[U-Boot] [PATCH 1/2] omap3: CONFIG_REVISION_TAG ifdef check for get_board_rev
Despite being defined with __weak, this declaration of get_board_rev will conflict with the fallback one when ONFIG_REVISION_TAG is not defined.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/cpu/armv7/omap3/sys_info.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap3/sys_info.c b/arch/arm/cpu/armv7/omap3/sys_info.c index bbb65bb..ab60a03 100644 --- a/arch/arm/cpu/armv7/omap3/sys_info.c +++ b/arch/arm/cpu/armv7/omap3/sys_info.c @@ -196,10 +196,12 @@ u32 get_gpmc0_width(void) * get_board_rev() - setup to pass kernel board revision information * returns:(bit[0-3] sub version, higher bit[7-4] is higher version) *************************************************************************/ +#ifdef CONFIG_REVISION_TAG u32 __weak get_board_rev(void) { return 0x20; } +#endif
/******************************************************** * get_base(); get upper addr of current execution
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/cpu/armv7/am33xx/sys_info.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/cpu/armv7/am33xx/sys_info.c b/arch/arm/cpu/armv7/am33xx/sys_info.c index 781d83f..9d5a5d3 100644 --- a/arch/arm/cpu/armv7/am33xx/sys_info.c +++ b/arch/arm/cpu/armv7/am33xx/sys_info.c @@ -54,10 +54,12 @@ u32 get_cpu_type(void) * get_board_rev() - setup to pass kernel board revision information * returns: 0 for the ATAG REVISION tag value. */ +#ifdef CONFIG_REVISION_TAG u32 __weak get_board_rev(void) { return 0; } +#endif
/** * get_device_type(): tell if GP/HS/EMU/TST
There is no support for am33xx boards and Linux-kernel board-file kernels so lets just drop this weak default one and let boards that must have this for various reasons implement a real one.
That's right, we can actually simply remove the whole function. If that's okay, I'll just send another patch that replaces 2/2 and 1/2 should still be good for merging without another iteration.
Thanks for the review!
What about merging this patch? It's been more than a week since we last discussed it.
Thanks!
Signed-off-by: Paul Kocialkowski contact@paulk.fr Reviewed-by: Tom Rini trini@konsulko.com
Paul Kocialkowski
