[U-Boot] [PATCH 1/1] efi_selftest: reduce noise in test output for device trees
Some messages are only useful if an error occurs. Fix a use after free. Add a missing free.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/efi_selftest_devicepath.c | 23 +++++++++++++---------- 1 file changed, 13 insertions(+), 10 deletions(-)
diff --git a/lib/efi_selftest/efi_selftest_devicepath.c b/lib/efi_selftest/efi_selftest_devicepath.c index 2f8f3c7f15..92940c7ab6 100644 --- a/lib/efi_selftest/efi_selftest_devicepath.c +++ b/lib/efi_selftest/efi_selftest_devicepath.c @@ -319,7 +319,6 @@ static int execute(void) efi_st_error("FreePool failed\n"); return EFI_ST_FAILURE; } - efi_st_printf("\n");
/* Test ConvertDevicePathToText */ string = device_path_to_text->convert_device_path_to_text( @@ -328,15 +327,14 @@ static int execute(void) efi_st_error("ConvertDevicePathToText failed\n"); return EFI_ST_FAILURE; } - efi_st_printf("dp2: %ps\n", string); if (efi_st_strcmp_16_8( string, "/VenHw(dbca4c98-6cb0-694d-0872-819c650cbbb1)/VenHw(dbca4c98-6cb0-694d-0872-819c650cbba2)") ) { + efi_st_printf("dp2: %ps\n", string); efi_st_error("Incorrect text from ConvertDevicePathToText\n"); return EFI_ST_FAILURE; } - ret = boottime->free_pool(string); if (ret != EFI_SUCCESS) { efi_st_error("FreePool failed\n"); @@ -350,17 +348,17 @@ static int execute(void) efi_st_error("ConvertDeviceNodeToText failed\n"); return EFI_ST_FAILURE; } - efi_st_printf("dp_node: %ps\n", string); - ret = boottime->free_pool(string); - if (ret != EFI_SUCCESS) { - efi_st_error("FreePool failed\n"); - return EFI_ST_FAILURE; - } if (efi_st_strcmp_16_8(string, "u-boot")) { + efi_st_printf("dp_node: %ps\n", string); efi_st_error( "Incorrect conversion by ConvertDeviceNodeToText\n"); return EFI_ST_FAILURE; } + ret = boottime->free_pool(string); + if (ret != EFI_SUCCESS) { + efi_st_error("FreePool failed\n"); + return EFI_ST_FAILURE; + }
/* Test LocateDevicePath */ remaining_dp = (struct efi_device_path *)dp3; @@ -380,13 +378,18 @@ static int execute(void) efi_st_error("ConvertDevicePathToText failed\n"); return EFI_ST_FAILURE; } - efi_st_printf("remaining device path: %ps\n", string); if (efi_st_strcmp_16_8(string, "/VenHw(dbca4c98-6cb0-694d-0872-819c650cbbc3)") ) { + efi_st_printf("remaining device path: %ps\n", string); efi_st_error("LocateDevicePath: wrong remaining device path\n"); return EFI_ST_FAILURE; } + ret = boottime->free_pool(string); + if (ret != EFI_SUCCESS) { + efi_st_error("FreePool failed\n"); + return EFI_ST_FAILURE; + }
return EFI_ST_SUCCESS; }
