[U-Boot] [PATCH V2] mx6: add support for el6x board
Custom Board based on MX6 Dual, 1GB RAM and eMMC.
There are two variants of the board with and without PCIe (ZC5202 and ZC5601).
Signed-off-by: Stefano Babic sbabic@denx.de --- Changes V2: - rebase on current master and moved defines to _defconfig
arch/arm/cpu/armv7/mx6/Kconfig | 13 + board/el/el6x/Kconfig | 25 ++ board/el/el6x/MAINTAINERS | 8 + board/el/el6x/Makefile | 7 + board/el/el6x/el6x.c | 640 +++++++++++++++++++++++++++++++++++++++++ configs/zc5202_defconfig | 22 ++ configs/zc5601_defconfig | 22 ++ include/configs/el6x_common.h | 139 +++++++++ include/configs/zc5202.h | 37 +++ include/configs/zc5601.h | 33 +++ 10 files changed, 946 insertions(+) create mode 100644 board/el/el6x/Kconfig create mode 100644 board/el/el6x/MAINTAINERS create mode 100644 board/el/el6x/Makefile create mode 100644 board/el/el6x/el6x.c create mode 100644 configs/zc5202_defconfig create mode 100644 configs/zc5601_defconfig create mode 100644 include/configs/el6x_common.h create mode 100644 include/configs/zc5202.h create mode 100644 include/configs/zc5601.h
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 663f970..01117ab 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -178,6 +178,18 @@ config TARGET_XPRESS select DM_THERMAL select SUPPORT_SPL
+config TARGET_ZC5202 + bool "zc5202" + select SUPPORT_SPL + select DM + select DM_THERMAL + +config TARGET_ZC5601 + bool "zc5601" + select SUPPORT_SPL + select DM + select DM_THERMAL + endchoice
config SYS_SOC @@ -192,6 +204,7 @@ source "board/boundary/nitrogen6x/Kconfig" source "board/ccv/xpress/Kconfig" source "board/compulab/cm_fx6/Kconfig" source "board/congatec/cgtqmx6eval/Kconfig" +source "board/el/el6x/Kconfig" source "board/embest/mx6boards/Kconfig" source "board/freescale/mx6qarm2/Kconfig" source "board/freescale/mx6qsabreauto/Kconfig" diff --git a/board/el/el6x/Kconfig b/board/el/el6x/Kconfig new file mode 100644 index 0000000..aa9bf25 --- /dev/null +++ b/board/el/el6x/Kconfig @@ -0,0 +1,25 @@ +if TARGET_ZC5202 + +config SYS_BOARD + default "el6x" + +config SYS_VENDOR + default "el" + +config SYS_CONFIG_NAME + default "zc5202" + +endif + +if TARGET_ZC5601 + +config SYS_BOARD + default "el6x" + +config SYS_VENDOR + default "el" + +config SYS_CONFIG_NAME + default "zc5601" + +endif diff --git a/board/el/el6x/MAINTAINERS b/board/el/el6x/MAINTAINERS new file mode 100644 index 0000000..9a40010 --- /dev/null +++ b/board/el/el6x/MAINTAINERS @@ -0,0 +1,8 @@ +EL6X BOARD +M: Stefano Babic sbabic@denx.de +S: Maintained +F: board/el/el6x/ +F: include/configs/zc5202.h +F: include/configs/zc5601.h +F: configs/zc5202_defconfig +F: configs/zc5601_defconfig diff --git a/board/el/el6x/Makefile b/board/el/el6x/Makefile new file mode 100644 index 0000000..48d5ad9 --- /dev/null +++ b/board/el/el6x/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) Stefano Babic sbabic@denx.de +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := el6x.o diff --git a/board/el/el6x/el6x.c b/board/el/el6x/el6x.c new file mode 100644 index 0000000..3b0fb32 --- /dev/null +++ b/board/el/el6x/el6x.c @@ -0,0 +1,640 @@ +/* + * Copyright (C) Stefano Babic sbabic@denx.de + * + * Based on other i.MX6 boards + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/video.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/arch/mxc_hdmi.h> +#include <asm/arch/crm_regs.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> +#include <asm/arch/mx6-ddr.