[PATCH] clk: versal: Remove alt_ref_clk from clock sources
alt_ref_clk is applicable only for PS extended version. For PS base version there is no separate alt_ref_clk. It is tied with ref_clk, so remove it from driver.
Signed-off-by: Rajan Vaja rajan.vaja@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/clk/clk_versal.c | 8 +------- 1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/drivers/clk/clk_versal.c b/drivers/clk/clk_versal.c index 075a08380d84..6cdd3dd90510 100644 --- a/drivers/clk/clk_versal.c +++ b/drivers/clk/clk_versal.c @@ -114,7 +114,6 @@ struct versal_clk_priv { struct versal_clock *clk; };
-static ulong alt_ref_clk; static ulong pl_alt_ref_clk; static ulong ref_clk;
@@ -545,8 +544,7 @@ int soc_clk_dump(void)
printf("\n ****** VERSAL CLOCKS *****\n");
- printf("alt_ref_clk:%ld pl_alt_ref_clk:%ld ref_clk:%ld\n", - alt_ref_clk, pl_alt_ref_clk, ref_clk); + printf("pl_alt_ref_clk:%ld ref_clk:%ld\n", pl_alt_ref_clk, ref_clk); for (i = 0; i < clock_max_idx; i++) { debug("%s\n", clock[i].clk_name); ret = versal_get_clock_type(i, &type); @@ -664,10 +662,6 @@ static int versal_clk_probe(struct udevice *dev)
debug("%s\n", __func__);
- ret = versal_clock_get_freq_by_name("alt_ref_clk", dev, &alt_ref_clk); - if (ret < 0) - return -EINVAL; - ret = versal_clock_get_freq_by_name("pl_alt_ref_clk", dev, &pl_alt_ref_clk); if (ret < 0)
Ășt 12. 5. 2020 v 8:19 odesĂlatel Michal Simek michal.simek@xilinx.com napsal:
if (ret < 0)
return -EINVAL;
-- 2.26.2
Applied. M
Michal Simek
Michal Simek
