[U-Boot] [PATCH v5 0/7] toradex: config block handling
This series integrates Toradex factory configuration block handling. The config block is a data structure which gets stored to flash during production testing. The structure holds such information as board resp. hardware revision, product ID and serial number which is used as the NIC part of the Ethernet MAC address as well. The config block will be read upon boot by the show_board_info() function, displayed as part of the board information and passed to Linux via device tree or ATAGs.
Changes in v5: - get rid of choice for config block location as it causes issues due to Kconfig multi sourcing (which BTW is not my invention as I simply copied TI's way of doing that for their common stuff) and anyway does not make much sense
Changes in v4: - add various peoples acked- resp. reviewed-bys with which it now hopefully could be pulled in ASAP
Changes in v3: - introduce new patch dropping unused CONFIG_CUSTOM_BOARDINFO by reverting commit a9ad18c9d5fe2554753b0f9a52adfd5ebce61147 - introduce new patch making show_board_info() a weak function which allows for custom board specific implementations thereof - fixup deactivation of CONFIG_DISPLAY_BOARDINFO in favour of CONFIG_DISPLAY_BOARDINFO_LATE which also displays on the LCD after recent move thereof to Kconfig - use custom show_board_info() rather than checkboard() and checkboard() rather than checkboard_fallback() - also reword commit message accordingly - use checkboard() rather than checkboard_fallback() - drop CUSTOM_BOARDINFO - drop patch 1 'colibri_imx7/vf: move to custom checkboard_fallback()' in favour of Stefan's proposed solution
Changes in v2: - fixed common.h include mess in board/toradex/common by renaming common* to tdx-common - renamed TRDX to TDX and trdx to tdx as in common use internally - consolidated makefiles and changed copyright message - renamed configblock* to tdx-cfg-block* analogous to Kconfig symbols - moved board/toradex/common/Kconfig sourcing from arch/arm/Kconfig into our own board Kconfig files - use a named choice for the config block location for above to work without issuing any warnings (undocumented kbuild feature curtsey Arnaud Lacombe) - added CUSTOM_BOARDINFO into our common Kconfig to avoid recent no_new_adhoc_configs_check error - add Max' patch colibri_vf: usb gadget: toradex pid is now set generically
Marcel Ziswiler (6): Revert "generic-board: allow showing custom board info" generic-board: make show_board_info a weak function apalis/colibri_t20/t30: deactivate displaying board info toradex: config block handling apalis/colibri_imx7/pxa270/t20/t30/vf: integrate config block handling apalis/colibri_t30: move environment location
Max Krummenacher (1): colibri_vf: usb gadget: toradex pid is now set generically
board/toradex/apalis_t30/Kconfig | 18 + board/toradex/apalis_t30/apalis_t30.c | 12 +- board/toradex/colibri_imx7/Kconfig | 16 + board/toradex/colibri_pxa270/Kconfig | 11 + board/toradex/colibri_pxa270/colibri_pxa270.c | 8 + board/toradex/colibri_t20/Kconfig | 11 + board/toradex/colibri_t20/colibri_t20.c | 13 + board/toradex/colibri_t30/Kconfig | 18 + board/toradex/colibri_t30/colibri_t30.c | 9 +- board/toradex/colibri_vf/Kconfig | 14 + board/toradex/colibri_vf/colibri_vf.c | 16 - board/toradex/common/Kconfig | 69 ++++ board/toradex/common/Makefile | 11 + board/toradex/common/tdx-cfg-block.c | 544 ++++++++++++++++++++++++++ board/toradex/common/tdx-cfg-block.h | 68 ++++ board/toradex/common/tdx-common.c | 168 ++++++++ board/toradex/common/tdx-common.h | 13 + common/board_info.c | 4 +- configs/apalis_t30_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/colibri_vf_defconfig | 1 + include/configs/apalis_t30.h | 11 +- include/configs/colibri_imx7.h | 6 +- include/configs/colibri_pxa270.h | 6 +- include/configs/colibri_t20.h | 2 +- include/configs/colibri_t30.h | 11 +- include/configs/colibri_vf.h | 13 +- scripts/config_whitelist.txt | 5 - 29 files changed, 1034 insertions(+), 47 deletions(-) create mode 100644 board/toradex/common/Kconfig create mode 100644 board/toradex/common/Makefile create mode 100644 board/toradex/common/tdx-cfg-block.c create mode 100644 board/toradex/common/tdx-cfg-block.h create mode 100644 board/toradex/common/tdx-common.c create mode 100644 board/toradex/common/tdx-common.h
Drop CONFIG_CUSTOM_BOARDINFO as it is not Kconfig compliant and anyway not really used anywhere plus the upcoming weak show_board_info() approach seems much superior.
This reverts commit a9ad18c9d5fe2554753b0f9a52adfd5ebce61147.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Tom Rini trini@konsulko.com Acked-by: Max Krummenacher max.krummenacher@toradex.com
Changes in v5: None Changes in v4: None Changes in v3: - introduce new patch dropping unused CONFIG_CUSTOM_BOARDINFO by reverting commit a9ad18c9d5fe2554753b0f9a52adfd5ebce61147
Changes in v2: None
common/board_info.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/board_info.c b/common/board_info.c index bd5dcfa..6afe98e 100644 --- a/common/board_info.c +++ b/common/board_info.c @@ -17,7 +17,7 @@ int __weak checkboard(void) */ int show_board_info(void) { -#if defined(CONFIG_OF_CONTROL) && !defined(CONFIG_CUSTOM_BOARDINFO) +#ifdef CONFIG_OF_CONTROL DECLARE_GLOBAL_DATA_PTR; const char *model;
Make show_board_info() a weak function which allows for custom board specific implementations thereof.
Changes in v5: None Changes in v4: None Changes in v3: - introduce new patch making show_board_info() a weak function which allows for custom board specific implementations thereof
Changes in v2: None
diff --git a/common/board_info.c b/common/board_info.c index 6afe98e..aa45e24 100644 --- a/common/board_info.c +++ b/common/board_info.c @@ -15,7 +15,7 @@ int __weak checkboard(void) * If the root node of the DTB has a "model" property, show it. * Then call checkboard(). */ -int show_board_info(void) +int __weak show_board_info(void) { #ifdef CONFIG_OF_CONTROL DECLARE_GLOBAL_DATA_PTR;
Deactivate CONFIG_DISPLAY_BOARDINFO in favour of CONFIG_DISPLAY_BOARDINFO_LATE which also displays on the LCD.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Acked-by: Max Krummenacher max.krummenacher@toradex.com
Changes in v5: None Changes in v4: None Changes in v3: - fixup deactivation of CONFIG_DISPLAY_BOARDINFO in favour of CONFIG_DISPLAY_BOARDINFO_LATE which also displays on the LCD after recent move thereof to Kconfig
Changes in v2: None
configs/apalis_t30_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + 3 files changed, 3 insertions(+)
diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 640c9ce..0ac2fe6 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra30-apalis" CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y +# CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Apalis T30 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 5f95e3e..fa56a75 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_COLIBRI_T20=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-colibri" CONFIG_OF_SYSTEM_SETUP=y CONFIG_SYS_STDIO_DEREGISTER=y +# CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri T20 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index de00afe..cb24627 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra30-colibri" CONFIG_OF_SYSTEM_SETUP=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_STDIO_DEREGISTER=y +# CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri T30 # " CONFIG_CMD_BOOTZ=y
Add Toradex factory configuration block handling. The config block is a data structure which gets stored to flash during production testing. The structure holds such information as board resp. hardware revision, product ID and serial number which is used as the NIC part of the Ethernet MAC address as well. The config block will be read upon boot by the show_board_info() function, displayed as part of the board information and passed to Linux via device tree or ATAGs.
