[U-Boot] [PATCH] mpc83xx: fix pcie configuration space read/write
This patch fix a problem for the pcie enumeration when the mpc83xx pcie controller is connected with switch or we use both of the two pcie controller.
Signed-off-by: Baidu Boy liucai.lfn@gmail.com --- arch/powerpc/cpu/mpc83xx/pcie.c | 8 ++++++-- 1 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/pcie.c b/arch/powerpc/cpu/mpc83xx/pcie.c index 46a706d..2a200b8 100644 --- a/arch/powerpc/cpu/mpc83xx/pcie.c +++ b/arch/powerpc/cpu/mpc83xx/pcie.c @@ -46,13 +46,15 @@ static struct { #endif };
+static u8 pcie_index =0; + #ifdef CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES
static int mpc83xx_pcie_remap_cfg(struct pci_controller *hose, pci_dev_t dev) { int bus = PCI_BUS(dev) - hose->first_busno; immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - pex83xx_t *pex = &immr->pciexp[bus]; + pex83xx_t *pex = &immr->pciexp[pcie_index]; struct pex_outbound_window *out_win = &pex->bridge.pex_outbound_win[0]; u8 devfn = PCI_DEV(dev) << 3 | PCI_FUNC(dev); u32 dev_base = bus << 24 | devfn << 16; @@ -324,6 +326,8 @@ void mpc83xx_pcie_init(int num_buses, struct pci_region **reg) num_buses = ARRAY_SIZE(mpc83xx_pcie_cfg_space); }
- for (i = 0; i < num_buses; i++) + for (i = 0; i < num_buses; i++){ + pcie_index = i; mpc83xx_pcie_init_bus(i, reg[i]); + } }
Hello.
Signed-off-by: Baidu Boyliucai.lfn@gmail.com
- for (i = 0; i< num_buses; i++)
- for (i = 0; i< num_buses; i++){
There should be space between ) and {
mpc83xx_pcie_init_bus(i, reg[i]);pcie_index = i;
WBR, Sergei
Baidu Boy
Sergei Shtylyov
