[U-Boot] [PATCH] ata: ahci: enable bus mastering
When using the coreboot target CONFIG_DM_SCSI gets set to y. This has the effect that the current 'enable bus mastering' logic gets not compiled in. This change fixes ahci problems I am seeing on an Intel Apollolake device.
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- drivers/ata/ahci.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/ata/ahci.c b/drivers/ata/ahci.c index e3135bb75f..3f9348a8b3 100644 --- a/drivers/ata/ahci.c +++ b/drivers/ata/ahci.c @@ -1174,6 +1174,12 @@ int ahci_probe_scsi(struct udevice *ahci_dev, ulong base) int ahci_probe_scsi_pci(struct udevice *ahci_dev) { ulong base; + u16 cmd; + + /* Enable bus mastering. */ + dm_pci_read_config16(ahci_dev, PCI_COMMAND, &cmd); + cmd |= PCI_COMMAND_MASTER; + dm_pci_write_config16(ahci_dev, PCI_COMMAND, cmd);
base = (ulong)dm_pci_map_bar(ahci_dev, PCI_BASE_ADDRESS_5, PCI_REGION_MEM);
Hi Christian,
On Wed, 22 May 2019 at 02:40, Christian Gmeiner christian.gmeiner@gmail.com wrote:
Where is it missing? Is it because U-Boot is not scanning the PCI bus?
u16 cmd;
Please don't put . at the end.
See dm_pci_clrset_config16()
-- 2.21.0
Hi Christian,
On Thu, May 23, 2019 at 2:40 AM Simon Glass sjg@chromium.org wrote:
Hi Christian,
If this is the case, we should fix similar issue on other devices, not just only SATA.
Regards, Bin
Hi Bin,
Am Do., 23. Mai 2019 um 04:17 Uhr schrieb Bin Meng bmeng.cn@gmail.com:
Hi Christian,
Hi Christian,
In the ahci driver there is some bus master stuff - but not build with the coreboot configuration. See: https://git.denx.de/?p=u-boot.git;a=blob;f=drivers/ata/ahci.c;h=e3135bb75fdd...
Other drivers I am using on this platform are fine and do the bus master enable thing. - e1000 - xhci
Hi Simon,
Am Mi., 22. Mai 2019 um 20:40 Uhr schrieb Simon Glass sjg@chromium.org:
Hi Christian,
PCI bus scanning is all fine - but the driver does not enable bus mastering which results in:
=> scsi scan scanning bus for devices... ahci mmio_base=0xc4f4b000 ahci_host_init: start cap 0xe536ff01 port_map 0x3 n_ports 2 SATA link ok. Spinning up device on SATA port 0... Target spinup took 0 ms. ok. PORT_SCR_ERR 0x0 PORT_IRQ_STAT 0x0 SATA port 0 status: 0x123 SATA link 1 timeout. HOST_CTL 0x80000000 HOST_CTL 0x80000002 AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode flags: 64bit ncq pm clo only pmp pio slum part apst Enter start port: 0 Port 0 status: 123 cmd_slot = 7a88e800 cmd_tbl_dma = 7a88ea00 Exit start port 0 Can not start port 0 Enter ahci_device_data_io: for port 0 ahci_dcache_flush_range: flush dcache: [0x7a88e800, 0x7a88f100) ahci_dcache_flush_range: flush dcache: [0x7a875340, 0x7a875540) timeout exit! scsi_ahci: SCSI inquiry command failure. SCSI command 0x12 ret errno -5 Enter ahci_device_data_io: for port 1 No Link on port 1! scsi_ahci: SCSI inquiry command failure. SCSI command 0x12 ret errno -5 =>
u16 cmd;
Ok
Ahhh... sounds fine.
Bin Meng
Christian Gmeiner