Changes in v4: None Changes in v3: - use custom show_board_info() rather than checkboard() and checkboard() rather than checkboard_fallback() - also reword commit message accordingly
Changes in v2: None
board/toradex/common/Kconfig | 69 +++++ board/toradex/common/Makefile | 11 + board/toradex/common/tdx-cfg-block.c | 544 +++++++++++++++++++++++++++++++++++ board/toradex/common/tdx-cfg-block.h | 68 +++++ board/toradex/common/tdx-common.c | 168 +++++++++++ board/toradex/common/tdx-common.h | 13 + 6 files changed, 873 insertions(+) create mode 100644 board/toradex/common/Kconfig create mode 100644 board/toradex/common/Makefile create mode 100644 board/toradex/common/tdx-cfg-block.c create mode 100644 board/toradex/common/tdx-cfg-block.h create mode 100644 board/toradex/common/tdx-common.c create mode 100644 board/toradex/common/tdx-common.h
diff --git a/board/toradex/common/Kconfig b/board/toradex/common/Kconfig new file mode 100644 index 0000000..b33baef --- /dev/null +++ b/board/toradex/common/Kconfig @@ -0,0 +1,69 @@ +# Copyright (c) 2016 Toradex, Inc. +# SPDX-License-Identifier: GPL-2.0+ + +menuconfig TDX_CFG_BLOCK + bool "Enable Toradex config block support" + select OF_BOARD_SETUP + help + The Toradex config block stored production data on the on-module + flash device (NAND, NOR or eMMC). The area is normally preserved by + software and contains the serial number (out of which the MAC + address is generated) and the exact module type. + +# Helper config to determine the correct default location of the cfg block +config TDX_HAVE_MMC + bool + +config TDX_HAVE_NAND + bool + +config TDX_HAVE_NOR + bool + +if TDX_CFG_BLOCK + +config TDX_CFG_BLOCK_IS_IN_MMC + bool + depends on TDX_HAVE_MMC + default y + +config TDX_CFG_BLOCK_IS_IN_NAND + bool + depends on TDX_HAVE_NAND + default y + +config TDX_CFG_BLOCK_IS_IN_NOR + bool + depends on TDX_HAVE_NOR + default y + +config TDX_CFG_BLOCK_DEV + int "Toradex config block eMMC device ID" + depends on TDX_CFG_BLOCK_IS_IN_MMC + +config TDX_CFG_BLOCK_PART + int "Toradex config block eMMC partition ID" + depends on TDX_CFG_BLOCK_IS_IN_MMC + +config TDX_CFG_BLOCK_OFFSET + int "Toradex config block offset" + help + Specify the byte offset of the Toradex config block within the flash + device the config block is stored on. + +config TDX_CFG_BLOCK_OFFSET2 + int "Toradex config block offset, second instance" + default 0 + help + Specify the byte offset of the 2nd instance of the Toradex config block + within the flash device the config block is stored on. + Set to 0 on modules which have no 2nd instance. + +config TDX_CFG_BLOCK_2ND_ETHADDR + bool "Set the second Ethernet address" + help + For each serial number two Ethernet addresses are available for dual + Ethernet carrier boards. This options enables the code to set the + second Ethernet address as environment variable (eth1addr). + +endif diff --git a/board/toradex/common/Makefile b/board/toradex/common/Makefile new file mode 100644 index 0000000..d645f5a --- /dev/null +++ b/board/toradex/common/Makefile @@ -0,0 +1,11 @@ +# Copyright (c) 2016 Toradex, Inc. +# SPDX-License-Identifier: GPL-2.0+ + +# Common for all Toradex modules +ifeq ($(CONFIG_SPL_BUILD),y) +# Necessary to create built-in.o +obj- := __dummy__.o +else +obj-$(CONFIG_TDX_CFG_BLOCK) += tdx-cfg-block.o +obj-y += tdx-common.o +endif diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c new file mode 100644 index 0000000..0014ce8 --- /dev/null +++ b/board/toradex/common/tdx-cfg-block.c @@ -0,0 +1,544 @@ +/* + * Copyright (c) 2016 Toradex, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include "tdx-cfg-block.h" + +#if defined(CONFIG_TARGET_APALIS_IMX6) || defined(CONFIG_TARGET_COLIBRI_IMX6) +#include <asm/arch/sys_proto.h> +#else +#define is_cpu_type(cpu) (0) +#endif +#if defined(CONFIG_CPU_PXA27X) +#include <asm/arch-pxa/pxa.h> +#else +#define cpu_is_pxa27x(cpu) (0) +#endif +#include <cli.h> +#include <console.h> +#include <flash.h> +#include <malloc.h> +#include <mmc.h> +#include <nand.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define TAG_VALID 0xcf01 +#define TAG_MAC 0x0000 +#define TAG_HW 0x0008 +#define TAG_INVALID 0xffff + +#define TAG_FLAG_VALID 0x1 + +#if defined(CONFIG_TDX_CFG_BLOCK_IS_IN_MMC) +#define TDX_CFG_BLOCK_MAX_SIZE 512 +#elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NAND) +#define TDX_CFG_BLOCK_MAX_SIZE 64 +#elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NOR) +#define TDX_CFG_BLOCK_MAX_SIZE 64 +#else +#error Toradex config block location not set +#endif + +struct toradex_tag { + u32 len:14; + u32 flags:2; + u32 id:16; +}; + +bool valid_cfgblock; +struct toradex_hw tdx_hw_tag; +struct toradex_eth_addr tdx_eth_addr; +u32 tdx_serial; + +const char * const toradex_modules[] = { + [0] = "UNKNOWN MODULE", + [1] = "Colibri PXA270 312MHz", + [2] = "Colibri PXA270 520MHz", + [3] = "Colibri PXA320 806MHz", + [4] = "Colibri PXA300 208MHz", + [5] = "Colibri PXA310 624MHz", + [6] = "Colibri PXA320 806MHz IT", + [7] = "Colibri PXA300 208MHz XT", + [8] = "Colibri PXA270 312MHz", + [9] = "Colibri PXA270 520MHz", + [10] = "Colibri VF50 128MB", /* not currently on sale */ + [11] = "Colibri VF61 256MB", + [12] = "Colibri VF61 256MB IT", + [13] = "Colibri VF50 128MB IT", + [14] = "Colibri iMX6 Solo 256MB", + [15] = "Colibri iMX6 DualLite 512MB", + [16] = "Colibri iMX6 Solo 256MB IT", + [17] = "Colibri iMX6 