[U-Boot] [PATCH] sunxi: Enable support for the eMMC found on the orangepi plus
This enables support for the eMMC found on the orangepi plus.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- configs/orangepi_plus_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index c4885f4..770bd98 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -4,6 +4,8 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_MMC0_CD_PIN="PF6" +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 # CONFIG_VIDEO is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set
Does CONFIG_MMC2_PINS also need to be set?
ChenYu
2.7.3
No there only is one pinmux option for MMC2 on H8, so there is no need to set this.
Regards,
Hans
Acked-by: Ian Campbell ijc@hellion.org.uk
Chen-Yu Tsai
Hans de Goede
Ian Campbell
