[PATCH] configs: socfpga: add kernel parameter for immediate reboot
Add Linux kernel line parameters for socfpga soc64 U-Boot. The "panic=-1" indicates the reset should occue immediately (without a delay).
Signed-off-by: Joyce Ooi joyce.ooi@intel.com --- include/configs/socfpga_soc64_common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 7237ec95e34..d51a532a929 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -79,7 +79,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * CONFIG_BOOTARGS goes into the environment value "bootargs". * Do note the value will override also the chosen node in FDT blob. */ -#define CONFIG_BOOTARGS "earlycon" +#define CONFIG_BOOTARGS "earlycon panic=-1" #define CONFIG_BOOTCOMMAND "run fatscript; run mmcload;run linux_qspi_enable;" \ "run mmcboot"
-----Original Message----- From: Ooi, Joyce joyce.ooi@intel.com Sent: Friday, August 7, 2020 11:52 AM To: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Tan, Ley Foon ley.foon.tan@intel.com; Miquel Raynal miquel.raynal@bootlin.com; Boris Brezillon bbrezillon@kernel.org; Marek Vasut marex@denx.de; Ashok Reddy Soma ashok.reddy.soma@xilinx.com; Hannes Schmelzer hannes.schmelzer@br-automation.com Cc: u-boot@lists.denx.de; Ooi, Joyce joyce.ooi@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com; See, Chin Liang chin.liang.see@intel.com; Nguyen, Dinh dinh.nguyen@intel.com Subject: [PATCH] configs: socfpga: add kernel parameter for immediate reboot
Typo "occue" -> "occur ".
Regards Ley Foon
Ooi, Joyce
Tan, Ley Foon