DualLite 512MB IT", + [18] = "UNKNOWN MODULE", + [19] = "UNKNOWN MODULE", + [20] = "Colibri T20 256MB", + [21] = "Colibri T20 512MB", + [22] = "Colibri T20 512MB IT", + [23] = "Colibri T30 1GB", + [24] = "Colibri T20 256MB IT", + [25] = "Apalis T30 2GB", + [26] = "Apalis T30 1GB", + [27] = "Apalis iMX6 Quad 1GB", + [28] = "Apalis iMX6 Quad 2GB IT", + [29] = "Apalis iMX6 Dual 512MB", + [30] = "Colibri T30 1GB IT", + [31] = "Apalis T30 1GB IT", + [32] = "Colibri iMX7 Solo 256MB", + [33] = "Colibri iMX7 Dual 512MB", + [34] = "Apalis TK1 2GB", + [35] = "Apalis iMX6 Dual 1GB IT", +}; + +#ifdef CONFIG_TDX_CFG_BLOCK_IS_IN_MMC +static int tdx_cfg_block_mmc_storage(u8 *config_block, int write) +{ + struct mmc *mmc; + int dev = CONFIG_TDX_CFG_BLOCK_DEV; + int offset = CONFIG_TDX_CFG_BLOCK_OFFSET; + uint part = CONFIG_TDX_CFG_BLOCK_PART; + uint blk_start; + int ret = 0; + + /* Read production parameter config block from eMMC */ + mmc = find_mmc_device(dev); + if (!mmc) { + puts("No MMC card found\n"); + ret = -ENODEV; + goto out; + } + if (part != mmc->block_dev.hwpart) { + if (blk_select_hwpart_devnum(IF_TYPE_MMC, dev, part)) { + puts("MMC partition switch failed\n"); + ret = -ENODEV; + goto out; + } + } + if (offset < 0) + offset += mmc->capacity; + blk_start = ALIGN(offset, mmc->write_bl_len) / mmc->write_bl_len; + + if (!write) { + /* Careful reads a whole block of 512 bytes into config_block */ + if (blk_dread(mmc_get_blk_desc(mmc), blk_start, 1, + (unsigned char *)config_block) != 1) { + ret = -EIO; + goto out; + } + /* Flush cache after read */ + flush_cache((ulong)(unsigned char *)config_block, 512); + } else { + /* Just writing one 512 byte block */ + if (blk_dwrite(mmc_get_blk_desc(mmc), blk_start, 1, + (unsigned char *)config_block) != 1) { + ret = -EIO; + goto out; + } + } + +out: + /* Switch back to regular eMMC user partition */ + blk_select_hwpart_devnum(IF_TYPE_MMC, 0, 0); + + return ret; +} +#endif + +#ifdef CONFIG_TDX_CFG_BLOCK_IS_IN_NAND +static int read_tdx_cfg_block_from_nand(unsigned char *config_block) +{ + size_t size = TDX_CFG_BLOCK_MAX_SIZE; + + /* Read production parameter config block from NAND page */ + return nand_read_skip_bad(nand_info[0], CONFIG_TDX_CFG_BLOCK_OFFSET, + &size, NULL, TDX_CFG_BLOCK_MAX_SIZE, config_block); +} + +static int write_tdx_cfg_block_to_nand(unsigned char *config_block) +{ + size_t size = TDX_CFG_BLOCK_MAX_SIZE; + + /* Write production parameter config block to NAND page */ + return nand_write_skip_bad(nand_info[0], CONFIG_TDX_CFG_BLOCK_OFFSET, + &size, NULL, TDX_CFG_BLOCK_MAX_SIZE, + config_block, WITH_WR_VERIFY); +} +#endif + +#ifdef CONFIG_TDX_CFG_BLOCK_IS_IN_NOR +static int read_tdx_cfg_block_from_nor(unsigned char *config_block) +{ + /* Read production parameter config block from NOR flash */ + memcpy(config_block, (void *)CONFIG_TDX_CFG_BLOCK_OFFSET, + TDX_CFG_BLOCK_MAX_SIZE); + return 0; +} + +static int write_tdx_cfg_block_to_nor(unsigned char *config_block) +{ + /* Write production parameter config block to NOR flash */ + return flash_write((void *)config_block, CONFIG_TDX_CFG_BLOCK_OFFSET, + TDX_CFG_BLOCK_MAX_SIZE); +} +#endif + +int read_tdx_cfg_block(void) +{ + int ret = 0; + u8 *config_block = NULL; + struct toradex_tag *tag; + size_t size = TDX_CFG_BLOCK_MAX_SIZE; + int offset; + + /* Allocate RAM area for config block */ + config_block = memalign(ARCH_DMA_MINALIGN, size); + if (!config_block) { + printf("Not enough malloc space available!\n"); + return -ENOMEM; + } + + memset(config_block, 0, size); + +#if defined(CONFIG_TDX_CFG_BLOCK_IS_IN_MMC) + ret = tdx_cfg_block_mmc_storage(config_block, 0); +#elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NAND) + ret = read_tdx_cfg_block_from_nand(config_block); +#elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NOR) + ret = read_tdx_cfg_block_from_nor(config_block); +#else + ret = -EINVAL; +#endif + if (ret) + goto out; + + /* Expect a valid tag first */ + tag = (struct toradex_tag *)config_block; + if (tag->flags != TAG_FLAG_VALID || tag->id != TAG_VALID) { + valid_cfgblock = false; + ret = -EINVAL; + goto out; + } + valid_cfgblock = true; + offset = 4; + + while (offset < TDX_CFG_BLOCK_MAX_SIZE) { + tag = (struct toradex_tag *)(config_block + offset); + offset += 4; + if (tag->id == TAG_INVALID) + break; + + if (tag->flags == TAG_FLAG_VALID) { + switch (tag->id) { + case TAG_MAC: + memcpy(&tdx_eth_addr, config_block + offset, + 6); + + /* NIC part of MAC address is serial number */ + tdx_serial = ntohl(tdx_eth_addr.nic) >> 8; + break; + case TAG_HW: + memcpy(&tdx_hw_tag, config_block + offset, 8); + break; + } + } + + /* Get to next tag according to current tags length */ + offset += tag->len * 4; + } + + /* Cap product id to avoid issues with a yet unknown one */ + if (tdx_hw_tag.prodid > (sizeof(toradex_modules) / + sizeof(toradex_modules[0]))) + tdx_hw_tag.prodid = 0; + +out: + free(config_block); + return ret; +} + +static int get_cfgblock_interactive(void) +{ + char message[CONFIG_SYS_CBSIZE]; + char *soc; + char it = 'n'; + int len; + + if (cpu_is_pxa27x()) + sprintf(message, "Is the module the 312 MHz version? [y/N] "); + else + sprintf(message, "Is the module an IT version? [y/N] "); + + len = cli_readline(message); + it = console_buffer[0]; + + soc = getenv("soc"); + if (!strcmp("mx6", soc)) { +#ifdef CONFIG_MACH_TYPE + if (it == 'y' || it == 'Y') + if (is_cpu_type(MXC_CPU_MX6Q)) + tdx_hw_tag.prodid = APALIS_IMX6Q_IT; + else + tdx_hw_tag.prodid = APALIS_IMX6D_IT; + else + if (is_cpu_type(MXC_CPU_MX6Q)) + tdx_hw_tag.prodid = APALIS_IMX6Q; + else + tdx_hw_tag.prodid = APALIS_IMX6D; +#else + if (it == 'y' || it == 'Y') + if (is_cpu_type(MXC_CPU_MX6DL)) + tdx_hw_tag.prodid = COLIBRI_IMX6DL_IT; + else + tdx_hw_tag.prodid = COLIBRI_IMX6S_IT; + else + if (is_cpu_type(MXC_CPU_MX6DL)) + tdx_hw_tag.prodid = COLIBRI_IMX6DL; + else + tdx_hw_tag.prodid = COLIBRI_IMX6S; +#endif /* CONFIG_MACH_TYPE */ + } else if (!strcmp("imx7d", soc)) { + tdx_hw_tag.prodid = COLIBRI_IMX7D; + } else if (!strcmp("imx7s", soc)) { + tdx_hw_tag.prodid = COLIBRI_IMX7S; + } else if (!strcmp("tegra20", soc)) { + if (it == 'y' || it == 'Y') + if (gd->ram_size == 0x10000000) + tdx_hw_tag.prodid = COLIBRI_T20_256MB_IT; + else + tdx_hw_tag.prodid = COLIBRI_T20_512MB_IT; + else + if (gd->ram_size == 0x10000000) + tdx_hw_tag.prodid = COLIBRI_T20_256MB; + else + tdx_hw_tag.prodid = COLIBRI_T20_512MB; + } else if (cpu_is_pxa27x()) { + if (it == 'y' || it == 'Y') + tdx_hw_tag.prodid = COLIBRI_PXA270_312MHZ; + else + tdx_hw_tag.prodid = COLIBRI_PXA270_520MHZ; +#ifdef CONFIG_MACH_TYPE + } else if (!strcmp("tegra30", soc)) { + if (CONFIG_MACH_TYPE == MACH_TYPE_APALIS_T30) { + if (it == 'y' || it == 'Y') + tdx_hw_tag.prodid = APALIS_T30_IT; + else + if (gd->ram_size == 0x40000000) + tdx_hw_tag.prodid = APALIS_T30_1GB; + else + tdx_hw_tag.prodid = APALIS_T30_2GB; + } else { + if (it == 'y' || it == 'Y') + tdx_hw_tag.prodid = COLIBRI_T30_IT; + else + tdx_hw_tag.prodid = COLIBRI_T30; + } +#endif /* CONFIG_MACH_TYPE */ + } else if (!strcmp("tegra124", soc)) { + tdx_hw_tag.prodid = APALIS_TK1_2GB; + } else if (!strcmp("vf500", soc)) { + if (it == 'y' || it == 'Y') + tdx_hw_tag.prodid = COLIBRI_VF50_IT; + else + tdx_hw_tag.prodid = COLIBRI_VF50; + } else if (!strcmp("vf610", soc)) { + if (it == 'y' || it == 'Y') + tdx_hw_tag.prodid = COLIBRI_VF61_IT; + else + tdx_hw_tag.prodid = COLIBRI_VF61; + } else { + printf("Module type not detectable due to unknown SoC\n"); + return -1; + } + + while (len < 4) { + sprintf(message, "Enter the module version (e.g. V1.1B): V"); + len = cli_readline(message); + } + + tdx_hw_tag.ver_major = console_buffer[0] - '0'; + tdx_hw_tag.ver_minor = console_buffer[2] - '0'; + tdx_hw_tag.ver_assembly = console_buffer[3] - 'A'; + + if (cpu_is_pxa27x() && (tdx_hw_tag.ver_major == 1)) + tdx_hw_tag.prodid -= (COLIBRI_PXA270_312MHZ - + COLIBRI_PXA270_V1_312MHZ); + + while (len < 8) { + sprintf(message, "Enter module serial number: "); + len = cli_readline(message); + } + + tdx_serial = simple_strtoul(console_buffer, NULL, 10); + + return 0; +} + +static int get_cfgblock_barcode(char *barcode) +{ + if (strlen(barcode) < 16) { + printf("Argument too short, barcode is 16 chars long\n"); + return -1; + } + + /* Get hardware information from the first 8 digits */ + tdx_hw_tag.ver_major = barcode[4] - '0'; + tdx_hw_tag.ver_minor = barcode[5] - '0'; + tdx_hw_tag.ver_assembly = barcode[7] - '0'; + + barcode[4] = '\0'; + tdx_hw_tag.prodid = simple_strtoul(barcode, NULL, 10); + + /* Parse second part of the barcode (serial number */ + barcode += 8; + tdx_serial = simple_strtoul(barcode, NULL, 10); + + return 0; +} + +static int do_cfgblock_create(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + u8 *config_block; + struct toradex_tag *tag; + size_t size = TDX_CFG_BLOCK_MAX_SIZE; + int offset = 0; + int ret = CMD_RET_SUCCESS; + int err; + + /* Allocate RAM area for config block */ + config_block = memalign(ARCH_DMA_MINALIGN, size); + if (!config_block) { + printf("Not enough malloc space available!\n"); + return CMD_RET_FAILURE; + } + + memset(config_block, 0xff, size); + + read_tdx_cfg_block(); + if (valid_cfgblock) { +#if defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NAND) + /* + * On NAND devices, recreation is only allowed if the page is + * empty (config block invalid...) + */ + printf("NAND erase block %d need to be erased before creating a Toradex config block\n", + CONFIG_TDX_CFG_BLOCK_OFFSET / nand_info[0]->erasesize); + goto out; +#elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NOR) + /* + * On NOR devices, recreation is only allowed if the sector is + * empty and write protection is off (config block invalid...) + */ + printf("NOR sector at offset 0x%02x need to be erased and unprotected before creating a Toradex config block\n", + CONFIG_TDX_CFG_BLOCK_OFFSET); + goto out; +#else + char message[CONFIG_SYS_CBSIZE]; + sprintf(message, + "A valid Toradex config block is present, still recreate? [y/N] "); + + if (!cli_readline(message)) + goto out; + + if (console_buffer[0] != 'y' && console_buffer[0] != 'Y') + goto out; +#endif + } + + /* Parse new Toradex config block data... */ + if (argc < 3) + err = get_cfgblock_interactive(); + else + err = get_cfgblock_barcode(argv[2]); + + if (err) { + ret = CMD_RET_FAILURE; + goto out; + } + + /* Convert serial number to MAC address (the storage format) */ + tdx_eth_addr.oui = htonl(0x00142dUL << 8); + tdx_eth_addr.nic = htonl(tdx_serial << 8); + + /* Valid Tag */ + tag = (struct toradex_tag *)config_block; + tag->id = TAG_VALID; + tag->flags = TAG_FLAG_VALID; + tag->len = 0; + offset += 4; + + /* Product Tag */ + tag = (struct toradex_tag *)(config_block + offset); + tag->id = TAG_HW; + tag->flags = TAG_FLAG_VALID; + tag->len = 2; + offset += 4; + + memcpy(config_block + offset, &tdx_hw_tag, 8); + offset += 8; + + /* MAC Tag */ + tag = (struct toradex_tag *)(config_block + offset); + tag->id = TAG_MAC; + tag->flags = TAG_FLAG_VALID; + tag->len = 2; + offset += 4; + + memcpy(config_block + offset, &tdx_eth_addr, 6); + offset += 6; + memset(config_block + offset, 0, 32 - offset); + +#if defined(CONFIG_TDX_CFG_BLOCK_IS_IN_MMC) + err = tdx_cfg_block_mmc_storage(config_block, 1); +#elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NAND) + err = write_tdx_cfg_block_to_nand(config_block); +#elif defined(CONFIG_TDX_CFG_BLOCK_IS_IN_NOR) + err = write_tdx_cfg_block_to_nor(config_block); +#else + err = -EINVAL; +#endif + if (err) { + printf("Failed to write Toradex config block: %d\n", ret); + ret = CMD_RET_FAILURE; + goto out; + } + + printf("Toradex config block successfully written\n"); + +out: + free(config_block); + return ret; +} + +static int do_cfgblock(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + int ret; + + if (argc < 2) + return CMD_RET_USAGE; + + if (!strcmp(argv[1], "create")) { + return do_cfgblock_create(cmdtp, flag, argc, argv); + } else if (!strcmp(argv[1], "reload")) { + ret = read_tdx_cfg_block(); + if (ret) { + printf("Failed to reload Toradex config block: %d\n", + ret); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; + } + + return CMD_RET_USAGE; +} + +U_BOOT_CMD( + cfgblock, 3, 0, do_cfgblock, + "Toradex config block handling commands", + "create [barcode] - (Re-)create Toradex config block\n" + "cfgblock reload - Reload Toradex config block from flash" +); diff --git a/board/toradex/common/tdx-cfg-block.h b/board/toradex/common/tdx-cfg-block.h new file mode 100644 index 0000000..fd7c362 --- /dev/null +++ b/board/toradex/common/tdx-cfg-block.h @@ -0,0 +1,68 @@ +/* + * Copyright (c) 2016 Toradex, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _TDX_CFG_BLOCK_H +#define _TDX_CFG_BLOCK_H + +#include "tdx-common.h" + +struct toradex_hw { + u16 ver_major; + u16 ver_minor; + u16 ver_assembly; + u16 prodid; +}; + +struct toradex_eth_addr { + u32 oui:24; + u32 nic:24; +} __attribute__((__packed__)); + +enum { + COLIBRI_PXA270_V1_312MHZ = 1, + COLIBRI_PXA270_V1_520MHZ, + COLIBRI_PXA320, + COLIBRI_PXA300, + COLIBRI_PXA310, + COLIBRI_PXA320_IT, + COLIBRI_PXA300_XT, + COLIBRI_PXA270_312MHZ, + COLIBRI_PXA270_520MHZ, + COLIBRI_VF50, /* not currently on sale */ + COLIBRI_VF61, + COLIBRI_VF61_IT, + COLIBRI_VF50_IT, + COLIBRI_IMX6S, + COLIBRI_IMX6DL, + COLIBRI_IMX6S_IT, + COLIBRI_IMX6DL_IT, + COLIBRI_T20_256MB = 20, + COLIBRI_T20_512MB, + COLIBRI_T20_512MB_IT, + COLIBRI_T30, + COLIBRI_T20_256MB_IT, + APALIS_T30_2GB, + APALIS_T30_1GB, + APALIS_IMX6Q, + APALIS_IMX6Q_IT, + APALIS_IMX6D, + COLIBRI_T30_IT, + APALIS_T30_IT, + COLIBRI_IMX7S, + COLIBRI_IMX7D, + APALIS_TK1_2GB, + APALIS_IMX6D_IT, +}; + +extern const char * const toradex_modules[]; +extern bool valid_cfgblock; +extern struct toradex_hw tdx_hw_tag; +extern struct toradex_eth_addr tdx_eth_addr; +extern u32 tdx_serial; + +int read_tdx_cfg_block(void); + +#endif /* _TDX_CFG_BLOCK_H */ diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx-common.c new file mode 100644 index 0000000..f1ab794 --- /dev/null +++ b/board/toradex/common/tdx-common.c @@ -0,0 +1,168 @@ +/* + * Copyright (c) 2016 Toradex, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <g_dnl.h> +#include <libfdt.h> + +#include "tdx-cfg-block.h" +#include "tdx-common.h" + +#ifdef CONFIG_TDX_CFG_BLOCK +static char tdx_serial_str[9]; +static char tdx_board_rev_str[6]; + +#ifdef CONFIG_REVISION_TAG +u32 get_board_rev(void) +{ + /* Check validity */ + if (!tdx_hw_tag.ver_major) + return 0; + + return ((tdx_hw_tag.ver_major & 0xff) << 8) | + ((tdx_hw_tag.ver_minor & 0xf) << 4) | + ((tdx_hw_tag.ver_assembly & 0xf) + 0xa); +} +#endif /* CONFIG_TDX_CFG_BLOCK */ + +#ifdef CONFIG_SERIAL_TAG +void get_board_serial(struct tag_serialnr *serialnr) +{ + int array[8]; + unsigned int serial = tdx_serial; + int i; + + serialnr->low = 0; + serialnr->high = 0; + + /* Check validity */ + if (serial) { + /* + * Convert to Linux serial number format (hexadecimal coded + * decimal) + */ + i = 7; + while (serial) { + array[i--] = serial % 10; + serial /= 10; + } + while (i >= 0) + array[i--] = 0; + serial = array[0]; + for (i = 1; i < 8; i++) { + serial *= 16; + serial += array[i]; + } + + serialnr->low = serial; + } +} +#endif /* CONFIG_SERIAL_TAG */ + +int show_board_info(void) +{ + unsigned char ethaddr[6]; + + if (read_tdx_cfg_block()) { + printf("Missing Toradex config block\n"); + checkboard(); + return 0; + } + + /* board serial-number */ + sprintf(tdx_serial_str, "%08u", tdx_serial); + sprintf(tdx_board_rev_str, "V%1d.