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define OPEN_PAD_CTRL (PAD_CTL_ODE | PAD_CTL_DSE_DISABLE | (0 << 12)) + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define ENET_PAD_CTRL_PD (PAD_CTL_PUS_100K_DOWN | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define ENET_PAD_CTRL_CLK ((PAD_CTL_PUS_100K_UP & ~PAD_CTL_PKE) | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_FAST) + +#define I2C_PMIC 1 + +#define I2C_PAD MUX_PAD_CTRL(I2C_PAD_CTRL) + +#define ETH_PHY_RESET IMX_GPIO_NR(2, 4) + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + + return 0; +} + +iomux_v3_cfg_t const uart2_pads[] = { + MX6_PAD_SD3_DAT5__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_SD3_DAT4__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); +} + +#ifdef CONFIG_TARGET_ZC5202 +iomux_v3_cfg_t const enet_pads[] = { + MX6_PAD_GPIO_18__ENET_RX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_RXD0__ENET_RX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_RXD1__ENET_RX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_KEY_COL2__ENET_RX_DATA2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_KEY_COL0__ENET_RX_DATA3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_CRS_DV__ENET_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL_CLK), + MX6_PAD_ENET_TXD0__ENET_TX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_TXD1__ENET_TX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_GPIO_19__ENET_TX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_KEY_ROW2__ENET_TX_DATA2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_KEY_ROW0__ENET_TX_DATA3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_TX_EN__ENET_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_RX_ER__ENET_RX_ER | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), + /* Switch Reset */ + MX6_PAD_NANDF_D4__GPIO2_IO04 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), + /* Switch Interrupt */ + MX6_PAD_NANDF_D5__GPIO2_IO05 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* use CRS and COL pads as GPIOs */ + MX6_PAD_KEY_COL3__GPIO4_IO12 | MUX_PAD_CTRL(OPEN_PAD_CTRL), + MX6_PAD_KEY_ROW1__GPIO4_IO09 | MUX_PAD_CTRL(OPEN_PAD_CTRL), + +}; + +#define BOARD_NAME "EL6x-ZC5202" +#else +iomux_v3_cfg_t const enet_pads[] = { + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL_CLK), + MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_NANDF_D4__GPIO2_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D5__GPIO2_IO05 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; +#define BOARD_NAME "EL6x-ZC5601" +#endif + +static void setup_iomux_enet(void) +{ + imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); + +#ifdef CONFIG_TARGET_ZC5202 + /* set CRS and COL to input */ + gpio_direction_input(IMX_GPIO_NR(4, 9)); + gpio_direction_input(IMX_GPIO_NR(4, 12)); + + /* Reset Switch */ + gpio_direction_output(ETH_PHY_RESET , 0); + mdelay(2); + gpio_set_value(ETH_PHY_RESET, 1); +#endif +} + +int board_phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +#ifdef CONFIG_MXC_SPI +#ifdef CONFIG_TARGET_ZC5202 +iomux_v3_cfg_t const ecspi1_pads[] = { + MX6_PAD_DISP0_DAT20__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT21__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT22__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT23__GPIO5_IO17 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_DISP0_DAT15__GPIO5_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +iomux_v3_cfg_t const ecspi3_pads[] = { + MX6_PAD_DISP0_DAT0__ECSPI3_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT2__ECSPI3_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT1__ECSPI3_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT7__GPIO4_IO28 | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT8__GPIO4_IO29 | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT9__GPIO4_IO30 | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT10__GPIO4_IO31 | MUX_PAD_CTRL(SPI_PAD_CTRL), +}; +#endif + +iomux_v3_cfg_t const