restore(struct blk_desc *dev_desc, char *str_disk_guid, struct disk_partition *partitions, const int parts_count); @@ -466,34 +480,34 @@ int gpt_restore(struct blk_desc *dev_desc, char *str_disk_guid, /** * is_valid_gpt_buf() - Ensure that the Primary GPT information is valid * - * @param dev_desc - block device descriptor - * @param buf - buffer which contains the MBR and Primary GPT info + * @dev_desc: block device descriptor + * @buf: buffer which contains the MBR and Primary GPT info * - * Return: - '0' on success, otherwise error + * Return: 0 on success, otherwise error */ int is_valid_gpt_buf(struct blk_desc *dev_desc, void *buf);
/** * write_mbr_and_gpt_partitions() - write MBR, Primary GPT and Backup GPT * - * @param dev_desc - block device descriptor - * @param buf - buffer which contains the MBR and Primary GPT info + * @dev_desc: block device descriptor + * @buf: buffer which contains the MBR and Primary GPT info * - * Return: - '0' on success, otherwise error + * Return: 0 on success, otherwise error */ int write_mbr_and_gpt_partitions(struct blk_desc *dev_desc, void *buf);
/** - * gpt_verify_headers() - Function to read and CRC32 check of the GPT's header + * gpt_verify_headers() - Read and check CRC32 of the GPT's header * and partition table entries (PTE) * * As a side effect if sets gpt_head and gpt_pte so they point to GPT data. * - * @param dev_desc - block device descriptor - * @param gpt_head - pointer to GPT header data read from medium - * @param gpt_pte - pointer to GPT partition table enties read from medium + * @dev_desc: block device descriptor + * @gpt_head: pointer to GPT header data read from medium + * @gpt_pte: pointer to GPT partition table enties read from medium * - * Return: - '0' on success, otherwise error + * Return: 0 on success, otherwise error */ int gpt_verify_headers(struct blk_desc *dev_desc, gpt_header *gpt_head, gpt_entry **gpt_pte); @@ -502,9 +516,9 @@ int gpt_verify_headers(struct blk_desc *dev_desc, gpt_header *gpt_head, * gpt_repair_headers() - Function to repair the GPT's header * and partition table entries (PTE) * - * @param dev_desc - block device descriptor + * @dev_desc: block device descriptor * - * Return: - '0' on success, otherwise error + * Return: 0 on success, otherwise error */ int gpt_repair_headers(struct blk_desc *dev_desc);
@@ -516,13 +530,13 @@ int gpt_repair_headers(struct blk_desc *dev_desc); * provided in '$partitions' environment variable. Specificially, name, start * and size of the partition is checked. * - * @param dev_desc - block device descriptor - * @param partitions - partition data read from '$partitions' env variable - * @param parts - number of partitions read from '$partitions' env variable - * @param gpt_head - pointer to GPT header data read from medium - * @param gpt_pte - pointer to GPT partition table enties read from medium + * @dev_desc: block device descriptor + * @partitions: partition data read from '$partitions' env variable + * @parts: number of partitions read from '$partitions' env variable + * @gpt_head: pointer to GPT header data read from medium + * @gpt_pte: pointer to GPT partition table enties read from medium * - * Return: - '0' on success, otherwise error + * Return: 0 on success, otherwise error */ int gpt_verify_partitions(struct blk_desc *dev_desc, struct disk_partition *partitions, int parts, @@ -530,15 +544,15 @@ int gpt_verify_partitions(struct blk_desc *dev_desc,
/** - * get_disk_guid() - Function to read the GUID string from a device's GPT + * get_disk_guid() - Read the GUID string from a device's GPT * * This function reads the GUID string from a block device whose descriptor * is provided. * - * @param dev_desc - block device descriptor - * @param guid - pre-allocated string in which to return the GUID + * @dev_desc: block device descriptor + * @guid: pre-allocated string in which to return the GUID * - * Return: - '0' on success, otherwise error + * Return: 0 on success, otherwise error */ int get_disk_guid(struct blk_desc *dev_desc, char *guid);
@@ -548,19 +562,19 @@ int get_disk_guid(struct blk_desc *dev_desc, char *guid); /** * is_valid_dos_buf() - Ensure that a DOS MBR image is valid * - * @param buf - buffer which contains the MBR + * @buf: buffer which contains the MBR * - * Return: - '0' on success, otherwise error + * Return: 0 on success, otherwise error */ int is_valid_dos_buf(void *buf);
/** * write_mbr_sector() - write DOS MBR * - * @param dev_desc - block device descriptor - * @param buf - buffer which contains the MBR + * @dev_desc: block device descriptor + * @buf: buffer which contains the MBR * - * Return: - '0' on success, otherwise error + * Return: 0 on success, otherwise error */ int write_mbr_sector(struct blk_desc *dev_desc, void *buf);
@@ -575,7 +589,7 @@ int layout_mbr_partitions(struct disk_partition *p, int count, /** * part_driver_get_count() - get partition driver count * - * Return: - number of partition drivers + * Return: number of partition drivers */ static inline int part_driver_get_count(void) { @@ -585,7 +599,7 @@ static inline int part_driver_get_count(void) /** * part_driver_get_first() - get first partition driver * - * Return: - pointer to first partition driver on success, otherwise NULL + * Return: pointer to first partition driver on success, otherwise NULL */ static inline struct part_driver *part_driver_get_first(void) { @@ -595,9 +609,9 @@ static inline struct part_driver *part_driver_get_first(void) /** * part_get_type_by_name() - Get partition type by name * - * @name: Name of partition type to look up (not case-sensitive) - * Returns: Corresponding partition type (PART_TYPE_...) or PART_TYPE_UNKNOWN if - * not known + * @name: Name of partition type to look up (not case-sensitive) + * Return: + * Corresponding partition type (PART_TYPE_...) or PART_TYPE_UNKNOWN */ int part_get_type_by_name(const char *name);
Hi Heinrich,
On Tue, 15 Aug 2023 at 04:32, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
- Convert comments in part.h to Sphinx style.
- Create documentation page for the partition API.
- Add the partition API page to the API index page.
Q below
- part pinctrl rng sandbox
+Partition API +============= +[..]
- struct part_driver - partition driver
Are we not allowed the () at end? I much prefer brackets as they show it is a function.
On 8/15/23 16:44, Simon Glass wrote:
Hi Heinrich,
Q below
- */ struct part_driver {
Thanks for reviewing.
'make htmldocs' does not like parentheses here:
Incorrect use of kernel-doc format: * @get_info(): Get ... Incorrect use of kernel-doc format: * @get_info() - Get ...
We are using code from the kernel.org. We would have to change that upstream first:
scripts/kernel-doc:2325: print STDERR "Incorrect use of kernel-doc format: $_";
Best regards
Heinrich
Hi Heinrich,
On Tue, 15 Aug 2023 at 09:18, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Q below
- @get_info(): Get ...
- @get_info() - Get ...
OK thank you, I will send an mail about it.
Do you think you could base your part on [1], since I changed the same file? It is available at u-boot-dm/methb-working
[1] https://patchwork.ozlabs.org/project/uboot/list/?series=368613