%1d%c", + tdx_hw_tag.ver_major, + tdx_hw_tag.ver_minor, + (char)tdx_hw_tag.ver_assembly + 'A'); + + setenv("serial#", tdx_serial_str); + + /* + * Check if environment contains a valid MAC address, + * set the one from config block if not + */ + if (!eth_getenv_enetaddr("ethaddr", ethaddr)) + eth_setenv_enetaddr("ethaddr", (u8 *)&tdx_eth_addr); + +#ifdef CONFIG_TDX_CFG_BLOCK_2ND_ETHADDR + if (!eth_getenv_enetaddr("eth1addr", ethaddr)) { + /* + * Secondary MAC address is allocated from block + * 0x100000 higher then the first MAC address + */ + memcpy(ethaddr, &tdx_eth_addr, 6); + ethaddr[3] += 0x10; + eth_setenv_enetaddr("eth1addr", ethaddr); + } +#endif + + printf("Model: Toradex %s %s, Serial# %s\n", + toradex_modules[tdx_hw_tag.prodid], + tdx_board_rev_str, + tdx_serial_str); + + return 0; +} + +#ifdef CONFIG_USBDOWNLOAD_GADGET +int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) +{ + unsigned short usb_pid; + + usb_pid = TORADEX_USB_PRODUCT_NUM_OFFSET + tdx_hw_tag.prodid; + put_unaligned(usb_pid, &dev->idProduct); + + return 0; +} +#endif /* CONFIG_USBDOWNLOAD_GADGET */ + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ + if (tdx_serial) { + fdt_setprop(blob, 0, "serial-number", tdx_serial_str, + strlen(tdx_serial_str) + 1); + } + + if (tdx_hw_tag.ver_major) { + char prod_id[5]; + + sprintf(prod_id, "%04u", tdx_hw_tag.prodid); + fdt_setprop(blob, 0, "toradex,product-id", prod_id, 5); + + fdt_setprop(blob, 0, "toradex,board-rev", tdx_board_rev_str, + strlen(tdx_board_rev_str) + 1); + } + + return 0; +} +#endif + +#else /* CONFIG_TDX_CFG_BLOCK */ + +#ifdef CONFIG_REVISION_TAG +u32 get_board_rev(void) +{ + return 0; +} +#endif /* CONFIG_REVISION_TAG */ + +#ifdef CONFIG_SERIAL_TAG +u32 get_board_serial(void) +{ + return 0; +} +#endif /* CONFIG_SERIAL_TAG */ + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ + return 0; +} +#endif + +#endif /* CONFIG_TDX_CFG_BLOCK */ diff --git a/board/toradex/common/tdx-common.h b/board/toradex/common/tdx-common.h new file mode 100644 index 0000000..f308ebd --- /dev/null +++ b/board/toradex/common/tdx-common.h @@ -0,0 +1,13 @@ +/* + * Copyright (c) 2016 Toradex, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _TDX_COMMON_H +#define _TDX_COMMON_H + +#define TORADEX_USB_PRODUCT_NUM_OFFSET 0x4000 +#define TDX_USB_VID 0x1B67 + +#endif /* _TDX_COMMON_H */
With our common code in place actually make use of it across all our modules.
Changes in v5: None Changes in v4: None Changes in v3: - use checkboard() rather than checkboard_fallback() - drop CUSTOM_BOARDINFO
Changes in v2: None
board/toradex/apalis_t30/Kconfig | 18 ++++++++++++++++++ board/toradex/apalis_t30/apalis_t30.c | 12 +++++++++++- board/toradex/colibri_imx7/Kconfig | 16 ++++++++++++++++ board/toradex/colibri_pxa270/Kconfig | 11 +++++++++++ board/toradex/colibri_pxa270/colibri_pxa270.c | 8 ++++++++ board/toradex/colibri_t20/Kconfig | 11 +++++++++++ board/toradex/colibri_t20/colibri_t20.c | 13 +++++++++++++ board/toradex/colibri_t30/Kconfig | 18 ++++++++++++++++++ board/toradex/colibri_t30/colibri_t30.c | 9 ++++++++- board/toradex/colibri_vf/Kconfig | 14 ++++++++++++++ configs/colibri_vf_defconfig | 1 + include/configs/apalis_t30.h | 4 ++-- include/configs/colibri_imx7.h | 6 +++++- include/configs/colibri_pxa270.h | 6 +++++- include/configs/colibri_t20.h | 2 +- include/configs/colibri_t30.h | 4 ++-- include/configs/colibri_vf.h | 6 ++++-- 17 files changed, 148 insertions(+), 11 deletions(-)
diff --git a/board/toradex/apalis_t30/Kconfig b/board/toradex/apalis_t30/Kconfig index f1dcda5..16224da 100644 --- a/board/toradex/apalis_t30/Kconfig +++ b/board/toradex/apalis_t30/Kconfig @@ -9,4 +9,22 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "apalis_t30"
+config TDX_CFG_BLOCK + default y + +config TDX_HAVE_MMC + default y + +config TDX_CFG_BLOCK_DEV + default "0" + +config TDX_CFG_BLOCK_PART + default "1" + +# Toradex config block in eMMC, at the end of 1st "boot sector" +config TDX_CFG_BLOCK_OFFSET + default "-512" + +source "board/toradex/common/Kconfig" + endif diff --git a/board/toradex/apalis_t30/apalis_t30.c b/board/toradex/apalis_t30/apalis_t30.c index 3f56971..3d83491 100644 --- a/board/toradex/apalis_t30/apalis_t30.c +++ b/board/toradex/apalis_t30/apalis_t30.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2014 + * (C) Copyright 2014-2016 * Marcel Ziswiler marcel@ziswiler.com * * SPDX-License-Identifier: GPL-2.0+ @@ -17,6 +17,8 @@
#include "pinmux-config-apalis_t30.h"
+DECLARE_GLOBAL_DATA_PTR; + #define PMU_I2C_ADDRESS 0x2D #define MAX_I2C_RETRY 3
@@ -29,6 +31,14 @@ int arch_misc_init(void) return 0; }
+int checkboard(void) +{ + printf("Model: Toradex Apalis T30 %dGB\n", + (gd->ram_size == 0x40000000) ? 1 : 2); + + return 0; +} + /* * Routine: pinmux_init * Description: Do individual peripheral pinmux configs diff --git a/board/toradex/colibri_imx7/Kconfig b/board/toradex/colibri_imx7/Kconfig index 7bba26b..414a600 100644 --- a/board/toradex/colibri_imx7/Kconfig +++ b/board/toradex/colibri_imx7/Kconfig @@ -16,5 +16,21 @@ config COLIBRI_IMX7_EXT_PHYCLK clock source. default y
+config TDX_CFG_BLOCK + default y + +config TDX_HAVE_NAND + default y + +config TDX_CFG_BLOCK_OFFSET + default "2048" + +config TDX_CFG_BLOCK_OFFSET2 + default "133120" + +config TDX_CFG_BLOCK_2ND_ETHADDR + default y + +source "board/toradex/common/Kconfig"
endif diff --git a/board/toradex/colibri_pxa270/Kconfig b/board/toradex/colibri_pxa270/Kconfig index 949407a..f646baa 100644 --- a/board/toradex/colibri_pxa270/Kconfig +++ b/board/toradex/colibri_pxa270/Kconfig @@ -9,4 +9,15 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "colibri_pxa270"
+config TDX_CFG_BLOCK + default y + +config TDX_HAVE_NOR + default y + +config TDX_CFG_BLOCK_OFFSET + default "262144" + +source "board/toradex/common/Kconfig" + endif diff --git a/board/toradex/colibri_pxa270/colibri_pxa270.c b/board/toradex/colibri_pxa270/colibri_pxa270.c index 3def0a6..de8cb28 100644 --- a/board/toradex/colibri_pxa270/colibri_pxa270.c +++ b/board/toradex/colibri_pxa270/colibri_pxa270.c @@ -2,6 +2,7 @@ * Toradex Colibri PXA270 Support * * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * Copyright (C) 2016 Marcel Ziswiler marcel.ziswiler@toradex.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -32,6 +33,13 @@ int board_init(void) return 0; }
