[U-Boot-Users] Pb compiling u-boot
I'm trying to port linux on an arm versatile board, currently I'm trying to create a loadable image of a recent u-boot. I've downloaded the latest release of u-boot on the site (I use the latest gcc provided by arm) and launched the compilation but an error occurred: I join the exact logs in attached file. <<log_u-boot_failure.doc>> It seems like the makefile is not valid (The start.o is not compiled...)
Here is a final extract:
DCONFIG_ARM -D__ARM__ -march=armv4t -I.. -Bstatic -T /home/dupas/linux/sources_u-boot/u-boot-1.1.2/board/versatile/u-boot.lds -Ttext 0x01000000 hello_world.c -o hello_world /home/dupas/linux/tool-chain/bin/../lib/gcc/arm-none-linux-gnueabi/3.4.3 /../../../../arm-none-linux-gnueabi/bin/ld: cannot find cpu/arm926ejs/start.o collect2: ld returned 1 exit status make[1]: *** [hello_world] Erreur 1 make[1]: Leaving directory `/home/dupas/linux/sources_u-boot/u-boot-1.1.2/examples' make: *** [examples] Erreur 2 dupas@vlblnxs2:~/linux/sources_u-boot/u-boot-1.1.2$
Can anyone help me please? Greetings thomas
Dear Thomas,
in message 550E696EB903B74E84CF33CF8D64DFC206BA9B@vlbse301.eu.infineon.com you wrote:
Ummm... I disagree.
This attachment is unreadable. Never post prorpietary document formats, especially when it's just a waste of bandwith like here: you could have copy & pasted the text directly.
Attachment ignored.
It works fine for everybody else.
It would have helped if you had at least given the complete command.
This is why I think you did not use a recent version of U-Boot. You should use top-of-tree in CVS instead.
Maybe. But this requires you to provide enough information in a readable format (plain text only).
It's already ported and available in the mainline kernel, you don't need write any code.
Catalin Marinas