ecspi4_pads[] = { + MX6_PAD_EIM_D21__ECSPI4_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D28__ECSPI4_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D22__ECSPI4_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D20__GPIO3_IO20 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +int board_spi_cs_gpio(unsigned bus, unsigned cs) +{ + return (bus == CONFIG_SF_DEFAULT_BUS && cs == CONFIG_SF_DEFAULT_CS) + ? (IMX_GPIO_NR(3, 20)) : -1; +} + +static void setup_spi(void) +{ +#ifdef CONFIG_TARGET_ZC5202 + gpio_request(IMX_GPIO_NR(5, 17), "spi_cs0"); + gpio_request(IMX_GPIO_NR(5, 9), "spi_cs1"); + gpio_direction_output(IMX_GPIO_NR(5, 17), 1); + gpio_direction_output(IMX_GPIO_NR(5, 9), 1); + imx_iomux_v3_setup_multiple_pads(ecspi1_pads, ARRAY_SIZE(ecspi1_pads)); +#endif + + gpio_request(IMX_GPIO_NR(3, 20), "spi4_cs0"); + gpio_direction_output(IMX_GPIO_NR(3, 20), 1); + imx_iomux_v3_setup_multiple_pads(ecspi4_pads, ARRAY_SIZE(ecspi4_pads)); + + enable_spi_clk(true, 3); +} +#endif + +static struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX6_PAD_EIM_EB2__I2C2_SCL | I2C_PAD, + .gpio_mode = MX6_PAD_EIM_EB2__GPIO2_IO30 | I2C_PAD, + .gp = IMX_GPIO_NR(2, 30) + }, + .sda = { + .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | I2C_PAD, + .gpio_mode = MX6_PAD_KEY_ROW3__GPIO4_IO13 | I2C_PAD, + .gp = IMX_GPIO_NR(4, 13) + } +}; + +static struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6_PAD_GPIO_5__I2C3_SCL | I2C_PAD, + .gpio_mode = MX6_PAD_GPIO_5__GPIO1_IO05 | I2C_PAD, + .gp = IMX_GPIO_NR(1, 5) + }, + .sda = { + .i2c_mode = MX6_PAD_GPIO_16__I2C3_SDA | I2C_PAD, + .gpio_mode = MX6_PAD_GPIO_16__GPIO7_IO11 | I2C_PAD, + .gp = IMX_GPIO_NR(7, 11) + } +}; + +iomux_v3_cfg_t const usdhc2_pads[] = { + MX6_PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_GPIO_4__SD2_CD_B | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ +}; + +iomux_v3_cfg_t const usdhc4_pads[] = { + MX6_PAD_SD4_CLK__SD4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_CMD__SD4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT0__SD4_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT1__SD4_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT2__SD4_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT3__SD4_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT4__SD4_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT5__SD4_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT6__SD4_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT7__SD4_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC2_BASE_ADDR}, + {USDHC4_BASE_ADDR}, +}; + +#define USDHC2_CD_GPIO IMX_GPIO_NR(1, 4) + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + break; + case USDHC4_BASE_ADDR: + ret = 1; /* eMMC/uSDHC4 is always present */ + break; + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ +#ifndef CONFIG_SPL_BUILD + int ret; + int i; + + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 SD2 + * mmc1 SD3 + * mmc2 eMMC + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + imx_iomux_v3_setup_multiple_pads( + usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + gpio_direction_input(USDHC2_CD_GPIO); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + break; + case 1: + imx_iomux_v3_setup_multiple_pads( + usdhc4_pads, ARRAY_SIZE(usdhc4_pads)); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) then supported by the board (%d)\n", + i + 1, CONFIG_SYS_FSL_USDHC_NUM); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; + } + + return 0; +#else + struct src *psrc = (struct src *)SRC_BASE_ADDR; + unsigned reg = readl(&psrc->sbmr1) >> 11; + + /* + * Upon reading BOOT_CFG register the following map is done: + * Bit 11 and 12 of BOOT_CFG register can determine the current + * mmc port + * 0x1 SD1 + * 0x2 SD2 + * 0x3 SD4 + */ + + switch (reg & 0x3) { + case 0x1: + imx_iomux_v3_setup_multiple_pads( + usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + