[PATCH v3] board: ti: common: board_detect: Fix EEPROM offset read for 1-byte
EEPROM detection logic in ti_i2c_eeprom_get() involves reading the total size and the 1-byte size with an offset 1. The commit 9f393a2d7af8 ("board: ti: common: board_detect: Fix EEPROM read quirk for 2-byte") that attempts to fix this uses a wrong pointer to compare.
The value with one offset is read into offset_test, but the pointer used to match was still ep, resulting in an invalid comparison of the values. The intent is to identify bad 2-byte addressing eeproms that get stuck on the successive reads.
Fixes: 9f393a2d7af8 (board: ti: common: board_detect: Fix EEPROM read quirk for 2-byte) Signed-off-by: Prasanth Babu Mantena p-mantena@ti.com Tested-by: Matwey V. Kornilov matwey.kornilov@gmail.com --- v3 <--> v2: Improved and concise commit description.
v2 <--> v1: Fix inplace for the else condition of CONFIG_IS_ENABLED(DM_I2C). Improved commit message.
board/ti/common/board_detect.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/ti/common/board_detect.c b/board/ti/common/board_detect.c index 9a53884c98..869f7a47f8 100644 --- a/board/ti/common/board_detect.c +++ b/board/ti/common/board_detect.c @@ -128,7 +128,7 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr,
rc = dm_i2c_read(dev, 0x1, &offset_test, sizeof(offset_test));
- if (*((u32 *)ep) != (header & 0xFF)) + if (offset_test != ((header >> 8) & 0xFF)) one_byte_addressing = false;
/* Corrupted data??? */ @@ -180,7 +180,7 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr,
rc = i2c_read(dev_addr, 0x1, byte, &offset_test, sizeof(offset_test));
Hi Prasanth,
Reviewed-by: Neha Malcom Francis n-francis@ti.com
On 15:15-20231107, Neha Malcom Francis wrote:
Hi Prasanth,
diff --git a/board/ti/common/board_detect.c b/board/ti/common/board_detect.c index 9a53884c98..869f7a47f8 100644 --- a/board/ti/common/board_detect.c +++ b/board/ti/common/board_detect.c @@ -128,7 +128,7 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr, rc = dm_i2c_read(dev, 0x1, &offset_test, sizeof(offset_test));
- if (offset_test != ((header >> 8) & 0xFF)) one_byte_addressing = false; /* Corrupted data??? */
@@ -180,7 +180,7 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr, rc = i2c_read(dev_addr, 0x1, byte, &offset_test, sizeof(offset_test));
Can this patch be considered for merge considering no further comments.
Regards, Prasanth
-- Thanking You Neha Malcom Francis
Hi Prasanth,
Given the "fun" of the various beagle families I think I was still hoping for a tested-by on some of the corner cases they have.
Fixes: 9f393a2d7af8 (board: ti: common: board_detect: Fix EEPROM read quirk for 2-byte) Signed-off-by: Prasanth Babu Mantena p-mantena@ti.com Tested-by: Matwey V. Kornilov matwey.kornilov@gmail.com Reviewed-by: Neha Malcom Francis n-francis@ti.com
Neha Malcom Francis
Prasanth Mantena