+int checkboard(void) +{ + puts("Model: Toradex Colibri PXA270\n"); + + return 0; +} + int dram_init(void) { pxa2xx_dram_init(); diff --git a/board/toradex/colibri_t20/Kconfig b/board/toradex/colibri_t20/Kconfig index 7f373b2..a43acdd 100644 --- a/board/toradex/colibri_t20/Kconfig +++ b/board/toradex/colibri_t20/Kconfig @@ -9,4 +9,15 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "colibri_t20"
+config TDX_CFG_BLOCK + default y + +config TDX_HAVE_NAND + default y + +config TDX_CFG_BLOCK_OFFSET + default "3145728" + +source "board/toradex/common/Kconfig" + endif diff --git a/board/toradex/colibri_t20/colibri_t20.c b/board/toradex/colibri_t20/colibri_t20.c index 68fbf49..01b55be 100644 --- a/board/toradex/colibri_t20/colibri_t20.c +++ b/board/toradex/colibri_t20/colibri_t20.c @@ -14,6 +14,9 @@ #include <asm/gpio.h> #include <asm/io.h> #include <i2c.h> +#include <nand.h> + +DECLARE_GLOBAL_DATA_PTR;
#define PMU_I2C_ADDRESS 0x34 #define MAX_I2C_RETRY 3 @@ -61,6 +64,16 @@ int arch_misc_init(void) return 0; }
+int checkboard(void) +{ + printf("Model: Toradex Colibri T20 %dMB V%s\n", + (gd->ram_size == 0x10000000) ? 256 : 512, + (nand_info[0]->erasesize >> 10 == 512) ? + ((gd->ram_size == 0x10000000) ? "1.1B" : "1.1C") : "1.2A"); + + return 0; +} + #ifdef CONFIG_TEGRA_MMC /* * Routine: pin_mux_mmc diff --git a/board/toradex/colibri_t30/Kconfig b/board/toradex/colibri_t30/Kconfig index 3e436a2..68ef82b 100644 --- a/board/toradex/colibri_t30/Kconfig +++ b/board/toradex/colibri_t30/Kconfig @@ -9,4 +9,22 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "colibri_t30"
+config TDX_CFG_BLOCK + default y + +config TDX_HAVE_MMC + default y + +config TDX_CFG_BLOCK_DEV + default "0" + +config TDX_CFG_BLOCK_PART + default "1" + +# Toradex config block in eMMC, at the end of 1st "boot sector" +config TDX_CFG_BLOCK_OFFSET + default "-512" + +source "board/toradex/common/Kconfig" + endif diff --git a/board/toradex/colibri_t30/colibri_t30.c b/board/toradex/colibri_t30/colibri_t30.c index e32362a..707d07e 100644 --- a/board/toradex/colibri_t30/colibri_t30.c +++ b/board/toradex/colibri_t30/colibri_t30.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2014 + * (C) Copyright 2014-2016 * Stefan Agner stefan@agner.ch * * SPDX-License-Identifier: GPL-2.0+ @@ -24,6 +24,13 @@ int arch_misc_init(void) return 0; }
+int checkboard(void) +{ + puts("Model: Toradex Colibri T30 1GB\n"); + + return 0; +} + /* * Routine: pinmux_init * Description: Do individual peripheral pinmux configs diff --git a/board/toradex/colibri_vf/Kconfig b/board/toradex/colibri_vf/Kconfig index 2c3cb30..bf9bb01 100644 --- a/board/toradex/colibri_vf/Kconfig +++ b/board/toradex/colibri_vf/Kconfig @@ -15,4 +15,18 @@ config SYS_SOC config SYS_CONFIG_NAME default "colibri_vf"
+config TDX_CFG_BLOCK + default y + +config TDX_HAVE_NAND + default y + +config TDX_CFG_BLOCK_OFFSET + default "2048" + +config TDX_CFG_BLOCK_2ND_ETHADDR + default y + +source "board/toradex/common/Kconfig" + endif diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 1020e44..54d3581 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -4,6 +4,7 @@ CONFIG_DEFAULT_DEVICE_TREE="vf610-colibri" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_vf/imximage.cfg,ENV_IS_IN_NAND,IMX_NAND" CONFIG_BOOTDELAY=1 CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri VFxx # " CONFIG_CMD_BOOTZ=y diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index d38302d..069ed20 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -1,5 +1,5 @@ /* - * Copyright (c) 2014-2015 Marcel Ziswiler + * Copyright (c) 2014-2016 Marcel Ziswiler * * Configuration settings for the Toradex Apalis T30 modules. * @@ -16,7 +16,7 @@ #define CONFIG_ARCH_MISC_INIT
/* High-level configuration options */ -#define CONFIG_TEGRA_BOARD_STRING "Toradex Apalis T30" +#define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */
/* Board-specific serial config */ #define CONFIG_TEGRA_ENABLE_UARTA diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 309aef8..5ce0a34 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -21,10 +21,14 @@ /*#define CONFIG_DBG_MONITOR*/ #define PHYS_SDRAM_SIZE SZ_512M
+#define CONFIG_ARCH_MISC_INIT #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_LATE_INIT
-#define CONFIG_DISPLAY_BOARDINFO_LATE +#define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */ + +#define CONFIG_ENV_VARS_UBOOT_CONFIG +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (32 * SZ_1M) diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index e44a847..b15ed72 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -2,7 +2,7 @@ * Toradex Colibri PXA270 configuration file * * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com - * Copyright (C) 2015 Marcel Ziswiler marcel@ziswiler.com + * Copyright (C) 2015-2016 Marcel Ziswiler marcel@ziswiler.com * * SPDX-License-Identifier: GPL-2.0+ */ @@ -21,10 +21,14 @@ /* We will never enable dcache because we have to setup MMU first */ #define CONFIG_SYS_DCACHE_OFF
