[U-Boot-Users] MPPC8560ADS and U-Boot 1.1.1 problems ?
Greetings,
We trying to install the latest version of U-Boot 1.1.1 on a MPPC 8560ADS development board, this initially does not boot (it actually sits inside in a permanent loop after the first couple of instructions). We have a Abatron debugger with a GDB/DDD interface but we don't seem to be able to step through the code to understand why it doesn't work.
We built U-Boot with the correct settings for the board, I believe that the dev board we're using is one of the support variants.
Are there any known problems with 1.1.1 and the 8560ADS boards ? Any help that any one could give would be extremely useful.
ADVthanxANCE Rob Farmer Senior Software Engineer Accton Technology Ltd UK
Tel: +44 (0) 8700 990400 Fax: +44 (0) 8700 990401 Cell: +44 (0) 7791 509347
This is actually an oxymoron. Either you use the latest version (top of CVS), or version 1.1.1 which is more than 2 months old - read: OLD.
As you can see with a simple look at the CHANGELOG file in CVS, a lot of changes have been added since: http://cvs.sourceforge.net/viewcvs.py/u-boot/u-boot/CHANGELOG?rev=HEAD
Try the current version (top of CVS).
Rob,
You should use the current top of CVS. However, I do not believe that it will work directly either. You must apply the patch that I submitted on 17-June-2004 called MPC85XXADS-20040617-diffs.tgz. That patch will complete the changes that were started and applied to the CVS tree a couple weeks earlier.
Please let me know how that goes.
Also, if you could, please let me know if you have a "Rev A" board or something else.
Thanks, jdl
Jon Loeliger
Rob Farmer
