[U-Boot] [PATCH 1/3] cm4008: set gd->ram_size in dram_init
Leave dram_init_banksize to set up the bank info data. ram_size was previously uninitialized.
Signed-off-by: Yann Vernier yann.vernier@orsoc.se --- board/cm4008/cm4008.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/board/cm4008/cm4008.c b/board/cm4008/cm4008.c index ed493a8..557cd8e 100644 --- a/board/cm4008/cm4008.c +++ b/board/cm4008/cm4008.c @@ -97,8 +97,7 @@ int board_init (void)
int dram_init (void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->ram_size = PHYS_SDRAM_1_SIZE;
return (0); }
return (0);
The dram_init should look like this nowadays:
---8<--- int dram_init (void) { /* dram_init must store complete ramsize in gd->ram_size */ gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE); return 0; } --->8---
PHYS_SDRAM_1_SIZE is also a remnant from older days, please switch to CONFIG_SYS_SDRAM_SIZE. The get_ram_size() should check how many ram is really accesable (think of a board which may have more options for RAM, just insert the biggest possible option to CONFIG_SYS_SDRAM_SIZE).
Best regards
Andreas Bießmann
Leave dram_init_banksize to set up the bank info data. ram_size was previously uninitialized. Also, generalize lowlevel assembly to support more RAM options.
Signed-off-by: Yann Vernier yann.vernier@orsoc.se --- Changes for v2: - Update to use CONFIG_SYS_SDRAM_ constants - Update cm41xx also - Map SDRAM to match configuration --- arch/arm/cpu/arm920t/ks8695/lowlevel_init.S | 8 +++----- board/cm4008/cm4008.c | 5 +++-- board/cm41xx/cm41xx.c | 5 +++-- include/configs/cm4008.h | 5 ++--- include/configs/cm41xx.h | 5 ++--- 5 files changed, 13 insertions(+), 15 deletions(-)
diff --git a/arch/arm/cpu/arm920t/ks8695/lowlevel_init.S b/arch/arm/cpu/arm920t/ks8695/lowlevel_init.S index e9f1227..df13de6 100644 --- a/arch/arm/cpu/arm920t/ks8695/lowlevel_init.S +++ b/arch/arm/cpu/arm920t/ks8695/lowlevel_init.S @@ -131,11 +131,9 @@ highflash: * before relocating, we have to setup RAM timing */ ldr r1, =(KS8695_IO_BASE+KS8695_SDRAM_CTRL0) -#if (PHYS_SDRAM_1_SIZE == 0x02000000) - ldr r2, =0x7fc0000e /* 32MB */ -#else - ldr r2, =0x3fc0000e /* 16MB */ -#endif + /* 8 column address bits, 4 banks, 32 bits data width */ + ldr r2, =((CONFIG_SYS_SDRAM_BASE+CONFIG_SYS_SDRAM_SIZE-0x10000)<<(22-16) | \ + (CONFIG_SYS_SDRAM_BASE>>(16-12) | 0x00e)) str r2, [r1] /* configure sdram bank0 setup */ ldr r1, =(KS8695_IO_BASE+KS8695_SDRAM_CTRL1) mov r2, #0 diff --git a/board/cm4008/cm4008.c b/board/cm4008/cm4008.c index ed493a8..6c0da9a 100644 --- a/board/cm4008/cm4008.c +++ b/board/cm4008/cm4008.c @@ -97,8 +97,9 @@ int board_init (void)
int dram_init (void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE);
return (0); } diff --git a/board/cm41xx/cm41xx.c b/board/cm41xx/cm41xx.c index d9dff4e..6aef617 100644 --- a/board/cm41xx/cm41xx.c +++ b/board/cm41xx/cm41xx.c @@ -97,8 +97,9 @@ int board_init (void)
return (0); } diff --git a/include/configs/cm4008.h b/include/configs/cm4008.h index 408e918..58b0f4b 100644 --- a/include/configs/cm4008.h +++ b/include/configs/cm4008.h @@ -110,9 +110,8 @@ * Physical Memory Map */ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0x00000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x01000000 /* 16 MB */ -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_SDRAM_BASE 0x00000000 /* SDRAM Bank #1 */ +#define CONFIG_SYS_SDRAM_SIZE 0x01000000 /* 16 MB */
#define CONFIG_SYS_INIT_SP_ADDR 0x00020000 /* lowest 128k of RAM */
diff --git a/include/configs/cm41xx.h b/include/configs/cm41xx.h index d85a600..d29040c 100644 --- a/include/configs/cm41xx.h +++ b/include/configs/cm41xx.h @@ -110,9 +110,8 @@ * Physical Memory Map */ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0x00000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_SDRAM_BASE 0x00000000 /* SDRAM Bank #1 */ +#define CONFIG_SYS_SDRAM_SIZE 0x02000000 /* 32 MB */
Changes for v2:
-#else
-#endif
- /* 8 column address bits, 4 banks, 32 bits data width */
- ldr r2, =((CONFIG_SYS_SDRAM_BASE+CONFIG_SYS_SDRAM_SIZE-0x10000)<<(22-16) | \
ugh ... magic. Will it work for every possible setting? How about one setting CONFIG_SYS_SDRAM_BASE != 0x0? I the base address related to register content in any way?
Would be great to have a little documentation here why it is shifted that way, unfortunately I can not find a KS8695 spec in the net. Don't get me wrong it is ok to do so. I think it is way better than hard coding the values like before but would be great to understand why it is done that way.
Best regards
Andreas Bießmann
Andreas Bießmann
Yann Vernier