+#define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */ + /* * Environment settings */ #define CONFIG_ENV_OVERWRITE +#define CONFIG_ENV_VARS_UBOOT_CONFIG +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_SYS_MALLOC_LEN (128 * 1024) #define CONFIG_ARCH_CPU_INIT #define CONFIG_BOOTCOMMAND \ diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index 4634989..6a52869 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -14,7 +14,7 @@ #define CONFIG_ARCH_MISC_INIT
/* High-level configuration options */ -#define CONFIG_TEGRA_BOARD_STRING "Toradex Colibri T20" +#define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */
/* Board-specific serial config */ #define CONFIG_TEGRA_ENABLE_UARTA diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index e2a2549..1ab5c41 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -1,5 +1,5 @@ /* - * Copyright (c) 2013-2015 Stefan Agner + * Copyright (c) 2013-2016 Stefan Agner * * Configuration settings for the Toradex Colibri T30 modules. * @@ -16,7 +16,7 @@ #define CONFIG_ARCH_MISC_INIT
/* High-level configuration options */ -#define CONFIG_TEGRA_BOARD_STRING "Toradex Colibri T30" +#define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */
/* Board-specific serial config */ #define CONFIG_TEGRA_ENABLE_UARTA diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index be773a3..0e622fb 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -1,7 +1,7 @@ /* - * Copyright 2015 Toradex, Inc. + * Copyright 2015-2016 Toradex, Inc. * - * Configuration settings for the Toradex VF50/VF61 module. + * Configuration settings for the Toradex VF50/VF61 modules. * * Based on vf610twr.h: * Copyright 2013 Freescale Semiconductor, Inc. @@ -21,6 +21,7 @@ #define CONFIG_SYS_FSL_CLK
#define CONFIG_ARCH_MISC_INIT +#define CONFIG_DISPLAY_BOARDINFO_LATE /* Calls show_board_info() */
#define CONFIG_SKIP_LOWLEVEL_INIT
@@ -36,6 +37,7 @@
/* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE +#define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_BAUDRATE 115200
Now with the config block handling in place move the U-Boot environment location before the config block at the end of 1st "boot sector" as deployed during production using our downstream BSP.
Changes in v5: None Changes in v4: - add various peoples acked- resp. reviewed-bys with which it now hopefully could be pulled in ASAP
Changes in v3: - drop patch 1 'colibri_imx7/vf: move to custom checkboard_fallback()' in favour of Stefan's proposed solution
include/configs/apalis_t30.h | 7 ++++--- include/configs/colibri_t30.h | 7 ++++--- 2 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index 069ed20..f2a24c1 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -32,11 +32,12 @@ #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC
-/* Environment in eMMC, at the end of 2nd "boot sector" */ +/* Environment in eMMC, before config block at the end of 1st "boot sector" */ #define CONFIG_ENV_IS_IN_MMC -#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) +#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ + CONFIG_TDX_CFG_BLOCK_OFFSET) #define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_SYS_MMC_ENV_PART 2 +#define CONFIG_SYS_MMC_ENV_PART 1
/* USB host support */ #define CONFIG_USB_EHCI diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index 1ab5c41..e8b3f99 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -32,11 +32,12 @@ #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC
From: Max Krummenacher max.krummenacher@toradex.com
remove now unused CONFIG_TRDX_PID_XXX
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Acked-by: Stefan Agner stefan.agner@toradex.com Acked-by: Max Krummenacher max.krummenacher@toradex.com ---
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
board/toradex/colibri_vf/colibri_vf.c | 16 ---------------- include/configs/colibri_vf.h | 7 ------- scripts/config_whitelist.txt | 5 ----- 3 files changed, 28 deletions(-)
diff --git a/board/toradex/colibri_vf/colibri_vf.c b/board/toradex/colibri_vf/colibri_vf.c index c65ccb3..e65d9c3 100644 --- a/board/toradex/colibri_vf/colibri_vf.c +++ b/board/toradex/colibri_vf/colibri_vf.c @@ -528,22 +528,6 @@ int checkboard(void) return 0; }
-int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) -{ - unsigned short usb_pid; - - put_unaligned(CONFIG_TRDX_VID, &dev->idVendor); - - if (is_colibri_vf61()) - usb_pid = CONFIG_TRDX_PID_COLIBRI_VF61IT; - else - usb_pid = CONFIG_TRDX_PID_COLIBRI_VF50IT; - - put_unaligned(usb_pid, &dev->idProduct); - - return 0; -} - #ifdef CONFIG_USB_EHCI_VF int board_ehci_hcd_init(int port) { diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 0e622fb..0cd77ff 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -208,13 +208,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_EHCI_HCD_INIT_AFTER_RESET
-/* USB Client Support */ -#define CONFIG_TRDX_VID 0x1B67 -#define CONFIG_TRDX_PID_COLIBRI_VF50 0x0016 -#define CONFIG_TRDX_PID_COLIBRI_VF61 0x0017 -#define CONFIG_TRDX_PID_COLIBRI_VF61IT 0x0018 -#define CONFIG_TRDX_PID_COLIBRI_VF50IT 0x0019 - /* USB DFU */ #define CONFIG_SYS_DFU_DATA_BUF_SIZE (1024 * 1024)
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d476367..c0571c3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -7985,11 +7985,6 @@ CONFIG_TRACE_EARLY_ADDR CONFIG_TRACE_EARLY_SIZE CONFIG_TRAILBLAZER CONFIG_TRATS -CONFIG_TRDX_PID_COLIBRI_VF50 -CONFIG_TRDX_PID_COLIBRI_VF50IT -CONFIG_TRDX_PID_COLIBRI_VF61 -CONFIG_TRDX_PID_COLIBRI_VF61IT -CONFIG_TRDX_VID CONFIG_TSEC CONFIG_TSEC1 CONFIG_TSEC1_NAME
Marcel Ziswiler
