[U-Boot] [PATCH 5/8] rockchip: dts: rk3328: support and enable xhci
Signed-off-by: Meng Dongyang daniel.meng@rock-chips.com --- arch/arm/dts/rk3328-evb.dts | 5 +++++ arch/arm/dts/rk3328.dtsi | 11 +++++++++++ 2 files changed, 16 insertions(+)
diff --git a/arch/arm/dts/rk3328-evb.dts b/arch/arm/dts/rk3328-evb.dts index 9920935..b807bc5 100644 --- a/arch/arm/dts/rk3328-evb.dts +++ b/arch/arm/dts/rk3328-evb.dts @@ -51,3 +51,8 @@ &usb_host0_ohci { status = "okay"; }; + +&usb_host0_xhci { + rockchip,vbus-gpio = <&gpio0 0 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; diff --git a/arch/arm/dts/rk3328.dtsi b/arch/arm/dts/rk3328.dtsi index e1219c3..f18cfc2 100644 --- a/arch/arm/dts/rk3328.dtsi +++ b/arch/arm/dts/rk3328.dtsi @@ -471,6 +471,17 @@ status = "disabled"; };
+ usb_host0_xhci: usb@ff600000 { + compatible = "rockchip,rk3328-xhci"; + reg = <0x0 0xff600000 0x0 0x100000>; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + snps,dis-enblslpm-quirk; + snps,phyif-utmi-bits = <16>; + snps,dis-u2-freeclk-exists-quirk; + snps,dis-u2-susphy-quirk; + status = "disabled"; + }; + gic: interrupt-controller@ffb70000 { compatible = "arm,gic-400"; #interrupt-cells = <3>;
On 17 May 2017 at 04:25, Meng Dongyang daniel.meng@rock-chips.com wrote:
Commit message?
Commit message?
Applied to u-boot-rockchip, thanks!
Meng Dongyang
sjg@google.com