usdhc_cfg[0].esdhc_base = USDHC2_BASE_ADDR; + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + gd->arch.sdhc_clk = usdhc_cfg[0].sdhc_clk; + break; + case 0x3: + imx_iomux_v3_setup_multiple_pads( + usdhc4_pads, ARRAY_SIZE(usdhc4_pads)); + usdhc_cfg[0].esdhc_base = USDHC4_BASE_ADDR; + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); + gd->arch.sdhc_clk = usdhc_cfg[0].sdhc_clk; + break; + } + + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +#endif + +} +#endif + + +/* + * Do not overwrite the console + * Use always serial for U-Boot console + */ +int overwrite_console(void) +{ + return 1; +} + +int board_eth_init(bd_t *bis) +{ + setup_iomux_enet(); + enable_enet_clk(1); + + return cpu_eth_init(bis); +} + +int board_early_init_f(void) +{ + + setup_iomux_uart(); + setup_spi(); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); + + return 0; +} + +int power_init_board(void) +{ + struct pmic *p; + int ret; + unsigned int reg; + + ret = power_pfuze100_init(I2C_PMIC); + if (ret) + return ret; + + p = pmic_get("PFUZE100"); + ret = pmic_probe(p); + if (ret) + return ret; + + pmic_reg_read(p, PFUZE100_DEVICEID, ®); + printf("PMIC: PFUZE100 ID=0x%02x\n", reg); + + /* Increase VGEN3 from 2.5 to 2.8V */ + pmic_reg_read(p, PFUZE100_VGEN3VOL, ®); + reg &= ~LDO_VOL_MASK; + reg |= LDOB_2_80V; + pmic_reg_write(p, PFUZE100_VGEN3VOL, reg); + + /* Increase VGEN5 from 2.8 to 3V */ + pmic_reg_read(p, PFUZE100_VGEN5VOL, ®); + reg &= ~LDO_VOL_MASK; + reg |= LDOB_3_00V; + pmic_reg_write(p, PFUZE100_VGEN5VOL, reg); + + /* Set SW1AB stanby volage to 0.975V */ + pmic_reg_read(p, PFUZE100_SW1ABSTBY, ®); + reg &= ~SW1x_STBY_MASK; + reg |= SW1x_0_975V; + pmic_reg_write(p, PFUZE100_SW1ABSTBY, reg); + + /* Set SW1AB/VDDARM step ramp up time from 16us to 4us/25mV */ + pmic_reg_read(p, PFUZE100_SW1ABCONF, ®); + reg &= ~SW1xCONF_DVSSPEED_MASK; + reg |= SW1xCONF_DVSSPEED_4US; + pmic_reg_write(p, PFUZE100_SW1ABCONF, reg); + + /* Set SW1C standby voltage to 0.975V */ + pmic_reg_read(p, PFUZE100_SW1CSTBY, ®); + reg &= ~SW1x_STBY_MASK; + reg |= SW1x_0_975V; + pmic_reg_write(p, PFUZE100_SW1CSTBY, reg); + + /* Set SW1C/VDDSOC step ramp up time from 16us to 4us/25mV */ + pmic_reg_read(p, PFUZE100_SW1CCONF, ®); + reg &= ~SW1xCONF_DVSSPEED_MASK; + reg |= SW1xCONF_DVSSPEED_4US; + pmic_reg_write(p, PFUZE100_SW1CCONF, reg); + + return 0; +} + +#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"sd2", MAKE_CFGVAL(0x40, 0x28, 0x00, 0x00)}, + /* 8 bit bus width */ + {"emmc", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + +int board_late_init(void) +{ +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + + setenv("board_name", BOARD_NAME); + return 0; +} + +int checkboard(void) +{ + puts("Board: "); + puts(BOARD_NAME "\n"); + + return 0; +} + +#ifdef CONFIG_SPL_BUILD +#include <spl.h> +#include <libfdt.h> + +const struct mx6dq_iomux_ddr_regs mx6_ddr_ioregs = { + .dram_sdclk_0 = 0x00020030, + .dram_sdclk_1 = 0x00020030, + .dram_cas = 0x00020030, + .dram_ras = 0x00020030, + .dram_reset = 0x00020030, + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + .dram_sdba2 = 0x00000000, + .dram_sdodt0 = 0x00003030, + .dram_sdodt1 = 0x00003030, + .dram_sdqs0 = 0x00000030, + .dram_sdqs1 = 0x00000030, + .dram_sdqs2 = 0x00000030, + .dram_sdqs3 = 0x00000030, + .dram_sdqs4 = 0x00000030, + .dram_sdqs5 = 0x00000030, + .dram_sdqs6 = 0x00000030, + .dram_sdqs7 = 0x00000030, + .dram_dqm0 = 0x00020030, + .dram_dqm1 = 0x00020030, + .dram_dqm2 = 0x00020030, + .dram_dqm3 = 0x00020030, + .dram_dqm4 = 0x00020030, + .dram_dqm5 = 0x00020030, + .dram_dqm6 = 0x00020030, + .dram_dqm7 = 0x00020030, +}; + +const struct mx6dq_iomux_grp_regs mx6_grp_ioregs = { + .grp_ddr_type = 0x000C0000, + .grp_ddrmode_ctl = 0x00020000, + .grp_ddrpke = 0x00000000, + .grp_addds = 0x00000030, + .grp_ctlds = 0x00000030, + .grp_ddrmode = 0x00020000, + .grp_b0ds = 0x00000030, + .grp_b1ds = 0x00000030, + .grp_b2ds = 0x00000030, + .grp_b3ds = 0x00000030, + .grp_b4ds = 0x00000030, + .grp_b5ds = 0x00000030, + .grp_b6ds = 0x00000030, + .grp_b7ds = 0x00000030, +}; + +const struct mx6_mmdc_calibration mx6_mmcd_calib = { + .p0_mpwldectrl0 = 0x001F001F, + .p0_mpwldectrl1 = 0x001F001F, + .p1_mpwldectrl0 = 0x00440044, + .p1_mpwldectrl1 = 0x00440044, + .p0_mpdgctrl0 = 0x434B0350, + .p0_mpdgctrl1 = 0x034C0359, + .p1_mpdgctrl0 = 0x434B0350, + .p1_mpdgctrl1 = 0x03650348, + .p0_mprddlctl = 0x4436383B, + .p1_mprddlctl = 0x39393341, + .p0_mpwrdlctl = 0x35373933, + .p1_mpwrdlctl = 0x48254A36, +}; + +/* MT41K128M16JT-125 */ +static struct mx6_ddr3_cfg mem_ddr = { + .mem_speed = 1600, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0x00FFF300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static void gpr_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* enable AXI cache for VDOA/VPU/IPU */ + writel(0xF00000CF, &iomux->gpr[4]); + /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); +} + +/* + * This section requires the differentiation between iMX6 Sabre boards, but + * for now, it will configure only for the mx6q variant. + */ +static void spl_dram_init(void) +{ + struct mx6_ddr_sysinfo sysinfo = { + /* width of data bus:0=16,1=32,2=64 */ + .dsize = 2, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, /* 32Gb per CS */ + /* single chip select */ + .ncs = 1, + .cs1_mirror = 0, + .rtt_wr = 1 /*DDR3_RTT_60_OHM*/, /* RTT_Wr = RZQ/4 */ + .rtt_nom = 1 /*DDR3_RTT_60_OHM*/, /* RTT_Nom = RZQ/4 */ + .walat = 1, /* Write additional latency */ + .ralat = 5, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ + .ddr_type = DDR_TYPE_DDR3, + }; + + mx6dq_dram_iocfg(64, &mx6_ddr_ioregs, &mx6_grp_ioregs); + mx6_dram_cfg(&sysinfo, &mx6_mmcd_calib, &mem_ddr); +} + +void board_init_f(ulong dummy) +{ + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + ccgr_init(); + gpr_init(); + + /* iomux and setup of i2c */ + board_early_init_f(); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} + +#endif diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig new file mode 100644 index 0000000..2ebeec0 --- /dev/null +++ b/configs/zc5202_defconfig @@ -0,0 +1,22 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_ZC5202=y +CONFIG_SPL=y +CONFIG_BOOTDELAY=3 +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_OF_LIBFDT=y diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig new file mode 100644 index 0000000..a52ae6f --- /dev/null +++ b/configs/zc5601_defconfig @@ -0,0 +1,22 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_ZC5601=y +CONFIG_SPL=y +CONFIG_BOOTDELAY=3 +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_OF_LIBFDT=y diff --git a/include/configs/el6x_common.h b/include/configs/el6x_common.h new file mode 100644 index 0000000..55ef612 --- /dev/null +++ b/include/configs/el6x_common.h @@ -0,0 +1,139 @@ +/* + * Copyright (C) Stefano Babic sbabic@denx.de + * + * Configuration settings for the E+L i.MX6Q DO82 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __EL6Q_COMMON_CONFIG_H +#define __EL6Q_COMMON_CONFIG_H + +#define CONFIG_BOARD_NAME EL6Q + +#include <config_distro_defaults.h> +#include "mx6_common.h" + +#define CONFIG_IMX_THERMAL + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT + +#define CONFIG_MXC_UART + +#ifdef CONFIG_SPL +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SYS_SPI_U_BOOT_OFFS (64 * 1024) +#define CONFIG_SPL_SPI_LOAD +#include "imx6_spl.h" +#endif + +/* MMC Configs */ +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +/* I2C config */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ +#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ +#define CONFIG_SYS_I2C_SPEED 100000 + +/* PMIC */ +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_PFUZE100 +#define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 + +/* Commands */ +#define CONFIG_MXC_SPI +#define CONFIG_SF_DEFAULT_BUS 3 +#define CONFIG_SF_DEFAULT_CS 0 +#define CONFIG_SF_DEFAULT_SPEED 20000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_MXC_UART_BASE UART2_BASE +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ + +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_BOOTZ +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOARD_NAME EL6Q + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +#define CONFIG_EXTRA_ENV_SETTINGS \ + "board="__stringify(CONFIG_BOARD_NAME)"\0" \ + "cma_size="__stringify(EL6Q_CMA_SIZE)"\0" \ + "chp_size="__stringify(EL6Q_COHERENT_POOL_SIZE)"\0" \ + "console=" CONFIG_CONSOLE_DEV "\0" \ + "fdtfile=undefined\0" \ + "fdt_high=0xffffffff\0" \ + "fdt_addr_r=0x18000000\0" \ + "fdt_addr=0x18000000\0" \ + "findfdt=setenv fdtfile " CONFIG_DEFAULT_FDT_FILE "\0" \ + "kernel_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ + "scriptaddr=" __stringify(CONFIG_LOADADDR) "\0" \ + "pxefile_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ + BOOTENV + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) \ + func(PXE, PXE, na) \ + func(DHCP, dhcp, na) + +#define CONFIG_BOOTCOMMAND \ + "run findfdt; " \ + "run distro_bootcmd" + +#include <config_distro_bootcmd.h> + +#define CONFIG_ARP_TIMEOUT 200UL + +#define CONFIG_CMD_MEMTEST + +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x10800000 +#define CONFIG_SYS_MEMTEST_SCRATCH 0x10800000 + +#define CONFIG_STACKSIZE (128 * 1024) + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE (8 * 1024) + +#define CONFIG_ENV_IS_IN_MMC + +#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_SYS_MMC_ENV_DEV 1 +#define CONFIG_SYS_MMC_ENV_PART 2 +#define CONFIG_ENV_OFFSET 0x0 +#endif + +#endif /* __EL6Q_COMMON_CONFIG_H */ diff --git a/include/configs/zc5202.h b/include/configs/zc5202.h new file mode 100644 index 0000000..073a42c --- /dev/null +++ b/include/configs/zc5202.h @@ -0,0 +1,37 @@ +/* + * Copyright (C) Stefano Babic sbabic@denx.de + * + * Configuration settings for the E+L i.MX6Q DO82 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __EL_ZC5202_H +#define __EL_ZC5202_H + +#define CONFIG_MXC_UART_BASE UART2_BASE +#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONFIG_MMCROOT "/dev/mmcblk0p2" + +#define CONFIG_DEFAULT_FDT_FILE "imx6q-zc5202.dtb" + +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ + +#include "el6x_common.h" + +/* Ethernet */ +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE MII100 +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0 +#define CONFIG_MV88E6352_SWITCH + +#define CONFIG_CMD_PCI +#define CONFIG_PCI +#define CONFIG_PCI_PNP +#define CONFIG_PCI_SCAN_SHOW +#define CONFIG_PCIE_IMX + +#endif /*__EL6Q_CONFIG_H */ diff --git a/include/configs/zc5601.h b/include/configs/zc5601.h new file mode 100644 index 0000000..28b9c6b --- /dev/null +++ b/include/configs/zc5601.h @@ -0,0 +1,33 @@ +/* + * Copyright (C) Stefano Babic sbabic@denx.de + * + * Configuration settings for the E+L i.MX6Q DO82 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __EL_ZC5601_H +#define __EL_ZC5601_H + + +#define CONFIG_MXC_UART_BASE UART2_BASE +#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONFIG_MMCROOT "/dev/mmcblk0p1" + +#define CONFIG_DEFAULT_FDT_FILE "imx6q-zc5601.dtb" + +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ + +#include "el6x_common.h" + +/* Ethernet */ +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0x10 +#define CONFIG_PHYLIB +#define CONFIG_FEC_FIXED_SPEED 1000 /* No autoneg, fix Gb */ + +#endif /*__EL6Q_CONFIG_H */
Stefano Babic
